05-Layer 3 - IP Routing Configuration Examples
HomeSupportSwitchesH3C S7500E Switch SeriesConfigure & DeployConfiguration ExamplesH3C S7500E Switch Series Configuration Examples-R7536P05-6W10005-Layer 3 - IP Routing Configuration Examples
03-H3C_IPv6_IS-IS_Configuration_Examples
03-H3C_IPv6_IS-IS_Configuration_Examples 97.80 KB
H3C IPv6 IS-IS Configuration Examples
H3C_彩色.emf
Introduction
This document provides IPv6 IS-IS configuration examples.
This document assumes that you have basic knowledge of IPv6 IS-IS.
Example: Configuring IPv6 IS-IS
As shown in Figure 1, the company's headquarters and the branch run IPv6 IS-IS. The partner runs OSPFv3.
Configure the switches to meet the following requirements:
·     Reduce traffic for Switch A and Switch B because they have relative low performance.
·     The Marketing department can reach the Finance department, the branch, and the partner.
·     The Finance department and the branch cannot reach each other, and the branch does not have a route to the Finance department.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To reduce traffic for Switch A and Switch B, configure them as Level-1 routers to allow communication only between the Marketing department and the Finance department.
·     Configure route redistribution between IPv6 IS-IS and OSPFv3 on Switch D to allow communication between the Marketing department and the partner.
·     Configure Switch C to use a prefix list to advertise only network 3001:1::/64 to Level-2, so that the branch does not have a route to the Finance department.
Software versions used
This configuration example was created and verified on S7500E-CMW710-R7536P05.
Procedures
Configuring Switch A
# Configure an IPv6 address for VLAN-interface 11.
[SwitchA-Vlan-interface11] ipv6 address 2001:1::1 64
# Configure IPv6 addresses for other interfaces, as shown in Figure 1. (Details not shown.)
# Configure IPv6 IS-IS.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.3001.0001.0001.00
[SwitchA-isis-1] address-family ipv6
[SwitchA-isis-1-ipv6] quit
[SwitchA-isis-1] quit
[SwitchA–vlan-interface 11] isis ipv6 enable 1
[SwitchA–vlan-interface 11] quit
[SwitchA–Vlan-interface100] isis ipv6 enable 1
[SwitchA–Vlan-interface100] quit
Configuring Switch B
# Configure an IPv6 address for VLAN-interface 12.
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ipv6 address 2001:2::1 64
[SwitchB-Vlan-interface12] quit
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.3001.0002.0001.00
[SwitchB-isis-1] address-family ipv6
[SwitchB-isis-1-ipv6] quit
[SwitchB-isis-1] quit
[SwitchB–Vlan-interface12] isis ipv6 enable 1
[SwitchB–Vlan-interface12] quit
[SwitchB–Vlan-interface 200] isis ipv6 enable 1
[SwitchB–Vlan-interface 200] quit
Configuring Switch C
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] ipv6 address 2001:1::2 64
[SwitchC-Vlan-interface11] quit
[SwitchC] isis 1
[SwitchC-isis-1] is-level level-1
[SwitchC-isis-1] network-entity 10.2001.0010.0001.00
[SwitchC-isis-1] address-family ipv6
[SwitchC-isis-1-ipv6] quit
[SwitchC-isis-1] quit
[SwitchC] interface vlan-interface 10
[SwitchC–Vlan-interface10] isis ipv6 enable 1
[SwitchC–Vlan-interface10] quit
[SwitchC–Vlan-interface11] isis ipv6 enable 1
[SwitchC–Vlan-interface11] quit
[SwitchC] interface vlan-interface 12
[SwitchC–Vlan-interface12] isis ipv6 enable 1
[SwitchC–Vlan-interface12] quit
# Configure route leaking from Level-1 to Level-2, and use prefix list 1 to advertise only network 3001:1::/64 to Level-2.
[SwitchC] ipv6 prefix-list 1 permit 3001:1:: 64
[SwitchC] isis 1
[SwitchC] address-family ipv6
[SwitchC-isis-1-ipv6] import-route isisv6 level-1 into level-2 filter-policy prefix-list 1
