06-Layer 3 - IP Services
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10206-Layer 3 - IP Services
05-NAT commands
05-NAT commands 273.07 KB
NAT commands
The following matrix shows the feature and hardware compatibility:
Hardware series
Model
NAT compatibility
WX1800H series
WX1804H
WX1810H
WX1820H
Yes
WX2500H series
WX2510H
WX2540H
WX2560H
Yes
WX3000H series
WX3010H
WX3010H-L
WX3010H-X
WX3024H
WX3024H-L
Yes:
·     WX3010H
·     WX3010H-X
·     WX3024H
No:
·     WX3010H-L
·     WX3024H-L
WX3500H series
WX3508H
WX3510H
WX3520H
WX3540H
Yes
WX5500E series
WX5510E
WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
The WX1800H series, WX2500H series, and WX3000H series access controllers do not support the slot keyword or the slot-number argument.
address
Use address to add an address range to a NAT address group.
Use undo address to remove an address range from a NAT address group.
address start-address end-address
undo address start-address end-address
No address range exists.
NAT address group view
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, the address range has only one IP address.
A NAT address group is a set of address ranges. The source address in a packet destined for an external network is translated into an address in one of the group ranges.
Each address range can contain a maximum of 65535 addresses.
If you add multiple address ranges, make sure they do not overlap.
# Add two group ranges to an address group.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
nat address-group
block-size
Use block-size to set the port block size.
Use undo block-size to restore the default.
block-size block-size
undo block-size
The port block size is 256.
NAT port block group view
block-size: Sets the number of ports for a port block. The value range for this argument is 1 to 65535.
When you set a port block size, make sure the port block size is not larger than the number of ports in the port range.
# Set the port block size to 1024 for port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] block-size 1024
display nat alg
Use display nat alg to display the NAT with ALG status for all supported protocols.
display nat alg
# Display the NAT with ALG status for all supported protocols.
<Sysname> display nat alg
NAT ALG:
  DNS        : Enabled
  FTP        : Disabled
  H323       : Disabled
  ICMP-ERROR : Disabled
  ILS        : Disabled
  MGCP       : Disabled
  NBT        : Disabled
  PPTP       : Disabled
  RTSP       : Disabled
  RSH        : Disabled
  SCCP       : Disabled
  SIP        : Disabled
  SQLNET     : Disabled
  TFTP       : Disabled
  XDMCP      : Disabled
display nat all
display nat all
Use display nat all to display all NAT configuration information.
display nat all
# Display all NAT configuration information.
<Sysname> display nat all
NAT address group information:
  Totally 3 NAT address groups.
  Address group 1:
    Port range: 1-65535
    Address information:
      Start address         End address
      202.110.10.10         202.110.10.15
  Address group 2:
    Port range: 10001-65535
    Port block size: 500
    Extended block number: 1
      202.110.10.60         202.110.10.65
  Address group 3:
    Port range: 1-65535
NAT server group information:
  Totally 3 NAT server groups.
  Group Number        Inside IP             Port        Weight
  1                   192.168.0.26          23          100
                      192.168.0.27          23          500
  2                   ---                   ---         ---
  3                   192.168.0.26          69          100
NAT inbound information:
  Totally 1 NAT inbound rules.
  Interface: Vlan-interface20
    ACL: 2038
   Address group ID: 2
   Add route: Y         NO-PAT:Y         Reversible: N
    Rule name: a
    Priority: 1000
    Config status: Active
NAT outbound information:
  Totally 2 NAT outbound rules.
  Interface: Vlan-interface10
    ACL: 2036
    Address group ID: 1
    Port-preserved: Y    NO-PAT: N         Reversible: N
    Rule name: b
    Priority: 22
    Config status: Inactive
    Reasons for inactive status:
      The following items don't exist or aren't effective: address group, and ACL.
    ACL: 2037
    Address group ID: 1
    Port-preserved: N    NO-PAT: Y         Reversible: Y
    Rule name: c
    Priority: 100
      The following items don't exist or aren't effective: ACL.
NAT internal server information:
  Totally 5 internal servers.
  Interface: Vlan-interface30
    Global ACL    : 2000
    Local IP/port : 192.168.10.1/23
    Rule name     : cdefgab
    Priority      : 1000
    Config status : Active
  Interface: Vlan-interface40
    Protocol: 255(Reserved)
    Global IP/port: 50.1.1.100/---
    Local IP/port : 192.168.10.150/---
    ACL           : 3000
    Rule name     : red
    Config status : Inactive
  Interface: Vlan-interface50
    Protocol: 17(UDP)
    Global IP/port: 50.1.1.2/23
    Local IP/port : server group 1
                    1.1.1.1/21            (Connections: 10)
                    192.168.100.200/80    (Connections: 20)
Static NAT mappings:
  Totally 2 inbound static NAT mappings.
  Net-to-net:
    Global IP    : 2.2.2.1 – 2.2.2.255
    Local IP     : 1.1.1.0
    Netmask      : 255.255.255.0
    ACL          : 3000
    Reversible   : Y
    Rule name    : green
    Priority     : 4
  IP-to-IP:
    Global IP    : 5.5.5.5
    Local IP     : 4.4.4.4
    ACL          : 2001
    Reversible   : Y
    Rule name    : blue
    Priority     : 4
  Totally 2 outbound static NAT mappings.
  Net-to-net:
    Local IP     : 1.1.1.1 - 1.1.1.255
    Global IP    : 2.2.2.0
    ACL          : 3000
    Reversible   : Y
    Rule name    : yellow
    Priority     : 5
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    ACL:         : 2001
    Reversible   : Y
    Rule name    : pink
    Priority     : 6
Interfaces enabled with static NAT:
  Totally 2 interfaces enabled with static NAT.
NAT DNS mappings:
  Totally 2 NAT DNS mappings.
  Domain name  : www.server.com
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Domain name  : www.service.com
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
    The following items don't exist or aren't effective: interface IP address.
NAT logging:
  Log enable          : Enabled(ACL 2000)
  Flow-begin          : Disabled
  Flow-end            : Disabled
  Flow-active         : Enabled(10 minutes)
  Port-block-assign   : Disabled
  Port-block-withdraw : Disabled
  Alarm               : Disabled
NAT mapping behavior:
  Mapping mode : Endpoint-Independent
  ACL          : 2050
NAT ALG:
  DNS        : Enabled
  FTP        : Disabled
  H323       : Enabled
  ICMP-ERROR : Enabled
  ILS        : Enabled
  MGCP       : Enabled
  NBT        : Enabled
  PPTP       : Enabled
  RSH        : Enabled
  RTSP       : Enabled
  SCCP       : Enabled
  SIP        : Disabled
  SQLNET     : Enabled
  TFTP       : Enabled
  XDMCP      : Enabled
NAT port block group information:
  Totally 2 NAT port block groups.
  Port block group 1:
    Port range: 1-65535
    Block size: 256
    Local IP address information:
      Start address        End address          VPN instance
      172.16.1.1           172.16.1.254         ---
      192.168.1.1          192.168.1.254        ---
      192.168.3.1          192.168.3.254        ---
    Global IP pool information:
      201.1.1.1            201.1.1.10
      201.1.1.21           201.1.1.25
  Port block group 2:
    Port range: 10001-30000
    Block size: 500
      10.1.1.1             10.1.10.255          ---
      202.10.10.101        202.10.10.120
NAT outbound port block group information:
  Totally 2 outbound port block group items.
    Port block group: 2
    Rule name       : red
    Priority        : 4
    Port block group: 10
    Rule name       : tigger
    Priority        : 6
      The following items don't exist or aren't effective: port block group.
The output shows all NAT configuration information. Table 1 describes only the fields for the output of the nat mapping-behavior and nat alg commands.
Information about the NAT address group. See Table 2 for output description.
Information about the internal server group. See Table 14 for output description.
Inbound dynamic NAT configuration. See Table 5 for output description.
Outbound dynamic NAT configuration. See Table 8 for output description.
NAT Server configuration. See Table 13 for output description.
Static NAT mappings
Static NAT mappings. See Table 16 for output description.
NAT DNS mappings
NAT with DNS mappings. See Table 3 for output description.
NAT logging
NAT logging configuration. See Table 6 for output description.
Mapping behavior mode of PAT: Endpoint-Independent or Address and Port-Dependent.
ACL
ACL number or name. If no ACL is specified for NAT, this field displays hyphens (---).
Rule name
Name of the NAT rule.
Priority
Priority of the NAT rule.
Config status
Status of NAT mapping behavior configuration: Active or Inactive.
