04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Command References-R752X-6W10004-Layer 2 - LAN Switching Command Reference
13-EPON commands
13-EPON commands 303.2 KB
EPON commands· 1
OLT commands· 1
dba-parameters· 1
dba-report queue-set-id queue-id threshold· 1
dba-report queue-set-number 2
display epon fiber-backup group· 3
display epon oam·· 3
display epon onu-event 4
display epon optics-parameters· 5
display epon parameter 5
display epon statistics· 6
display epon version· 6
display epon workmode· 7
encryption update-time· 8
fiber-backup group· 9
ftth· 9
grant-filtering enable· 10
interface· 10
max-rtt 10
member 11
multicast call-detail-record cache-limit 12
multicast call-detail-record enable· 12
multicast call-detail-record record-delay· 13
multicast call-detail-record report-interval 14
multicast call-detail-record send· 14
oam-discovery-timeout 15
onu invalid-address mode· 15
port fiber-backup group· 16
port switch-over 17
port-type· 17
vendor-compatible· 18
ONU remote management commands· 19
bandwidth-downstream·· 19
bandwidth-downstream policy enable· 20
bind onu-id· 20
deregister onu· 21
display dhcp-client 21
display epon multicast 22
display onu· 23
display onu mac-address· 24
display onu protocol 24
display onu protocol smart-link uni-bind information· 26
display onu protocol transparent-multicast 26
display serial-information· 27
display uni 27
display vendor-specific information· 30
encryption enable· 31
forward-error-correction· 32
ip address· 32
management-vlan· 33
multicast mode· 34
multicast vlan-id ip· 34
multicast-control host-aging-time· 35
onu bind auto· 36
onu bind batch· 36
onu event 37
onu multicast fast-leave enable· 38
onu port-isolate enable· 38
onu protocol enable· 39
onu protocol igmp-snooping timer 40
onu protocol igmp-snooping suppression· 41
onu protocol loopback-detection action· 41
onu protocol smart-link flush enable· 42
onu protocol smart-link uni-bind enable· 42
onu protocol transparent-multicast dest-mac· 43
qos cos-local-precedence-map· 44
reboot onu· 45
reset counters serial 45
reset counters uni 46
serial databit 46
serial parity· 47
serial session protocol-type· 48
serial speed· 49
serial stopbit 50
shutdown management-vlan-interface· 50
uni auto-negotiation· 51
uni classification-marking· 52
uni description· 53
uni duplex· 54
uni flow-control 55
uni igmp-snooping fast-leave· 55
uni mdix-mode· 56
uni mirroring-port 57
uni monitor-port 57
uni multicast vlan· 58
uni multicast-control multicast-address· 59
uni multicast-group-number 60
uni multicast-strip-tag enable· 61
uni port-isolate· 61
uni port-policy inbound· 62
uni port-policy outbound· 62
uni qinq· 63
uni restart auto-negotiation· 64
uni shutdown· 64
uni speed· 65
uni virtual-cable-test 66
uni vlan-mode· 67
update onu filename· 68
update onu type· 69
upstream-sla· 70
using onu· 71
voip-port shutdown· 71
EPON alarm commands· 72
alarm device-fatal-error enable· 72
alarm oam critical-event enable· 73
alarm oam dying-gasp enable· 73
alarm oam local-link-fault enable· 74
alarm onu-laser always-on enable· 75
alarm onu-over-limit enable· 75
alarm registration-error enable· 76
monitor enable· 76
timer monitor 77
BCMP proxy commands· 78
bcmp-proxy enable· 78
bcmp-proxy server address· 78
bcmp-proxy server port 79
bcmp-proxy vlan· 79
EPON commands
OLT commands
dba-parameters
Use dba-parameters to set ONU discovery parameters.
Use undo dba-parameters to restore the default.
dba-parameters { discovery-frequency frequency | discovery-length length } *
undo dba-parameters { discovery-frequency | discovery-length } *
An OLT port initiates ONU discovery at an interval of 500 milliseconds, and each ONU discovery process lasts for 307.6 milliseconds.
OLT port view
discovery-frequency frequency: Specifies the ONU discovery interval at which the OLT port broadcasts discovery GATE messages, in the range of 100 to 60000. The unit of the frequency argument is 0.1 millisecond.
discovery-length length: Specifies the duration of each ONU discovery, in the range of 200 to 10240. The unit of the length argument is 0.1 millisecond.
Incorrect DBA settings might interrupt services. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Set the ONU discovery interval to 300 milliseconds on OLT 3/0/1.
[Sysname] interface olt 3/0/1
[Sysname-Olt3/0/1] dba-parameters discovery-frequency 3000
Use dba-report queue-set-id queue-id threshold to configure the threshold for a queue.
Use undo dba-report queue-set-id to restore the default.
dba-report queue-set-id queue-set-id queue-id queue-id { active | inactive } threshold threshold-value
undo dba-report queue-set-id queue-set-id
The default thresholds are as follows:
·     0 for queues 1 through 3, and the threshold is activated.
·     65535 for queues 4 and 5, and the threshold is activated.
·     0 for queues 6 through 8, and the threshold is not activated.
ONU port view
queue-set-id: Specifies a queue set ID in the range of 1 to 3.
queue-id: Specifies a queue ID in the range of 1 to 8.
threshold-value: Specifies a threshold in the range of 0 to 65535.
active: Activates the threshold.
inactive: Does not activate the threshold.
# Set the threshold to 200 for queue 1 in queue set 1 and activate the threshold.
[Sysname] interface onu 3/0/1:1
[Sysname-Onu3/0/1:1] dba-report queue-set-id 1 queue-id 1 active threshold 200
Use dba-report queue-set-number to set the number of queue sets that ONU REPORT messages support.
Use undo dba-report queue-set-number to restore the default.
dba-report queue-set-number queue-set-number
ONU REPORT messages support two queue sets.
ONU port view
queue-set-number: Specifies the number of queue sets, in the range of 2 to 4.
# Set the number of queue sets to 2 for ONU REPORT messages on ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] dba-report queue-set-number 2
Use display epon fiber-backup group to display information about fiber backup groups.
display epon fiber-backup group { group-number | all }
group-number: Specifies a fiber backup group number in the range of 1 to 80.
all: Specifies all fiber backup groups.
# Display information about fiber backup group 1.
<Sysname> display epon fiber-backup group 1
Fiber backup group 1 information:
 Member         Role        State
 OLT3/0/1       Master      Active
 OLT3/0/2       Standby     Ready
Role
OLT port role:
·     Master—Master port.
·     Standby—Subordinate port.
OLT port status:
·     Active—The master port is active. (The chip is active and the EPON transceiver module is plugged in.)
·     Ready—The subordinate port is ready, and a master/subordinate switchover can be performed.
·     Down—Any other condition.
display epon oam
Use display epon oam to display Operations, Administration and Maintenance (OAM) information for an ONU port.
display epon oam interface interface-type interface-number
interface-type: Specifies an interface type. The value of this argument must be onu.
# Display OAM information for ONU 4/0/1:1.
<Sysname> display epon oam interface onu 4/0/1:1
OAM information:
 OAM version: 1
 Multiplexer action: Discard non-OAM PDUs
 Parser action     : Forward non-OAM PDUs to higher layer
 Sending variable-length OAM response PDUs: Not supported
 Interpreting link events                 : Not supported
 OAM mode              : Active
 Unidirectional support: Disabled
 Loopback support      : Disabled
 Maximal PDU size      : 494 bytes
 Identifier            : 433348
Use display epon onu-event to display ONU registration and deregistration records for an ONU port.
display epon onu-event interface interface-type interface-number
# Display ONU registration and deregistration records for ONU 3/0/1:1.
<Sysname> display epon onu-event interface onu 3/0/1:1
Date         Time       ONU Event          ONU Status
2015/06/24   14:41:18   Registration       Up
2015/06/24   14:41:59   Deregistration     Down
2015/06/24   14:42:02   Registration       Up
2015/06/24   14:42:49   Deregistration     Down
Use display epon optics-parameters to display optical parameters for an OLT port.
display epon optics-parameters interface interface-type interface-number
interface-type: Specifies an interface type. The value of this argument must be olt.
# Display optical parameters for OLT 3/0/1.
<Sysname> display epon optics-parameters interface olt 3/0/1
Optical parameters:
 Temperature       :34.16 °C
 Voltage           :3.29 V
 Bias              :1.51 mA
 Transmitter power :4.60 dbm
Use display epon parameter to display EPON system parameters.
display epon parameter slot slot-number
slot slot-number: Specifies a card by its slot number.
# Display EPON system parameters for card 4.
<Sysname> display epon parameter slot 4
Parameters:
     OUI: 111111     OAM version:3.0
     OUI: 111111     OAM version:2.1
     OUI: 111111     OAM version:2.0
     OUI: 111111     OAM version:1.3
     OUI: 111111     OAM version:1(default)
     Key update timer            : 10 seconds
     OAM discovery timeout timer : 3.0 seconds
Use display epon statistics to display packet error rates on an ONU port.
display epon statistics interface interface-type interface-number
You can view packet error rates of an ONU port only when the port is up.
This command displays the average error rates for the last sampling interval. An error rate value less than 1e-9 is displayed as 0.
# Display packet error rates on ONU 3/0/1:1.
<Sysname> display epon statistics interface onu 3/0/1:1
ONU statistics:
 Bit error rate(in 1e-9 unit)  : 0
 Frame error rate(in 1e-9 unit): 0
Use display epon version to display version information for an OLT or ONU port.
display epon version interface interface-type interface-number
interface-type: Specifies an interface type. The value of this argument must be olt or onu.
You can view version information for an OLT or ONU port only when the port is up.
# Display version information for OLT 3/0/1.
<Sysname> display epon version interface olt 3/0/1
OLT version information:
 Firmware major version: 0
 Firmware minor version: 3
 Hardware major version: 1
 Hardware minor version: 1
 Supported LLIDs       : 63
# Display version information for ONU 3/0/1:1.
<Sysname> display epon version interface onu 3/0/1:1
ONU version information:
 Hardware major version: A
 Hardware minor version: 0
 Supported LLIDs       : 1
 MAC type of UNI port  : MII
Use display epon workmode to display the operation mode of an OLT or ONU port.
display epon workmode interface interface-type interface-number
If you specify an OLT port, this command also displays the port's MAC address and DBA algorithm.
You can view the operation mode of an ONU port only when the port has been bound to an ONU.
# Display the operation mode of OLT 3/0/1.
<Sysname> display epon workmode interface olt 3/0/1
Port status: Open
MAC address: 000f-e2a1-1027
DBA mode   : Internal
# Display the operation mode of ONU 3/0/1:1.
<Sysname> display epon workmode interface onu 3/0/1:1
Port status: Open
FEC mode   : Disabled
Port status
Port status:
·     Open.
