06-Layer 3 - IP Services
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E5208P03 E5215P01 R5215P01)-6W10206-Layer 3 - IP Services
09-GRE commands
09-GRE commands 77.74 KB
GRE commands
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth (in kbps) is the interface maximum rate divided by 1000.
Tunnel interface view
The expected bandwidth for an interface affects the link costs.
# Set the expected bandwidth for Tunnel 1 to 100 kbps.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] bandwidth 100
default
Use default to restore the default settings for a tunnel interface.
default
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands. Use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings of interface tunnel 1.
[Sysname-Tunnel1] default
description
Use description to configure a description for a tunnel interface.
The description for a tunnel interface is Tunnelnumber Interface, for example, Tunnel1 Interface.
text: Configures a description for the interface, a case-sensitive string of 1 to 255 characters.
Configure descriptions for different interfaces for identification and management purposes.
You can use the display interface command to display the configured interface description.
# Configure the description for interface Tunnel 1 as tunnel1.
[Sysname-Tunnel1] description tunnel1
display interface tunnel
destination
Use destination to specify the destination address for a tunnel interface.
Use undo destination to remove the configured tunnel destination address.
destination { ip-address | ipv6-address }
undo destination
No tunnel destination address is configured.
ip-address: Specifies the tunnel destination IPv4 address.
ipv6-address: Specifies the tunnel destination IPv6 address.
The tunnel destination address must be the address of the receiving interface on the tunnel peer. It is used as the destination address of tunneled packets.
The destination address of the local tunnel interface must be the source address of the peer tunnel interface, and vice versa.
# VLAN-interface 1 on Sysname 1 uses the IP address 193.101.1.1 and VLAN-interface 1 on Sysname 2 uses the IP address 192.100.1.1. Configure the source address 193.101.1.1 and destination address 192.100.1.1 for the tunnel interface on Sysname 1.
<Sysname1> system-view
[Sysname1] interface tunnel 1 mode gre
[Sysname1-Tunnel1] source 193.101.1.1
[Sysname1-Tunnel1] destination 192.100.1.1
# Configure the source address 192.100.1.1 and destination address 193.101.1.1 for the tunnel interface on Sysname 2.
<Sysname2> system-view
[Sysname2] interface tunnel 1 mode gre
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
·     display interface tunnel
·     interface tunnel
·     source
Use display interface tunnel to display information about tunnel interfaces, including the source address, destination address, and tunnel mode.
display interface [ tunnel [ number ] ] [ brief [ description | down ] ]
number: Specifies the number of an existing tunnel interface.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify the tunnel keyword, this command displays information about all interfaces on the device.
If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
# Display detailed information about interface Tunnel 1.
<Sysname> display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 64000
Tunnel source 2002::1:1 (Vlan-interface10), destination 2001::2:1
Tunnel keepalive enabled, Period(50 s), Retries(3)
Tunnel TOS 0xC8, Tunnel TTL 255
Tunnel protocol/transport GRE/IPv6
    GRE key value is 1
    Checksumming of GRE packets disabled
Tunnel1
Information about the tunnel interface Tunnel 1.
Current state
State of the tunnel interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up but its physical state is down.
·     DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the interface belongs has been shut down by using the shutdown command.
·     UP—Both the administrative and physical states of the interface are up.
Line protocol state
Link layer protocol state of the tunnel interface. The value is determined by parameter negotiation on the link layer.
·     UP—The protocol state of the interface is up.
·     UP (spoofing)—The link protocol state of the interface is up, but the link is temporarily set up on demand or does not exist. This attribute is available for null interfaces and loopback interfaces.
·     DOWN—The protocol state of the interface is down.
Description for the tunnel interface.
Bandwidth
Expected bandwidth for the tunnel interface.
MTU of the tunnel interface.
Internet address
IP address of the tunnel interface.
If no IP address is assigned to the interface, this field displays Internet protocol processing: Disabled, and the tunnel interface cannot process packets.
If (primary) is displayed, the IP address is the primary IP address of the interface.
Tunnel source
Source address of the tunnel. If a source interface is specified for the tunnel interface, this field also displays the source interface in parentheses.
destination
Destination address of the tunnel.
Keepalive is enabled to detect the state of the tunnel interface. In this example, keepalive packets are sent every 50 seconds, and the maximum sending attempts are three.
Tunnel TOS
ToS of tunneled packets.
Tunnel TTL
TTL of tunneled packets.
Tunnel mode and transport protocol:
·     GRE/IP—GRE/IPv4 tunnel mode.
·     GRE/IPv6—GRE/IPv6 tunnel mode.
GRE key value is 1
The GRE tunnel interface key is 1.
The GRE packet checksum feature is disabled.
Last time when counters were cleared.
Last 300 seconds input:  0 bytes/sec, 0 packets/sec
Average input rate in the last 300 seconds.