Reasons why the NAT mapping behavior configuration does not take effect. This field is available when the Config status is Inactive.
NAT ALG
NAT with ALG configuration for different protocols.
Configuration information about NAT port block groups. See Table 11 for output description.
Information about port block group application. See Table 9 for output description.
display nat address-group
Use display nat address-group to display NAT address group information.
display nat address-group [ group-number ]
group-number: Specifies the ID of a NAT address group. The value range for this argument is 0 to 65535. If you do not specify the group-number argument, this command displays information about all NAT address groups.
# Display information about all NAT address groups.
<Sysname> display nat address-group
  Totally 5 NAT address groups.
  Address group 1:
    Port range: 1-65535
  Address group 2:
    Port range: 1-65535
      202.110.10.20         202.110.10.25
      202.110.10.30         202.110.10.35
  Address group 3:
    Port range: 1024-65535
      202.110.10.40         202.110.10.50
  Address group 4:
  Address group 6:
    Port range: 1-65535
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
  Address group 1:
    Port range: 1-65535
Address group
ID of the NAT address group.
Port range
Port range for public IP addresses.
Block size
Number of ports in a port block. This field is not displayed if the port block size is not set.
Number of extended port blocks. This field is not displayed if the number of extended port blocks is not set.
Address information
Information about the public IP addresses in the address group.
Start address
Start IP address of an address range. If you do not specify a start address for the range, this field displays hyphens (---).
End address
End IP address of an address range. If you do not specify an end address for the range, this field displays hyphens (---).
nat address-group
display nat dns-map
Use display nat dns-map to display NAT with DNS mapping configuration.
display nat dns-map
# Display NAT with DNS mapping configuration.
<Sysname> display nat dns-map
NAT DNS mapping information:
  Global IP    : 6.6.6.6
  Global port  : 23
  Protocol     : TCP(6)
  Global IP    : ---
  Global port  : 12
  Protocol     : TCP(6)
Information about NAT with DNS mappings.
Domain-name
Domain name of the internal server.
Global IP
Public IP address of the internal server.
·     If Easy IP is configured, this field displays the IP address of the specified interface.
·     If you do not specify a public IP address, this field displays hyphens (---).
Global port
Public port number of the internal server.
Protocol
Protocol type and number of the internal server.
Config status
Status of the DNS mapping configuration: Active or Inactive.
Reasons why the DNS mapping configuration does not take effect. This field is available when the Config status is Inactive.
nat dns-map
display nat eim
Use display nat eim to display information about NAT Endpoint-Independent Mapping (EIM) entries.
display nat eim [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays EIM entry information for all member devices.
A NAT device with PAT EIM configured performs the following tasks:
1.     Creates a NAT session entry.
2.     Creates an EIM entry for recording the mapping between a private address/port and a public address/port.
The EIM entry ensures the following:
·     The same EIM entry applies to subsequent connections originating from the same source IP and port.
·     The EIM entries allow reverse translation for connections initiated by external hosts to internal hosts.
# Display information about NAT EIM entries for IRF member device 1.
<Sysname> display nat eim slot 1
Slot 1:
Local  IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Protocol: TCP(6)
Local  IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
Local IP/port
Private IP address and port number.
Global IP/port
Public IP address and port number.
Protocol
Protocol type and number.
Total entries found
Total number of EIM entries.
·     nat mapping-behavior
·     nat outbound
display nat inbound
Use display nat inbound to display information about inbound dynamic NAT.
display nat inbound
# Display information about inbound dynamic NAT.
<Sysname> display nat inbound
  Totally 2 NAT inbound rules.
    ACL: 2038
    Address group ID: 2      Address group name: b
    Add route: Y    NO-PAT: Y         Reversible: N
    Rule name: abcd
    Priority: 1000
    ACL: 2037
    Address group ID: 1      Address group name: a
    Rule name: eif
    Priority: 1000
Table 5 Command output
Information about inbound dynamic NAT.
Interface where inbound dynamic NAT is configured.
ACL
ACL number or name.
Address group
NAT address group used by inbound dynamic NAT rule.
Add route
Whether to add a route when a packet matches the inbound dynamic NAT rule.
NO-PAT
Whether NO-PAT or PAT is used:
·     Y—NO-PAT is used.
·     N—PAT is used.
Reversible
Whether reverse address translation is allowed.
Rule name
Priority
Config status
Status of the inbound dynamic NAT configuration: Active or Inactive.
Reasons why the inbound dynamic NAT configuration does not take effect. This field is available when the Config status is Inactive.
nat inbound
display nat log
Use display nat log to display NAT logging configuration.
display nat log
# Display NAT logging configuration.
<Sysname> display nat log
NAT logging:
  Flow-end            : Disabled
  Alarm               : Disabled
Table 6 Command output
NAT logging
Log enable
Whether NAT logging is enabled.
If an ACL is specified for NAT logging, this field also displays the ACL number or name.
Flow-begin
Whether logging is enabled for NAT session establishment events.
Flow-end
Whether logging is enabled for NAT session removal events.
Flow-active
Whether logging is enabled for active NAT flows. If it is, this field also displays the interval in minutes at which active flow logging is generated.
Port-block-assign
Whether logging is enabled for NAT444 port block assignment.
Port-block-withdraw
Whether logging is enabled for NAT444 port block withdrawal.
Alarm
Whether logging is enabled for NAT444 alarms.
·     nat log enable
·     nat log flow-active
·     nat log flow-begin
display nat no-pat
Use display nat no-pat command to display information about NAT NO-PAT entries.
display nat no-pat [ slot slot-number ]
Default user roles
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NO-PAT entry information for all member devices.
If a NAT device has a NO-PAT translation method configured, the device creates the following items:
·     A NAT session entry.
·     A NO-PAT entry for recording the mapping between a private address and a public address.
A NO-PAT entry can also be created during the ALG process for NAT.
The NO-PAT entry ensures the following:
·     The same entry applies to subsequent connections originating from the same source IP address.
·     The NO-PAT entries allow reverse translation for connections initiated by external hosts to internal hosts.
Outbound and inbound NO-PAT address translations create their own NO-PAT tables. These two types of tables are displayed separately.
# Display information about NO-PAT entries.
<Sysname> display nat no-pat
Slot 1:
Global  IP: 200.100.1.100
Local   IP: 192.168.100.100
Reversible: N
Type      : Inbound
Local   IP: 192.168.100.200
Global  IP: 200.100.1.200
Reversible: Y
Type      : Outbound
Table 7 Command output
Local IP
Private IP address.
Global IP
Public IP address.
Reversible
Type of the NO-PAT entry:
·     Inbound—NO-PAT entries are created during inbound dynamic NAT.
·     Outbound—NO-PAT entries are created during outbound dynamic NAT.
Total entries found
Total number of NO-PAT entries.
·     nat inbound
·     nat outbound
display nat outbound
Use display nat outbound to display information about outbound dynamic NAT.
# Display information about outbound dynamic NAT.
<Sysname> display nat outbound
    ACL: 2036
    Rule name: abcd
    Priority: 1000
    ACL: 2037
    Address group ID: ---
    Rule name: abcd
    Priority: 1000
Table 8 Command output
Information about outbound dynamic NAT.
Interface where outbound dynamic NAT is configured.
ACL
IPv4 ACL number or name. If no IPv4 ACL is specified for outbound dynamic NAT, this field displays hyphens (---).
Address group
Address group used by inbound dynamic NAT. If no address group is specified for address translation, the field displays hyphens (---).
Port-preserved
Whether to try to preserve the port numbers for PAT.
NO-PAT
Whether NO-PAT is used:
·     Y—NO-PAT is used.
·     N—PAT is used.
Reversible
Rule name
Priority
Config status
Status of the outbound dynamic NAT configuration: Active or Inactive.
Reasons why the outbound dynamic NAT configuration does not take effect. This field is available when the Config status is Inactive.
nat outbound
display nat outbound port-block-group
Use display nat outbound port-block-group to display information about port block group application for NAT444.
# Display information about port block group application for NAT444.
<Sysname> display nat outbound port-block-group
    Port block group: 2
    Rule name: abcdefg
    Rule name: abcfg
Table 9 Command output
Interface to which a port block group is applied.
Port block group
ID of the port block group.
Rule name
Config status
Status of the port block group application: Active or Inactive.
Reasons why the port block group application fails. This field is available when the Config status is Inactive.
display nat port-block
Use display nat port-block to display NAT444 mappings.
display nat port-block { dynamic | static } [ slot slot-number ]
dynamic: Displays dynamic NAT444 mappings.
static: Displays static NAT444 mappings.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT444 mappings for all member devices.
