10-Security Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R7523P01-6W10010-Security Command Reference
15-IP source guard commands
15-IP source guard commands 67.97 KB
display ip source binding
Use display ip source binding to display IPv4SG bindings.
display ip source binding [ static | [ vpn-instance vpn-instance-name ] [ arp-snooping | dhcp-relay | dhcp-server | dhcp-snooping | dot1x ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
static: Displays static IPv4SG bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display dynamic IPv4SG bindings for the public network, do not specify a VPN instance.
arp-snooping: Specifies the ARP snooping module.
dhcp-relay: Specifies the DHCP relay agent module.
dhcp-server: Specifies the DHCP server module.
dhcp-snooping: Specifies the DHCP snooping module.
dot1x: Specifies the 802.1X module. To display dynamic IPv4SG bindings generated based on the 802.1X module, you must also specify the slot through which 802.1X users access the network.
ip-address ip-address: Specifies an IPv4 address.
mac-address mac-address: Specifies a MAC address in H-H-H format.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command displays IPv4SG bindings for the master device.
# Display all IPSG bindings on the public network.
<Sysname> display ip source binding
Total entries found: 5
IP Address      MAC Address    Interface                VLAN Type
10.1.0.5        040a-0000-4000 XGE1/1/1                 1    DHCP snooping
10.1.0.6        040a-0000-3000 XGE1/1/1                 1    DHCP snooping
10.1.0.7        040a-0000-2000 XGE1/1/1                 1    DHCP snooping
10.1.0.8        040a-0000-1000 XGE1/1/2                 N/A  DHCP relay
10.1.0.9        040a-0000-2000 XGE1/1/2                 N/A  Static
Total entries found
Total number of IPv4SG bindings.
IP Address
IPv4 address in the IPv4SG binding. If no IP address is bound in the binding, this field displays N/A.
MAC Address
MAC address in the IPv4SG binding. If no MAC address is bound in the binding, this field displays N/A.
Interface of the binding. This field displays N/A for a global IPv4SG binding.
VLAN
VLAN information in the IPv4SG binding. If the binding contains no VLAN information, this field displays N/A.
IPSG binding type:
·     Static—Manually configured by using the ip source binding command. Static bindings are for packet filtering in IPSG or used by other modules to provide security services.
·     ARP snooping—Dynamically generated based on ARP snooping. The binding is for packet filtering in IPSG.
·     802.1X—Dynamically generated based on 802.1X. The binding is for packet filtering in IPSG.
·     DHCP relay—Dynamically generated based on DHCP relay agent. The binding is for packet filtering in IPSG.
·     DHCP server—Dynamically generated based on DHCP server. The binding is used by other modules to provide security services.
·     DHCP snooping—Dynamically generated based on DHCP snooping. The binding is for packet filtering in IPSG.
ip source binding
ip verify source
display ip verify source excluded
Use display ip verify source excluded to display source items that have been configured to be excluded from IPSG filtering.
display ip verify source excluded [ vlan start-vlan-id [ to end-vlan-id ] ] [ slot slot-number ]
vlan start-vlan-id [ to end-vlan-id ]: Specifies VLANs that have been configured to be excluded from IPSG filtering. Value ranges for both the start-vlan-id and end-vlan-id arguments are 1 to 4094. The value for the end-vlan-id argument must be equal to or greater than the value for the start-vlan-id argument.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command displays information for the master device.
# Display all source items that have been configured to be excluded from IPSG filtering.
<Sysname> display ip verify source excluded
Slot:
  Start VLAN ID        End VLAN ID    Status
  1                    20             Active
  24                   50             Active
  200                  300            Inactive
# Display VLANs (VLAN 3, VLAN 5, and VLAN 5 through VLAN 10) that have been configured to be excluded from IPSG filtering.
<Sysname> display ip verify source excluded vlan 3
Slot:
  VLAN ID: 3
  Status: Active
<Sysname> display ip verify source excluded vlan 5
Slot:
  VLAN ID: 5
  Status: Active
<Sysname> display ip verify source excluded vlan 5 to 10
Slot:
  5                    10             Active
Start VLAN ID
Start VLAN ID of the VLAN range that has been configured to be excluded from IPSG filtering.
End VLAN ID
End VLAN ID of the VLAN range that has been configured to be excluded from IPSG filtering.
Status
Whether the excluded VLAN configuration is issued to the driver:
·     Active—The configuration is issued to the driver successfully.
·     Inactive—The configuration fails to be issued to the driver.
display ipv6 source binding
Use display ipv6 source binding to display IPv6SG bindings.
display ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-relay | dhcpv6-snooping | dot1x  | nd-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
static: Displays static IPv6SG bindings.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display dynamic IPSG bindings for the public network, do not specify a VPN instance.
dhcpv6-relay: Specifies the DHCPv6 relay agent module.
dhcpv6-snooping: Specifies the DHCPv6 snooping module.
dot1x: Specifies the 802.1X module. To display dynamic IPv6SG bindings generated based on the 802.1X module, you must also specify the slot through which 802.1X users access the network.
nd-snooping: Specifies the ND snooping module.
ip-address ipv6-address: Specifies an IPv6 address.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. If you do not specify a member device or PEX, this command displays IPv6SG bindings for the master device.
