08-Security Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10208-Security Command Reference
02-802.1X commands
02-802.1X commands 151.02 KB
802.1X commands
display dot1x
Use display dot1x to display information about 802.1X.
display dot1x [ sessions | statistics ] [ interface interface-type interface-number ]
sessions: Displays 802.1X session information.
statistics: Displays 802.1X statistics.
interface interface-type interface-number: Specifies a port by its type and number.
If you specify neither the sessions keyword nor the statistics keyword, the command displays all information about 802.1X, including session information, statistics, and settings.
# Display all information about 802.1X.
Global 802.1X parameters:
   802.1X authentication  : Enabled
   CHAP authentication    : Enabled
   Max-tx period          : 30 s
   Handshake period       : 15 s
   Quiet timer            : Disabled
       Quiet period       : 60 s
   Supp timeout           : 30 s
   Server timeout         : 100 s
   Reauth period          : 3600 s
   Max auth requests      : 2
   EAD assistant function : Disabled
       EAD timeout        : 30 min
   Domain delimiter       : @
 Max 802.1X users         : 2048 per slot
 Online 802.1X users      : 0
GigabitEthernet1/0/1  is link-up
   Handshake                  : Enabled
   Handshake reply            : Disabled
   Handshake security         : Disabled
   Unicast trigger            : Disabled
   Periodic reauth            : Disabled
   Port role                  : Authenticator
   Authorization mode         : Auto
   Port access control        : MAC-based
   Multicast trigger          : Enabled
   Mandatory auth domain      : Not configured
   Guest VLAN                 : Not configured
   Auth-Fail VLAN             : Not configured
   Critical VLAN              : Not configured
   Critical voice VLAN        : Disabled
   Max online users           : 2048
   Max Attempts Fail Number   : 0
   Add Guest VLAN delay       : Disabled
   EAPOL packets: Tx 0, Rx 0
   Sent EAP Request/Identity packets : 0
        EAP Request/Challenge packets: 0
        EAP Success packets: 0
        EAP Failure packets: 0
   Received EAPOL Start packets : 0
            EAPOL LogOff packets: 0
            EAP Response/Identity packets : 0
            EAP Response/Challenge packets: 0
            Error packets: 0
   Online 802.1X users: 0
Global 802.1X configuration.
Whether 802.1X is enabled globally.
CHAP authentication
Performs EAP termination and uses CHAP to communicate with the RADIUS server.
If EAP or PAP is enabled, this field is not available.
EAP authentication
Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
If CHAP or PAP is enabled, this field is not available.
PAP authentication
Performs EAP termination and uses PAP to communicate with the RADIUS server.
If CHAP or EAP is enabled, this field is not available.
Max-tx period
Username request timeout timer in seconds.
Handshake period
Handshake timer in seconds.
Quiet timer
Status of the quiet timer, enabled or disabled.
Quiet period
Quiet timer in seconds.
Supp timeout
Client timeout timer in seconds.
Server timeout
Server timeout timer in seconds.
Reauth period
Periodic reauthentication timer in seconds.
Max auth requests
Maximum number of attempts for sending an authentication request to a client.
Whether EAD assistant is enabled.
URL
Redirect URL for unauthenticated users using a Web browser to access the network.
Free IP
Network segment accessible to unauthenticated users.
EAD timeout
EAD rule timer in minutes.
Domain delimiter
Domain delimiters supported by the device.
Max 802.1X users
Maximum number of concurrent 802.1X users each device supports.
Online 802.1X users
Number of online 802.1X users.
Status of the port. In this example, GigabitEthernet 1/0/1 is up.
Whether 802.1X is enabled on the port.
Handshake
Whether the online user handshake feature is enabled on the port.
Handshake reply
Whether the online user handshake reply feature is enabled on the port.
Handshake security
Whether the online user handshake security feature is enabled on the port.
Unicast trigger
Whether the 802.1X unicast trigger is enabled on the port.
Periodic reauth
Whether periodic online user reauthentication is enabled on the port.
Port role
Role of the port. The port acts only as an Authenticator.
Authorization mode
Authorization state of the port, which can be Force-Authorized, Auto, or Force-Unauthorized.
Port access control
Access control method of the port:
·     MAC-based—MAC-based access control.
·     Port-based—Port-base access control.