# Display static NAT444 mappings.
<Sysname> display nat port-block static
Slot 1:
Local VPN     Local IP         Global IP        Port block   Connections
---           100.100.100.111  202.202.100.101  10001-10256  0
---           100.100.100.112  202.202.100.101  10257-10512  0
---           100.100.100.113  202.202.100.101  10513-10768  0
---           100.100.100.113  202.202.100.101  10769-11024  0
Total mappings found: 4
# Display dynamic NAT444 mappings.
<Sysname> display nat port-block dynamic
Slot 1:
---           101.1.1.12       192.168.135.201  10001-11024  1
Total mappings found: 1
Table 10 Command output
Local VPN
VPN to which the private IP address belongs.
The device does not support this field in the current software version.
Local IP
Private IP address.
Global IP
Public IP address.
Port block
Port block defined by a start port and an end port.
Connections
Number of connections established by using the ports in the port block.
display nat port-block-group
Use display nat port-block-group to display information about NAT port block groups.
display nat port-block-group [ group-number ]
group-number: Specifies the ID of a port block group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays information about all port block groups.
# Display information about all port block groups.
<Sysname> display nat port-block-group
  Totally 3 NAT port block groups.
  Port block group 1:
    Port range: 1-65535
    Block size: 256
  Port block group 2:
    Block size: 500
  Port block group 3:
    Port range: 1-65535
    Block size: 256
# Display information about port block group 1.
<Sysname> display nat port-block-group 1
  Port block group 1:
    Port range: 1-65535
    Block size: 256
Table 11 Command output
Port block group
ID of the NAT port block group.
Port range
Port range for the public IP addresses.
Block size
Information about private IP addresses.
Information about public IP addresses.
Start address
Start IP address of a private or public IP address range. If no start IP address is specified for the address range, this field displays hyphens (---).
End address
End IP address of a private or public IP address range. If no end IP address is specified for the address range, this field displays hyphens (---).
VPN instance
VPN to which the private IP address range belongs.
display nat port-block-usage
Use display nat port-block-usage to display the port block usage for dynamic NAT444 address groups.
display nat port-block-usage [ address-group group-id ] [ slot slot-number ]
address-group group-id: Specifies the ID of an address group. The value range is 0 to 65535. If you do not specify an address group, this command displays the port block usage for all address groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the port block usage for all member devices.
# Display the port block usage for dynamic NAT444 address groups in slot 1.
<Sysname> display nat port-block-usage slot 1
Slot 1:
Total NAT address groups found: 1
Table 12 Command output
Number of address groups.
display nat server
Use display nat server to display NAT Server configuration.
display nat server
# Display NAT Server configuration.
<Sysname> display nat server
    Global ACL    : 2000
    Rule name     : cdefgab
    Priority      : 1000
    Rule name     : abcg
    Protocol: 17(UDP)
    Rule name     : cdefg
Table 13 Command output
Information about NAT Server configuration.
Interface where NAT Server is configured.
Protocol
Protocol number and type of the internal server.
Global IP/port
Public IP address and port number of the internal server.
·     Global IP—A single IP address or an address pool of consecutive addresses. If you use Easy IP, this field displays the address of the specified interface. If you do not specify an address for the interface, the Global IP field displays hyphens (---).
·     port—A single port number or a port pool of consecutive port numbers. If no port number is in the specified protocol, the port field displays hyphens (---).
Local IP/port
For common NAT Server, this field displays the private IP address and port number of the server.
·     Local IP—A single IP address or an address pool of consecutive addresses.
For load sharing NAT Server, this field displays the internal server group name, IP address, port number, and number of connections of each member.
ACL
ACL number or name. If no ACL is specified, this field is not displayed.
Rule name
Config status
Status of the NAT Server configuration: Active or Inactive.
Reasons why the NAT Server configuration does not take effect. This field is available when the Config status is Inactive.
nat server
display nat server-group
Use display nat server-group to display internal server group configuration.
display nat server-group [ group-number ]
group-number: Specifies the ID of the internal server group. The value range for this argument is 0 to 65535. If you do not specify this argument, this command displays configuration about all internal server groups.
# Display configuration about all internal server groups.
<Sysname> display nat server-group
                      192.168.0.27          23          500
  2                   ---                   ---         ---
# Display configuration about the specified internal server group.
<Sysname> display nat server-group 1
                      192.168.0.27          23          500
Table 14 Command output
Group Number
Inside IP
Private IP address of a member in an internal server group. If no address is specified, this field displays hyphens (---).
Port
Private port number of a member in an internal server group. If no port number is specified, this field displays hyphens (---).
Weight
Weight of a member in an internal server. If no weight value is specified, this field displays hyphens (---).
nat server-group
display nat session
Use display nat session to display sessions that have been NATed.
display nat session [ { source-ip source-ip | destination-ip destination-ip } * ] [ slot slot-number ] [ verbose ]
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the real source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT sessions for all member devices.
verbose: Display detailed information about NAT sessions. If you do not specify this keyword, this command displays brief information about NAT sessions.
If you do not specify any parameters, this command displays all NAT sessions.
# Display detailed information about NAT sessions.
<Sysname> display nat session verbose
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Vlan-interface10
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.10/1877
  Protocol: TCP(6)
  Inbound interface: Vlan-interface20
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36  TTL: 28s
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Total sessions found: 1
Table 15 Command output
Initiator
Session information about an initiator.
Responder
Session information about a responder.
DS-Lite tunnel peer
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
MPLS L3VPN instance to which the session belongs. The device does not support this field in the current software version.
VLAN ID to which the session belongs for Layer 2 forwarding.
INLINE to which the session belongs for Layer 2 forwarding.
If a setting is not specified, this field displays a hyphen (-).
Protocol
Transport layer protocol type, DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite.
Inbound interface
Input interface.
NAT session status.
Application
Application layer protocol type, such as FTP and DNS.
This field displays OTHER for the protocol types identified by non-well-known ports.
Start time
Time when the session starts.
TTL
NAT session lifetime in seconds.
Number of packets and packet bytes from the initiator to the responder.
Number of packets and packet bytes from the responder to the initiator.
Total number of session tables.
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
# Display static NAT mappings.
<Sysname> display nat static
  Net-to-net:
    Global IP    : 1.1.1.1 - 1.1.1.255
    Local IP     : 2.2.2.0
    ACL          : 3000
    Reversible   : Y
    Rule name    : abcdefg
    Priority     : 1000
  IP-to-IP:
    Global IP    : 5.5.5.5
    Local IP     : 4.4.4.4
    ACL          : 3000
    Reversible   : Y
    Rule name    : abefg
    Priority     : 1000
  Net-to-net:
    Global IP    : 2.2.2.0
    ACL          : 3000
    Reversible   : Y
  IP-to-IP:
    Local IP     : 4.4.4.4
    Global IP    : 5.5.5.5
    ACL:         : 3001
    Reversible   : Y
Table 16 Command output
Net-to-net
Net-to-net static NAT mapping.
IP-to-IP
One-to-one static NAT mapping.
Local IP
Private IP address or address pool.
Global IP
Public IP address or address pool.
Netmask
Network mask.
ACL
Reversible
Whether reverse address translation is allowed. If this feature is not configured, this field is not displayed.
Rule name
Priority
Config status
Status of the static NAT mapping configuration: Active or Inactive.
Reasons why the static NAT mapping configuration does not take effect. This field is available when the Config status is Inactive.
·     nat static
·     nat static net-to-net
·     nat static enable
display nat statistics
Use display nat statistics to display NAT statistics.
display nat statistics [ summary ] [ slot slot-number ]
summary: Displays NAT statistics summary. If you do not specify this keyword, this command displays detailed NAT statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT statistics for all member devices.
# Display detailed information about all NAT statistics.
<Sysname> display nat statistics
Slot 1:
  Total session entries: 100
  Total EIM entries: 1
  Total inbound NO-PAT entries: 0
  Total outbound NO-PAT entries: 0
  Total static port block entries: 10
  Total dynamic port block entries: 15
  Active static port block entries: 0
  Active dynamic port block entries: 0
Table 17 Command output
Number of NAT session entries.
Total EIM entries
Number of EIM entries.
Number of inbound NO-PAT entries.
Number of outbound NO-PAT entries.
Number of static NAT444 mappings.
Number of dynamic NAT444 mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks.
Number of static NAT444 mappings that are in use.
Number of dynamic NAT444 mappings that have been created. It equals the number of dynamically assigned port blocks.
# Display summary information about all NAT statistics.
<Sysname> display nat statistics summary
EIM: Total EIM entries.
