04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Command Reference
16-RIP Commands
16-RIP Commands 124.44 KB
RIP configuration commands
checkzero
Use checkzero to enable zero field check on RIPv1 messages.
Use undo checkzero to disable zero field check.
checkzero
undo checkzero
The zero field check function is enabled.
RIP view
Default command level
2: System level
When the zero field check is enabled, the router discards RIPv1 messages in which zero fields contains non-zero values. If all messages are trustworthy, disable this feature to reduce the workload of the CPU.
# Disable the zero field check on RIPv1 messages for RIP process 100.
[Sysname] rip 100
[Sysname-rip-100] undo checkzero
default cost (RIP view)
Use default cost to configure a default metric for redistributed routes.
Use undo default cost to restore the default.
default cost value
undo default cost
The default metric of redistributed routes is 0.
RIP view
2: System level
value: Specifies a default metric for redistributed routes, in the range of 0 to 16.
When you use the import-route command to redistribute routes from another routing protocol without specifying a metric, the metric specified by the default cost command applies.
# Configure a default metric of 3 for redistributed routes.
[Sysname] rip 100
[Sysname-rip-100] default cost 3
import-route
default-route
Use default-route to configure all the interfaces running a RIP process to advertise a default route with a specified metric to RIP neighbors.
Use undo default-route to disable all the interfaces running the RIP process from sending a default route.
default-route { only | originate } [ cost cost ]
undo default-route
No default route is sent to RIP neighbors.
RIP view
2: System level
only: Advertises only a default route.
originate: Advertises both a default route and other routes.
cost: Specifies a cost for the default route, in the range of 1 to 15. The default is 1.
A RIP router configured with this feature does not receive any default routes from RIP neighbors.
# Configure all the interfaces running RIP process 100 to send only a default route with a metric of 2 to RIP neighbors.
[Sysname] rip 100
[Sysname-rip-100] default-route only cost 2
rip default-route
display rip
Use display rip to display state and configuration information for a RIP process.
display rip [ process-id ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
process-id: Specifies a RIP process by its ID in the range of 1 to 65535. If no process ID is specified, the command displays information about all configured RIP processes.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the current state and configuration information for all configured RIP processes.
<Sysname> display rip
    RIP process : 1
       RIP version : 1
       Preference : 100
       Checkzero : Enabled
       Default-cost : 0
       Summary : Enabled
       Hostroutes : Enabled
       Maximum number of balanced paths : 8
       Update time   :   30 sec(s)  Timeout time         :  180 sec(s)
       Suppress time :  120 sec(s)  Garbage-collect time :  120 sec(s)
       update output delay :   20(ms)  output count :    3
       TRIP retransmit time :    5 sec(s)
       TRIP response packets retransmit count :   36
       Silent interfaces : None
       Default routes : Only  Default route cost : 3
       Verify-source : Enabled
       Networks :
           192.168.1.0
       Configured peers : None
       Triggered updates sent : 0
       Number of routes changes : 0
       Number of replies to queries : 0
RIP process
RIP process ID.
RIP version
RIP version 1 or 2.
Preference
RIP route priority.
Checkzero
Indicates whether the zero field check is enabled for RIPv1 messages.
Default-cost
Default cost of the redistributed routes.
Summary
Indicates whether route summarization is enabled.
Hostroutes
Indicates whether to receive host routes.
Maximum number of load balanced routes.
Update time
RIP update interval.
Timeout time
RIP timeout time.
Suppress time
RIP suppress interval.
update output delay
RIP packet sending interval.
output count
Maximum number of RIP packets sent at each interval.
RIP garbage collection interval.
TRIP retransmit interval for sending update requests and responses.
Maximum retransmit times for update requests and responses.
Silent interfaces
Number of silent interfaces, which do not periodically send updates.
Default routes
Indicates whether a default route is sent to RIP neighbors:
·     only—Only a default route is advertised.
·     originate—A default route is advertised along with other routes.
·     disable—No default route is advertised.
Default route cost
Cost of the default route.
Verify-source
Indicates whether the source IP address is checked on the received RIP routing updates.
Networks
Networks enabled with RIP.
Configured peers
Configured neighbors.
Number of sent triggered updates.
Number of changed routes in the database.