Multicast trigger
Whether the 802.1X multicast trigger feature is enabled.
Mandatory authentication domain on the port.
Guest VLAN
802.1X guest VLAN configured on the port.
If no 802.1X guest VLAN is configured on the port, this field displays Not configured.
Auth-Fail VLAN
802.1X Auth-Fail VLAN configured on the port.
If no 802.1X Auth-Fail VLAN is configured on the port, this field displays Not configured.
Critical VLAN
802.1X critical VLAN configured on the port.
If no 802.1X critical VLAN is configured on the port, this field displays Not configured.
Critical voice VLAN
Whether the 802.1X critical voice VLAN is enabled on the port.
This field is available in Release 1122 and later.
Whether to log off online 802.1X users or keep them online when no server is reachable for 802.1X reauthentication.
Max online users
Maximum number of concurrent 802.1X users on the port.
Maximum number of 802.1X authentication attempts for MAC authenticated users.
Whether the 802.1X guest VLAN assignment delay feature is enabled on the port.
EAPOL packets
Number of sent (Tx) and received (Rx) EAPOL packets.
Number of sent EAP-Request/Identity packets.
Number of sent EAP-Request/Challenge packets.
EAP Success packets
Number of sent EAP-Success packets.
EAP Failure packets
Number of sent EAP-Failure packets.
Number of received EAPOL-Start packets.
Number of received EAPOL-LogOff packets.
Number of received EAP-Response/Identity packets.
Number of received EAP-Response/Challenge packets.
Error packets
Number of received error packets.
Online 802.1X users
Number of online 802.1X users on the port.
MAC address
MAC addresses of the online 802.1X users.
Auth state
Authentication status of the online 802.1X users.
display dot1x connection
Use display dot1x connection to display information about online 802.1X users.
display dot1x connection [ interface interface-type interface-number | slot slot-number | user-mac mac-address | user-name name-string ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, this command displays online 802.1X user information on all ports.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays online 802.1X user information on all member devices.
user-name name-string: Specifies an 802.1X user by its name. The name-string argument represents the username, a case-sensitive string of 1 to 253 characters.
user-mac mac-address: Specifies an 802.1X user by its MAC address. The mac-address argument represents the MAC address, in the form of H-H-H.
# Display information about all online 802.1X users.
<Sysname> display dot1x connection
Slot ID: 1
Username: ias
Authentication domain: aaa
Authentication method: CHAP
Initial VLAN: 1
Authorization untagged VLAN: N/A
Authorization tagged VLAN list: 1 to 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 29 31 33
                                35 37 40 to 100
Authorization ACL ID: 3001
Termination action: Default
Session timeout period: 2 s
Online from: 2013/03/02  13:14:15
Online duration: 0h 2m 15s
Total 1 connections matched.
Slot ID
Member ID of a device.
User MAC address
MAC address of the user.
Access interface
Interface through which the user access the device.
ISP domain used for 802.1X authentication.
EAP message handling method:
·     CHAP—Performs EAP termination and uses CHAP to communicate with the RADIUS server.
·     EAP—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
·     PAPPerforms EAP termination and uses PAP to communicate with the RADIUS server.
Initial VLAN
VLAN to which the user belongs before 802.1X authentication.
Untagged VLAN authorized to the user.
Tagged VLANs authorized to the user.
ACL authorized to the user.
User profile authorized to the user.
Termination action
Action attribute assigned by the server when the session timeout timer expires:
·     Default—Logs off the online authenticated 802.1X user. This attribute does not take effect when periodic online user reauthentication is enabled and the periodic reauthentication timer is shorter than the session timeout timer.
·     Radius-request—Reauthenticates the online user when the session timeout timer expires, regardless of whether the periodic online reauthentication feature is enabled or not.
If the device performs local authentication, this field displays N/A.
Session timeout timer assigned by the server.
Online from
Time from which the 802.1X user came online.
Online duration
Online duration of the 802.1X user.
Total xxx connections matched.
dot1x
Use dot1x to enable 802.1X globally or on a port.
Use undo dot1x to disable 802.1X globally or on a port.
dot1x
undo dot1x
802.1X is neither enabled globally nor enabled for any port.
System view, Layer 2 Ethernet interface view
For 802.1X to take effect on a port, you must enable it both globally and on the port.