Configuring Switch D
# Configure an IPv6 address for VLAN-interface 10.
<SwitchD> system-view
[SwitchD] interface vlan-interface 10
[SwitchD- Vlan-interface10] ipv6 address 2001:10::2 64
[SwitchD- Vlan-interface10] quit
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.2001.0020.0001.00
[SwitchD-isis-1] address-family ipv6
[SwitchD-isis-1-ipv6] quit
[SwitchD-isis-1] quit
[SwitchD–Vlan-interface10] isis ipv6 enable 1
[SwitchD–Vlan-interface10] quit
[SwitchD] interface vlan-interface 20
[SwitchD–Vlan-interface20] isis ipv6 enable 1
[SwitchD–Vlan-interface20] quit
# Configure OSPFv3.
[SwitchD] ospfv3
[SwitchD-ospfv3-1] router-id 4.4.4.4
[SwitchD-ospfv3-1] quit
[SwitchD–Vlan-interface20] ospfv3 1 area 0
# Redistribute OSPFv3 and direct routes into IPv6 IS-IS.
[SwitchD] isis 1
[SwitchD] address-family ipv6
[SwitchD-isis-1-ipv6] import-route ospfv3
[SwitchD-isis-1-ipv6] import-route direct
# Redistribute IPv6 IS-IS and direct routes into OSPFv3.
[SwitchD] ospfv3 1
[SwitchD-ospfv3-1] import-route isisv6 1
[SwitchD-ospfv3-1] import-route direct
Configuring Switch E
# Configure an IPv6 address for VLAN-interface 20.
<SwitchE> system-view
[SwitchE] interface vlan-interface20
[SwitchE-Vlan-interface12] ipv6 address 2001:20::2 64
[SwitchE-Vlan-interface12] quit
# Configure OSPFv3.
[SwitchE] ospfv3
[SwitchE-ospfv3-1] router-id 5.5.5.5
[SwitchE-ospfv3-1] quit
[SwitchE] interface vlan-interface 20
[SwitchE–Vlan-interface 20] ospfv3 1 area 0
[SwitchE–Vlan-interface 20] quit
[SwitchE] interface vlan-interface 300
[SwitchE–Vlan-interface 300] ospfv3 1 area 0
[SwitchE–Vlan-interface 300] quit
# Verify that the branch can reach the Marketing department, but cannot reach the Finance department.
[SwitchD] display isis route ipv6
                         Level-2 IPv6 Forwarding Table
 Destination : 2001:10::                               PrefixLen: 64
 Flag        : D/L/-                                   Cost     : 10
 Next Hop    : Direct                                  Interface: Vlan10
 Destination : 2001:1::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 20
 Next Hop    : FE80::7625:8AFF:FE02:4D13               Interface: Vlan10
 Destination : 2001:2::                                PrefixLen: 64
 Destination : 3001:1::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 30
# Verify that the company can communicate with the partner.
·     Display the IPv6 IS-IS routing table on Switch C.
[SwitchC] display isis route ipv6 level-2
 Next Hop    : Direct                                  Interface: Vlan11
 Next Hop    : Direct                                  Interface: Vlan12
 Destination : 2001:20::                               PrefixLen: 64
 Flag        : R/L/-                                   Cost     : 20
 Next Hop    : FE80::BAAF:67FF:FE30:3304               Interface: Vlan10
 Destination : 3001:200::                              PrefixLen: 64
·     Ping 3001:200::1 from the interface VLAN-interface 100 on Switch A.
[SwitchA] ping ipv6 –a 3001:1::1 3001:200::1
Ping6(56 data bytes) 2001:10::1 --> 3001:200::1, press CTRL_C to break
56 bytes from 3001:200::1, icmp_seq=0 hlim=61 time=7.230 ms
56 bytes from 3001:200::1, icmp_seq=1 hlim=61 time=3.449 ms
56 bytes from 3001:200::1, icmp_seq=2 hlim=61 time=2.779 ms
56 bytes from 3001:200::1, icmp_seq=3 hlim=61 time=2.652 ms
56 bytes from 3001:200::1, icmp_seq=4 hlim=61 time=2.558 ms
--- Ping6 statistics for 3001:200::1 ---
round-trip min/avg/max/std-dev = 2.558/3.734/7.230/1.776 ms
Configuration files
·     Switch A:
isis 1
 is-level level-1
 address-family ipv6 unicast
vlan 11
vlan 100
interface Vlan-interface11
 isis ipv6 enable 1
 ipv6 address 2001:1::1/64
interface Vlan-interface100
 isis ipv6 enable 1
 ipv6 address 3001:1::1/64
·     Switch B:
isis 1
 is-level level-1
vlan 12
vlan 200
interface Vlan-interface12
 isis ipv6 enable 1
 ipv6 address 2001:2::1/64
interface Vlan-interface200
 isis ipv6 enable 1
 ipv6 address 3001:2::1/64
·     Switch C:
isis 1
vlan 11 to 13
 isis ipv6 enable 1
 ipv6 address 2001:1::2/64
 isis ipv6 enable 1
 ipv6 address 2001:2::2/64
interface Vlan-interface13
 isis ipv6 enable 1
 ipv6 address 2001:10::1/64
 ipv6 prefix-list 1 index 10 permit 3001:1:: 64
·     Switch D:
isis 1
 is-level level-2
  import-route direct
  import-route ospfv3 1
ospfv3 1
 router-id 4.4.4.4
 area 0.0.0.0
 import-route direct
vlan 10
vlan 20
 isis ipv6 enable 1
 ipv6 address 2001:10::2/64
 ospfv3 1 area 0.0.0.0
 ipv6 address 2001:20::1/64
·     Switch E:
ospfv3 1
 router-id 5.5.5.5
 area 0.0.0.0
vlan 20
vlan 300
 ospfv3 1 area 0
 ipv6 address 2001:20::2/64
interface Vlan-interface300
 ospfv3 1 area 0
 ipv6 address 3001:200::1/64
Related documentation
·     H3C S7500E Switch Series Layer 3IP Routing Command Reference-R7536P05
·     H3C S7500E Switch Series Layer 3IP Routing Configuration Guide-R7536P05
