- 06-IP Multicast Configuration Examples
- 01-H3C_S10500_Static_Multicast_MAC_Address_Entry_Configuration_Examples
- 02-H3C_S10500_IGMP_Snooping_Configuration_Examples
- 03-H3C_S10500_IGMP_Configuration_Examples
- 04-H3C_S10500_BIDIR-PIM_Configuration_Examples
- 05-H3C_S10500_MLD_Snooping_Configuration_Exampels
- 06-H3C_S10500_IPv6_Multicast_VLAN_Configuration_Examples
04-H3C_S10500_BIDIR-PIM_Configuration_Examples | 79.16 KB |
H3C BIDIR-PIM Configuration Examples
Copyright © 2017 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Introduction
This document introduces BIDIR-PIM configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of BIDIR-PIM.
Example: Configuring BIDIR-PIM
As shown in Figure 1:
· Switch A, Switch B, and Switch C run OSPF.
· Source 1 and Source 2 send multicast data to multicast group 225.1.1.1.
· Host A and Host B are member hosts of multicast group 225.1.1.1.
Configure BIDIR-PIM on the switches to implement multicast forwarding.
Device |
IP address |
Device |
IP address |
Switch A |
VLAN-interface 100 |
10.10.1.1/24 |
Switch C |
VLAN-interface 102 |
10.102.1.1/24 |
Switch A |
VLAN-interface 12 |
10.12.1.1/24 |
Switch C |
VLAN-interface 13 |
10.13.1.3/24 |
Switch A |
VLAN-interface 13 |
10.13.1.1/24 |
Switch C |
VLAN-interface 23 |
10.23.1.3/24 |
Switch B |
VLAN-interface 101 |
10.101.1.1/24 |
Switch C |
VLAN-interface 33 |
Switch B |
VLAN-interface 12 |
10.12.1.2/24 |
Source 1 |
10.10.1.2/24 |
Switch B |
VLAN-interface 23 |
10.23.1.2/24 |
Source 2 |
10.33.1.4/24 |
Analysis
To meet the network requirements, perform the following tasks:
· To establish the bidirectional RPT, configure VLAN-interface 12 on Switch A as a C-RP.
· To use the BSR mechanism to dynamically elect the RP, configure VLAN-interface 12 on Switch A as a C-BSR.
· To avoid multicast forwarding interruption when the RP fails, specify the unused IP address 10.13.1.4/24 as the static RP. In this way, the link on the subnet 10.13.1.0/24 becomes the RPL. Switch A and Switch C on the link function as the RPs.
Software versions used
This configuration example was created and verified on S10500-CMW710-R7536P05.
When you configure BIDIR-PIM, follow these restrictions and guidelines:
· Enable the same PIM mode on the interfaces that belong to the same VPN instance on each switch.
· Configure the same static RP on all the switches in the BIDIR-PIM domain.
· Enable PIM-SM for all interfaces on the switches in the BIDIR-PIM domain.
· Enable IGMP for the interfaces that connect to the stub networks on all the switches in the BIDIR-PIM domain.