# Enable 802.1X globally.
[Sysname] dot1x
# Enable 802.1X on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x
display dot1x
dot1x after-mac-auth max-attempt
Use dot1x after-mac-auth max-attempt to set the maximum number of 802.1X authentication attempts for MAC authenticated users on a port.
Use undo dot1x after-mac-auth max-attempt to restore the default.
dot1x after-mac-auth max-attempt max-attempts
The number of 802.1X authentication attempts for MAC authenticated users is not limited on a port.
max-attempts: Specifies a number in the range of 1 to 50.
The device denies 802.1X authentication requests of a MAC authenticated user after the maximum number of 802.1X authentication attempts has been made.
The device will recount the number of 802.1X authentication attempts made by a MAC authenticated user if a user logoff or device reboot occurs.
# Configure GigabitEthernet 1/0/1 to allow a maximum of 10 802.1X authentication attempts made by a MAC authenticated user.
[Sysname-GigabitEthernet1/0/1] dot1x after-mac-auth max-attempt 10
dot1x authentication-method
Use dot1x authentication-method to specify an EAP message handling method.
Use undo dot1x authentication-method to restore the default.
The access device performs EAP termination and uses CHAP to communicate with the RADIUS server.
chap: Sets the access device to perform Extensible Authentication Protocol (EAP) termination and use the Challenge Handshake Authentication Protocol (CHAP) to communicate with the RADIUS server.
eap: Sets the access device to relay EAP packets, and supports any of the EAP authentication methods to communicate with the RADIUS server.
pap: Sets the access device to perform EAP termination and use the Password Authentication Protocol (PAP) to communicate with the RADIUS server.
The access device terminates or relays EAP packets.
·     In EAP termination mode—The access device re-encapsulates and sends the authentication data from the client in standard RADIUS packets to the RADIUS server. The device performs either CHAP or PAP authentication with the RADIUS server. In this mode the RADIUS server supports only MD5-Challenge EAP authentication, and the username and password EAP authentication initiated by an iNode client.
¡     PAP transports usernames and passwords in plain text. The authentication method applies to scenarios that do not require high security. To use PAP, the client can be an iNode 802.1X client.
¡     CHAP transports usernames in plain text and passwords in encrypted form over the network. CHAP is more secure than PAP.
·     In EAP relay mode—The access device relays EAP messages between the client and the RADIUS server. The EAP relay mode supports multiple EAP authentication methods, such as MD5-Challenge, EAP-TLS, and PEAP. To use this mode, make sure the RADIUS server meets the following requirements:
¡     Supports the EAP-Message and Message-Authenticator attributes.
¡     Uses the same EAP authentication method as the client.
If this mode is used, the user-name-format command configured in RADIUS scheme view does not take effect. For more information about the user-name-format command, see "RADIUS commands."
If RADIUS authentication is used, you must configure the access device to use the same authentication method (PAP, CHAP, or EAP) as the RADIUS server.
# Enable the access device to terminate EAP packets and perform PAP authentication with the RADIUS server.
[Sysname] dot1x authentication-method pap
display dot1x
dot1x auth-fail vlan
Use dot1x auth-fail vlan to configure an 802.1X Auth-Fail VLAN on a port.
Use undo dot1x auth-fail vlan to restore the default.
dot1x auth-fail vlan authfail-vlan-id
No 802.1X Auth-Fail VLAN is configured on a port.
authfail-vlan-id: Specifies the ID of the 802.1X Auth-Fail VLAN on the port. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created and is not a super VLAN. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
An 802.1X Auth-Fail VLAN accommodates users that have failed 802.1X authentication for any reason other than unreachable servers.
To delete a VLAN that has been configured as an 802.1X Auth-Fail VLAN, you must first use the undo dot1x auth-fail vlan command.
# Configure VLAN 100 as the Auth-Fail VLAN on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x auth-fail vlan 100
display dot1x
dot1x critical eapol
Use dot1x critical eapol to enable the sending of an EAP-Success packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN on a port.
Use undo dot1x critical eapol to restore the default.
The device sends an EAP-Failure packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN on a port.
This command is available in Release 1122 and later.
