04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Command Reference
15-GRE Commands
15-GRE Commands 98.86 KB
GRE configuration commands
Support for GRE configuration commands depends on the device model. For more information, see About the H3C Access Controllers Command References.
destination
Use destination to specify the destination address for a tunnel interface.
Use undo destination to remove the configured tunnel destination address.
destination { ip-address | ipv6-address }
undo destination
No tunnel destination address is configured.
Tunnel interface view
Default command level
2: System level
ip-address: Tunnel destination IPv4 address.
ipv6-address: Tunnel destination IPv6 address.
The tunnel destination address is the address of the peer interface receiving packets and should be configured as the source address of the peer tunnel interface.
Automatic tunnel interfaces using the same encapsulation protocol must have different source addresses. Manual tunnel interfaces using the same encapsulation protocol must have different source and destination addresses.
# VLAN-interface 100 of Sysname 1 uses the IP address 193.101.1.1 and VLAN-interface 100 of Sysname 2 uses the IP address 192.100.1.1. Configure source and destination addresses for the tunnel between Sysname 1 and Sysname 2.
// Configure the source address 193.101.1.1 and destination address 192.100.1.1 for the tunnel interface of Sysname 1.
<Sysname1> system-view
[Sysname1] interface tunnel 0
[Sysname1-Tunnel0] source 193.101.1.1
[Sysname1-Tunnel0] destination 192.100.1.1
// Configure the source address 192.100.1.1 and destination address 193.101.1.1 for the tunnel interface of Sysname 2.
<Sysname2> system-view
[Sysname2] interface tunnel 1
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
# GigabitEthernet 1/0/5 of Sysname 1 uses the IP address 193.101.1.1 and GigabitEthernet 1/0/5 of Sysname 2 uses the IP address 192.100.1.1. Configure source and destination addresses for the tunnel between Sysname 1 and Sysname 2.
·     source
·     interface tunnel
·     display interface tunnel
·     display ipv6 interface tunnel
Use display interface tunnel to display information about tunnel interfaces, including the source address, destination address, and tunnel mode.
display interface [ tunnel ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface tunnel number [ brief ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
number: Number of a tunnel interface.
down: Displays information about interfaces in the DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you do not specify the tunnel keyword, this command displays information about all interfaces on the device.
If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
# Display detailed information about interface Tunnel 0.
<Sysname> display interface tunnel 0
Tunnel0 current state: UP
The Maximum Transmit Unit is 1476
Internet Address is 1.1.1.1/24 Primary
Encapsulation is TUNNEL, service-loopback-group ID not set.
Tunnel source 10.1.1.1, destination 10.1.1.2
Tunnel bandwidth 64 (kbps)
Tunnel keepalive enabled, Period(50 s), Retries(3)
Tunnel protocol/transport GRE/IP
    GRE key disabled
    Checksumming of GRE packets disabled
 Last clearing of counters:  Never
    Last 300 seconds input:  0 bytes/sec, 0 packets/sec
    Last 300 seconds output:  0 bytes/sec, 0 packets/sec
    0 packets input,  0 bytes
    0 input error
    0 packets output,  0 bytes
    0 output error
Physical state of the tunnel interface:
·     Administratively DOWN—The interface has been shut down by the shutdown command.
·     DOWN—The interface is administratively up but its physical state is down.
·     UP—Both the administrative and physical states of the interface are up.
Link layer state of the tunnel interface:
·     DOWN—The protocol state of the interface is down.
·     UP—The protocol state of the interface is up.
Description of the tunnel interface.
MTU of the tunnel interface.
Internet Address
IP address of the tunnel interface.
If no IP address is assigned to the interface, "Internet protocol processing : disabled" is displayed, which means that the tunnel interface cannot process packets.
Primary indicates it is the primary IP address of the interface. Sub indicates it is a secondary IP address of the interface.
The encapsulation protocol is tunnel.
ID of the service loopback group referenced by the tunnel.
If service loopback group is not supported or not specified, "service-loopback-group ID not set" is displayed.
Tunnel source
Source address of the tunnel.
destination
Destination address of the tunnel.
Tunnel bandwidth
Bandwidth of the tunnel interface.
GRE keepalive is enabled to detect the state of the tunnel interface. In this example, keepalive packets are sent every 50 seconds, and the maximum retries are three.
Tunnel mode and transport protocol:
·     GRE/IP—GRE over IPv4 tunnel mode.
·     GRE/IPv6—GRE over IPv6 tunnel mode.
