04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10004-Layer 2 - LAN Switching Command Reference
04-Spanning tree commands
04-Spanning tree commands 201.81 KB
active region-configuration
Use active region-configuration to activate your MST region configuration.
MST region view
When you configure MST region parameters, MSTP launches a new spanning tree calculation process that might cause network topology instability. This is most likely to occur when you configure the VLAN-to-instance mapping table. The launch occurs after you execute the active region-configuration command or the stp global enable command.
As a best practice, use the check region-configuration command to determine whether the MST region configurations to be activated are correct. Run this command only when they are correct.
# Map VLAN 2 to MSTI 1 and manually activate the MST region configuration.
[Sysname-mst-region] instance 1 vlan 2
·     check region-configuration
·     instance
·     region-name
·     revision-level
·     stp global enable
·     vlan-mapping modulo
bpdu-drop any
Use bpdu-drop any to enable BPDU drop on a port.
Use undo bpdu-drop any to disable BPDU drop on a port.
bpdu-drop any
undo bpdu-drop any
BPDU drop is disabled on a port.
# Enable BPDU drop on port Ten-GigabitEthernet 1/1/1.
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] bpdu-drop any
Use check region-configuration to display MST region pre-configuration information, including the region name, revision level, and VLAN-to-instance mapping settings.
MST region view
Spanning tree devices belong to the same MST region only when they are connected through a physical link and configured with the same details as follows:
·     Format selector (0 by default and not configurable).
·     MST region name.
·     MST region revision level.
·     VLAN-to-instance mapping entries in the MST region.
As a best practice, use this command to determine whether the MST region configurations to be activated are correct. Activate them only when they are correct.
# Display MST region pre-configurations.
[Sysname-mst-region] check region-configuration
 Admin Configuration
   Format selector      : 0
   Region name          : example
   Revision level       : 0
   Configuration digest : 0x3e24359aeafa90cfb26a5884ac35343d
   Instance  VLANs Mapped
   0         1 to 9, 11 to 29, 31 to 4094
   1         10
   3         30
Format selector
Format selector of the MST region, which is 0 (not configurable).
Region name
MST region name.
Revision level
Revision level of the MST region.
VLAN-to-instance mappings in the MST region.
·     active region-configuration
·     instance
·     region-name
·     revision-level
display stp
Use display stp to display spanning tree status and statistics. Based on the information, you can analyze and maintain the network topology or determine whether the spanning tree is working correctly.
display stp [ instance instance-list | vlan vlan-id-list ] [ interface interface-list | slot slot-number ] [ brief ]
instance instance-list: Specifies a space-separated list of up to 10 MSTI items. Each item specifies an MSTI or a range of MSTIs in the form of instance-id1 [ to instance-id2 ]. The value for instance-id2 must be equal to or greater than the value for instance-id1. The value range for the instance-id argument is 0 to 4094, and the value 0 represents the CIST.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 [ to vlan-id2 ]. The value for vlan-id2 must be equal to or greater than the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
interface interface-list: Specifies a space-separated list of up to 10 interface items. Each item specifies an interface or a range of interfaces in the form of interface-type interface-number 1 [ to interface-type interface-number 2 ]. The interface number for interface-number 2 must be equal to or greater than the interface number for interface-number 1.
brief: Displays brief spanning tree status and statistics. If this keyword is not specified, the command displays the detailed spanning tree status and statistics.
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays spanning tree status and statistics for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
In STP or RSTP mode, the command output is sorted by port name.
·     If you do not specify a port, this command applies to all ports.
·     If you specify a port list, this command applies to the specified ports.
In PVST mode, the command output is sorted by VLAN ID and by port name in each VLAN.
·     If you do not specify a VLAN or port, this command applies to all ports in all VLANs.
·     If you only specify a VLAN list but not a port, this command applies to all ports in the specified VLANs.
·     If you only specify a port list but not a VLAN, this command applies to the specified ports in all VLANs.
·     If you specify both a VLAN list and a port list, this command applies to the ports in the specified VLANs.
In MSTP mode, the command output is sorted by MSTI ID and by port name in each MSTI.
·     If you do not specify an MSTI or port, this command applies to all MSTIs on all ports.
·     If you specify an MSTI list but not a port, this command applies to all ports in the specified MSTIs.
·     If you specify a port list but not an MSTI, this command applies to all MSTIs on the specified ports.
·     If you specify both an MSTI list and a port list, this command applies to the specified ports in the specified MSTIs.
