- 06-Layer 3 - IP Routing Configuration Guide
- 01-Basic IP routing configuration
- 02-Static routing configuration
- 03-RIP configuration
- 04-OSPF configuration
- 05-IS-IS configuration
- 06-BGP configuration
- 07-Policy-based routing configuration
- 08-IPv6 static routing configuration
- 09-RIPng configuration
- 10-OSPFv3 configuration
- 11-IPv6 IS-IS configuration
- 12-IPv6 policy-based routing configuration
- 13-Routing policy configuration
- 14-DCN configuration
| 11-IPv6 IS-IS configuration | 213.89 KB |
Configuring IPv6 IS-IS route control
Configuring IPv6 IS-IS link cost
Tuning and optimizing IPv6 IS-IS networks
Assigning a convergence priority to IPv6 IS-IS routes
Configuring a tag value on an interface
Controlling SPF calculation interval
Configuring BFD for IPv6 IS-IS
Displaying and maintaining IPv6 IS-IS
IPv6 IS-IS configuration examples
IPv6 IS-IS basic configuration example
BFD for IPv6 IS-IS configuration example
IPv6 IS-IS FRR configuration example
Overview
IPv6 IS-IS supports all IPv4 IS-IS features except that it advertises IPv6 routing information. This chapter describes only IPv6 IS-IS specific configuration tasks. For information about IS-IS, see "Configuring IS-IS."
Intermediate System-to-Intermediate System (IS-IS) supports multiple network protocols, including IPv6. To support IPv6, the IETF added two type-length-values (TLVs) and a new network layer protocol identifier (NLPID).
The TLVs are as follows:
· IPv6 Reachability—Contains routing prefix and metric information to describe network reachability and has a type value of 236 (0xEC).
· IPv6 Interface Address—Same as the "IP Interface Address" TLV in IPv4 ISIS, except that the 32-bit IPv4 address is translated to the 128-bit IPv6 address.
The new NLPID is an 8-bit field that identifies which network layer protocol is supported. For IPv6, the NLPID is 142 (0x8E), which must be carried in hello packets sent by IPv6 IS-IS.
Configuring basic IPv6 IS-IS
Before you configure basic IPv6 IS-IS, complete the following tasks:
· Configure IPv6 addresses for interfaces to ensure IPv6 connectivity between neighboring nodes.
· Enable IS-IS.
Basic IPv6 IS-IS configuration can implement the interconnection of IPv6 networks.
To configure basic IPv6 IS-IS:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable an IS-IS process and enter IS-IS view. |
isis [ process-id ] [ vpn-instance vpn-instance-name ] |
By default, no IS-IS process is enabled. |
3. Configure the network entity title (NET) for the IS-IS process. |
network-entity net |
By default, no NET is configured. |
4. Create the IPv6 address family and enter its view. |
address-family ipv6 [ unicast ] |
By default, no IS-IS IPv6 address family exists. |
5. Return to IS-IS view. |
quit |
N/A |
6. Return to system view. |
quit |
N/A |
7. Enter interface view. |
N/A |
8. Enable IPv6 for IS-IS on the interface. |
isis ipv6 enable [ process-id ] |
By default, IPv6 is disabled for IS-IS on an interface. |
Before you configure IPv6 IS-IS route control, complete basic IPv6 IS-IS configuration.