Number of RIP responses.
display rip database
Use display rip database to display active routes in the database of the specified RIP process, which are sent in normal RIP routing updates.
display rip process-id database [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the active routes for RIP process 100.
<Sysname> display rip 100 database
   10.0.0.0/8, cost 1, ClassfulSumm
   10.0.0.0/24, cost 1, nexthop 10.0.0.1, Rip-interface
   11.0.0.0/8, cost 1, ClassfulSumm
   11.0.0.0/24, cost 1, nexthop 10.0.0.1, Imported
X.X.X.X/X
Destination address and subnet mask.
cost
Cost of the route.
classful-summ
Indicates that the route is a RIP summary route.
Nexthop
Address of the next hop.
Rip-interface
Routes learned from a RIP-enabled interface.
imported
Routes redistributed from other routing protocols.
display rip interface
Use display rip interface to display the RIP interface information for a RIP process.
display rip process-id interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If no interface is specified, the command displays information about all RIP interfaces for the RIP process.
# Display information about all interfaces for RIP process 1.
<Sysname> display rip 1 interface
 Interface-name: GigabitEthernet1/0/5
         Address/Mask:1.1.1.1/24        Version:RIPv1
         MetricIn:5                     MetricIn route policy:123
         MetricOut:5                    MetricOut route policy:234
         Split-horizon/Poison-reverse:on/off  Input/Output:on/on
         Default route:off
         Current packets number/Maximum packets number:234/2000
Interface-name
Name of an interface running RIP.
Address/Mask
IP address and mask of the interface.
Version
RIP version running on the interface.
MetricIn
Additional routing metric added to the incoming routes.
Name of the routing policy used to add the additional routing metric for the incoming routes. If no routing policy is referenced, the field displays Not designated.
MetricOut
Additional routing metric added to the outgoing routes.
Name of the routing policy used to add the additional routing metric for the outgoing routes. If no routing policy is referenced, the field displays Not designated.
Split-horizon
Indicates whether split-horizon is enabled:
·     on—Enabled.
·     off—Disabled.
Poison-reverse
Indicates whether poison-reverse is enabled:
·     on—Enabled.
·     off—Disabled.
Input/Output
Indicates if the interface is allowed to receive (Input) or send (Output) RIP messages:
·     on—Allowed.
·     off—Not allowed.
Default route
Indicates whether sending the default route to RIP neighbors is allowed:
·     on—Allowed.
·     off—Not allowed.
Packets to be sent/Maximum packets that can be sent on the interface.
display rip route
Use display rip route to display the routing information of a specified RIP process.
display rip process-id route [ ip-address { mask | mask-length } | peer ip-address | statistics ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ip-address { mask | mask-length }: Displays route information for the specified IP address.
peer ip-address: Displays all routing information learned from a specified neighbor.
statistics: Displays the route statistics, including total number of routes and number of routes of each neighbor.
# Display all routing information for RIP process 1.
<Sysname> display rip 1 route
 Peer 111.1.1.2  on GigabitEthernet1/0/5
      Destination/Mask        Nexthop     Cost    Tag   Flags   Sec
        122.0.0.0/8          111.1.1.2      1       0    RA      22
Route Flags
Route flags:
·     R—RIP route.
·     T—TRIP route.
·     P—The route never expires.
·     A—The route is aging.
·     S—The route is suppressed.
·     G—The route is in Garbage-collect state.
Peer 21.0.0.23 on GigabitEthernet1/0/5
Routing information learned on a RIP interface from the specified neighbor.
Destination/Mask
Destination IP address and subnet mask.
Nexthop
Next hop of the route.
Cost
Cost of the route.
Tag
Route tag.
Flags
Indicates the route state.
Sec
Remaining time of the timer corresponding to the route state.
# Display the routing statistics for RIP process 1.
<Sysname> display rip 1 route statistics
 Peer            Aging     Permanent    Garbage
 111.1.1.2        1         0             0
 Total            1         0             0
Table 5 Command output
Peer
IP address of a neighbor.
Aging
Total number of aging routes learned from the specified neighbor.
Permanent
Total number of permanent routes learned from the specified neighbor.
Garbage
Total number of routes in the Garbage-collection state learned from the specified neighbor.
