04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Command References-R752X-6W10004-Layer 2 - LAN Switching Command Reference
02-Ethernet link aggregation commands
02-Ethernet link aggregation commands 120.75 KB
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth to 10000 kbps for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface 1.
[Sysname-Bridge-Aggregation1] default
description
The description of an interface is interface-name Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
# Configure the description as connect to the lab for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
interface-number.subnumber: Specifies an existing subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.).
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an aggregate interface type, the command displays information about all interfaces.
If you specify an aggregate interface type but do not specify an interface number, the command displays information about all aggregate interfaces of the specified type.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
IP packet frame type: Ethernet II, hardware address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 1000 kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: Access
 Tagged VLANs:   None
 UnTagged VLANs: 1
Last 300 seconds input:  6900 packets/sec 885160 bytes/sec    0%
Last 300 seconds output:  3150 packets/sec 404430 bytes/sec    0%
Input (total):  5364747 packets, 686688416 bytes
         2682273 unicasts, 1341137 broadcasts, 1341337 multicasts, 0 pauses
Input (normal):  5364747 packets, 686688416 bytes
         - ignored, - parity errors
Output (total): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, - pauses
Output (normal): 1042508 packets, 133441832 bytes
         1042306 unicasts, 0 broadcasts, 202 multicasts, 0 pauses
         - lost carrier, - no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Line protocol state: UP
Description: Route-Aggregation1 Interface
IP packet frame type: Ethernet II, hardware address: 0000-0000-0000
IPv6 packet frame type: Ethernet II, hardware address: 0000-0000-0000
Port priority: 0
    0 packets input, 0 bytes, 0 drops
    0 packets output, 0 bytes, 0 drops
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Speed: (a) – auto
BAGG1                UP   auto    A      A    1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Protocol: (s) - spoofing
RAGG1                UP   UP       --
Bridge-Aggregation1
Layer 2 aggregate interface name.
Route-Aggregation1
Layer 3 aggregate interface name.
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
IPv4 packet framing format.
Description of the interface.
Bandwidth
Expected bandwidth of the interface. This field is not displayed when the bandwidth is 0 kbps.
Port priority
Port priority of the interface.
Information about the urgent output queue:
·     Size—Number of packets in the queue.
·     Length—Maximum number of packets that the queue can contain.
·     Discards—Number of dropped packets.
Information about the protocol output queue:
Information about the FIFO output queue:
The interface speed and duplex mode are unknown.
Port link-type
Port link type:
·     Access.
·     Trunk.
·     Hybrid.
Tagged VLANs
VLAN whose packets are sent out of this interface with a tag.
Untagged VLANs
VLAN whose packets are sent out of this interface without a tag.
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Last 300 seconds input/output rate
Average input or output rate over the last 300 seconds.
Input/Output (total)
Statistics of all packets received or sent on the interface.
Input/Output (normal)
Statistics of all normal packets received or sent on the interface.
Line protocol state
Data link layer state of the interface:
·     UP.
·     DOWN.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
Internet address
IP address of the interface. The primary attribute indicates that the address is the primary IP address.
Brief information about Layer 3 interfaces.
Brief information about Layer 2 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state.
Speed
Speed of the interface, in bps.
This field displays the (a) flag next to the speed if the speed is automatically negotiated.
This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started.
Duplex
Duplex mode of the interface:
·     A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started.
·     F—Full duplex.
·     F(a)—Autonegotiated full duplex.
·     H—Half duplex.
·     H(a)—Autonegotiated half duplex.
Link type of the interface:
·     A—Access.
·     H—Hybrid.
·     T—Trunk.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN.
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed in hexadecimal format in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Local system ID, which contains the system LACP priority (0x8000 in this sample output) and the system MAC address (0000-FC00-6504 in this sample output).
display link-aggregation load-sharing mode
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
The bridge-aggregation or route-aggregation keyword is available only when the corresponding aggregate interfaces exist on the device.
# Display the default global link-aggregation load sharing modes.
<Sysname> display link-aggregation load-sharing mode
Link-aggregation load-sharing mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the set global link-aggregation load sharing mode.
destination-mac address, source-mac address
# Display the default link-aggregation load sharing modes of Layer 2 aggregation group 10.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 10
Bridge-Aggregation10 load-sharing mode:
# Display the set link-aggregation load sharing mode of Layer 2 aggregation group 10.
Global link-aggregation load sharing mode.
By default, this field displays the link-aggregation load sharing modes for Layer 2, Layer 3, Layer 4, and MPLS traffic.
If you have set the global link-aggregation load sharing mode, this field displays the set mode.
Link-aggregation load sharing mode of Layer 2 aggregation group 10.