·     Closed.
·     Resetting—The chip is resetting. This value is available for OLT ports.
·     Pending—The ONU has been registered but fails the authentication. This value is available for ONU ports.
·     Unknown.
MAC address
MAC address of the OLT port.
All OLT ports on a device use the same MAC address.
DBA mode
DBA algorithm of the OLT port:
·     Internal—Internal DBA algorithm.
·     External—External DBA algorithm.
Use encryption update-time to set the LLID key update interval.
Use undo encryption update-time to restore the default.
encryption slot slot-number update-time update-time
undo encryption slot slot-number update-time
The LLID key update interval is 10 seconds.
FTTH view
update-time update-time: Specifies the LLID key update interval in the range of 1 to 255 seconds.
# Set the LLID key update interval to 100 seconds for card 2.
[Sysname] ftth
[Sysname-ftth] encryption slot 2 update-time 100
fiber-backup group
Use fiber-backup group to create a fiber backup group, or enter the view of an existing fiber backup group.
Use undo fiber-backup group to delete a fiber backup group.
fiber-backup group group-number
undo fiber-backup group group-number
No fiber backup groups exist.
FTTH view
# Create fiber backup group 1 and enter its view.
[Sysname] ftth
[Sysname-ftth] fiber-backup group 1
member
ftth
Use ftth to enter FTTH view.
ftth
# Enter FTTH view.
[Sysname] ftth
[Sysname-ftth]
Use grant-filtering enable to enable grant filtering on an OLT port.
Use undo grant-filtering enable to disable grant filtering on an OLT port.
Grant filtering is enabled on an OLT port.
OLT port view
# Enable grant filtering on OLT 3/0/1.
[Sysname-Olt3/0/1] grant-filtering enable
interface
Use interface to enter OLT port or ONU port view.
# Enter the view of OLT 3/0/1.
[Sysname-Olt3/0/1]
max-rtt
Use max-rtt to set the maximum ONU-OLT RTT.
Use undo max-rtt to restore the default.
max-rtt max-rtt-value
undo max-rtt
The maximum ONU-OLT RTT is 14500 TQ.
OLT port view
max-rtt-value: Specifies an RTT in the range of 2000 to 32000 TQ. 1 time quantum (TQ) is equal to 16 ns, the time for transmitting two bytes of data at 1 Gbps.
# Set the maximum ONU-OLT RTT to 25000 TQ on OLT 3/0/1.
[Sysname-Olt3/0/1] max-rtt 25000
member
Use member to assign an OLT port to a fiber backup group.
Use undo member to remove an OLT port from a fiber backup group.
member olt interface-number
undo member olt interface-number
A fiber backup group does not contain any OLT ports.
Fiber backup group view
olt interface-number: Specifies an OLT port by its number.
A fiber backup group contains a maximum of two OLT ports. An OLT port can be assigned to only one fiber backup group. The OLT port assigned first acts as the master port, and the other OLT port acts as the subordinate port. Only the master OLT port forwards traffic.
To assign an OLT port to a fiber backup group in OLT port view, use the port fiber-backup group command.
# Assign OLT 3/0/1 to fiber backup group 1.
[Sysname] ftth
[Sysname-fiber-group1] member olt 3/0/1
fiber-backup group
Use multicast call-detail-record cache-limit to set the upper limit for the Call Detail Record (CDR) buffer.
Use undo multicast call-detail-record cache-limit to restore the default.
multicast call-detail-record cache-limit number
The CDR buffer can save a maximum of 32 records.
FTTH view
number: Specifies an upper limit in the range of 16 to 1024.
If the CDR buffer upper limit is reached, the OLT automatically sends the CDR records to the information center module and clears the CDR buffer.
# Set the upper limit of the CDR buffer to 16.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record cache-limit 16
Use multicast call-detail-record enable to enable CDR.
Use undo multicast call-detail-record enable to disable CDR.
CDR is disabled.
FTTH view
CDR takes effect only on ONUs in multicast control mode.
# Enable CDR.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record enable
multicast mode
Use multicast call-detail-record record-delay to set the CDR generation delay.
Use undo multicast call-detail-record record-delay to restore the default.
multicast call-detail-record record-delay delay-time
The CDR generation delay is 30 seconds.
FTTH view
delay-time: Specifies a delay time in the range of 10 to 600 seconds.
After CDR is enabled, the OLT periodically checks the online duration of users. If the online duration of a user is longer than the CDR generation delay, the OLT generates a CDR record and saves it to the CDR buffer.
# Set the CDR generation delay to 20 seconds.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record record-delay 20
Use multicast call-detail-record report-interval to set the CDR sending interval.
Use undo multicast call-detail-record report-interval to restore the default.
multicast call-detail-record report-interval interval
The CDR sending interval is 30 seconds.
FTTH view
interval: Specifies an interval in the range of 30 to 600 seconds.
The OLT sends CDR records to the information center module and clears the CDR buffer at the CDR sending interval.
# Set the CDR sending interval to 40 seconds.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record report-interval 40
Use multicast call-detail-record send to manually send CDR records.
FTTH view
This command allows you to manually send CDR records to the information center module and clears the CDR buffer. You can set CDR record output rules, including output destinations. For more information about using the information center, see Network Management and Monitoring Configuration Guide.
# Manually send CDR records.
[Sysname] ftth
[Sysname-ftth] multicast call-detail-record send
Use oam-discovery-timeout to set the timeout timer for extended OAM discovery.
Use undo oam-discovery-timeout to restore the default.
oam-discovery-timeout slot slot-number value value
undo oam-discovery-timeout slot slot-number value
The timeout timer for extended OAM discovery is 3 seconds.
FTTH view
value value: Specifies a timeout period in the range of 30 to 2550. The unit of the value argument is 100 milliseconds.
The timeout timer for extended OAM discovery determines the timeout period for extended OAM messages during extended OAM discovery.
As a best practice, use the default setting for this timer. Increase this timer on the card that hosts an OLT port if an ONU connected to the OLT and bound to an ONU port remains down.
# Set the timeout timer for extended OAM discovery to 10 seconds for card 2.
[Sysname] ftth
[Sysname-ftth] oam-discovery-timeout slot 2 value 100
Use onu invalid-address mode to set the processing mode for frames with an invalid source MAC address.
Use undo onu invalid-address mode to restore the default.
onu invalid-address mode { abandon | broadcast | unicast }
The abandon mode is enabled for frames with an invalid source MAC address.
FTTH view
abandon: Specifies the abandon mode. In this mode, the OLT drops frames with an invalid source MAC address.
broadcast: Specifies the broadcast mode. In this mode, the OLT forwards frames sourced from an invalid MAC address without learning the source MAC address. When the OLT receives a frame with an invalid destination MAC address, it floods the frame to all interfaces in the frame's VLAN except for the incoming interface.
unicast: Specifies the unicast mode. In this mode, the OLT forwards frames sourced from an invalid MAC address and generates a unicast MAC address entry for the invalid MAC address. The OLT uses the entry for forwarding frames destined for the invalid MAC address.
An invalid MAC address is a MAC address whose seventh bit of the first byte is 1, for example, 02-10-94-00-00-02 (the first byte is 00000010).
The processing mode for frames with an invalid source MAC address does not take effect on a GigabitEthernet interface that is changed from an EPON fiber interface.
# Set the processing mode to broadcast for frames with an invalid source MAC address.
[Sysname] ftth
[Sysname-ftth] onu invalid-address mode broadcast
Use port fiber-backup group to assign an OLT port to a fiber backup group.
Use undo port fiber-backup group to restore the default.
port fiber-backup group group-number
An OLT port is not assigned to a fiber backup group.
OLT port view
group-number: Specifies a fiber backup group number.
To assign an OLT port to a fiber backup group in fiber backup group view, use the member command.
[Sysname] ftth
[Sysname-fiber-group1] quit
[Sysname-Olt3/0/1] port fiber-backup group 1
fiber-backup group
member
port switch-over
Use port switch-over to perform a master/subordinate switchover for a fiber backup group.
port switch-over
For successful command execution, use this command when the subordinate OLT port is in Ready state.
# Perform a master/subordinate switchover for fiber backup group 1.
[Sysname] ftth
[Sysname-fiber-group1] port switch-over
port-type
Use port-type to change the type of a fiber interface.
Use undo port-type to cancel the type change of a fiber interface.
This command is supported by the LSQM1PT24TSSC0 interface card.
In OLT port view:
port-type gigabitethernet
undo port-type gigabitethernet
In Layer 2 or Layer 3 GigabitEthernet interface view:
port-type olt
undo port-type olt
The type of a fiber interface is OLT.
Layer 2/Layer 3 GigabitEthernet interface view
OLT port view
gigabitethernet: Changes the OLT port to a GigabitEthernet interface. By default, the GigabitEthernet interface is in Layer 2 mode.
olt: Changes the GigabitEthernet interface to an OLT port.
The fiber interfaces on the LSQM1PT24TSSC0 interface card are grouped by port number in order, starting from 1. Each group contains four interfaces. To change the type of an interface in a group, you must change the type of all the four interfaces in the group. For the interface type change to take effect, reboot the interface card.
If you change the type of an interface, the system automatically removes the original interface and then creates the target interface with the same number as the original interface.
# Change GigabitEthernet 3/0/1 through GigabitEthernet 3/0/4 to OLT ports.
[Sysname] interface range gigabitethernet 3/0/1 to gigabitethernet 3/0/4
[Sysname-if-range] port-type olt
vendor-compatible
Use vendor-compatible to enable compatibility with third-party ONUs.
Use undo vendor-compatible to disable compatibility with third-party ONUs.
vendor-compatible slot slot-number
undo vendor-compatible slot slot-number
Compatibility with third-party ONUs is enabled.
FTTH view
To allow non-H3C ONUs to register with an OLT, enable compatibility with third-party ONUs. If this feature is disabled, only H3C ONUs can register with the OLT.
If you bind a non-H3C ONU to an ONU port before this feature is enabled, the non-H3C ONU cannot register with the OLT even if you enable this feature. For successful registration, you must perform one of the following tasks:
·     Use the deregister onu command to deregister the ONU.
·     Use the shutdown command to shut down the ONU port and then use the undo shutdown command to bring it up.
# Disable compatibility with third-party ONUs on card 2.
[Sysname] ftth
[Sysname-ftth] undo vendor-compatible slot 2
Support for ONU remote management commands depends on the ONU model.
Use bandwidth-downstream to configure the downlink bandwidth limits on an ONU port.
