10-MPLS Command Reference
HomeSupportResource CenterReference GuidesCommand ReferencesH3C MSR810 2600 3600 Routers Command References(V7)-R0707-6W30110-MPLS Command Reference
09-MPLS L3VPN commands
09-MPLS L3VPN commands 253.60 KB
MPLS L3VPN commands· 1
address-family ipv4 (VPN instance view) 1
dampening ibgp· 2
address-family vpnv4· 3
description (VPN instance view) 4
display bgp routing-table ipv4 unicast inlabel 4
display bgp routing-table ipv4 unicast outlabel 5
display bgp routing-table vpnv4· 7
display bgp routing-table vpnv4 inlabel 16
display bgp routing-table vpnv4 outlabel 17
display ip vpn-instance· 18
display ospf sham-link· 20
domain-id (OSPF view) 21
export route-policy· 22
ext-community-type (OSPF view) 23
import route-policy· 23
ip binding vpn-instance· 24
ip vpn-instance (system view) 25
nesting-vpn· 26
peer next-hop-invariable· 26
peer reflect-route· 27
peer upe· 28
peer upe route-policy· 28
policy vpn-target 29
route-distinguisher (VPN instance view) 30
route-replicate· 31
route-tag (OSPF view) 32
routing-table limit 33
rr-filter (BGP VPNv4 address family view) 35
sham-link (OSPF area view) 35
snmp context-name· 38
snmp-agent trap enable l3vpn· 39
tnl-policy· 39
vpn popgo· 41
vpn-id· 41
vpn-route cross multipath· 42
vpn-target 43
IPv6 MPLS L3VPN commands· 45
address-family ipv6 (VPN instance view) 45
address-family vpnv6· 46
disable-dn-bit-check· 46
disable-dn-bit-set 47
display bgp routing-table vpnv6· 48
display bgp routing-table vpnv6 inlabel 56
display bgp routing-table vpnv6 outlabel 57
display ospfv3 sham-link· 59
domain-id (OSPFv3 view) 60
ext-community-type (OSPFv3 view) 61
peer next-hop-invariable (BGP VPNv6 address family view) 62
policy vpn-target 63
route-tag (OSPFv3 view) 64
route-tag-check enable· 65
rr-filter (BGP VPNv6 address family view) 66
sham-link (OSPFv3 area view) 66
MPLS L3VPN commands
The following compatibility matrix shows the support of hardware platforms for MPLS L3VPN:
Hardware
MPLS L3VPN compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA
No
MSR810-LMS, MSR810-LUS
No
MSR2600-6-X1, MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
MSR3610-I-DP, MSR3610-IE-DP
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
Use address-family ipv4 to enter VPN instance IPv4 VPN view.
Use undo address-family ipv4 to remove all configurations from VPN instance IPv4 VPN view.
address-family ipv4
VPN instance view
In VPN instance IPv4 VPN view, you can configure IPv4 VPN parameters such as inbound and outbound routing policies.
# Enter VPN instance IPv4 VPN view.
[Sysname-vpn-instance-vpn1] address-family ipv4
[Sysname-vpn-ipv4-vpn1]
dampening ibgp
Use dampening ibgp to configure BGP VPNv4 route dampening.
Use undo dampening ibgp to restore the default.
dampening ibgp [ half-life-reachable half-life-unreachable reuse suppress ceiling | route-policy route-policy-name ] *
undo dampening ibgp
BGP VPNv4 route dampening is not configured.
half-life-reachable: Specifies a half-life for active flapping routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Specifies a half-life for suppressed flapping routes, in the range of 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Specifies a reuse threshold value for suppressed routes, in the range of 1 to 20000. The default value is 750. A suppressed route whose penalty value decreases under the value is reused. The reuse threshold must be smaller than the suppression threshold.
suppress: Specifies a suppression threshold in the range of 1 to 20000. The default value is 2000. A route with a penalty value greater than this threshold is suppressed.
ceiling: Specifies a ceiling penalty value in the range of 1001 to 20000. The default value is 16000. The value must be greater than the suppression threshold.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
This command applies only to IBGP routes.
If an IBGP peer goes down after you configure this feature, VPNv4 routes coming from the peer are dampened but not deleted.
# In BGP VPNv4 address family view, configure IBGP route dampening. Set the half-life for both active and suppressed flapping routes to 10 minutes, the reuse threshold to 1000, the suppression threshold to 2000, and the ceiling penalty to 10000.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] dampening ibgp 10 10 1000 2000 10000
display bgp dampening parameter (Layer 3—IP Routing Command Reference)
Use address-family vpnv4 in BGP view to create the BGP VPNv4 address family and enter its view, or enter the view of the existing BGP VPNv4 address family.
Use address-family vpnv4 in BGP-VPN instance view to create the BGP-VPN VPNv4 address family and enter its view, or enter the view of the existing BGP-VPN VPNv4 address family.
Use undo address-family vpnv4 to remove the BGP VPNv4 address family or BGP-VPN VPNv4 address family, and all settings in address family view.
The BGP VPNv4 address family or BGP-VPN VPNv4 address family does not exist.
BGP instance view
A VPNv4 address consists of an RD and an IPv4 prefix. VPNv4 routes are routes that carry VPNv4 addresses.
For a PE to exchange BGP VPNv4 routes with a BGP peer, enable that peer by executing the peer enable command in BGP VPNv4 or BGP-VPN VPNv4 address family view.
In BGP VPNv4 address family view, you can configure the following settings:
·     BGP VPNv4 route attributes, such as the preferred value.
·     Whether to allow the local AS number to appear in the AS_PATH attribute of received route updates.
The settings in BGP VPNv4 address family view control VPNv4 route exchange between PEs.
The settings in BGP-VPN VPNv4 address family view control VPNv4 route exchange between provider PE and provider CE in nested MPLS L3VPN.
# Create the BGP VPNv4 address family and enter its view.
[Sysname] bgp 100
Use description to configure a description for a VPN instance.
No description is configured for a VPN instance.
VPN instance view
text: Specifies a description, a case-sensitive string of 1 to 79 characters.
# Configure a description of This is vpn1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] description This is vpn1
Use display bgp routing-table ipv4 unicast inlabel to display incoming labels for BGP IPv4 unicast routes.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] inlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays incoming labels for BGP IPv4 unicast routes in the default BGP instance.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays incoming labels for BGP IPv4 unicast routes on the public network.
This command displays incoming labels for BGP IPv4 unicast routes regardless of whether the unicast keyword is specified or not.
# Display incoming labels for all BGP IPv4 unicast routes on the public network.
<Sysname> display bgp routing-table ipv4 inlabel
 Total number of routes: 1
 BGP local router ID is 3.3.3.9
     Network            NextHop         OutLabel        InLabel
* >  2.2.2.9/32         1.1.1.2         1151            1279
BGP local router ID
Router ID of the local BGP router.
Status codes
Route status codes:
·     * - valid—Valid route.
·     > - best—Common optimal route.
·     d – damped—Route damped for route flap.
·     h - history—History route.
·     i - internal—Internal route.
·     e - external—External route.
·     s - suppressed—Suppressed route.
·     S - Stale—Stale route.
Origin
Route origin:
·     i - IGP—Originated in the AS. The origin of routes advertised by the network command is IGP.
·     e - EGP—Learned through EGP.
·     ? - incomplete—Redistributed from IGP protocols.
OutLabel
Outgoing label.
InLabel
Incoming label.
Use display bgp routing-table ipv4 unicast outlabel to display outgoing labels for BGP IPv4 unicast routes.
display bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays outgoing labels for BGP IPv4 unicast routes in the default BGP instance.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays outgoing labels for BGP IPv4 unicast routes on the public network.
This command displays outgoing labels for BGP IPv4 unicast routes regardless of whether the unicast keyword is specified or not.
# Display outgoing labels for all public BGP IPv4 unicast routes in the default BGP instance.
<Sysname> display bgp routing-table ipv4 outlabel
BGP local router ID
Status codes
Route status codes:
Origin
Route origin:
OutLabel
Outgoing label.
Use display bgp routing-table vpnv4 to display BGP VPNv4 routing information.
display bgp [ instance instance-name ] routing-table vpnv4 [ [ route-distinguisher route-distinguisher ] [ ipv4-address [ { mask-length | mask } [ longest-match ] ] | ipv4-address [ mask-length | mask ] advertise-info | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | [ vpn-instance vpn-instance-name ] peer ipv4-address { advertised-routes | received-routes } [ ipv4-address [ mask-length | mask ] | statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays BGP VPNv4 routes in the default BGP instance.
route-distinguisher route-distinguisher: Specifies an RD, a string of 3 to 21 characters in one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
ipv4-address: Specifies the destination IPv4 address.
mask-length: Specifies the length of the network mask, in the range of 0 to 32.
mask: Specifies the network mask, in dotted decimal notation.
longest-match: Displays the longest matching BGP VPNv4 route. The longest matching BGP VPNv4 route is selected through the following steps:
1.     ANDs the specified network address with the mask of each route.
2.     Matches a route if the AND result is the same as the network address of the route and the mask of the route is shorter than or equal to the specified mask.
