11-High Availability Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10011-High Availability Command Reference
09-Track commands
09-Track commands 55.63 KB
Track commands
display track
Use display track to display track entry information.
display track { track-entry-number | all }
track-entry-number: Specifies the track entry ID in the range of 1 to 1024.
all: Specifies all track entries.
# Display information about all track entries.
<Sysname> display track all
Track ID: 1
  State: Positive
  Duration: 0 days 0 hours 0 minutes 7 seconds
  Notification delay: Positive 20, Negative 30 (in seconds)
  Tracked object:
    NQA entry: admin test
    Reaction: 10
Track ID: 2
  State: NotReady
  Tracked object:
    BFD session mode: Echo
    Outgoing interface: Vlan-interface2
    VPN instance name: -
    Remote IP: 192.168.40.1
    Local IP: 192.168.40.2
Track ID: 3
  State: Negative
  Tracked object:
    Interface:  Vlan-interface3
    Protocol: IPv4
Track ID: 4
  State: Negative
  Tracked object:
    CFD service instance: 1, MEP ID: 2
Track ID
ID of a track entry.
States of a track entry:
·     PositiveThe tracked object operates correctly.
·     NotReadyThe tracked object is invalid.
·     NegativeThe tracked object is abnormal.
Duration
Time period during which the track entry stays in the state.
·     The Track module notifies the application modules that the status of the track entry changes to Positive after a delay time of 20 seconds.
·     The Track module notifies the application modules that the status of the track entry changes to Negative after a delay time of 30 seconds.
Tracked object
Tracked object associated with the track entry.
NQA entry
NQA operation associated with the track entry.
Reaction
Reaction entry associated with the track entry.
BFD session mode
BFD session mode. Only echo mode is supported.
Outgoing interface
Outgoing interface of BFD echo packets.
VPN instance name
Name of VPN instance to which BFD session packets belong. If the packets belong to a public network, a hyphen (-) is displayed.
Remote IP
Remote IP address of the BFD echo packets.
Local IP
Local IP address of the BFD echo packets.
Interface to be monitored.
Protocol
Link states or Layer 3 protocol states of the monitored interface:
·     None—Link status of the monitored interface.
·     IPv4IPv4 protocol status of the monitored Layer 3 interface.
·     IPv6IPv6 protocol status of the monitored Layer 3 interface.
·     track bfd
·     track cfd
·     track interface
·     track interface protocol
·     track nqa
track bfd
Use track bfd to create a track entry and associate it with a BFD session.
Use undo track to remove the track entry.
track track-entry-number bfd echo interface interface-type interface-number remote ip remote-ip local ip local-ip [ delay { negative negative-time | positive positive-time } * ]
undo track track-entry-number
No track entry exists.
interface interface-type interface-number: Specifies the outgoing interface by its type and number of the BFD echo packets.
remote ip remote-ip: Specifies the destination IP address of the BFD echo packets.
local ip local-ip: Specifies the source IP address of the BFD echo packets.
delay: Specifies the delay before the Track module notifies the application modules of the track entry state change. If you do not specify this keyword, the Track module notifies the application modules immediately when the track entry state changes.
negative negative-time: Specifies the delay before the Track module notifies the application modules that the track entry state has changed to Negative. The negative-time argument represents the notification delay in the range of 1 to 300 seconds.
positive positive-time: Specifies the delay before the Track module notifies the application modules that the track entry state has changed to Positive. The positive-time argument represents the notification delay in the range of 1 to 300 seconds.
After a track entry is created, you can only use the track bfd delay command to modify its notification delay settings. To modify other settings, you must delete the entry and create a new one.
When you associate Track with BFD, the virtual IP address of a VRRP group cannot be the local or remote address of a BFD session.
# Associate track entry 1 with BFD to monitor the link between local IP address 1.1.1.2 and remote IP address 1.1.1.1 by sending BFD echo packets through VLAN-interface 2.
[Sysname] track 1 bfd echo interface vlan-interface 2 remote ip 1.1.1.1 local ip 1.1.1.2
display track
track cfd
Use track cfd to create a track entry and associate it with CFD.
track track-entry-number cfd cc service-instance instance-id mep mep-id [ delay { negative negative-time | positive positive-time } * ]
service-instance instance-id: Specifies a service instance by its ID in the range of 1 to 32767.
mep mep-id: Specifies a MEP by its ID in the range of 1 to 8191.
After a track entry is created, you can only use the track cfd delay command to modify its notification delay settings. To modify other settings, you must delete the entry and create a new one.
# Create track entry 1 and specify the CFD service instance ID as 2 and MEP ID as 3.
[Sysname] track 1 cfd cc service-instance 2 mep 3
·     display track
·     cfd mep
·     cfd service-instance
track interface
Use track interface to create a track entry and associate it with the link state of the specified interface.
track track-entry-number interface interface-type interface-number [ delay { negative negative-time | positive positive-time } * ]
When you associate Track with interface management to monitor the link status of an interface, the track entry state changes as follows:
·     The track entry state is Positive if the link state of the interface is up.
·     The track entry state is Negative if the link state of the interface is down.
To display the link state of an interface, use the display ip interface brief command.
After you create a track entry, you can only use the track interface delay command to modify its notification delay settings. To modify other settings, you must delete the entry and create a new one.
# Create track entry 1 and associate it with the link state of interface VLAN-interface 10.
[Sysname] track 1 interface vlan-interface 10
·     display track
·     display ip interface brief (Layer 3—IP Services Command Reference)
Use track interface protocol to create a track entry and associate it with the protocol state of the specified interface.
track track-entry-number interface interface-type interface-number protocol { ipv4 | ipv6 } [ delay { negative negative-time | positive positive-time } * ]
ipv4: Monitors the IPv4 protocol state. When the IPv4 protocol state of an interface is up, the state of the track object is Positive. When the IPv4 protocol state of an interface is down, the state of the track object is Negative. To display the IPv4 protocol state of an interface, use the display ip interface brief command.
ipv6: Monitors the IPv6 protocol state. When the IPv6 protocol state of an interface is up, the state of the track object is Positive. When the IPv6 protocol state of an interface is down, the state of the track object is Negative. To display the IPv6 protocol state of an interface, use the display ipv6 interface brief command.
After a track entry is created, you can only use the track interface protocol delay command to modify its notification delay settings. To modify other settings, you must delete the entry and create a new one.
# Create track entry 1 and associate it with the IPv4 protocol state of interface VLAN-interface 2.
[Sysname] track 1 interface vlan-interface 2 protocol ipv4
·     display track
·     display ipv6 interface brief (Layer 3—IP Services Command Reference)
track nqa
Use track nqa to create a track entry and associate it with the specified reaction entry of an NQA operation.
track track-entry-number nqa entry admin-name operation-tag reaction item-number [ delay { negative negative-time | positive positive-time } * ]
entry admin-name operation-tag: Specifies the NQA operation to be associated with the track entry. The admin-name argument specifies the name of the NQA operation administrator who creates the NQA operation, and is a case-insensitive string of 1 to 32 characters. The operation-tag argument specifies the NQA operation tag, and is a case-insensitive string of 1 to 32 characters.
reaction item-number: Specifies the reaction entry to be associated with the track entry. The item-number argument is the reaction entry ID in the range of 1 to 10.
After a track entry is created, you can only use the track nqa delay command to modify its notification delay settings. To modify other settings, you must delete the entry and create a new one.
# Create track entry 1 and associate it with reaction entry 3 of the NQA operation admin-test.
[Sysname] track 1 nqa entry admin test reaction 3
display track
