01-Fundamentals Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10201-Fundamentals Command Reference
02-Login Management Commands
02-Login Management Commands 180.85 KB
Login management commands
acl (user interface view)
Use acl to reference ACLs to control access to the VTY user interface.
Use undo acl to cancel the ACL application.
To use a basic or advanced ACL:
acl [ ipv6 ] acl-number { inbound | outbound }
undo acl [ ipv6 ] acl-number { inbound | outbound }
To use a WLAN or Ethernet frame header ACL:
acl acl-number inbound
undo acl acl-number inbound
Access to the VTY user interface is not restricted.
VTY user interface view
Default command level
2: System level
ipv6: Specifies an IPv6 ACL. If you do not specify this keyword, you specify an IPv4 ACL.
acl-number: Specifies the number of the ACL:
·     WLAN ACL100 to 199
·     Basic ACL2000 to 2999
·     Advanced ACL3000 to 3999
·     Ethernet frame header ACL4000 to 4999
inbound: Restricts Telnet or SSH connections established in the inbound direction through the VTY user interface. If the received packets for establishing a Telnet or SSH connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet server or SSH server, use this keyword to control access of Telnet clients or SSH clients.
outbound: Restricts Telnet connections established in the outbound direction through the VTY user interface. If the packets sent for establishing a Telnet connection are permitted by an ACL rule, the connection is allowed to be established. When the device functions as a Telnet client, use this keyword to define Telnet servers accessible to the client.
If no ACL is referenced in VTY user interface view, the VTY user interface has no access control over establishing a Telnet or SSH connection.
If an ACL is referenced in VTY user interface view, the connection is permitted to be established only when packets for establishing a Telnet or SSH connection match a permit statement in the ACL.
The system regards the basic/advanced ACL with the inbound keyword, the basic/advanced ACL with the outbound keyword, WLAN ACL, and Ethernet frame header ACL as different types of ACLs, which can coexist in one VTY user interface. The match order is WLAN ACL, basic/advanced ACL, Ethernet frame header ACL. At most, one ACL of each type can be referenced in the same VTY user interface, and the most recently configured one takes effect.
For more information about ACL, see ACL and QoS Command Reference.
# Allow only the user with the IP address of 192.168.1.26 to access the device through Telnet or SSH.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 192.168.1.26 0
[Sysname-acl-basic-2001] quit
[Sysname] user-interface vty 0
[Sysname-ui-vty0] acl 2001 inbound
After the configuration, user A (with the IP address 192.168.1.26) can Telnet to the device, but user B (with the IP address 192.168.1.60) cannot. Upon a connection failure, the following message appears: "%connection closed by remote host!"
# Allow the device to only Telnet to the Telnet server with IP address 192.168.1.41.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit tcp destination 192.168.1.41 0
[Sysname-acl-adv-3001] quit
[Sysname] user-interface vty 0 4
[Sysname-ui-vty0-4] acl 3001 outbound
[Sysname-ui-vty0-4] return
<Sysname>
After your configuration, if you Telnet to 192.168.1.46, your operation fails.
<Sysname> telnet 192.168.1.46
%Can't access the host from this terminal!
However, you can Telnet to 192.168.1.41.
<Sysname> telnet 192.168.1.41
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
# Allow only the WLAN client with the SSID of Admin to access the device through VTY 0.
[Sysname] acl number 100
[Sysname-acl-wlan-100] rule permit ssid Admin
[Sysname-acl-wlan-100] quit
[Sysname-ui-vty0] acl 100 inbound
activation-key
Use activation-key to define a shortcut key for starting a terminal session.
Use undo activation-key to restore the default.
activation-key character
undo activation-key
Pressing the Enter key starts a terminal session.
User interface view
3: Manage level
character: Specifies the shortcut key for starting a terminal session. It can be a string of 1 to 3 characters, or an ASCII code value in the range of 0 to 127. If you enter a number that is greater than 127, or enter a string that is not a number, the first character is used as the shortcut key. For example, if you configure activation-key 987, the shortcut key is 9. If you configure activation-key abc, the shortcut key is a.
This command is not supported on VTY user interfaces.
To display the shortcut key you have defined, use the display current-configuration command.
# Configure character s as the shortcut key for starting a terminal session on the console user interface.
[Sysname] user-interface console 0
[Sysname-ui-console0] activation-key s
# Verify the configuration:
1.     Exit the console session.
[Sysname-ui-console0] return
<Sysname> quit
2.     Log in to the console user interface again.
The following message appears:
User interface con0 is available.
Please press ENTER.
3.     Press Enter.
Pressing Enter does not start a session.
4.     Enter s.
A terminal session is started.
<Sysname>
%Mar  2 18:40:27:981 2005 Sysname SHELL/5/LOGIN: Console login from con0
authentication-mode
Use authentication-mode to set the authentication mode for a user interface.