3.     Selects the route with the longest mask among the matching routes.
advertise-info: Displays advertisement information for BGP VPNv4 routes.
as-path-acl as-path-acl-number: Displays BGP VPNv4 routes that match the AS path list specified by its number in the range of 1 to 256.
community-list: Displays BGP VPNv4 routes that match a BGP community list.
basic-community-list-number: Specifies a basic community list by its number in the range of 1 to 99.
comm-list-name: Specifies a community list by its name, a case-sensitive string of 1 to 63 characters.
whole-match: Displays BGP VPNv4 routes exactly matching the specified community list. If you do not specify this keyword, the command displays BGP VPNv4 routes whose COMMUNITY attributes include the specified community list.
adv-community-list-number: Specifies an advanced community list by its number in the range of 100 to 199.
vpn-instance vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays BGP VPNv4 routes advertised to or received from the specified peer on the public network.
peer: Displays BGP VPNv4 routing information advertised to or received from a peer.
ipv4-address: Specifies the peer IPv4 address.
advertised-routes: Displays BGP VPNv4 routing information advertised to the specified peer.
received-routes: Displays BGP VPNv4 routing information received from the specified peer.
statistics: Displays BGP VPNv4 routing statistics.
If you do not specify any parameters, this command displays brief information about all BGP VPNv4 routes.
If you specify ipv4-address mask or ipv4-address mask-length, this command displays detailed information about the BGP VPNv4 route that exactly matches the specified address and mask.
If you specify only ipv4-address, the system ANDs the network address with the mask of a route. If the result matches the network address of the route, this command displays detailed information about the BGP VPNv4 route.
# Display brief information about all BGP VPNv4 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv4
 BGP local router ID is 1.1.1.9
 Total number of routes from all PEs: 8
 Route distinguisher: 100:1(vpn1)
 Total number of routes: 6
* >  10.1.1.0/24        10.1.1.2        0                     32768   ?
*  e                    10.1.1.1        0                     0       65410?
* >  10.1.1.2/32        127.0.0.1       0                     32768   ?
* >i 10.3.1.0/24        3.3.3.9         0          100        0       ?
* >e 192.168.1.0        10.1.1.1        0                     0       65410?
*  i                    3.3.3.9         0          100        0       65420?
 Route distinguisher: 200:1
 Total number of routes: 2
* >i 192.168.1.0        3.3.3.9         0          100        0       65420?
# Display brief information about BGP VPNv4 routes with RD 100:1 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1
# Display information about BGP VPNv4 routes matching AS_PATH list 1 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 as-path-acl 1
# Display information about BGP VPNv4 routes matching BGP community list 100 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 community-list 100
# Display information about public BGP VPNv4 routes advertised to peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes
     Network            NextHop         MED        LocPrf             Path/Ogn
* >  10.1.1.0/24        10.1.1.2        0                             ?
* >e 192.168.1.0        10.1.1.1        0                             65410?
# Display information about public BGP VPNv4 routes received from peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes
BGP local router ID
Status codes
Route status codes:
Origin
Route origin:
Total number of VPNv4 routes from all PEs.
Network
Network address.
NextHop
Next hop address.
MED
MULTI_EXIT_DISC attribute.
LocPrf
Local preference value.
PrefVal
Preferred value.
Path/Ogn
AS_PATH and Origin attributes.
# Display detailed information about BGP VPNv4 routes to 10.3.1.0/24 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 10.3.1.0 24
 BGP local router ID: 1.1.1.9
 Local AS number: 100
 Paths:   1 available, 1 best
 Rely nexthop    : 172.1.1.2
 Original nexthop: 3.3.3.9
 OutLabel        : 1279
 Ext-Community   : <RT: 111:1>
 AS-path         : (null)
 Origin          : incomplete
 State           : valid, internal, best
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 VPN-Peer UserID : N/A
 DSCP            : N/A
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
# Display detailed information about the BGP VPNv4 route to 10.3.1.0/24 and with RD 100:1 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 route-distinguisher 100:1 10.3.1.0 24
 OutLabel        : 1279
 AS-path         : (null)
 Origin          : incomplete
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
Rely Nexthop
Recursive next hop. If no recursive next hop is found, this field displays not resolved.
Original nexthop
Original next hop. If the route is learned from a BGP update, it is the next hop in the update message.
Ext-Community
Extended community attribute:
·     RT—Route Target extended community.
·     RT Import—VRF Route Import extended community used for multicast VPN.
·     SrcAs—Source AS extended community used for multicast VPN.
Origin
Route origin:
·     igp—Originated in the AS. The origin of routes advertised by the network command is IGP.
·     egp—Learned through EGP.
·     incomplete—Redistributed from IGP protocols.
Attribute value
BGP route attribute information:
·     MED—MED attribute.
·     localpref—Local preference.
·     pref-val—Preferred value.
·     pre—Protocol preference.
Route status:
·     valid—Valid route.
·     internal—Internal route.
·     external—External route.
·     local—Locally generated route.
·     synchronize—Synchronized route.
·     best—Optimal route.
IP precedence
IP priority of a route, in the range of 0 to 7. N/A indicates that the route does not support this field.
QoS local ID
QoS local ID attribute of a route, in the range of 1 to 4095. N/A indicates that the route does not support this field.
Traffic index
Index of the traffic, in the range of 1 to 64. N/A indicates that the route does not support this field.
VPN-Peer UserID
VPN peer ID in the range of 1 to 134217727. N/A indicates that the route does not support this field.
DSCP
DSCP value in the range of 0 to 63. N/A indicates that the route does not support this field.
# Display advertisement information for BGP VPNv4 routes to 10.1.1.0/24 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 10.1.1.0 24 advertise-info
 Paths:   1 best
 BGP routing table information of 10.1.1.0/24:
    3.3.3.9
 Inlabel         : 1279
Table 5 Command output
Paths
Number of routes to the specified destination network.
Advertisement information for the BGP route to 10.1.1.0/24.
VPNv4 peers to which the route is advertised, and the number of peers.
Inlabel
Incoming label of the route.
# Display statistics about public BGP VPNv4 routes advertised to peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 advertised-routes statistics
 Advertised routes total: 2
# Display statistics about public BGP VPNv4 routes received from peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 peer 3.3.3.9 received-routes statistic
 Received routes total: 2
Table 6 Command output
Total number of routes advertised to the specified peer.
Total number of routes received from the specified peer.
# Display statistics about public BGP VPNv4 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 statistics
Table 7 Command output
Total number of VPNv4 routes with the specified RD.
ip as-path (Layer 3—IP Routing Command Reference)
Use display bgp routing-table vpnv4 inlabel to display incoming labels for BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 inlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays incoming labels for all BGP VPNv4 routes in the default BGP instance.
# Display incoming labels for all BGP VPNv4 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 inlabel
* >  10.1.1.0/24        10.1.1.2        NULL            1279
* >e 192.168.1.0        10.1.1.1        NULL            1278
Table 8 Command output
BGP local router ID
Status codes
Route status codes:
Origin
Route origin:
OutLabel
Outgoing label. If the peer PE assigns a null label, this field displays NULL.
InLabel
Incoming label.
Use display bgp routing-table vpnv4 outlabel to display outgoing labels for BGP VPNv4 routes.
display bgp [ instance instance-name ] routing-table vpnv4 outlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays outgoing labels for all BGP VPNv4 routes in the default BGP instance.
# Display outgoing labels for all BGP VPNv4 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv4 outlabel
 Total number of routes from all PEs: 4
* >i 10.3.1.0/24        3.3.3.9         1279
*  i 192.168.1.0        3.3.3.9         1278
* >i 192.168.1.0        3.3.3.9         1278
Table 9 Command output
BGP local router ID
Status codes
Route status codes:
Origin
Route origin:
OutLabel
Use display ip vpn-instance to display information about VPN instances.
display ip vpn-instance [ instance-name vpn-instance-name ]
instance-name vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays brief information about all VPN instances.
# Display brief information about all VPN instances.
<Sysname> display ip vpn-instance
  VPN-Instance Name               RD                     Create time
  abc                             1:1                    2011/05/18 10:48:17
Table 10 Command output
VPN-Instance Name
Name of the VPN instance.
RD
RD of the VPN instance.
Create Time
Time when the VPN instance was created.