Total
Total number of routes learned from all RIP neighbors.
filter-policy export (RIP view)
Use filter-policy export to configure RIP to filter outbound routes.
Use undo filter-policy export to remove the filtering.
filter-policy { acl-number | ip-prefix ip-prefix-name } export [ protocol [ process-id ] | interface-type interface-number ]
undo filter-policy export [ protocol [ process-id ] | interface-type interface-number ]
RIP does not filter outbound routes.
RIP view
2: System level
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter outbound routes.
ip-prefix ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters, to filter outbound routes.
protocol: Filters outbound routes redistributed from a specified routing protocol, which can be direct, rip, and static.
process-id: Specifies the process ID of the specified routing protocol, in the range of 1 to 65535. You need to specify a process ID when the routing protocol is rip.
If a protocol is specified, RIP filters only the routes redistributed from the specified routing protocol. Otherwise, RIP filters all outbound routes.
If an interface is, RIP filters only the routes advertised by the specified interface. Otherwise, RIP filters routes advertised by all RIP interfaces.
To reference an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL in one of the following ways:
·     To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command
·     To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route. The specified subnet mask must be contiguous. Otherwise, the configuration does not take effect.
# Use ACL 2000 to filter outbound routes.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 export
# Use IP prefix list abc to filter outbound routes on GigabitEthernet 1/0/5.
[Sysname-rip-1] filter-policy ip-prefix abc export gigabitethernet 1/0/5
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass. Use ACL 3000 to filter outbound routes.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-adv-3000] rule 100 deny ip
[Sysname-acl-adv-3000] quit
[Sysname] rip 1
[Sysname-rip 1] filter-policy 3000 export
·     acl (ACL and QoS Command Reference)
·     import-route
filter-policy import (RIP view)
Use filter-policy import to configure RIP to filter the inbound routes.
Use undo filter-policy import to restore the default.
filter-policy { acl-number | gateway ip-prefix-name | ip-prefix ip-prefix-name [ gateway ip-prefix-name ] } import [ interface-type interface-number ]
undo filter-policy import [ interface-type interface-number ]
RIP does not filter inbound routes.
RIP view
2: System level
acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter inbound routes.
ip-prefix ip-prefix-name: Specifes an IP prefix list by its name, a string of 1 to 19 characters, to filter inbound routes.
gateway ip-prefix-name: Specifies an IP prefix list by its name, a string of 1 to 19 characters, to filter routes from the gateway.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route. The subnet mask must be contiguous. Otherwise, the configuration does not take effect.
# Use ACL 2000 to filter inbound RIP routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 2000 import
# Use IP prefix list abc on GigabitEthernet 1/0/5 to filter all inbound RIP routes.
[Sysname-rip-1] filter-policy ip-prefix abc import gigabitethernet 1/0/5
# Configure ACL 3000 to permit only route 113.0.0.0/16 to pass. Use ACL 3000 to filter inbound routes.
[Sysname] rip 1
[Sysname-rip-1] filter-policy 3000 import
host-route
Use host-route to enable host route reception.
Use undo host-route to disable host route reception.
host-route
undo host-route
RIP receives host routes.
RIP view
2: System level
A router might receive many host routes from the same subnet. These routes are not helpful for routing and occupy many resources. To solve this problem, use the undo host-route command to disable RIP from receiving host routes.
This command takes effect only for RIPv2.
# Disable RIP from receiving host routes.
[Sysname] rip 1
[Sysname-rip-1] undo host-route
import-route (RIP view)
Use import-route to enable route redistribution from another routing protocol.
Use undo import-route to disable route redistribution.
import-route protocol [ process-id | all-processes ] [ cost cost | tag tag ] *
RIP does not redistribute routes from any other routing protocol.
RIP view
2: System level
protocol: Specifies a routing protocol from which to redistribute routes. It can be direct, rip, or static.
process-id: Specifies a process by its ID, in the range of 1 to 65535. The default is 1. This argument is available only when the protocol is rip.
all-processes: Enables route redistribution from all the processes of the specified protocol. This keyword takes effect only when the protocol is rip.
cost:  Specifies a cost for redistributed routes, in the range of 0 to 16. If no cost is specified, the default cost specified by the default cost command applies.
tag: Specifies a tag for marking redistributed routes, in the range of 0 to 65535. The default is 0.
