| 00-Preface | 118.42 KB |
H3C S5800 Series Ethernet Switches Quick Start describes the installation of the H3C S5800 series Ethernet switches.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S5800 series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Obtaining documentation
To access the most up-to-date H3C product documentation, go to the H3C website at http://www.h3c.com.hk.
To obtain information about installation, configuration, and maintenance, click http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click http://www.h3c.com.hk/Software_Download
Technical support
Documentation feedback
You can email your comments about product documentation to [email protected].
We appreciate your comments.