# Display detailed information about VPN instance vpn1.
<Sysname> display ip vpn-instance instance-name vpn1
  VPN-Instance Name and Index : vpn1, 2
  Route Distinguisher : 100:1
  VPN ID : 1:1
  Description : vpn1
  Interfaces : GigabitEthernet1/0/2
  Address-family IPv4:
   Export VPN Targets :
       2:2
   Import VPN Targets :
       3:3
   Export Route Policy : outpolicy
   Import Route Policy : inpolicy
   Tunnel Policy : tunnel1
   Maximum Routes Limit : 500
   Threshold Value(%): 50
  Address-family IPv6:
       2:2
       3:3
   Maximum Routes Limit :500
Table 11 Command output
Route Distinguisher
Route distinguisher of the VPN instance.
Interfaces
Interfaces that are associated with the VPN instance.
Address-family IPv4
IPv4 VPN information.
Address-family IPv6
IPv6 VPN information.
Export Route Policy
Routing policy in the outbound direction.
Import Route Policy
Routing policy in the inbound direction.
Maximum number of routes.
Threshold Value(%)
Alarm threshold for number of active routes.
Use display ospf sham-link to display OSPF sham link information.
display ospf [ process-id ] sham-link [ area area-id ]
process-id: Specifies an OSPF process by its ID. The process ID is in the range of 1 to 65535. If you do not specify a process, this command displays sham link information for all OSPF processes.
area area-id: Specifies an OSPF area by its ID, which is an IP address, or an integer. The integer is in the range of 0 to 4294967295. If you do not specify an area, this command displays sham link information for all OSPF areas.
If you do not specify any processes or areas, this command displays information about all OSPF sham links.
# Display information about all OSPF sham links.
<Sysname> display ospf sham-link
          OSPF Process 1 with Router ID 125.1.1.1
                  Sham link
 Area            Neighbor ID     Source IP       Destination IP  State  Cost
 0.0.0.0         95.1.1.1        125.2.1.1       95.2.1.1        P-2-P  1
# Display OSPF sham link information for OSPF area 1.
<Sysname> display ospf sham-link area 1
          OSPF Process 100 with Router ID 100.1.1.2
 Sham link: 3.3.3.3 --> 5.5.5.5
 Neighbor ID: 120.1.1.2        State: Full
 Area: 0.0.0.1
 Cost: 1  State: P-2-P  Type: Sham
 Request list: 0  Retransmit list: 0
 GTSM: Enabled, maximum number of hops: 2
 MD5 authentication enabled.
    The last key is 3.
    The rollover is in progress, 1 neighbor(s) left.
Table 12 Command output
Neighbor state for the sham link: Down, Init, 2-way, ExStart, Exchange, Loading, or Full.
Cost
Cost of the sham link.
Sham link state: Down or P-2-P.
Timers
Timers for the sham link, in seconds. The timers include Hello timer, Dead timer, Retransmit timer, and Transmit Delay timer.
OSPF GTSM is enabled, and the maximum number of hops is 2.
If OSPF GTSM is disabled, this field displays GTSM: Disabled.
Use domain-id to set an OSPF domain ID.
Use undo domain-id to delete an OSPF domain ID.
undo domain-id [ domain-id ]
The OSPF domain ID is 0.
OSPF view
domain-id: Specifies an OSPF domain ID, in one of the following formats:
·     Integer, in the range of 0 to 4294967295. For example, 1.
·     Dotted decimal notation. For example, 0.0.0.1.
·     Dotted decimal notation:16-bit user-defined number in the range of 0 to 65535. For example, 0.0.0.1:512.
secondary: Specifies a secondary domain ID. If you do not specify this keyword, the command specifies a primary domain ID.
When you redistribute OSPF routes into BGP, BGP adds the primary domain ID to the redistributed BGP VPNv4 routes as a BGP extended community attribute. Then, BGP advertises the routes to the peer PE.
When the peer PE receives the routes, it compares the OSPF domain ID in the routes with the locally configured primary and secondary domain IDs. OSPF advertises these routes in Network Summary LSAs (Type 3) if both the following conditions exist:
·     The primary or secondary domain ID is the same as the received domain ID.
·     The received routes are intra-area or inter-area routes.
Otherwise, OSPF advertises these routes in AS External LSAs (Type 5) or NSSA External LSAs (Type 7).
If you do not specify any parameters, the undo domain-id command restores the default.
# Set the OSPF domain ID to 234.
[Sysname] ospf 100
[Sysname-ospf-100] domain-id 234
export route-policy
Use export route-policy to apply an export routing policy to a VPN instance.
Use undo export route-policy to restore the default.
No export routing policy is applied to a VPN instance.
VPN instance view
VPN instance IPv6 VPN view
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter advertised routes or modify their route attributes for the VPN instance.
An export routing policy specified in VPN instance view applies to both IPv4 VPN and IPv6 VPN. An export routing policy specified in VPN instance IPv4 VPN view applies only to the IPv4 VPN. An export routing policy specified in VPN instance IPv6 VPN view applies only to the IPv6 VPN.
IPv4 VPN prefers the export routing policy specified in VPN instance IPv4 VPN view over the one specified in VPN instance view.
IPv6 VPN prefers the export routing policy specified in VPN instance IPv6 VPN view over the one specified in VPN instance view.
# Apply export routing policy poly-1 to VPN instance vpn1.
[Sysname-vpn-instance-vpn1] export route-policy poly-1
import route-policy
route-policy (Layer 3—IP Routing Command Reference)
Use ext-community-type to configure the type code of an OSPF extended community attribute.
Use undo ext-community-type to restore the default.
undo ext-community-type [ domain-id | router-id | route-type ]
The type codes for domain ID, router ID, and route type are hex numbers 0005, 0107, and 0306, respectively.
OSPF view
domain-id type-code1: Specifies the type code for domain ID. Valid values are hex numbers 0005, 0105, 0205, and 8005.
router-id type-code2: Specifies the type code for router ID. Valid values are hex numbers 0107 and 8001.
route-type type-code3: Specifies the type code for route type. Valid values are hex numbers 0306 and 8000.
# Configure the type codes of domain ID, router ID, and route type as hex numbers 8005, 8001, and 8000, respectively, for OSPF process 100.
[Sysname] ospf 100
[Sysname-ospf-100] ext-community-type domain-id 8005
[Sysname-ospf-100] ext-community-type router-id 8001
[Sysname-ospf-100] ext-community-type route-type 8000
import route-policy
Use import route-policy to apply an import routing policy to a VPN instance.
Use undo import route-policy to restore the default.
All routes matching the import target attribute are accepted.
VPN instance view
You can specify an import routing policy to filter received routes or modify their route attributes for the VPN instance.
An import routing policy specified in VPN instance view applies to both IPv4 VPN and IPv6 VPN. An import routing policy specified in VPN instance IPv4 VPN view applies only to the IPv4 VPN. An import routing policy specified in VPN instance IPv6 VPN view applies only to the IPv6 VPN.
IPv4 VPN prefers the import routing policy specified in VPN instance IPv4 VPN view over the one specified in VPN instance view.
IPv6 VPN prefers the import routing policy specified in VPN instance IPv6 VPN view over the one specified in VPN instance view.
# Apply import routing policy poly-1 to VPN instance vpn1.
[Sysname-vpn-instance-vpn1] import route-policy poly-1
export route-policy
Use ip binding vpn-instance to associate an interface with a VPN instance.
Use undo ip binding vpn-instance to restore the default.
An interface is associated with no VPN instance and belongs to the public network.
Interface view
Use this command to associate the VPN instance with the interface connected to the CE.
This command or its undo form clears the IP address and routing protocol configuration on the interface. The specified VPN instance must have been created by using the ip vpn-instance command in system view.
To associate a new VPN instance with an interface, first execute the undo ip binding vpn-instance command to remove the existing association.
# Associate GigabitEthernet 1/0/1 with VPN instance vpn1.
[Sysname-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
Use ip vpn-instance to create a VPN instance and enter its view, or enter the view of an existing VPN instance.
Use undo ip vpn-instance to delete a VPN instance.
No VPN instances exist.
vpn-instance-name: Specifies a VPN instance name, a case-sensitive string of 1 to 31 characters.
# Create a VPN instance named vpn1 and enter its view.
route-distinguisher
nesting-vpn
Use nesting-vpn to enable the nested VPN feature.
Use undo nesting-vpn to disable the nested VPN feature.
nesting-vpn
undo nesting-vpn
The nested VPN feature is disabled.
To exchange VPNv4 routes with a peer in nested VPN, enable nested VPN, and then execute the peer enable command to enable that peer in BGP-VPN VPNv4 address family view.
# Enable nested VPN.
[Sysname] bgp 10
[Sysname-bgp-default-vpnv4] nesting-vpn
Use peer next-hop-invariable to configure the device to not change the next hop of routes advertised to peers.
Use undo peer next-hop-invariable to configure the device to use its address as the next hop of routes advertised to peers.
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-invariable
The device uses its address as the next hop of routes advertised to peers.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters.
ipv4-address: Specifies a peer by its IP address.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet in this command, the device does not change the next hop of routes advertised to the dynamic peers in the subnet.