Average output rate in the last 300 seconds.
# Display brief information about interface Tunnel 1.
<Sysname> display interface tunnel 1 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP     Description
Tun1                 UP   UP       1.1.1.1        tunnel1
# Display brief information about interface Tunnel 1, including the complete interface description.
<Sysname> display interface tunnel 1 brief description
# Display information about interfaces in DOWN state and the causes.
<Sysname> display interface tunnel brief down
Tun0                 DOWN Not connected
Tun1                 DOWN Not connected
Brief information about Layer 3 interfaces.
Link status:
·     ADM—The interface has been administratively shut down. To bring it up, use the undo shutdown command.
·     Stby—The interface is a backup interface. To show the primary interface, use the display interface-backup state command.
(s) indicates that the data link layer protocol state is UP, but the link is temporarily set up on demand or does not exist. This attribute is available for null interfaces and loopback interfaces.
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The link is physically up.
·     DOWN—The link is physically down.
·     ADM—The link has been administratively shut down. To bring it up, use the undo shutdown command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link protocol state of the interface is up.
·     DOWN—The data link protocol state of the interface is down.
·     UP(s)—The data link protocol state of the interface is up, but the link is temporarily set up on demand or does not exist. This attribute is available for null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface.
Description for the interface.
Cause
Causes for the physical state of DOWN:
·     Administratively—The link has been shut down by using the shutdown command. To bring it up, use the undo shutdown command.
·     Not connected—The tunnel is not established.
·     DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the tunnel interface belongs has been shut down by using the shutdown command.
·     destination
·     interface tunnel
·     source
gre checksum
Use gre checksum to enable GRE checksum.
Use undo gre checksum to disable GRE checksum.
gre checksum
undo gre checksum
GRE checksum is disabled.
GRE checksum verifies packet integrity.
You can enable or disable GRE checksum at each end of a tunnel as needed. After GRE checksum is enabled, the sender does the following:
·     Calculates the checksum for the GRE header and the payload.
·     Sends the packet containing the checksum information to the peer.
The receiver calculates the checksum for the received packet and compares it with that carried in the packet. If the checksums are the same, the receiver processes the packet. If the checksums are different, the receiver discards the packet.
If a packet carries a GRE checksum, the receiver checks the checksum whether or not the receiver is enabled with GRE checksum.
# Enable GRE checksum.
[Sysname] interface tunnel 2 mode gre
[Sysname-Tunnel2] gre checksum
gre key
Use gre key to configure a key for a GRE tunnel interface.
Use undo gre key to remove the configuration.
gre key key-number
undo gre key
No key is configured for a GRE tunnel interface.
key-number: Specifies the key for the GRE tunnel interface, in the range of 0 to 4294967295.
You can configure a GRE key to check for the validity of packets received on a GRE tunnel interface.
When a GRE key is configured, the sender puts the GRE key into each sent packet. The receiver compares the GRE key in the received packet with its own GRE key. If the two keys are the same, the receiver accepts the packet. If the two keys are different, the receiver drops the packet.
Both ends of a GRE tunnel must have the same key or no key.
# Configure the GRE key as 123 for the GRE tunnel interface.
[Sysname-Tunnel2] gre key 123
interface tunnel
Use interface tunnel to create a tunnel interface, specify the tunnel mode, and enter tunnel interface view.
Use undo interface tunnel to delete a tunnel interface.
interface tunnel number [ mode gre [ ipv6 ] ]
undo interface tunnel number
No tunnel interface is created on the device.
number: Specifies the number of the tunnel interface. The value range for this argument is 0 to 1023. The number of tunnel interfaces that can be created is restricted by the total number of interfaces and the memory.
mode gre: Specifies the GRE/IPv4 tunnel mode.
mode gre ipv6: Specifies the GRE/IPv6 tunnel mode.
To create a new tunnel interface, you must specify the tunnel mode in this command. To enter the view of an existing tunnel interface, you do not need to specify the tunnel mode.
A tunnel interface number is locally significant. The tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
# Create the GRE/IPv4 tunnel interface Tunnel 1 and enter tunnel interface view.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
·     destination
·     source
keepalive
Use keepalive to enable GRE keepalive and set the keepalive interval and the keepalive number.
Use undo keepalive to disable GRE keepalive.
keepalive [ interval [ times ] ]
undo keepalive
GRE keepalive is disabled.
interval: Sets the keepalive interval in the range of 1 to 32767 seconds. The default value is 10.
times: Sets the keepalive number in the range of 1 to 255. The default value is 3.
This command enables the tunnel interface to send keepalive packets at the specified interval. If the device receives no response from the peer within the timeout time, it shuts down the local tunnel interface. The device brings the local tunnel interface up if it receives a keepalive acknowledgment packet from the peer. The timeout time is the result of multiplying the keepalive interval by the keepalive number.