Use undo bandwidth-downstream to restore the default maximum downlink bandwidth or default maximum downlink burst buffer on an ONU port.
bandwidth-downstream { max-bandwidth value1 | max-burstsize value2 } *
undo bandwidth-downstream { max-bandwidth | max-burstsize } *
The maximum downlink bandwidth is 999994 Kbps, and the maximum downlink burst buffer is 4194240 bytes on an ONU port.
ONU port view
value1: Specifies the maximum downlink bandwidth in the range of 0 to 999994 Kbps.
value2: Specifies the maximum downlink burst buffer in the range of 0 to 4194240 bytes.
For the downlink bandwidth limits to take effect, you must enable the downlink bandwidth allocation policy. The downlink bandwidth limits take effect only on known unicast packets.
# Set the maximum downlink bandwidth to 888 Kbps and the maximum downlink burst buffer to 999 bytes on ONU 2/0/1:1.
[Sysname] interface onu 2/0/1:1
[Sysname-Onu2/0/1:1] bandwidth-downstream max-bandwidth 888 max-burstsize 999
Use bandwidth-downstream policy enable to enable the downlink bandwidth allocation policy on an ONU port.
Use undo bandwidth-downstream policy enable to disable the downlink bandwidth allocation policy on an ONU port.
The downlink bandwidth allocation policy is disabled on an ONU port.
ONU port view
# Enable the downlink bandwidth allocation policy on ONU 2/0/1:1.
[Sysname-Onu2/0/1:1] bandwidth-downstream policy enable
bind onu-id
Use bind onu-id to bind an ONU to an ONU port.
Use undo bind onu-id to unbind an ONU from an ONU port.
bind onu-id mac-address
undo bind onu-id
No ONU is bound to an ONU port.
ONU port view
mac-address: Specifies an ONU by its MAC address.
If fiber backup is not configured, you can create only one-to-one bindings between ONUs and ONU ports. For a fiber backup group, you can bind an ONU to two ONU ports that are on different member OLT ports.
# Bind the ONU with MAC address 11-22-33 to ONU 2/0/2:1.
[Sysname] interface onu 2/0/2:1
[Sysname-Onu2/0/2:1] bind onu-id 11-22-33
deregister onu
Use deregister onu to deregister an ONU.
deregister onu
ONU port view
After you deregister an ONU, the ONU will be re-registered.
# Deregister the ONU bound to ONU 2/0/1:1.
[Sysname] interface ONU 2/0/1:1
[Sysname-Onu2/0/1:1] deregister onu
display dhcp-client
Use display dhcp-client to display IP address assignment information for an ONU that acts as a DHCP client.
display dhcp-client
ONU port view
# Display IP address assignment information for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] display dhcp-client
DHCP client statistic information :
  Current machine state : HALT
Output of this command varies by ONU model.
Use display epon multicast to display multicast information for an ONU port in multicast control mode.
ONU port view
You can view multicast information for an ONU port only when the ONU port is up and in multicast control mode.
# Display multicast information for ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] display epon multicast
Multicast control information:
UNI number 1:
 Multicast vlan 10
 Current channel list:
 Multicast IP: 225.0.0.2
 Status: Permit
 Multicast vlan 10
 Multicast IP: 225.0.0.3
 Status: Preview
 Preview times: 16
 Preview remaining time: 144s
Multicast-control information: None.
No multicast control entries are generated. The causes are as follows:
·     Multicast control is not configured.
·     Multicast clients do not send multicast membership reports.
Status
Multicast control policy:
·     Permit—Users are permitted to access the channel.
·     Preview—Users can only preview the channel.
display onu
Use display onu to display ONU information.
display onu [ silent ] { interface interface-type interface-number | slot slot-number }
silent: Specifies silent ONUs.
interface interface-type interface-number: Specifies an OLT port or ONU port by its number. The value of the interface-type argument must be olt or onu.
# Display information about all ONUs on OLT 3/0/1.
<Sysname> display onu interface olt 3/0/1
MAC               LLID Dist(M)    Port           Model/Version        Sft/Epm   State  Aging
586a-b1ea-8a6d   60  <1000     Onu3/0/1:1    ET254-G-S/A         206/100   Up    N/A
586a-b1ea-8a03   41  <1000     Onu3/0/1:2    ET254-G-S/A         206/100   Up    N/A
586a-b1ea-91c4   18  <1000     Onu3/0/1:62   ET254-G-S/A         206/100   Up    N/A
 ---  62 entries found  ---
MAC
ONU MAC address.
LLID
LLID assigned to the registered ONU. This field displays N/A if the ONU is not registered.
Dist(M)
Actual length (in metres) of the optical fiber between the OLT and the ONU. If the optical fiber is shorter than 1 km, this field displays <1000. If the ONU is not registered, this field displays N/A.
Port
Bound ONU port number. This field displays N/A if the ONU is not bound to an ONU port.
Model/Version
ONU model and PCB version. This field displays N/A if the ONU is not registered.
Sft/Epm
ONU software version and EEPROM version. This field displays N/A if the ONU is not registered.
ONU state:
·     Silent—The ONU is powered on, and it is not bound to an ONU port.
·     Offline—The ONU is powered off, and it is bound to an ONU port.
·     Up—The ONU is powered on, and it is bound to an ONU port.
·     Down—The ONU is bound to an ONU port, but the ONU port is manually shut down.
Aging
Remaining MAC address aging time of an ONU in silent state. This field displays N/A if the ONU is not in silent state.
Use display onu mac-address to display information about a legal ONU.
display onu mac-address mac-address
# Display information about the legal ONU with MAC address 586a-b1ea-8a6d.
<Sysname> display onu mac-address 586a-b1ea-8a6d
 ---  1 entry found  ---
For information about the parameters in the command output, see Table 4.
Use display onu protocol to display information about protocols supported by an ONU.
display onu protocol { dhcp-snooping information | igmp-snooping | loopback-detection | pppoe | smart-link | stp }
ONU port view
dhcp-snooping information: Specifies DHCP snooping Option 82.
igmp-snooping: Specifies IGMP snooping.
loopback-detection: Specifies loop detection.
pppoe: Specifies PPPoE+.
smart-link: Specifies Smart Link.
stp: Specifies RSTP.
# Display IGMP snooping information for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] display onu protocol igmp-snooping
 Protocol name: IGMP snooping
 Protocol status: Enabled
 Total 4 Multicast groups.
 Group: 0100-5e01-0140
 Port : 9
 Group: 0100-5e01-013f
 Port : 9
 Group: 0100-5e01-013e
 Port : 9
 Group: 0100-5e01-013d
 Port : 9
# Display loop detection information for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] display onu protocol loopback-detection
 Protocol name: Loopback detection
 Loopback action: Semi-block
 Loopback is detected on following interfaces:UNI 1  UNI 4
Table 5 Command output
Group
Multicast MAC address.
Port
UNI number.
Loopback action
Loop protection action:
·     Semi-block—If a loop is detected on a UNI, the system generates a log message, disables MAC learning on the UNI, and blocks the inbound direction of the UNI.
·     No-learning—If a loop is detected on a UNI, the system generates a log message and disables MAC learning on the UNI.
·     Shutdown—If a loop is detected on a UNI, the system generates a log message and shuts down the UNI. The UNI will automatically come up after the interval set by using the shutdown-interval command. For more information about the command, see device management commands in Fundamentals Command Reference.
Use display onu protocol smart-link uni-bind information to display information about UNI count-based PON port activation for an ONU.
ONU port view
# Display information about UNI count-based PON port activation for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] display onu protocol smart-link uni-bind information
 Protocol name: smart-link uni-bind
Use display onu protocol transparent-multicast to display the multicast MAC addresses enabled with transparent transmission.
ONU port view
# Display the multicast MAC addresses enabled with transparent transmission.
[Sysname-Onu3/0/1:1] display onu protocol transparent-multicast
 Transparent dest-mac packet:  0100-ffff-ffff
Table 6 Command output
Multicast MAC address enabled with transparent transmission.
Use display serial-information to display information about a serial interface on an ONU.
display serial-information interface-number
ONU port view
interface-number: Specifies a serial interface by its number. An ONU can have a maximum of 10 serial interfaces.
# Display information about serial interface 1.
[Sysname-Onu3/0/1:1] display serial-information 1
Description: Serial 1 interface
Parameters:
  Baud:9600
  Databits:8
  Parity:none
  Stopbits:1
Statistics:
  Input total: 0 bytes, Error 0 bytes
  Output total: 0 bytes, Error 0 bytes
display uni
Use display uni to display information about a UNI on an ONU.
display uni uni-number
ONU port view
uni-number: Specifies a UNI by its number. An ONU can have a maximum of 79 UNIs.
# Display information about UNI 1.
[Sysname-Onu3/0/1:1] display uni 1
 UNI 1
 Configuration        :
 Port status          : UP
 Flow control         : Closed
 Autonegotiation state: Enable
 Port isolation       : Disable
 MDI type             : Automdix
 Port policy :
   Inbound : None
   Outbound : None
 Vlan configuration :
   VLAN mode : Transparent
 Classification & marking :
 Multicast VLAN : None
 Multicast groups : 64
 Multicast VLAN untagging : Disable
 Current Status :
 Link state : DOWN
 Local autonegotiation ability :
     1000BASE-T UTP PHY
     Full duplex 1000BASE-T UTP PHY
     100BASE-TX
     Full duplex 100BASE-TX
     Full duplex 10BASE-T
     10BASE-T
     Symmetric PAUSE operation for full duplex links
     Asymmetric PAUSE operation for full duplex links
 Autonegotiation advertisement ability :
     1000BASE-T UTP PHY
     100BASE-TX
     10BASE-T
 100Mbps-speed mode, Full-duplex mode
 Link speed type is autonegotiation, Link duplex type is autonegotiation
 Input(total):  0 packets, 0 bytes
          0 broadcasts, 0 multicasts, 0 unicasts, 0 pauses
 Input:  0 input errors, 0 runts, 0 giants, 0 InRxErr, 0 CRC
         0 buffer failures
 Output(total): 0 packets, 0 bytes
 Output: 0 output errors, 0 deferred, 0 collisions, 0 InTxErr
Table 7 Command output
Port status
Port status:
·     UP.
·     DOWN—The port is shut down by using the shutdown command.
MDI type
MDIX mode:
·     Automdix.
·     Mdi.
·     Mdix.
Port policy
Traffic policing parameters:
·     Inbound—Uplink traffic policing parameters.
·     Outbound—Downlink traffic policing parameters.
Vlan configuration
VLAN operation mode.
Link state
Link layer status:
·     UP.
·     DOWN.
Input(total)
Total input packet statistics (in packets and bytes), and the packet counts for input broadcast packets, multicast packets, unicast packets, and pause frames.
Input
Counts for the following frames:
·     Error frames.
·     Runt frames.
·     Giant frames.
·     Frames having the InRxErr error.
·     Frames having the CRC error.