On an RR in an inter-AS option C scenario, you must configure next-hop-invariable to not change the next hop of VPNv4 routes advertised to BGP peers and RR clients.
This command is exclusive with the peer next-hop-local command.
# Configure the device to not change the next hop of routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 next-hop-invariable
peer next-hop-local (Layer 3—IP Routing Command Reference)
peer reflect-route
Use peer reflect-route to allow an RR to send routes received from a peer or peer group to the RR clients.
Use undo peer reflect-route to disable an RR from sending routes received from a peer or peer group to the RR clients.
peer { group-name | ipv4-address [ mask-length ] } reflect-route
undo peer { group-name | ipv4-address [ mask-length ] } reflect-route
An RR can send received routes to its clients.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must have been created.
ipv4-address: Specifies a peer by its IP address. The peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ipv4-address and mask-length arguments together to specify a subnet. If you specify a subnet, you specify all dynamic peers in the subnet.
# In BGP VPNv4 address family view, disable the RR from sending routes received from peer 1.2.3.4 to the RR clients.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] undo peer 1.2.3.4 reflect-route
peer upe
Use peer upe to configure BGP peers as HoVPN UPEs.
Use undo peer upe to delete HoVPN UPEs.
peer { group-name | ip-address [ mask-length ] } upe
undo peer { group-name | ip-address [ mask-length ] } upe
No BGP peer is configured as a UPE.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must exist.
ip-address: Specifies a peer by its IP address. The specified peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command configures all dynamic peers in the subnet as UPEs.
A UPE is a special VPNv4 peer. It can accept one default route for each related VPN instance and routes permitted by the routing policy on the SPE. An SPE is a common VPN peer.
# Configure peer 1.1.1.1 as a UPE.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 upe
Use peer upe route-policy to advertise routes permitted by a routing policy to UPEs.
Use undo peer upe route-policy to remove the configuration.
peer { group-name | ip-address [ mask-length ] } upe route-policy route-policy-name export
undo peer { group-name | ip-address [ mask-length ] } upe route-policy export
No routes are advertised to any peers.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ip-address: Specifies a peer by its IP address. The peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command advertises routes permitted by a routing policy to all dynamic peers in the subnet.
export: Applies the filtering policy to routes to be advertised.
This command must be used with the peer upe command.
# Configure peer 1.1.1.1 as a UPE, and advertise routes permitted by routing policy hope to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1.1.1.1 as-number 200
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 enable
[Sysname-bgp-default-vpnv4] peer 1.1.1.1 upe route-policy hope export
peer upe
policy vpn-target
Use policy vpn-target to enable route target filtering of received VPNv4 routes. Only VPNv4 routes whose export route target attribute matches local import route target attribute are added to the routing table.
Use undo policy vpn-target to disable route target filtering, permitting all incoming VPNv4 routes.
policy vpn-target
The route target filtering feature is enabled for received VPNv4 routes.
In an inter-AS option B scenario, an ASBR must save all incoming VPNv4 routes and advertise those routes to the peer ASBR. For this purpose, you must execute the undo policy vpn-target command on the ASBR to disable route target filtering.
# Disable route target filtering of received VPNv4 routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] undo policy vpn-target
Use route-distinguisher to configure a route distinguisher (RD) for a VPN instance.
Use undo route-distinguisher to restore the default.
No RD is configured for a VPN instance.
VPN instance view
route-distinguisher: Specifies an RD for the VPN instance, a string of 3 to 21 characters in one of the following formats:
RDs enable VPNs to use the same address space. An RD and an IPv4 prefix form a unique VPN-IPv4 prefix.
To guarantee global uniqueness for a VPN-IPv4 address, do not set the AS number or IP address in an RD to any private AS number or private IP address.
To modify an RD, execute the undo route-distinguisher command to remove the RD and then execute the route-distinguisher command.
# Configure RD 22:1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] route-distinguisher 22:1
route-replicate
Use route-replicate to enable a VPN instance to replicate routes from the public network or other VPN instances.
Use undo route-replicate to cancel the configuration.
route-replicate from { public | vpn-instance vpn-instance-name } protocol bgp as-number [ route-policy route-policy-name ]
route-replicate from { public | vpn-instance vpn-instance-name } protocol eigrp eigrp-as [ advertise ] [ route-policy route-policy-name ]
route-replicate from { public | vpn-instance vpn-instance-name } protocol { direct | static | { isis | ospf | rip } process-id } [ advertise ] [ route-policy route-policy-name ]
undo route-replicate from { public | vpn-instance vpn-instance-name } protocol { direct | eigrp eigrp-as | static | bgp as-number | { isis | ospf | rip } process-id }
A VPN instance cannot replicate routes of the public network or other VPN instances.
public: Replicates routes from the public network.
vpn-instance vpn-instance-name: Replicates routes from a VPN instance. The vpn-instance-name argument specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters.
protocol: Replicates routes of the specified routing protocol.
bgp: Replicates BGP routes.
as-number: Specifies an AS number in the range of 1 to 4294967295.
direct: Replicates direct routes.
eigrp: Replicates EIGRP routes.
static: Replicates static routes.
isis: Replicates IS-IS routes.
ospf: Replicates OSPF routes.
rip: Replicates RIP routes.
eigrp-as: Specifies an EIGRP process by its ID, in the range of 1 to 65535.
process-id: Specifies a process by its ID, in the range of 1 to 65535.
advertise: Allows the VPN instance to advertise replicated routes. If you do not specify this keyword, the VPN instance cannot advertise replicated routes.
route-policy route-policy-name: Applies a routing policy to replicated routes. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
In a BGP/MPLS L3VPN network, only VPN instances that have matching route targets can communicate with each other.
This command allows a VPN instance to communicate with the public network or other VPN instances by replicating routing information of the public network or other VPN instances.
In an intelligent traffic control network, traffic of different tenants is assigned to different VPNs. To enable the tenants to communicate with the public network, configure this command to replicate routes from the public network to the VPN instances.
# Replicates OSPF routes from the public network to VPN instance vpn1.
[Sysname]ip vpn-instance vpn1
[Sysname-vpn-ipv4-vpn1] route-replicate from public protocol ospf 1
Use route-tag to configure an external route tag for redistributed VPN routes.
Use undo route-tag to restore the default.
route-tag tag-value
undo route-tag
If BGP runs within an MPLS backbone, and the BGP AS number is not greater than 65535, the first two octets of the external route tag are 0xD000, and the last two octets are the local BGP AS number. For example, if the local BGP AS number is 100, the external route tag value is 3489661028 (100 + the decimal value of 0xD0000000). If the AS number is greater than 65535, the external route tag is 0.
OSPF view
tag-value: Specifies the external route tag for redistributed VPN routes, in the range of 0 to 4294967295.
In a dual-homed scenario where OSPF runs between the CE and the connected PEs (PE-A and PE-B, for example), you can use external route tags to avoid routing loops.
PE-A redistributes BGP routes from the peer PE into OSPF, and advertises these routes in the Type 5 or 7 LSAs to the CE. In these LSAs, PE-A adds the local external route tag.
When PE-B receives the Type 5 or 7 LSAs advertised by the CE, it compares the external route tag in the LSAs with the local external route tag. If the two tags have the same value (including the value of 0), PE-B ignores the LSA in route calculation to avoid routing loops.
The commands used to configure the external route tag (in the descending order of tag priority) are as follows:
·     import-route
·     route-tag (for PEs) and default tag (for CEs and MCEs)
As a best practice, configure the same external route tag for PEs in the same area.
An external route tag is not transferred in any BGP extended community attribute. It takes effect only on the PEs that receive BGP routes and generate OSPF Type 5 or 7 LSAs.
You can configure the same external route tag for different OSPF processes.
# In OSPF process 100, set the external route tag to 100 for redistributed VPN routes.
[Sysname] ospf 100
[Sysname-ospf-100] route-tag 100
default (Layer 3—IP Routing Command Reference)
import-route (Layer 3—IP Routing Command Reference)
routing-table limit
Use routing-table limit to set the maximum number of active routes in a VPN instance.
Use undo routing-table limit to restore the default.
The number of active routes in a VPN instance is not limited.
VPN instance view
number: Specifies the maximum number of active routes.
The following compatibility matrix shows the value ranges for the number argument:
Hardware
Value range
1 to 51024
MSR 2630
1 to 51024
1 to 51024
1 to 51024
1 to 51024
1 to 101024
1 to 101024
1 to 101024
1 to 101024
warn-threshold: Specifies a warning threshold in the range of 1 to 100 in percentage. When the percentage of the existing active routes to the maximum active routes exceeds the threshold, the system gives a log message but still allows new active routes. If active routes in the VPN instance reach the maximum, no more active routes are added.
simply-alert: Specifies that when active routes exceed the maximum number, the system still accepts active routes but generates a log message.
