HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release7178-6W10001-Fundamentals Configuration Guide
04-FTP and TFTP configuration
04-FTP and TFTP configuration 166.26 KB
Configuring FTP
File Transfer Protocol (FTP) is an application layer protocol for transferring files from one host to another over an IP network. It uses TCP port 20 to transfer data and TCP port 21 to transfer control commands. For more information about FTP, see RFC 959.
FTP is based on the client/server model. The device can act as the FTP server or FTP client. Make sure the FTP server and the FTP client can reach each other before establishing the FTP connection.
Figure 1 FTP application scenario
FTP supports the following transfer modes:
·           Binary modeUsed to non-text files, such as .app, .bin, and .btm files.
·           ASCII mode—Used to transfer text files, such as .txt, .bat, and .cfg files.
When the device acts as the FTP client, you can set the transfer mode (binary by default). When the device acts as the FTP server, the transfer mode is determined by the FTP client.
FTP can operate in either of the following modes:
·           Active mode (PORT)—The FTP server initiates the TCP connection. This mode is not suitable when the FTP client is behind a firewall, for example, when the FTP client resides in a private network.
·           Passive mode (PASV)—The FTP client initiates the TCP connection. This mode is not suitable when the server does not allow the client to use a random unprivileged port greater than 1024.
FTP operation mode varies depending on the FTP client program.
FIPS compliance
FTP is not supported in FIPS mode.
Using the device as an FTP server
To use the device as an FTP server, you must enable the FTP server and configure authentication and authorization on the device. Other commands are optional.
Configuring basic parameters
Step
Remarks
1.      Enter system view.
N/A
2.      Enable the FTP server.
ftp server enable
By default, the FTP server is disabled.
3.      (Optional.) Use an ACL to control access to the FTP server.
ftp server acl { acl-number | ipv6 acl-number6 }
By default, no ACL is used for access control.
4.      (Optional.) Associate an SSL server policy with the FTP server to ensure data security.
ftp server ssl-server-policy policy-name
By default, no SSL server policy is associated with the FTP server.
5.      (Optional.) Set the FTP connection idle-timeout timer.
ftp timeout minutes
By default, the FTP connection idle-timeout timer is 30 minutes.
If no data transfer occurs on an FTP connection within the idle-timeout interval, the FTP server closes the FTP connection to release resources.
6.      (Optional.) Set the DSCP value for outgoing FTP packets.
·           For an IPv4 FTP server:
ftp server dscp dscp-value
·           For an IPv6 FTP server:
ftp server ipv6 dscp dscp-value
By default, the DSCP value is 0.
7.      (Optional.) Set the maximum number of concurrent FTP users.
aaa session-limit ftp max-sessions
The default maximum number is 32.
Changing this setting does not affect users who are currently online. If the current number of online FTP users is equal to or greater than the new setting, no additional FTP users can log in until online users log out.
For more information about this command, see Security Command Reference.
Configuring authentication and authorization
Perform this task on the FTP server to authenticate FTP clients and set the authorized directories that authenticated clients can access.
The following authentication modes are available:
·           Local authentication—The device looks up the client's username and password in the local user account database. If a match is found, authentication succeeds.
·           Remote authentication—The device sends the client's username and password to a remote authentication server for authentication. The user account is configured on the remote authentication server rather than the device.
The following authorization modes are available:
·           Local authorization—The device assigns authorized directories to FTP clients based on the locally configured authorization attributes.
·           Remote authorization—A remote authorization server assigns authorized directories on the device to FTP clients.
For information about configuring authentication and authorization, see Security Configuration Guide.
Manually releasing FTP connections
Execute the following commands in user view.
Manually release FTP connections.
·           Release the FTP connection established by using a specific user account:
free ftp user username
·           Release the FTP connection to a specific IP address:
free ftp user-ip [ ipv6 ] client-address [ port port-num ]
Displaying and maintaining the FTP server
Display FTP server configuration and status information.
display ftp-server
Display detailed information about online FTP users.
display ftp-user
FTP server configuration example in standalone mode
Network requirements
·           Configure the device as an FTP server.
·           Create a local user account with the username abc and password 123456 on the FTP server.
·           Use the user account to log in to the FTP server from the FTP client.
·           Upload the file temp.bin from the FTP client to the FTP server.
·           Download the configuration file startup.cfg from the FTP server to the FTP client for backup.
