HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release7178-6W10001-Fundamentals Configuration Guide
08-ISSU configuration
08-ISSU configuration 376.54 KB
Performing an ISSU·· 2
Overview· 2
ISSU methods· 2
ISSU commands· 3
Preparing for ISSU· 3
Identifying ISSU availability and licensing requirements· 3
Verifying the device operating status· 4
Preparing the upgrade images· 4
Identifying the ISSU method· 4
Verifying feature status· 4
Determining the upgrade procedure· 5
Understanding ISSU guidelines· 5
Logging in to the device through the console port 5
Adjusting and saving the running configuration· 6
Performing an ISSU by using issu commands· 6
Performing a compatible upgrade· 6
Performing an incompatible upgrade· 7
Performing an ISSU by using install commands· 8
ISSU task list 8
Decompressing an .ipe file· 8
Installing or upgrading software images· 9
Uninstalling feature or patch images· 10
Aborting a software activate/deactivate operation· 11
Committing software changes· 11
Verifying software images· 11
Deleting inactive software images· 12
Displaying and maintaining ISSU· 12
Standalone mode· 12
IRF mode· 13
Troubleshooting ISSU in IRF mode· 14
Failure to execute the issu load/issu run switchover/issu commit/install activate/install deactivate command  14
Examples of using issu commands for ISSU on a dual-member IRF fabric· 14
HTTP feature upgrade to a compatible version· 14
HTTP feature upgrade to an incompatible version· 17
Examples of using issu commands for ISSU on a four-member IRF fabric· 21
Feature upgrade to a compatible version· 21
Feature upgrade to an incompatible version (upgrading one subordinate member first) 26
Feature upgrade to an incompatible version (upgrading multiple subordinate members first) 31
Examples of using issu commands for ISSU on an IRF 3 system·· 36
HTTP feature upgrade to a compatible version· 36
HTTP feature upgrade to an incompatible version· 42
Examples of using install commands for ISSU on a standalone device· 46
HTTP feature upgrade example· 46
Examples of using install commands for ISSU on an IRF fabric· 48
HTTP feature upgrade example· 48
Examples of using install commands for ISSU on an IRF 3 system·· 53
HTTP feature upgrade example· 53
Performing an ISSU
Unless otherwise stated, the term "upgrade" refers to both software upgrade and downgrade in ISSU.
Overview
The In-Service Software Upgrade (ISSU) feature upgrades software with a minimum amount of downtime.
ISSU is implemented on the basis of the following design advantages:
·           Separation of service features from basic functions—Device software is segmented into boot, system, and feature images. The images can be upgraded individually.
·           Independence between service features—Features run independently. One feature can be added or upgraded without affecting the operation of the system or other features.
·           Support for hotfix—Patch images are available to fix system bugs without a system reboot.
·           Hardware redundancy—On a dual-MPU device or a multichassis IRF fabric, one MPU or member device can be upgraded while other MPUs or member devices are providing services.
For more information about images, see "Upgrading software."
ISSU methods
ISSU methods are automatically determined depending on the compatibility between software versions.
ISSU supports the following upgrade types:
·           Compatible upgrade—The running software version is compatible with the new software version. This upgrade type supports the ISSU methods in Table 1.
·           Incompatible upgrade—The running software version is incompatible with the new software version. The two versions cannot run concurrently.
This upgrade type supports only one upgrade method (also called incompatible upgrade). This method requires a cold reboot to upgrade both control and data planes. Incompatible upgrade disrupts service if hardware redundancy is not available.
For information about identifying the ISSU method, see "Identifying the ISSU method."
Table 1 ISSU methods for compatible upgrade
ISSU method
Incremental upgrade:
·           Service Upgrade
·           File Upgrade
Upgrades only user mode processes that have differences between the new and old software versions. Backup processes and a main/backup process switchover are required for service continuity.
·           Service upgrade—Upgrades service features. The upgrade does not affect the operation of the features that are not being upgraded.
·           File upgrade—Upgrades hidden system program files. The system can provide services during the upgrade.
Reboot
CAUTION CAUTION:
The Reboot method disrupts service if hardware redundancy (MPU- or device-level) is not available. As a best practice, schedule the downtime carefully to minimize the upgrade impact on the services.
The Reboot method reboots MPUs to complete the software upgrade. While one MPU is rebooting, the other MPUs can provide services.
ISSU commands
ISSU includes the install and issu command sets. After you identify the ISSU method, use Table 2 to choose the command set you want to use.
Table 2 Command set comparison
Item
issu commands
install commands
Upgrade types
·           Compatible.
·           Incompatible.
Compatible.
Patch install/uninstall
Not supported.
Supported.
Upgrade mode
Chassis by chassis.
MPU by MPU.
Applicable image types and application scenarios
·           Multichassis IRF fabrics.
·           Multiparent IRF 3 systems.
You can upgrade the boot image, system image, and feature images.
·           IRF 3 system where only PEXs need to be upgraded. You can upgrade the boot image, system image, and feature images.
·           Standalone device, IRF fabric, or IRF 3 system where only feature images need to be upgraded.
·           Standalone device, IRF fabric, or IRF 3 system that needs to be patched.
Impact on the system
Large.
Small.
Technical skill requirements
Low.
As a best practice, use this command set.
High.
Administrators must have extensive system knowledge and understand the impact of each upgrade task on the network.
Preparing for ISSU
To perform a successful ISSU, make sure all the preparation requirements are met.
If the IRF 3 fabric has one tier of PEXs and a PEX is connected to only one parent device, ISSU is not supported. To upgrade the parent devices and PEXs, you must use the boot-loader file command. For more information about PEXs, see Virtual Technologies Configuration Guide.