Use undo authentication-mode to restore the default.
authentication-mode { none | password | scheme }
The authentication mode is password for VTY and AUX user interfaces, and none for the console user interface.
User interface view
3: Manage level
none: Performs no authentication. This keyword is not supported in FIPS mode.
password: Performs local password authentication. This keyword is not supported in FIPS mode.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
In FIPS mode, only scheme mode is supported.
# Enable the none authentication mode for user interface VTY 0.
[Sysname-ui-vty0] authentication-mode none
# Enable password authentication for user interface VTY 0 and set the password to 321.
[Sysname-ui-vty0] authentication-mode password
[Sysname-ui-vty0] set authentication password simple 321
# Enable scheme authentication for user interface VTY 0, and set the username to 123 and the password to 321.
[Sysname-ui-vty0] authentication-mode scheme
[Sysname-ui-vty0] quit
[Sysname] local-user 123
[Sysname-luser-123] password simple 321
[Sysname-luser-123] service-type telnet
[Sysname-luser-123] authorization-attribute level 3
auto-execute command
CAUTION
CAUTION:
After configuring this command for a user interface, you might be unable to access the CLI through the user interface. Make sure you can access the CLI through a different user interface before you configure this command and save the configuration.
Use auto-execute command to specify a command that is to be automatically executed when a user logs in to the current user interface.
Use undo auto-execute command to remove the configuration.
auto-execute command command
Command auto-execution is disabled.
User interface view
3: Manage level
command: Specifies the command to be automatically executed.
This command is not supported on the console user interface, or the AUX user interface when the device has only one AUX port and no console port.
The system automatically executes the specified command when a user logs in to the user interface, and tears down the user connection after the command is executed. If the command triggers another task, the system does not tear down the user connection until the task is completed.
The command auto-execute function is typically used for redirecting a Telnet user to a specific host.
# Configure the device to automatically Telnet to 192.168.1.41 after a user logs in to interface VTY 0.
[Sysname -ui-vty0] auto-execute command telnet 192.168.1.41
% This action will lead to configuration failure through ui-vty0. Are you sure?
[Y/N]:y
[Sysname-ui-vty0]
# To verify the configuration, Telnet to 192.168.1.40.
The device automatically Telnets to 192.168.1.41, and the following output is displayed:
C:\> telnet 192.168.1.40
<Sysname>
<Sysname.41>
This operation is the same as directly logging in to the device at 192.168.1.41. If the Telnet connection to 192.168.1.41 is broken down, the Telnet connection to 192.168.1.40 breaks down at the same time.
command accounting
Use command accounting to enable command accounting.
Use undo command accounting to restore the default.
command accounting
Command accounting is disabled, and the accounting server does not record executed commands.
User interface view
3: Manage level
When command accounting is enabled and command authorization is not, every executed command is recorded on the HWTACACS server.
When both command accounting and command authorization are enabled, only the authorized and executed commands are recorded on the HWTACACS server.
# Enable command accounting for user interface VTY 0.
[Sysname-ui-vty0] command accounting
Use command authorization to enable command authorization.
Use undo command authorization to restore the default.
Command authorization is disabled. Logged-in users can execute commands without authorization.
User interface view
3: Manage level
With command authorization enabled, users can perform only commands authorized by the server.
# Enable command accounting for VTY 0 so users logged in to VTY 0 can perform only the commands authorized by the HWTACACS server.
[Sysname-ui-vty0] command authorization
databits
Use databits to specify the number of data bits for each character.
Use undo databits to restore the default.
databits { 7 | 8 }
undo databits
Eight data bits are used for each character.
User interface view
2: System level
7: Uses seven data bits for each character.
8: Uses eight data bits for each character.
This command is only applicable to asynchronous serial interfaces, including AUX and console ports.
This setting must be the same as that on the configuration terminal.
# Configure AUX 0 to use 7 data bits for each character.
[Sysname] user-interface aux 0
[Sysname-ui-aux0] databits 7
display ip http
Use display ip http to display HTTP information.
display ip http [ | { begin | exclude | include } regular-expression ]
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about HTTP.
<Sysname> display ip http
HTTP port: 80
WLAN ACL: 100
Basic ACL: 2222
Current connection: 0
Operation status: Running
HTTP port
Port number used by the HTTP service.
WLAN ACL
WLAN ACL associated with the HTTP service.
Basic ACL
Basic ACL number associated with the HTTP service.
Current connection
Number of current connections.
Operation status
Operation status:
·     Running—The HTTP service is enabled.
·     Stopped—The HTTP service is disabled.
display ip https
Use display ip https to display information about HTTPS.
display ip https [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information about HTTPS.
<Sysname> display ip https
HTTPS port: 443
SSL server policy: test
Certificate access-control-policy:
WLAN ACL: 100
Basic ACL: 2222
HTTPS port
Port number used by the HTTPS service.