Typically, the device sends EAP-Failure packets to 802.1X clients when the client users are assigned to the 802.1X critical VLAN. Some 802.1X clients, such as Windows built-in 802.1X clients, cannot respond to the EAP-Request/Identity packets of the device if they have received an EAP-Failure packet. As a result, reauthentication fails for these clients when an authentication server is reachable.
This command enables the device to send EAP-Success packets instead of EAP-Failure packets to 802.1X clients when the client users are assigned to the 802.1X critical VLAN. This operation ensures that all 802.1X clients can perform reauthentication.
# Send an EAP-Success packet to a client when the 802.1X client user is assigned to the 802.1X critical VLAN on GigabitEthernet1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x critical eapol
dot1x critical vlan
dot1x critical vlan
Use dot1x critical vlan to configure an 802.1X critical VLAN on a port.
Use undo dot1x critical vlan to restore the default.
dot1x critical vlan vlan-id
No 802.1X critical VLAN is configured on a port.
vlan-id: Specifies the ID of the 802.1X critical VLAN on the port. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created and is not a super VLAN. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
An 802.1X critical VLAN accommodates users that fail 802.1X authentication because all the RADIUS servers in their ISP domains are unreachable.
To delete a VLAN that has been configured as an 802.1X critical VLAN, you must first use the undo dot1x critical vlan command.
# Specify VLAN 100 as the 802.1X critical VLAN on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x critical vlan 100
display dot1x
dot1x critical-voice-vlan
Use dot1x critical-voice-vlan to enable the 802.1X critical voice VLAN on a port.
Use undo dot1x critical-voice-vlan to restore the default.
The 802.1X critical voice VLAN is disabled on a port.
The 802.1X critical voice VLAN on a port accommodates 802.1X voice users that have failed authentication because none of the RADIUS servers in their ISP domain are reachable.
Before you enable the 802.1X critical voice VLAN on the port, make sure the following requirements are met:
·     The port is configured with the voice VLAN.
To configure a voice VLAN on a port, use the voice-vlan enable command (see Layer 2—LAN Switching Command Reference).
·     LLDP is enabled both globally and on the port.
The device uses LLDP to identify voice users. For information about LLDP commands, see Layer 2—LAN Switching Command Reference.
# Enable the 802.1X critical voice VLAN on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x critical-voice-vlan
·     display dot1x
·     lldp enable (Layer 2—LAN Switching Command Reference)
·     lldp global enable (Layer 2—LAN Switching Command Reference)
·     voice-vlan enable (Layer 2—LAN Switching Command Reference)
dot1x domain-delimiter
Use dot1x domain-delimiter to specify a set of domain name delimiters supported by the device.
Use undo dot1x domain-delimiter to restore the default.
dot1x domain-delimiter string
The device supports only the at sign (@) delimiter for 802.1X users.
string: Specifies a set of 1 to 16 domain name delimiters for 802.1X users. No space is required between delimiters. Available delimiters include the at sign (@),backslash (\), dot (.), and forward slash (/). If you want to use backslash (\) as the domain name delimiter, you must enter the escape character (\) along with the backslash (\) sign.
Any character in the configured set can be used as the domain name delimiter for 802.1X authentication users.
Usernames that include domain names can use the format of username@domain-name, domain-name\username, username.domain-name, or username/domain-name.
The delimiter set you configured overrides the default setting. If the at sign (@) is not included in the delimiter set, the device does not support the 802.1X users that use this sign as the domain name delimiter.
If a username string contains multiple configured delimiters, the device takes the rightmost delimiter in the username string as the domain name delimiter. For example, if you configure the forward slash (/), dot (.), and backslash (\) as delimiters, the domain name delimiter for the username string 121.123/22\@abc is the backslash (\). The username is @abc and the domain name is 121.123/22.
# Specify the at sign (@) and forward slash (/) as domain name delimiters.
[Sysname] dot1x domain-delimiter @/
display dot1x
dot1x ead-assistant enable
Use dot1x ead-assistant enable to enable the EAD assistant feature.
Use undo dot1x ead-assistant enable to disable the EAD assistant feature.
The EAD assistant feature is disabled.
The EAD assistant feature enables the access device to redirect a user seeking to access the network to download and install EAD client. This feature eliminates the tedious job of the administrator to deploy EAD clients.