During network convergence, the spanning tree information of the changing network topology is not displayed.
# In MSTP mode, display the brief spanning tree status and statistics for MSTI 0 on ports Ten-GigabitEthernet 1/1/1 through Ten-GigabitEthernet 1/1/4.
<Sysname> display stp instance 0 interface ten-gigabitethernet 1/1/1 to ten-gigabitethernet 1/1/4 brief
 MST ID      Port                         Role  STP State     Protection
 0           Ten-GigabitEthernet1/1/1         ALTE  DISCARDING    LOOP
 0           Ten-GigabitEthernet1/1/2         DESI  FORWARDING    NONE
 0           Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
 0           Ten-GigabitEthernet1/1/4         DESI  FORWARDING    NONE
# In PVST mode, display the brief spanning tree status and statistics for VLAN 2 on ports Ten-GigabitEthernet 1/1/1 through Ten-GigabitEthernet 1/1/4.
[Sysname] stp mode pvst
[Sysname] display stp vlan 2 interface ten-gigabitethernet 1/1/1 to ten-gigabitethernet 1/1/4 brief
 VLAN ID     Port                         Role  STP State     Protection
 2           Ten-GigabitEthernet1/1/1         ALTE  DISCARDING    LOOP
 2           Ten-GigabitEthernet1/1/2         DESI  FORWARDING    NONE
 2           Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
 2           Ten-GigabitEthernet1/1/4         DESI  FORWARDING    NONE
MST ID
MSTI ID in the MST region.
Port
Port name, corresponding to each MSTI or VLAN.
Role
Port role:
·     ALTE—The port is an alternate port.
·     BACK—The port is a backup port.
·     ROOT—The port is a root port.
·     DESI—The port is a designated port.
·     MAST—The port is a master port.
·     DISA—The port is disabled.
STP State
Spanning tree status on the port:
·     FORWARDING—The port can receive and send BPDUs and also forward user traffic.
·     DISCARDING—The port can receive and send BPDUs but cannot forward user traffic.
·     LEARNING—The port is in a transitional state. It can receive and send BPDUs but cannot forward user traffic.
Protection
Protection type on the port:
·     ROOT—Root guard.
·     LOOP—Loop guard.
·     BPDU—BPDU guard.
·     NONE—No protection.
# In MSTP mode, display the detailed spanning tree status and statistics for all MSTIs on all ports.
-------[CIST Global Info][Mode MSTP]-------
 Bridge ID           : 32768.000f-e200-2200
 Bridge times        : Hello 2s MaxAge 20s FwdDelay 15s MaxHops 20
 Root ID/ERPC        : 0.00e0-fc0e-6554, 200200
 RegRoot ID/IRPC     : 32768.000f-e200-2200, 0
 RootPort ID         : 128.48
 BPDU-Protection     : Disabled
 Bridge Config-
 Digest-Snooping     : Disabled
 TC or TCN received  : 2
 Time since last TC  : 0 days 0h:5m:42s
----[Port153(Ten-GigabitEthernet1/1/1)][FORWARDING]----
 Port protocol       : Enabled
 Port role           : Designated Port (Boundary)
