01-Fundamentals
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E5208P03 E5215P01 R5215P01)-6W10201-Fundamentals
11-License management
11-License management 616.62 KB
Managing licenses
Overview
License-based features require a license to run on your device. To use a license-based feature, you must purchase a license or obtain a free trial license.
License types
The following types of licenses are available depending on validity period:
·     Permanent—A permanent license is always valid and never expires.
·     Days restricted—A license valid for a limited period in days, for example, 30 days.
Trial licenses are typically days restricted.
The following types of licenses are available depending on locking method:
·     Device locked—A license can be installed only on the DID-specific device. The license takes effect on any MPU in the device even after an MPU replacement. The device supports this locking method.
·     MPU locked—A license can be installed only on the DID-specific MPU. The license takes effect on the MPU even after the MPU is moved to a different device.
License pool
The following matrix shows hardware compatibility with license pool:
Hardware series
Model
License pool compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
No
WX2500H series
WX2510H
WX2540H
WX2560H
No
WX3000H series
WX3010H
WX3010H-L
WX3010H-X
WX3024H
WX3024H-L
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
Yes
WX5500E series
WX5510E
WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
Access controller modules
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20
LSQM1WCMX40
LSUM1WCME0
LSUM1WCMX20RT
LSUM1WCMX40RT
Yes
Understanding the license pool
An IRF fabric provides the license pool feature when the fabric meets the following requirements:
·     Member ACs are of the same model.
·     The ACs form the N + 1 or N + M backup mode.
·     Licenses are installed on the master ACs.
The license pool enables backup ACs to use the licenses of a master AC that goes down for a maximum of 30 days. In the N + 1 or N + M backup mode, you need to purchase licenses only for the mater ACs, which saves customer investment. For example, in a 3 + 1 backup structure, you need to purchase and install licenses only for the three mater ACs. When a master AC goes down, the backup AC takes over and uses the licenses of the master AC to provide services.
The master AC can share only licenses that are registered by selecting WLAN_H3C WLAN AC V7 from the Product category dropdown list during the registration procedure.
Calculating the total number of licensed APs in a license pool
The license pool capacity determines the number of APs that can be connected to the ACs. The number of APs allowed in the license pool are affected by the following factors:
·     Number of member devices supported in an IRF fabric. For information about hardware compatibility for IRF, see Table 1.
·     Number of licensed APs supported by each IRF member device in the IRF fabric.
·     The way each IRF member device licenses features.
¡     By activation files
¡     By activation keys.
Table 1 Hardware compatibility for IRF
Hardware series
Model
IRF compatibility
Maximum number of IRF member devices
WX1800H series
WX1804H
WX1810H
WX1820H
No
N/A
WX2500H series
WX2510H
WX2540H
WX2560H
No
N/A
WX3000H series
WX3010H
WX3010H-L
WX3010H-X
WX3024H
WX3024H-L
No
N/A
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
Yes
2
WX5500E series
WX5510E
WX5540E
Yes
2
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
4
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20
LSQM1WCMX40
LSUM1WCME0
LSUM1WCMX20RT
LSUM1WCMX40RT
Yes
2:
·     LSUM1WCME0
·     EWPXM1WCME0
·     LSQM1WCMX20
·     LSUM1WCMX20RT
4:
·     LSQM1WCMX40
·     LSUM1WCMX40RT
·     EWPXM2WCMD0F
·     EWPXM1MAC0F
The following describes the calculation of the total number of licensed APs in a license pool:
The total number of licensed APs = the minimum number of APs licensed through activation keys + the sum of APs licensed through activation files.
·     For example, ACs A, B, C, D form an IRF fabric. A and B support activation keys and C and D support activation files. The licensed number of APs on the ACs A and B are a and b, respectively. The value a is less than b. The licensed number of APs on the ACs C and D are c and d, respectively.
The total number of licensed APs in the license pool = min(a,b) + sum(c,d) = a + c + d.
·     For example, ACs A, B, C, D form an IRF fabric. All the ACs support only activation files. The number of licensed APs on the ACs A, B, C, and D are a, b, c, and d, respectively.
The total number of licensed APs in the license pool = sum(a,b,c,d) = a + b + c + d.
