- 04-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-Port isolation configuration
- 04-VLAN configuration
- 05-QinQ configuration
- 06-Loop detection configuration
- 07-Spanning tree configuration
- 08-LLDP configuration
- 09-Layer 2 forwarding configuration
- 10-VLAN termination configuration
| 03-Port isolation configuration | 74.56 KB |
Restrictions: Hardware compatibility with port isolation
Assigning a port to the isolation group·
Display and maintenance commands for port isolation
Port isolation configuration examples
Example: Configuring port isolation (for single-isolation group devices)
About port isolation
The port isolation feature isolates Layer 2 traffic for data privacy and security without using VLANs.
Ports in an isolation group cannot communicate with each other. However, they can communicate with ports outside the isolation group.
This feature is not supported on Ethernet switching modules SIC-4FSW or SIC-4FSW-PoE.
About port assignment to the isolation group
The device supports only one isolation group that is automatically created as isolation group 1. You cannot remove the isolation group or create other isolation groups on the device. The number of ports assigned to the isolation group is not limited.
· The configuration in Layer 2 Ethernet interface view applies only to the interface.
· The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
1. Enter system view.
2. Enter interface view.
3. Assign the port to the isolation group.
port-isolate enable
By default, the port is not in the isolation group.
Task |
Command |
Display port isolation group information. |
display port-isolate group |
As shown in Figure 1:
· LAN users Host A, Host B, and Host C are connected to GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 on the device, respectively.
· The device connects to the Internet through GigabitEthernet 1/0/4.
Configure the device to provide Internet access for all the hosts, and isolate them from one another.
# Assign GigabitEthernet1/0/1, GigabitEthernet1/0/2, and GigabitEthernet1/0/3 to the isolation group.
[Device-GigabitEthernet1/0/1] port-isolate enable
[Device-GigabitEthernet1/0/2] port-isolate enable
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] port-isolate enable
[Device-GigabitEthernet1/0/3] quit
# Display information about the isolation group.
[Device] display port-isolate group
Port isolation group information:
Group ID: 1
Group members:
GigabitEthernet1/0/1 GigabitEthernet1/0/2 GigabitEthernet1/0/3
The output shows that GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 are assigned to the isolation group. As a result, Host A, Host B, and Host C are isolated from one another at Layer 2.
This example applies to devices that support only one isolation group.
Network requirements
As shown in Figure 2, AP 1, AP 2, and AP 3 are connected to GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 on the AC, respectively. The AC connects to the Internet through GigabitEthernet 1/0/4.
Configure the AC to provide Internet access for the APs, and isolate APs from one another.
Configuration procedure
# Assign ports GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to the isolation group.
<AC> system-view
[AC-GigabitEthernet1/0/1] port-isolate enable
[AC] interface gigabitethernet 1/0/2
[AC-GigabitEthernet1/0/2] port-isolate enable
[AC-GigabitEthernet1/0/2] quit
[AC] interface gigabitethernet 1/0/3
[AC-GigabitEthernet1/0/3] port-isolate enable
[AC-GigabitEthernet1/0/3] quit
[AC] display port-isolate group
Group ID: 1
Group members:
The output shows that ports GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 are assigned to the isolation group. As a result, the APs are isolated from one another at Layer 2.