Figure 2 Network diagram
Configuration procedure
1.      Configure IP addresses as shown in Figure 2. Make sure the device and PC can reach other. (Details not shown.)
2.      Configure the device (FTP server):
# Create a local user with the username abc and password 123456.
[Sysname] local-user abc class manage
[Sysname-luser-abc] password simple 123456
# Assign the user role network-admin to the user. (The default working directory is the root directory of the flash memory on the active MPU. To change the working directory to the root directory of the flash memory on the standby MPU, specify the work-directory slotm#flash:/ option for the command. The m argument represents the slot number of the standby MPU.)
[Sysname-luser-abc] authorization-attribute user-role network-admin
# Assign the service type FTP to the user.
[Sysname-luser-abc] service-type ftp
[Sysname-luser-abc] quit
# Enable the FTP server.
[Sysname] ftp server enable
[Sysname] quit
# Examine the storage space for space insufficiency and delete unused files for more free space.
<Sysname> dir
Directory of flash:
     0      -rw-           0  Sep 27 2010 14:43:34     kernel.bin
     1      -rw-           0  Sep 27 2010 14:43:34     base.bin
     2      drw-           -  Jun 29 2011 18:30:38     logfile
     3      drw-           -  Jun 21 2011 14:51:38     diagfile
     4      drw-           -  Jun 21 2011 14:51:38     seclog
     5      -rw-        2943  Jul 02 2011 08:03:08     startup.cfg
     6      -rw-       63901  Jul 02 2011 08:03:08     startup.mdb
     7      -rw-         716  Jun 21 2011 14:58:02     hostkey
     8      -rw-         572  Jun 21 2011 14:58:02     serverkey
     9      -rw-     6541264  Aug 04 2011 20:40:49     backup.bin
473664 KB total (467080 KB free)
<Sysname> delete /unreserved flash:/backup.bin
3.      Perform FTP operations from the PC (FTP client):
# Log in to the FTP server at 1.1.1.1 using the username abc and password 123456.
c:\> ftp 1.1.1.1
Connected to 1.1.1.1.
220 FTP service ready.
User(1.1.1.1:(none)):abc
331 Password required for abc.
Password:
230 User logged in.
# Use the ASCII mode to download the configuration file startup.cfg from the device to the PC for backup.
ftp> ascii
200 TYPE is now ASCII
ftp> get startup.cfg back-startup.cfg
# Use the binary mode to upload the file temp.bin from the PC to the root directory of the flash memory on the active MPU.
ftp> binary
200 TYPE is now 8-bit binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
FTP server configuration example in IRF mode
·           Configure the IRF fabric as an FTP server.
·           Download the configuration file config.cfg from the FTP server to the FTP client for backup.
Figure 3 Network diagram
1.      Configure IP addresses as shown in Figure 3. Make sure the IRF fabric and the PC can reach each other. (Details not shown.)
2.      Configure the FTP server:
# Examine the storage space on the member devices. If the free space is insufficient, use the delete/unreserved file-url command to delete unused files. (Details not shown.)
# Assign the user role network-admin to the user. Set the working directory to the root directory of the flash memory on the global active MPU. (To set the working directory to the root directory of the flash memory on a global standby MPU, replace flash:/ with, for example, chassis2#slot7#flash:/.)
[Sysname-luser-abc] authorization-attribute user-role network-admin work-directory flash:/
[Sysname] quit
3.      Perform FTP operations from the FTP client:
c:\> ftp 1.1.1.1
Password:
230 User logged in.
# Use the ASCII mode to download the configuration file config.cfg from the server to the client for backup.
ftp> ascii
ftp> get config.cfg back-config.cfg
# Use the binary mode to upload the file temp.bin to the root directory of the flash memory on the global active MPU.
ftp> binary
ftp> put temp.bin
# Exit FTP.
ftp> bye
Using the device as an FTP client
Establishing an FTP connection
To access the FTP server, you must establish a connection from the FTP client to the FTP server.
To establish an IPv4 FTP connection:
Step
Remarks
N/A
2.      (Optional.) Specify a source IP address for outgoing FTP packets.
By default, no source IP address is specified, and the primary IP address of the output interface is used as the source IP address.
3.      Return to user view.
N/A
4.      Log in to the FTP server.
·           (Method 1.) Log in to the FTP server from user view:
ftp ftp-server [ service-port ]
[ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface { interface-name | interface-type interface-number } | ip source-ip-address } ] *
·           (Method 2.) Log in to the FTP server from FTP client view:
a.   Enter FTP client view:
ftp
b.   Log in to the FTP server:
open server-address [ service-port ]
The source IP address specified in the ftp command takes precedence over the one set by the ftp client source command.