By default, this field displays the global link-aggregation load sharing modes.
If you have set a link-aggregation load sharing mode for this aggregation group, this field displays the set mode.
Route-Aggregation10 load-sharing mode
Link-aggregation load sharing mode of Layer 3 aggregation group 10.
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, Layer 2 traffic is load shared based on the packet type.
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, Layer 3 traffic is load shared based on the packet type.
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses.
display link-aggregation member-port
Use display link-aggregation member-port to display detailed link aggregation information for the specified member ports.
display link-aggregation member-port [ interface-list ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
A member port in a static aggregation group cannot obtain information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed link aggregation information for Ten-GigabitEthernet 1/0/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port ten-gigabitethernet 1/0/1
       G -- Defaulted, H -- Expired
Ten-GigabitEthernet1/0/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed link aggregation information for Ten-GigabitEthernet 1/0/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port ten-gigabitethernet 1/0/2
Ten-GigabitEthernet1/0/2:
Aggregate Interface: Bridge-Aggregation10
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Flags
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. A letter appears when its bit is 1 and does not appear when its bit is 0.
·     A—Indicates whether LACP is active on the port. 1 indicates active. 0 indicates passive.
·     B—Indicates the LACP timeout interval. 1 indicates the short timeout interval. 0 indicates the long timeout interval.
·     C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes. 0 indicates no.
·     D—Indicates whether the sending system considers that the link has been aggregated. 1 indicates yes. 0 indicates no.
·     E—Indicates whether the sending system considers that the link can collect frames. 1 indicates yes. 0 indicates no.
·     F—Indicates whether the sending system considers that the link can distribute frames. 1 indicates yes. 0 indicates no.
·     G—Indicates whether the RX state machine of the sending system is in default state. 1 indicates yes. 0 indicates no.
·     H—Indicates whether the RX state machine of the sending system is in expired state. 1 indicates yes. 0 indicates no.
Aggregate Interface
Aggregate interface to which the member port belongs.
Local
Information about the local end.
Oper-key
Operational key.
Flag
LACP protocol state flag.
Remote
Information about the peer end.
System ID
Peer system ID, containing the system LACP priority and the system MAC address.
Total number of LACP packets received.
Illegal
Total number of illegal packets.
Sent LACP Packets
Total number of LACP packets sent.
display link-aggregation summary
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups cannot obtain information about the peer groups. As a result, the Partner ID field displays None or nothing for a static link aggregation group.
# Display brief information about all aggregation groups.
<Sysname> display link-aggregation summary
Aggregate Interface Type:
BAGG -- Bridge-Aggregation, BLAGG –- Blade-Aggregation, RAGG -- Route-Aggregation, SCH-B – Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 000f-e267-6c6a
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
RAGG10     S     None                    1         0           0           NonS
BAGG20     D     0x8000,00e0-fcff-ff01   2         0           0           Shar
SCH-B1     S     None                    0         0           0           Shar
Table 5 Command output
Aggregate interface type:
·     BAGG—Layer 2.
·     RAGG—Layer 3.
Aggregation Mode
Aggregation group type:
·     S—Static.
·     D—Dynamic.
Loadsharing Type
Load sharing type:
·     Shar—Load-sharing.
·     NonS—Non-load-sharing.
Actor System ID
Local system ID, which contains the local system LACP priority and the local system MAC address.
AGG Interface
Type and number of the aggregate interface.
AGG Mode
Aggregation group type.
Partner ID
System ID of the peer system, which contains the peer system LACP priority and the peer system MAC address.
Selected Ports
Total number of Selected ports.
Unselected Ports
Total number of Unselected ports.
Individual Ports
Total number of Individual ports.
Share Type
Load sharing type.
display link-aggregation verbose
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
interface-number: Specifies an existing aggregate interface by its number.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
If you specify an aggregate interface type but do not specify an interface number, the command displays detailed information about all aggregation groups of the specified type.
# Display detailed information about Layer 2 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 10
Port: A -- Auto port, M -- Management port, R -- Reference port
Aggregation Mode: Dynamic
Management VLANs: None
Local:
  Port                Status   Priority Index    Oper-Key               Flag
  XGE1/0/1            S        32768    61       2                      {ACDEF}
  XGE1/0/2            S        32768    62       2                      {ACDEF}
  XGE1/0/3            S        32768    63       2                      {AG}
Remote:
  Actor               Priority Index    Oper-Key SystemID               Flag
  XGE1/0/1(R)         32768    111      2        0x8000, 000f-e267-57ad {ACDEF}
  XGE1/0/2            32768    112      2        0x8000, 000f-e267-57ad {ACDEF}
  XGE1/0/3            32768    113      0        0x8000, 0000-0000-0000 {DEF}
# Display detailed information about Layer 2 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
  Port             Status  Priority Oper-Key
  XGE1/0/1         U       32768    1
  XGE1/0/2         U       32768    1
  XGE1/0/3         U       32768    1
Table 6 Command output
Loadsharing Type
Load sharing type:
Port Status
Port state:
·     Selected.