# Display all IPv6SG bindings on the public network.
<Sysname> display ipv6 source binding
Total entries found: 2
IPv6 Address         MAC Address    Interface               VLAN Type
2012:1222:2012:1222: 000f-2202-0435 XGE1/1/1                1    DHCPv6 snooping
2012:1222:2012:1222
2012:1222:2012:1222: 000f-2202-0436 XGE1/1/1                N/A  Static
2012:1222:2012:1223
Total entries found
Total number of IPv6SG bindings.
IPv6 Address
IPv6 address in the IPv6SG binding. If no IPv6 address is bound in the binding, this field displays N/A.
MAC Address
MAC address in the IPv6SG binding. If no MAC address is bound in the binding, this field displays N/A.
Interface of the IPv6SG binding. This field displays N/A for a global IPv6SG binding.
VLAN
VLAN information in the IPv6SG binding. If the binding contains no VLAN information, this field displays N/A.
IPv6SG binding type:
·     Static—Manually configured by using the ipv6 source binding command. Static bindings are for packet filtering in IPv6SG or used by other modules to provide security services.
·     DHCPv6 relay—Dynamically generated based on DHCPv6 relay agent. The binding is for packet filtering in IPv6SG.
·     DHCPv6 snooping—Dynamically generated based on DHCPv6 snooping. The binding is for packet filtering in IPv6SG.
·     802.1X—Dynamically generated based on 802.1X. The binding is for packet filtering in IPv6SG.
·     ND snooping—Dynamically generated based on ND snooping. The binding is for packet filtering in IPv6SG.
ipv6 source binding
ipv6 verify source
ip source binding (interface view)
Use ip source binding to configure a static IPv4SG binding on an interface.
Use undo ip source binding to delete the static IPv4SG bindings configured on an interface.
ip source binding { ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
undo ip source binding { all | ip-address ip-address | ip-address ip-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
No static IPv4SG bindings exist on an interface.
VLAN interface view
all: Removes all static IPv4SG bindings on the interface.
ip-address ip-address: Specifies an IPv4 address for the static binding. The IPv4 address must be a class A, B, or C address, and cannot be 127.x.x.x or 0.0.0.0.
mac-address mac-address: Specifies a MAC address for the static binding. The MAC address must be in H-H-H format, and cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
vlan vlan-id: Specifies a VLAN ID for the static binding. The value range is 1 to 4094. This option is supported only in Layer 2 Ethernet interface view and Layer 2 aggregate interface view.
Static IPv4SG bindings on an interface implement the following functions:
·     Filter incoming IPv4 packets on the interface.
·     Check user validity by cooperating with the ARP attack detection feature.
You cannot configure static IPv4SG bindings on a service loopback interface.
# Configure a static IPv4SG binding on Ten-GigabitEthernet 1/1/1.
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] ip source binding ip-address 192.168.0.1 mac-address 0001-0001-0001
ip source binding (system view)
Use ip source binding to configure a global static IPv4SG binding.
Use undo ip source binding to delete one or all global static IPv4SG bindings.
undo ip source binding { all | ip-address ip-address mac-address mac-address }
No global static IPv4SG bindings exist.
ip-address ip-address: Specifies the IPv4 address for the static binding. The IPv4 address must be a class A, B, or C address, and cannot be 127.x.x.x or 0.0.0.0.
mac-address mac-address: Specifies the MAC address for the static binding. The MAC address is in the format H-H-H but cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
all: Removes all global static IPv4SG bindings.
A global static IPv4SG binding takes effect on all interfaces.
# Configure a global static IPv4SG binding.
[Sysname] ip source binding ip-address 192.168.0.1 mac-address 0001-0001-0001
ip verify source
Use ip verify source to enable IPv4SG on an interface.
Use undo ip verify source to disable IPv4SG on an interface.
The IPv4SG feature is disabled on an interface.
VLAN interface view
ip-address: Filters incoming packets by source IPv4 addresses.
ip-address mac-address: Filters incoming packets by source IPv4 addresses and source MAC addresses.
mac-address: Filters incoming packets by source MAC addresses.
After you enable IPv4SG on an interface, this feature uses static and dynamic IPv4SG bindings to match incoming packets on the interface. Packets that match an IPv4SG binding are forwarded and packets that do not match any IPv4SG binding are discarded.
The matching criterion specified by this command applies only to dynamic IPSG. Static IPv4SG uses static bindings configured by using the ip source binding command.
You cannot enable dynamic IPv4SG on a service loopback interface.