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions  EIM       SPB       DPB       ASPB      ADPB
1    0         0         0         1572720   0         0
Table 18 Command output
Slot
Member ID of the IRF member device.
Sessions
EIM
SPB
DPB
ASPB
Number of static NAT444 mappings in use.
ADPB
global-ip-pool
Use global-ip-pool to add a public IP address range to a NAT port block group.
Use undo global-ip-pool to delete a public IP address range from a NAT port block group.
global-ip-pool start-address end-address
undo global-ip-pool start-address
No public IP address range exists in the NAT port block group.
start-address end-address: Specifies the start IP address and end IP address of a public IP address range. The end IP address cannot be smaller than the start IP address. If the start and end IP addresses are the same, only one public IP address is specified.
You can add multiple public IP address ranges to a port block group, but they cannot overlap.
Public IP address ranges in different port block groups can overlap. But the port ranges for overlapped ranges in different port block groups cannot overlap.
The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
# Add a public IP address range to the port block group 1. The public IP address range consists of IP addresses from 202.10.1.1 to 202.10.1.10.
[Sysname-port-block-group-1] global-ip-pool 202.10.1.1 202.10.1.10
inside ip
Use inside ip to add a member to an internal server group.
Use undo inside ip to remove a member from an internal server group.
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
An internal server group does not contain any member.
Internal server group view
inside-ip: Specifies the IP address of an internal server.
port port-number: Specifies the port number of an internal server, in the range of 1 to 65535, excluding FTP port 20.
weight weight-value: Specifies the weight of the internal server. The value range is 1 to 1000, and the default value is 100. An internal server with a larger weight receives a larger percentage of connections in the internal server group.
# Add a member with IP address 10.1.1.2 and port number 30 to internal server group 1.
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
nat server-group
local-ip-address
Use local-ip-address to add a private IP address range to a NAT port block group.
Use undo local-ip-address to delete a private IP address range from a NAT port block group.
local-ip-address start-address end-address
undo local-ip-address start-address
No private IP address range exists in a NAT port block group.
start-address end-address: Specifies the start IP address and end IP address of a private IP address range. The end IP address cannot be smaller than the start IP address. If the start and end IP addresses are the same, only one private IP address is specified.
You can add multiple private IP address ranges to a port block group, but they cannot overlap.
Private IP address ranges in different port block groups can overlap.
For static NAT444 mappings in one port block group, the number of private IP addresses cannot be larger than the number of assignable port blocks. Otherwise, some private IP addresses cannot obtain port blocks.
# Add a private IP address range to the port block group 1. The private IP address range consists of IP addresses from 172.16.1.1 to 172.16.1.255.
[Sysname-port-block-group-1] local-ip-address 172.16.1.1 172.16.1.255
nat address-group
Use nat address-group to create a NAT address group and enter its view.
Use undo nat address-group to remove a NAT address group.
nat address-group group-number [ name group-name ]
undo nat address-group group-number
No NAT address group exists.
group-number: Assigns an ID to the NAT address group. The value range for this argument is 0 to 65535.
name group-name: Assigns a name to the NAT address group. The group-name argument is a case-insensitive string of 1 to 63 characters.
A NAT address group consists of multiple address ranges. Use the address command to specify an address range.
# Create a NAT address group numbered 1 and named abc.
[Sysname] nat address-group 1 name abc
·     address
·     display nat address-group
·     display nat all
·     nat inbound
·     nat outbound
nat alg
Use nat alg to enable NAT with ALG for the specified or all supported protocols.
Use undo nat alg to disable NAT with ALG for the specified or all supported protocols.
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet |tftp | xdmcp }
NAT with ALG is enabled for DNS, FTP, ICMP error messages, RTSP, and PPTP, and is disabled for the other supported protocols.
all: Enables NAT with ALG for all supported protocols.
dns: Enables NAT with ALG for DNS.
ftp: Enables NAT with ALG for FTP.
h323: Enables NAT with ALG for H.323.
icmp-error: Enables NAT with ALG for ICMP error packets.
ils: Enables NAT with ALG for ILS.
mgcp: Enables NAT with ALG for MGCP.
nbt: Enables NAT with ALG for NBT.
pptp: Enables NAT with ALG for PPTP.
rsh: Enables NAT with ALG for RSH.
rtsp: Enables NAT with ALG for RTSP.
sccp: Enables NAT with ALG for SCCP.
sip: Enables NAT with ALG for SIP.
sqlnet: Enables NAT with ALG for SQLNET.
tftp: Enables NAT with ALG for TFTP.
xdmcp: Enables NAT with ALG for XDMCP.
NAT with ALG translates address or port information in the application layer payload to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT with ALG to translate the address and port information to establish data connection.
# Enable NAT with ALG for FTP.
[Sysname] nat alg ftp
display nat all
nat dns-map
Use nat dns-map to configure a DNS mapping for NAT. The mapping maps the domain name of an internal server to the public IP address, public port number, and protocol type of the internal server.
Use undo nat dns-map to remove a DNS mapping for NAT.
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
No DNS mapping for NAT exists.
domain domain-name: Specifies the domain name of an internal server. A domain name is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.) (for example, aabbcc.com). The domain name suffix can contain a maximum of 253 characters, and each separated string contains no more than 63 characters.
protocol pro-type: Specifies the type of the protocol used by the internal server, tcp or udp.
interface interface-type interface-number: Enables Easy IP to use the IP address of the interface specified by its type and number as the public address of the internal server.
ip global-ip: Specifies the public IP address used by the internal server to provide services for the external network.
port global-port: Specifies the public port number used by the internal server to provide services for the external network. The port number format can be one of the following:
·     A number in the range of 1 to 65535.
·     A protocol name, a string of 1 to 15 characters. For example, ftp and telnet.
NAT with DNS mapping must operate with the NAT Server feature. NAT with DNS mapping maps the domain name of the internal server to the public IP address, public port number, and protocol type of the server. NAT Server maps the public IP and port to the private IP and port of the internal server. This allows an internal host to access an internal server on the same private network by using the domain name of the internal server when the DNS server is on the public network.
You can configure multiple NAT with DNS mappings.
# Configure a NAT with DNS mapping between the domain name www.server.com, the public IP address 202.112.0.1, and the public port number 12345. Specify the protocol type as TCP.
[Sysname] nat dns-map domain www.server.com protocol tcp ip 202.112.0.1 port 12345
·     display nat all
·     display nat dns-map
·     nat server
nat icmp-error reply
Use nat icmp-error reply to enable sending ICMP error messages for NAT failures.
Use undo nat icmp-error reply to restore the default.
No ICMP error messages are sent for NAT failures.
Disabling sending ICMP error messages for NAT failures reduces useless packets, saves bandwidth, and avoids exposing the firewall IP address to the public network.
This command is required for traceroute.
# Enable sending ICMP error messages for NAT failures.
[Sysname] nat icmp-error reply
nat inbound
Use nat inbound to configure an inbound dynamic NAT rule on an interface.
Use undo nat inbound to remove the specified inbound dynamic NAT rule on an interface.
nat inbound { acl-number | name acl-name } address-group { group-number | name group-name } [ no-pat [ reversible ] [ add-route ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ]
undo nat inbound { acl-number | name acl-name }
No inbound dynamic NAT rule is configured.
Interface view
acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters.
address-group group-number: Specifies an address group for address translation. The value for the group-number argument is 0 to 65535.
group-name: Specifies the name of a NAT address group. The group-name argument is a case-insensitive string of 1 to 63 characters.
no-pat: Uses NO-PAT for inbound NAT. If you do not specify this keyword, PAT is used. PAT supports only TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal hosts to external hosts. It uses existing NO-PAT entries to translate destination addresses for packets of these connections if the packets are permitted by ACL reverse matching.
add-route: Automatically adds a route to the private address when address translation is performed for a packet. The output interface is the NAT interface and the next-hop is the source address before translation. If you do not specify this keyword, you must manually add the route. Because automatic route adding is slow, H3C recommends that you add routes manually.
rule rule-name: Specifies the name of a NAT rule. The rule name is a case-insensitive string of 1 to 63 characters. If you do not specify a rule name, the specified NAT rule does not have a name.
priority priority: Specifies the priority of a NAT rule. The value range for the priority argument is 0 to 65535. The smaller the priority value, the higher the priority. If you do not specify a priority, the priority value is 65535, which is the lowest. For NAT rules of the same type and the same priority, the device uses them to match packets in the order as they are configured.
disable: Disables the inbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
description text: Specifies a description for the inbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
Inbound dynamic NAT translates the source IP addresses of incoming packets permitted by the ACL into IP addresses in the address group.
