03-Layer 2 - LAN Switching Configuration Examples
HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-XS Switch Series Configuration Examples-R7536P05-6W10003-Layer 2 - LAN Switching Configuration Examples
02-H3C_Ethernet_Link_Aggregation_Configuration_Examples
H3C Ethernet Link Aggregation
H3C_彩色.emf
Introduction
This document provides Ethernet link aggregation configuration examples.
This document assumes that you have basic knowledge of Ethernet link aggregation.
Example: Configuring Layer 2 link aggregation
As shown in Figure 1, both Device A and Device B forward traffic from VLAN 10 and VLAN 20.
Configure link aggregation on Device A and Device B to meet the following requirements:
·     VLAN 10 on Device A can communicate with VLAN 10 on Device B.
·     VLAN 20 on Device A can communicate with VLAN 20 on Device B.
Figure 1 Network diagram
Analysis
To enable traffic from VLAN 10 and VLAN 20 to pass through Layer 2 aggregate interface Bridge-aggregation 1, perform the following tasks:
·     Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
·     Assign the aggregate interface to VLAN 10 and VLAN 20.
Software version used
This configuration example was created and verified on S7500EXS-CMW710-R7536P05.
When you configure Layer 2 link aggregation, follow these restrictions and guidelines:
·     When you assign a port to an aggregation group, the recommended configuration procedure is as follows:
a.     Use the display this command in interface view to check the following attribute configurations of the port:
-     Port isolation.
-     QinQ.
-     VLAN.
-     VLAN mapping.
b.     If any of the above configurations exist, use the undo forms of the corresponding commands to remove these configurations. This enables the port to use the default attribute configurations.
c.     Assign the port to the aggregation group.
·     An aggregation group can operate in static or dynamic mode. You can choose one mode as required.
¡     In a static aggregation group, the aggregation states of the member ports are not affected by the peer ports. Static link aggregation is stable.
¡     In a dynamic aggregation group, the local system and the peer system automatically maintain the aggregation states of the member ports. Dynamic link aggregation reduces the administrators' workload.
·     In a static aggregation group, the Selected state of a port is not affected by whether the peer port is added to an aggregation group and is Selected. As a result, the Selected state of a port might be different from the Selected state of the peer port. When both ends support static aggregation and dynamic aggregation, H3C recommends using dynamic aggregation.
·     You cannot assign a port to a Layer 2 aggregation group when MAC authentication, port security mode, or 802.1X is configured or enabled on the port.
Procedures
1.     Configure Device A:
# Create VLAN 10, and assign port Ten-GigabitEthernet 1/1/4 to VLAN 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port ten-gigabitethernet 1/1/4
[DeviceA-vlan10] quit
# Create VLAN 20, and assign port Ten-GigabitEthernet 1/1/5 to VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] port ten-gigabitethernet 1/1/5
[DeviceA-vlan20] quit
# Create Layer 2 aggregate interface Bridge-aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA] interface bridge-aggregation 1
[DeviceA-Bridge-Aggregation1] quit
¡     Use the dynamic aggregation mode to create Layer 2 aggregate interface Bridge-aggregation 1.
[DeviceA-Bridge-Aggregation1] link-aggregation mode dynamic
# Assign ports Ten-GigabitEthernet 1/1/1 through Ten-GigabitEthernet 1/1/3 to aggregation group 1.
[DeviceA] interface range ten-gigabitethernet 1/1/1 to ten-gigabitethernet 1/1/3
[DeviceA-if-range] port link-aggregation group 1
[DeviceA-if-range] quit
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as a trunk port.
[DeviceA-Bridge-Aggregation1] port link-type trunk
 Configuring Ten-GigabitEthernet1/1/1 done.
 Configuring Ten-GigabitEthernet1/1/2 done.
 Configuring Ten-GigabitEthernet1/1/3 done.