SSL server policy
SSL server policy associated with the HTTPS service.
Certificate attribute access control policy associated with the HTTPS service.
WLAN ACL
WLAN ACL number associated with the HTTPS service.
Basic ACL
Basic ACL number associated with the HTTPS service.
Operation status
Operation status:
·     Running—The HTTPS service is enabled.
·     Stopped—The HTTPS service is disabled.
display telnet client configuration
Use display telnet client configuration to display the configuration of the device when it serves as a Telnet client.
display telnet client configuration [ | { begin | exclude | include } regular-expression ]
1: Monitor level
This command is not supported in FIPS mode.
# Display the configuration of the device when it serves as a Telnet client.
<Sysname> display telnet client configuration
 The source IP address is 1.1.1.1.
The output shows that the device uses the source IPv4 address 1.1.1.1 for outgoing Telnet packets when it serves as a Telnet client.
display user-interface
Use display user-interface to display user interface information.
display user-interface [ num1 | { aux | console | vty } num2 ] [ summary ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
num1: Specifies the absolute number of a user interface. The value range varies with devices and typically starts from 0. For more information, see About the H3C Access Controllers Command References.
aux: Specifies the AUX user interface. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
console: Specifies the console user interface. Support for this keyword depends on the device model. For more information, see About the H3C Access Controllers Command References.
vty: Specifies the VTY user interface.
num2: Specifies the relative number of a user interface. The value range depends on the user interface type:
·     AUX—0
·     Console—0
·     VTY—0 to 4
summary: Displays summary information about user interfaces.
# Display information about user interface 0.
<Sysname> display user-interface 0
  Idx  Type     Tx/Rx      Modem Privi Auth  Int
+ 0    CON 0    9600       -     3     N     -
  +    : Current user-interface is active.
  F    : Current user-interface is active and work in async mode.
  Idx  : Absolute index of user-interface.
  Type : Type and relative index of user-interface.
  Privi: The privilege of user-interface.
  Auth : The authentication mode of user-interface.
  Int  : The physical location of UIs.
  A    : Authentication use AAA.
  L    : Authentication use local database.
  N    : Current UI need not authentication.
  P    : Authentication use current UI's password.
Idx
Absolute number of the user interface.
Type and relative number of the user interface.
Tx/Rx
Transmit/receive rate of the user interface.
Privi
Command level of a user under that user interface.
Auth
Authentication mode for the users:
·     AScheme authentication mode.
·     LLocal authentication mode (not supported).
·     NNone authentication mode.
·     PPassword authentication mode.
Int
Physical port that corresponds to the user interface.
For console, AUX, and VTY user interfaces, a hyphen (-) is displayed.
# Display summary information about all user interfaces.
<Sysname> display user-interface summary
  User interface type : [CON]
            0:X
  User interface type : [AUX]
            1:X
  User interface type : [VTY]
            2:XUXU U
    3 character mode users.      (U)
    4 UI never used.             (X)
    3 total UI in use
0:X
0 represents the absolute number of the user interface. If the user interface is not used, an X is displayed. If the user interface is being used, a U is displayed. For example, 2:XUXU U shows there are five user interfaces of the user interface type, which use the absolute numbers 2 through 6. User interfaces 2 and 4 are not used, and the other user interfaces are being used.
display users
Use display users to display information about the user interfaces being used.
Use display users all to display information about all user interfaces supported by the device.
display users [ all ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays information about all user interfaces the device supports.
# Display information about the user interfaces being used.
<Sysname> display users
The user application information of the user interface(s):
  Idx UI      Delay    Type Userlevel
+ 178 VTY 0   00:00:00 TEL  3
  179 VTY 1   00:02:34 TEL  3
Following are more details.
VTY 0   :
VTY 1   :
+   : Current operation user.
F   : Current operation user work in async mode.
The output shows that two users have logged in to the device: You are using user interface VTY 0 and the other user is using VTY 1. Your IP address is 192.168.1.54.
Table 5 Command output
Idx
UI
Relative number of the user interface. For example, with VTY, the first column represents user interface type, and the second column represents the relative number of the user interface.
Delay
Time elapsed after the user's last input, in the format hh:mm:ss.
User type, such as Telnet or SSH.
Userlevel
User level: 0 for visit, 1 for monitor, 2 for system, and 3 for manage.
User interface you are using.
Location
IP address of the user.
F
The current user is operating in asynchronous mode.
display web users
Use display web users to display information about the Web users.
display web users [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information about the Web users.
<Sysname> display web users
UserID   Name      Lang Level   State    Links Login    LastOp   Ip
ab830100 admin     zn   Manage  Enabled     0  17:22:53 17:31:43 192.168.1
Table 6 Command output
UserID
Web user ID.
Name
Web username.