·     Unselected.
·     Individual.
Port
Port type:
·     Auto port—The port is enabled with automatic link aggregation. This type is not supported in the current software version.
·     Management port—The port is a management port. This type is not supported in the current software version.
·     Reference port—The port is a reference port.
Flags
Aggregate Interface
Name of the aggregate interface.
Aggregation Mode
·     S—Static.
·     D—Dynamic.
Management VLANs
Management VLANs. If no management VLANs are specified, this field displays None.
System ID
Local system ID, containing the local system LACP priority and the local system MAC address.
Local
Information about the local end:
·     Port—Port type and number.
·     Status—Port state, which can be Selected, Unselected, or Individual.
·     Priority—Port priority.
·     Index—Port index.
·     Oper-Key—Operational key.
·     Flag—LACP state flag.
For static aggregation groups, the Flag field is not displayed.
Remote
Information about the peer end:
·     Actor—Type and number of the local port. This field displays the (R) flag next to the port if its peer port is the reference port.
·     Priority—Priority of the peer port.
·     Index—Index of the peer port.
·     Oper-Key—Operational key of the peer port.
·     System ID—System ID of the peer end.
·     Flag—LACP state flag of the peer end.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter its view, or enter the view of an existing Layer 2 aggregate interface.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
Use interface route-aggregation to create a Layer 3 aggregate interface or subinterface and enter its view, or enter the view of an existing Layer 3 aggregate interface or subinterface.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface or subinterface.
undo interface route-aggregation { interface-number | interface-number.subnumber }
No Layer 3 aggregate interfaces or subinterfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
interface-number.subnumber: Specifies a subinterface of a Layer 3 aggregate interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
Deleting a Layer 3 aggregate subinterface does not affect the state of the main interface and the corresponding aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
[Sysname-Route-Aggregation1]
# Create Layer 3 aggregate subinterface Route-Aggregation 1.1 and enter its view.
[Sysname] interface route-aggregation 1.1
[Sysname-Route-Aggregation1.1]
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface that connects the device to a server if dynamic link aggregation is configured only on the device. This feature improves link reliability by enabling all member ports of the aggregation group to forward packets.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as an edge aggregate interface.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP operates in active mode on a port.
This command takes effect only on member ports of dynamic aggregation groups.
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
# Configure LACP to operate in passive mode on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] lacp mode passive
lacp period short
Use lacp period short to set the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds) on an interface.
To avoid traffic interruption during an ISSU, do not set the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Set the short LACP timeout interval (3 seconds) on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] lacp period short
Use lacp system-priority to set the system LACP priority.
Use undo lacp system-priority to restore the default.
lacp system-priority priority
The system LACP priority is 32768.
priority: Specifies the system LACP priority in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
link-aggregation port-priority
link-aggregation global load-sharing mode
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | source-ip | source-mac | source-port } *
The system automatically chooses link-aggregation load sharing mode based on packet types.
destination-ip: Load shares traffic based on destination IP addresses.
destination-mac: Load shares traffic based on destination MAC addresses.
destination-port: Load shares traffic based on destination ports.
ingress-port: Load shares traffic based on ingress ports.
source-ip: Load shares traffic based on source IP addresses.
source-mac: Load shares traffic based on source MAC addresses.
source-port: Load shares traffic based on source ports.
If an unsupported load sharing mode is set, an error prompt appears.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
link-aggregation ignore vlan
Use link-aggregation ignore vlan to configure a Layer 2 aggregate interface to ignore the specified VLANs.
Use undo link-aggregation ignore vlan to remove the specified ignored VLANs for a Layer 2 aggregate interface.
link-aggregation ignore vlan vlan-id-list
undo link-aggregation ignore vlan vlan-id-list
A Layer 2 aggregate interface does not ignore any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
With this command configured, a Layer 2 aggregate interface ignores the permitted VLAN and VLAN tagging mode configuration of the specified VLANs when choosing Selected ports.
# Configure Layer 2 aggregate interface bridge-aggregation 1 to ignore VLAN 50.
[Sysname-Bridge-Aggregation1] link-aggregation ignore vlan 50
link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
This feature redirects traffic on a Selected port to the remaining available Selected ports of an aggregation group if one of the following events occurs:
·     The port is shut down by using the shutdown command.