Setting the maximum number of active routes for a VPN instance can prevent a PE from learning too many routes.
A limit configured in VPN instance view applies to both the IPv4 VPN and the IPv6 VPN. A limit configured in VPN instance IPv4 VPN view applies only to the IPv4 VPN. A limit configured in VPN instance IPv6 VPN view applies only to the IPv6 VPN.
IPv4 VPN prefers the limit configured in VPN instance IPv4 VPN view over the limit configured in VPN instance view.
IPv6 VPN prefers the limit configured in VPN instance IPv6 VPN view over the limit configured in VPN instance view.
# Specify that VPN instance vpn1 supports a maximum of 1000 active routes. When active routes exceed this limit, the device can receive new active routes but generates a log message.
[Sysname-vpn-instance-vpn1] routing-table limit 1000 simply-alert
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
undo rr-filter
An RR does not filter reflected routes.
ext-comm-list-number: Specifies an extended community list number in the range of 1 to 65535.
After this command is executed, only the VPNv4 routes that are permitted by the specified extended community list are reflected.
By configuring different RR reflection policies on RRs in a cluster, you can implement load balancing among the RRs.
For more information about extended community lists, see Layer 3—IP Routing Configuration Guide.
# Configure the RR to reflect only VPNv4 routes that are permitted by extended community list 10.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv4] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
Use sham-link to create an OSPF sham link.
Use undo sham-link to remove an OSPF sham link or restore the defaults of specified parameters for an OSPF sham link.
sham-link source-ip-address destination-ip-address [ cost cost-value | dead dead-interval | hello hello-interval | { { hmac-md5 | md5 } key-id { cipher | plain } string | keychain keychain-name | simple { cipher | plain } string } | retransmit retrans-interval | trans-delay delay | ttl-security hops hop-count ] *
undo sham-link source-ip-address destination-ip-address [ cost | dead | hello | { { hmac-md5 | md5 } key-id | keychain | simple } | retransmit | trans-delay | ttl-security ] *
No OSPF sham links exist.
OSPF area view
source-ip-address: Specifies the source IP address of the sham link.
destination-ip-address: Specifies the destination IP address of the sham link.
cost cost-value: Specifies the cost of the sham link, in the range of 1 to 65535. The default cost is 1.
dead dead-interval: Specifies the dead interval in the range of 1 to 32768 seconds. The default is 40 seconds. The dead interval configured on the two ends of the sham link must be identical, and it must be at least four times the hello interval.
hello hello-interval: Specifies the interval for sending hello packets, in the range of 1 to 8192 seconds. The default is 10 seconds. The hello interval configured on the two ends of the sham link must be identical.
hmac-md5: Enables HMAC-MD5 authentication.
md5: Enables MD5 authentication.
simple: Enables simple authentication.
key-id: Specifies a key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. This argument is case sensitive.
·     In simple authentication mode, the plaintext form of the key is a string of 1 to 8 characters. The encrypted form of the key is a string of 33 to 41 characters.
·     In MD5/HMAC-MD5 authentication mode, the plaintext form of the key is a string of 1 to 16 characters. The encrypted form of the key is a string of 33 to 53 characters.
keychain: Enables keychain authentication.
keychain-name: Specifies a keychain by its name. A keychain name is a case-sensitive string of 1 to 63 characters.
retransmit retrans-interval: Specifies the interval for retransmitting LSAs, in the range of 1 to 3600 seconds. The default is 5 seconds.
trans-delay delay: Specifies the delay interval before the interface sends an LSA, in the range of 1 to 3600 seconds. The default is 1 second.
ttl-security hops hop-count: Enables OSPF GTSM and specifies the maximum number of hops to the sham link neighbor. The value range for the hop-count argument is 1 to 254. The default value is 255. By default, OSPF GTSM is disabled.
When a backdoor link exists between the two sites of a VPN, traffic is forwarded through the backdoor link. To forward VPN traffic over the backbone, you can create a sham link between PEs. A sham link is considered an OSPF intra-area route.
This command can configure MD5/HMAC-MD5, simple, or keychain authentication for the sham link. If you configure the authentication mode multiple times, the most recent configuration takes effect. For MD5/HMAC-MD5 authentication, you can configure multiple keys by executing this command multiple times, but a key-id can correspond with only one key.
The authentication mode specified for an OSPF sham link has a higher priority than the authentication mode specified for the area where the sham link resides. If no authentication mode is specified for the sham link, the authentication mode specified for the area applies.
To modify the MD5/HMAC-MD5 authentication key of a sham link, perform the following tasks:
1.     Configure a new key for the sham link on the local device. If the neighbor on the sham link has not been configured with the new key, this configuration triggers a key rollover process, during which, OSPF advertises both the new and old keys so the neighbor can pass authentication and the neighbor relationship is maintained.
2.     Configure the same key for the sham link on the neighbor. After the local device receives a packet carrying the new key from the neighbor, it quits the key rollover process.
3.     Execute the undo sham-link command on the local device and the neighbor to remove the old key. This operation can avoid attacks to the sham link that uses the old key and reduce bandwidth consumption by key rollover.
The keychain authentication process for an OSPF sham link and the restrictions are as follows:
·     OSPF performs the following operations before sending a packet:
a.     Obtains a valid send key from the keychain.
b.     Uses the key ID, authentication algorithm, and key string of the send key to authenticate the packet.
If OSPF fails to obtain a valid send key or if the key ID is greater than 255, OSPF does not send the packet.
·     OSPF performs the following operations before accepting a received packet:
c.     Uses the key ID carried in the packet to obtain a valid accept key from the keychain.
d.     Uses the authentication algorithm and key string of the accept key to authenticate the packet.
If OSPF fails to obtain a valid accept key or if the authentication fails, OSPF discards the packet.
·     OSPF supports the MD5 and HMAC-MD5 authentication algorithms for keychain authentication. The ID of keys used for authentication can only be in the range of 0 to 255.
OSPF GTSM protects the device from being attacked by CPU-utilization attacks. When OSPF GTSM is enabled for a sham link, the device compares the TTL value of an OSPF packet received from the sham link against the valid TTL range. If the TTL value is within the valid TTL range, the packet is accepted. If not, the packet is discarded. The valid TTL range is from "255 – the configured hop count + 1" to 255. For packets sent to the sham link, the device sets the packet TTL value to 255.
You cannot configure a sham link with the same source and destination IP address for multiple OSPF processes in a VPN instance.
For an OSPF neighbor relationship to be successfully established, the sham links configured on the local and remote PEs must be in the same OSPF area.
To use GTSM, you must configure GTSM on both the local and peer devices. You can specify different hop-count values on the devices.
# Create a sham link with the source address 1.1.1.1 and destination address 2.2.2.2.
[Sysname] ospf
[Sysname-ospf-1] area 0
[Sysname-ospf-1-area-0.0.0.0] sham-link 1.1.1.1 2.2.2.2
snmp context-name
Use snmp context-name to configure an SNMP context for a VPN instance.
Use undo snmp context-name to restore the default.
No SNMP context is configured for a VPN instance.
VPN instance view
context-name: Specifies an SNMP context, a case-sensitive string of 1 to 32 characters.
VPN-aware features such as AAA and NAT do not know the VPN instance to which a managed MIB node belongs. To resolve this issue, configure different SNMP contexts for different VPN instances.
The device selects a MIB for an SNMP packet according to the context (for SNMPv3) or community name (for SNMPv1/v2c) in the following ways:
·     For an SNMPv3 packet:
¡     The device selects the public MIB if the packet does not carry a context.
¡     The device selects the MIB of a VPN instance if the packet meets the following conditions:
-     Carries a context that was configured with the snmp-agent context command in system view.
-     Matches the context of the VPN instance.
¡     The device does not process any MIBs in other situations.
·     For an SNMPv1/v2c packet:
¡     The device selects the public MIB if no SNMP community to SNMP context mapping was configured with the snmp-agent community-map command in system view.
¡     The device selects the MIB of a VPN instance if the SNMP community is mapped to an SNMP context and the context matches the context of the VPN instance.
For more information about SNMP context and community name, see Network Management and Monitoring Configuration Guide.
Do not configure the same SNMP context for different VPN instances.
# Configure SNMP context vpna for VPN instance vpna.
[Sysname] snmp-agent context vpna
[Sysname-vpn-instance-vpna] route-distinguisher 22:33
[Sysname-vpn-instance-vpna] snmp context-name vpna
snmp-agent community-map (Network Management and Monitoring Command Reference)
snmp-agent context (Network Management and Monitoring Command Reference)
Use snmp-agent trap enable l3vpn to enable SNMP notifications for MPLS L3VPN.
Use undo snmp-agent trap enable l3vpn to disable SNMP notifications for MPLS L3VPN.
SNMP notifications for MPLS L3VPN are enabled.
