10-Security Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Command References-R752X-6W10010-Security Command Reference
14-TCP attack prevention commands
14-TCP attack prevention commands 28.57 KB
tcp anti-naptha enable
Use tcp anti-naptha enable to enable Naptha attack prevention.
Use undo tcp anti-naptha enable to disable Naptha attack prevention.
Naptha attack prevention is disabled.
After you enable Naptha attack prevention, the device periodically checks the number of TCP connections in each state. If the number of TCP connections in a state exceeds the limit, the device will accelerate the aging of the TCP connections in that state. The check interval is set by the tcp check-state interval command. The TCP connection limits are set by the tcp state command.
# Enable Naptha attack prevention.
[Sysname] tcp anti-naptha enable
tcp state
Use tcp check-state interval to set the interval for checking the number of TCP connections in each state.
Use undo tcp check-state interval to restore the default.
tcp check-state interval interval
The interval for checking the number of TCP connections in each state is 30 seconds.
System
Parameter
interval: Specifies the check interval in the range of 1 to 60 seconds.
This command takes effect after you enable Naptha attack prevention.
After you enable Naptha attack prevention, the device checks the number of TCP connections in each state at intervals. If the number of TCP connections in a state exceeds the limit, the device will accelerate the aging of the TCP connections in that state.
# Set the interval to 40 seconds for checking the number of TCP connections in each state.
[Sysname] tcp check-state interval 40
tcp state
tcp state
Use tcp state to set the maximum number of TCP connections in a state.
Use undo tcp state to restore the default.
tcp state { closing | established | fin-wait-1 | fin-wait-2 | last-ack } connection-limit number
undo tcp state { closing | established | fin-wait-1 | fin-wait-2 | last-ack } connection-limit
The maximum number of TCP connections in each state (CLOSING, ESTABLISHED, FIN_WAIT_1, FIN_WAIT_2, and LAST_ACK) is 50.
closing: Specifies the CLOSING state.
established: Specifies the ESTABLISHED state.
fin-wait-1: Specifies the FIN_WAIT_1 state.
fin-wait-2: Specifies the FIN_WAIT_2 state.
last-ack: Specifies the LAST_ACK state.
connection-limit number: Specifies the maximum number of TCP connections, in the range of 0 to 500. The value of 0 represents that the device does not accelerate the aging of the TCP connections in a state.
This command takes effect after you enable Naptha attack prevention. If the number of TCP connections in a state exceeds the limit, the device will accelerate the aging of the TCP connections in the state.
# Set the maximum number of TCP connections in the ESTABLISHED state to 100.
[Sysname] tcp state established connection-limit 100