Inbound dynamic NAT supports the PAT and NO-PAT modes.
·     PAT—Performs port translation in addition to IP address translation.
·     NO-PAT—Performs only IP address translation.
The NO-PAT mode supports reverse address translation. Reverse address translation uses ACL reverse matching to identify packets to be translated. ACL reverse matching works as follows:
·     Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
·     Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Inbound dynamic NAT typically operates with one of the following to implement bidirectional NAT:
·     Outbound dynamic NAT (the nat outbound command).
·     The NAT Server feature (the nat server command).
·     Outbound static NAT (the nat static command).
An address group cannot be used by both the nat inbound and nat outbound commands. It cannot be used by the nat inbound command in both PAT and NO-PAT modes.
Do not specify the add-route keyword if the internal and external networks are on the same subnet.
An ACL can be used by only one inbound dynamic NAT rule on an interface.
You can configure multiple inbound dynamic NAT rules on an interface.
The vpn-instance parameter is required if you deploy inbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure ACL 2001, and create a rule to permit packets only from subnet 10.110.10.0/24 to pass through.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# Create address group 1 and add an address range to the group.
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# Configure an inbound NO-PAT rule on interface VLAN-interface 10, and specify the name and the priority of the rule as abc and 0, respectively. NAT translates the source addresses of incoming packets into the addresses in address group 1, and automatically adds a route for translated packets.
[Sysname-Vlan-interface10] nat inbound 2001 address-group 1 no-pat add-route rule abc priority 0
·     display nat all
·     display nat inbound
·     display nat no-pat
nat inbound rule move
Use nat inbound rule move to modify the priority of an inbound dynamic NAT rule.
nat inbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
nat-rule-name1: Specifies the name of a NAT rule to be moved.
after: Moves NAT rule nat-rule-name1 to appear behind NAT rule nat-rule-name2.
before: Moves NAT rule nat-rule-name1 to appear in front of NAT rule nat-rule-name2.
nat-rule-name2: Specifies the name of a NAT rule to be moved.
This command takes effect only on an inbound dynamic NAT rule that has a name.
After you change the order of the inbound dynamic NAT rules by executing this command, the priorities of these NAT rules also changes.
·     If you execute the nat inbound rule move nat-rule-name1 after nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. The priority value of NAT rule nat-rule-name1 changes to be greater than that of NAT rule nat-rule-name2 by 1.
·     If you execute the nat inbound rule move nat-rule-name1 before nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. The priority value of NAT rule nat-rule-name1 changes to be smaller than that of NAT rule nat-rule-name2 by 1.
A rule with a high priority takes precedence over a rule with a low priority for packet matching.
# Move inbound dynamic NAT rule abc to appear in front of inbound dynamic NAT rule def.
<Sysname> nat inbound rule move abc before def
nat inbound
nat log alarm
Use nat log alarm to enable NAT444 alarm logging.
Use undo nat log alarm to disable NAT444 alarm logging.
nat log alarm
undo nat log alarm
NAT alarm logging is disabled.
Enable NAT logging before you enable NAT444 alarm logging. The alarm logs are informational.
The NAT444 gateway generates alarm logs in the following situations:
·     The ports in the selected port block of a static NAT444 mapping are all occupied.
·     The ports in the selected port blocks (including extended ones) of a dynamic NAT444 mapping are all occupied.
·     The public IP addresses and port blocks for dynamic NAT444 are all assigned.
# Enable NAT444 alarm logging.
[Sysname] nat log alarm
·     display nat all
·     display nat log
·     nat log enable
nat log enable
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl { acl-number | name acl-name } ]
undo nat log enable
NAT logging is disabled.
acl: Specifies an ACL.
You must enable NAT logging before you enable NAT session logging, NAT444 user logging, or NAT444 alarm logging.
The acl keyword takes effect only for NAT session logging. If an ACL is specified, flows matching the permit rule might trigger NAT session logs. If you do not specify an ACL, all flows processed by NAT might trigger NAT session logs.
# Enable NAT logging.
[Sysname] nat log enable
·     display nat all
·     display nat log
·     nat log alarm
·     nat log flow-end
·     nat log port-block-assign
·     nat log port-block-withdraw
nat log flow-active
Use nat log flow-active to log active NAT flows and set the logging interval.
Use undo nat log flow-active to disable the logging feature for active NAT flows.
nat log flow-active time-value
Logging for active NAT flows is disabled.
time-value: Specifies the interval for logging active NAT flows, in the range of 10 to 120 minutes.
This feature helps track active NAT flows.
Logging for active flows takes effect only after you enable NAT logging.
# Enable logging for active NAT flows and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
·     display nat all
·     display nat log
·     nat log enable
nat log flow-begin
Use nat log flow-begin to enable logging for NAT session establishment events.
Use undo nat log flow-begin to disable logging for NAT session establishment events.
nat log flow-begin
Logging for NAT session establishment events is disabled.
Logging for NAT session establishment events takes effect only after you enable NAT logging.
# Enable logging for NAT session establishment events.
[Sysname] nat log flow-begin
·     display nat all
·     display nat log
·     nat log enable
nat log flow-end
Use nat log flow-end to enable logging for NAT session removal events.
Use undo nat log flow-end to disable logging for NAT session removal events.
nat log flow-end
Logging for NAT session removal events is disabled.
Logging for NAT session removal events takes effect only after you enable NAT logging.
# Enable logging for NAT session removal events.
[Sysname] nat log flow-end
·     display nat all
·     display nat log
·     nat log enable
Use nat log port-block-assign to enable NAT444 user logging for port block assignment.
Use undo nat log port-block-assign to disable NAT444 user logging for port block assignment.
NAT444 user logging is disabled for port block assignment.
Enable NAT logging before you enable NAT444 user logging for port block assignment.
For static NAT444, the NAT444 gateway generates a user log when it translates the first connection from a private IP address.
For dynamic NAT444, the NAT444 gateway generates a user log when it assigns or extends a port block for a private IP address.
# Enable NAT444 user logging for port block assignment.
[Sysname] nat log port-block-assign
·     display nat all
·     display nat log
·     nat log enable
Use nat log port-block-withdraw to enable NAT444 user logging for port block withdrawal.
Use undo nat log port-block-withdraw to disable NAT444 user logging for port block withdrawal.
NAT444 user logging is disabled for port block withdrawal.
Enable NAT logging before you enable NAT444 user logging for port block withdrawal.
For static NAT444, the NAT444 gateway generates a user log when all connections from a private IP address are disconnected.
For dynamic NAT444, the NAT444 gateway generates a user log when all the following conditions are met:
·     All connections from a private IP address are disconnected.
·     The port blocks (including the extended ones) assigned to the private IP address are withdrawn.
·     The corresponding mapping entry is deleted.
# Enable NAT444 user logging for port block withdrawal.
[Sysname] nat log port-block-withdraw
·     display nat all
·     display nat log
·     nat log enable
Use nat mapping-behavior to configure the mapping behavior mode for PAT.
Use undo nat mapping-behavior to restore the default.
nat mapping-behavior endpoint-independent [ acl { acl-number | name acl-name } ]
undo nat mapping-behavior endpoint-independent
Address and Port-Dependent Mapping applies.
acl: Specifies an ACL to apply the NAT mapping behavior to packets that are permitted by the ACL. If you do not specify an ACL, the Endpoint-Independent Mapping applies to all packets.
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
PAT supports the following types of NAT mappings:
·     Endpoint-Independent Mapping—Uses the same IP and port mapping (EIM entry) for packets from the same source and port to any destination. EIM allows external hosts to access the internal hosts by using the translated IP address and port. It allows internal hosts behind different NAT gateways to access each other.
·     Address and Port-Dependent Mapping—Uses different IP and port mappings for packets with the same source IP and port to different destination IP addresses and ports. APDM allows an external host to access an internal host only under the condition that the internal host has previously accessed the external host. It is secure, but it does not allow internal hosts behind different NAT gateways to access each other.
This command takes effect only on outbound PAT. Address and Port-Dependent Mapping always applies to inbound PAT.
# Apply the Endpoint-Independent Mapping mode to all packets for address translation.
[Sysname] nat mapping-behavior endpoint-independent
# Apply the Endpoint-Independent Mapping to FTP and HTTP packets, and the Address and Port-Dependent Mapping to other packets for address translation.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 21
[Sysname] nat mapping-behavior endpoint-independent acl 3000
·     nat outbound
·     display nat eim
nat outbound
Use nat outbound to configure an outbound dynamic NAT rule on an interface.