To configure IPv6 IS-IS route control:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter IS-IS view. |
N/A |
3. Enter IS-IS IPv6 address family view. |
N/A |
4. Specify a preference for IPv6 IS-IS routes. |
preference { route-policy route-policy-name | preference } * |
By default, the default setting is 15. |
5. Configure an IPv6 IS-IS summary route. |
summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] * |
By default, no IPv6 IS-IS summary route is configured. |
6. Configure IPv6 IS-IS to advertise a default route. |
default-route-advertise [ avoid-learning | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] * |
By default, IPv6 IS-IS does not advertise Level-1 and Level-2 default routes. |
7. Configure IPv6 IS-IS to filter redistributed routes. |
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ protocol [ process-id ] ] |
By default, IPv6 IS-IS does not filter redistributed routes. This command is usually used together with the import-route command. |
8. Configure IPv6 IS-IS to filter received routes. |
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import |
By default, IPv6 IS-IS does not filter received routes. |
9. Configure IPv6 IS-IS to redistribute routes from another routing protocol. |
import-route protocol [ as-number | process-id ] [ allow-ibgp ] [ allow-direct | cost cost-value | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] * |
By default, IPv6 IS-IS does not redistribute routes from any other routing protocol. |
10. Configure the maximum number of redistributed Level 1/Level 2 IPv6 routes. |
import-route limit number |
By default, the maximum number of redistributed Level 1/Level 2 IPv6 routes is not configured. |
11. Configure route advertisement from Level-2 to Level-1. |
import-route isisv6 level-2 into level-1 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] * |
By default, IPv6 IS-IS does not advertise routes from Level-2 to Level-1. |
12. Configure route advertisement from Level-1 to Level-2. |
import-route isisv6 level-1 into level-2 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] * |
By default, IPv6 IS-IS advertises routes from Level-1 to Level-2. |
13. Specify the maximum number of ECMP routes for load balancing. |
maximum load-balancing number |
By default, the maximum number of ECMP routes equals the maximum number of ECMP routes supported by the system. |
Configuring an IPv6 IS-IS cost for an interface
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Specify an IS-IS cost style. |
cost-style { narrow | wide | wide-compatible | { compatible | narrow-compatible } [ relax-spf-limit ] } |
By default, the IS-IS cost type is narrow. |
4. Enter IPv6 address family view. |
N/A |
5. Enable IPv6 IS-IS MTR. |
multi-topology [ compatible ] |
By default, IPv6 IS-IS MTR is disabled. |
6. Return to IS-IS view. |
quit |
N/A |
7. Return to system view. |
quit |
N/A |
8. Enter interface view. |
N/A |
9. Enable IPv6 for IS-IS on the interface. |
10. Specify an IPv6 cost for the IS-IS interface. |
isis ipv6 cost |
By default, no IPv6 cost is specified for the interface. |
Configuring a global IPv6 IS-IS cost
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
cost-style { wide | wide-compatible | compatible } |
By default, the IS-IS cost style is narrow. |
N/A |
6. Specify a global IPv6 IS-IS cost. |
circuit-cost cost-value [ level-1 | level-2 ] |
By default, no global IPv6 cost is specified. |
Enabling automatic link cost calculation
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
cost-style { wide | wide-compatible } |
N/A |
6. Enable automatic IPv6 IS-IS cost calculation. |
auto-cost enable |
By default, automatic IPv6 IS-IS cost calculation is disabled. |
7. (Optional.) Configure a bandwidth reference value for automatic IPv6 IS-IS cost calculation. |
bandwidth-reference value |
The default setting is 100 Mbps. |
Configuration prerequisites
Before you tune and optimize IPv6 IS-IS networks, complete basic IPv6 IS-IS tasks.
A topology change causes IS-IS routing convergence. To improve convergence speed, you can assign convergence priorities to IPv6 IS-IS routes. Convergence priority levels are critical, high, medium, and low. The higher the convergence priority, the faster the convergence speed.
By default, IPv6 IS-IS host routes have medium convergence priority, and other IPv6 IS-IS routes have low convergence priority.
To assign a convergence priority to specific IPv6 IS-IS routes:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
6. Assign a convergence priority to specific IPv6 IS-IS routes. |
· Method 1: · Method 2: |
By default, IPv6 IS-IS routes, except IPv6 IS-IS host routes, have the low convergence priority. |
Setting the LSDB overload bit
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
6. Set the overload bit. |
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp4+ [ timeout3 ] ] ] [ allow { external | interlevel } * ] |
By default, the overload bit is not set. |
When IS-IS advertises an IPv6 prefix with a tag value, it adds the tag to the IPv6 reachability information TLV, regardless of the link cost style.