·     IPsec/IP—IPsec over IPv4 tunnel mode.
·     IPsec/IPv6—IPsec over IPv6 tunnel mode.
GRE key disabled
Tunnel interface key option of GRE is not configured.
GRE packet checksum function is disabled.
Last time of clearing of counters.
Average input rate in the last 300 seconds in bytes/sec or packets/sec.
Average output rate in the last 300 seconds in bytes/sec or packets/sec.
packets input
Total number of input packets.
input error
Number of input error packets.
packets output
Total number of output packets.
output error
Number of output error packets.
# Display brief information about interface Tunnel 0.
<Sysname> display interface tunnel 0 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Tun0                 UP   UP       1.1.1.1
# Display brief information about the interface Tunnel 1 in the DOWN state.
<Sysname> display interface tunnel brief down
Tun1                 DOWN Not connected
Brief information about Layer 3 interfaces.
Link status:
·     ADM—The interface has been administratively shut down by the undo shutdown command.
·     Stby—The interface is a backup interface. To see the primary interface, use the display standby state command in High Availability Command Reference.
(s) indicates that the network layer protocol state is UP, but the link is not available because it is either an on-demand link or not present at all.
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The link is physically up.
·     DOWN—The link is physically down.
·     ADM—The link has been administratively shut down. To bring it up, perform the undo shutdown command.
Protocol
Protocol state:
·     DOWN—The protocol is disabled.
·     UP—The protocol is enabled.
Main IP
Primary IP address of the interface.
Description of the interface.
Cause
Cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To bring up the port, use the undo shutdown command.
·     interface tunnel
·     source
·     destination
·     tunnel-protocol
Use display ipv6 interface tunnel to display IPv6 information for tunnel interfaces.
display ipv6 interface tunnel [ number ] [ brief ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
number: Displays IPv6 information on a specific tunnel interface. If no interface number is specified, IPv6 information about all tunnel interfaces is displayed.
brief: Displays brief information of tunnel interfaces. If this keyword is not specified, detailed information and IPv6 packet statistics for tunnel interfaces are displayed.
# Display detailed IPv6 information and IPv6 packet statistics for interface Tunnel 0.
<Sysname> display ipv6 interface tunnel 0
Tunnel0 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::202:201
  Global unicast address(es):
    3000::1, subnet is 3000::/64
  Joined group address(es):
    FF02::1:FF02:201
    FF02::1:FF00:1
    FF02::1:FF00:0
    FF02::2
    FF02::1
  MTU is 1480 bytes
IPv6 Packet statistics:
  InReceives:                    45
  InTooShorts:                   0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    45
  OutRequests:                   45
  OutForwDatagrams:              0
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   0
  InMcastNotMembers:             0
  OutMcastPkts:                  0
  InAddrErrors:                  0
·     DOWN—Indicates that the protocol state of the interface is down.
·     UP—Indicates that the protocol state of the interface is up.
IPv6 is enabled
IPv6 packet forwarding state of the tunnel interface. IPv6 packet forwarding is automatically enabled after an IPv6 address is assigned to the interface. IPv6 packet forwarding is enabled in the example.
link-local address
Link-local address configured for the tunnel interface.
Global unicast addresses configured for the tunnel interface.
Multicast addresses of the tunnel interface.
MTU is 1480 bytes
Maximum transmission unit of the tunnel interface. It is 1480 bytes in the example.
ND reachable time
Neighbor reachable time.
Interval for retransmitting a neighbor solicitation message.
Hosts use stateless autoconfiguration mode to acquire IPv6 addresses.
InReceives
All IPv6 packets received by the tunnel interface, including types of error packets.
InTooShorts
Received IPv6 packets that are too short, with a length less than 40 bytes, for example.
InTruncatedPkts
Received IPv6 packets with a length less than that specified in the packets.
InHopLimitExceeds
Received IPv6 packets with a hop count exceeding the limit.
InBadHeaders
Received IPv6 packets with bad basic headers.
InBadOptions
Received IPv6 packets with bad extension headers.
ReasmReqds
Received IPv6 fragments.
ReasmOKs
Number of packets after reassembly rather than the number of fragments.
InFragDrops
IPv6 fragments discarded due to certain errors.
InFragTimeouts
IPv6 fragments discarded because the interval for which they had stayed in the system buffer exceeded the specified period.
OutFragFails
Packets failed in fragmentation on the outbound interface.
InUnknownProtos
Received IPv6 packets with unknown or unsupported protocol type.