The device always acknowledges the keepalive packets it receives whether or not GRE keepalive is enabled.
GRE/IPv6 mode tunnel interfaces do not support this command.
# Enable GRE keepalive, set the keepalive interval to 20 seconds, and set the keepalive number to 5.
[Sysname-Tunnel2] keepalive 20 5
mtu
Use mtu to set the MTU on a tunnel interface.
mtu size
undo mtu
If the tunnel interface has never been up, the MTU is 64000 bytes.
If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers. The outgoing interface is automatically obtained through routing table lookup based on the tunnel destination address.
size: Specifies the MTU in the range of 100 to 64000 bytes.
After you configure an MTU for a tunnel interface, the configured MTU applies regardless of the tunnel interface status (up/down) and the outgoing interface MTU.
To avoid fragmentation after tunnel encapsulation, set the tunnel interface MTU no greater than the value of the outgoing interface MTU minus the length of the tunnel headers.
# Set the MTU on interface Tunnel 1 to 10000 bytes.
[Sysname-Tunnel1] mtu 10000
reset counters interface
Use reset counters interface to clear interface statistics.
reset counters interface [ tunnel [ number ] ]
tunnel: Specifies a tunnel interface.
Use this command to clear old statistics so you can observe new traffic statistics on a tunnel interface.
·     If you do not specify any parameters, this command clears statistics for all interfaces.
·     If you specify only the tunnel keyword, this command clears statistics for all tunnel interfaces.
·     If you specify both the tunnel keyword and the number argument, this command clears statistics for the specified tunnel interface.
# Clear statistics for interface Tunnel 1.
<Sysname> reset counters interface tunnel 1
shutdown
Use shutdown to shut down a tunnel interface.
Use undo shutdown to bring up a tunnel interface.
shutdown
The tunnel interface is not in the Administratively DOWN state.
This command disconnects all links set up on the interface. Make sure you fully understand the impact of the command on your network.
# Shut down interface Tunnel 1.
[Sysname-Tunnel1] shutdown
source
Use source to specify the source address or source interface for the tunnel interface.
Use undo source to restore the default.
source { ip-address | ipv6-address | interface-type interface-number }
undo source
No source address or source interface is specified for the tunnel interface.
ip-address: Specifies the tunnel source IPv4 address.
ipv6-address: Specifies the tunnel source IPv6 address.
interface-type interface-number: Specifies the source interface. The interface must be up and must have an IP address.
The specified source address or the address of the specified source interface is used as the source address of tunneled packets. To display the configured tunnel source address, use the display interface tunnel command.
The source address of the local tunnel interface must be the destination address of the peer tunnel interface, and vice versa.
# Specify VLAN-interface 10 as the source interface of interface Tunnel 1.
[Sysname-Tunnel1] source vlan-interface 10
# Specify 192.100.1.1 as the source address of interface Tunnel 1.
[Sysname-Tunnel1] source 192.100.1.1
·     destination
·     interface tunnel
tunnel dfbit enable
Use tunnel dfbit enable to set the Don't Fragment (DF) bit for tunneled packets.
Use undo tunnel dfbit enable to restore the default.
tunnel dfbit enable
The DF bit is not set for tunneled packets.
To avoid fragmentation and delay, set the DF bit for tunneled packets. Make sure the path MTU is larger than the tunneled packet length. To avoid discarding tunneled packets whose length is larger than the path MTU, do not set the DF bit.
This command is not supported on a GRE/IPv6 tunnel interface.
# Set the DF bit for tunneled packets on interface Tunnel 1.
[Sysname-Tunnel1] tunnel dfbit enable
tunnel tos
Use tunnel tos to set the ToS of tunneled packets.
Use undo tunnel tos to restore the default.
tunnel tos tos-value
undo tunnel tos
The ToS of tunneled packets is the same as the ToS of the original packets.
tos-value: Specifies the ToS of tunneled packets, in the range of 0 to 255.
After you configure this command, all the tunneled packets of different services sent on the tunnel interface will use the same configured ToS. For more information about ToS, see ACL and QoS Configuration Guide.
# Set the ToS of tunneled packets to 20 on interface Tunnel 1.
[Sysname-Tunnel1] tunnel tos 20
tunnel ttl
Use tunnel ttl to set the Time to Live (TTL) of tunneled packets.
Use undo tunnel ttl to restore the default.
tunnel ttl ttl-value
undo tunnel ttl
The TTL of tunneled packets is 255.
ttl-value: Specifies the TTL of tunneled packets, in the range of 1 to 255.
The TTL determines the maximum number of hops that the tunneled packets can pass. When the TTL expires, the tunneled packets are discarded to avoid loops.
# Set the TTL of tunneled packets to 100 on interface Tunnel 1.
[Sysname-Tunnel1] tunnel ttl 100