Read the software release notes to identify the following items:
·           Support of the device for ISSU between the current software version and the new software version.
·           Licensing requirements for the upgrade software images.
If the upgrade software images require licenses, make sure the device has the required licenses before ISSU. For more information about license installation, see "Managing licenses."
Verify the following items:
·           Use the display device command to verify that no cards are in Fault state.
·           Use the display mdc command to verify that all MDCs are in active state.
·           Use the switchto mdc command to verify that no automatic configuration process is in progress. If the message Automatic configuration is running, press CTRL_C or CTRL_D to break. appears, an automatic configuration process is in progress. To perform an ISSU, wait for the process to complete, or abort the process. For more information about automatic configuration, see "Using automatic configuration."
1.      Use the dir command to verify that all MPUs have sufficient storage space for the upgrade images. Use the display mdc resource command to verify that all MDCs have sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete /unreserved file-url command. If the files to be deleted will be used, back up the files before deleting them. You will be unable to restore a deleted file if the /unreserved keyword is used. For more information, see "Managing the file system."
2.      Use FTP or TFTP to transfer upgrade image files (in .bin or .ipe) to the root directory of a storage medium on any one of the MPUs.
1.      Execute the display version comp-matrix file command for the upgrade image version compatibility information.
2.      Check the Version compatibility list field.
¡  If the running software version is in the list, a compatible upgrade is required.
¡  If the running software version is not in the list, an incompatible upgrade is required.
3.      Identify the ISSU method.
¡  If a compatible upgrade is required, check the Upgrade Way field to identify the ISSU method. For more information about ISSU methods, see Table 1.
¡  If an incompatible upgrade is required, check the end of command output for the Incompatible upgrade string.
For service continuity during ISSU, configure the following feature settings:
Feature
Setting requirements
GR/NSR
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF.
BFD
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA.
Ethernet link aggregation
Use the long LACP timeout interval (the lacp period short command is not configured) on all member ports in dynamic aggregation groups.
IRF
·           Set the physical state change suppression interval to 0 on Ethernet interfaces so their physical state changes are immediately reported to the CPU.
·           Enable link-aggregation traffic redirection to ensure continuous traffic service.
·           Enable the IRF bridge MAC address to be permanent.
IMPORTANT
IMPORTANT:
To ensure a successful ISSU, strictly follow the recommended ISSU procedure. Make sure a step is completed successfully before you proceed with the next step.
1.      Use Table 2 to choose an upgrade command set, depending on the ISSU method.
2.      Choose the correct procedure from the procedures described in "Performing an ISSU by using issu commands" or "Performing an ISSU by using install commands."
During an ISSU, use the following guidelines:
·           In a multiuser environment, make sure no other administrators access the device while you are performing the ISSU.
·           Do not perform any of the following tasks during an ISSU:
¡  Reboot, add, or remove cards.
¡  Execute commands that are irrelevant to the ISSU.
¡  Modify, delete, or rename image files.
·           You cannot use both install and issu commands for an ISSU. However, you can use display issu commands with both command sets. For more information, see "Displaying and maintaining ISSU."
·           You do not need to upgrade LPUs separately. They are upgraded automatically when MPUs are upgraded.
·           You only need to perform the upgrade on the default MDC. The system completes software upgrade for all the other MDCs automatically.
·           You may use issu commands to upgrade all or some of the software images. If you are upgrading only some of the images, make sure the new images are compatible with the images that are not to be upgraded. The upgrade will fail if a conflict exists.
After an ISSU, you must log in to the device again before you can configure the device.
Log in to the device through the console port after you finish all the preparation tasks and read all the ISSU guidelines.
If you use Telnet or SSH, you might be disconnected from the device before the ISSU is completed.
1.      Read the release notes for the device carefully to identify all feature changes between the current version and the new version. Remove all commands that the new software version does not support from the running configuration.
IMPORTANT
IMPORTANT:
For a successful ISSU, you must identify all feature changes between the current version and the new version and remove all commands that the new version does not support.
2.      To uninstall a feature image, remove the commands configured for the feature.
IMPORTANT
IMPORTANT:
To ensure correct system operation, you must remove the commands configured for features to be uninstalled before uninstalling the features.
3.      Use the save command to save the running configuration.
Perform this task only on a multichassis IRF fabric or a multiparent IRF 3 system.
Always start ISSU with a subordinate member.
Step
Remarks
1.      Enter system view.
N/A
2.      Disable automatic rollback.
issu rollback-timer 0
By default, the automatic rollback timer is set to 45 minutes.
As a best practice, do not use the automatic rollback feature. This feature is complicated.
3.      Return to user view.
N/A
4.      (Optional.) Specify PEX startup images.
·           Use .bin files:
issu pex pex-model file { boot filename | system filename | feature filename&<1-30> } *
·           Use an .ipe file:
issu pex pex-model file ipe ipe-filename
Perform this step if you want to upgrade PEXs.
5.      Load the upgrade images as main startup software images on subordinate members.
·           Use .bin image files:
issu load file { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number
·           Use an .ipe image file:
issu load file ipe ipe-filename chassis chassis-number&<1-3>
Specify the member ID of a subordinate member for the chassis-number argument.
The command also upgrades single-homed PEXs that are attached to the specified subordinate members.
6.      Perform a switchover.
issu run switchover
This command also upgrades multihomed PEXs.
7.      (Optional.) Accept the upgrade.
issu accept
N/A
8.      Upgrade the remaining members to complete the ISSU.
issu commit chassis chassis-number
Repeat the issu commit command to upgrade the remaining members one by one, including the original master.