InDelivers
Received IPv6 packets that were delivered to application layer protocols (such as ICMPv6, TCP, and UDP).
OutRequests
Local IPv6 packets sent by IPv6 application protocols.
OutForwDatagrams
Packets forwarded by the outbound interface.
InNoRoutes
IPv6 packets that were discarded because no matched route can be found.
InTooBigErrors
IPv6 packets that were received normally but discarded before they were forwarded because they exceeded the PMTU.
OutFragOKs
Packets that were fragmented on the outbound interface.
OutFragCreates
Number of packet fragments after fragmentation on the outbound interface.
InMcastPkts
IPv6 multicast packets received on the interface.
InMcastNotMembers
Incoming IPv6 multicast packets that were discarded because the interface did not belong to the corresponding multicast groups.
OutMcastPkts
IPv6 multicast packets sent by the interface.
InAddrErrors
IPv6 packets that were discarded due to invalid destination addresses.
InDiscards
Received IPv6 packets that were discarded due to resource problems rather than packet content errors.
OutDiscards
Sent packets that were discarded due to resource problems rather than packet content errors.
# Display brief IPv6 information for interface Tunnel 0.
<Sysname> display ipv6 interface tunnel 0 brief
*down: administratively down
(s): spoofing
Interface                                Physical   Protocol   IPv6 Address
Tunnel0                                    up         up       3000::1
*down
The tunnel interface is administratively shut down by the shutdown command.
(s)
Spoofing attribute of the tunnel interface. The link protocol state of the tunnel interface is up, but the link does not exist, or the link is established on demand, instead of being permanent.
Name of the tunnel interface.
Physical
·     *down—The interface has been shut down by the shutdown command.
·     down—The interface is administratively up but its physical state is down.
·     up—Both the administrative and physical states of the interface are up.
Protocol
Link layer protocol state of the tunnel interface:
·     down—The protocol state of the interface is down.
·     up—The protocol state of the interface is up.
IPv6 Address
IPv6 address of the tunnel interface. Only the first of configured IPv6 addresses is displayed. If no address is configured for the interface, Unassigned is displayed.
gre checksum
Use gre checksum to enable GRE packet checksum. This feature verifies the validity of packets and discards invalid packets.
Use undo gre checksum to disable GRE packet checksum.
gre checksum
undo gre checksum
GRE packet checksum is disabled.
2: System level
# Enable GRE packet checksum for the tunnel between devices Sysname1 and Sysname2.
// Enable GRE packet checksum on Sysname1.
[Sysname1] interface tunnel 3
[Sysname1-Tunnel3] gre checksum
// Enable GRE packet checksum on Sysname2.
[Sysname2] interface tunnel 2
[Sysname2-Tunnel2] gre checksum
·     interface tunnel
gre key
Use gre key to configure a key for a GRE tunnel interface.
Use undo gre key to remove the configuration.
gre key key-number
undo gre key
No key is configured for a GRE tunnel interface.
2: System level
key-number: Key for the GRE tunnel interface, in the range of 0 to 4294967295.
For a P2P GRE tunnel, both ends of the tunnel must be configured with the same GRE key. Otherwise, packets cannot pass the GRE key verification and will be discarded. This weak security mechanism can prevent packets from being received mistakenly.
# Set the key for the GRE tunnel interfaces to 123 on devices Sysname1 and Sysname2.
// Set the GRE key to 123 for GRE tunnel interface 3 on Sysname1.
[Sysname1-Tunnel3] gre key 123
// Set the GRE key to 123 for GRE tunnel interface 2 on Sysname2.
[Sysname2-Tunnel2] gre key 123
·     interface tunnel
gre recursion
Use gre recursion to specify a value for the Recursion Control field in the GRE header.
Use undo gre recursion to restore the default.
gre recursion recursion-value
undo gre recursion
The value of the Recursion Control field in the GRE header is 0, which means not to limit the number of encapsulations.
2: System level
recursion-value: Value for the Recursion Control field in the GRE header, in the range of 1 to 7.
To work with devices that require the Recursion Control field not to be 0, use this command to set the Recursion Control field to a nonzero value. The value of the Recursion Control field does not affect how many times the H3C device encapsulates a GRE packet.
# Set the Recursion Control field in the GRE header to 1.
[Sysname1-Tunnel3] gre recursion 1
interface tunnel
Use interface tunnel to create a tunnel interface and enter tunnel interface view.