·     Frames dropped because of insufficient buffer.
Output(total)
Total output packet statistics (in packets and bytes), and the packet counts for output broadcast packets, multicast packets, unicast packets, and pause frames.
Output
·     Error frames.
·     Deferred frames.
·     Collision frames.
·     Frames having the InTxErr error.
Use display vendor-specific information to display detailed information about an ONU.
ONU port view
# Display detailed information about the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] display vendor-specific information
 Serial number
     Vendor ID : kt
     ONU MAC address : 00e0-0f01-b33a
     ONU model : 0x706e6334
     ONU hardware version : 0000
     ONU software version : 342
     ONU extend model :
 Firmware version : 0x0
 Chipset information :
     Vendor ID : 0x6b74
     Chip model : 3000
     Revision version : 0x01
     Design date : 08/01/29
 ONU capability :
     Gigabit ethernet interface :  Not support
     Fast ethernet interface :  Support
     VoIP service :  Not support
     TDM ces service :  Not support
     Gigabit ethernet ports number :  0
     Fast ethernet ports number :  4
     Fast ethernet ports :
       0x1
       0x2
       0x3
       0x4
     POTS ports number :  0
     E1 ports number :  0
     Upstream queues number :  8
     Maximum queues per port upstream :  8
     Downstream queues number :  8
     Maximum queues per port downstream :  8
     Battery backup :  Not support
 Forward error correction ability : Support
 IGMP-snooping fast-leave : Support
 Multicast control fast-leave : Support
 Forward error correction mode : Disable
 DBA-Report parameters :
      Queue sets number : 2
      Queue 1 : State:1 , Value:0
      Queue 2 : State:1 , Value:0
      Queue 3 : State:1 , Value:0
      Queue 4 : State:1 , Value:65535
      Queue 5 : State:1 , Value:65535
      Queue 6 : State:0 , Value:0
      Queue 7 : State:0 , Value:0
      Queue 8 : State:0 , Value:0
 Multicast-fast-leave : Disable
 ONU-Isolate state : Disable
 Multicast-mode : IGSP
Table 8 Command output
ONU extend model
Complete ONU model. This field is required for CTC 3.0.
DBA report message parameters:
·     Queue sets number—Number of queue sets.
·     Queue x: State:x , Value:x—State and threshold (Value) of a queue. The State field displays 0 for a disabled queue and 1 for an enabled queue.
Whether fast-leave processing is enabled for all UNIs on the ONU.
ONU-Isolate state
Whether port isolation is enabled for all UNIs on the ONU.
encryption enable
Use encryption enable to enable downlink traffic encryption for an ONU.
Use undo encryption enable to disable downlink traffic encryption for an ONU.
encryption enable
Downlink traffic encryption is enabled for an ONU.
ONU port view
# Disable downlink traffic encryption for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] undo encryption enable
Use forward-error-correction enable to enable Forward Error Correction (FEC) for an ONU.
Use undo forward-error-correction enable to disable FEC for an ONU.
FEC is disabled on an ONU port.
ONU port view
# Enable FEC for the ONU bound to ONU 2/0/1:1.
[Sysname-Onu2/0/1:1] forward-error-correction enable
ip address
Use ip address to assign an IP address to the management VLAN interface of an ONU.
Use undo ip address to restore the default.
ip address { dhcp-alloc | ip-address { mask-length | mask } gateway gateway }
undo ip address
The management VLAN interface of an H3C ONU uses the IP address 192.168.0.240 and subnet mask 255.255.255.0.
ONU port view
dhcp-alloc: Specifies DHCP IP address allocation.
ip-address: Specifies an IP address in dotted decimal format.
mask-length: Specifies the length of the subnet mask, in the range of 1 to 31. The subnet mask length is the number of consecutive 1s in the subnet mask.
mask: Specifies a subnet mask in dotted decimal format.
gateway: Specifies the gateway IP address.
If the management VLAN of an ONU is changed, the IP address of the original management VLAN interface is deleted.
# Assign the IP address 192.168.0.1/24 to the management VLAN interface of the ONU bound to ONU 3/0/1:1, and specify the gateway IP address as 192.168.0.99.
[Sysname-Onu3/0/1:1] ip address 192.168.0.1 24 gateway 192.168.0.99
management-vlan
management-vlan
Use management-vlan to specify the management VLAN of an ONU.
Use undo management-vlan to restore the default.
management-vlan vlan-id
The management VLAN of an ONU is VLAN 1.
ONU port view
vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If the management VLAN of an ONU is changed, the IP address of the original management VLAN interface is deleted. You must assign an IP address to the new management VLAN interface.
# Specifies the management VLAN as VLAN 10 for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] management-vlan 10
ip address
multicast mode
Use multicast mode to set the multicast mode of an ONU.
Use undo multicast mode to restore the default.
multicast mode { igmp-snooping | multicast-control }
undo multicast mode
The multicast mode of an ONU is IGMP snooping.
ONU port view
igmp-snooping: Specifies the IGMP snooping mode.
multicast-control: Specifies the multicast control mode.
# Set the multicast mode to multicast control for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] multicast mode multicast-control
Use multicast vlan-id ip to map multicast IP addresses to a multicast VLAN.
Use undo multicast vlan-id ip to restore the default.
multicast vlan-id vlan-id ip ip-address-list
undo multicast vlan-id vlan-id
No multicast IP addresses are mapped to a multicast VLAN.
FTTH view
vlan-id: Specifies a multicast VLAN ID in the range of 1 to 4094.
ip-address-list: Specifies a space-separated list of up to 10 multicast IP address items. Each item specifies a multicast IP address or a range of multicast IP addresses in the format of ip-address1 to ip-address2.
When receiving an IGMP report message, the OLT verifies whether the multicast IP address in the message belongs to a multicast VLAN.
·     If the address belongs to a multicast VLAN, the OLT generates a multicast forwarding entry for the multicast VLAN.
·     If the address does not belong to a multicast VLAN, the OLT drops the message.
A multicast IP address can be mapped to only one multicast VLAN.
# Map the multicast IP address 225.1.2.1 to multicast VLAN 1002.
[Sysname] ftth
[Sysname-ftth] multicast vlan-id 1002 ip 225.1.2.1
Use multicast-control host-aging-time to set the multicast group member port aging timer for an ONU.
Use undo multicast-control host-aging-time to restore the default.
multicast-control host-aging-time host-aging-time
The multicast group member port aging timer is 260 seconds.
ONU port view
host-aging-time: Set the aging timer in the range of 200 to 1000 seconds.
This command is available only on an ONU in multicast control mode.
# Set the multicast mode to multicast control for the ONU bound to ONU 3/0/1:1. Set the multicast group member port aging timer to 500 seconds for the ONU.
[Sysname-Onu3/0/1:1] multicast-control host-aging-time 500
multicast mode
onu bind auto
Use onu bind auto to enable automatic ONU binding.
Use undo onu bind auto to disable automatic ONU binding.
onu bind auto [ slot slot-number ]
undo onu bind auto [ slot slot-number ]
Automatic ONU binding is disabled.
FTTH view
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command enables automatic ONU binding for all cards.
If an ONU is not bound to any ONU port, the ONU cannot be registered. Such an ONU is called a silent ONU. Automatic ONU binding automatically binds ONU ports to existing silent ONUs and ONUs that join the system after this feature is enabled.
Automatic ONU binding applies to an EPON system where ONUs attached to the OLT are completely trustworthy. To unbind an ONU, first use the undo onu bind auto command to disable automatic ONU binding.
# Enable automatic ONU binding on card 2.
[sysname] ftth
[sysname-ftth] onu bind auto slot 2
onu bind batch
Use onu bind batch to perform batch ONU binding.
onu bind batch [ slot slot-number ]
Batch ONU binding is not performed.
FTTH view
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command enables batch ONU binding for all cards.
Batch ONU binding automatically binds existing silent ONUs to ONU ports at a time. The ONUs that join the system after batch ONU binding is performed will not be bound.
Batch ONU binding applies to a newly established EPON system that contains only legal ONUs. You can use the bind onu-id command to manually bind new ONUs after batch ONU binding is performed.
# Perform batch ONU binding on card 2.
[sysname] ftth
[sysname-ftth] onu bind batch slot 2
bind onu-id
onu event
Use onu event to enable event reporting for an ONU.
Use undo onu event to disable event reporting for an ONU.
onu event { debug | log | trap } enable level severity
undo onu event { debug | log | trap } enable
Event reporting is disabled for an ONU.
ONU port view
debug: Specifies debugging information.
log: Specifies log information.
trap: Specifies trap information.
level severity: Specifies the severity level threshold. The ONU reports an event to the OLT if the severity level of the event reaches or exceeds this threshold. The following are the severity levels in descending order of priority:
·     Emergencies (severity=0).
·     Alerts (severity=1).
·     Critical (severity=2).
·     Errors (severity=3).
·     Warnings (severity=4).
·     Notifications (severity=5).
·     Information (severity=6).
·     Debugging (severity=7).
# Enable the ONU bound to ONU 2/0/2:1 to report debugging events with a severity level of alerts or a higher severity level.
[Sysname-Onu2/0/2:1] onu event debug enable level alerts
Use onu multicast fast-leave enable to enable fast-leave processing for all UNIs on an ONU.
Use undo onu multicast fast-leave enable to disable fast-leave processing for all UNIs on an ONU.
Fast-leave processing is disabled for all UNIs on an ONU.
ONU port view
Before you use this command on an ONU, set the multicast mode of the ONU to IGMP snooping.
You cannot use this command together with the uni igmp-snooping fast-leave command.
# Enable fast-leave processing for all UNIs on the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] onu multicast fast-leave enable
multicast mode
Use onu port-isolate enable to assign all UNIs on an ONU to the isolation group.
Use undo onu port-isolate enable to remove all UNIs on an ONU from the isolation group.
A UNI is not in the isolation group.
ONU port view
You cannot use this command together with the uni port-isolate command.
# Assign all UNIs on the ONU bound to ONU 3/0/1:1 to the isolation group.
[Sysname-Onu3/0/1:1] onu port-isolate enable
uni port-isolate
onu protocol enable
Use onu protocol enable to enable a user network management feature on an ONU.
Use undo onu protocol enable to disable a user network management feature on an ONU.
onu protocol { dhcp-snooping | dhcp-snooping information | loopback-detection | pppoe | stp } enable
undo onu protocol { dhcp-snooping | dhcp-snooping information | loopback-detection | pppoe | stp } enable
RSTP is enabled, and DHCP snooping, DHCP snooping Option82, loop detection, and PPPoE+ are disabled on an ONU.
ONU port view
dhcp-snooping: Specifies DHCP snooping.
# Enable DHCP snooping on the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] onu protocol dhcp-snooping enable
Use onu protocol igmp-snooping timer to set IGMP snooping timers.