To configure a tag value on an interface:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Configure a tag value on the interface. |
isis ipv6 tag tag |
By default, no tag value is configured on an interface. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
6. Set the SPF calculation interval. |
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ] |
By default: · The maximum interval is 5 seconds. · The minimum interval is 50 milliseconds. · The incremental interval is 200 milliseconds. |
Enabling IPv6 IS-IS ISPF
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
6. Enable IPv6 IS-IS ISPF. |
ispf enable |
By default, IPv6 IS-IS ISPF is enabled. |
Enabling prefix suppression
Perform this task to disable an interface from advertising its prefix in LSPs. This enhances network security by preventing IP routing to the interval nodes and speeds up network convergence.
To enable prefix suppression:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable prefix suppression on the interface. |
isis ipv6 prefix-suppression |
By default, prefix suppression is disabled on an interface. |
Bidirectional forwarding detection (BFD) can quickly detect faults between IPv6 IS-IS neighbors to improve the convergence speed of IPv6 IS-IS. For more information about BFD, see High Availability Configuration Guide.
To configure BFD for IPv6 IS-IS:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the NET for the IS-IS process. |
N/A |
5. Return to system view. |
quit |
N/A |
6. Enter interface view. |
N/A |
7. Enable IPv6 for IS-IS on the interface. |
8. Enable BFD for IPv6 IS-IS. |
isis ipv6 bfd enable |
By default, BFD for IPv6 IS-IS is disabled. |
Configuring IPv6 IS-IS FRR
IMPORTANT: ECMP routes do not support FRR. |
A link or router failure on a path can cause packet loss and routing loop. IPv6 IS-IS FRR enables fast rerouting to minimize the failover time.
Figure 1 Network diagram for IPv6 IS-IS FRR
In Figure 1, after you enable FRR on Router B, IPv6 IS-IS FRR automatically calculates or designates a backup next hop when a link failure is detected. In this way, packets are directed to the backup next hop to reduce traffic recovery time. Meanwhile, IPv6 IS-IS calculates the shortest path based on the new network topology, and forwards packets over the path after network convergence.
You can assign a backup next hop for IPv6 IS-IS FRR in the following ways:
· Enable IPv6 IS-IS FRR to calculate a backup next hop through Loop Free Alternate (LFA) calculation.
· Designate a backup next hop with a routing policy for routes matching specific criteria.
Before you configure IPv6 IS-IS FRR, complete the following tasks:
· Configure IPv6 addresses for interfaces to ensure IP connectivity between neighboring nodes.
· Enable IPv6 IS-IS.
· Make sure the backup next hop is reachable.
Configuration procedure
Configuring IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. (Optional.) Disable LFA calculation on the interface. |
isis ipv6 fast-reroute lfa-backup exclude |
By default, the interface participates in LFA calculation and can be elected as a backup interface. |
4. Return to system view. |
quit |
N/A |
5. Enter IS-IS IPv6 unicast address family view. |
isis [ process-id ] [ vpn-instance vpn-instance-name ] address-family ipv6 [ unicast ] |
N/A |
6. Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation. |
fast-reroute lfa |
By default, IPv6 IS-IS FRR is disabled. |
Configuring IPv6 IS-IS FRR using a routing policy
You can use the apply ipv6 fast-reroute backup-interface command to specify a backup next hop in a routing policy for routes matching specific criteria. You can also perform this task to reference the routing policy for IPv6 IS-IS FRR. For more information about the apply ipv6 fast-reroute backup-interface command and routing policy configurations, see "Configuring routing policies."
To configure IPv6 IS-IS FRR using a routing policy:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
By default, the interface participates in LFA calculation, and can be elected as a backup interface. |
quit |
N/A |
N/A |
6. Enable IPv6 IS-IS FRR using a routing policy. |
fast-reroute route-policy route-policy-name |
Enabling BFD for IPv6 IS-IS FRR
By default, IPv6 IS-IS FRR does not use BFD to detect primary link failures. To speed up IPv6 IS-IS convergence, enable BFD for IPv6 IS-IS FRR to detect primary link failures.