Lang
Language used in Web login.
Level
Web user level.
Web user status.
Links
Number of tasks running for the Web user.
Login
Login time.
LastOp
Last time when the Web user accessed the device.
IP
IP address of the Web user.
escape-key
Use escape-key to define a shortcut key for terminating a task.
Use undo escape-key to disable the shortcut key for terminating tasks.
escape-key { default | character }
undo escape-key
Pressing Ctrl+C terminates a task.
User interface view
3: Manage level
character: Specifies the shortcut key for terminating a task. It can be a string of 1 to 3 characters, or an ASCII code value in the range of 0 to 127. If you enter a number that is greater than 127, or enter a string that is not a number, the first character is used as the shortcut key. For example, if you configure escape-key 987, the shortcut key is 9. If you configure escape-key abc, the shortcut key is a.
default: Restores the default escape key sequence Ctrl+C.
If you execute this command multiple times, the most recent definition takes effect. To display the effective shortcut key definition, use the display current-configuration command.
If you set the character argument in a user interface of a device, when you use the user interface to log in to the device and then Telnet to another device, the character argument can be used as a control character to terminate a task rather than being used as a common character. For example, if you specify character e in VTY 0 user interface of Device A, when you log in to Device A using VTY 0 from a PC (HyperTerminal), you can enter e as a common character on the PC, and you can also use e to terminate the task running on Device A. If you Telnet to Device B from Device A, you can only use e to terminate the task running on Device B, rather than using e as a common character. It is a good practice to specify a key sequence.
# Define character a as the shortcut key for terminating a task.
[Sysname-ui-console0] escape-key a
# To verify the configuration:
1.     Ping IP address 192.168.1.49, specifying the -c keyword to set the number of ICMP echo request packets to 20.
<Sysname> ping -c 20 192.168.1.49
  PING 192.168.1.49: 56  data bytes, press a to break
    Reply from 192.168.1.49: bytes=56 Sequence=1 ttl=255 time=3 ms
    Reply from 192.168.1.49: bytes=56 Sequence=2 ttl=255 time=3 ms
2.     Press a.
The task terminates, and the system returns to user view.
  --- 192.168.1.49 ping statistics ---
    2 packet(s) transmitted
    2 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 3/3/3 ms
<Sysname>
free user-interface
Use free user-interface to release a user interface.
free user-interface { num1 | { aux | console | vty } num2 }
3: Manage level
·     AUX—0
·     Console—0
·     VTY—0 to 4
This command cannot release the connection you are using.
# Release user interface VTY 1:
1.     Display which users are operating the device.
+ 82  VTY 0   00:00:00 TEL  3
  83  VTY 1   00:00:03 TEL  3
VTY 0   :
VTY 1   :
2.     If the operations of the user on VTY 1 affect your operations, log out the user.
<Sysname> free user-interface vty 1
Are you sure to free user-interface vty1? [Y/N]:y
free web-users
Use free web-users to log out Web users.
free web-users { all | user-id user-id | user-name user-name }
2: System level
all: Specifies all Web users.
user-id: Web user ID, a hexadecimal number of eight digits.
user-name: Web user name, a string of 1 to 80 characters.
# Log out all Web users.
<Sysname> free web-users all
display web users
history-command max-size
Use history-command max-size to set the size of the command history buffer for a user interface.
Use undo history-command max-size to restore the default.
history-command max-size size-value
The buffer of a user interface saves 10 history commands at most.
User interface view
2: System level
size-value: Specifies the maximum number of history commands the buffer can store, in the range of 0 to 256.
Each user interface uses a separate command history buffer to save commands successfully executed by its user. The size of the buffer determines how many history commands the buffer can store.
To view stored history commands on your user interface, press the up arrow key or down arrow key or execute the display history-command command.
Terminating the CLI session clears the commands in the history buffer.
# Set the size of the command history buffer to 20 for user interface Console 0.
[Sysname-ui-console0] history-command max-size 20
idle-timeout
Use idle-timeout to set the session idle-timeout timer.
Use undo idle-timeout to restore the default.
undo idle-timeout
The idle-timeout time is 10 minutes.
User interface view
2: System level
minutes: Specifies the number of minutes for the idle-timeout time, in the range of 0 to 35791. The default is 10 minutes.
seconds: Specifies the number of seconds for the idle-timeout time, in the range of 0 to 59. The default is 0 seconds.
The system automatically terminates the user connection on the user interface if there is no information interaction between the device and the user within the idle-timeout time.
Setting the idle-timeout timer to 0 disables the idle-timeout function.
# Set the idle-timeout timer to 1 minute and 30 seconds.
[Sysname-ui-console0] idle-timeout 1 30
ip http acl
Use ip http acl to associate the HTTP service with an ACL.
Use undo ip http acl to remove the association.
ip http acl acl-number
undo ip http acl acl-number
The HTTP service is not associated with any ACL.