To establish an IPv6 FTP connection:
Step
Remarks
N/A
2.      (Optional.) Specify the source IPv6 address for FTP packets sent by the FTP client.
ftp client ipv6 source { interface interface-type interface-number | ipv6 source-ipv6-address }
By default, no source IPv6 address is specified. The source address is automatically selected as defined in RFC 3484.
N/A
ftp ipv6 ftp-server [ service-port ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } ] * [ -i interface-type interface-number ]
ftp ipv6
The source IP address specified in the ftp ipv6 command takes precedence over the one set by the ftp client ipv6 source command.
Managing directories on the FTP server
Perform the following tasks in FTP client view:
Display directory and file information on the FTP server.
·           Display the detailed information of a directory or file on the FTP server:
dir [ remotefile [ localfile ] ]
·           Display the name of a directory or file on the FTP server:
ls [ remotefile [ localfile ] ]
Change the working directory on the FTP server.
cd { directory | .. | / }
Return to the upper level directory on the FTP server.
cdup
Display the working directory that is being accessed.
pwd
Create a directory on the FTP server.
mkdir directory
Delete a directory from the remote FTP server.
rmdir directory
Working with files on the FTP server
After you log in to the server, you can upload a file to or download a file from the authorized directory by following these steps:
1.      Use the dir or ls command to display the directory and location of the file on the FTP server.
2.      Delete unused files to get more free storage space.
3.      Set the file transfer mode to ASCII for text files or to binary for non-text files.
4.      Use the lcd command to change the local working directory of the FTP client. You can upload the file or save the downloaded file in this directory.
5.      Upload or download the file.
To work with files on an FTP server, execute the following commands in FTP client view:
Remarks
Display directory or file information on the FTP server.
N/A
Delete the specified file on the FTP server permanently.
delete remotefile
N/A
Set the file transfer mode.
·           Set the file transfer mode to ASCII:
ascii
·           Set the file transfer mode to binary:
binary
The default file transfer mode is binary.
Set the FTP operation mode to passive.
passive
The default mode is passive.
Display or change the local working directory of the FTP client.
lcd [ directory | / ]
N/A
Upload a file to the FTP server.
put localfile [ remotefile ]
N/A
Download a file from the FTP server.
get remotefile [ localfile ]
N/A
Add the content of a file on the FTP client to a file on the FTP server.
append localfile [ remotefile ]
N/A
Specify the retransmit marker.
restart marker
Use this command together with the put, get, or append command.
Update the local file.
newer remotefile
N/A
Get the missing part of a file.
reget remotefile [ localfile ]
N/A
Rename the file.
rename [ oldfilename [ newfilename ] ]
N/A
Changing to another user account
After you log in to the FTP server with one account, you can change to another account to get a different privilege without re-establishing the FTP connection. You must correctly enter the new username and password. A wrong username or password can cause the FTP connection to disconnect.
To change to another user account, execute the following command in user view:
Change to another user account.
user username [ password ]
Maintaining and troubleshooting the FTP connection
Remarks
Display FTP commands on the FTP server.
rhelp
N/A
Display FTP commands help information on the FTP server.
rhelp protocol-command
N/A
Display FTP server status.
rstatus
N/A
Display detailed information about a directory or file on the FTP server.
rstatus remotefile
N/A
Display FTP connection status.
status
N/A
Display the system information of the FTP server.
system
N/A
Enable or disable FTP operation information displaying.
verbose
By default, FTP operation information displaying is enabled.
Enable or disable FTP client debugging.
debug
By default, FTP client debugging is disabled.
Clear the reply information in the buffer.
reset
N/A
Terminating the FTP connection
Execute one of the following commands in FTP client view:
Terminate the connection to the FTP server without exiting FTP client view.
·           disconnect
·           close
Terminate the connection to the FTP server and return to user view.
·           bye
·           quit
Displaying command help information
Display command help information.
·           help [ command-name ]
·           ? [ command-name ]
Displaying and maintaining FTP client
Execute the display command in any view.
Display source IP address information on the FTP client.
display ftp client source
FTP client configuration example in standalone mode
As shown in Figure 4, the PC is acting as an FTP server. A user account with the username abc and password 123456 has been created on the PC.
·           Use the device as an FTP client to log in to the FTP server.
·           Download the file temp.bin from the PC to the device.
·           Upload the configuration file startup.cfg from the device to the PC for backup.
Figure 4 Network diagram
# Configure IP addresses as shown in Figure 4. Make sure the device and PC can reach each other. (Details not shown.)
# Examine the storage space of the device. If the free space is insufficient, use the delete/unreserved file-url command to delete unused files. (Details not shown.)