To report critical MPLS L3VPN events to an NMS, enable SNMP notifications for MPLS L3VPN. For MPLS L3VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for MPLS L3VPN.
[Sysname] snmp-agent trap enable l3vpn
tnl-policy
Use tnl-policy to associate a VPN instance with a tunnel policy.
Use undo tnl-policy to restore the default.
tnl-policy tunnel-policy-name
undo tnl-policy
No tunnel policy is associated with a VPN instance.
VPN instance view
tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters.
The VPN instance uses the specified tunnel policy to select tunnels for traffic.
If a VPN instance is not associated with any tunnel policies or the associated tunnel policy is not configured, the VPN instance selects tunnels according to the default tunnel policy. The default tunnel policy selects only one tunnel in this order: LSP tunnel, GRE tunnel, CRLSP tunnel, and SRLSP tunnel.
A tunnel policy specified in VPN instance view applies to both the IPv4 VPN and the IPv6 VPN. A tunnel policy specified in VPN instance IPv4 VPN view applies only to the IPv4 VPN. A tunnel policy specified in VPN instance IPv6 VPN view applies only to the IPv6 VPN.
IPv4 VPN prefers the tunnel policy specified in VPN instance IPv4 VPN view over the tunnel policy specified in VPN instance view.
IPv6 VPN prefers the tunnel policy specified in VPN instance IPv6 VPN view over the tunnel policy specified in VPN instance view.
# Associate VPN instance vpn1 with tunnel policy po1.
[Sysname] tunnel-policy po1
[Sysname-tunnel-policy-po1] select-seq lsp load-balance-number 1
[Sysname-tunnel-policy-po1] quit
[Sysname-vpn-instance-vpn1] route-distinguisher 22:33
[Sysname-vpn-instance-vpn1] tnl-policy po1
tunnel-policy
vpn popgo
Use vpn popgo to specify the VPN label processing mode as POPGO forwarding on an egress PE. In POPGO forwarding mode, the egress PE pops the label for each packet and forwards the packet out of the interface corresponding to the label.
Use undo vpn popgo to restore the default.
vpn popgo
undo vpn popgo
The VPN label processing mode is POP forwarding on an egress PE, which will pop the label for each packet and forward the packet through the FIB table.
BGP instance view
After you execute the vpn popgo command, the egress PE disconnects and re-establishes BGP sessions to re-learn VPN routes, and it does not support load sharing among VPN BGP peers.
The vpn popgo and label-allocation-mode per-vrf commands are mutually exclusive. Do not configure both commands in a BGP instance.
# Specify the VPN label processing mode on the egress PE as POPGO forwarding.
[Sysname] bgp 100
[Sysname-bgp-default] vpn popgo
label-allocation-mode (Layer 3—IP Routing Command Reference)
vpn-id
Use vpn-id to configure a VPN ID for a VPN instance.
Use undo vpn-id to restore the default.
vpn-id vpn-id
undo vpn-id
No VPN ID is configured for a VPN instance.
VPN instance view
vpn-id: Specifies a VPN ID for the VPN instance, in the form of OUI:Index. The OUI is a hexadecimal number in the range of 0 to FFFFFF, and the index is a hexadecimal number in the range of 0 to FFFFFFFF.
A VPN ID uniquely identifies a VPN instance. Different VPN instances must have different VPN IDs.
A VPN ID cannot be 0:0.
# Configure VPN ID 20:1 for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] vpn-id 20:1
Use vpn-route cross multipath to enable ECMP VPN route redistribution.
Use undo vpn-route cross multipath to disable ECMP VPN route redistribution.
ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, a VPN redistributes only the optimal route to its routing table.
BGP IPv4 unicast address family view
BGP IPv6 unicast address family view
BGP-VPN IPv4 unicast address family view
BGP-VPN IPv6 unicast address family view
This feature enables a VPN instance to redistribute multiple routes that have the same prefix and RD into its routing table. Then, you can configure load sharing among the ECMP routes or MPLS L3VPN FRR.
# In BGP-VPN IPv4 unicast address family view, enable ECMP route redistribution.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] vpn-route cross multipath
vpn-target
Use vpn-target to configure route targets for a VPN instance.
Use undo vpn-target to remove the specified or all route targets of a VPN instance.
No route targets are configured for a VPN instance.
VPN instance view
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets.
A route target is a string of 3 to 21 characters in one of the following formats:
·     32-bit AS number:16-bit user-defined number, where the AS number must not be less than 65536. For example, 65536:1.
both: Uses the specified route targets as both import targets and export targets. The both keyword is also used when you do not specify any of the following keywords: both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
MPLS L3VPN uses route targets to control the advertisement of VPN routing information. A PE adds the configured export targets into the route target attribute of routes advertised to a peer. The peer uses the local import targets to match the route targets of received routes. If a match is found, the peer adds the routes to the routing table of the VPN instance.
If you repeat this command, all the configured route targets take effect.
Route targets configured in VPN instance view applies to both the IPv4 VPN and the IPv6 VPN. Route targets configured in VPN instance IPv4 VPN view apply only to the IPv4 VPN. Route targets configured in VPN instance IPv6 VPN view apply only to the IPv6 VPN.
IPv4 VPN prefers the route targets configured in VPN instance IPv4 VPN view over those configured in VPN instance view.
IPv6 VPN prefers the route targets configured in VPN instance IPv6 VPN view over those configured in VPN instance view.
# Configure route targets for VPN instance vpn1.
[Sysname-vpn-instance-vpn1] vpn-target 3:3 export-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 4:4 import-extcommunity
[Sysname-vpn-instance-vpn1] vpn-target 5:5 both
IPv6 MPLS L3VPN commands
This chapter describes only IPv6 MPLS L3VPN-specific commands. For information about the commands available for both IPv4 MPLS L3VPN and IPv6 MPLS L3VPN, see "MPLS L3VPN commands."
The following compatibility matrix shows the support of hardware platforms for IPv6 MPLS L3VPN:
Hardware
IPv6 MPLS L3VPN compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA
No
MSR810-LMS, MSR810-LUS
No
MSR2600-6-X1, MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
Yes
Yes
MSR3610-I-DP, MSR3610-IE-DP
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
address-family ipv6 (VPN instance view)
Use address-family ipv6 to enter VPN instance IPv6 VPN view.
Use undo address-family ipv6 to remove all configurations from VPN instance IPv6 VPN view.
address-family ipv6
VPN instance view
In VPN instance IPv6 VPN view, you can configure IPv6 VPN parameters such as inbound and outbound routing policies.
# Enter VPN instance IPv6 VPN view.
[Sysname-vpn-instance-vpn1] address-family ipv6
[Sysname-vpn-ipv6-vpn1]
address-family ipv4 (VPN instance view)
address-family vpnv6
Use address-family vpnv6 to create the BGP VPNv6 address family and enter its view, or enter the view of the existing BGP VPNv6 address family.
Use undo address-family vpnv6 to remove the BGP VPNv6 address family and all configurations in address family view.
The BGP VPNv6 address family is not created.
BGP instance view
A VPNv6 address consists of an RD and an IPv6 prefix. In IPv6 MPLS L3VPNs, PEs exchange BGP VPNv6 routes.
For a PE to exchange BGP VPNv6 routes with a BGP peer, you must enable that peer by executing the peer enable command in BGP VPNv6 address family view.
In BGP VPNv6 address family view, you can configure the following settings:
·     BGP VPNv6 route attributes, such as the preferred value.
# Create the BGP VPNv6 address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family vpnv6
[Sysname-bgp-default-vpnv6]
disable-dn-bit-check
Use disable-dn-bit-check to ignore the DN bit in OSPFv3 LSAs.
Use undo disable-dn-bit-check to restore the default.
A PE checks the DN bit in OSPFv3 LSAs.
OSPFv3 view
When a PE redistributes BGP routes into OSPFv3 and creates OSPFv3 LSAs, it sets the DN bit for the LSAs. When receiving the LSAs whose DN bit is set, the other PEs ignore the LSAs in route calculation to avoid routing loops.
If all LSAs from other PEs, including the LSAs whose DN bit is set, are required for route calculation, use the disable-dn-bit-check command to ignore the DN bit.
Before using this command, make sure it does not cause any routing loops.
This command takes effect only for a VPN OSPFv3 process that is not configured with the vpn-instance-capability simple command.
# Ignore the DN bit in LSAs for VPN OSPFv3 process 100.
[Sysname] ospfv3 100 vpn-instance vpn1
[Sysname-ospfv3-100] disable-dn-bit-check
disable-dn-bit-set
display ospfv3 (Layer 3—IP Routing Command Reference)
disable-dn-bit-set
Use disable-dn-bit-set to disable setting the DN bit in OSPFv3 LSAs.
Use undo disable-dn-bit-set to restore the default.
disable-dn-bit-set
OSPFv3 view
If other PEs require all LSAs from a local PE for route calculation, use the disable-dn-bit-set command to disable setting the DN bit in the LSAs.