IMPORTANT IMPORTANT:
After executing the command for one member, you must wait for the member to restart and join the IRF fabric before you execute the command for another member.
9.      Verify that the ISSU is finished.
display issu state
If the ISSU state field displays Init, the ISSU is finished.
Perform this task in user view.
Step
Remarks
1.      (Optional.) Specify PEX startup images.
·           Use .bin files:
·           Use an .ipe file:
2.      Load the upgrade images as main startup software images on subordinate members.
issu load file { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number&<1-3>
Because incompatible versions cannot run simultaneously, the upgraded subordinate devices will be isolated and cannot forward traffic until a master/subordinate switchover occurs.
As a best practice in a ring-topology IRF fabric, specify half of the subordinate members for this command to reduce service interruption. Make sure the specified subordinate members are physically connected.
This command also upgrades the PEXs that are attached only to the specified subordinate members.
3.      Perform a master/subordinate switchover to complete the ISSU process.
issu run switchover
This command upgrades the remaining members and PEXs.
ISSU task list
Tasks at a glance
Remarks
(Optional.) Decompressing an .ipe file
To use install commands for upgrade, you must use .bin image files. If the upgrade file is an .ipe file, perform this task before you use install commands for upgrade.
(Required.) Perform one of the following tasks to update software:
·           Installing or upgrading software images
¡  Installing or upgrading images for PEXs
¡  Installing or upgrading feature images
¡  Installing patch images
·           Uninstalling feature or patch images
¡  Uninstalling feature images
¡  Uninstalling patch images
Perform an activate operation to install new images or upgrade existing images.
Perform a deactivate operation to uninstall feature or patch images.
An image is added to or removed from the current software image list when it is activated or deactivated.
(Optional.) Aborting a software activate/deactivate operation
You can perform this task while an image is being activated or deactivated.
This task is available only for service upgrade or file upgrade.
(Optional.) Committing software changes
This task updates the main startup image list with the changes.
If service upgrade or file upgrade is performed, you must perform this task for the changes to take effect after a reboot.
(Optional.) Verifying software images
Perform this task to verify that the software changes are correct.
(Optional.) Deleting inactive software images
Perform this task to delete images
Step
1.      (Optional.) Identify images that are included in the .ipe file.
display install ipe-info
2.      Decompress the .ipe file.
install add ipe-filename medium-name:
Use one of the following methods to perform this task:
·           Slot by slot—Activate all the images on one slot, and then move to the next slot.
·           Image by image—Activate one image on all slots before activating another image.
In standalone mode:
·           When you install an image, you must begin with the active MPU.
·           When you upgrade an image, you must begin with the standby MPU.
In IRF mode:
·           When you install an image, you must begin with the master. On each member device, begin with the active MPU.
·           When you upgrade an image, you must begin with a subordinate device. On each member device, begin with the standby MPU.
When you install or upgrade images on an active MPU, the system automatically upgrades its LPUs. You do not need to upgrade their software separately.
Perform this task in an IRF 3 system when only PEXs need to be upgraded.
Step
Remarks
1.      (Optional.) Identify the ISSU method and possible impact of the upgrade.
install activate { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number slot slot-number test
Specify the virtual chassis number of a PEX for the chassis-number argument.
2.      Activate images.
You can perform this task on a standalone device, an IRF fabric, or an IRF 3 system.
Step
Remarks
·           In standalone mode:
install activate
{ boot filename | system filename | feature filename&<1-30>} * slot slot-number test
·           In IRF mode:
The device does not support the boot filename or system filename option.
To upgrade a PEX, specify the virtual chassis number of the PEX for the chassis-number argument.
2.      Activate images.
install activate
{ boot filename | system filename | feature filename&<1-30> } * slot slot-number
·           In IRF mode:
If a system image has multiple versions of patch images, you only need to install the latest version. You do not need to uninstall older patch images before you install a new patch image.
Remarks
Activate patch images.
install activate patch filename
{ all | slot slot-number }
·           In IRF mode:
{ all | chassis chassis-number slot slot-number }
To patch a PEX, specify the virtual chassis number of the PEX for the chassis-number argument.
The uninstall operation only removes images from the current software image list. For the change to take effect after a reboot, you must perform a commit operation to remove the images from the main startup image list.
Uninstalled images are still stored on the storage medium. To permanently remove the images, execute the install remove command. For more information, see "Deleting inactive software images."
Boot and system images cannot be uninstalled.
Remarks
Deactivate feature images.
install deactivate feature filename&<1-30> slot slot-number
·           In IRF mode:
30> chassis chassis-number slot slot-number
To deactivate feature images on a PEX, perform the following tasks:
·           Specify the virtual chassis number of the PEX for the chassis-number argument.
·           Specify the virtual slot number of the PEX for the slot-number argument.
Remarks
Deactivate patch images.
install deactivate patch filename slot slot-number
·           In IRF mode:
install
deactivate patch filename chassis chassis-number slot slot-number
To deactivate patch images on a PEX, perform the following tasks:
This task is available only for service upgrade or file upgrade performed through activate or deactivate operation. After the operation is aborted, the system runs with the software images that it was running with before the operation.
Abort a software activate/deactivate operation.
·           Method 1: Press Ctrl+C while a software image is being activated or deactivated.
·           Method 2: Abort a software activate/deactivate operation in user view.
install abort [ job-id ]
When you activate or deactivate images for an incremental upgrade, or install or uninstall patches, the main startup image list does not update with the changes. The software changes are lost at reboot. For the changes to take effect after a reboot, you must commit the changes.
Remarks
Commit the software changes.
install commit
This command commits all software changes, including software changes for PEXs.
Perform this task to verify the following items:
·           Integrity—Verify that the boot, system, and feature images are integral.