2: System level
acl-number: ACL number. The value range depends on the ACL category:
·     Basic IPv4 ACL2000 to 2999
After the HTTP service is associated with an ACL, only the clients permitted by the ACL can access the device through HTTP.
The HTTP service can be associated with a WLAN ACL and a basic ACL, and the two types of ACLs will not overwrite each other. However, ACLs of the same type will overwrite each other. If you execute the ip http acl command multiple times to associate the HTTP service with the same type of ACLs, the HTTP service is only associated with the most recently specified ACL.
When the HTTP service is associated with a WLAN ACL, the HTTP service uses this ACL to filter wireless clients only, and does not filter wired clients with this ACL.
# Associate the HTTP service with ACL 100 to allow only the wireless client with the SSID user-ssid-name to access the device through HTTP.
[Sysname-acl-wlan-100] rule permit ssid user-ssid-name
[Sysname] ip http acl 100
# Associate the HTTP service with ACL 2001 to only allow the clients within the 10.10.0.0/16 network to access the device through HTTP.
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname] ip http acl 2001
·     display ip http
·     acl number (ACL and QoS Command Reference)
ip http enable
Use ip http enable to enable the HTTP service.
Use undo ip http enable to disable the HTTP service.
ip http enable
undo ip http enable
2: System level
The default setting of this command varies with devices.
The device can act as the HTTP server that can be accessed only after the HTTP service is enabled.
# Enable the HTTP service.
[Sysname] ip http enable
# Disable the HTTP service.
[Sysname] undo ip http enable
display ip http
ip http port
Use ip http port to configure the port number of the HTTP service.
Use undo ip http port to restore the default.
ip http port port-number
undo ip http port
The port number of the HTTP service is 80.
3: Manage level
port-number: Port number of the HTTP service, which ranges from 1 to 65535.
Verify that the port number is not used by another service, because this command does not check for conflicts with configured port numbers.
# Configure the port number of the HTTP service as 8080.
[Sysname] ip http port 8080
display ip http
ip https acl
Use ip https acl to associate the HTTPS service with an ACL.
Use undo ip https acl to remove the association.
ip https acl acl-number
undo ip https acl acl-number
The HTTPS service is not associated with any ACL.
3: Manage level
After the HTTPS service is associated with an ACL, only the clients permitted by the ACL can access the device.
The HTTPS service can be associated with a WLAN ACL and basic ACL, and the two types of ACLs will not overwrite each other. However, ACLs of the same type will overwrite each other. If you execute the ip https acl command multiple times to associate the HTTPS service with the same type of ACLs, the HTTPS service is only associated with the most recently specified ACL.
When the HTTPS service is associated with a WLAN ACL, the HTTPS service uses this ACL to filter wireless clients only, and does not filter wired clients with this ACL.
# Associate the HTTPS service with ACL 100 to only allow the wireless client with the SSID user-ssid-name to access the device through HTTP.
[Sysname] ip https acl 100
# Associate the HTTPS service with ACL 2001 to only allow the clients within the 10.10.0.0/16 network segment to access the HTTPS server through HTTP.
[Sysname] ip https acl 2001
·     display ip https
ip https certificate access-control-policy
Use ip https certificate access-control-policy to associate the HTTPS service with a certificate attribute access control policy.
Use undo ip https certificate access-control-policy to remove the association.
The HTTPS service is not associated with any certificate attribute access control policy.
3: Manage level
policy-name: Name of the certificate attribute access control policy, a string of 1 to 16 characters.
Association of the HTTPS service with a certificate attribute access control policy can control the access rights of clients.
# Associate the HTTPS server to certificate attribute access control policy myacl.
[Sysname] ip https certificate access-control-policy myacl
·     display ip https
·     pki certificate access-control-policy (Security Command Reference)
ip https enable
Use ip https enable to enable the HTTPS service.
Use undo ip https enable to disable the HTTPS service.
ip https enable
3: Manage level
Enabling the HTTPS service triggers an SSL handshake negotiation process:
·     If the local certificate of the device exists, the SSL negotiation succeeds, and the HTTPS service can be started.
·     If no local certificate exists, the SSL negotiation triggers a certificate application process that often fails because it times out. If that happens, execute the ip https enable command multiple times to start the HTTPS service.
# Enable the HTTPS service.
[Sysname] ip https enable
ip https port
Use ip https port to configure the port number of the HTTPS service.
Use undo ip https port to restore the default.
ip https port port-number
undo ip https port
The port number of the HTTPS service is 443.
3: Manage level
port-number: Port number of the HTTPS service, which ranges from 1 to 65535.
# Configure the port number of the HTTPS service as 6000.
[Sysname] ip https port 6000
display ip https
ip https ssl-server-policy
Use ip https ssl-server-policy to associate the HTTPS service with an SSL server-end policy.