The feature is mutually exclusive with MAC authentication and port security. You must disable MAC authentication and port security globally before you enable the EAD assistant feature.
To make the EAD assistant feature take effect on a port, you must enable 802.1X on the port and set the port authorization mode to auto.
# Enable the EAD assistant feature.
[Sysname] dot1x ead-assistant enable
·     display dot1x
·     dot1x ead-assistant free-ip
·     dot1x ead-assistant url
Use dot1x ead-assistant free-ip to configure a free IP.
Use undo dot1x ead-assistant free-ip to restore the default.
dot1x ead-assistant free-ip ip-address { mask-address | mask-length }
undo dot1x ead-assistant free-ip { ip-address { mask-address | mask-length } | all }
No free IP is configured. Users cannot access any segments before they pass 802.1X authentication.
ip-address: Specifies a freely accessible IP address segment, also called a free IP.
mask: Specifies an IP address mask.
mask-length: Specifies IP address mask length in the range of 1 to 32.
all: Removes all free IP addresses.
Execute this command multiple times to configure multiple free IPs.
With EAD assistant enabled on the device, unauthenticated 802.1X users can access the network resources in the free IP segments before they pass 802.1X authentication.
# Configure 192.168.1.1/16 as a free IP.
[Sysname] dot1x ead-assistant free-ip 192.168.1.1 255.255.0.0
·     display dot1x
·     dot1x ead-assistant enable
Use dot1x ead-assistant url to configure a redirect URL.
Use undo dot1x ead-assistant url to restore the default.
dot1x ead-assistant url url-string
No redirect URL is configured.
url-string: Specifies a redirect URL, a case-insensitive string of 1 to 64 characters in the format http://string.
When an unauthenticated user uses a Web browser to access networks other than the free IP, the device redirects the user to the redirect URL.
The redirect URL must be on the free IP subnet.
If you execute the dot1x ead-assistant url command multiple times, the most recent configuration takes effect.
# Configure the redirect URL as http://test.com.
[Sysname] dot1x ead-assistant url http://test.com
·     display dot1x
dot1x guest-vlan
Use dot1x guest-vlan to configure an 802.1X guest VLAN on a port.
Use undo dot1x guest-vlan to restore the default.
dot1x guest-vlan guest-vlan-id
No 802.1X guest VLAN is configured on a port.
guest-vlan-id: Specifies the ID of the 802.1X guest VLAN. The value range for the VLAN ID is 1 to 4094. Make sure the VLAN has been created and is not a super VLAN. For more information about super VLANs, see Layer 2—LAN Switching Configuration Guide.
An 802.1X guest VLAN accommodates users that have not performed 802.1X authentication. In the guest VLAN, users can access a limited set of network resources, such as a software server, to download anti-virus software and system patches.
To delete a VLAN that has been configured as a guest VLAN, you must use the undo dot1x guest-vlan command first.
# Specify VLAN 100 as the 802.1X guest VLAN on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x guest-vlan 100
display dot1x
dot1x guest-vlan-delay
Use dot1x guest-vlan-delay to enable 802.1X guest VLAN assignment delay on a port.
Use undo dot1x guest-vlan-delay to disable 802.1X guest VLAN assignment delay on a port.
802.1X guest VLAN assignment delay is disabled on a port.
# Enable 802.1X guest VLAN assignment delay on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x guest-vlan-delay
dot1x handshake
Use dot1x handshake to enable the online user handshake feature.
Use undo dot1x handshake to disable the feature.
dot1x handshake
The online user handshake feature is enabled.
The online user handshake feature enables the device to periodically send handshake messages to the client for verifying the connectivity status of online 802.1X users. If the device does not receive any responses from an online user after making the maximum handshake attempts within the handshake timer, it sets the user to offline state. To set the handshake timer, use the dot1x timer handshake-period command. To set the maximum handshake attempts, use the dot1x retry command.
# Enable the online user handshake feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake
·     display dot1x
·     dot1x timer handshake-period
·     dot1x retry
dot1x handshake reply enable
Use dot1x handshake reply enable to enable the 802.1X online user handshake reply feature.
Use undo dot1x handshake reply enable to disable the 802.1X online user handshake reply feature.
The 802.1X online user handshake reply feature is disabled.
