11-High Availability Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10011-High Availability Command Reference
06-Monitor Link commands
06-Monitor Link commands 48.91 KB
display monitor-link group
Use display monitor-link group to display monitor link group information.
display monitor-link group { group-id | all }
group-id: Specifies a monitor link group. The value range for the group-id argument is 1 to 16.
all: Specifies all monitor link groups.
This command does not display information about ports that belong to a link aggregation group.
# Display information about monitor link group 1.
<Sysname> display monitor-link group 1
Monitor link group 1 information:
  Group status     : UP
  Downlink up-delay: 0(s)
  Last-up-time     : 16:38:26 2012/4/21
  Last-down-time   : 16:37:20 2012/4/21
  Up-port-threshold: 1
  Member                    Role       Status
  GE1/0/1                   UPLINK     UP
  GE1/0/2                   DOWNLINK   UP
Information about monitor link group 1.
Group status
Monitor link group state, which can be up or down.
Downlink up-delay
Switchover delay of the downlink interfaces in the monitor link group, in seconds.
Last-up-time
Last time when the monitor link group was up.
Last-down-time
Last time when the monitor link group was down.
Up-port-threshold
Threshold for triggering monitor link group state switchover.
Member
Member interfaces of the monitor link group.
Role
Interface role, which can be uplink interface or downlink interface.
Status
Member link state, which can be up or down.
downlink up-delay
Use downlink up-delay to configure the switchover delay for the downlink interfaces in a monitor link group.
Use undo downlink up-delay to restore the default.
downlink up-delay delay
The switchover delay is 0 seconds. The downlink interfaces come up as soon as an uplink interface in the monitor link group comes up.
Monitor link group view
delay: Specifies the switchover delay in the range of 1 to 300 seconds.
To avoid frequent state changes of downlink interfaces in the event that the uplink interfaces in the monitor link group flap, you can configure a switchover delay. The switchover delay is the time that the downlink interfaces wait before they come up following an uplink interface.
# Configure the switchover delay for the downlink interfaces in monitor link group 1 as 50 seconds.
[Sysname] monitor-link group 1
[Sysname-mtlk-group1] downlink up-delay 50
monitor-link disable
Use monitor-link disable to disable Monitor Link globally.
Use undo monitor-link disable to enable Monitor Link globally.
Monitor Link is enabled globally.
All monitor link groups can operate only after you enable Monitor Link globally. When you disable Monitor Link globally, all monitor link groups cannot operate and the downlink interfaces brought down by the monitor link groups resume their original states.
# Disable Monitor Link globally.
[Sysname] monitor-link disable
monitor-link group
Use monitor-link group to create a monitor link group and enter monitor link group view.
Use undo monitor-link group to remove a monitor link group.
monitor-link group group-id
undo monitor-link group group-id
No monitor link group is created.
# Create monitor link group 1 and enter the view of monitor link group 1.
port
Use port to assign an interface to the monitor link group.
Use undo port to remove an interface from the monitor link group.
port interface-type interface-number { downlink | uplink }
undo port interface-type interface-number
A monitor link group has no member interfaces.
interface-type: Specifies an interface by its type. The interface type can be Layer 2 Ethernet interface, Layer 3 Ethernet interface, Layer 2 aggregate interface, Layer 3 aggregate interface.
downlink: Specifies a downlink interface.
uplink: Specifies an uplink interface.
To avoid interrupting Monitor Link operation, do not assign the aggregate interface and member ports of an aggregate group to the same monitor link group.
An interface can be assigned to only one monitor link group.
You can also assign an interface to a monitor link group by using the port monitor-link group command in interface view.
# Configure GigabitEthernet 1/0/1 as an uplink interface and GigabitEthernet 1/0/2 as a downlink interface for monitor link group 1.
[Sysname-mtlk-group1] port gigabitethernet 1/0/1 uplink
[Sysname-mtlk-group1] port gigabitethernet 1/0/2 downlink
Use port monitor-link group to assign the current interface to a monitor link group as a member interface.
Use undo port monitor-link group to remove the current interface from a monitor link group.
port monitor-link group group-id { downlink | uplink }
undo port monitor-link group group-id
The interface is not a monitor link group member.
To avoid interrupting Monitor Link operation, do not add an aggregate interface and its member ports to the same monitor link group.
You can also assign an interface to a monitor link group with the port command in monitor link group view.
[Sysname-mtlk-group1] quit
[Sysname-GigabitEthernet1/0/1] port monitor-link group 1 uplink
[Sysname-GigabitEthernet1/0/2] port monitor-link group 1 downlink
port
uplink up-port-threshold
Use uplink up-port-threshold to configure the threshold for triggering monitor link group state switchover.
Use undo uplink up-port-threshold to restore the default.
uplink up-port-threshold number-of-port
The threshold for triggering monitor link group state switchover is 1.
number-of-port: Specifies the threshold for triggering monitor link group state switchover, in the range of 1 to 1024.
When the number of uplink interfaces in up state in a monitor link group is less than the specified threshold, the monitor link group goes down and shuts down its downlink interfaces. When the number of uplink interfaces in up state reaches the threshold, the monitor link group comes up and brings up all its downlink interfaces.
As a best practice, use the display monitor-link group command to display the total number of uplink interfaces before executing the uplink up-port-threshold command. If you set the threshold to be greater than the total number of the uplink interfaces, the monitor link group cannot come up and data will be lost.
# Set the threshold for triggering monitor link group state switchover to 5.
[Sysname-mtlk-group1] uplink up-port-threshold 5