# Disable setting the DN bit in LSAs for VPN OSPFv3 process 100.
[Sysname-ospfv3-100] disable-dn-bit-set
display bgp routing-table vpnv6
Use display bgp routing-table vpnv6 to display BGP VPNv6 routing information.
display bgp [ instance instance-name ] routing-table vpnv6 [ [ route-distinguisher route-distinguisher ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } ] | peer ipv4-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays BGP VPNv6 routes in the default BGP instance.
ipv6-address prefix-length: Displays detailed information about the BGP VPNv6 route that exactly matches the specified network address and prefix length. The prefix length is in the range of 0 to 128. If you do not specify this argument, the command displays brief information about all BGP VPNv6 routes.
advertise-info: Displays BGP VPNv6 route advertisement information.
as-path-acl as-path-acl-number: Displays BGP VPNv6 routes that match the AS path list specified by its number in the range of 1 to 256.
community-list: Displays BGP VPNv6 routes that match a BGP community list.
whole-match: Displays BGP VPNv6 routes exactly matching the specified community list. If you do not specify this keyword, the command displays BGP VPNv6 routes whose COMMUNITY attributes include the specified community list.
peer: Displays BGP VPNv6 routing information advertised to or received from a peer.
ipv4-address: Specifies the peer IP address.
advertised-routes: Displays BGP VPNv6 routing information advertised to the specified peer.
received-routes: Displays BGP VPNv6 routing information received from the specified peer.
statistics: Displays BGP VPNv6 routing statistics.
If you do not specify any parameters, this command displays brief information about all BGP VPNv6 routes.
# Display brief information about all BGP VPNv6 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv6
 Total number of routes from all PEs: 1
 Total number of routes: 4
* >  Network : 2001:1::                                 PrefixLen : 96
     NextHop : ::                                       LocPrf    :
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: ?
*  e Network : 2001:1::                                 PrefixLen : 96
     NextHop : 2001:1::1                                LocPrf    :
     MED     : 0
     Path/Ogn: 65410?
* >  Network : 2001:1::2                                PrefixLen : 128
     NextHop : ::1                                      LocPrf    :
     MED     : 0
     Path/Ogn: ?
* >i Network : 2001:3::                                 PrefixLen : 96
     NextHop : ::FFFF:3.3.3.9                           LocPrf    : 100
     PrefVal : 0                                        OutLabel  : 1279
     MED     : 0
     Path/Ogn: ?
 Total number of routes: 1
     MED     : 0
     Path/Ogn: ?
# Display information about BGP VPNv6 routes matching AS_PATH list 1 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 as-path-acl 1
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: 65410?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
# Display information about BGP VPNv6 routes matching BGP community list 100 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 community-list 100
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: 65410?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
# Display information about public BGP VPNv6 routes advertised to 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 advertised-routes
     MED     : 0                                        OutLabel  : NULL
     Path/Ogn: ?
# Display information about public BGP VPNv6 routes received from 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 received-routes
     MED     : 0
     Path/Ogn: ?
Table 13 Command output
BGP local router ID
Router ID of the local BGP router.
Status codes
Route status codes:
·     * - valid—Valid route.
·     > - best—Common optimal route.
·     d – damped—Route damped for route flap.
·     h - history—History route.
·     i - internal—Internal route.
·     e - external—External route.
·     s - suppressed—Suppressed route.
·     S - Stale—Stale route.
Origin
Route origin:
·     i - IGP—Originated in the AS. The origin of routes advertised by the network command is IGP.
·     e - EGP—Learned through EGP.
·     ? - incomplete—Redistributed from IGP protocols.
Total number of VPNv6 routes from all PEs.
Network
Network address.
PrefixLen
Prefix length.
NextHop
Address of the next hop.
LocPrf
PrefVal
Preferred value.
MED
Path/Ogn
# Display detailed information about BGP VPNv6 routes to 2::/64 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 2:: 64
 Local AS number: 200
 Paths:   2 available, 1 best
 BGP routing table information of 2::/64:
 Rely nexthop    : ::FFFF:10.1.1.1
 Original nexthop: ::FFFF:10.1.1.1
 OutLabel        : NULL
 AS-path         : 100
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
 Backup route.
 Rely nexthop    : 1::1
 Original nexthop: 1::1
 OutLabel        : NULL
 AS-path         : 100
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 DSCP            : N/A
Table 14 Command output
BGP local router ID
Paths
Number of routes:
·     available—Available routes.
·     best—Optimal routes.
Routing information for the BGP routes to 2::/64.
From
IP address of the BGP peer that advertises the route.
Rely Nexthop
Original nexthop
Origin
Route origin:
Attribute value
Route status:
IP precedence
QoS local ID
Traffic index
VPN-Peer UserID
DSCP
# Display advertisement information for BGP VPNv6 routes to 2001:1::/96 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 2001:1:: 96 advertise-info
 Paths:   1 best
 BGP routing table information of 2001:1::/96:
    3.3.3.9
 Inlabel         : 1279
Table 15 Command output
Paths
Advertisement information for the BGP route to 2001:1::/96.
VPNv6 peers to which the route is advertised, and the number of peers.
Inlabel
# Display statistics about public BGP VPNv6 routes advertised to peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 advertised-routes statistics
# Display statistics about public BGP VPNv6 routes received from peer 3.3.3.9 in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 peer 3.3.3.9 received-routes statistic
Table 16 Command output
# Display statistics about public BGP VPNv6 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 statistics
Table 17 Command output
Total number of VPNv6 routes with the specified RD.
display bgp routing-table vpnv6 inlabel
Use display bgp routing-table vpnv6 inlabel to display incoming labels for all BGP VPNv6 routes.
display bgp [ instance instance-name ] routing-table vpnv6 inlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays incoming labels for all BGP VPNv6 routes in the default BGP instance.
# Display incoming labels for all BGP VPNv6 routes.
<Sysname> display bgp routing-table vpnv6 inlabel
 BGP local router ID is 1.1.1.9
 Route distinguisher: 100:1
     NextHop : ::                                       OutLabel  : NULL
     InLabel : 1279
Table 18 Command output
BGP local router ID
Status codes
Route status codes:
Origin
Route origin:
OutLabel
InLabel
Incoming label.
display bgp routing-table vpnv6 outlabel
Use display bgp routing-table vpnv6 outlabel to display outgoing labels for BGP VPNv6 routes.
display bgp [ instance instance-name ] routing-table vpnv6 outlabel
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays outgoing labels for all BGP VPNv6 routes in the default BGP instance.
# Display outgoing labels for all BGP VPNv6 routes in the default BGP instance.
<Sysname> display bgp routing-table vpnv6 outlabel
 Route distinguisher: 100:1(vpn1)
     NextHop : ::FFFF:3.3.3.9                           OutLabel  : 1279
 Route distinguisher: 200:1
Table 19 Command output
BGP local router ID
Status
Route status codes:
Origin
Route origin:
OutLabel
display ospfv3 sham-link
Use display ospfv3 sham-link to display OSPFv3 sham link information.
display ospfv3 [ process-id ] [ area area-id ] sham-link [ verbose ]
process-id: Specifies an OSPFv3 process by its ID. The process ID is in the range of 1 to 65535. If you do not specify a process, this command displays sham link information for all OSPFv3 processes.
area area-id: Specifies an OSPFv3 area by its ID, which is an IP address, or an integer. The integer is in the range of 0 to 4294967295. If you do not specify an area, this command displays sham link information for all OSPFv3 areas.
verbose: Displays detailed sham link information. If you do not specify this keyword, the command displays brief sham link information.
# Display brief information about all OSPFv3 sham links.
<Sysname> display ospfv3 sham-link
               OSPFv3 Process 1 with Router ID 125.0.0.1
 Sham-link (Area: 0.0.0.1)
 Neighbor ID      State  Instance ID  Destination address
 0.0.0.0          Down   1            1:1::58
 95.0.0.1         P-2-P  1            1:1::95
# Display detailed information about all OSPFv3 sham links.
<Sysname> display ospfv3 sham-link verbose
 Source      : 1:1::125
 Destination : 1:1::58
 Interface ID: 2147483649
 Neighbor ID : 0.0.0.0, Neighbor state: Down
 Cost: 1  State: Down  Type: Sham  Instance ID: 1
 Timers: Hello 10, Dead 40, Retransmit 5, Transmit delay 1
 Keychain authentication: Enabled (test), inherited
 Source      : 1:1::125
 Destination : 1:1::95
 Interface ID: 2147483650
 Neighbor ID : 95.0.0.1, Neighbor state: Full
 Cost: 1  State: P-2-P  Type: Sham  Instance ID: 1
Table 20 Command output
Neighbor state
Neighbor state for the sham link: Down, Init, 2-Way, ExStart, Exchange, Loading, or Full.
