08-Security Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10208-Security Command Reference
19-User profile commands
19-User profile commands 36.29 KB
display user-profile
Use display user-profile to display configuration and online user information for a user profile or all user profiles.
display user-profile [ name profile-name ] [ slot slot-number ]
name profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. Valid characters include English letters, digits, and underscores (_). The name must start with an English letter. If you do not specify this option, the command displays configuration and online user information for all user profiles.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays user profile configuration and online user information on all member devices.
# Display configuration and online user information for all user profiles.
<Sysname> display user-profile
  User-Profile: abc
    Inbound:
      Policy: abc
    Outbound:
      Policy: abc
    slot 1:
      User -:
        Authentication type: 802.1X
        Network attributes:
          Interface    : GigabitEthernet1/0/1
          MAC address  : 6805-ca06-557b
          Service VLAN : 1
User-Profile
User profile name.
Policy
Policy name.
Authentication type
·     802.1X—802.1X authentication.
·     MACA—MAC authentication.
Network attributes
Online user information.
user-profile
Use user-profile to create a user profile and enter user profile view.
Use undo user-profile to remove a user profile.
user-profile profile-name
undo user-profile profile-name
No user profile exists.
profile-name: Specifies a user profile by its name, a case-sensitive string of 1 to 31 characters. A user profile name can only contain English letters, digits, and underscores (_), and it must start with an English letter.
You can use the command to enter the view of an existing user profile.
# Create user profile a123 and enter the view of user profile a123.
[Sysname] user-profile a123
[Sysname-user-profile-a123]
