06-IP Multicast Configuration Examples
HomeSupportSwitchesH3C S10500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C S10500 Switch Series Configuration Examples-Release7536P05-6W10006-IP Multicast Configuration Examples
06-H3C_S10500_IPv6_Multicast_VLAN_Configuration_Examples
H3C IPv6 Multicast VLAN Configuration Examples
H3C_彩色.emf
Introduction
This document provides IPv6 multicast VLAN configuration examples.
This document assumes that you have basic knowledge of IPv6 multicast VLAN.
Example: Configuring sub-VLAN-based IPv6 multicast VLANs
As shown in Figure 1:
·     VLAN 10 and VLAN 20 are Department 1 and Department 2, respectively.
·     VLAN-interface 10 and VLAN-interface 20 on Layer 3 device Switch A are the gateways of VLAN 10 and VLAN 20, respectively.
·     MLDv1 runs in VLAN 10 on Switch A, and MLDv1 snooping runs in VLAN 10 on Layer 2 device Switch B.
·     Source sends IPv6 multicast data to IPv6 multicast group FF1E::101.
·     Host A and Host B in VLAN 10 join the group FF1E::101. They can receive the IPv6 multicast data that Source sends to the group.
Figure 1 Network diagram
Now, Host C and Host D in VLAN 20 also join the group to receive the IPv6 multicast data, as shown in Figure 2. To meet the requirement, you can enable MLDv1 for VLAN 20 on Switch A and MLDv1 snooping for VLAN 20 on Switch B. However, this method occupies a large amount of bandwidth and increases the burden on Switch A.
To avoid the problems, you can configure a sub-VLAN-based IPv6 multicast VLAN on Switch B.
Figure 2 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     Create VLAN 30 on Switch A and Switch B, and assign Ten-GigabitEthernet 1/0/1 on them to VLAN 10 through VLAN 30 as tagged VLAN members.
·     Create VLAN-interface 30 on Switch A, and enable MLD on the interface.
·     Enable MLD snooping for VLAN 10 through VLAN 30 on Switch B.
·     Configure VLAN 30 on Switch B as an IPv6 multicast VLAN, and assign VLAN 10 and VLAN 20 to IPv6 multicast VLAN 30 as sub-VLANs.
Software versions used
This configuration example was created and verified on S10500-CMW710-R7536P05.
When you configure sub-VLAN-based IPv6 multicast VLANs, follow these restrictions and guidelines:
·     As a best practice, do not configure IPv6 multicast VLANs on the device that is enabled with IPv6 multicast routing.
·     The IPv6 address assigned to the VLAN interface of the IPv6 multicast VLAN must be unique on the user network.
Procedures
1.     Assign IPv6 addresses to VLAN-interface 10 and VLAN-interface 20 on Switch A. (Details not shown.)
2.     Configure a unicast routing protocol so that all devices on the network can interoperate at the network layer. (Details not shown.)
3.     Configure Switch A:
# Enable IPv6 multicast routing.
[SwitchA-mrib6] quit
# Create VLAN 30, configure Ten-GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLAN 10 through VLAN 30 as a tagged VLAN member.