·           Consistency—Verify that the same active images are running across the entire system.
·           Software commit status—Verify that the active images are committed as needed.
If an image is not integral, consistent, or committed, use the install activate, install deactivate, and install commit commands as appropriate to resolve the issue.
Remarks
Verify software images.
install verify
This command takes effect for both the parent devices and PEXs.
This task permanently deletes inactive image files from the device.
Remarks
Delete inactive software images.
install remove [ slot slot-number
] { filename | inactive }
·           In IRF mode:
install remove [ chassis chassis-number slot slot-number
To delete inactive software images from a PEX, perform the following tasks:
Standalone mode
The commands in this section applies to devices in standalone mode.
Display active software images.
display install active [ slot slot-number ] [ verbose ]
Display backup startup software images.
display install backup [ slot slot-number ] [ verbose ]
Display main startup software images.
display install committed [ slot slot-number ] [ verbose ]
Display inactive software images.
display install inactive [ slot slot-number ] [ verbose ]
Display the software images included in an .ipe file.
display install ipe-info ipe-filename
Display ongoing ISSU activate and deactivate operations.
display install job
Display ISSU log entries.
display install log [ log-id ] [ verbose ]
Display software image file information.
display install package { filename | all } [ verbose ]
Display all software image files that include a specific component or file.
display install which { component name | file filename } [ slot slot-number ]
Display version compatibility information and identify the upgrade method.
Clear ISSU log entries.
reset install log-history oldest log-number
IRF mode
The commands in this section applies to devices in IRF mode.
Remarks
display install active [ chassis chassis-number slot slot-number ] [ verbose ]
N/A
display install backup [ chassis chassis-number slot slot-number ] [ verbose ]
N/A
display install committed [ chassis chassis-number slot slot-number ] [ verbose ]
N/A
display install inactive [ chassis chassis-number slot slot-number ] [ verbose ]
N/A
N/A
display install job
N/A
N/A
N/A
display install which { component name | file filename } [ chassis chassis-number slot slot-number ]
N/A
Display ISSU status information.
display issu state
This command applies only to an ISSU that uses the issu series commands.
N/A
N/A
Symptom
The following commands cannot be executed:
·           issu commandsissu load, issu run switchover, and issu commit.
·           install commandsinstall activate and install deactivate.
Solution
To resolve this issue:
1.      Use the display device command to verify that all cards are not in Fault state.
2.      Use the display mdc command to verify that all MDCs are in active state.
3.      If the problem persists, contact H3C Support.
Upgrade requirements
As shown in Figure 1, the IRF fabric has two members. Each member has one active MPU (slot 6) and one standby MPU (slot 7).
Upgrade the HTTP feature from R0201 to R0202. The two versions are compatible.
Figure 1 Network diagram
Upgrade procedure
# Download the image file that contains the R0202 HTTP feature from the TFTP server.
<Sysname> tftp 2.2.2.2 get http-r0202.bin
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   256  100  256     0     0    764      0 --:--:-- --:--:-- --:--:--   810
# Display active software images.
<Sysname> display install active
Active packages on chassis 1 slot 6:
  flash:/boot-r0201.bin
  flash:/system-r0201.bin
  flash:/http-r0201.bin
Active packages on chassis 1 slot 7:
Active packages on chassis 2 slot 6:
Active packages on chassis 2 slot 7:
# Identify the ISSU method and possible impact of the upgrade.
<Sysname> display version comp-matrix file feature flash:/http-r0202.bin
Verifying the file flash:/http-r0202.bin on Chassis 1 slot 6...Done.
Feature image: flash:/http-r0202.bin
  Version:
  V700R001B45D002
  Version Compatibility List:
  V700R001B45D001
  V700R001B45D002
  Version Dependency System List:
  V700R001B45D001
  V700R001B45D002
  Chassis   Slot              Upgrade Way
  1         6                 Service Upgrade
  1         7                 Service Upgrade
  2         6                 Service Upgrade
  2         7                 Service Upgrade
Influenced service according to following table on chassis 1 slot 6:
         HTTP      CFA
Influenced service according to following table on chassis 1 slot 7:
         HTTP      CFA
Influenced service according to following table on chassis 2 slot 6:
         HTTP      CFA
Influenced service according to following table on chassis 2 slot 7:
         HTTP      CFA
The output shows that service upgrade is recommended. The HTTP and CFA modules will be rebooted during the upgrade.
# Disable automatic rollback.
[Sysname] issu rollback-timer 0
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
# Enable the IRF bridge MAC address to be permanent.
[Sysname] irf mac-address persistent always
# Set the physical state change suppression interval to 0 on the interfaces.
[Sysname] interface gigabitethernet1/3/0/1
[Sysname-GigabitEthernet1/3/0/1] link-delay 0 mode updown
[Sysname-GigabitEthernet1/3/0/1] quit
[Sysname] interface gigabitethernet2/3/0/1
[Sysname-GigabitEthernet2/3/0/1] link-delay 0 mode updown
[Sysname-GigabitEthernet2/3/0/1] quit
[Sysname] quit
# Upgrade the HTTP feature on the subordinate member.
<Sysname> issu load file feature flash:/http-r0202.bin chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/http-r0202.bin to chassis2#slot6#flash:/http-r0202.bin......Done.
Verifying the file flash:/http-r0202.bin on Chassis 2 slot 6...Done.
Copying file flash:/http-r0202.bin to chassis2#slot7#flash:/http-r0202.bin......Done.
Verifying the file flash:/http-r0202.bin on Chassis 2 slot 7...Done.