# Log in to the FTP server at 10.1.1.1 using the username abc and password 123456.
<Sysname> ftp 10.1.1.1
Press CTRL+C to abort.
Connected to 10.1.1.1 (10.1.1.1).
User (10.1.1.1:(none)): abc
Password:
230 Logged in successfully
Remote system type is MSDOS.
ftp>
# Set the file transfer mode to binary.
ftp> binary
# Download the file temp.bin from the PC to the root directory of the flash memory on the active MPU.
ftp> get temp.bin
local: temp.bin remote: temp.bin
150 Connecting to port 47457
226 File successfully transferred
23951480 bytes received in 95.399 seconds (251.0 kbyte/s)
# Download the file temp.bin from the PC to the root directory of the flash memory on the standby MPU (in slot 7).
ftp> get temp.bin slot7#flash:/temp.bin
# Use the ASCII mode to upload the configuration file startup.cfg from the device to the PC for backup.
ftp> ascii
ftp> put startup.cfg back-startup.cfg
local: startup.cfg remote: back-startup.cfg
150 Connecting to port 47461
3494 bytes sent in 5.646 seconds (618.00 kbyte/s)
ftp> bye
221-Goodbye. You uploaded 2 and downloaded 2 kbytes.
221 Logout.
<Sysname>
FTP client configuration example in IRF mode
As shown in Figure 5, the PC is acting as an FTP server. A user account with the username abc and password 123456 has been created on the PC.
·           Use the IRF fabric as an FTP client to log in to the FTP server.
·           Download the file temp.bin from the FTP server to the FTP client.
·           Upload the configuration file config.cfg from the FTP client to the FTP server for backup.
Figure 5 Network diagram
# Configure IP addresses as shown in Figure 5. Make sure the IRF fabric and PC can reach each other. (Details not shown.)
# Log in to the FTP server using the username abc and password 123456.
Password:
ftp>
ftp> binary
# Download the file temp.bin from the PC to the root directory of the flash memory on the global active MPU.
ftp> get temp.bin
# Download the file temp.bin from the PC to the root directory of the flash memory on each global standby MPU.
ftp> get temp.bin chassis1#slot7#flash:/temp.bin
ftp> get temp.bin chassis2#slot6#flash:/temp.bin
ftp> get temp.bin chassis2#slot7#flash:/temp.bin
# Use the ASCII mode to upload the configuration file config.cfg from the IRF fabric to the PC for backup.
ftp> ascii
ftp> put config.cfg back-config.cfg
local: config.cfg remote: back-config.cfg
ftp> bye
221 Logout.
<Sysname>
Configuring TFTP
Trivial File Transfer Protocol (TFTP) is a simplified version of FTP for file transfer over secure reliable networks. TFTP uses UDP port 69 for data transmission. In contrast to TCP-based FTP, TFTP does not require authentication or complex message exchanges, and is easier to deploy. TFTP is suited for reliable network environments.
The device can only act as a TFTP client. You can upload a file from the device to the TFTP server or download a file from the TFTP server to the device. If you download a file with a file name that exists in the target directory, the device deletes the existing file and saves the new one. If file download fails due to network disconnection or other reasons, the original file cannot be restored. Therefore, use a nonexistent file name instead.
Figure 6 TFTP application scenario
FIPS compliance
TFTP is not supported in FIPS mode.
Configuring the device as an IPv4 TFTP client
Step
Remarks
N/A
2.      (Optional.) Use an ACL to control the client's access to TFTP servers.
tftp-server acl acl-number
3.      Specify the source IP address for TFTP packets sent by the TFTP client.
4.      Return to user view.
N/A
5.      Download or upload a file in an IPv4 network.
tftp tftp-server { get | put | sget } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ip source-ip-address } ] *
The source IP address specified in this command takes precedence over the one set by the tftp client source command.
Use this command in user view.
Configuring the device as an IPv6 TFTP client
Step
Remarks
N/A
tftp-server ipv6 acl acl-number
3.      Specify the source IPv6 address for TFTP packets sent by the TFTP client.
tftp client ipv6 source { interface interface-type interface-number | ipv6 source-ip-address }
N/A
5.      Download or upload a file in an IPv6 network.
tftp ipv6 tftp-server [ -i interface-type interface-number ] { get | put | sget } source-filename [ destination-filename ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value | source { interface interface-type interface-number | ipv6 source-ipv6-address } ] *
The source IP address specified in this command takes precedence over the one set by the tftp client ipv6 source command.