Use undo onu protocol igmp-snooping timer to restore the default.
This command is supported by ET704 ONUs.
onu protocol igmp-snooping timer { host-aging-time host-aging-time | max-response-time max-response-time | router-aging-time router-aging-time }
undo onu protocol igmp-snooping timer { host-aging-time | max-response-time | router-aging-time }
The query response timer is 1 second.
The router port aging timer is 105 seconds.
ONU port view
host-aging-time host-aging-time: Sets the multicast group member port aging timer in the range of 200 to 1000 seconds.
max-response-time max-response-time: Sets the query response timer in the range of 1 to 25 seconds.
router-aging-time router-aging-time: Sets the router port aging timer in the range of 1 to 1000 seconds.
The multicast group member port aging timer determines how often multicast group members are refreshed. If the ONU does not receive an IGMP report from a multicast group member port when this timer expires, the ONU deletes the port. In a network where multicast group members change frequently, set this timer to a small value.
The query response timer sets the response timeout time for group-specific queries. If the ONU does not receive a response before the query response timer expires for the first time, it re-sends group-specific queries and re-starts the query response timer. If the ONU still does not receive a response when the timer expires, the multicast group on the ONU is deleted.
The router port is the port that connects the ONU to the router. The ONU receives IGMP general query messages from the router through this port. If no IGMP general query message is received through the router port when the router port aging timer expires, the ONU determines that the port is not a router port. The router port aging timer must be a value about 2.5 times of the general query interval. For more information about the general query interval, see IGMP in IP Multicast Configuration Guide.
# Set the multicast group member port aging timer to 200 seconds for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] onu protocol igmp-snooping timer host-aging-time 200
Use onu protocol igmp-snooping suppression to enable IGMP membership report suppression or IGMP leave suppression.
Use undo onu protocol igmp-snooping suppression to disable IGMP membership report suppression or IGMP leave suppression.
onu protocol igmp-snooping suppression { leave | report }
undo onu protocol igmp-snooping suppression { leave | report }
IGMP leave suppression is enabled, and IGMP membership report suppression is disabled.
ONU port view
# Enable IGMP leave suppression on the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] onu protocol igmp-snooping suppression leave
Use onu protocol loopback-detection action to set the loop protection action.
Use undo onu protocol loopback-detection action to restore the default.
onu protocol loopback-detection action { no-learning | semi-block | shutdown }
The loop protection action of an ONU port is semi-block.
ONU port view
no-learning: Disables MAC address learning and generates a log when a loop is detected.
semi-block: Disables MAC address learning, generates a log, and blocks inbound traffic when a loop is detected.
shutdown: Shuts down the port and generates a log when a loop is detected. The device automatically sets the port to the forwarding state after the interval set by using the shutdown-interval command (see Fundamentals Command Reference).
# Set the loop protection action to semi-block on ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] onu protocol loopback-detection action semi-block
Use onu protocol smart-link flush enable to enable an ONU to send flush messages.
Use undo onu protocol smart-link flush enable to disable an ONU from sending flush messages.
onu protocol smart-link flush enable [ control-vlan vlan-id ]
An ONU does not send flush messages.
ONU port view
control-vlan vlan-id: Specifies the control VLAN for receiving flush messages. The VLAN ID is in the range of 1 to 4094, and the default control VLAN is VLAN 1.
# Enable the ONU bound to ONU 3/0/1:1 to send flush messages, and specify the control VLAN as VLAN 2.
[Sysname-Onu3/0/1:1] onu protocol smart-link flush enable control-vlan 2
Use onu protocol smart-link uni-bind enable to enable UNI count-based PON port activation for an ONU.
Use undo onu protocol smart-link uni-bind enable to disable UNI count-based PON port activation for an ONU.
This command is supported by ET824-E ONUs.
UNI count-based PON port activation is disabled for an ONU.
ONU port view
This command enables an ONU to activate the PON port that has more online UNIs if two PON ports are online.
# Enable UNI count-based PON port activation for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] onu protocol smart-link uni-bind enable
Use onu protocol transparent-multicast dest-mac to enable transparent transmission for a multicast MAC address.
Use undo onu protocol transparent-multicast dest-mac to disable transparent transmission for a multicast MAC address.
onu protocol transparent-multicast dest-mac mac-address
undo onu protocol transparent-multicast dest-mac mac-address
Transparent transmission is disabled for unknown multicast frames.
ONU port view
mac-address: Specifies a multicast MAC address. In the current software version, you can specify only 0100-ffff-ffff for a registered ONU.
By default, an ONU drops unknown multicast frames. This feature enables the ONU to flood frames destined for specific multicast MAC addresses.
If a multicast source is in the customer network connected to a UNI, enable transparent transmission for the corresponding multicast MAC address. This setting ensures that the other UNIs on the ONU can receive the multicast frames sent by the multicast source.
# Enable transparent transmission for multicast MAC address 0100-ffff-ffff for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] onu protocol transparent-multicast dest-mac 0100-ffff-ffff
Use qos cos-local-precedence-map to configure CoS-to-local priority mappings.
Use undo qos cos-local-precedence-map to restore the default.
qos cos-local-precedence-map cos0 cos1 cos2 cos3 cos4 cos5 cos6 cos7
Table 9 shows default CoS-to-local priority mappings.
Table 9 Default CoS-to-local priority mappings
CoS priority
Local precedence
0
0
1
0
2
1
3
1
4
2
5
2
6
3
7
3
ONU port view
cos0: Specifies the local precedence to be mapped to CoS priority 0, in the range of 0 to 3.
cos1: Specifies the local precedence to be mapped to CoS priority 1, in the range of 0 to 3.
cos2: Specifies the local precedence to be mapped to CoS priority 2, in the range of 0 to 3.
cos3: Specifies the local precedence to be mapped to CoS priority 3, in the range of 0 to 3.
cos4: Specifies the local precedence to be mapped to CoS priority 4, in the range of 0 to 3.
cos5: Specifies the local precedence to be mapped to CoS priority 5, in the range of 0 to 3.
cos6: Specifies the local precedence to be mapped to CoS priority 6, in the range of 0 to 3.
cos7: Specifies the local precedence to be mapped to CoS priority 7, in the range of 0 to 3.
This command takes effect only on downlink data flows.
# Configure CoS-to-local priority mappings on ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] qos cos-local-precedence-map 2 2 1 1 3 3 0 0
reboot onu
Use reboot onu to reboot an ONU.
reboot onu
ONU port view
This command takes effect only on online ONUs.
# Reboot the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] reboot onu
Use reset counters serial to clear packet statistics on a serial interface on an ONU.
reset counters serial interface-number
ONU port view
Before you use this command, make sure the ONU has serial interfaces.
# Clear packet statistics on serial interface 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] reset counters serial 1
reset counters uni
Use reset counters uni to clear packet statistics on UNIs of an ONU.
reset counters uni [ uni-number ]
ONU port view
uni-number: Specifies a UNI by its number. An ONU can have a maximum of 79 UNIs. If you do not specify this argument, the command clears packet statistics on all UNIs of the ONU.
# Clear packet statistics on UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] reset counters uni 1
serial databit
Use serial databit to set the number of data bits for a serial interface on an ONU.
Use undo serial databit to restore the default.
serial interface-number databit { 5 | 6 | 7 | 8 }
undo serial interface-number databit
The number of data bits is 8 for an ONU serial interface.
ONU port view
5: Sets the number of data bits to 5.
6: Sets the number of data bits to 6.
7: Sets the number of data bits to 7.
8: Sets the number of data bits to 8.
# Set the number of data bits to 5 for serial interface 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] serial 1 databit 5
serial parity
Use serial parity to set the parity type for a serial interface on an ONU.
Use undo serial parity to restore the default.
serial interface-number parity { even | mark | none | odd | space }
undo serial interface-number parity
The parity type of an ONU serial interface is none, which indicates that no parity is used.
ONU port view
even: Uses even parity.
mark: Uses mark parity.
none: Uses no parity.
odd: Uses odd parity.
space: Uses space parity.
# Set the parity type to odd for serial interface 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] serial 1 parity odd
Use serial session protocol-type to establish a session on a serial interface of an ONU.
Use undo serial session protocol-type to delete the session on a serial interface of an ONU.
serial interface-number session session-number protocol-type tcp-client server ip-address port port-number
serial interface-number session session-number protocol-type tcp-server listen-port port-number
serial interface-number session session-number protocol-type udp server ip-address port port-number listen-port port-number
undo serial interface-number session session-number protocol-type
No session is established on an ONU serial interface.
ONU port view
protocol-type tcp-client: Uses the ONU as the client of a TCP session.
protocol-type tcp-server: Uses the ONU as the server of a TCP session.
protocol-type udp: Uses the ONU as both the server and client of a UDP session.
server: Specifies a server.
port: Specifies a port on the server.
listen-port: Specifies a local listening port.
session-number: Specifies a session number. An ONU can have a maximum of 6 sessions.
ip-address: Specifies the IP address of the server.
port-number: Specifies the port number of the server, in the range of 1024 to 65535.
# Establish a TCP session on serial interface 1 of the ONU bound to ONU 3/0/1:1, and configure the ONU as the client of the session.
[Sysname-Onu3/0/1:1] serial 1 session 1 protocol-type tcp-client server 122.100.52.5
2 port 15
# Establish a TCP session on serial interface 1 of the ONU bound to ONU 3/0/1:1, and configure the ONU as the server of the session.
[Sysname-Onu3/0/1:1] serial 1 session 3 protocol-type tcp-server listen-port 2500
# Establish a UDP session on serial interface 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] serial 1 session 5 protocol-type udp server 3.3.2.5 port 4500 l
isten-port 75
# Delete the session on serial interface 1 of the ONU bound to ONU 3/0/1:1.
[Sysname] undo serial 1 session 4 protocol-type
serial speed
Use serial speed to set the baud rate for a serial interface of an ONU.
Use undo serial speed to restore the default.
serial interface-number speed { 300 | 600 | 1200 | 2400 | 4800 | 9600 | 19200 | 38400 | 57600 | 115200 }
undo serial interface-number speed
The baud rate of an ONU serial interface is 9600 bps.
ONU port view
300: Sets the baud rate to 300 bps.
600: Sets the baud rate to 600 bps.
1200: Sets the baud rate to 1200 bps.
2400: Sets the baud rate to 2400 bps.
4800: Sets the baud rate to 4800 bps.
9600: Sets the baud rate to 9600 bps.
19200: Sets the baud rate to 19200 bps.
38400: Sets the baud rate to 38400 bps.
57600: Sets the baud rate to 57600 bps.
115200: Sets the baud rate to 115200 bps.