  Running Version             New Version
  Alpha 0201                  Alpha 0202
  2         6                 Service Upgrade
  2         7                 Service Upgrade
Upgrading software images to compatible versions. Continue? [Y/N]: y
# Perform a main/backup HTTP process switchover.
<Sysname> issu run switchover
  Chassis   Slot              Switchover Way
  1         6                 Active standby process switchover
# Upgrade the feature on the original master.
<Sysname> issu commit chassis 1
Copying file flash:/http-r0202.bin to chassis1#slot7#flash:/http-r0202.bin......Done.
Verifying the file flash:/http-r0202.bin on Chassis 1 slot 7...Done.
  1         6                 Service Upgrade
  1         7                 Service Upgrade
# Verify that both members are running the new HTTP image.
As shown in Figure 2, the IRF fabric has two members. Each member has one MPU in slot 6 (active MPU) and one MPU in slot 7 (standby MPU).
Upgrade the HTTP feature from R0201 to R0202. The two versions are incompatible.
Figure 2 Network diagram
Upgrade procedure
# Identify the recommended ISSU method for the upgrade and view the possible impact of the upgrade.
  Version:
  V700R001B45D002
  V700R001B45D002
  V700R001B45D001
  V700R001B45D002
Incompatible upgrade.
The output shows that the two versions are incompatible. The cards will be rebooted for the upgrade.
[Sysname] quit
# Upgrade the HTTP feature on the subordinate member. After the upgrade, the subordinate member will leave the original IRF fabric and form a new IRF fabric by itself.
  2         6                 Reboot
  2         7                 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]: y
# Perform a master/subordinate switchover to upgrade the original master. The original master will reboot and join the new IRF fabric.
  1         6                 Reboot
  1         7                 Reboot
As shown in Figure 3, the IRF fabric has four members. Each member has one active MPU (slot 6), one standby MPU (slot 7), and one LPU (slot 3).
Upgrade a feature from soft-version1 to soft-version2 on the IRF fabric. The two versions are compatible.
Figure 3 Network diagram
Upgrade procedure
# Download the upgrade image file from the TFTP server.
<Sysname> tftp 2.2.2.2 get soft-version2.bin
Press CTRL+C to abort.
100 13312    0 13312    0     0   295k      0 --:--:-- --:--:-- --:--:--  309k
Active packages on chassis 1 slot 3:
  flash:/cmw710-boot-test.bin
  flash:/cmw710-system-test.bin
  flash:/soft-version1.bin
Active packages on chassis 2 slot 3:
Active packages on chassis 3 slot 3:
Active packages on chassis 3 slot 6:
Active packages on chassis 3 slot 7:
Active packages on chassis 4 slot 3:
Active packages on chassis 4 slot 6:
Active packages on chassis 4 slot 7:
<Sysname> display version comp-matrix file feature flash:/soft-version2.bin
Verifying the file flash:/soft-version2.bin on chassis 1 slot 6...Done.
Feature image: flash:/soft-version2.bin
  Version:
  7.1.045-Release 7168
  Version compatibility list:
  Version dependency system list:
  1         3                 Service Upgrade
  1         6                 Service Upgrade
  1         7                 Service Upgrade
  2         3                 Service Upgrade
  2         6                 Service Upgrade
  2         7                 Service Upgrade
  3         3                 Service Upgrade
  3         6                 Service Upgrade
  3         7                 Service Upgrade
  4         3                 Service Upgrade
  4         6                 Service Upgrade
  4         7                 Service Upgrade
The output shows that service upgrade is recommended. The feature module will be rebooted during the upgrade.
[Sysname] interface gigabitethernet3/3/0/1
[Sysname-GigabitEthernet3/3/0/1] link-delay 0 mode updown
[Sysname-GigabitEthernet3/3/0/1] quit
[Sysname] interface gigabitethernet4/3/0/1
[Sysname-GigabitEthernet4/3/0/1] link-delay 0 mode updown
[Sysname-GigabitEthernet4/3/0/1] quit
[Sysname] quit
# Upgrade the feature on subordinate member 2.
<Sysname> issu load file feature flash:/soft-version2.bin chassis 2
Copying file flash:/soft-version2.bin to chassis2#slot6#flash:/soft-version2.bin
...Done.
Verifying the file flash:/soft-version2.bin on chassis 2 slot 6...Done
Copying file flash:/soft-version2.bin to chassis2#slot7#flash:/soft-version2.bin
...Done.
Verifying the file flash:/soft-version2.bin on chassis 2 slot 7...Done.
  None                        Release 7168
  2         3                 Service Upgrade
  2         6                 Service Upgrade
  2         7                 Service Upgrade
This operation maybe take several minutes, please wait.....Done.
# Perform a main/backup feature process switchover.
  None                        Release 7168
This operation maybe take several minutes, please wait...Done.
# Upgrade the feature on the original master and the other subordinate members.
Copying file flash:/soft-version2.bin to chassis1#slot7#flash:/soft-version2.bin
...Done.
Verifying the file flash:/soft-version2.bin on chassis 1 slot 7...Done.
  None                        Release 7168
  1         3                 Service Upgrade
  1         6                 Service Upgrade
  1         7                 Service Upgrade
This operation maybe take several minutes, please wait........Done.
<Sysname> issu commit chassis 3
Copying file flash:/soft-version2.bin to chassis3#slot6#flash:/soft-version2.bin
...Done.
Verifying the file flash:/soft-version2.bin on chassis 3 slot 6...Done
Copying file flash:/soft-version2.bin to chassis3#slot7#flash:/soft-version2.bin
...Done.
Verifying the file flash:/soft-version2.bin on chassis 3 slot 7...Done.