[SwitchA] vlan 30
[SwitchA-vlan30] quit
[SwitchA] interface ten-gigabitethernet 1/0/1
[SwitchA-Ten-GigabitEthernet1/0/1] port link-type hybrid
[SwitchA-Ten-GigabitEthernet1/0/1] port hybrid vlan 10 20 30 tagged
# Create VLAN-interface 30, assign it an IPv6 address, and enable MLD on it.
[SwitchA] interface vlan-interface 30
[SwitchA-Vlan-interface30] ipv6 address 2001::1 64
[SwitchA-Vlan-interface30] mld enable
[SwitchA-Vlan-interface30] quit
# Create VLAN 40, and assign Ten-GigabitEthernet 1/0/2 to VLAN 40.
[SwitchA] vlan 40
[SwitchA-vlan40] port ten-gigabitethernet 1/0/2
[SwitchA-vlan40] quit
# Create VLAN-interface 40, assign it an IPv6 address, and enable IPv6 PIM-DM on it.
[SwitchA] interface vlan-interface 40
[SwitchA-Vlan-interface40] ipv6 address 1::1 64
[SwitchA-Vlan-interface40] ipv6 pim dm
[SwitchA-Vlan-interface40] quit
4.     Configure Switch B:
# Enable MLD snooping globally.
[SwitchB] mld-snooping
[SwitchB-mld-snooping] quit
# Create VLAN 10, and enable MLD snooping for VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] mld-snooping enable
[SwitchB-vlan10] quit
# Create VLAN 20, and enable MLD snooping for VLAN 20.
[SwitchB] vlan 20
[SwitchB-vlan20] mld-snooping enable
[SwitchB-vlan20] quit
# Create VLAN 30, and enable MLD snooping for VLAN 30.
[SwitchB] vlan 30
[SwitchB-vlan30] mld-snooping enable
[SwitchB-vlan30] quit
# Configure Ten-GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLAN 10 through VLAN 30 as a tagged VLAN member.
[SwitchB] interface ten-gigabitethernet 1/0/1
[SwitchB-Ten-GigabitEthernet1/0/1] port link-type hybrid
# Configure VLAN 30 as an IPv6 multicast VLAN, and assign VLAN 10 and VLAN 20 to IPv6 multicast VLAN 30 as sub-VLANs.
[SwitchB] ipv6 multicast-vlan 30
[SwitchB-ipv6-mvlan-30] subvlan 10 20
[SwitchB-ipv6-mvlan-30] quit
# Display information about all IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan
Total 1 IPv6 multicast VLANs.
IPv6 multicast VLAN 30:
  Sub-VLAN list(2 in total):
     10,20
  Port list(0 in total):
# Display information about multicast groups in IPv6 multicast VLANs on Switch B.
[SwitchB] display ipv6 multicast-vlan group
Total 1 entries.
IPv6 multicast VLAN 30: Total 1 entries.
  (::, FF1E::101)
    Sub-VLANs (2 in total):
      VLAN 10
      VLAN 20
The output shows that IPv6 multicast VLAN (VLAN 30) contains sub-VLANs VLAN 10 and VLAN 20. Switch B will forward IPv6 multicast data for VLAN 30 to VLAN 10 and VLAN 20.
Configuration files
·     Switch A:
vlan 10
vlan 20
vlan 30
vlan 40
interface Vlan-interface10
 ipv6 address 2002::1/64
interface Vlan-interface20
 ipv6 address 2003::1/64
interface Vlan-interface30
 ipv6 address 2001::1/64
 mld enable
interface Vlan-interface40
 ipv6 address 1::1/64
 ipv6 pim dm
 port link-mode bridge
 port hybrid vlan 1 untagged
port access vlan 40
·     Switch B:
mld-snooping
vlan 10
 mld-snooping enable
vlan 20
 mld-snooping enable
vlan 30
 mld-snooping enable
 subvlan 10 20
 port access vlan 10
 port access vlan 10
interface Ten-GigabitEthernet1/0/4
 port access vlan 20
interface Ten-GigabitEthernet1/0/5
 port access vlan 20
Example: Configuring port-based IPv6 multicast VLANs
As shown in Figure 3:
Figure 3 Network diagram
Now, Host C and Host D in VLAN 20 also join the group to receive the IPv6 multicast data, as shown in Figure 4. To meet the requirement, you can enable MLDv1 for VLAN 20 on Switch A and MLDv1 snooping for VLAN 20 on Switch B. However, this method occupies a large amount of bandwidth and increases the burden on Switch A.
To avoid the problems, you can configure a port-based IPv6 multicast VLAN on Switch B.
Figure 4 Network diagram
Analysis
·     On Switch B, configure the ports that have receiver hosts attached as hybrid ports, and assign the ports to their port VLAN IDs and VLAN 30 as untagged VLAN members.
·     On Switch B, configure VLAN 30 as an IPv6 multicast VLAN, and assign the ports that have receiver hosts attached to IPv6 multicast VLAN 30.
When you configure port-based IPv6 multicast VLANs, follow these restrictions and guidelines:
·     As a best practice, do not configure IPv6 multicast VLANs on a device that is enabled with IPv6 multicast routing.
·     A port can belong to only one IPv6 multicast VLAN.
Procedures
# Create VLAN 30, configure Ten-GigabitEthernet 1/0/1 as a hybrid port, and assign it to VLAN 10 through 30 as a tagged VLAN member.