Request list
Number of LSAs in the request list.
Retransmit list
Number of LSAs in the retransmit list.
IPsec profile name
Name of the IPsec profile used by the sham link.
Keychain authentication is enabled for the sham link, and keychain test is used. The inherited attribute indicates that the sham link uses the authentication mode specified for the area where the sham link resides.
domain-id (OSPFv3 view)
Use domain-id to set an OSPFv3 domain ID.
Use undo domain-id to delete an OSPFv3 domain ID.
domain-id { domain-id [ secondary ] | null }
undo domain-id [ domain-id | null ]
The OSPFv3 domain ID is 0.
OSPFv3 view
domain-id: Specifies an OSPFv3 domain ID, in one of the following formats:
null: Carries no domain ID in the community attribute.
When you redistribute OSPFv3 routes into BGP, BGP adds the primary domain ID to the redistributed BGP VPNv6 routes as a BGP extended community attribute. Then, BGP advertises the routes to the peer PE.
When the peer PE receives the routes, it compares the OSPFv3 domain ID in the routes with the locally configured primary and secondary domain IDs. OSPFv3 advertises these routes in Inter-Area-Prefix LSAs (Type 3 LSAs) if both the following conditions exist:
Otherwise, OSPFv3 advertises these routes in AS External LSAs (Type 5 LSAs) or NSSA External LSAs (Type 7 LSAs).
A null domain ID and a domain ID of 0 are considered the same in domain ID comparison.
You cannot configure a secondary domain ID when the primary domain ID is configured as 0.
# Set the primary domain ID for VPN OSPFv3 process 100 to 1.1.1.1.
[Sysname-ospfv3-100] domain-id 1.1.1.1
ext-community-type (OSPFv3 view)
Use ext-community-type to configure the type code of an OSPFv3 extended community attribute.
ext-community-type { domain-id type-code1 | route-type type-code2 | router-id type-code3 }
undo ext-community-type [ domain-id | route-type | router-id ]
The type codes for domain ID, route type, and router ID are hex numbers 0005, 0306, and 0107, respectively.
OSPFv3 view
route-type type-code2: Specifies the type code for route type. Valid values are hex numbers 0306 and 8000.
router-id type-code3: Specifies the type code for router ID. Valid values are hex numbers 0107 and 8001.
# Configure the type codes of domain ID, route type, and router ID as hex numbers 8005, 8000, and 8001, respectively, for VPN OSPFv3 process 100.
[Sysname-ospfv3-100] ext-community-type domain-id 8005
[Sysname-ospfv3-100] ext-community-type route-type 8000
[Sysname-ospfv3-100] ext-community-type router-id 8001
peer next-hop-invariable (BGP VPNv6 address family view)
peer { group-name | ip-address [ mask-length ] } next-hop-invariable
undo peer { group-name | ip-address [ mask-length ] } next-hop-invariable
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a network. If you specify a network in this command, the device does not change the next hop of routes advertised to the dynamic peers in the network.
On an RR in an inter-AS option C scenario, you must configure this command to not change the next hop of VPNv6 routes advertised to BGP peers and RR clients.
# In BGP VPNv6 address family view, configure the device to not change the next hop of routes advertised to peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv6] peer 1.1.1.1 next-hop-invariable
policy vpn-target
Use policy vpn-target to enable route target filtering of received VPNv6 routes. Only VPNv6 routes whose export route target attribute matches local import route target attribute are added to the routing table.
Use undo policy vpn-target to disable route target filtering, permitting all incoming VPNv6 routes.
policy vpn-target
The route target filtering feature is enabled for received VPNv6 routes.
# Disable route target filtering of received VPNv6 routes.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv6] undo policy vpn-target
route-tag (OSPFv3 view)
route-tag tag-value
undo route-tag
OSPFv3 view
In a dual-homed scenario where OSPFv3 runs between the CE and the connected PEs (PE-A and PE-B, for example), you can use external route tags to avoid routing loops.
PE-A redistributes BGP VPNv6 routes from the peer PE into OSPFv3, and advertises these routes in the Type 5 or 7 LSAs to the CE. In these LSAs, PE-A adds the locally configured external route tag.
If the route-tag-check enable command is configured on the PE-B, it compares the external route tag in the receiving Type 5 or 7 LSAs with the locally configured tag. If they are the same, PE-B ignores the LSA in route calculation to avoid routing loops.
·     import-route
An external route tag is not transferred in any BGP extended community attribute. It takes effect only on PEs that receive BGP routes and generate OSPF Type 5 or 7 LSAs.
# Set the external route tag for redistributed VPN routes to 100 for VPN OSPFv3 process 100.
[Sysname-ospfv3-100] route-tag 100
default tag (Layer 3—IP Routing Command Reference)
Use route-tag-check enable to enable external route check for OSPFv3 LSAs.
Use undo route-tag-check enable to disable external route check for OSPFv3 LSAs.
The external route check feature is disabled for OSPFv3 LSAs.
OSPFv3 view
If external route check for OSPFv3 LSAs is enabled on PE-B, it compares the external route tag in the receiving Type 5 or 7 LSAs with the locally configured tag. If they are the same, PE-B ignores the LSA in route calculation to avoid routing loops.
Use the external route tag check feature only when the device does not support the DN bit. Otherwise, use the DN bit to avoid routing loops.
# Enable external route check in OSPFv3 LSAs for VPN OSPFv3 process 100.
[Sysname-ospfv3-100] route-tag-check enable
route-tag
rr-filter (BGP VPNv6 address family view)
Use rr-filter to create an RR reflection policy.
undo rr-filter
After this command is executed, only the VPNv6 routes that are permitted by the specified extended community list are reflected.
# Configure the RR to reflect only VPNv6 routes that are permitted by extended community list 10.
[Sysname] bgp 100
[Sysname-bgp-default-vpnv6] rr-filter 10
sham-link (OSPFv3 area view)
Use sham-link to create an OSPFv3 sham link.
Use undo sham-link to remove an OSPFv3 sham link or restore the defaults of specified parameters for an OSPFv3 sham link.
sham-link source-ipv6-address destination-ipv6-address [ cost cost-value | dead dead-interval | hello hello-interval | instance instance-id | ipsec-profile profile-name | keychain keychain-name | retransmit retrans-interval | trans-delay delay ] *
undo sham-link source-ipv6-address destination-ipv6-address [ cost | dead | hello | ipsec-profile | keychain | retransmit | trans-delay ] *
No OSPFv3 sham links exist.
OSPFv3 area view
source-ipv6-address: Specifies the source IPv6 address of the sham link.
destination-ipv6-address: Specifies the destination IPv6 address of the sham link.
dead dead-interval: Specifies the dead interval in the range of 1 to 32768 seconds. The default is 40 seconds. The dead interval configured on each end of the sham link must be identical, and it must be at least four times the hello interval.
hello hello-interval: Specifies the interval for sending hello packets, in the range of 1 to 8192 seconds. The default is 10 seconds. The hello interval configured on each end of the sham link must be identical.
instance instance-id: Specifies the instance ID of the sham link, in the range of 0 to 255. The default value is 0.
ipsec-profile profile-name: Specifies the IPsec profile for the sham link. The profile-name argument specifies the profile by its name, a case-insensitive string of 1 to 63 characters.
keychain: Specifies keychain authentication for the sham link.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
When a backdoor link exists between the two sites of a VPN, traffic is forwarded through the backdoor link. To forward VPN traffic over the backbone, you can create a sham link between PEs. A sham link is considered an OSPFv3 intra-area route.
The authentication mode specified for an OSPFv3 sham link has a higher priority than the authentication mode specified for the area where the sham link resides. If no authentication mode is specified for the sham link, the authentication mode specified for the area applies.
When keychain authentication is configured for an OSPFv3 sham link, OSPFv3 performs the following operations before sending a packet:
1.     Obtains a valid send key from the keychain.
OSPFv3 does not send the packet if it fails to obtain a valid send key.
2.     Uses the key ID, authentication algorithm, and key string to authenticate the packet.
If the authentication fails, OSPFv3 does not send the packet.
When keychain authentication is configured for an OSPFv3 sham link, OSPFv3 performs the following operations after receiving a packet:
1.     Uses the key ID carried in the packet to obtain a valid accept key from the keychain.
OSPFv3 discards the packet if it fails to obtain a valid accept key.
2.     Uses the authentication algorithm and key string for the valid accept key to authenticate the packet.
If the authentication fails, OSPFv3 discards the packet.
OSPFv3 supports only the HMAC-SHA-256 authentication algorithm.
The ID of keys used for authentication can only be in the range of 0 to 65535.
# Create a sham link with the source address 1::1 and destination address 2::2.
[Sysname-ospfv3-100] area 0
[Sysname-ospfv3-100-area-0.0.0.0] sham-link 1::1 2::2