To enable BFD control packet mode for IPv6 IS-IS FRR:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable BFD control packet mode for IPv6 IS-IS FRR. |
isis ipv6 primary-path-detect bfd ctrl |
By default, BFD control packet mode for IPv6 IS-IS FRR is disabled. |
To enable BFD echo packet mode for IPv6 IS-IS FRR:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the source IPv6 address of BFD echo packets. |
bfd echo-source-ipv6 ip-address |
By default, the source IPv6 address of BFD echo packets is not configured. The source IPv6 address cannot be on the same network segment as any local interface's IP address. For more information, see High Availability Command Reference. |
3. Enter interface view. |
N/A |
4. Enable BFD echo packet mode for IPv6 IS-IS FRR. |
isis ipv6 primary-path-detect bfd echo |
By default, BFD echo packet mode for IPv6 IS-IS FRR is disabled. |
Enabling IPv6 IS-IS MTR
On a network, IPv4 and IPv6 topologies must be consistent so that both IPv6 IS-IS and IPv4 IS-IS can use the SPF algorithm to perform route calculation. If they are different, routers supporting both IPv4 and IPv6 might send IPv6 packets to routers that do not support IPv6, resulting in packet loss.
To resolve this issue, configure IPv6 IS-IS Multi-Topology Routing (MTR) to perform route calculation separately in IPv4 and IPv6 topologies.
As shown in Figure 2, the numbers refer to the link costs. Router A, Router B, and Router D support both IPv4 and IPv6. Router C supports only IPv4 and cannot forward IPv6 packets.
Enable IPv6 IS-IS MTR on Router A, Router B, Router C, and Router D to make them perform route calculation separately in IPv4 and IPv6 topologies. With this configuration, Router A does not forward IPv6 packets destined to Router D through Router B, avoiding packet loss.
Before you configure IPv6 IS-IS MTR, configure basic IPv4 and IPv6 IS-IS functions, and establish IS-IS neighbors.
To enable IPv6 IS-IS MTR:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
N/A |
Execute display commands in any view. For other display and reset commands, see "Configuring IS-IS."
Command |
Display information about routes redistributed by IPv6 IS-IS. |
display isis redistribute ipv6 [ ipv6-address mask-length ] [ level-1 | level-2 ] [ process-id ] |
Display IPv6 IS-IS routing information. |
display isis route ipv6 [ ipv6-address ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ] |
Display IPv6 IS-IS topology information. |
display isis spf-tree ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ] |
Display IPv6 IS-IS route calculation log information. |
display isis event-log spf ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ] |
Network requirements
As shown in Figure 3, Switch A, Switch B, Switch C, and Switch D, all enabled with IPv6, reside in the same AS. Configure IPv6 IS-IS on the switches so that they can reach each other.
Switch A and Switch B are Level-1 switches, Switch D is a Level-2 switch, and Switch C is a Level-1-2 switch.
1. Configure IPv6 addresses for interfaces. (Details not shown.)
2. Configure IPv6 IS-IS:
# Configure Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.0000.0000.0001.00
[SwitchA-isis-1] address-family ipv6
[SwitchA-isis-1-ipv6] quit
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface100] isis ipv6 enable 1
# Configure Switch B.
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.0000.0000.0002.00
[SwitchB-isis-1] address-family ipv6
[SwitchB-isis-1-ipv6] quit
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface200] isis ipv6 enable 1
# Configure Switch C.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.0000.0000.0003.00
[SwitchC-isis-1] address-family ipv6
[SwitchC-isis-1-ipv6] quit
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface100] isis ipv6 enable 1
[SwitchC-Vlan-interface200] isis ipv6 enable 1
[SwitchC-Vlan-interface300] isis ipv6 enable 1
[SwitchC-Vlan-interface300] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.0000.0000.0004.00