Use undo nat outbound to remove the specified outbound dynamic NAT rule.
NO-PAT:
nat outbound [ acl-number | name acl-name ] address-group { group-number | name group-name } no-pat [ reversible ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ]
undo nat outbound [ acl-number | name acl-name ]
PAT:
nat outbound [ acl-number | name acl-name ] [ address-group { group-number | name group-name } ] [ port-preserved ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ]
No outbound dynamic NAT rule is configured.
Interface view
address-group group-number: Specifies an address group for NAT. The value range for the group-number argument is 0 to 65535. If you do not specify an address group, the IP address of the interface is used as the NAT address. Easy IP is used.
no-pat: Uses NO-PAT for outbound NAT. If you do not specify this keyword, PAT is used. PAT only supports TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Allows reverse address translation. Reverse address translation uses existing NO-PAT entries to translate destination addresses for packets of connections actively initiated by external hosts to internal hosts.
port-preserved: Tries to preserve port number for PAT.
disable: Disables the outbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
description text: Specifies a description for the outbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
Outbound dynamic NAT is typically configured on the interface connected to the external network. NAT translates the source IP addresses of outgoing packets permitted by the ACL into IP addresses in the address group. If you do not specify an ACL, NAT translates all packets.
Outbound dynamic NAT supports the following modes:
The NO-PAT mode supports reverse address translation. If an ACL is specified, reverse address translation only applies to packets permitted by ACL reverse matching. ACL reverse matching works as follows:
Dynamic NAT444 does not support the NO-PAT mode.
An address group cannot be used by both the nat inbound and nat outbound commands. It cannot be used by the nat outbound command in both PAT and NO-PAT modes.
An ACL can be used by only one outbound dynamic NAT rule an interface.
You can configure multiple outbound dynamic NAT rules on an interface.
Outbound dynamic NAT rules with ACLs configured on an interface takes precedence over those without ACLs. The priority for the ACL-based dynamic NAT rules depends on ACL number. A higher ACL number represents a higher priority.
When a port range and port block parameters are specified in the NAT address group, this command configures a dynamic NAT444 rule. Packets matching the ACL permit rule are processed by dynamic NAT444.
The port-preserved keyword does not take effect on dynamic NAT444.
The vpn-instance parameter is required if you deploy outbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure ACL 2001, and create a rule to permit packets only from segment 10.110.10.0/24 to pass through.
# Configure an outbound dynamic PAT rule on interface VLAN-interface 10 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1
[Sysname-Vlan-interface10] quit
Or
# Configure an outbound NO-PAT rule on interface VLAN-interface 10 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address pool 1.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1 no-pat
Or
# Enable Easy IP to use the IP address of VLAN-interface 10 as translated address.
Or
# Enable reverse address translation and use addresses in address pool 1 as NAT addresses.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1 no-pat reversible
·     display nat eim
·     display nat outbound
Use nat outbound port-block-group to apply a port block group to the outbound direction of an interface.
Use undo nat outbound port-block-group to remove a port block group application.
nat outbound port-block-group group-number [ rule rule-name ]
undo nat outbound port-block-group group-number
No port block group is applied to an interface.
Interface view
group-number: Specifies a port block group by its ID. The value range for this argument is 0 to 65535.
You can apply multiple port block groups to one interface.
After you apply a port block group to an interface, the system automatically computes the NAT444 mappings and creates entries for them. When a private IP address accesses the public network, the private IP address is translated to the mapped public IP address, and the ports are translated to ports in the selected port block.
# Apply port block group 1 to the outbound direction of VLAN-interface 10, and specify the name of the port block group mapping rule as abc.
[Sysname-Vlan-interface10] nat outbound port-block-group 1 rule abc
·     display nat all
·     display nat outbound port-block-group
·     display nat port-block
·     nat port-block-group
nat outbound rule move
Use nat outbound rule move to modify the priority of an outbound dynamic NAT rule.
nat outbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
This command takes effect only on an outbound dynamic NAT rule that has a name.
After you change the order of the outbound dynamic NAT rules by executing this command, the priorities of these NAT rules also changes.
·     If you execute the nat outbound rule move nat-rule-name1 after nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. The priority value of NAT rule nat-rule-name1 changes to be greater than that of NAT rule nat-rule-name2 by 1.
·     If you execute the nat outbound rule move nat-rule-name1 before nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. The priority value of NAT rule nat-rule-name1 changes to be smaller than that of NAT rule nat-rule-name2 by 1.
# Move outbound dynamic NAT rule abc to appear in front of outbound dynamic NAT rule def.
<Sysname> nat outbound rule move abc before def
nat outbound
nat port-block global-share enable
Use nat port-block global-share enable to enable global mapping sharing for dynamic NAT444.
Use undo nat port-block global-share enable to disable global mapping sharing for dynamic NAT444.
Global mapping sharing is disabled for Dynamic NAT444.
When multiple interfaces have dynamic NAT444 configured, the interfaces might create different NAT444 mappings for packets from the same IP address. You can use this command to configure the interfaces to share the same NAT444 mapping for translating packets from the same IP address.
# Enable global mapping sharing for dynamic NAT444.
[Sysname] nat port-block global-share enable
port-block
Use nat port-block-group to create a port block group and enter its view.
Use undo nat port-block-group to delete a port block group.
nat port-block-group group-number
undo nat port-block-group group-number
No port block group exists.
group-number: Assigns an ID to the NAT port block group. The value range for this argument is 0 to 65535.
A port block group is configured to implement static NAT444.
You must configure the following items for a port block group:
·     A minimum of one private IP address range (see the local-ip-address command).
·     A minimum of one public IP address range (see the global-ip-address command).
·     A port range (see the port-range command).
·     A port block size (see the block-size command).
The system computes static NAT444 mappings according to the port block group configuration, and creates entries for the mappings.
# Create NAT port block group 1.
<Sysname>system-view
[Sysname]nat port-block-group 1
·     block-size
·     display nat all
·     display nat port-block-group
·     global-ip-pool
·     local-ip-address
·     nat outbound port-block-group
·     port-range
nat log port-block usage threshold
Use nat log port-block usage threshold to set the port block usage threshold for dynamic NAT444.
Use undo nat log port-block usage threshold to restore the default.
nat log port-block usage threshold threshold-value
The port block usage threshold for dynamic NAT444 is 90%.
threshold-value: Specifies the port block usage threshold in percentage, in the range of 40 to 100.
The system generates alarm logs if the port block usage exceeds the threshold.
# Set the port block usage threshold for dynamic NAT444 to 60%.
[Sysname] nat log port-block usage threshold 60
nat server
Use nat server to create a mapping from the private IP address and port of an internal server to a public address and port for an internal server.
Use undo nat server to remove a mapping.
Common NAT Server:
·     A single public address with no or a single public port:
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] inside local-address [ local-port ] [ acl { acl-number | name acl-name } ] [ reversible ] [ rule rule-name ] [ disable ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ]
·     A single public address with consecutive public ports:
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ acl { acl-number | name acl-name } ] [ rule rule-name ] [ disable ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2
·     Consecutive public addresses with no or a single public port:
nat server protocol pro-type global global-address1 global-address2 [ global-port ] inside { local-address | local-address1 local-address2 } [ local-port ] [ acl { acl-number | name acl-name } ] [ rule rule-name ] [ disable ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ]
·     Consecutive public addresses with a single public port:
nat server protocol pro-type global global-address1 global-address2 global-port inside local-address local-port1 local-port2 [ acl { acl-number | name acl-name } ] [ rule rule-name ] [ disable ]
undo nat server protocol pro-type global global-address1 global-address2 global-port
Load sharing NAT Server:
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } inside server-group group-number [ acl { acl-number | name acl-name } ] [ rule rule-name ] [ disable ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port }
ACL-based NAT Server:
nat server global { global-acl-number | name global-acl-name } inside local-address [ local-port ] [ rule rule-name ] [ priority priority ] [ disable ]
undo nat server global { global-acl-number | name global-acl-name } inside local-address [ local-port ]
The NAT Server feature is not configured.
Interface view
protocol pro-type: Specifies a protocol type. When the protocol is TCP or UDP, NAT Server can be configured with port information. If you do not specify a protocol type, the command applies to packets of all protocols. The protocol type format can be one of the following:
·     A number in the range of 1 to 255.