  None                        Release 7168
  3         3                 Service Upgrade
  3         6                 Service Upgrade
  3         7                 Service Upgrade
This operation maybe take several minutes, please wait....Done.
<Sysname> issu commit chassis 4
Copying file flash:/soft-version2.bin to chassis4#slot6#flash:/soft-version2.bin
...Done.
Verifying the file flash:/soft-version2.bin on chassis 4 slot 6...Done
Copying file flash:/soft-version2.bin to chassis4#slot7#flash:/soft-version2.bin
...Done.
Verifying the file flash:/soft-version2.bin on chassis 4 slot 7...Done
  None                        Release 7168
  4         3                 Service Upgrade
  4         6                 Service Upgrade
  4         7                 Service Upgrade
# Verify that all members are running the new image.
As shown in Figure 4, the IRF fabric has four members. Each member has one active MPU (slot 6), one standby MPU (slot 7), and one LPU (slot 3).
Upgrade a feature from soft-version1 to soft-version2 on the IRF fabric. The two versions are incompatible.
Figure 4 Network diagram
Upgrade procedure
e.
  Version:
Upgrade Way: Incompatible upgrade.
[Sysname] quit
# Upgrade the feature on subordinate member 2. After the upgrade, the subordinate member will leave the original IRF fabric and form a new IRF fabric by itself.
...Done.
Verifying the file flash:/soft-version2.bin on chassis 2 slot 6...Done.
Copying file flash:/soft-version2.bin to chassis2#slot7#flash:/ soft-version2.bin
...Done.
  Release 7168                  Release 7168
  2         3                 Reboot
  2         6                 Reboot
  2         7                 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
# Perform a master/subordinate switchover to upgrade the original master and the other two subordinate members. The original master and the other two subordinate members will reboot and join the new IRF fabric.
...Done.
...Done.
Verifying the file flash:/soft-version2.bin on chassis 3 slot 6...Done.
...Done.
...Done.
Verifying the file flash:/soft-version2.bin on chassis 4 slot 6...Done.
...Done.
Verifying the file flash:/soft-version2.bin on chassis 4 slot 7...Done.
  1         3                 Reboot
  1         6                 Reboot
  1         7                 Reboot
  3         3                 Reboot
  3         6                 Reboot
  3         7                 Reboot
  4         3                 Reboot
  4         6                 Reboot
  4         7                 Reboot
As shown in Figure 5, the IRF fabric has four members. Each member has one active MPU (slot 6), one standby MPU (slot 7), and one LPU (slot 3).
Figure 5 Network diagram
Upgrade procedure
Verifying the file flash:/soft-version2.bin on chassis 2 slot 4...Done
  Version:
[Sysname] quit
# Upgrade the feature on all subordinate members. After the upgrade, the subordinate members will leave the original IRF fabric and form a new IRF fabric.
<Sysname> issu load file feature flash:/soft-version2.bin chassis 2 3 4
...Done.
...Done.
...Done.
...Done.
...Done.
...Done.
Verifying the file flash:/soft-version2.bin on chassis 2 slot 6............Done.
Verifying the file flash:/soft-version2.bin on chassis 2 slot 7............Done.
Verifying the file flash:/soft-version2.bin on chassis 3 slot 6............Done.
Verifying the file flash:/soft-version2.bin on chassis 3 slot 7............Done.
Verifying the file flash:/soft-version2.bin on chassis 4 slot 6............Done.
Verifying the file flash:/soft-version2.bin on chassis 4 slot 7............Done.
  2         3                 Reboot
  2         6                 Reboot
  2         7                 Reboot
  3         3                 Reboot
  3         6                 Reboot
  3         7                 Reboot
  4         3                 Reboot
  4         6                 Reboot
  4         7                 Reboot
...Done.
Verifying the file flash:/soft-version2.bin on chassis 1 slot 7............Done.
  1         3                 Reboot
  1         6                 Reboot
  1         7                 Reboot
As shown in Figure 6, the IRF 3 system contains a two-chassis parent fabric and an S5120HI PEX.
·           The PEX is connected to both the master and the subordinate member.
·           The master has two MPUs (active in slot 6 and standby in slot 7) and two LPUs (in slot 8 and slot 12).
·           The subordinate member has one MPU (in slot 6) and one LPU (in slot 8).
Upgrade the HTTP feature as follows:
·           From a0041 to the compatible version a0042 on the parent IRF fabric.
·           From d2402 to the compatible version d2403 on the PEX.
Figure 6 Network diagram
Upgrade procedure
# Download the image file that contains the d2403 HTTP feature for PEX upgrade from the TFTP server.
<Sysname> tftp 2.2.2.2 get s5120hi-http-d2403.bin
# Download the image file that contains the a0042 HTTP feature for parent IRF fabric upgrade from the TFTP server.
<Sysname> tftp 2.2.2.2 get http-a0042.bin
  flash:/boot-a0041.bin
  flash:/system-a0041.bin
  flash:/http-a0041.bin
Active packages on chassis 1 slot 8:
Active packages on chassis 1 slot 12:
Active packages on chassis 2 slot 8:
Active packages on chassis 101 slot 0:
  flash:/s5120hi-boot.bin
  flash:/s5120hi-system.bin
  flash:/s5120hi-http-d2402.bin
[Sysname] quit
# Specify PEX startup images.
<Sysname> issu pex PEX-S5120HI file feature flash:/s5120hi-http-d2403.bin
Verifying the file flash:/s5120hi-http-d2403.bin on chassis 1 slot 6...Done.
Copying file flash:/s5120hi-http-d2403.bin to chassis1#slot7#flash:/s5120hi-http-d2403...Done.
Copying file flash:/s5120hi-http-d2403.bin to chassis2#slot6#flash:/s5120hi-http-d2403...Done.