[SwitchD-isis-1] address-family ipv6
[SwitchD-isis-1-ipv6] quit
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] isis ipv6 enable 1
[SwitchD-Vlan-interface300] quit
[SwitchD] interface vlan-interface 301
[SwitchD-Vlan-interface301] isis ipv6 enable 1
[SwitchD-Vlan-interface301] quit
# Display the IPv6 IS-IS routing table on Switch A.
[SwitchA] display isis route ipv6
Level-1 IPv6 Forwarding Table
Destination : :: PrefixLen: 0
Flag : R/-/- Cost : 10
Next Hop : FE80::200:FF:FE0F:4 Interface: Vlan100
Destination : 2001:1:: PrefixLen: 64
Flag : D/L/- Cost : 10
Next Hop : Direct Interface: Vlan100
Destination : 2001:2:: PrefixLen: 64
Flag : R/-/- Cost : 20
Destination : 2001:3:: PrefixLen: 64
# Display the IPv6 IS-IS routing table on Switch B.
[SwitchB] display isis route ipv6
Next Hop : FE80::200:FF:FE0F:4 Interface: Vlan200
Next Hop : Direct Interface: Vlan200
# Display the IPv6 IS-IS routing table on Switch C.
[SwitchC] display isis route ipv6
Next Hop : Direct Interface: Vlan300
Level-2 IPv6 Forwarding Table
Destination : 2001:4::1 PrefixLen: 128
Next Hop : FE80::20F:E2FF:FE3E:FA3D Interface: Vlan300
# Display the IPv6 IS-IS routing table on Switch D.
[SwitchD] display isis route ipv6
Next Hop : FE80::200:FF:FE0F:4 Interface: Vlan300
Flag : D/L/- Cost : 0
Next Hop : Direct Interface: Loop1
As shown in Figure 4:
· Configure IPv6 IS-IS on Switch A and Switch B so that they can reach other.
· Enable BFD on VLAN-interface 10 of Switch A and Switch B.
After the link between Switch B and the Layer-2 switch fails, BFD can quickly detect the failure and notify IPv6 IS-IS of the failure. Then Switch A and Switch B communicate through Switch C.
Device |
IPv6 address |
Switch A |
Vlan-int10 |
2001::1/64 |
Switch A |
Vlan-int11 |
2001:2::1/64 |
Switch B |
Vlan-int10 |
2001::2/64 |
Switch B |
Vlan-int13 |
2001:3::2/64 |
Switch C |
Vlan-int11 |
2001:2::2/64 |
Switch C |
Vlan-int13 |
2001:3::1/64 |
[SwitchA] isis 1
[SwitchA-Vlan-interface10] isis ipv6 enable 1
[SwitchA-Vlan-interface11] isis ipv6 enable 1
[SwitchB] isis 1
[SwitchB-Vlan-interface10] isis ipv6 enable 1
[SwitchB] interface vlan-interface 13
[SwitchB-Vlan-interface13] isis ipv6 enable 1
[SwitchB-Vlan-interface13] quit
[SwitchC] isis 1
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] isis ipv6 enable 1
[SwitchC-Vlan-interface11] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] isis ipv6 enable 1
[SwitchC-Vlan-interface13] quit
3. Configure BFD functions:
# Enable BFD and configure BFD parameters on Switch A.
[SwitchA-Vlan-interface10] isis ipv6 bfd enable
[SwitchA-Vlan-interface10] bfd min-transmit-interval 500
[SwitchA-Vlan-interface10] bfd min-receive-interval 500
[SwitchA-Vlan-interface10] bfd detect-multiplier 7
[SwitchA-Vlan-interface10] return
# Enable BFD and configure BFD parameters on Switch B.
[SwitchB] bfd session init-mode active
[SwitchB-Vlan-interface10] isis ipv6 bfd enable
[SwitchB-Vlan-interface10] bfd min-transmit-interval 500
[SwitchB-Vlan-interface10] bfd min-receive-interval 500
[SwitchB-Vlan-interface10] bfd detect-multiplier 6
# Display BFD session information on Switch A.
<SwitchA> display bfd session
Total Session Num: 1 Init Mode: Active
IPv6 Session Working Under Ctrl Mode:
Local Discr: 1441 Remote Discr: 1450
Source IP: FE80::20F:FF:FE00:1202 (link-local address of VLAN-interface 10 on Switch A)
Destination IP: FE80::20F:FF:FE00:1200 (link-local address of VLAN-interface 10 on Switch B)
Session State: Up Interface: Vlan10
Hold Time: 2319ms
# Display routes destined for 2001:4::0/64 on Switch A.
<SwitchA> display ipv6 routing-table 2001:4::0 64
Summary Count : 1
Destination: 2001:4::/64 Protocol : IS_L1
NextHop : FE80::20F:FF:FE00:1200 Preference: 15
Interface : Vlan10 Cost : 10
The output shows that Switch A and Switch B communicate through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
Summary Count : 1
NextHop : FE80::BAAF:67FF:FE27:DCD0 Preference: 15
Interface : Vlan11 Cost : 20
The output shows that Switch A and Switch B communicate through VLAN-interface 11.