·     The slot that hosts the port reboots, and the aggregation group spans multiple slots.
This feature ensures zero packet loss for known unicast traffic, but does not protect unknown unicast traffic.
This feature applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
To prevent packet loss that might occur when a slot reboots, do not enable spanning tree together with link-aggregation traffic redirection.
Global link-aggregation traffic redirection settings take effect on all aggregation groups. A link aggregation group preferentially uses the group-specific link-aggregation traffic redirection settings. If group-specific link-aggregation traffic redirection is not configured, the group uses the global link-aggregation traffic redirection settings.
As a best practice, enable link-aggregation traffic redirection on aggregate interfaces. If you enable this feature globally, communication with a third-party peer device might be affected if the peer is not compatible with this feature.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode for an aggregation group.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { { destination-ip | destination-mac | mpls-label1 | mpls-label2 | source-ip | source-mac } * | flexible }
The group-specific load sharing mode is the same as the global load sharing mode.
mpls-label1: Load shares MPLS traffic based on Layer 1 labels.
mpls-label2: Load shares MPLS traffic based on Layer 2 labels.
flexible: Load shares traffic flexibly based on the packet types (Layer 2 protocol packet, IPv4 packet, IPv6 packet, or MPLS packet).
# Configure Layer 2 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
link-aggregation load-sharing mode local-first
Use link-aggregation load-sharing mode local-first to enable local-first load sharing for link aggregation.
Use undo link-aggregation load-sharing mode local-first to disable local-first load sharing for link aggregation.
Local-first load sharing is enabled for link aggregation.
After you disable local-first load sharing, the packets will be load shared among all Selected ports of the aggregate interface on all IRF member devices.
# Disable local-first load sharing for link aggregation.
[Sysname] undo link-aggregation load-sharing mode local-first
link-aggregation mode
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode and enable LACP.
Use undo link-aggregation mode to restore the default.
An aggregation group operates in static aggregation mode.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
The port priority of an interface is 32768.
priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface Ten-GigabitEthernet 1/0/2.
[Sysname-Ten-GigabitEthernet1/0/2] link-aggregation port-priority 64
link-aggregation selected-port maximum
Use link-aggregation selected-port maximum to set the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum max-number
The maximum number of Selected ports allowed in an aggregation group depends on hardware limitation.
max-number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 32.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
The maximum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
·     Maximum number set by using the link-aggregation selected-port maximum command.
·     Maximum number of Selected ports allowed by the link aggregation capability.
You can implement backup between two ports by performing the following tasks:
·     Assigning two ports to an aggregation group.
·     Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
link-aggregation selected-port minimum
Use link-aggregation selected-port minimum to set the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
The minimum number of Selected ports in an aggregation group is not specified.
min-number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 32.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups must be the same for the local and peer ends.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
mtu
Use mtu to set the MTU for a Layer 3 aggregate interface or subinterface.
mtu size
undo mtu
The MTU for Layer 3 aggregate interfaces and subinterfaces is 1500 bytes.
size: Specifies the MTU in bytes. The value range for this argument is 46 to 1560.
# Set the MTU to 1430 bytes for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mtu 1430
display interface
port link-aggregation group
Use port link-aggregation group to assign an interface to an aggregation group.
Use undo port link-aggregation group to remove an interface from the aggregation group to which it belongs.
An interface does not belong to any aggregation group.
group-id: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 1024.
A Layer 2 Ethernet interface can be assigned to a Layer 2 aggregation group only. A Layer 3 Ethernet interface can be assigned to a Layer 3 aggregation group only.
An interface can belong to only one aggregation group.
# Assign Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/1 to Layer 2 aggregation group 1.
[Sysname-Ten-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface Ten-GigabitEthernet 1/0/2 to Layer 3 aggregation group 2.
[Sysname-Ten-GigabitEthernet1/0/2] port link-aggregation group 2
Use reset counters interface to clear statistics for the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number | interface-number.subnumber ] ]
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify an aggregate interface type, the command clears statistics for all interfaces in the system.
If you specify only an aggregate interface type, the command clears statistics for all aggregate interfaces of the specified type.
# Clear statistics for Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number1 [ to interface-type interface-number2 ]. The value for the interface-type interface-number1 argument must be equal to or greater than the value for the interface-type interface-number2 argument. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an aggregate interface or subinterface.
Use undo shutdown to bring up an aggregate interface or subinterface.
shutdown
An aggregate interface or subinterface is up.
Shutting down or bringing up a Layer 3 aggregate interface shuts down or brings up its subinterfaces. Shutting down or bringing up a Layer 3 aggregate subinterface does not affect its main interface.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