Procedures
Configure Switch A
1. Enable IP multicast routing.
[SwitchA] multicast routing
[SwitchA-mrib] quit
2. Configure each interface and enable PIM-SM.
# Create VLAN 100, and assign GigabitEthernet 3/0/1 to this VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 3/0/1
[SwitchA-vlan100] quit
# Assign an IP address to VLAN-interface 100, and enable PIM-SM on the interface.
[SwitchA-Vlan-interface100] ip address 10.10.1.1 24
# Create VLAN 12, and assign GigabitEthernet 3/0/2 to the VLAN.
[SwitchA] vlan 12
[SwitchA-vlan12] port gigabitethernet 3/0/2
[SwitchA-vlan12] quit
# Assign an IP address to VLAN-interface 12, and enable PIM-SM on the interface.
[SwitchA-vlan12] interface vlan-interface 12
[SwitchA-Vlan-interface12] ip address 10.12.1.1 24
[SwitchA-Vlan-interface12] pim sm
[SwitchA-Vlan-interface12] quit
# Create VLAN 13, and assign GigabitEthernet 3/0/3 to the VLAN.
[SwitchA] vlan 13
[SwitchA-vlan13] port gigabitethernet 3/0/3
[SwitchA-vlan13] quit
# Assign an IP address to VLAN-interface 13, and enable PIM-SM on the interface.
[SwitchA] interface vlan-interface 13
[SwitchA-Vlan-interface13] ip address 10.13.1.1 24
[SwitchA-Vlan-interface13] pim sm
[SwitchA-Vlan-interface13] quit
3. Configure a C-RP, a C-BSR, and the static RP.
# Configure VLAN-interface 12 as a C-BSR and a C-RP.
[SwitchA] pim
[SwitchA-pim] c-bsr 10.12.1.1
[SwitchA-pim] c-rp 10.12.1.1 bidir
# Specify the unused IP address 10.13.1.4 as the static RP.
[SwitchA-pim] static-rp 10.13.1.4 bidir
4. Enable BIDIR-PIM.
[SwitchA-pim] bidir-pim enable
[SwitchA-pim] quit
5. Configure OSPF.
[SwitchA] ospf 1
[SwitchA-ospf-1] import-route direct
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchA-ospf-1] quit
Configure Switch B
[SwitchB] multicast routing
[SwitchB-mrib] quit
# Create VLAN 12, and assign GigabitEthernet 3/0/2 to this VLAN.
[SwitchB] vlan 12
[SwitchB-vlan12] port gigabitethernet 3/0/2
[SwitchB-vlan12] quit
[SwitchB] interface vlan-interface 12
[SwitchB-Vlan-interface12] ip address 10.12.1.2 24
[SwitchB-Vlan-interface12] pim sm
[SwitchB-Vlan-interface12] quit
# Create VLAN 23, and assign GigabitEthernet 3/0/3 to this VLAN.
[SwitchB] vlan 23
[SwitchB-vlan23] port gigabitethernet 3/0/3
[SwitchB-vlan23] quit
# Assign an IP address to VLAN-interface 23, and enable PIM-SM on the interface.
[SwitchB] interface vlan-interface 23
[SwitchB-Vlan-interface23] ip address 10.23.1.2 24
[SwitchB-Vlan-interface23] pim sm
[SwitchB-Vlan-interface23] quit
# Create VLAN 101, and assign GigabitEthernet 3/0/1 to this VLAN.
[SwitchB] vlan 101
[SwitchB-vlan101] port gigabitethernet 3/0/1
[SwitchB-vlan101] quit
# Assign an IP address to VLAN-interface 101, and enable PIM-SM and IGMP on the interface.
[SwitchB-Vlan-interface101] ip address 10.101.1.1 24
[SwitchB-Vlan-interface101] pim sm
[SwitchB-Vlan-interface101] igmp enable
3. Specify the unused IP address 10.13.1.4 as the static RP.
[SwitchB] pim
[SwitchB-pim] static-rp 10.13.1.4 bidir
[SwitchB-pim] bidir-pim enable
[SwitchB-pim] quit
5. Configure OSPF.
[SwitchB] ospf 1
[SwitchB-ospf-1] import-route direct
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchB-ospf-1] quit
Configure Switch C
[SwitchC] multicast routing
[SwitchC-mrib] quit
# Create VLAN 33, and assign GigabitEthernet 3/0/4 to this VLAN.
[SwitchC] vlan 33
[SwitchC-vlan33] port gigabitethernet 3/0/4
[SwitchC-vlan33] quit
# Assign an IP address to VLAN-interface 33, and enable PIM-SM on the interface.
[SwitchC] interface vlan-interface 33
[SwitchC-Vlan-interface33] ip address 10.33.1.3 24
[SwitchC-Vlan-interface33] pim sm
[SwitchC-Vlan-interface33] quit
# Create VLAN 13, and assign GigabitEthernet 3/0/3 to this VLAN.
[SwitchC] vlan 13
[SwitchC-vlan13] port gigabitethernet 3/0/3
[SwitchC-vlan13] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] ip address 10.13.1.3 24