[SwitchA] vlan 30
[SwitchA] vlan 40
[SwitchB] vlan 10
[SwitchB] vlan 20
[SwitchB] vlan 30
# Configure Ten-GigabitEthernet 1/0/2 as a hybrid port.
[SwitchB] interface ten-gigabitethernet 1/0/2
[SwitchB-Ten-GigabitEthernet1/0/2] port link-type hybrid
# Configure the PVID of Ten-GigabitEthernet 1/0/2 to be VLAN 10, and assign the port to VLAN 10 and VLAN 30 as an untagged VLAN member.
[SwitchB-Ten-GigabitEthernet1/0/2] port hybrid pvid vlan 10
[SwitchB-Ten-GigabitEthernet1/0/2] port hybrid vlan 10 30 untagged
[SwitchB-Ten-GigabitEthernet1/0/2] quit
# Configure Ten-GigabitEthernet 1/0/3 as a hybrid port.
[SwitchB] interface ten-gigabitethernet 1/0/3
[SwitchB-Ten-GigabitEthernet1/0/3] port link-type hybrid
# Configure the PVID of the Ten-GigabitEthernet 1/0/3 to be VLAN 10, and assign the port to VLAN 10 and VLAN 30 as an untagged VLAN member.
[SwitchB-Ten-GigabitEthernet1/0/3] port hybrid pvid vlan 10
[SwitchB-Ten-GigabitEthernet1/0/3] port hybrid vlan 10 30 untagged
[SwitchB-Ten-GigabitEthernet1/0/3] quit
# Configure Ten-GigabitEthernet 1/0/4 as a hybrid port.
[SwitchB] interface ten-gigabitethernet 1/0/4
[SwitchB-Ten-GigabitEthernet1/0/4] port link-type hybrid
# Configure the PVID of Ten-GigabitEthernet 1/0/4 to be VLAN 20, and assign the port to VLAN 20 and VLAN 30 as an untagged VLAN member.
[SwitchB-Ten-GigabitEthernet1/0/4] port hybrid pvid vlan 20
[SwitchB-Ten-GigabitEthernet1/0/4] port hybrid vlan 20 30 untagged
[SwitchB-Ten-GigabitEthernet1/0/4] quit
# Configure Ten-GigabitEthernet 1/0/5 as a hybrid port.
[SwitchB] interface ten-gigabitethernet 1/0/5
[SwitchB-Ten-GigabitEthernet1/0/5] port link-type hybrid
# Configure the PVID of Ten-GigabitEthernet 1/0/5 to be VLAN 20, and assign the port to VLAN 20 and VLAN 30 as an untagged VLAN member
[SwitchB-Ten-GigabitEthernet1/0/5] port hybrid pvid vlan 20
[SwitchB-Ten-GigabitEthernet1/0/5] port hybrid vlan 20 30 untagged
[SwitchB-Ten-GigabitEthernet1/0/5] quit
5.     Configure VLAN 30 as an IPv6 multicast VLAN, and assign Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/5 to IPv6 multicast VLAN 30.
[SwitchB-ipv6-mvlan-30] port ten-gigabitethernet 1/0/2 to ten-gigabitethernet 1/0/5
# Display information about IPv6 multicast VLANs on Switch B.
  Sub-VLAN list(0 in total):
  Port list(4 in total):
    XGE1/0/2
    XGE1/0/3
    XGE1/0/4
    XGE1/0/5
# Display information about IPv6 multicast groups in IPv6 multicast VLANs.
[SwitchB] display mld-snooping group
Total 1 entries.
  (::, FF1E::101)
    Host slots (0 in total):
    Host ports (4 in total):
      XGE1/0/2         (00:03:23)
      XGE1/0/3         (00:04:07)
      XGE1/0/4         (00:04:16)
      XGE1/0/5         (00:05:10)
The output shows that MLD snooping maintains the user ports in the multicast VLAN (VLAN 30). Switch B will forward the IPv6 multicast data of VLAN 10 through these user ports.
Configuration files
·     Switch A:
vlan 10
vlan 20
vlan 30
vlan 40
 mld enable
 ipv6 pim dm
port access vlan 40
·     Switch B:
mld-snooping
vlan 10
 mld-snooping enable
vlan 20
 mld-snooping enable
vlan 30
 mld-snooping enable
ipv6 port multicast-vlan 30
Related documentation
·     H3C S10500 Switch Series IP Multicast Configuration Guide-R7536P05
·     H3C S10500 Switch Series IP Multicast Command Reference-R7536P05