 Port ID             : 128.153
 Port cost(Legacy)   : Config=auto, Active=200
 Desg.bridge/port    : 32768.000f-e200-2200, 128.2
 Port edged          : Config=disabled, Active=disabled
 Point-to-Point      : Config=auto, Active=true
 Transmit limit      : 10 packets/hello-time
 TC-Restriction      : Disabled
 Role-Restriction    : Disabled
 Protection type     : Config=none, Active=none
 MST BPDU format     : Config=auto, Active=legacy
 Port Config-
 Rapid transition    : False
 Num of VLANs mapped : 1
 Port times          : Hello 2s MaxAge 20s FwdDelay 15s MsgAge 2s RemHops 20
 BPDU sent           : 186
          TCN: 0, Config: 0, RST: 0, MST: 186
 BPDU received       : 0
          TCN: 0, Config: 0, RST: 0, MST: 0
-------[MSTI 1 Global Info]-------
 Bridge ID         : 0.000f-e23e-9ca4
 RegRoot ID/IRPC   : 0.000f-e23e-9ca4, 0
 RootPort ID       : 0.0
 Root type         : Primary root
 Master bridge     : 32768.000f-e23e-9ca4
 Cost to master    : 0
 TC received       : 0
# In PVST mode, display the spanning tree status and statistics for all ports in all VLANs.
-------[VLAN 1 Global Info]-------
Protocol status     : Enabled
VlanRoot ID/RPC     : 0.00e0-fc0e-6554, 200200
 ----[Port1(Ten-GigabitEthernet1/1/1)][FORWARDING]----
 Port ID             : 128.153
 Desg. bridge/port   : 32768.000f-e200-2200, 128.2
-------[VLAN 2 Global Info]-------
Bridge times         : Hello 2s MaxAge 20s FwDly 15s
# In MSTP mode, display the spanning tree status and statistics when the spanning tree feature is disabled.
 Protocol status    : Disabled
 Protocol Std.      : IEEE 802.1s
 Version            : 3
 Bridge-Prio.       : 32768
 MAC address        : 000f-e200-8048
 Max age(s)         : 20
 Forward delay(s)   : 15
 Hello time(s)      : 2
 Max hops           : 20
 TC Snooping        : Disabled
# In PVST mode, display the spanning tree status and statistics when the spanning tree feature is disabled.
 Protocol Std.      : IEEE 802.1w (pvst)
 Version            : 2
 MAC address        : 3822-d69f-0800
 Max age(s)         : 20
 Hello time(s)      : 2
Bridge ID
Bridge ID, which contains the device's priority and its MAC address. For example, in output 32768.000f-e200-2200, the value preceding the dot is the device's priority. The value following the dot is the device's MAC address.
Bridge times
Major parameters for the bridge:
·     Hello—Hello timer.
·     MaxAgeMaximum age timer.
·     FwdDelay—Forward delay timer.
·     MaxHopsMaximum hops within the MST region.
Root ID/ERPC
CIST root ID and external path cost (the path cost from the device to the CIST root).
RegRoot ID/IRPC
CIST regional root ID and internal path cost (the path cost from the device to the CIST regional root).
VlanRoot ID/RPC
VLAN root ID and root path cost (the path cost from the device to the VLAN root bridge).
RootPort ID
Root port ID. The value 0.0 indicates that the device is the root and there is no root port.
BPDU-Protection
Global status of the BPDU guard feature.
Bridge Config-
Digest-Snooping
Global status of Digest Snooping.
TC or TCN received
Number of TC/TCN BPDUs received in the MSTI or VLAN.
Time since last TC
Time since the latest topology change in the MSTI or VLAN.
[FORWARDING]
The port is in forwarding state.
[DISCARDING]
The port is in discarding state.
[LEARNING]
The port is in learning state.
Port protocol
Status of the spanning tree feature on the port.
Port role
Port role:
·     Alternate.
·     Backup.
·     Root.
·     Designated.
·     Master.
·     Disabled.
(Boundary)
The port is a regional boundary port.
Port cost(Legacy)
Path cost of the port. The field in parentheses indicates the standard (legacy, dot1d-1998, or dot1t) used for port path cost calculation.
·     Config—Configured value.
·     Active—Actual value.
Desg.bridge/port
Designated bridge ID and port ID of the port.
The port ID displayed is insignificant for a port which does not support port priority.
Port edged
The port is an edge port or non-edge port.
Point-to-Point
The port is connected to a point-to-point link or not.
Transmit limit
Number of BPDUs sent within each hello time.
Protection type
Whether spanning tree protection is configured on the port:
·     Config—Configured spanning tree protection feature.
·     ActiveEffective spanning tree protection feature.
Spanning tree protection features are as follows:
·     root—Root guard.
·     loop—Loop guard.
·     bpdu—BPDU guard.
·     none—No protection.
TC-Restriction
Status of TC transmission restriction on the port.
Role-Restriction
Status of port role restriction on the port.
MST BPDU format
Format of the MST BPDUs that the port can send:
·     Config—Configured value (legacy or 802.1s).
·     Active—Actual value (legacy or 802.1s).
Port Config-
Digest-Snooping
Status of Digest Snooping on the port.
Rapid transition
Indicates whether the port rapidly transits to the forwarding state in the MSTI or VLAN.
Num of VLANs mapped
Number of VLANs that are mapped to the MSTI.
Port times
Major parameters for the port:
·     MsgAge—Message age timer.
·     RemHops—Remaining hops.
BPDU sent
Statistics on sent BPDUs.
BPDU received
Statistics on received BPDUs.
RegRoot ID/IRPC
MSTI regional root/internal path cost.
Root Type
MSTI root type:
·     Primary root.
·     Secondary root.
Master bridge
MSTI root bridge ID.