This command redistributes only active routes. To view route state information, use the display ip routing-table protocol command.
The undo import-route protocol all-processes command removes only the configuration made by the import-route protocol all-processes command, instead of the configuration made by the import-route protocol process-id command.
# Redistribute static routes into RIP, and set the cost for redistributed routes to 4.
[Sysname] rip 1
[Sysname-rip-1] import-route static cost 4
# Configure a default cost of 3 for redistributed routes.
[Sysname-rip-1] default cost 3
default cost
maximum load-balancing (RIP view)
Use maximum load-balancing to specify the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of ECMP routes is 4.
RIP view
2: System level
number: Specifies the maximum number of ECMP routes. The value range is 1 to 4.
# Specify the maximum number of ECMP routes as 2.
[Sysname] rip
[Sysname-rip-1] maximum load-balancing 2
network
Use network to enable RIP on an interface attached to a specified network.
Use undo network to disable RIP on an interface attached to a specified network.
network network-address
undo network network-address
RIP is disabled on an interface.
RIP view
2: System level
network-address: Specifies a subnet address where an interface resides.
RIP runs only on an interfaces attached to the specified network. An interface not on the specified network does not receive or send routes, or advertise its direct routes.
For a single process, the network 0.0.0.0 command can enable RIP on all interfaces. If multiple RIP processes exist, the command is not applicable.
If a physical interface is attached to multiple networks, you cannot advertise these networks in different RIP processes.
# Enable RIP on the interface attached to the network 129.102.0.0.
[Sysname] rip 100
[Sysname-rip-100] network 129.102.0.0
output-delay
Use output-delay to configure the rate at which an interface sends RIP packets.
Use undo output-delay to restore the default.
output-delay time count count
undo output-delay
An interface sends up to three RIP packets every 20 milliseconds.
RIP view
2: System level
time: Specifies the sending interval, in the range of 10 to 100 milliseconds.
count: Specifies the maximum number of RIP packets sent at each interval, in the range of 1 to 20.
# Configure all interfaces running RIP process 1 to send up to 10 RIP packets every 30 milliseconds.
[Sysname] rip 1
[Sysname-rip-1] output-delay 30 count 10
peer
Use peer to specify an IP address for a neighbor in the NBMA network, where routing updates destined for the peer are unicast, rather than multicast or broadcast.
Use undo peer to remove the IP address of a neighbor.
peer ip-address
undo peer ip-address
No neighbor is specified.
RIP view
2: System level
ip-address: Specifies the IP address of a RIP neighbor, in dotted decimal notation.
Do not use the peer ip-address command when the neighbor is directly connected. Otherwise the neighbor might receive the same routing information in both unicast and multicast (or broadcast) mode.
# Specify RIP to unicast updates to peer 202.38.165.1.
[Sysname] rip 1
[Sysname-rip-1] peer 202.38.165.1
preference
Use preference to specify a preference for RIP routes.
Use undo preference to restore the default.
preference value
undo preference
The preference of RIP routes is 100.
RIP view
2: System level
value: Specifies a preference for RIP routes, in the range of 1 to 255. The smaller the value, the higher the preference.
# Set a preference of 120 for RIP routes.
[Sysname] rip 1
[Sysname-rip-1] preference 120
reset rip process
Use reset rip process to reset a RIP process.
reset rip process-id process
1: Monitor level
After you execute the command, you are prompted to confirm the operation.
# Reset RIP process 100.
<Sysname> reset rip 100 process
Warning : Reset RIP process? [Y/N]:y
reset rip statistics
Use reset rip statistics to clear statistics for a RIP process.
reset rip process-id statistics
2: System level
# Clear statistics for RIP process 100.
<Sysname> reset rip 100 statistics
rip
Use rip to create a RIP process and enter RIP view.
Use undo rip to disable a RIP process.
rip [ process-id ]
undo rip [ process-id ]
No RIP process runs.
2: System level
process-id: Specifies a RIP process by its ID in the range of 1 to 65535. The default is 1.
You must create a RIP process before configuring global parameters for it. This restriction does not apply to configuring interface parameters.