Use undo ip https ssl-server-policy to remove the association.
The HTTPS service is not associated with any SSL server-end policy, and the device uses a self-signed certificate for authentication. (A self-signed certificate is generated and signed by the device itself, rather than the CA.)
3: Manage level
policy-name: Name of an SSL server policy, a string of 1 to 16 characters.
The HTTPS service can be enabled only after this command is configured successfully.
With the HTTPS service enabled, you cannot modify the associated SSL server-end policy or remove the association between the HTTPS service and the SSL server-end policy after the HTTPS service is enabled.
# Associate the HTTPS service with SSL server-end policy myssl.
[Sysname] ip https ssl-server-policy myssl
·     display ip https
·     ssl server-policy (Security Command Reference)
lock
Use lock to lock the current user interface.
lock
This function is disabled.
3: Manage level
When you must leave the device for a while, use this command to lock the current user interface to prevent unauthorized access.
After you enter this command, you are asked to enter a password (up to 16 characters) and then confirm it by entering the password again.
To unlock the user interface, press Enter and enter the correct password.
# Lock the current user interface and then unlock it.
<Sysname> lock
Please input password<1 to 16> to lock current user terminal interface:
Password:
Again:
                   locked !
Password:
<Sysname>
parity
Use parity to specify a parity check mode.
Use undo parity to restore the default.
parity { even | none | odd }
undo parity
The setting is none, and no parity check is performed.
User interface view
2: System level
even: Performs even parity check.
none: Disables parity check.
odd: Performs odd parity check.
The configuration terminal and the device must be configured with the same parity check mode to communicate.
# Configure user interface AUX 0 to perform odd parity check.
[Sysname-ui-aux0] parity odd
protocol inbound
Use protocol inbound to enable a user interface to support Telnet, SSH, or both of them.
Use undo protocol inbound to restore the default.
In non-FIPS mode:
In FIPS mode:
protocol inbound { all | ssh }
Both Telnet and SSH are supported.
VTY interface view
3: Manage level
all: Supports both Telnet and SSH in non-FIPS mode and supports SSH in FIPS mode.
ssh: Supports SSH only.
telnet: Supports Telnet only. This keyword is not supported in FIPS mode.
This configuration is effective only for a user who logs in to the user interface after the configuration is made.
Before configuring a user interface to support SSH, set the authentication mode to scheme for the user interface. For more information, see authentication-mode.
# Enable the VTYs 0 through 4 to support only SSH.
[Sysname-ui-vty0-4] authentication-mode scheme
[Sysname-ui-vty0-4] protocol inbound ssh
screen-length
Use screen-length to set the maximum number of lines to be displayed on a screen.
Use undo screen-length to restore the default.
screen-length screen-length
undo screen-length
Up to 24 lines are displayed on a screen.
User interface view
2: System level
screen-length: Specifies the maximum number of lines to be displayed on a screen, in the range of 0 to 512. The value of 0 disables pausing between screens of output.
When screen output pauses, press the Space key to display the next screen. Not all terminals support this setting. For example, assume you set screen-length to 40, but the terminal can display 24 lines in one screen at most. When you press Space, the device sends 40 lines to the terminal, but the screen displays only lines 18 through 40. To view the first 17 lines, press the page up or page down key.
To disable pausing between screens of output for the current session, use the screen-length disable command.
# Set the maximum number of lines to be displayed on a screen to 30 for user interface Console 0.
[Sysname-ui-console0] screen-length 30
send
Use send to send messages to user interfaces.
send { all | num1 | { aux | console | vty } num2 }
1: Monitor level
all: Specifies all user interfaces.
·     AUX—0
·     Console—0
·     VTY—0 to 4
To end message input, press Ctrl+Z. To cancel message input and return to user view, press Ctrl+C.
# Send message hello abc to your own user interface Console 0.
<Sysname> send console 0
Enter message, end with CTRL+Z or Enter; abort with CTRL+C:
hello abc^Z
Send message? [Y/N]:y
<Sysname>
***Message from con0 to con0
hello abc
<Sysname>
# Before you restart the device, inform other login users so they can prepare for the reboot:
1.     Display information about the user interfaces that are being used.
VTY 0   :
VTY 1   :
The output shows that you are using VTY 0 and another user is using VTY 1.
2.     Send a notification message to the user of VTY1.
<Sysname> send vty 1
Your attention, please. I will reboot the system in 3 minutes!^Z
The message should appear on the screen of the user's configuration terminal. The following example assumes that the user was executing the interface gigabitethernet command when the message arrived:
[Sysname] interface gigabitethernet
***Message from vty0 to vty1
Note please, I will reboot the system in 3 minutes!
Use set authentication password to set a password for password authentication.
Use undo set authentication password to remove the password.
set authentication password [ hash ] { cipher | simple } password
No password is set for password authentication.