Cost to master
Path cost from the MSTI to the master bridge.
TC received
Number of received TC BPDUs.
Protocol status
Spanning tree protocol status.
Protocol Std.
Spanning tree protocol standard.
Version
Spanning tree protocol version.
Bridge-Prio.
·     In MSTP mode: Device's priority in the CIST.
·     In PVST mode: Device's priority in VLAN 1.
Max age(s)
Aging timer for BPDUs (in seconds, which is the same as the aging timer for VLAN 1 in PVST mode).
Forward delay(s)
Port state transition delay (in seconds, which is the same as the port state transition delay for VLAN 1 in PVST mode).
Hello time(s)
Interval for the root bridge to send BPDUs (in seconds, which is the same as the interval for VLAN 1 in PVST mode).
Max hops
Maximum hops in the MSTI.
TC Snooping
Status of TC Snooping, which can be Enabled or Disabled.
reset stp
display stp abnormal-port
Use display stp abnormal-port to display information about ports that are blocked by spanning tree protection features.
# In MSTP mode, display information about ports that are blocked by spanning tree protection features.
<Sysname> display stp abnormal-port
 MST ID      Blocked Port                 Reason
 1           Ten-GigabitEthernet1/1/1     Root-Protected
 2           Ten-GigabitEthernet1/1/2     Loop-Protected
 12          Ten-GigabitEthernet1/1/3     Loopback-Protected
# In PVST mode, display information about ports that are blocked by spanning tree protection features.
[Sysname] display stp abnormal-port
 VLAN ID      Blocked Port                 Reason
MST ID
MSTI of the blocked port.
VLAN ID
VLAN of the blocked port.
Blocked Port
Name of a blocked port.
Reason
Reason that the port was blocked:
·     Root-Protected—Root guard feature.
·     Loop-Protected—Loop guard feature.
·     Loopback-Protected—Self-loop protection. A port in the MSTI receives a BPDU that it sends.
·     Disputed—Dispute protection. A port receives a low-priority BPDU from a non-blocked designated port.
·     InconsistentPortType-Protected—Inconsistent port type protection.
·     InconsistentPvid-Protected—Inconsistent PVID protection.
display stp bpdu-statistics
Use display stp bpdu-statistics to display the BPDU statistics for ports.
display stp bpdu-statistics [ interface interface-type interface-number [ instance instance-list ] ]
In MSTP mode, the command output is sorted by port name and by MSTI ID on each port.
·     If you specify a port but not an MSTI, this command applies to all MSTIs on the port.
·     If you specify both an MSTI ID and a port, this command applies to the specified MSTI on the port.
In STP, RSTP, or PVST mode, the command output is sorted by port name.
·     If you specify a port, this command applies to the port.
# In MSTP mode, display the BPDU statistics for all MSTIs on Ten-GigabitEthernet 1/1/1.
<Sysname> display stp bpdu-statistics interface ten-gigabitethernet 1/1/1
 Port: Ten-GigabitEthernet1/1/1
 Instance-Independent:
 Type                        Count      Last Updated
 Invalid BPDUs               0
 Looped-back BPDUs           0
 Max-aged BPDUs              0
 TCN sent                    0
 TCN received                0
 TCA sent                    0
 TCA received                2          10:33:12 01/13/2011
 Config sent                 0
 Config received             0
 RST sent                    0
 RST received                0
 MST sent                    4          10:33:11 01/13/2011
 MST received                151        10:37:43 01/13/2011
 Instance 0:
 Timeout BPDUs               0
 Max-hoped BPDUs             0
 TC detected                 1          10:32:40 01/13/2011
 TC sent                     3          10:33:11 01/13/2011
 TC received                 0
# In PVST mode, display the BPDU statistics for Ten-GigabitEthernet 1/1/1.
[Sysname] display stp bpdu-statistics interface ten-gigabitethernet 1/1/1
 Invalid BPDUs               0
 Looped-back BPDUs           0
 Max-aged BPDUs              0
 TCN sent                    0
 TCN received                0
 TCA sent                    0
 TCA received                2           10:33:12 01/13/2010
 Config sent                 0
 Config received             0
 RST sent                    0
 RST received                0
 MST sent                    4           10:33:11 01/13/2010
 MST received                151         10:37:43 01/13/2010
 Timeout BPDUs               0
 Max-hoped BPDUs             0
 TC detected                 511         10:32:40 01/13/2010
 TC sent                     8844        10:33:11 01/13/2010
 TC received                 1426        10:33:32 01/13/2010
Table 5 Command output
Port
Port name.