As shown in Figure 5, Switch A, Switch B, and Switch C belong to the same IS-IS routing domain. Configure IPv6 IS-IS FRR so that when the Link A fails, traffic can be switched to Link B immediately.
Device |
IP address |
Device |
IP address |
Switch A |
Vlan-int100 |
1::1/64 |
Switch B |
Vlan-int101 |
3::1/64 |
Vlan-int200 |
2::1/64 |
Vlan-int200 |
2::2/64 |
Loop0 |
10::1/128 |
Loop0 |
20::1/128 |
Switch C |
Vlan-int100 |
1::2/64 |
Vlan-int101 |
3::2/64 |
1. Configure IPv6 addresses for interfaces on the switches and enable IPv6 IS-IS. (Details not shown.)
2. Configure IPv6 IS-IS on the switches to make sure Switch A, Switch B, and Switch C can communicate with each other at Layer 3. (Details not shown.)
3. Configure IPv6 IS-IS FRR:
Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation, or designate a backup next hop by using a referenced routing policy.
¡ (Method 1.) Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation:
[SwitchA] isis 1
[SwitchA-isis-1-ipv6] fast-reroute lfa
[SwitchB] isis 1
[SwitchB-isis-1-ipv6] fast-reroute lfa
¡ (Method 2.) Enable IPv6 IS-IS FRR to designate a backup next hop by using a routing policy:
[SwitchA] ipv6 prefix-list abc index 10 permit 20:: 128
[SwitchA-route-policy-frr-10] if-match ipv6 address prefix-list abc
[SwitchA-route-policy-frr-10] apply ipv6 fast-reroute backup-interface vlan-interface 100 backup-nexthop 1::2
[SwitchA] isis 1
[SwitchA-isis-1-ipv6] fast-reroute route-policy frr
[SwitchB] ipv6 prefix-list abc index 10 permit 10:: 128
[SwitchB-route-policy-frr-10] if-match ipv6 address prefix-list abc
[SwitchB-route-policy-frr-10] apply ipv6 fast-reroute backup-interface vlan-interface 101 backup-nexthop 3::2
[SwitchB] isis 1
[SwitchB-isis-1-ipv6] fast-reroute route-policy frr
# Display route 20::1/128 on Switch A to view the backup next hop information.
[SwitchA] display ipv6 routing-table 20::1 128 verbose
Summary count : 1
Destination: 20::1/128
Protocol: IS_L1
Process ID: 1
SubProtID: 0x1 Age: 00h27m45s
Cost: 10 Preference: 15
IpPre: N/A QosLocalID: N/A
Tag: 0 State: Active Adv
OrigTblID: 0xa OrigVrf: default-vrf
TableID: 0xa OrigAs: 0
NibID: 0x24000005 LastAs: 0
AttrID: 0xffffffff Neighbor: ::
Flags: 0x10041 OrigNextHop: FE80::34CD:9FF:FE2F:D02
Label: NULL RealNextHop: FE80::34CD:9FF:FE2F:D02
BkLabel: NULL BkNextHop: FE80::7685:45FF:FEAD:102
Tunnel ID: Invalid Interface: Vlan-interface200
BkTunnel ID: Invalid BkInterface: Vlan-interface100
FtnIndex: 0x0 TrafficIndex: N/A
Connector: N/A
# Display route 10::1/128 on Switch B to view the backup next hop information.
[SwitchB] display ipv6 routing-table 10::1 128 verbose
Summary count : 1
Destination: 10::1/128
Protocol: IS_L1
Process ID: 1
SubProtID: 0x1 Age: 00h33m23s
NibID: 0x24000006 LastAs: 0
Flags: 0x10041 OrigNextHop: FE80::34CC:E8FF:FE5B:C02
Label: NULL RealNextHop: FE80::34CC:E8FF:FE5B:C02
BkTunnel ID: Invalid BkInterface: Vlan-interface101
Connector: N/A