User interface view
3: Manage level
hash: Enables hash-based encryption.
{ cipher | simple } password: Specifies a case-sensitive password string. The password length and form requirements vary with the keywords or keyword combinations.
Table 7 Password length and form requirements for the password argument
Keyword combination
Password string form
Length (in characters)
simple
Plain text
1 to 16
hash simple
Plain text
1 to 16
cipher
Plain text, cipher text
Plain text: 1 to 16
Cipher text: 1 to 53
hash cipher
Cipher text (hashed form)
1 to 110
For security purposes, all passwords, including passwords configured in plain text, are saved in cipher text.
# Set the password for password authentication on user interface Console 0 to plaintext hello.
[Sysname-ui-console0] authentication-mode password
[Sysname-ui-console0] set authentication password simple hello
authentication-mode
shell
Use shell to enable the terminal service for a user interface.
Use undo shell to disable the terminal service for a user interface.
shell
undo shell
The terminal service is enabled on all user interfaces.
User interface view
3: Manage level
The console user interface does not support the undo shell command.
The AUX user interface does not support the undo shell command when the device has only one AUX port and no console port.
You cannot disable the terminal service on the user interface you are using.
# Disable the terminal service for user interface VTY 0 through VTY 4 so no user can log in to the device through the user interfaces.
[Sysname-ui-vty0-4] undo shell
% Disable ui-vty0-4 , are you sure? [Y/N]:y
[Sysname-ui-vty0-4]
The following message appears when a user tries to Telnet to the device:
The connection was closed by the remote host!
speed (user interface view)
Use speed to set the transmission rate (also called the "baud rate") on a user interface.
Use undo speed to restore the default.
speed speed-value
undo speed
The transmission rate is 9600 bps.
User interface view
2: System level
speed-value: Transmission rate in bps. The transmission rates available for asynchronous serial interfaces include 2400 bps, 9600 bps, 19200 bps, 38400 bps, 57600 bps, and 115200 bps. The transmission rate varies with devices and configuration environments.
The configuration terminal and the device must be configured with the same transmission rate to communicate.
# Set the transmission rate on the user interface AUX 0 to 19200 bps.
[Sysname-ui-aux0] speed 19200
stopbits
Use stopbits to specify the number of stop bits for a character.
Use undo stopbits to restore the default.
stopbits { 1 | 2 }
undo stopbits
One stop bit is used.
User interface view
2: System level
1: Uses one stop bit.
2: Uses two stop bits.
The configuration terminal and the device must be configured to use the same number of stop bits to communicate.
# Set the number of stop bits to 1 for user interface AUX 0.
[Sysname-ui-aux0] stopbits 1
stopbit-error intolerance
telnet
Use telnet to Telnet to a host in an IPv4 network.
telnet remote-host [ service-port ] [ source { interface interface-type interface-number | ip ip-address } ]
0: Visit level
remote-host: Specifies the IPv4 address or host name of a remote host, a case-insensitive string of 1 to 20 characters.
service-port: Specifies the TCP port number for the Telnet service on the remote host. It ranges from 0 to 65535 and defaults to 23.
source: Specifies a source IPv4 address or source interface for outgoing Telnet packets.
interface interface-type interface-number: Specifies the source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies the source IPv4 address for outgoing Telnet packets.
To terminate the current Telnet connection, press Ctrl+K or execute the quit command.
The source IPv4 address or source interface specified by this command is only applicable to the current Telnet connection.
# Telnet to host 1.1.1.2, using 1.1.1.1 as the source IP address for outgoing Telnet packets.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
telnet client source
Use telnet client source to specify a source IPv4 address or source interface for outgoing Telnet packets when the device serves as a Telnet client.
Use undo telnet client source to remove the configuration.
No source IPv4 address or source interface is specified for outgoing Telnet packets. The source IPv4 address is the primary IPv4 address of the outbound interface.
2: System level
interface interface-type interface-number: Specifies a source interface. The primary IP address of this interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies a source IPv4 address.
The source IPv4 address or source interface specified by this command is applicable to all Telnet connections. However, if a user specifies a source IPv4 address or source interface when executing the telnet command, the setting specified by the user takes effect.
# Set the source IPv4 address for outgoing Telnet packets to 1.1.1.1 when the device serves as a Telnet client.
[Sysname] telnet client source ip 1.1.1.1
telnet ipv6
Use telnet ipv6 to Telnet to a host in an IPv6 network.
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ]
0: Visit level
remote-host: Specifies the IP address or host name of a remote host, a case-insensitive string of 1 to 46 characters.
-i interface-type interface-number: Specifies the outbound interface for sending Telnet packets. This option is required when the destination address is a link-local address.
port-number: Specifies the TCP port number for the Telnet service on the remote host. It ranges from 0 to 65535 and defaults to 23.