# Assign the aggregate interface to VLANs 10 and 20.
[DeviceA-Bridge-Aggregation1] port trunk permit vlan 10 20
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
# Display detailed information about the link aggregation groups on Device A.
·     Link aggregation configuration information when the static aggregation mode is used:
[DeviceA] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation Interface: Bridge-Aggregation1
Aggregation Mode: Static
Management VLANs: None
  Port             Status  Priority  Oper-Key
  XGE1/1/1(R)      S       32768     1
  XGE1/1/2         S       32768     1
  XGE1/1/3         S       32768     1
The output shows that all member ports in the local aggregation group are in the Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
·     Link aggregation configuration information when the dynamic aggregation mode is used:
Aggregation Mode: Dynamic
System ID: 0x8000, 000f-e234-5678
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  XGE1/1/1            S        32768    2        1                      {ACDEF}
  XGE1/1/2            S        32768    3        1                      {ACDEF}
  XGE1/1/3            S        32768    4        1                      {ACDEF}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  XGE1/1/1(R)         32768    2        1        0x8000, a4e5-c316-0100 {ACDEF}
  XGE1/1/2            32768    3        1        0x8000, a4e5-c316-0100 {ACDEF}
  XGE1/1/3            32768    4        1        0x8000, a4e5-c316-0100 {ACDEF}
The output shows that the local member ports and the corresponding peer member ports are all Selected. In the dynamic link aggregation mode, each local member port and its peer member port have the same Selected state through exchanging LACPDUs. The user data traffic can be forwarded correctly.
Configuration files
·     Device A:
vlan 10
interface Ten-GigabitEthernet1/1/4
 port link-mode bridge
 port access vlan 10
vlan 20
interface Ten-GigabitEthernet1/1/5
 port access vlan 20
¡     In the static aggregation mode:
interface Bridge-Aggregation1
¡     In the dynamic aggregation mode:
interface Ten-GigabitEthernet1/1/1
interface Ten-GigabitEthernet1/1/2
interface Ten-GigabitEthernet1/1/3
·     Device B:
The configuration file on Device B is the same as the configuration file on Device A.
Example: Configuring Layer 3 link aggregation
On the network as shown in Figure 2, perform the following tasks:
·     Configure a Layer 3 dynamic aggregation group on both Device A and Device B.
·     Configure IP addresses and subnet masks for the corresponding Layer 3 aggregate interfaces.
Figure 2 Network diagram
·     In a static aggregation group, the aggregation states of the member ports are not affected by the peer ports. Static link aggregation is stable.
·     In a dynamic aggregation group, the local system and the peer system automatically maintain the aggregation states of the member ports. Dynamic link aggregation reduces the administrators' workload.
Procedures
# Create Layer 3 aggregate interface Route-Aggregation 1. Use one of the following methods as needed.
¡     Use the static aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA] interface route-aggregation 1
¡     Use the dynamic aggregation mode to create Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] link-aggregation mode dynamic
# Configure an IP address and subnet mask for Layer 3 aggregate interface Route-Aggregation 1.
[DeviceA-Route-Aggregation1] ip address 192.168.1.1 24
[DeviceA-Route-Aggregation1] quit
[DeviceA-if-range] port link-mode route
  XGE1/1/2         S       32768    1
  XGE1/1/3         S       32768    1
The output shows that all member ports in the local aggregation group are in Selected state. The Selected states of the local member ports are not affected by the Selected states of the peer member ports.
Local:
  XGE1/1/1(R)         S        32768    2        1                      {ACDEF}
Remote:
  XGE1/1/1            32768    2        1        0x8000, 68fa-34f2-0200 {ACDEF}
  XGE1/1/2            32768    3        1        0x8000, 68fa-34f2-0200 {ACDEF}
  XGE1/1/3            32768    4        1        0x8000, 68fa-34f2-0200 {ACDEF}
Configuration files
·     Device A:
interface route-aggregation1
·     Device B:
The configuration file on Device B is similar as the configuration file on Device A.
Related documentation
·     H3C S7500E-XS Switch Series Layer 2—LAN Switching Configuration Guide-Release R7536P05
·     H3C S7500E-XS Switch Series Layer 2—LAN Switching Command Reference-Release R7536P05