# Set the baud rate to 300 bps for serial interface 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] serial 1 speed 300
serial stopbit
Use serial stopbit to set the number of stop bits for a serial interface of an ONU.
Use undo serial stopbit to restore the default.
serial interface-number stopbit { 1 | 1.5 | 2 }
undo serial interface-number stopbit
The number of stop bits is 1 for an ONU serial interface.
ONU port view
1: Sets the number of stop bits to 1.
1.5: Sets the number of stop bits to 1.5.
2: Sets the number of stop bits to 2.
# Set the number of stop bits to 1.5 for serial interface 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] serial 1 stopbit 1.5
Use shutdown management-vlan-interface to shut down the management VLAN interface of an ONU.
Use undo shutdown management-vlan-interface to bring up the management VLAN interface of an ONU.
The management VLAN interface of an ONU is down.
ONU port view
After you execute this command, the status of the management VLAN interface depends on the status of the UNIs in the management VLAN.
·     If all UNIs are down, the management VLAN interface is down.
·     If a minimum of one UNI is up, the management VLAN interface is up.
# Bring up the management VLAN interface of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] undo shutdown management-vlan-interface
uni auto-negotiation
Use uni auto-negotiation to enable autonegotiation on a UNI.
Use undo uni auto-negotiation to disable autonegotiation on a UNI.
uni uni-number auto-negotiation
undo uni uni-number auto-negotiation
Autonegotiation is enabled on a UNI.
ONU port view
On a UNI, do not enable autonegotiation and manually set the duplex mode, MDIX mode, or port rate at the same time.
# Enable autonegotiation on UNI 1 of the ONU bound to ONU 2/0/1:1.
[Sysname-Onu2/0/1:1] uni 1 auto-negotiation
uni classification-marking
Use uni classification-marking to configure priority marking on a UNI.
Use undo uni classification-marking to remove priority marking configuration from a UNI.
uni uni-number classification-marking index index queue qid priority priority { selector operator matched-value } & <1-4>
uni uni-number classification-marking index index queue qid priority priority { always-match | never-match }
undo uni uni-number classification-marking index index
Priority marking is not configured on a UNI.
ONU port view
index: Specifies an index in the range of 1 to 8. The smaller the index, the higher the priority.
qid: Assigns packets to a queue specified by its ID in the range of 0 to 7.
priority: Marks packets with a priority in the range of 0 to 7.
{ selector operator matched-value } & <1-4>: Specifies a maximum of four matching field and rule pairs.
·     selector: Specifies a matching field. Table 10 shows the available values.
·     operator: Specifies a matching rule. Table 11 shows the available values.
·     matched-value: Specifies the value of the matching field if the value of the operator argument is not exist or not-exist.
?     ip-address: Specifies an IP address.
?     mac-address: Specifies a MAC address. Do not specify an ONU MAC address bound to an ONU port for the dst-mac and src-mac fields.
?     port-number: Specifies a port number in the range of 0 to 65535.
?     priority: Specifies a CoS priority in the range of 0 to 7.
?     eth-type: Specifies an Ethernet frame type in the range of 0 to FFFF.
?     ip-dscp: Specifies a ToS priority or DSCP priority in the range of 0 to 63.
?     ip-type: Specifies an IP protocol type in the range of 0 to FF.
?     vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
always-match: Performs match for traffic classification.
never-match: Does not perform match.
Table 10 Values for the selector argument
selector
dst-ip
Matches the destination IP address.
dst-mac
Matches the destination MAC address.
dst-port
Matches the destination port number.
eth-pri
Matches the CoS priority.
eth-type
Matches the Ethernet frame type.
ip-precedence
Matches the IP precedence.
ip-tos-dscp
Matches the ToS priority or DSCP priority.
ip-type
Matches the IP protocol type.
src-ip
Matches the source IP address.
src-mac
Matches the source MAC address.
src-port
Matches the source port number.
vlan-id
Matches the VLAN ID.
Table 11 Values for the operator argument
operator
equal
The value of the matched-value argument must be equal to the value of the matching field of packets.
exist
The packets must contain the matching field.
not-equal
The value of the matched-value argument must be different from the value of the matching field of packets.
not-exist
The packets cannot contain the matching field.
greater-equal
The value of the matched-value argument must be greater than the value of the matching field of packets.
less-equal
The value of the matched-value argument must be smaller than the value of the matching field of packets.
Do not use the uni classification-marking commands together with the qos trust dscp command. For more information about the qos trust command, see ACL and QoS Command Reference.
# Configure UNI 1 of the ONU bound to ONU 3/0/1:1 to modify the priority to 3 for packet tagged with VLAN ID 10.
[Sysname] interface onu 3/0/1:1
[Sysname-Onu3/0/1:1] uni 1 classification-marking index 1 queue 3 priority 3 vlan-id
 equal 10
uni description
Use uni description to configure the description for a UNI.
Use undo uni description to restore the default.
uni uni-number description text
undo uni uni-number description
A UNI does not have a description.
ONU port view
text: Specifies the description, a string of 1 to 40 characters.
# Configure the description as Test for UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 description Test
uni duplex
Use uni duplex to set the duplex mode of a UNI.
Use undo uni duplex to restore the default.
uni uni-number duplex { auto | full | half }
undo uni uni-number duplex
A UNI is operating in full duplex mode.
ONU port view
auto: Specifies the auto mode.
full: Specifies the full duplex mode.
half: Specifies the half duplex mode.
Before you use this command, make sure autonegotiation is disabled on the UNI.
# Set the duplex mode to auto for UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 duplex auto
uni flow-control
Use uni flow-control to enable flow control for a UNI.
Use undo uni flow-control to disable flow control for a UNI.
uni uni-number flow-control
undo uni uni-number flow-control
Flow control is disabled for a UNI.
ONU port view
# Enable flow control for UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 flow-control
Use uni igmp-snooping fast-leave to enable fast-leave processing for a UNI.
Use undo uni igmp-snooping fast-leave to disable fast-leave processing for a UNI.
uni uni-number igmp-snooping fast-leave
undo uni uni-number igmp-snooping fast-leave
Fast-leave processing is disabled for a UNI.
ONU port view
You cannot use this command together with the onu multicast fast-leave enable command.
# Enable fast-leave processing for UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 igmp-snooping fast-leave
multicast mode
uni mdix-mode
Use uni mdix-mode to set the MDIX mode for a UNI.
Use undo uni mdix-mode to restore the default.
This command is not supported by ET254 ONUs.
uni uni-number mdix-mode { automdix | mdi | mdix }
undo uni uni-number mdix-mode
The MDIX mode of a UNI is automdix.
ONU port view
automdix: Negotiates pin roles with its peer.
mdi: Uses pins 1 and 2 as transmit pins and pins 3 and 6 as receive pins.
mdix: Uses pins 1 and 2 as receive pins and pins 3 and 6 as transmit pins.
# Set the MDIX mode to automdix for UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 mdix-mode automdix
uni mirroring-port
Use uni mirroring-port to configure a UNI as a mirroring source port.
Use undo uni mirroring-port to remove mirroring source port configuration from a UNI.
uni uni-number mirroring-port { both | inbound | outbound }
undo uni uni-number mirroring-port
A UNI is not a mirroring source port.
ONU port view
both: Specifies both inbound and outbound mirroring.
inbound: Specifies inbound mirroring.
outbound: Specifies outbound mirroring.
A UNI cannot be both a mirroring source port and destination port.
# Configure UNI 1 of the ONU bound to ONU 3/0/1:1 as a mirroring source port and enable both inbound and outbound mirroring.
[Sysname-Onu3/0/1:1] uni 1 mirroring-port both
uni monitor-port
uni monitor-port
Use uni monitor-port to configure a UNI as a mirroring destination port.
Use undo uni monitor-port to restore the default.
uni uni-number monitor-port
undo uni uni-number monitor-port
A UNI is not a mirroring destination port.
ONU port view
An ONU can have only one mirroring destination port. To change the mirroring destination port, first remove the original mirroring destination port.
# Configure UNI 1 of the ONU bound to ONU 3/0/1:1 as a mirroring destination port.
[Sysname-Onu3/0/1:1] uni 1 monitor-port
uni mirroring-port
uni multicast vlan
Use uni multicast vlan to assign a UNI to multicast VLANs on an ONU.
Use undo uni multicast vlan to remove a UNI from the specified or all multicast VLANs on an ONU.
uni uni-number multicast vlan vlan-id-list
undo uni uni-number multicast vlan { vlan-id-list | all }
A UNI is not assigned to any multicast VLANs.
ONU port view
vlan-id-list: Specifies a space-separated list of up to 15 multicast VLAN IDs in the range of 1 to 4094.
all: Specifies all multicast VLAN IDs.
On an ONU, UNIs can be assigned to a maximum of 15 multicast VLANs.
This command is available only on an ONU in IGMP snooping mode.
# Assign UNI 1 of the ONU bound to ONU 3/0/1:1 to multicast VLANs 2000 and 3000.
[Sysname-Onu3/0/1:1] uni 1 multicast vlan 2000 3000
multicast mode
uni multicast-control multicast-address
Use uni multicast-control multicast-address to configure the access to multicast channels on a UNI.
Use undo uni multicast-control multicast-address to restore the default.
uni uni-number multicast-control multicast-address multicast-address-list [ source-ip ip-address [ to ip-address ] ] rule { deny | permit [ channel-limit channel-number ] | preview time-slice preview-time [ preview-interval interval-time | preview-times preview-times [ reset-interval reset-interval-time ] ]* }
undo uni uni-number multicast-control multicast-address [ multicast-address-list ]
The access to multicast channels is not configured on a UNI.
ONU port view
multicast-address-list: Specifies a space-separated list of up to 10 multicast IP address items. Each item specifies a multicast IP address or a range of multicast IP address in the format of multicast-address1 to multicast-address2.
source-ip ip-address [ to ip-address ]: Specifies the IP address range of the multicast sources that issue multicast channels. The ip-address argument indicates the IP address of a multicast source.
deny: Denies user access to the specified multicast channels.
permit: Permits user access to the specified multicast channels.
channel-number: Specifies the number of channels that can be accessed at the same time when the permit keyword is specified. The value range for this argument is 1 to 5.
preview time-slice: Assigns users preview right to multicast channels within a specified time period.
preview-time: Specifies the preview period in the range of 1 to 3 minutes.
interval-time: Specifies the preview interval in the range of 1 to 10 minutes.
preview-times: Specifies the times of previews, in the range of 1 to 3.
reset-interval-time: Specifies the preview reset interval in the range of 1 to 43200 minutes. If the preset number of previews is reached, you must wait for a preview reset interval before the next preview.