·     A protocol name of icmp, tcp, or udp.
global-address: Specifies the public address of an internal server.
global-address1 global address2: Specifies a public IP address range, which can include a maximum number of 65535 addresses. The global-address1 argument specifies the start address, and global address2 specifies the end address that must be greater than the start address.
global: Specifies an ACL. The destination IP addresses of packets permitted by the ACL can be translated.
global-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name global-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters.
current-interface: Enables Easy IP on the current interface. The IP address of the interface is used as the public address for the internal server.
interface interface-type interface-number: Enables Easy IP on the interface specified by its type and number. The IP address of the interface is used as the public address for the internal server. Only loopback interfaces are supported.
global-port1 global-port2: Specifies a public port number range, which can include a maximum of 256 ports. The global-port1 argument specifies the start port, and global-port2 specifies the end port that must be greater than the start port. The public port number format can be one of the following:
·     A number in the range of 1 to 65535. Both the start port and the end port support this format.
·     A protocol name, a string of 1 to 15 characters. For example, http and telnet. Only the start port supports this format.
local-address1 local-address2: Specifies a private IP address range. The local-address1 argument specifies the start address, and local-address2 specifies the end address that must be greater than the start address. The number of addresses in the range must equal the number of ports in the public port number range.
local-port: Specifies the private port number. The private port number format can be one of the following:
·     A number in the range of 1 to 65535, excluding FTP port 20. Both the start port and the end port support this format.
global-port: Specifies the public port number. The default value and value range are the same as those for the local-port argument.
local-address: Specifies the private IP address.
server-group group-number: Specifies the internal server group to which the internal server belongs. With this parameter, the load sharing NAT Server feature is configured. The group-number argument specifies the internal server group number. The value range for this argument is 0 to 65535.
acl: Specifies an ACL to identify packets that can be translated by using the mapping.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal servers to the external network. It translates the private IP addresses of the internal servers to their public IP addresses.
disable: Disables the NAT Server mapping. If you do not specify this keyword, the mapping is enabled.
You can configure the NAT Server feature to allow internal servers (such as Web, FTP, Telnet, POP3, and DNS servers) in the internal network to provide services for external users.
NAT Server is usually configured on the interface connected to the external network on a NAT device. By using the global-address and global-port arguments, external users can access the internal server at local-address and local-port. The following table describes the address-port mappings between an external network and an internal network for NAT Server.
Table 19 Address-port mappings for NAT Server
External network
Internal network
One public address
One private address
One public address and one public port number
One private address and one private port number
One public address and N consecutive public port numbers
N consecutive private addresses and one private port number
One private address and N consecutive private port numbers
N consecutive public addresses
One private address
N consecutive public addresses and one public port number
One private server group
Public addresses matching an ACL
One private address
The number of internal servers that each command can define equals the number of public ports in the specified public port range.
When the protocol type is not udp (protocol number 17) or tcp (protocol number 6), you can configure only one-to-one IP address mapping.
The mapping of the protocol type, public address, and public port number must be unique for an internal server on an interface.
If the IP address of an interface used by Easy IP changes and conflicts with the IP address of an internal server not using Easy IP, the Easy IP configuration becomes invalid. If the conflicted address is modified to an unconflicted address or the internal server configuration without Easy IP is removed, the Easy IP configuration takes effect.
The vpn-instance parameter is required if you deploy NAT Server for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Allow external users to access the internal Web server at 10.110.10.10 on the LAN through http://202.110.10.10:8080.
[Sysname-Vlan-interface10] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 http
# Allow external users to access the internal FTP server at 10.110.10.11 through ftp://202.110.10.10.
[Sysname-Vlan-interface10] nat server protocol tcp global 202.110.10.10 21 inside 10.110.10.11
# Allow external hosts to ping the host at 10.110.10.12 by using the ping 202.110.10.11 command.
[Sysname-Vlan-interface10] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12
# Allow external hosts to access the Telnet services of internal servers at 10.110.10.1 to 10.110.10.100 through the public address 202.110.10.10 and port numbers from 1001 to 1100. As a result, a user can Telnet to 202.110.10.10:1001 to access 10.110.10.1, Telnet to 202.110.10.10:1002 to access 10.110.10.2, and so on.
[Sysname-Vlan-interface10] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet
# Configure ACL-based NAT Server to allow users to use IP addresses in subnet 192.168.0.0/24 to access the internal server at 10.0.0.172.
[Sysname-acl-ipv4-adv-3000] rule 5 permit ip destination 192.168.0.0 0.0.0.255
[Sysname-Vlan-interface10] nat server global 3000 inside 10.0.0.172
·     display nat all
·     display nat server
·     nat server-group
nat server-group
Use nat server-group to create an internal server group.
Use undo nat server-group to remove an internal server group.
nat server-group group-number
undo nat server-group group-number
No internal server group exists.
group-number: Assigns an ID to the internal server group. The value range for this argument is 0 to 65535.
An internal server group can contain multiple members configured by the inside ip command.
# Create internal server group 1.
·     display nat all
·     display nat server-group
·     inside ip
·     nat server
nat server rule move
Use nat server rule move to modify the priority of an ACL-based NAT server rule.
nat server rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
This command takes effect only on an ACL-based NAT server rule that has a name.
After you change the order of the ACL-based NAT server rules by executing this command, the priorities of these NAT rules also changes.
·     If you execute the nat server rule move nat-rule-name1 after nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. And the priority value of NAT rule nat-rule-name1 changes to be greater than that of NAT rule nat-rule-name2 by 1.
·     If you execute the nat server rule move nat-rule-name1 before nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. And the priority value of NAT rule nat-rule-name1 changes to be smaller than that of NAT rule nat-rule-name2 by 1.
# Move ACL-based NAT server rule abc to appear in front of ACL-based NAT server rule def.
<Sysname> nat server rule move abc before def
nat server
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface.
nat static enable
Static NAT is disabled.
Interface view
Static NAT mappings take effect on an interface only after static NAT is enabled on the interface.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on interface VLAN-interface 10.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-Vlan-interface10] nat static enable
·     display nat all
·     display nat static
·     nat static
nat static inbound
Use nat static inbound to configure a one-to-one mapping for inbound static NAT.
Use undo nat static inbound to remove a one-to-one mapping for inbound static NAT.
nat static inbound global-ip [ acl { acl-number | name acl-name } [ reversible ] ] local-ip [ rule rule-name ] [ priority priority ] [ disable ]
undo nat static inbound global-ip [ acl { acl-number | name acl-name } ]
No NAT mapping exists.
global-ip: Specifies a public IP address.
acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal hosts to the external host. It uses the mapping to translate the destination address for packets of these connections if the packets are permitted by ACL reverse matching.
local-ip: Specifies a private IP address.
disable: Disables the one-to-one inbound static mapping. If you do not specify this keyword, the mapping is enabled.
When the source IP address of a packet from the public network to the private network matches the global-ip, the source IP address is translated into the local-ip. When the destination IP address of a packet from the private network to the public network matches the local-ip, the destination IP address is translated into the global-ip.
·     If you do not specify an ACL, the source address of all incoming packets and the destination address of all outgoing packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address of packets is not translated for connections actively initiated by internal hosts to the external host.
·     If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated by internal hosts to the external host are permitted by ACL reverse matching, the destination address is translated.
·     Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP address/port in the ACL.
Static NAT takes precedence over dynamic NAT when both are configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound command and the nat static inbound net-to-net command.
The vpn-instance parameter is required if you deploy inbound static NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure an inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
·     display nat all
·     nat static enable
Use nat static inbound net-to-net to configure a net-to-net mapping for inbound static NAT.
Use undo nat static inbound net-to-net to remove a net-to-net mapping for inbound static NAT.
nat static inbound net-to-net global-start-address global-end-address [ acl { acl-number | name acl-name } [ reversible ] ] local local-network { mask-length | mask } [ rule rule-name ] [ priority priority ] [ disable ]
undo nat static inbound net-to-net global-start-address global-end-address [ acl { acl-number | name acl-name } ]
global-start-address global-end-address: Specifies a public address range which can contain a maximum of 255 addresses. The global-end-address must not be lower than global-start-address. If they are the same, only one public address is specified.
acl: Specifies an ACL to identify packets that can use NAT rules for address translation.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal hosts to the external hosts. It uses the mapping to translate destination addresses for packets of these connections if the packets are permitted by ACL reverse matching.
local-network: Specifies a private network address.
mask-length: Specifies the mask length of the private network address, in the range of 8 to 31.
mask: Specifies the mask of the private network address.
disable: Disables the net-to-net inbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a public network through a start address and an end address, and a private network through a private address and a mask.