Use undo interface tunnel to delete a specific tunnel interface.
undo interface tunnel number
No tunnel interface is created on the device.
2: System level
number: Number of the tunnel interface, in the range of 0 to 255. The number of tunnel interfaces that can be created is restricted by the total number of interfaces and the memory.
Use the interface tunnel command to enter the interface view of a specific tunnel. If the specified tunnel interface does not exist, the system creates the interface and enters its view.
A tunnel interface number is locally significant. The tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
# Create interface Tunnel 3 and enter tunnel interface view.
[Sysname] interface tunnel 3
[Sysname-Tunnel3]
·     source
·     destination
·     tunnel-protocol
keepalive
Use keepalive to enable GRE keepalive for a tunnel interface and set the keepalive interval and the maximum number of attempts for transmitting a keepalive packet.
Use undo keepalive to disable GRE keepalive.
keepalive [ seconds [ times ] ]
undo keepalive
GRE keepalive is disabled.
2: System level
seconds: Interval in seconds for transmitting keepalive packets, in the range of 1 to 32767. The default value is 10.
times: Maximum number of attempts for transmitting a keepalive packet, in the range of 1 to 255. The default value is 3.
With GRE keepalive enabled on a tunnel interface, the device sends GRE keepalive packets from the tunnel interface periodically. If no response is received from the peer within the specified interval, the device retransmits a keepalive packet. If the device still receives no response from the peer after sending the keepalive packet for the maximum number of attempts, the local tunnel interface goes down and stays down until it receives a keepalive acknowledgement packet from the peer.
# Set the GRE keepalive interval to 20 seconds and the maximum number of transmission attempts to 5.
[Sysname] interface tunnel 0
[Sysname-Tunnel0] keepalive 20 5
·     interface tunnel
source
Use source to specify the source address or source interface for a tunnel interface.
Use undo source to restore the default.
source { ip-address | ipv6-address | interface-type interface-number }
undo source
No source address or source interface is specified for a tunnel interface.
2: System level
ip-address: Tunnel source IPv4 address.
ipv6-address: Tunnel source IPv6 address.
interface-type interface-number: Specifies the source interface type and number.
The tunnel source address is the address of the interface sending packets and should be configured as the destination address of the peer tunnel interface.
# Set the tunnel source address to 192.100.1.1 on the interface Tunnel 5.
[Sysname] interface tunnel 5
[Sysname-Tunnel5] source 192.100.1.1
Or set the tunnel source interface to VLAN-interface 100.
[Sysname-Tunnel5] source vlan-interface 100
Or set the tunnel source interface to GigabitEthernet 1/0/5.
[Sysname-Tunnel5] source GigabitEthernet1/0/5
·     destination
·     interface tunnel
tunnel discard ipv4-compatible-packet
Use tunnel discard ipv4-compatible-packet to enable dropping of IPv6 packets using IPv4-compatible IPv6 addresses.
Use undo tunnel discard ipv4-compatible-packet to restore the default.
IPv6 packets using IPv4-compatible IPv6 addresses are not dropped.
2: System level
The tunnel discard ipv4-compatible-packet command enables the device to check the source and destination IPv6 addresses of the de-encapsulated IPv6 packets from the tunnel and discard packets that use a source or destination IPv4-compatible IPv6 address.
# Enable dropping of IPv6 packets using IPv4-compatible IPv6 addresses.
[Sysname] tunnel discard ipv4-compatible-packet
tunnel-protocol
Use tunnel-protocol to specify the tunnel mode for a tunnel interface.
Use undo tunnel-protocol to restore the default.
tunnel-protocol { gre [ ipv6 ] | ipsec { ipv4 | ipv6 } }
A tunnel interface runs in GRE over IPv4 tunnel mode.
2: System level
gre: Specifies the GRE over IPv4 tunnel mode.
gre ipv6: Specifies the GRE over IPv6 tunnel mode.
ipsec ipv4: Specifies the IPsec over IPv4 tunnel mode.
ipsec ipv6: Specifies the IPsec over IPv6 tunnel mode.
You can select a tunnel mode according to the actual network topology and application. The two ends of a tunnel must have the same tunnel mode specified. Otherwise, traffic transmission may fail.
Only one automatic tunnel can be created at the start point of a tunnel.
For more information about IPsec tunnel mode, see Security Configuration Guide.
# Specify the GRE over IPv4 tunnel mode for interface Tunnel 2.
[Sysname] interface tunnel 2
[Sysname-Tunnel2] tunnel-protocol gre