If you specify the source-ip keyword, the OLT processes received IGMPv3 packets as follows:
·     For IS_IN, TO_IN, or ALLOW IGMPv3 packets:
?     If their multicast IP address and source IP address are in the address range that has multicast rights, the OLT creates multicast entries.
?     If this requirement is not met, the OLT drops the packets.
·     If the packet type is IS_EX or TO_EX, the OLT drops the packets.
·     If the packet type is BLOCK, the OLT directly deletes the corresponding multicast entries without checking the packet rights.
For more information about IS_IN, TO_IN, ALLOW, IS_EX, TO_EX, and BLOCK IGMPv3 packets, see IP Multicast Configuration Guide.
If you assign preview right to multiple multicast channels to users on a UNI, only one of the multicast channels can be previewed at a given time.
# Permit users on UNI 1 of the ONU bound to ONU 3/0/1:1 to access the multicast channel 224.1.1.2.
[Sysname-Onu3/0/1:1] uni 1 multicast-control multicast-address 224.1.1.2 rule permit
multicast mode
uni multicast-group-number
Use uni multicast-group-number to configure the number of multicast channels that users can access at the same time on a UNI.
Use undo multicast-group-number to restore the default.
uni uni-number multicast-group-number number
undo uni uni-number multicast-group-number
The users on a UNI can access 64 multicast channels at the same time.
ONU port view
number: Specifies the number of multicast channels, in the range of 0 to 255.
# Configure the number of multicast channels as 30 on UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 multicast-group-number 30
uni multicast-strip-tag enable
Use uni multicast-strip-tag enable to configure a UNI to remove the VLAN tag of downlink multicast flows.
Use undo uni multicast-strip-tag enable to restore the default.
uni uni-number multicast-strip-tag enable
undo uni uni-number multicast-strip-tag enable
A UNI does not remove the VLAN tag of downlink multicast flows.
ONU port view
# Configure UNI 1 of the ONU bound to ONU 3/0/1:1 to remove the VLAN tag of downlink multicast flows.
[Sysname-Onu3/0/1:1] uni 1 multicast-strip-tag enable
uni port-isolate
Use uni port-isolate to assign a UNI to the isolation group.
Use undo uni port-isolate to remove a UNI from the isolation group.
uni uni-number port-isolate
undo uni uni-number port-isolate
ONU port view
An ONU supports only one isolation group. The number of UNIs in the isolation group is not limited.
You cannot use this command together with the onu port-isolate enable command.
# Assign UNI 1 and UNI 2 of the ONU bound to ONU 3/0/1:1 to the isolation group.
[Sysname-Onu3/0/1:1] uni 1 port-isolate
[Sysname-Onu3/0/1:1] uni 2 port-isolate
uni port-policy inbound
Use uni port-policy inbound to configure uplink traffic policing on a UNI.
Use undo uni port-policy inbound to restore the default.
uni uni-number port-policy inbound { bucket-depth bucket-depth-value | cir cir-value | extra-burst-size extra-burst-size-value } *
undo uni uni-number port-policy inbound
The CBS is 1522 bytes, the CIR is not configured, and the EBS is 0 bytes.
ONU port view
bucket-depth bucket-depth-value: Specifies the CBS in the range of 1522 to 65535 bytes. The CBS is the maximum burst bandwidth.
cir cir-value: Specifies the CIR in the range of 64 to 1024000 Kbps. The value of the cir-value argument must be a multiple of 64.
extra-burst-size extra-burst-size-value: Specifies the EBS in the range of 0 to 1522 bytes.
# Configure uplink traffic policing on UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 port-policy inbound cir 640 bucket-depth 2000 extra-burst-size 1000
uni port-policy outbound
Use uni port-policy outbound to configure downlink traffic policing on a UNI.
Use undo uni port-policy outbound to restore the default.
uni uni-number port-policy outbound cir cir-value [ pir pir-value ]
undo uni uni-number port-policy outbound
Downlink traffic policing is not configured.
ONU port view
pir pir-value: Specifies the PIR in the range of 64 to 1024000 Kbps. The value of the pir-value argument must be a multiple of 64 and be larger than the CIR.
# Configure downlink traffic policing on UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 port-policy outbound cir 64 pir 640
uni qinq
Use uni qinq to add an SVLAN tag for packets with specific CVLAN tags, or enable transparent transmission for VLANs on a UNI.
Use undo uni qinq to remove QinQ configuration from a UNI.
uni uni-number qinq svlan svlan-id cvlan { cvlan-id-list | all }
undo uni uni-number qinq svlan svlan-id
uni uni-number qinq transparent-vlan { cvlan-id-list | all }
undo uni uni-number qinq transparent-vlan { cvlan-id-list | all }
QinQ is not configured on a UNI.
ONU port view
svlan svlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
cvlan-id-list: Specifies a space-separated list of up to 10 CVLAN ID items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value of vlan-id2 cannot be smaller than the value of vlan-id1. The value range for VLAN IDs is 1 to 4094.
all: Specifies all CVLAN IDs.
Before you can configure QinQ for a UNI, you must set its VLAN operation mode to QinQ.
Enable transparent transmission for VLANs that have special purposes, for example, a VLAN dedicated to a corporation or a management VLAN. When receiving packets tagged with the VLAN ID, the ONU does not add the SVLAN tag to the packets before forwarding them to the service provider network.
# Configure UNI 1 of the ONU bound to ONU 3/0/1:1 to add the SVLAN tag 20 for packets with a CVLAN tag of VLAN 3 or 4.
[Sysname-Onu3/0/1:1] uni 1 qinq svlan 20 cvlan 3 to 4
uni vlan-mode
uni restart auto-negotiation
Use uni restart auto-negotiation to force a UNI to restart autonegotiation.
uni uni-number restart auto-negotiation
ONU port view
This command is available only when autonegotiation is enabled.
# Force UNI 1 of the ONU bound to ONU 2/0/1:1 to restart autonegotiation.
[Sysname-Onu2/0/1:1] uni 1 restart auto-negotiation
uni shutdown
Use uni shutdown to shut down a UNI.
Use undo uni shutdown to bring up a UNI.
uni uni-number shutdown
undo uni uni-number shutdown
A UNI is up.
ONU port view
# Shut down UNI 1 of the ONU bound to ONU 2/0/1:1.
[Sysname-Onu2/0/1:1] uni 1 shutdown
uni speed
Use uni speed to set the rate of a UNI.
Use undo uni speed to restore the default.
uni uni-number speed { 10 | 100 | 1000 | auto }
undo uni uni-number speed
The rate of a UNI is 100 Mbps.
ONU port view
10: Sets the UNI rate to 10 Mbps.
100: Sets the UNI rate to 100 Mbps.
1000: Sets the UNI rate to 1000 Mbps.
auto: Enable auto rate negotiation.
# Set the rate to 10 Mbps for UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 speed 10
uni virtual-cable-test
Use uni virtual-cable-test to test the cable connected to a UNI.
uni uni-number virtual-cable-test
ONU port view
# Test the cable connected to UNI 1 of the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 virtual-cable-test
Cable status: abnormal(open), 0 metre(s)
Pair Impedance mismatch: -
Pair skew: - ns
Pair swap: -
Pair polarity: -
Insertion loss: - db
Return loss: - db
Near-end crosstalk: 4294967040 db
Table 12 Command output
Cable status
Cable status:
·     Normal.
·     Abnormal.
·     abnormal(open).
·     abnormal(short).
·     failure.
n metre(s)
If the cable is operating correctly, this field displays the total length of the cable.
If the cable is not operating correctly, this field displays the length of the cable between the UNI and the point of failure.
Pair skew
Pair skew. The hyphen (-) indicates that the test item is not supported.
Pair swap
Pair swap. The hyphen (-) indicates that the test item is not supported.
Pair polarity
Pair polarity. The hyphen (-) indicates that the test item is not supported.
Insertion loss
Insertion loss. The hyphen (-) indicates that the test item is not supported.
Return loss
Return loss. The hyphen (-) indicates that the test item is not supported.
Near-end crosstalk
Near-end crosstalk. The hyphen (-) indicates that the test item is not supported.
uni vlan-mode
Use uni vlan-mode to set the VLAN operation mode of a UNI.
Use undo uni vlan-mode to restore the default.
uni uni-number vlan-mode transparent
uni uni-number vlan-mode tag pvid pvid [ priority priority ]
uni uni-number vlan-mode translation pvid pvid [ priority priority ] { vlan-id to vlan-id } &<1-15>
uni uni-number vlan-mode qinq pvid pvid [ priority priority ]
undo uni uni-number vlan-mode
The VLAN operation mode of a UNI is transparent.
ONU port view
pvid: Specifies a PVID in the range of 1 to 4094.
priority priority: Specifies an 802.1p precedence in the range of 0 to 7.
{ vlan-id to vlan-id } &<1-15>: Specifies a maximum of 15 original VLAN ID and translated VLAN ID pairs. The value range for VLAN IDs is 1 to 4094.
If the link type of all ONU ports on an OLT port is access, you must set the VLAN operation mode to transparent for UNIs of the ONUs. This setting ensures that the ONU ports and users receive only untagged packets.
# Set the VLAN operation mode of UNI 1 to transparent for the ONU bound to ONU 1/0/1:1.
[Sysname] interface onu 1/0/1:1
[Sysname-Onu1/0/1:1] uni 1 vlan-mode transparent
# Set the VLAN operation mode of UNI 1 to tag for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 vlan-mode tag pvid 100 priority 3
# Set the VLAN operation mode of UNI 1 to translation for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu3/0/1:1] uni 1 vlan-mode translation pvid 100 priority 3 2 to 5
# Set the VLAN operation mode of UNI 1 to QinQ for the ONU bound to ONU 1/0/1:1.
[Sysname-Onu1/0/1:1] uni 1 vlan-mode qinq pvid 100 priority 3
update onu filename
Use update onu filename to update an ONU or all ONUs on an OLT port.
Use undo update onu to cancel the update configuration for an ONU or all ONUs on an OLT port.
update onu filename filename
undo update onu
OLT port view
ONU port view
filename: Specifies a file by its name, a string of 1 to 63 characters. The string can contain only letters, numbers, and special characters in Table 13. The file name is formed by the device name and the ONU update file name. If you do not specify a device name, the name of the Flash on the active MPU is used as the device name. The files on the standby MPU cannot be used for the update.
Table 13 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Plus sign
Exclamation point
Equal sign
At sign
Left brace
Pound sign
Right brace
Dollar sign
Left bracket
Percent sign
Right bracket
Caret
Backslash
Ampersand sign
Semi-colon
Left parenthesis
Apostrophe
Right parenthesis
Comma
Hyphen
Dot
Underscore
_
To update a single ONU, use this command in ONU port view. To update all ONUs on an OLT port, use this command in OLT port view.
This command issues the update file to ONUs.
