03-Layer 2 - LAN Switching Configuration Examples
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-XS Switch Series Configuration Examples-R7536P05-6W10003-Layer 2 - LAN Switching Configuration Examples
03-H3C_Port_Isolation_Configuration_Examples
03-H3C_Port_Isolation_Configuration_Examples 57.79 KB
H3C Port Isolation Configuration Examples
H3C_彩色.emf
Introduction
This document provides port isolation configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of port isolation.
Example: Configuring port isolation
As shown in Figure 1, the company branches Site 1 and Site 2 transfer service traffic in VLAN 2 and VLAN 3. Device A connects to the Internet through Ten-GigabitEthernet 1/1/1.
Configure port isolation on Device A to meet the following requirements:
·     All hosts can access the Internet through Device A.
·     Host A and Host B are isolated from each other at Layer 2.
·     Host C and Host D are isolated from each other at Layer 2.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on S7500EXS-CMW710-R7536P05.
When you configure port isolation on the device, follow these restrictions and guidelines:
·     Before assigning a port to an isolation group, make sure the isolation group already exists.
·     You can assign a port to only one isolation group.
Procedures
# Create VLAN 2 and assign ports Ten-GigabitEthernet 1/1/2 and Ten-GigabitEthernet 1/1/3 to the VLAN.
[DeviceA] vlan 2
[DeviceA-vlan2] port ten-gigabitethernet 1/1/2
[DeviceA-vlan2] port ten-gigabitethernet 1/1/3
[DeviceA-vlan2] quit
# Create VLAN 3 and assign ports Ten-GigabitEthernet 1/1/4 and Ten-GigabitEthernet 1/1/5 to the VLAN.
[DeviceA] vlan 3
[DeviceA-vlan3] port ten-gigabitethernet 1/1/4
[DeviceA-vlan3] port ten-gigabitethernet 1/1/5
[DeviceA-vlan3] quit
# Configure port Ten-GigabitEthernet 1/1/1 as a trunk port and assign it to VLAN 2 and VLAN 3.
[DeviceA] interface ten-gigabitethernet 1/1/1
[DeviceA-Ten-GigabitEthernet1/1/1] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/1/1] port trunk permit vlan 2 3
[DeviceA-Ten-GigabitEthernet1/1/1] quit
# Create isolation groups 1 and 2.
[DeviceA] port-isolate group 1
[DeviceA-port-isolate-group1] quit
[DeviceA] port-isolate group 2
[DeviceA-port-isolate-group2] quit
# Assign ports Ten-GigabitEthernet 1/1/2 and Ten-GigabitEthernet 1/1/3 to isolation group 1.
[DeviceA] interface ten-gigabitethernet 1/1/2
[DeviceA-Ten-GigabitEthernet1/1/2] port-isolate enable group 1
[DeviceA-Ten-GigabitEthernet1/1/2] quit
[DeviceA] interface ten-gigabitethernet 1/1/3
[DeviceA-Ten-GigabitEthernet1/1/3] port-isolate enable group 1
[DeviceA-Ten-GigabitEthernet1/1/3] quit
# Assign ports Ten-GigabitEthernet 1/1/4 and Ten-GigabitEthernet 1/1/5 to isolation group 2.
[DeviceA] interface ten-gigabitethernet 1/1/4
[DeviceA-Ten-GigabitEthernet1/1/4] port-isolate enable group 2
[DeviceA-Ten-GigabitEthernet1/1/4] quit
[DeviceA] interface ten-gigabitethernet 1/1/5
[DeviceA-Ten-GigabitEthernet1/1/5] port-isolate enable group 2
[DeviceA-Ten-GigabitEthernet1/1/5] quit
# Display information about all isolation groups.
[DeviceA] display port-isolate group
 Port isolation group information:
 Group ID: 1
 Group members:
    Ten-GigabitEthernet1/1/2     Ten-GigabitEthernet1/1/3
 Community VLAN ID: None
 Group ID: 2
 Group members:
    Ten-GigabitEthernet1/1/4     Ten-GigabitEthernet1/1/5
The output shows that:
·     Ports Ten-GigabitEthernet 1/1/2 and Ten-GigabitEthernet 1/1/3 are in isolation group 1. As a result, Host A and Host B are isolated from each other at Layer 2.
·     Ports Ten-GigabitEthernet 1/1/4 and Ten-GigabitEthernet 1/1/4 are in isolation group 2. As a result, Host C and Host D are isolated from each other at Layer 2.
Configuration files
vlan 2 to 3
interface Ten-GigabitEthernet1/1/1
 port link-mode bridge
 port trunk permit vlan 1 to 3
interface Ten-GigabitEthernet1/1/2
 port access vlan 2
interface Ten-GigabitEthernet1/1/3
 port access vlan 2
interface Ten-GigabitEthernet1/1/4
 port access vlan 3
interface Ten-GigabitEthernet1/1/5
 port access vlan 3
Related documentation
·     H3C S7500E-XS Switch Series Layer 2—LAN Switching Configuration Guide-R7536P05
·     H3C S7500E-XS Switch Series Layer 2—LAN Switching Command Reference-R7536P05