# Enable IPv4SG on Layer 2 Ethernet interface Ten-GigabitEthernet 1/1/1 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname-Ten-GigabitEthernet1/1/1] ip verify source ip-address mac-address
# Enable IPv4SG on VLAN-interface 100 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname-Vlan-interface100] ip verify source ip-address mac-address
# Enable IPv4SG on Layer 3 Ethernet interface Ten-GigabitEthernet 1/1/2 and verify the source IPv4 address and MAC address for dynamic IPSG.
[Sysname] interface ten-gigabitethernet 1/1/2
[Sysname-Ten-GigabitEthernet1/1/2] ip verify source ip-address mac-address
# Enable IPv4SG on Layer 3 Ethernet interface Ten-GigabitEthernet 1/1/2 and verify the source MAC address for dynamic IPSG.
[Sysname-Ten-GigabitEthernet1/1/2] ip verify source mac-address
Use ip verify source exclude to exclude IPv4 packets with the specified source items from IPSG filtering.
Use undo ip verify source exclude to remove the configuration.
ip verify source exclude vlan start-vlan-id [ to end-vlan-id ]
undo ip verify source exclude vlan start-vlan-id [ to end-vlan-id ]
No excluded source items are configured.
vlan start-vlan-id [ to end-vlan-id ]: Specifies excluded VLANs. Value ranges for both the start-vlan-id and end-vlan-id arguments are 1 to 4094. The value for the end-vlan-id argument must be equal to or greater than the value for the start-vlan-id argument. A single excluded VLAN is specified if you specify only the start-vlan-id argument or specify the same VLAN ID for the start-vlan-id and end-vlan-id arguments.
You can execute this command multiple times to specify multiple excluded VLANs. The specified excluded VLANs cannot overlap. If the specified excluded VLANs overlap, an error prompt appears.
# Exclude IPv4 packets from VLAN 3 and VLAN 5 through VLAN 10 from IPSG filtering.
[Sysname] ip verify source exclude vlan 3
[Sysname] ip verify source exclude vlan 5 to 10
ipv6 source binding (interface view)
Use ipv6 source binding to configure a static IPv6SG binding.
Use undo ipv6 source binding to delete the static IPv6SG bindings configured on an interface.
ipv6 source binding { ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
undo ipv6 source binding { all | ip-address ipv6-address | ip-address ipv6-address mac-address mac-address | mac-address mac-address } [ vlan vlan-id ]
No static IPv6SG bindings exist on an interface.
VLAN interface view
all: Removes all the static IPv6SG bindings on the interface.
ip-address ipv6-address: Specifies an IPv6 address for the static binding. The IPv6 address cannot be an all-zero address, a multicast address, or a loopback address.
vlan vlan-id: Specifies a VLAN ID for the static binding. The value range is 1 to 4094. This option is supported only in Layer 2 Ethernet interface view.
Static IPv6SG bindings on an interface filter incoming IPv6 packets, and check user validity by cooperating with the ND attack detection feature.
You cannot configure static IPv6SG bindings on a service loopback interface.
# Configure a static IPv6SG binding on Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] ipv6 source binding ip-address 2001::1 mac-address 0002-0002-0002
ipv6 source binding (system view)
Use ipv6 source binding to configure a global static IPv6SG binding.
Use undo ipv6 source binding to delete one or all global static IPv6SG bindings.
undo ipv6 source binding { all | ip-address ipv6-address mac-address mac-address }
No global static IPv6SG bindings exist.
ipv6-address ipv6-address: Specifies the IPv6 address for the static binding. The IPv6 address cannot be an all-zero address, a multicast address, or a loopback address.
mac-address mac-address: Specifies the MAC address for the static binding. The MAC address must be in H-H-H format, and cannot be all 0s, all Fs (a broadcast MAC address), or a multicast MAC address.
all: Removes all global static IPv6SG bindings.
A global static IPv6SG binding takes effect on all interfaces.
# Configure a global static IPv6SG binding.
[Sysname] ipv6 source binding ipv6-address 2001::1 mac-address 0002-0002-0002
ipv6 verify source
Use ipv6 verify source to enable IPv6SG on an interface.
Use undo ipv6 verify source to disable IPv6SG on an interface.
The IPv6SG feature is disabled on an interface.
VLAN interface view
ip-address: Filters incoming packets by source IPv6 addresses.
ip-address mac-address: Filters incoming packets by source IPv6 addresses and source MAC addresses.
After you enable IPv6SG on an interface, this feature uses static and dynamic IPv6SG bindings to match incoming packets on the interface. Packets that match an IPv6SG binding are forwarded and packets that do not match any IPv6SG binding are discarded.
The matching criterion specified by this command applies only to dynamic IPv6SG. Static IPv6SG uses static bindings configured by using the ipv6 source binding command.
You cannot enable dynamic IPv6SG on a service loopback interface.
# Enable IPv6SG on Layer 2 Ethernet interface Ten-GigabitEthernet 1/1/1 and verify the source IPv6 address and MAC address for dynamic IPv6SG.
[Sysname-Ten-GigabitEthernet1/1/1] ipv6 verify source ip-address mac-address