·     If an ONU is online and matches the update file, the ONU is updated.
·     If an ONU is online but does not match the update file, the ONU is not updated.
·     If an ONU that matches the update file is not online, the ONU is updated when it is online. An ONU is not online if it is not bound to an ONU port, or the extended OAM connection is not established.
After you use this command in OLT port view, whether the OLT updates a matching ONU that newly comes online depends on the creation time of the corresponding ONU port.
·     If the ONU port is created before you execute this command, the ONU will be updated.
·     If the ONU port is created after you execute this command, the ONU will not be updated.
# Update the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] update onu filename file.app
Update flash:/file.app?[Y/N] Y
update onu type
Use update onu type to update ONUs by type.
Use undo update onu type to cancel the update configuration for an ONU type.
update onu type onu-type filename filename
undo update onu type onu-type
FTTH view
onu-type: Specifies an ONU type, a case-insensitive string of 1 to 16 characters. The string can contain only letters, numbers, and special characters in Table 14.
Table 14 Special characters
Character name
Symbol
Character name
Symbol
Tilde
Plus sign
Exclamation point
Equal sign
At sign
Left brace
Pound sign
Right brace
Dollar sign
Left bracket
Percent sign
Right bracket
Caret
Backslash
Ampersand sign
Semi-colon
Left parenthesis
Apostrophe
Right parenthesis
Comma
Hyphen
Dot
Underscore
_
filename: Specifies a file by its name, a string of 1 to 63 characters. The string can contain only letters, numbers, and special characters in Table 14. The file name is formed by the device name and the ONU update file name. If you do not specify a device name, the name of the Flash on the active MPU is used as the device name. The files on the standby MPU cannot be used for the update.
This command enables the OLT to automatically update ONUs that match the specified ONU type and do not have an update file. The OLT updates ONUs as follows:
·     If a matching ONU is online, the ONU is updated.
·     If a matching ONU is not online, the ONU is updated when it is online. An ONU is not online if it is not bound to an ONU port, or the extended OAM connection is not established.
You can update a maximum of 64 types of ONUs at the same time.
# Update all ET704-A-L ONUs.
[Sysname] ftth
[Sysname-ftth] update onu type et704-a-l filename file.app
upstream-sla
Use upstream-sla to specify the uplink bandwidth range for an ONU.
Use undo upstream-sla to restore the default.
upstream-sla { fixed-bandwidth fixed-value | maximum-bandwidth max-value | minimum-bandwidth min-value } *
undo upstream-sla
The fixed uplink bandwidth is 0 kbps, the maximum uplink bandwidth is 23552 kbps, and the minimum uplink bandwidth is 2048 kbps.
ONU port view
fixed-bandwidth fixed-value: Sets the fixed uplink bandwidth in the range of 0 to 14843. The unit of the fixed-value argument is 64 kbps.
maximum-bandwidth max-value: Sets the maximum uplink bandwidth in the range of 8 to 15625. The unit of the max-value argument is 64 kbps.
minimum-bandwidth min-value: Sets the minimum uplink bandwidth in the range of 8 to 15000. The unit of the min-value argument is 64 kbps.
On an ONU port, the sum of the minimum uplink bandwidth and the fixed uplink bandwidth cannot be greater than the maximum uplink bandwidth.
Make sure the total minimum uplink bandwidth of ONUs does not exceed 972800 kbps on an OLT port.
# Set the minimum uplink bandwidth to 9600 kbps and the maximum uplink bandwidth to 12800 kbps,for the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] upstream-sla minimum-bandwidth 150 maximum-bandwidth 200
using onu
Use using onu to create ONU ports.
Use undo using onu to delete ONU ports.
using onu onu-number-list
undo using onu onu-number-list
No ONU ports exist.
OLT port view
onu-number-list: Specifies a space-separated list of up to 10 ONU port number items. Each item specifies an ONU port number or a range of ONU port numbers in the format of onu-number1 to onu-number2. The value of onu-number2 cannot be smaller than the value of onu-number1. The value range for ONU port numbers is 1 to 64.
# Create ONU port 1 on OLT 2/0/2.
[sysname] interface olt 2/0/2
[sysname-Olt2/0/2] using onu 1
voip-port shutdown
Use voip-port shutdown to shut down a VoIP interface on an ONU.
Use undo voip-port shutdown to bring up a VoIP interface on an ONU.
voip-port port-number shutdown
undo voip-port port-number shutdown
A VoIP interface is down on an ONU.
ONU port view
port-number: Specifies a VoIP interface by its number.
# Bring up VoIP interface 1 on the ONU bound to ONU 3/0/1:1.
[Sysname-Onu3/0/1:1] undo voip-port 1 shutdown
EPON alarm commands
alarm device-fatal-error enable
Use alarm device-fatal-error enable to enable the device fatal error alarm.
Use undo alarm device-fatal-error enable to disable the device fatal error alarm.
The device fatal error alarm is enabled.
FTTH view
OLT port view
This alarm is sent if an error that causes system unavailability occurs, such as memory leak and high memory usage.
If you configure this alarm in OLT port view, the configuration takes effect only on the OLT port. If you configure this alarm in FTTH view, the configuration takes effect on all OLT ports.
If you configure this alarm in both OLT port view and FTTH view, the most recent configuration takes effect on the OLT port.
# Enable the device fatal error alarm on OLT 3/0/1.
[Sysname] interface olt 3/0/1
[Sysname-Olt3/0/1] alarm device-fatal-error enable
alarm oam critical-event enable
Use alarm oam critical-event enable to enable the critical event alarm.
Use undo alarm oam critical-event enable to disable the critical event alarm.
The critical event alarm is enabled.
FTTH view
OLT port view
This alarm is sent if the local link fault or dying gasp alarm is sent.
# Enable the critical event alarm on OLT 3/0/1.
[Sysname-Olt3/0/1] alarm oam critical-event enable
alarm oam dying-gasp enable
Use alarm oam dying-gasp enable to enable the dying gasp alarm.
Use undo alarm oam dying-gasp enable to disable the dying gasp alarm.
The dying gasp alarm is enabled.
FTTH view
OLT port view
This alarm is sent if an irrecoverable error occurs, such as a system error and a data loading error.
# Enable the dying gasp alarm on OLT 3/0/1.
[Sysname-Olt3/0/1] alarm oam dying-gasp enable
alarm oam local-link-fault enable
Use alarm oam local-link-fault enable to enable the local link fault alarm.
Use undo alarm oam local-link-fault enable to disable the local link fault alarm.
The local link fault alarm is enabled.
FTTH view
OLT port view
This alarm is sent if a fault occurs in the inbound direction on the OLT.
# Enable the local link fault alarm on OLT 3/0/1.
[Sysname-Olt3/0/1] alarm oam local-link-fault enable
alarm onu-laser always-on enable
Use alarm onu-laser always-on enable to enable the ONU laser always on alarm.
Use undo alarm onu-laser always-on enable to disable the ONU laser always on alarm.
The ONU laser always on alarm is enabled.
FTTH view
OLT port view
This alarm is sent if an ONU keeps sending optical signals for a long period of time.
# Enable the ONU laser always on alarm on OLT 3/0/1.
[Sysname-Olt3/0/1] alarm onu-laser always-on enable
alarm onu-over-limit enable
Use alarm onu-over-limit enable to enable the ONU over limit alarm.
Use undo alarm onu-over-limit enable to disable the ONU over limit alarm.
The ONU over limit alarm is enabled.
FTTH view
OLT port view
This alarm is sent if the number of ONUs connected to the OLT reaches the upper limit.
# Enable the ONU over limit alarm on OLT 3/0/1.
[Sysname-Olt3/0/1] alarm onu-over-limit enable
alarm registration-error enable
Use alarm registration-error enable to enable the registration error alarm.
Use undo alarm registration-error enable to disable the registration error alarm.
The registration error alarm is enabled.
FTTH view
OLT port view
This alarm is sent if an error occurs during ONU registration.
# Enable the registration error alarm on OLT 3/0/1.
[Sysname] interface olt3/0/1
[Sysname-Olt3/0/1] alarm registration-error enable
monitor enable
Use monitor enable to enable alarm monitoring.
Use undo monitor enable to disable alarm monitoring.
monitor enable
undo monitor enable
Alarm monitoring is enabled.
FTTH view
# Enable alarm monitoring.
[Sysname] ftth
[Sysname-ftth] monitor enable
timer monitor
timer monitor
Use timer monitor to set the alarm monitoring interval.
Use undo timer monitor to restore the default.
timer monitor seconds
undo timer monitor
The alarm monitoring interval is 80 seconds.
FTTH view
seconds: Specifies an interval in the range of 1 to 3600 seconds.
# Set the alarm monitoring interval to 100 seconds.
[Sysname] ftth
[Sysname-ftth] timer monitor 100
monitor enable
BCMP proxy commands
bcmp-proxy enable
Use bcmp-proxy enable to enable the BCMP proxy feature.
Use undo bcmp-proxy enable to disable the BCMP proxy feature.
bcmp-proxy enable
The BCMP proxy feature is disabled.
An OLT with this feature enabled operates as a BCMP proxy to forward member registration information and configuration between the BCMP server and BCMP clients.
# Enable the BCMP proxy feature.
[Sysname] bcmp-proxy enable
bcmp-proxy server address
Use bcmp-proxy server address to specify the IP address of the BCMP server.
Use undo bcmp-proxy server address to restore the default.
bcmp-proxy server address ip-address
The IP address of the BCMP server is not specified.
For a BCMP proxy to communicate with a BCMP server, you must specify the IP address of the server on the BCMP proxy.
# Specify 1.1.1.1 as the IP address of the BCMP server.
[Sysname] bcmp-proxy server address 1.1.1.1
bcmp-proxy enable
bcmp-proxy server port
Use bcmp-proxy server port to specify the port number of the BCMP server.
Use undo bcmp-proxy server port to restore the default.
bcmp-proxy server port port-number
The port number of the BCMP server is 5000.
port-number: Specifies a port number in the range of 1 to 65535.
Use this command to specify the UDP port number that the BCMP proxy and the BCMP server use to establish a UDP connection. The BCMP proxy and the BCMP server can communicate only after the UDP connection is set up.
# Specify 2000 as the port number of the BCMP server.
[Sysname] bcmp-proxy server port 2000
bcmp-proxy enable
bcmp-proxy vlan
Use bcmp-proxy vlan to specify the BCMP VLAN.
Use undo bcmp-proxy vlan to restore the default.
bcmp-proxy vlan vlan-id
The BCMP VLAN is 4041.
The BCMP proxy communicates with BCMP clients only in the BCMP VLAN.
# Specify VLAN 100 as the BCMP VLAN.
[Sysname] bcmp-proxy vlan 100
bcmp-proxy enable