<Sysname> display version comp-matrix file feature flash:/http-a0042.bin
Verifying the file flash:/http-a0042.bin on chassis 1 slot 6...Done.
Feature image: flash:/http-a0042.bin
  Version:
  A0042
  A0041
  A0042
  A0041
Compatible info of S5120HI:
Feature image: flash:/s5120hi-http-d2403.bin
  Version:
  D2403
  D2402
  D2403
  D2402
  1         6                 Service Upgrade
  1         7                 Service Upgrade
  1         8                 Service Upgrade
  1         12                Service Upgrade
  2         6                 Service Upgrade
  2         8                 Service Upgrade
  101       0                 Service Upgrade
         HTTP      CFA
         HTTP      CFA
Influenced service according to following table on chassis 1 slot 8:
         HTTP
Influenced service according to following table on chassis 1 slot 12:
         HTTP
         HTTP      CFA
Influenced service according to following table on chassis 2 slot 8:
         HTTP
Influenced service according to following table on chassis 101 slot 0:
         HTTP
The output shows that an incremental upgrade is recommended and the following items will be rebooted during the upgrade:
·           HTTP and CFA modules on the MPUs.
·           HTTP module on the LPUs.
·           HTTP module on the PEX.
<Sysname> issu load file feature flash:/http-a0042.bin chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:Y
flash:/http-a0042.bin already exists on chassis 2 slot 6.
Overwrite it?[Y/N]:Y
Successfully copied flash:/http-a0042.bin to chassis2#slot6#flash:/http-a0042.bin.
Verifying the file flash:/http-a0042.bin on chassis 2 slot 6...Done.
flash:/http-a0042.bin already exists on chassis 2 slot 8.
Successfully copied flash:/http-a0042.bin to chassis2#slot8#flash:/http-a0042.bin.
Verifying the file flash:/http-a0042.bin on chassis 2 slot 8...Done.
  Alpha 0041                  Alpha 0042
  2         6                 Service Upgrade
  2         8                 Service Upgrade
  2         12                Service Upgrade
Upgrading software images to compatible versions. Continue? [Y/N]:Y
# Perform a main/backup HTTP process switchover and upgrade the PEX.
# Upgrade the HTTP feature on the master.
  1         6                 Service Upgrade
  1         7                 Service Upgrade
  1         8                 Service Upgrade
# Verify that the IRF members and the PEX are all running the new HTTP images.
<Sysname>display install active
Active packages on chassis 2 slot 12:
As shown in Figure 7, the IRF 3 system contains a two-chassis parent fabric and an S5120HI PEX.
·           The master has two MPUs (active in slot 6 and standby in slot 7) and two LPUs (in slot 8 and in slot 12).
·           From a0041 to the incompatible version a0043 on the parent IRF fabric.
·           From d2402 to the incompatible version d2404 on the PEX.
Figure 7 Network diagram
Upgrade procedure
# Download the image file that contains the d2404 HTTP feature for PEX upgrade from the TFTP server.
<Sysname> tftp 2.2.2.2 get s5120hi-http-d2404.bin
# Download the image file that contains the a0043 HTTP feature for parent IRF fabric upgrade from the TFTP server.
<Sysname> tftp 2.2.2.2 get flash:/http-a0043.bin
[Sysname] quit
<Sysname> issu pex PEX-S5120HI file feature flash:/s5120hi-http-d2404.bin
Verifying the file flash:/s5120hi-http-d2404.bin on chassis 1 slot 6...Done.
Copying file flash:/s5120hi-http-d2404.bin to chassis1#slot7#flash:/s5120hi-http-d2404.bin...Done.
Copying file flash:/s5120hi-http-d2404.bin to chassis2#slot6#flash:/s5120hi-http-d2404.bin...Done.
<Sysname> display version comp-matrix file feature flash:/http-a0043.bin
Verifying the file flash:/http-a0043.bin on chassis 1 slot 6...Done.
Feature image:flash:/http-a0043.bin
  Version:
  A0043
  A0043
  A0041
Feature image: flash:/s5120hi-http-d2404.bin
  Version:
  D2404
  D2404
  D2402
<Sysname> issu load file feature flash:/http-a0043.bin chassis 2
Copying file flash:/http-a0043.bin to chassis2#slot6#flash:/http-a0043.bin...Done.
Verifying the file flash:/http-a0043.bin on chassis 2 slot 6...Done.
  Alpha 0041                  Alpha 0043
  2         6                 Reboot
  2         8                 Reboot
After the upgrade, the upgraded subordinate member leaves the current IRF fabric and forms a new IRF fabric.
# Perform an ISSU switchover on the current IRF fabric and upgrade the PEX.
Copying file flash:/http-a0043.bin to chassis1#slot7#flash:/http-a0043.bin...Done.
Verifying the file flash:/http-a0043.bin on chassis 1 slot 7...Done.
  1         6                 Reboot
  1         7                 Reboot
  1         8                 Reboot
  1         12                Reboot
  101       0                 Reboot
After the upgrade, the original master joins the new IRF fabric.
As shown in Figure 8, the device has two MPUs. The active MPU is in slot 6. The standby MPU is in slot 7.
Figure 8 Network diagram
Upgrade procedure
# Download the .ipe file that contains the R0202 HTTP feature image from the TFTP server.
<Sysname> tftp 2.2.2.2 get http-r0202.ipe
Writing file...Done.
# Decompress the .ipe file.
<Sysname> install add flash:/http-r0202.ipe flash:/
Verifying the file flash:/http-r0202.ipe on slot 6...Done.
Decompressing file http-r0202.bin to flash:/http-r0202.bin.......................Done.