Compatibility information
Feature and hardware compatibility
The following matrix shows hardware compatibility with license management:
Hardware series
Model
License management compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
No
WX2500H series
WX2510H
WX2540H
WX2560H
Yes
WX3000H series
WX3010H
WX3010H-L
WX3010H-X
WX3024H
WX3024H-L
Yes
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
Yes
WX5500E series
WX5510E
WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
EWPXM1MAC0F
EWPXM1WCME0
EWPXM2WCMD0F
LSQM1WCMX20
LSQM1WCMX40
LSUM1WCME0
LSUM1WCMX20RT
LSUM1WCMX40RT
Yes
You can install an activation file or activation key on the device to license a feature. The following matrix shows hardware compatibility with the activation file licensing and activation key licensing:
Hardware series
Model
Activation file licensing compatibility
Activation key licensing compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
No
No
WX2500H series
WX2510H
WX2540H
WX2560H
Yes
No
WX3000H series
WX3010H
WX3010H-L
WX3010H-X
WX3024H
WX3024H-L
Yes
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
Yes
No
WX5500E series
WX5510E
WX5540E
Yes
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
No
EWPXM1MAC0F
Yes
No
EWPXM1WCME0
Yes
Yes
EWPXM2WCMD0F
Yes
No
LSQM1WCMX20
Yes
No
LSQM1WCMX40
Yes
No
LSUM1WCME0
Yes
Yes
LSUM1WCMX20RT
Yes
No
LSUM1WCMX40RT
Yes
No
Command and hardware compatibility
WX2500H series and WX3000H series access controllers do not support the slot keyword or the slot-number argument.
General restrictions and guidelines
When you manage licenses, follow the general restrictions and guidelines:
·     Make sure you have purchased an upgrade license for add-on nodes, add-on features, or time extension.
·     Use the display license feature command to identify license-based features and their licensing information.
·     After you execute the display license command, it will take certain time for the device to output detailed license information depending on the device load.
·     Make sure no one else is performing license management tasks on the device you are working with.
·     When installing a license, the system also searches the storage media for a matching feature package. When it finds a matching package, it stops searching and installs the package.
·     When uninstalling a license, the system checks whether the feature package for the license is running. If it is running, the system uninstalls the package automatically.
·     If you cannot obtain or re-register the activation file due to problems such as operating system and browser errors, contact H3C Support.
Licenses for different device types
When you register and install licenses, follow the restrictions and guidelines:
·     License registration requires a license key, hardware SN, and DID. This information is device specific. A registered license takes effect on the entire device.
·     For a license-based feature to run correctly on an IRF fabric:
¡     Install one license for the feature on each member in the fabric. The license takes effect on each member device, and it is effective even after the member device joins another IRF fabric.
¡     Make sure the licenses installed on the members are the same.
License file safety
When you manage licenses, follow these restrictions and guidelines for license file safety:
·     Save and back up the obtained activation file or activation key in case of loss.
·     If you use FTP to transfer the .id file and the activation file, use the Binary mode.
·     Do not open and edit the .id file or activation file to avoid file corruption.
·     Do not modify the name of the .id file or activation file to avoid licensing error.
·     Do not delete or move files in the flash:/license directory on a device. The license management feature uses this directory for license management. An incorrect file operation can cause problems. For example, if you delete an activation file that is usable or in use, the related feature will not function correctly. If a file is missing or corrupted, copy the activation file to the directory to recover the license. If the state of the recovered license is In use, but not all licensed features can function, reboot the device. To verify the license state, use the display license command.
Licensing procedure summary
Tasks at a glance
Remarks
Registering licenses:
·     Registering licenses for the first time—Registers a license for a device that has never been activated.
·     Registering upgrade licenses—Registers a license for add-on nodes, add-on features, or time extension.
H3C website provides the license registration function.
Activating licenses
N/A
Transferring a license
N/A
Compressing the license storage
N/A
Figure 1 describes the license registration and activation procedure.
Figure 1 Licensing procedure summary
1.     Visit the H3C website at www.h3c.com.hk. Select Technical Support > Product Licensing > Register the First Time.
Figure 2 Registering a license for the first time
2.     Perform either of the following tasks depending on the licensing method:
¡     Activation file licensing—Select WLAN_H3C WLAN AC V7 from the Product category dropdown list, and click Submit.
Figure 3 Selecting a product category for activation file licensing
¡     Activation key licensing—Select WLAN_H3C WLAN Acess Controller from the Product category dropdown list, and click Submit.
Figure 4 Selecting a product category for activation key licensing
If you do not know the product category, enter the license key in the text box, and click Submit. The product category is automatically displayed.
3.     Enter the license, device, and contact information, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
Figure 5 Entering the information for activation file licensing
Figure 6 Entering the information for activation key licensing
Table 2 Field description
Item
Remarks
License key
Enter the license key provided on the paper license.
Required.
H3C device S/N
Enter the device serial number, a string of 20 characters.
You can use the display license device-id command on the device to display the device serial number.
Required.
Device information file
Upload the device DID file.
You can use the display license device-id command on the device to display the file path and use FTP or TFTP to download the DID file to the device.
Required.
Available only for activation file licensing.
CHECK_SUM
Enter the checksum for verifying the device serial number. It is 8 bytes long.
You can use the display license device-id command on the device to display the checksum value.
Required.
Available only for activation key licensing.
Customer company/organization
Enter the name of the company or organization that uses the device.
Required.
Company/organization
Enter your company or organization name.