Statistics not related to any particular MSTI.
Statistical item.
Looped-back BPDUs
BPDUs sent and then received by the same port.
Max-aged BPDUs
BPDUs whose max age was exceeded.
TCN sent
TCN BPDUs sent.
TCN received
TCN BPDUs received.
TCA sent
TCA BPDUs sent.
TCA received
TCA BPDUs received.
Config sent
Configuration BPDUs sent.
Config received
RST sent
Configuration BPDUs received.
RST received
RSTP BPDUs sent.
MST sent
RSTP BPDUs received.
MST received
MSTP BPDUs sent.
Instance
Statistical information for a particular MSTI.
Timeout BPDUs
Expired BPDUs.
Max-hoped BPDUs
BPDUs whose maximum hops were exceeded.
TC detected
TC BPDUs detected.
TC sent
TC BPDUs sent.
TC received
TC BPDUs received.
display stp down-port
Use display stp down-port to display information about ports that were shut down by spanning tree protection features.
# Display information about ports that were shut down by spanning tree protection features.
<Sysname> display stp down-port
 Down Port                     Reason
 Ten-GigabitEthernet1/1/1      BPDU-Protected
Table 6 Command output
Down Port
Name of a port that was shut down by the spanning tree protection features.
Reason
Reason that the port was shut down. BPDU-Protected indicates the BPDU guard feature.
display stp history
Use display stp history to display port role calculation history.
display stp [ instance instance-list | vlan vlan-id-list ] history [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays port role calculation history for all member devices if you do not specify a member device. On an IRF 3 system, this command displays port role calculation history for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
In STP or RSTP mode, the command output is sorted by port role calculation time.
In PVST mode, the command output is sorted by VLAN ID and by port role calculation time in each VLAN.
·     If you do not specify a VLAN, this command applies to all VLANs.
·     If you specify a VLAN list, this command applies to the specified VLANs.
In MSTP mode, the command output is sorted by MSTI ID and by port role calculation time in each MSTI.
·     If you do not specify an MSTI, this command applies to all MSTIs.
·     If you specify an MSTI list, this command applies to the specified MSTIs.
# In MSTP mode, display the port role calculation history for slot 1 in MSTI 2.
<Sysname> display stp instance 2 history slot 1
 --------------- STP slot 1 history trace ---------------
 -------------------  Instance 2   ---------------------
Port Ten-GigabitEthernet1/1/1
   Role change         : ROOT->DESI (Aged)
   Time                : 2009/02/08 00:22:56
   Port priority       : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.1
   Designated priority : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.1
 Port Ten-GigabitEthernet1/1/2
   Role change         : ALTER->ROOT
   Port priority       : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.2
                         128.153
   Designated priority : 0.00e0-fc01-6510 0 0.00e0-fc01-6510 128.2
                         128.153
Table 7 Command output
Port
Port name.
Role change
Role change of the port (Aged means that the change was caused by expiration of the received configuration BPDU).
Time
Time of port role calculation.
display stp region-configuration
Use display stp region-configuration to display effective MST region configuration, including the following information:
·     Region name.
·     Revision level.
·     User-configured VLAN-to-instance mappings.
# In MSTP mode, display effective MST region configuration.
<Sysname> display stp region-configuration
 Oper Configuration
   Format selector      : 0
   Revision level       : 0
   Configuration digest : 0xae082c70c28100a1497b32a14c4e22ae
   0         2 to 9, 11 to 29, 31 to 4094
   1         1, 10
   3         30
Table 8 Command output
Format selector
Format selector that is defined by the spanning tree protocol. The default value is 0, and the selector cannot be configured.
Region name
MST region name.
Revision level
Revision level of the MST region. The default value is 0, and the level can be configured by using the revision-level command.
VLANs Mapped
VLANs mapped to the MSTI.
·     instance
·     region-name
·     revision-level
display stp root
Use display stp root to display the root bridge information of spanning trees.
display stp root
# In MSTP mode, display the root bridge information of all spanning trees.
<Sysname> display stp root
 MST ID  Root Bridge ID        ExtPathCost IntPathCost Root Port
 0       0.00e0-fc0e-6554      200200      0           Ten-GigabitEthernet1/1/1
# In PVST mode, display the root bridge information of all spanning trees.
 VLAN ID  Root Bridge ID        ExtPathCost IntPathCost Root Port
 1        0.00e0-fc0e-6554      200200      0           Ten-GigabitEthernet1/1/1
Table 9 Command output
ExtPathCost
External path cost. The device automatically calculates the default path cost of a port. Or, you can use the stp cost command to configure the path cost of a port.