If you disable the RIP process, the configured interface parameters become invalid.
# Create a RIP process and enter RIP process view.
[Sysname] rip
[Sysname-rip-1]
rip authentication-mode
Use rip authentication-mode to configure RIPv2 authentication.
Use undo rip authentication-mode to cancel RIPv2 authentication.
rip authentication-mode { md5 { rfc2082 [ cipher ] key-string key-id | rfc2453 [ cipher ] key-string } | simple [ cipher ] password }
Interface view
2: System level
md5: Specifies the MD5 authentication mode.
rfc2082: Uses the message format defined in RFC 2082.
cipher: Sets a ciphertext authentication key or password. If this keyword is not specified, you set a plaintext authentication key or password.
key-string: Specifies the MD5 key string. This argument is case sensitive. It must be a plaintext string of 1 to 16 characters, or a ciphertext string of 33 to 53 characters.
key-id: Specifies the MD5 key number, in the range of 1 to 255.
rfc2453: Uses the message format defined in RFC 2453 (IETF standard).
simple: Specifies the simple authentication mode.
password: Sets the password in simple authentication mode. This argument is case sensitive. It must be a plaintext string of 1 to 16 characters, or a ciphertext string of 33 to 53 characters.
A newly configured key string or password overwrites the old one, if any.
For secrecy, all keys or passwords, including keys or passwords configured in plain text, are saved in cipher text.
Although you can specify an authentication mode for RIPv1 in interface view, the configuration does not take effect because RIPv1 does not support authentication.
# Configure MD5 authentication on GigabitEthernet 1/0/5, and specify a plaintext key rose in the format defined in RFC 2453.
[Sysname] interface gigabitethernet 1/0/5
[Sysname-GigabitEthernet1/0/5] rip version 2
[Sysname-GigabitEthernet1/0/5] rip authentication-mode md5 rfc2453 rose
rip version
rip default-route
Use rip default-route to configure a RIP interface to advertise a default route with a specified metric.
Use undo rip default-route to disable the RIP interface from sending a default route.
rip default-route { { only | originate } [ cost cost ] | no-originate }
A RIP interface can advertise a default route if the RIP process runs is enabled to advertise a default route.
Interface view
2: System level
originate: Advertises a default route and other routes.
no-originate: Advertises only non-default route.
A RIP interface that is enabled to advertise a default does not receive any default routes from RIP neighbors.
# Configure GigabitEthernet 1/0/5 to advertise only a default route with a metric of 2.
[Sysname-GigabitEthernet1/0/5] rip default-route only cost 2
default-route
rip input
Use rip input to enable an interface to receive RIP messages.
Use undo rip input to disable an interface from receiving RIP messages.
rip input
undo rip input
An interface is enabled to receive RIP messages.
Interface view
2: System level
# Enable GigabitEthernet 1/0/5 to receive RIP messages.
[Sysname-GigabitEthernet1/0/5] rip input
rip metricin
Use rip metricin to configure an interface to add a metric to inbound routes.
Use undo rip metricin to restore the default.
rip metricin value
undo rip metricin
The additional metric of an inbound route is 0.
Interface view
2: System level
value: Add an additional metric to inbound routes, in the range of 0 to 16.
When a valid RIP route is received, the system adds a metric to it and then installs it into the routing table. The metric of the route received on the configured interface is then increased. If the sum of the additional metric and the original metric is greater than 16, the metric of the route will be 16.
# Configure GigabitEthernet 1/0/5 to add a metric of 6 to the inbound route 1.0.0.0/8 and to add a metric of 2 to other inbound routes.
[Sysname] ip ip-prefix 123 permit 1.0.0.0 8
[Sysname] route-policy abc permit node 0
[Sysname-route-policy] if-match ip-prefix 123
[Sysname-route-policy] apply cost 6
[Sysname-GigabitEthernet1/0/5] rip metricin route-policy abc 2
rip metricout
Use rip metricout to configure an interface to add a metric to outbound routes.
Use undo rip metricout to restore the default.
rip metricout value
undo rip metricout
The additional metric for outbound routes is 1.
Interface view
value: Add an additional metric to outbound routes, in the range of 1 to 16.
With the command configured on an interface, the metric of RIP routes sent on the interface is increased.