# Telnet to the host at 5000::1.
<Sysname> telnet ipv6 5000::1
telnet server enable
Use telnet server enable to enable the Telnet server function.
Use undo telnet server enable to disable the Telnet server function.
The Telnet server function is enabled.
3: Manage level
# Enable the Telnet server function.
terminal type
Use terminal type to specify the terminal display type.
Use undo terminal type to restore the default.
undo terminal type
The terminal display type is ANSI.
User interface view
2: System level
ansi: Specifies the terminal display type ANSI.
vt100: Specifies the terminal display type VT100.
The device supports two terminal display types: ANSI and VT100. To ensure proper display on the terminal, set the display type of both the device and the configuration terminal to VT100. Otherwise, when a command line has more than 80 characters, an anomaly such as cursor positioning error or abnormal display might occur.
# Set the terminal display type to VT100.
[Sysname-ui-vty0] terminal type vt100
user privilege level
Use user privilege level to configure the user privilege level. Users logging into the user interface are assigned a user privilege level.
Use undo user privilege level to restore the default.
user privilege level level
The command level is 3 for the console user interface and 0 for other user interfaces.
User interface view
3: Manage level
level: Specifies a user privilege level, which ranges from 0 to 3.
User privilege levels include visit, monitor, system, and manage, represented by the numbers 0, 1, 2, and 3, respectively. You can change the user privilege level when necessary.
In FIPS mode, only scheme authentication is supported, and this command is not available.
# Set the command level for users logging in through VTY 0 to 0.
[Sysname-ui-vty0] user privilege level 0
After you Telnet to the device through VTY 0, the terminal only displays commands of level 0 in the help information:
<Sysname> ?
User view commands:
  cluster  Run cluster command
  display  Display current system information
  ping     Ping function
  quit     Exit from current command view
  rsh      Establish one RSH connection
  ssh2     Establish a secure shell client connection
  super    Set the current user priority level
  telnet   Establish one TELNET connection
  tracert  Trace route function
user-interface
Use user-interface to enter user interface view.
user-interface { first-num1 [ last-num1 ] | { aux | console | vty } first-num2 [ last-num2 ] }
2: System level
first-num1: Specifies the absolute number of the first user interface. The value range varies with devices and typically starts from 0. For more information, see About the H3C Access Controllers Command References.
last-num1: Specifies the absolute number of the last user interface. The value range varies with devices typically starts from 0, and cannot be smaller than first-num1. For more information, see About the H3C Access Controllers Command References.
first-num2: Specifies the relative number of the first user interface. The value range depends on the user interface type:
·     AUX—0
·     Console—0
·     VTY—0 to 4
last-num2: Specifies the relative number of the last user interface. For a VTY user interface, the value range is 1 to 4. This argument cannot be smaller than first-num2.
If you use this command to enter a single user interface view, your configuration applies only to the user interface.
If you use this command to enter multiple user interface views, your configuration applies to all the specified user interfaces.
# Enter the view of user interface Console 0.
# Enter the views of user interfaces VTY 0 to VTY 4.
[Sysname-ui-vty0-4]
web https-authorization mode
Use web https-authorization mode to specify the authentication mode for users trying to log in to the device through HTTPS.
Use undo web https-authorization mode to restore the default.
A user must enter correct username and password to log in through HTTPS.
2: System level
auto: Uses the PKI certificates of HTTPS users to automatically authenticate them.
manual: Provides a login page for HTTPS users to enter the correct username and password.
When the auto mode is enabled:
·     If the PKI certificate of the user is correct and not expired, the CN field in the certificate is used as the username to perform AAA authentication. If the authentication succeeds, the user automatically enters the Web interface of the device.
·     If the PKI certificate of the user is correct and not expired, but the AAA authentication fails, the device shows the Web login page. The user can log in to the device after entering correct username and password.
·     When the PKI certificate of the user is incorrect or expired, the HTTPS connection is terminated.
# Specify the auto authentication mode for users trying to log in to the device through HTTPS.
[Sysname] web https-authorization mode auto
web idle-timeout
Use web idle-timeout to set the Web user connection timeout time.
Use undo web idle-timeout to restore the default.
web idle-timeout minutes
The Web user connection timeout time is 10 minutes.
2: System level
minutes: Timeout time in minutes, in the range of 1 to 999.
# Set the Web user connection timeout time to 20 minutes.
<System> system-view
[System] web idle-timeout 20
web logbuffer size
Use web logbuffer size to set the size of the buffer for Web login logging.
Use undo web logbuffer size to restore the default.
web logbuffer size pieces
The buffer for Web login logging can store 512 log messages.
2: System level
pieces: Size of the buffer for Web login logging, in the number of log messages. The value range is 1 to 1024.
# Set the size of the buffer for Web login logging to 800.
[System] web logbuffer size 800