Required.
First name
Enter your first name.
Required.
Last name
Enter your last name.
Optional.
Phone number
Enter your phone number.
Required.
Email address
Enter your email address.
H3C will send a copy of the activation file or key to your email box in addition to providing a link to the activation file on the registration result page.
Required.
Zip code
Enter the zip code of your region.
Optional.
Address
Enter your address.
Optional.
Project name
Enter the name of the project that uses the device.
Optional.
Verify code
Enter the code literally as is displayed on the image to the right of the text box.
Required.
4.     Perform either of the following tasks depending on the licensing method:
¡     Activation file licensing—When the registration success message appears, click the .lic link to save the activation file. Unzip the file and follow the procedures described in "Installing an activation file" to activate the license on your device.
Figure 7 Registration success for activation file licensing
¡     Activation key licensing—Confirm the activation operation at the system prompt. Then, the operation success page appears as shown in Figure 8. The page displays the activation key. Follow the procedures described in "Installing an activation key" to activate the license on your device.
Figure 8 Registration success for activation key licensing
1.     Visit the H3C website at www.h3c.com.hk, and select Technical Support > Product Licensing > Register Upgrade Licenses.
Figure 9 Registering an upgrade license
¡     Activation file licensing—Select WLAN_H3C WLAN AC V7 from the Product category dropdown list.
Figure 10 Selecting a product category for activation file licensing
¡     Activation key licensing—Select WLAN_H3C WLAN Access Controller from the Product category dropdown list.
Figure 11 Selecting a product category for activation key licensing
3.     Enter the device information and click Submit.
Figure 12 Entering the device information for activation file licensing
Figure 13 Entering the device information for activation key licensing
Table 3 Field description
Item
Remarks
H3C device S/N
You can use the display license device-id command to display the device serial number.
Required.
You can use the display license device-id command to display the file path and use FTP or TFTP to download the DID file to the device.
Required.
CHECK_SUM
Required.
4.     On the page that appears, enter the license, and contact information, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
Figure 14 Entering the information for license upgrade (activation file licensing)
Figure 15 Entering the information for license upgrade (activation key licensing)
Table 4 Configuration items
Item
Remarks
License key
Required.
Required.
Required.
First name
Required.
Last name
Optional.
Phone number
Required.
Email address
Required.
Zip code
Optional.
Address
Enter your address.
Optional.
Project name
Optional.
Verify code
Required.
5.     Perform either of the following tasks depending on the licensing method:
Figure 16 Registration success activation file licensing
¡     Activation key licensing—Confirm the activation operation at the system prompt. Then, the operation success page appears as shown in Figure 17. The page displays the activation key. Follow the procedures described in "Installing an activation key" to activate the license on your device.
Figure 17 Registration success for activation key licensing
Activating licenses
Step
1.     Upload the activation file to the storage media of the device through FTP or TFTP.
N/A
2.     Enter system view.
3.     Install the activation file.
license activation-file install file-name slot slot-number
Step
2.     Install the activation key.
license activation-key install activation-key-string slot slot-number
IMPORTANT
IMPORTANT:
License transfer is available only when activation file licensing is used.
You can transfer a license from one device to another if its activation file has not expired. If the activation file has expired, the license is not transferrable.
To transfer a license:
Step
Remarks
1.     Enter system view on the source device.
N/A
2.     Uninstall an activation file.
license activation-file uninstall file-name slot slot-number
When an activation file is uninstalled, the system creates an Uninstall file. This file is required when you register the license for the target device.
The uninstallation action does not delete license data from the license storage area. To free storage space, you must compress the license storage (see "Compressing the license storage").
3.     Obtain the Uninstall key of the source device.
display license
N/A
4.     Use the Uninstall key to uninstall the license from the source device on the H3C website.
N/A
N/A
5.     Access the target device and display the SN string and the DID's .id file path.
N/A
6.     Use FTP or TFTP to transfer the .id file to the PC.
N/A
N/A
7.     Access http://www.h3c.com.hk/Technical_Support___Documents/Product_Licensing/, and use the target device's SN and DID information and the source device's Uninstall key to generate a new activation file.
N/A
See "Registering licenses."
8.     Download the new activation file to the target device.
N/A
N/A
9.     Install the new activation file on the target device.
N/A
See "Activating licenses."
CAUTION:
The DID changes each time the license storage is compressed. Before performing a compression, make sure all activation files generated based on the old DID have been installed. They cannot be installed after the compression.
If the license storage area is not sufficient for installing new licenses, compress the license storage. This action deletes expired licenses and uninstalled licenses.
To compress the license storage:
Step
2.     Compress the license storage.
license compress slot slot-number
Displaying and maintaining licenses
Display the SN and DID of the device.
display license device-id slot slot-number
Display detailed license information.
display license [ activation-file | activation-key ] slot slot-number
Display brief feature license information.