# Configure GigabitEthernet 1/0/5 to add a metric of 6 to the outbound route 1.0.0.0/8 and to add a metric of 2 to other outbound routes.
[Sysname-GigabitEthernet1/0/5] rip metricout route-policy abc 2
rip mib-binding
Use rip mib-binding to bind MIB operations with a specified RIP process, so that the RIP process can receive SNMP requests.
Use undo rip mib-binding to restore the default.
rip mib-binding process-id
MIB operations are bound to RIP process 1. RIP process 1 is enabled to receive SNMP requests.
2: System level
process-id: RIP process ID, in the range of 1 to 65535.
# Enable RIP process 100 to receive SNMP requests.
[Sysname] rip mib-binding 100
# Restore the default.
[Sysname] undo rip mib-binding
rip output
Use rip output to enable the interface to send RIP messages.
Use undo rip output to disable the interface from sending RIP messages.
rip output
undo rip output
Sending RIP messages is enabled on an interface.
Interface view
2: System level
[Sysname-GigabitEthernet1/0/5] rip output
rip poison-reverse
Use rip poison-reverse to enable the poison reverse function.
Use undo rip poison-reverse to disable the poison reverse function.
rip poison-reverse
The poison reverse function is disabled.
Interface view
2: System level
# Enable the poison reverse function for RIP routing updates on GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] rip poison-reverse
rip split-horizon
Use rip split-horizon to enable the split horizon function.
Use undo rip split-horizon to disable the split horizon function.
rip split-horizon
The split horizon function is enabled.
Interface view
2: System level
·     The split horizon function prevents routing loops. If you want to disable the function, make sure the operation is dispensable.
·     On NBMA networks, such as FR and X.25 where multiple VCs are configured on the primary and secondary interfaces, disable split horizon to ensure route advertisement.
·     If both split horizon and poison reverse are enabled, only the poison reverse function takes effect.
# Enable the split horizon function on GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] rip split-horizon
rip summary-address
Use rip summary-address to configure RIPv2 to advertise a summary route on an interface.
Use undo rip summary-address to remove the configuration.
rip summary-address ip-address { mask | mask-length }
undo rip summary-address ip-address { mask | mask-length }
Interface view
2: System level
ip-address: Specifies the destination IP address of summary route.
mask: Specifies the subnet mask of summary route, in dotted decimal notation.
mask-length: Specifies the subnet mask length of summary route, in the range of 0 to 32.
The summary address takes effect only when the automatic summarization is disabled.
# Advertise a local summary address on GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] rip summary-address 10.0.0.0 255.255.255.0
summary
rip version
Use rip version to specify a RIP version for the interface.
Use undo rip version to remove the specified RIP version.
rip version { 1 | 2 [ broadcast | multicast ] }
undo rip version
No RIP version is configured for an interface, which uses the global RIP version. If the global RIP version is not configured, the interface can only send RIPv1 broadcasts and can receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
Interface view
2: System level
1: Specifies RIP version 1.
2: Specifies RIP version 2.
broadcast: Sends RIPv2 messages in broadcast mode.
multicast: Sends RIPv2 messages in multicast mode.
If RIPv2 is specified with no sending mode configured, RIPv2 messages are sent in multicast mode.
When RIPv1 runs on an interface, the interface can perform the following operations:
·     Sends RIPv1 broadcast messages.
·     Receives RIPv1 broadcast and unicast messages.
When RIPv2 runs on the interface in broadcast mode, the interface can perform the following operations:
·     Sends RIPv2 broadcast messages.
·     Receives RIPv1 broadcast and unicast messages, and RIPv2 broadcast, multicast, and unicast messages.
When RIPv2 runs on the interface in multicast mode, the interface can perform the following operations:
·     Sends RIPv2 multicast messages.
·     Receives RIPv2 broadcast, multicast, and unicast messages.
# Configure GigabitEthernet 1/0/5 to broadcast RIPv2 messages.
[Sysname-GigabitEthernet1/0/5] rip version 2 broadcast
silent-interface (RIP view)
Use silent-interface to disable an interface from sending routing updates. The interface can still receive routing updates.
Use undo silent-interface to restore the default.
All interfaces are allowed to send routing updates.