This command enables the device to reply to 802.1X clients' EAP-Response/Identity packets with EAP-Success packets during the online handshake process.
Use this command only if 802.1X clients will go offline without receiving EAP-Success packets from the device.
# Enable the 802.1X online user handshake reply feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake reply enable
dot1x handshake
dot1x handshake secure
Use dot1x handshake secure to enable the online user handshake security feature.
Use undo dot1x handshake secure to restore the default.
The online user handshake security feature is disabled.
The online user handshake security feature enables the device to prevent users from using illegal client software.
The device implements the feature based on the online user handshake feature. To bring the security feature into effect, make sure the online user handshake feature is enabled.
The online user handshake security feature takes effect only on the network where the iNode client and IMC server are used.
# Enable the online user handshake security feature on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x handshake secure
·     display dot1x
·     dot1x handshake
dot1x mandatory-domain
Use dot1x mandatory-domain to specify a mandatory 802.1X authentication domain on a port.
Use undo dot1x mandatory-domain to remove the mandatory authentication domain.
No mandatory 802.1X authentication domain is specified on a port.
domain-name: Specifies the ISP domain name, a case-insensitive string of 1 to 24 characters.
When the system authenticates an 802.1X user trying to access a port, it selects an authentication domain in the following order:
1.     Mandatory domain.
2.     ISP domain specified in the username.
3.     Default ISP domain.
# Configure the mandatory authentication domain my-domain for 802.1X users on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x mandatory-domain my-domain
display dot1x
dot1x max-user
Use dot1x max-user to set the maximum number of concurrent 802.1X users on a port.
Use undo dot1x max-user to restore the default.
dot1x max-user user-number
undo dot1x max-user
The maximum number of concurrent 802.1X users on a port is 2048.
user-number: Specifies the maximum number of concurrent 802.1X users on a port. The value range is 1 to 2048.
Set the maximum number of concurrent 802.1X users on a port to prevent the system resources from being overused. When the maximum number is reached, the port denies subsequent 802.1X users.
# Set the maximum number of concurrent 802.1X users on GigabitEthernet 1/0/1 to 32.
[Sysname-GigabitEthernet1/0/1] dot1x max-user 32
display dot1x
dot1x multicast-trigger
Use dot1x multicast-trigger to enable the 802.1X multicast trigger feature.
Use undo dot1x multicast-trigger to disable the feature.
The multicast trigger feature is enabled.
The multicast trigger feature enables the device to act as the initiator. The device periodically multicasts Identify EAP-Request packets out of a port to detect 802.1X clients and trigger authentication. You can use the dot1x timer tx-period command to set the interval for sending multicast Identify EAP-Request packets.
# Enable the multicast trigger feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x multicast-trigger
·     display dot1x
·     dot1x timer tx-period
·     dot1x unicast-trigger
dot1x port-control
Use dot1x port-control to set the authorization state for the port.
Use undo dot1x port-control to restore the default.
dot1x port-control { authorized-force | auto | unauthorized-force }
The default port authorization state is auto.
authorized-force: Places the port in authorized state, enabling users on the port to access the network without authentication.
auto: Places the port initially in unauthorized state to allow only EAPOL packets to pass, and places the port in authorized state after a user passes authentication. You can use this option in most scenarios.
unauthorized-force: Places the port in unauthorized state, denying any access requests from users on the port.
You can use this command to set the port authorization state to determine whether a client is granted access to the network or not.
# Set the authorization state of port GigabitEthernet 1/0/1 to unauthorized-force.
[Sysname-GigabitEthernet1/0/1] dot1x port-control unauthorized-force
display dot1x
dot1x port-method
Use dot1x port-method to specify an access control method for the port.
Use undo dot1x port-method to restore the default.
dot1x port-method { macbased | portbased }
MAC-based access control applies.
macbased: Uses MAC-based access control on the port to separately authenticate each user attempting to access the network. Using this method, when an authenticated user logs off, no other online users are affected.
portbased: Uses port-based access control on the port. Using this method, once an 802.1X user passes authentication on the port, any subsequent user can access the network through the port without authentication. When the authenticated user logs off, all other users are logged off.
# Configure GigabitEthernet 1/0/1 to implement port-based access control.
[Sysname-GigabitEthernet1/0/1] dot1x port-method portbased
display dot1x
dot1x quiet-period
Use dot1x quiet-period to enable the quiet timer.