The public end address cannot be greater than the greatest IP address in the subnet determined by the public start address and the private network mask. For example, if the private address is 2.2.2.0 with a mask 255.255.255.0 and the public start address is 1.1.1.100, the public end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
When the source IP address of an incoming packet matches the public address range, the source IP address is translated into a private address in the private address range. When the destination IP address of a packet from the private network matches the private address range, the destination IP address is translated into a public address in the public address range.
·     If you do not specify an ACL, the source addresses of all incoming packets and the destination addresses of all outgoing packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source addresses of incoming packets permitted by the ACL are translated. The destination addresses of packets are not translated for connections actively initiated by internal hosts to the external hosts.
·     If you specify both an ACL and the reversible keyword, the source addresses of incoming packets permitted by the ACL are translated. If packets of connections actively initiated by internal hosts to the external hosts are permitted by ACL reverse matching, the destination addresses are translated.
·     Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
# Configure an inbound static NAT between public network address 202.100.1.0/24 and private network address 192.168.1.0/24.
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
·     display nat all
·     nat static enable
nat static inbound rule move
Use nat static inbound rule move to modify the priority of a one-to-one static inbound NAT rule.
nat static inbound rule move nat-rule-name1 { after | before } nat-rule-name2
This command takes effect only on a one-to-one static inbound NAT rule that has a name.
After you change the order of the one-to-one static inbound NAT rules by executing this command, the priorities of these NAT rules also changes.
·     If you execute the nat static inbound rule move nat-rule-name1 after nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. And the priority value of NAT rule nat-rule-name1 changes to be greater than that of NAT rule nat-rule-name2 by 1.
·     If you execute the nat static inbound rule move nat-rule-name1 before nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. And the priority value of NAT rule nat-rule-name1 changes to be smaller than that of NAT rule nat-rule-name2 by 1.
# Move one-to-one static inbound NAT rule abc to appear in front of one-to-one static inbound NAT rule def.
<Sysname> nat static inbound rule move abc before def
nat static inbound
nat static outbound
Use nat static outbound to configure a one-to-one mapping for outbound static NAT.
Use undo nat static outbound to remove a one-to-one mapping for outbound static NAT.
nat static outbound local-ip [ acl { acl-number | name acl-name } [ reversible ] ] global-ip [ rule rule-name ] [ priority priority ] [ disable ]
undo nat static outbound local-ip [ acl { ipv4-acl-number | name ipv4-acl-name } ]
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by external hosts to the internal host. It uses the mapping to translate the destination address for packets of these connections if the packets are permitted by ACL reverse matching.
disable: Disables the one-to-one outbound static mapping. If you do not specify this keyword, the mapping is enabled.
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
·     If you do not specify an ACL, the source address of all outgoing packets and the destination address of all incoming packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address of packets is not translated for connections actively initiated by external hosts to the internal host.
·     If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated by external hosts to the internal host are permitted by ACL reverse matching, the destination address is translated.
You can configure multiple outbound static NAT mappings by using the nat static outbound command and the nat static outbound net-to-net command.
The vpn-instance parameter is required if you deploy outbound static NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
# Configure outbound static NAT, and allow the internal user 192.168.1.1 to access the external network 3.3.3.0/24 by using the public IP address 2.2.2.2.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 acl 3001 2.2.2.2
·     display nat all
·     nat static enable
Use nat static outbound net-to-net to configure a net-to-net outbound static NAT mapping.
Use undo nat static outbound net-to-net to remove the specified net-to-net outbound static NAT mapping.
nat static outbound net-to-net local-start-address local-end-address [ acl { acl-number | name acl-name } [ reversible ] ] global global-network { mask-length | mask } [ rule rule-name ] [ priority priority ] [ disable ]
undo nat static outbound net-to-net local-start-address local-end-address [ acl { acl-number | name acl-name }
local-start-address local-end-address: Specifies a private address range which can contain a maximum of 255 addresses. The local-end-address must not be lower than local-start-address. If they are the same, only one private address is specified.
acl-number: Specifies an ACL number in the range of 3000 to 3999.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by external hosts to the internal hosts. It uses the mapping to translate destination addresses for packets of these connections if the packets are permitted by ACL reverse matching.
global-network: Specifies a public network address.
mask-length: Specifies the mask length of the public network address, in the range of 8 to 31.
mask: Specifies the mask of the public network address.
disable: Disables the net-to-net outbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a private network through a start address and an end address, and a public network through a public address and a mask.
The private end address cannot be greater than the greatest IP address in the subnet determined by the private start address and the public network mask. For example, the public address is 2.2.2.0 with a mask 255.255.255.0, and the private start address is 1.1.1.100. The private end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
When the source IP address of a packet from the private network matches the private address range, the source IP address is translated into a public address in the public address range. When the destination IP address of a packet from the public network matches the public address range, the destination IP address is translated into a private address in the private address range.
·     If you do not specify an ACL, the source addresses of all outgoing packets and the destination addresses of all incoming packets are translated.
·     If you specify an ACL and do not specify the reversible keyword, the source addresses of outgoing packets permitted by the ACL are translated. The destination addresses of packets are not translated for connections actively initiated by external hosts to the internal hosts.
·     If you specify both an ACL and the reversible keyword, the source addresses of outgoing packets permitted by the ACL are translated. If packets of connections actively initiated by external hosts to the internal hosts are permitted by ACL reverse matching, the destination addresses are translated.
# Configure an outbound static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# Configure outbound static NAT. Allow internal users on subnet 192.168.1.0/24 to access the external subnet 3.3.3.0/24 by using public IP addresses on subnet 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 acl 3001 global 2.2.2.0 24
·     display nat all
·     nat static enable
nat static outbound rule move
Use nat static outbound rule move to modify the priority of a one-to-one static outbound NAT rule.
nat static outbound rule move nat-rule-name1 { after | before } nat-rule-name2
This command takes effect only on a one-to-one static outbound NAT rule that has a name.
After you change the order of the one-to-one static outbound NAT rules by executing this command, the priorities of these NAT rules also changes.
·     If you execute the nat static outbound rule move nat-rule-name1 after nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. And the priority value of NAT rule nat-rule-name1 changes be greater than that of NAT rule nat-rule-name2 by 1.
·     If you execute the nat static outbound rule move nat-rule-name1 before nat-rule-name2 command, the priority value of NAT rule nat-rule-name2 does not change. And the priority value of NAT rule nat-rule-name1 changes to be smaller than that of NAT rule nat-rule-name2 by 1.
# Move one-to-one static outbound NAT rule abc to appear in front of one-to-one static outbound NAT rule def.
<Sysname> nat static outbound rule move abc before def
nat static outbound
port-block
Use port block to configure port block parameters for a NAT address group.
Use undo port block to remove port block configuration from a NAT address group.
port block block-size block-size [ extended-block-number extended-block-number ]
undo port block
Port block parameters are not configured for a NAT address group.
NAT address group view
block-size block-size: Sets the port block size. The value range for this argument is 1 to 65535. In a NAT address group, the port block size cannot be larger than the number of ports in the port range.
extended-block-number extended-block-number: Specifies the number of extended port blocks, in the range of 1 to 5. When a private IP address accesses the public network, but the ports in the selected port block are all occupied, the NAT444 gateway extends port blocks one by one for the private IP address.
With dynamic NAT444 configured, when a private IP address initiates a connection to the public network, the NAT444 gateway assigns it a public IP address and a port block, and creates an entry for the mapping. For subsequent connections from the private IP address, the NAT444 gateway translates the private IP address to the mapped public IP address and the ports to ports in the selected port block.
# Set the port block size to 256 and the number of extended port blocks to 1 for NAT address group 2.
[Sysname] nat address-group 2
[Sysname-address-group-2] port-block block-size 256 extended-block-number 1
nat address-group
port-range
Use port-range to specify a port range for public IP addresses.
Use undo port-range to restore the default.
port-range start-port-number end-port-number
undo port-range
The port range for public IP addresses is 1 to 65535.
NAT port block group view
start-port-number end-port-number: Specifies the start port number and end port number for the port range. The end port number cannot be smaller than the start port number.
The port range must include all ports that a public IP address uses for address translation.
The number of ports in a port range cannot be smaller than the port block size.
# Specify the port range as 1024 to 65535 for NAT address group 1.
[Sysname-address-group-1] port-range 1024 65535
# Specify the port range as 30001 to 65535 for NAT port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] port-range 30001 65535
·     nat address-group
reset nat session
Use reset nat session to clear NAT sessions.
reset nat session [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears NAT sessions for all member devices.
After you remove the NAT session, the corresponding NAT EIM table and NO-PAT table are removed at the same time.
# Clear all NAT sessions.
<Sysname> reset nat session
display nat session
