04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10004-Layer 2 - LAN Switching Command Reference
05-Loop detection commands
05-Loop detection commands 51 KB
display loopback-detection
Use display loopback-detection to display the loop detection configuration and status.
Example
# Display the loop detection configuration and status.
<Sysname> display loopback-detection
Loopback detection is enabled.
Loopback detection interval is 30 second(s).
Loopback is detected on following interfaces:
 Interface                Action mode
 GigabitEthernet1/0/2     Shutdown
 GigabitEthernet1/0/3     None
Action mode
Loop protection action:
·     NoneWhen a loop is detected on a port, the device generates a log but performs no action on the port.
·     ShutdownWhen a loop is detected on a port, the device performs the following tasks:
¡     Generates a log.
¡     Shuts down the port to disable the port from receiving or sending frames. The device automatically sets the port to the forwarding state after a time interval. Configure the time interval by using the shutdown-interval command (see Fundamentals Command Reference).
loopback-detection action
Use loopback-detection action to configure the loop protection action on a per-port basis.
Use undo loopback-detection action to restore the default.
loopback-detection action shutdown
When the device detects a loop on a port, it generates a log but performs no action on the port.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
shutdown: Enables the shutdown mode. If a loop is detected, the device generates a log and shuts down the port. The device automatically sets the port to the forwarding state after the time interval configured by using the shutdown-interval command (see Fundamentals Command Reference).
To configure the loop protection action globally, use the loopback-detection global action command.
The global configuration applies to all ports. The per-port configuration applies to the individual ports. The per-port configuration takes precedence over the global configuration.
Example
# Set the loop protection action to shutdown on port GigabitEthernet 1/0/1.
[System-GigabitEthernet1/0/1] loopback-detection action shutdown
·     display loopback-detection
·     loopback-detection global action
loopback-detection enable
Use loopback-detection enable to enable loop detection on a per-port basis.
Use undo loopback-detection enable to disable loop detection on a port.
loopback-detection enable vlan { vlan-list | all }
undo loopback-detection enable vlan { vlan-list | all }
The loop detection feature is disabled on ports.
vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The ID for vlan-id2 must be equal to or greater than the ID for vlan-id1.
all: Specifies all existing VLANs.
The per-port loop detection configuration takes effect only after you enable loop detection globally. To enable loop detection globally, use the loopback-detection global enable command.
The global configuration applies to all ports in the specified VLAN. The per-port configuration applies to the individual port only when the port belongs to the specified VLAN. The per-port configuration takes precedence over the global configuration.
Example
# Enable loop detection on port GigabitEthernet 1/0/1 for VLAN 10 through VLAN 20.
[System-GigabitEthernet1/0/1] loopback-detection enable vlan 10 to 20
·     loopback-detection global enable
Use loopback-detection global action to configure the global loop protection action.
Use undo loopback-detection global action to restore the default.
loopback-detection global action shutdown
shutdown: Enables the shutdown mode. If a loop is detected, the device generates a log and shuts down the port. The device automatically sets the port to the forwarding state after you set the time interval by using the shutdown-interval command (see Fundamentals Command Reference).
To configure the loop protection action on a per-port basis, use the loopback-detection action command in interface view.
Example
# Set the global loop protection action to shutdown.
[System] loopback-detection global action shutdown
·     loopback-detection action
Use loopback-detection global enable to enable loop detection globally.
Use undo loopback-detection global enable to disable loop detection globally.
loopback-detection global enable vlan { vlan-list | all }
undo loopback-detection global enable vlan { vlan-list | all }
The loop detection feature is globally disabled.
To enable loop detection on a per-port basis, use the loopback-detection enable command in interface view.
Example
# Globally enable loop detection for VLAN 10 through VLAN 20.
[System] loopback-detection global enable vlan 10 to 20
·     loopback-detection enable
loopback-detection interval-time
Use loopback-detection interval-time to set the loop detection interval.
Use undo loopback-detection interval-time to restore the default.
loopback-detection interval-time interval
The loop detection interval is 30 seconds.
interval: Sets the loop detection interval in the range of 1 to 300 seconds.
With loop detection enabled, the device sends loop detection frames at the specified interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
Example
# Set the loop detection interval to 10 seconds.
[Sysname] loopback-detection interval-time 10