Use undo dot1x quiet-period to disable the quiet timer.
dot1x quiet-period
The quiet timer is disabled.
When a client fails 802.1X authentication, the device must wait a period of time before it can process authentication requests from the client. You can use the dot1x timer quiet-period command to set the quieter timer.
# Enable the quiet timer and set the quiet timer to 100 seconds.
[Sysname] dot1x quiet-period
[Sysname] dot1x timer quiet-period 100
·     display dot1x
·     dot1x timer
dot1x re-authenticate
Use dot1x re-authenticate to enable the periodic online user reauthentication feature.
Use undo dot1x re-authenticate to disable the feature.
The periodic online user reauthentication feature is disabled.
Periodic reauthentication enables the access device to periodically authenticate online 802.1X users on a port. This feature tracks the connection status of online users and updates the authorization attributes assigned by the server.
You can use the dot1x timer reauth-period command to configure the interval for reauthentication.
# Enable the 802.1X periodic online user reauthentication feature on GigabitEthernet 1/0/1 and set the periodic reauthentication interval to 1800 seconds.
[Sysname] dot1x timer reauth-period 1800
[Sysname-GigabitEthernet1/0/1] dot1x re-authenticate
·     display dot1x
·     dot1x timer
dot1x re-authenticate server-unreachable keep-online
Use dot1x re-authenticate server-unreachable keep-online to enable the keep-online feature on a port. This feature keeps authenticated 802.1X users online when no server is reachable for 802.1X reauthentication.
Use undo dot1x re-authenticate server-unreachable to restore the default.
The keep-online feature is disabled on a port. The device logs off online 802.1X authenticated users if no server is reachable for 802.1X reauthentication.
# Enable the keep-online feature on GigabitEthernet 1/0/1 for 802.1X reauthentication.
[Sysname-GigabitEthernet1/0/1] dot1x re-authenticate server-unreachable keep-online
·     display dot1x
·     dot1x re-authenticate
dot1x retry
Use dot1x retry to set the maximum number of attempts for sending an authentication request to a client.
Use undo dot1x retry to restore the default.
dot1x retry max-retry-value
undo dot1x retry
A maximum of two attempts are made to send an authentication request to a client.
max-retry-value: Specifies the maximum number of attempts for sending an authentication request to a client. The value range is 1 to 10.
The access device retransmits an authentication request to a client in any of the following situations:
·     The device does not receive any responses from the client within the username request timeout timer. The timer is set by using the dot1x timer tx-period tx-period-value command for the EAP-Request/Identity packet.
·     The device does not receive any responses from the client within the client timeout timer. The timer is set by using the dot1x timer supp-timeout supp-timeout-value command for the EAP-Request MD5 Challenge packet.
The access device stops retransmitting the request, if it has made the maximum number of request transmission attempts but still received no response.
# Set the maximum number of attempts for sending an authentication request to a client to 9.
[Sysname] dot1x retry 9
·     display dot1x
·     dot1x timer
dot1x timer
Use dot1x timer to set 802.1X timers.
Use undo dot1x timer to restore the defaults.
dot1x timer { ead-timeout ead-timeout-value | handshake-period handshake-period-value | quiet-period quiet-period-value | reauth-period reauth-period-value | server-timeout server-timeout-value | supp-timeout supp-timeout-value | tx-period tx-period-value }
undo dot1x timer { ead-timeout | handshake-period | quiet-period | reauth-period | server-timeout | supp-timeout | tx-period }
The following timers apply:
·     EAD rule timer: 30 minutes.
·     Handshake timer: 15 seconds.
·     Quiet timer: 60 seconds.
·     Periodic reauthentication timer: 3600 seconds.
·     Server timeout timer: 100 seconds.
·     Client timeout timer: 30 seconds.