RIP view
2: System level
interface-type interface-number: Disables an specified interface from sending routing updates.
all: Disables all interfaces from sending routing updates.
# Configure all interfaces to operate in silent mode except GigabitEthernet 1/0/5.
[Sysname] rip 100
[Sysname-rip-100] silent-interface all
[Sysname-rip-100] undo silent-interface gigabitethernet 1/0/5
[Sysname-rip-100] network 131.108.0.0
summary
Use summary to enable automatic RIPv2 summarization. Natural masks are used to advertise summary routes so as to reduce the size of routing tables.
Use undo summary to disable automatic RIPv2 summarization to advertise all subnet routes.
summary
undo summary
Automatic RIPv2 summarization is enabled.
RIP view
2: System level
Automatic RIPv2 summarization can reduce the routing table size to enhance the scalability and efficiency of large networks.
# Disable RIPv2 automatic summarization.
[Sysname] rip
[Sysname-rip-1] undo summary
rip version
timers
Use timers to configure RIP timers.
Use undo timers to restore the default.
timers { garbage-collect garbage-collect-value | suppress suppress-value | timeout timeout-value | update update-value }*
undo timers { garbage-collect | suppress | timeout | update } *
The garbage-collect timer is 120 seconds, the suppress timer is 120 seconds, the timeout timer is 180 seconds, and the update timer is 30 seconds.
RIP view
2: System level
garbage-collect-value: Specifies the garbage-collect timer time in seconds, in the range of 1 to 3600.
suppress-value: Specifies the suppress timer time in seconds, in the range of 0 to 3600.
timeout-value: Specifies the timeout timer time in seconds, in the range of 1 to 3600.
update-value: Specifies the update timer time in seconds, in the range of 1 to 3600.
RIP is controlled by the following timers:
·     Update timer—Specifies the interval between routing updates.
·     Timeout timer—Specifies the route aging time. If no update for a route is received before the time expires, the metric of the route is set to 16.
·     Suppress timer—Specifies how long a RIP route stays in suppressed state. When the metric of a route becomes 16, the route enters the suppressed state. If RIP receives an update for the route from the same neighbor and the route in the update has a metric less than 16, RIP uses the route to replace the suppressed route.
·     Garbage-collect timer—Specifies the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIP advertises the route with a metric of 16. If no update is announced for that route before the garbage-collect timer expires, RIP deletes the route from the routing table.
H3C does not recommend changing the default values of these timers.
The time lengths must be consistent on all routers in the network.
# Specifies the update, timeout, suppress, and garbage-collect timers as 5, 15, 15 and 30 seconds.
[Sysname] rip 100
[Sysname-rip-100] timers update 5 timeout 15 suppress 15 garbage-collect 30
validate-source-address
Use validate-source-address to enable the source IP address check on inbound RIP routing updates.
Use undo validate-source-address to disable the source IP address check.
Source IP address check on inbound RIP routing updates is enabled.
RIP view
2: System level
H3C does not recommend disabling source IP address check.
# Disable the source IP address check on inbound RIP routing updates.
[Sysname-rip] rip 100
[Sysname-rip-100] undo validate-source-address
version
Use version to specify a global RIP version.
Use undo version to remove the configuration.
version { 1 | 2 }
undo version
If an interface has a RIP version specified, the RIP version takes effect. If it has no RIP version specified, it can send RIPv1 broadcasts, and receive RIPv1 broadcasts and unicasts, and RIPv2 broadcasts, multicasts, and unicasts.
RIP view
2: System level
1: Specifies the RIP version as RIPv1.
2: Specifies the RIP version as RIPv2. RIPv2 messages are multicast.
An interface prefers the RIP version configured on it over the global RIP version. If no RIP version is specified for the interface and the global version is RIPv1, the interface uses RIPv1, and it can send RIPv1 broadcasts, and receive RIPv1 broadcasts and unicasts. If no RIP version is specified for the interface and the global version is RIPv2, the interface uses RIPv2 multicast mode, and it can send RIPv2 multicasts, and receive RIPv2 broadcasts, multicasts, and unicasts.
# Specify RIPv2 as the global RIP version.
[Sysname] rip 100
[Sysname-rip-100] version 2