[SwitchC-Vlan-interface13] pim sm
[SwitchC-Vlan-interface13] quit
# Create VLAN 23, and assign GigabitEthernet 3/0/2 to this VLAN.
[SwitchC] vlan 23
[SwitchC-vlan23] port gigabitethernet 3/0/2
[SwitchC-vlan23] quit
[SwitchC] interface vlan-interface 23
[SwitchC-Vlan-interface23] ip address 10.23.1.3 24
[SwitchC-Vlan-interface23] pim sm
[SwitchC-Vlan-interface23] quit
# Create VLAN 102, and assign GigabitEthernet 3/0/1 to this VLAN.
[SwitchC] vlan 102
[SwitchC-vlan102] port gigabitethernet 3/0/1
[SwitchC-vlan102] quit
# Assign an IP address to VLAN-interface 102, and enable PIM-SM and IGMP on the interface.
[SwitchC-Vlan-interface102] ip address 10.102.1.1 24
[SwitchC-Vlan-interface102] igmp enable
[SwitchC] pim
[SwitchC-pim] static-rp 10.13.1.4 bidir
[SwitchC-pim] bidir-pim enable
[SwitchC-pim] quit
5. Configure OSPF.
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 10.0.0.0 0.255.255.255
[SwitchC-ospf-1] quit
1. Verify that Switch A, Switch B, and Switch C have established PIM neighbor relationships.
# Display PIM neighbor information on Switch A.
[SwitchA] display pim neighbor
Total Number of Neighbors = 2
Neighbor Interface Uptime Expires DR-Priority Mode
10.12.1.2 Vlan12 00:02:27 00:01:45 1 B
10.13.1.3 Vlan13 00:02:27 00:01:19 1 B
# Display PIM neighbor information on Switch B.
[SwitchB] display pim neighbor
10.12.1.1 Vlan12 00:03:05 00:01:44 1 B
10.23.1.3 Vlan23 00:13:49 00:01:29 1 B
# Display PIM neighbor information on Switch C.
[SwitchC] display pim neighbor
10.13.1.1 Vlan13 00:03:28 00:01:39 1 B
10.23.1.2 Vlan23 00:14:05 00:01:36 1 B
2. Verify that VLAN-interface 12 on Switch A has been elected as the BSR on each switch.
# Display BSR information on Switch A.
[SwitchA] display pim bsr-info
Scope: non-scoped
State: Elected
Bootstrap timer: 00:01:18
Elected BSR address: 10.12.1.1
Priority: 64
Hash mask length: 30
Uptime: 00:04:01
Candidate BSR address: 10.12.1.1
Priority: 64
# Display BSR information on Switch B.
[SwitchB] display pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:00:26
Priority: 64
Uptime: 00:10:41
# Display BSR information on Switch C.
[SwitchC] display pim bsr-info
Scope: non-scoped
Bootstrap timer: 00:02:08
Priority: 64
Uptime: 00:15:41
3. Verify that VLAN-interface 12 on Switch A has been elected as the RP, and verify that the IP address of the static RP is 10.13.1.4 on each switch.
# Display RP information on Switch A.
[SwitchA] display pim rp-info
BSR RP information:
Scope: non-scoped
Group/MaskLen: 224.0.0.0/4 [B]
RP address Priority HoldTime Uptime Expires
10.12.1.1 (local) 192 150 00:06:01 00:02:58
Static RP information:
RP address ACL Mode Preferred
10.13.1.4 ---- bidir No
# Display RP information on Switch B.
[SwatchB] display pim rp-info
BSR RP information:
Scope: non-scoped
10.12.1.1 192 150 00:06:33 00:02:26
# Display RP information on Switch C.
[SwitchC] display pim rp-info
BSR RP information:
Scope: non-scoped
10.12.1.1 192 150 00:06:51 00:02:05
4. Verify that the DFs have been elected for BIDIR-PIM on each switch.
# Display information about DFs for BIDIR-PIM on Switch A.
[SwitchA] display pim df-info
RP address: 10.12.1.1
Interface State DF-Pref DF-Metric DF-Uptime DF-Address
Vlan100 Win 0 0 00:01:09 10.10.1.1 (local)
Vlan12 - - - - -
Vlan13 Win 0 0 00:01:10 10.13.1.1 (local)
RP address: 10.13.1.4
Vlan100 Win 0 0 00:00:07 10.10.1.1 (local)
Vlan12 Win 0 0 00:00:07 10.12.1.1 (local)
Vlan13 - - - - -
# Display information about DFs for BIDIR-PIM on Switch B.
[SwatchB] display pim df-info
Vlan12 - - - - -
Vlan23 Win 0 0 00:01:46 10.23.1.2 (local)
Vlan101 Win 0 0 00:01:45 10.101.1.1 (local)
Vlan12 Lose 0 0 00:00:44 10.12.1.1
Vlan23 Lose 0 0 00:00:53 10.23.1.3
Vlan101 Win 10 2 00:00:53 10.101.1.1 (local)
# Display information about DFs for BIDIR-PIM on Switch C.
[SwitchC] display pim df-info
Vlan102 Win 10 2 00:02:07 10.102.1.1 (local)
Vlan33 Win 10 2 00:02:06 10.33.1.3 (local)
Vlan13 Lose 0 0 00:02:07 10.13.1.1
Vlan23 Lose 0 0 00:02:07 10.23.1.2
Vlan102 Win 0 0 00:01:24 10.102.1.1 (local)
Vlan33 Win 0 0 00:01:23 10.33.1.3 (local)
Vlan13 - - - - -
Vlan23 Win 0 0 00:01:24 10.23.1.3 (local)
5. Verify that DFs for multicast forwarding are correct on each switch.
# Display information about DFs for multicast forwarding on Switch A.
[SwitchA] display multicast forwarding df-info
Total 2 RPs, 2 matched
00001. RP address: 10.12.1.1
Flags: 0x0
Uptime: 00:02:42
RPF interface: Vlan-interface12
List of 2 DF interfaces:
1: Vlan-interface100
2: Vlan-interface13
00002. RP address: 10.13.1.4
Flags: 0x0
Uptime: 00:01:41
RPF interface: Vlan-interface13
2: Vlan-interface12
# Display information about DFs for multicast forwarding on Switch B.
[SwitchB] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:03:18
1: Vlan-interface23
2: Vlan-interface101
Flags: 0x0
Uptime: 00:02:24
RPF interface: Vlan-interface23
List of 1 DF interfaces:
1: Vlan-interface101
# Display information about DFs for multicast forwarding on Switch C.
[SwitchC] display multicast forwarding df-info
Flags: 0x0
Uptime: 00:03:38
1: Vlan-interface102
2: Vlan-interface33
Flags: 0x0
Uptime: 00:02:41
List of 3 DF interfaces:
1: Vlan-interface33
2: Vlan-interface23
3: Vlan-interface102
6. Send IGMP reports from Host A and Host B to join multicast group 225.1.1.1, and send multicast data from Source 1 and Source 2 to the group. (Details not shown.)
7. Verify that PIM forwarding entries have been correctly established on each switch.
# Display information about PIM routing entries on Switch A.
[SwitchA] display pim routing-table
Total 1 (*, G) entry; 0 (S, G) entry
(*, 225.1.1.1)
RP: 10.12.1.1 (local)
Protocol: pim-bidir, Flag: WC LOC ACT
UpTime: 00:21:59
Upstream interface: Vlan-interface12
Upstream neighbor: NULL
RPF prime neighbor: NULL
1: Vlan-interface12
Protocol: pim-bidir, UpTime: 00:21:59, Expires: -
2: Vlan-interface13
Protocol: pim-bidir, UpTime: 00:03:26, Expires: -
# Display information about PIM routing entries on Switch B.
[SwitchB] display pim routing-table
(*, 225.1.1.1)
RP: 10.12.1.1
UpTime: 00:23:47
Total number of downstreams: 3
1: Vlan-interface12
Protocol: pim-bidir, UpTime: 00:23:47, Expires: -
2: Vlan-interface23
Protocol: pim-bidir, UpTime: 00:21:56, Expires: -
3: Vlan-interface101
Protocol: igmp, UpTime: 00:23:47, Expires: -
# Display information about PIM routing entries on Switch C.
[SwitchC] display pim routing-table
(*, 225.1.1.1)
RP: 10.12.1.1
Protocol: pim-bidir, Flag: WC ACT
UpTime: 00:01:45
Upstream interface: Vlan-interface23
Upstream neighbor: 10.23.1.2
RPF prime neighbor: 10.23.1.2
Total number of downstreams: 2
Protocol: igmp, UpTime: 00:01:05, Expires: -
2: Vlan-interface23
Protocol: pim-bidir, UpTime: 00:00:53, Expires: -
Configuration files
· Switch A:
ospf 1
area 0.0.0.0
vlan 12 to 13
vlan 100
interface Vlan-interface12
ip address 10.12.1.1 255.255.255.0
pim sm
interface Vlan-interface13
ip address 10.13.1.1 255.255.255.0
pim sm
interface Vlan-interface100
ip address 10.10.1.1 255.255.255.0
pim sm
interface GigabitEthernet3/0/1
port link-mode bridge
port access vlan 100
interface GigabitEthernet3/0/2
port access vlan 12
interface GigabitEthernet3/0/3
port access vlan 13
multicast routing
pim
bidir-pim enable
c-bsr 10.12.1.1
· Switch B:
ospf 1
area 0.0.0.0
vlan 12
Vlan 23
vlan 101
ip address 10.12.1.2 255.255.255.0
pim sm
interface Vlan-interface23
ip address 10.23.1.2 255.255.255.0
pim sm
interface Vlan-interface101
ip address 10.101.1.1 255.255.255.0
pim sm
igmp enable
port access vlan 101
port access vlan 12
port access vlan 23
multicast routing
pim
bidir-pim enable
· Switch C:
ospf 1
area 0.0.0.0
vlan 13
vlan 23
vlan 33
vlan 102
ip address 10.13.1.3 255.255.255.0
pim sm
ip address 10.23.1.3 255.255.255.0
pim sm
interface Vlan-interface33
ip address 10.33.1.3 255.255.255.0
pim sm
interface Vlan-interface102
ip address 10.102.1.1 255.255.255.0
pim sm
igmp enable
port access vlan 102
port access vlan 23
port access vlan 13
interface GigabitEthernet3/0/4
port access vlan 33
multicast routing
pim
bidir-pim enable
Related documentation
· H3C S10500 Switch Series IP Multicast Configuration Guide-R7536P05
· H3C S10500 Switch Series IP Multicast Command Reference-R7536P05