·     Username request timeout timer: 30 seconds.
ead-timeout ead-timeout-value: Sets the EAD rule timer in minutes. The value range for the ead-timeout-value argument is 1 to 1440.
handshake-period handshake-period-value: Sets the handshake timer in seconds. The value range for the handshake-period-value argument is 5 to 1024.
quiet-period quiet-period-value: Sets the quiet timer in seconds. The value range for the quiet-period-value argument is 10 to 120.
reauth-period reauth-period-value: Sets the periodic reauthentication timer in seconds. The value range for the reauth-period-value argument is 60 to 7200.
server-timeout server-timeout-value: Sets the server timeout timer in seconds. The value range for the server-timeout-value argument is 100 to 300.
supp-timeout supp-timeout-value: Sets the client timeout timer in seconds. The value range for the supp-timeout-value argument is 1 to 120.
tx-period tx-period-value: Sets the username request timeout timer in seconds. The value range for the tx-period-value argument is 1 to 120.
In most cases, the default settings are sufficient. You can edit the timers, depending on the network conditions.
·     In a low-speed network, increase the client timeout timer.
·     In a vulnerable network, set the quiet timer to a high value.
·     In a high-performance network with quick authentication response, set the quiet timer to a low value.
·     In a network with authentication servers of different performance, adjust the server timeout timer.
The network device uses the following 802.1X timers:
·     EAD rule timer (EAD timeout)Sets the lifetime of each EAD rule. When the timer expires or the user passes authentication, the rule is removed. If users fail to download the EAD client or fail to pass authentication within the timer, they must reconnect to the network to access the free IP.
·     Handshake timer (handshake-period)Sets the interval at which the access device sends client handshake requests to check the online status of a client that has passed authentication. If the device does not receive a response after sending the maximum number of handshake requests, it considers that the client has logged off.
·     Quiet timer (quiet-period)Starts when a client fails authentication. The access device must wait the time period before it can process the authentication attempts from the client.
·     Periodic reauthentication timer (reauth-period)Sets the interval at which the network device periodically reauthenticates online 802.1X users. To enable periodic online user reauthentication on a port, use the dot1x re-authenticate command. The change to the periodic reauthentication timer applies to the users that have been online only after the old timer expires.
·     Server timeout timer (server-timeout)Starts when the access device sends a RADIUS Access-Request packet to the authentication server. If no response is received when this timer expires, the access device retransmits the request to the server.
·     Client timeout timer (supp-timeout)Starts when the access device sends an EAP-Request/MD5 Challenge packet to a client. If no response is received when this timer expires, the access device retransmits the request to the client.
·     Username request timeout timer (tx-period)Starts when the device sends an EAP-Request/Identity packet to a client in response to an authentication request. If the device does not receive a response before this timer expires, it retransmits the request. The timer also sets the interval at which the network device sends multicast EAP-Request/Identity packets to detect clients that cannot actively request authentication.
# Set the server timeout timer to 150 seconds.
[Sysname] dot1x timer server-timeout 150
display dot1x
Use dot1x unicast-trigger to enable the 802.1X unicast trigger feature.
Use undo dot1x unicast-trigger to disable the feature.
The unicast trigger feature is disabled.
The unicast trigger feature enables the access device to initiate 802.1X authentication when the device receives a data frame from an unknown source MAC address. The device sends a unicast Identity EAP/Request packet to the unknown source MAC address. It will retransmit the packet if it does not receive any responses within a period of time (set by using the dot1x timer tx-period command). This process continues until the maximum number of request attempts (set by using the dot1x retry command) is reached.
# Enable the unicast trigger feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dot1x unicast-trigger
·     display dot1x
·     dot1x multicast-trigger
·     dot1x retry
·     dot1x timer
reset dot1x guest-vlan
Use reset dot1x guest-vlan to remove users from the 802.1X guest VLAN on a port.
reset dot1x guest-vlan interface interface-type interface-number [ mac-address mac-address ]
mac-address mac-address: Specifies the MAC address of an 802.1X user in the guest VLAN.
# Remove the 802.1X user with MAC address 1-1-1 from the 802.1X guest VLAN on port GigabitEthernet 1/0/1.
<Sysname> reset dot1x guest-vlan interface gigabitethernet 1/0/1 mac-address 1-1-1
dot1x guest-vlan
reset dot1x statistics
Use reset dot1x statistics to clear 802.1X statistics on ports.
reset dot1x statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies a port by its type and number. If you do not specify a port, the command clears 802.1X statistics on all ports.
# Clear 802.1X statistics on GigabitEthernet 1/0/1.
<Sysname> reset dot1x statistics interface gigabitethernet 1/0/1
display dot1x