Active packages on slot 6:
Active packages on slot 7:
# Identify the version compatibility, recommended ISSU methods, and possible impact of the upgrade.
<Sysname> install activate feature flash:/http-r0202.bin slot 7 test
Copying file flash:/http-r0202.bin to slot7#flash:/http-r0202.bin......Done.
Verifying the file flash:/http-r0202.bin on slot 7...Done.
  Slot                        Upgrade Way
  7                           Service Upgrade
Influenced service according to following table on slot 7:
         HTTP      CFA
<Sysname> install activate feature flash:/http-r0202.bin slot 6 test
Verifying the file flash:/http-r0202.bin on slot 6...Done.
  Slot                        Upgrade Way
  6                           Service Upgrade
  7                           Service Upgrade
Influenced service according to following table on slot 6:
         HTTP      CFA
The output shows that both MPUs need a service upgrade and the HTTP and CFA modules will be rebooted during the upgrade.
# Activate the new HTTP image to upgrade the HTTP feature.
flash:/http-r0202.bin already exists on slot 7.
Overwrite it?[Y/N]:y
  Slot                        Upgrade Way
  7                           Service Upgrade
This operation maybe take several minutes, please wait......................Done.
  Slot                        Upgrade Way
  6                           Service Upgrade
  7                           Service Upgrade
# Verify that the new HTTP image has been activated.
# Commit the software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
As shown in Figure 9, the IRF fabric has two members. Each member has one MPU in slot 6 (active MPU) and one MPU in slot 7 (standby MPU).
Figure 9 Network diagram
Upgrade procedure
Verifying the file flash:/http-r0202.ipe on chassis 1 slot 6...Done.
# Identify the recommended ISSU methods for the upgrade and view the possible impact of the upgrade.
<Sysname> install activate feature flash:/http-r0202.bin chassis 2 slot 7 test
Verifying the file flash:/http-r0202.bin on chassis 2 slot 7...Done.
  2         6                 Service Upgrade
  2         7                 Service Upgrade
         HTTP      CFA
         HTTP      CFA
<Sysname> install activate feature flash:/http-r0202.bin chassis 2 slot 6 test
Verifying the file flash:/http-r0202.bin on chassis 2 slot 6...Done.
  2         6                 Service Upgrade
         HTTP      CFA
<Sysname> install activate feature flash:/http-r0202.bin chassis 1 slot 7 test
Verifying the file flash:/http-r0202.bin on chassis 1 slot 7...Done.
  1         6                 Service Upgrade
  1         7                 Service Upgrade
         HTTP      CFA
         HTTP      CFA
<Sysname> install activate feature flash:/http-r0202.bin chassis 1 slot 6 test
Verifying the file flash:/http-r0202.bin on chassis 1 slot 6...Done.
  1         6                 Service Upgrade
         HTTP      CFA
The output shows that all the MPUs need a service upgrade and the HTTP and CFA modules will be rebooted during the upgrade.
flash:/http-r0202.bin already exists on chassis 2 slot 7.
  2         6                 Service Upgrade
  2         7                 Service Upgrade
flash:/http-r0202.bin already exists on chassis 2 slot 6.
  2         6                 Service Upgrade
flash:/http-r0202.bin already exists on chassis 1 slot 7.
  1         6                 Service Upgrade
  1         7                 Service Upgrade
  1         6                 Service Upgrade
As shown in Figure 10, the IRF 3 system contains a two-chassis parent fabric and an S5120HI PEX.
Figure 10 Network diagram
Upgrade procedure
<Sysname> install activate feature flash:/http-a0042.bin chassis 1 slot 6 test
  1         6                 Service Upgrade
  1         8                 Service Upgrade
         HTTP      CFA
         HTTP
         HTTP
<Sysname> install activate feature flash:/http-a0042.bin chassis 1 slot 7 test
Verifying the file flash:/http-a0042.bin on chassis 1 slot 7...Done.
  1         7                Service Upgrade
         HTTP      CFA
<Sysname> install activate feature flash:/http-a0042.bin chassis 2 slot 6 test
  2         6                Service Upgrade
  2         8                 Service Upgrade
         HTTP      CFA
         HTTP
<Sysname> install activate feature flash:/s5120hi-http-d2403.bin chassis 101 slot 0 test
  Demo 2402                   Demo 2403
         HTTP
·           HTTP module on the LPU.
# Activate the new HTTP image to upgrade the HTTP feature on the MPU in slot 7 of chassis 1.
flash:/http-a0042.bin already exists on chassis 1 slot 7.
Successfully copied flash:/http-a0042.bin to chassis1#slot7#flash:/http-a0042.bin.
  1         7                 Service Upgrade
# Activate the new HTTP image to upgrade the HTTP feature on the MPU in slot 6 of chassis 1 and the LPUs in chassis 1.
flash:/http-a0042.bin already exists on chassis 1 slot 6.
Successfully copied flash:/http-a0042.bin to chassis1#slot6#flash:/http-a0042.bin.
  1         6                 Service Upgrade
  1         8                 Service Upgrade
# Activate the new HTTP image to upgrade the HTTP feature on the cards in chassis 2.
Successfully copied flash:/http-a0042.bin to chassis2#slot6# flash:/http-a0042.bin.
  2         6                 Service Upgrade
  2         8                 Service Upgrade
# Activate the new HTTP image to upgrade the HTTP feature on the PEX.
flash:/s5120hi-http-d2403.bin already exists on chassis 101 slot 0.
Successfully copied s5120hi-http-d2403.bin to chassis101#slot0#flash:/s5120hi-http-d2403.bin.
  Demo 2402                   Demo 2403
