| 00-Preface | 113.16 KB |
Preface
This command reference describes the fundamentals configuration commands.
The Fundamentals Command Reference describes the configuration commands for using the CLI, login management, FTP and TFTP, file system management, configuration file management, software upgrade, license management, and device management.
NOTE: Support of the H3C access controllers for commands might vary by device model. For the command matrixes, see About the H3C Access Controllers Command References. |
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