IntPathCost
Internal path cost. The device automatically calculates the default path cost of a port. Or, you can use the stp cost command to configure the path cost of a port.
Root Port
Root port name (displayed only if a port of the device is the root port of MSTIs).
display stp tc
Use display stp tc to display the incoming and outgoing TC/TCN BPDU statistics for ports.
display stp [ instance instance-list | vlan vlan-id-list ] tc [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number. On an IRF fabric, this command displays information for all member devices if you do not specify a member device. On an IRF 3 system, this command displays information for all IRF member devices and PEXs if you do not specify an IRF member device or PEX.
# In MSTP mode, display the incoming and outgoing TC/TCN BPDU statistics for all ports of slot 1 in MSTI 0.
<Sysname> display stp instance 0 tc slot 1
 -------------- STP slot 1 TC or TCN count -------------
 MST ID      Port                       Receive      Send
 0           Ten-GigabitEthernet1/1/1   6            4
 0           Ten-GigabitEthernet1/1/2   0            2
Table 10 Command output
Port
Port name.
Receive
Number of TC/TCN BPDUs received on each port.
Send
Number of TC/TCN BPDUs sent by each port.
instance
Use instance to map a list of VLANs to an MSTI.
Use undo instance to remap the specified VLAN or all VLANs to the CIST (MSTI 0).
instance instance-id vlan vlan-id-list
undo instance instance-id [ vlan vlan-id-list ]
All VLANs are mapped to the CIST.
MST region view
instance-id: Specifies an MSTI ID in the range of 0 to 4094. A value of 0 represents the CIST. The value range for the instance-id argument is 1 to 4094 for the undo instance command.
CAUTION
CAUTION:
Use caution with global Digest Snooping in the following situations:
·     When you modify the VLAN-to-instance mappings.
·     When you restore the default MST region configuration.
If the local device has different VLAN-to-instance mappings than its neighboring devices, loops or traffic interruption will occur.
If you specify no VLAN in the undo instance command, all VLANs mapped to the specified MSTI are remapped to the CIST.
You cannot map the same VLAN to different MSTIs. If you map a VLAN that has been mapped to an MSTI to a new MSTI, the old mapping is automatically removed.
You can configure VLAN-to-instance mapping for up to 65 MSTIs.
After configuring this command, run the active region-configuration command to activate the VLAN-to-instance mapping.
# Map VLAN 2 to MSTI 1.
·     display stp region-configuration
region-name
Use region-name to configure the MST region name.
Use undo region-name to restore the default MST region name.
region-name name
undo region-name
The MST region name of a device is its MAC address.
MST region view
name: Specifies the MST region name, a string of 1 to 32 characters.
The MST region name, the VLAN-to-instance mapping table, and the MSTP revision level of a device determine the device's MST region.
After configuring this command, run the active region-configuration command to activate the configured MST region name.
# Set the MST region name of the device to hello.
[Sysname-mst-region] region-name hello
·     instance
·     revision-level
reset stp
Use reset stp to clear spanning tree statistics. The spanning tree statistics include the numbers of TCN BPDUs, configuration BPDUs, RST BPDUs, and MST BPDUs that are sent and received through the specified ports.
reset stp [ interface interface-list ]
interface interface-list: Specifies a space-separated list of up to 10 interface items. Each item specifies an interface or a range of interfaces in the form of interface-type interface-number 1 [ to interface-type interface-number 2 ]. The interface number for interface-number 2 must be equal to or greater than the interface number for interface-number 1. If you do not specify an interface, this command clears the spanning tree statistics on all ports.
# Clear the spanning tree statistics on ports Ten-GigabitEthernet 1/1/1 through Ten-GigabitEthernet 1/1/3.
<Sysname> reset stp interface ten-gigabitethernet 1/1/1 to ten-gigabitethernet 1/1/3
display stp
revision-level
Use revision-level to configure the MSTP revision level.
Use undo revision-level to restore the default MSTP revision level.
revision-level level
undo revision-level
The MSTP revision level is 0.
MST region view
level: Specifies an MSTP revision level in the range of 0 to 65535.
The MSTP revision level, the MST region name, and the VLAN-to-instance mapping table of a device determine the device's MST region.
After configuring this command, run the active region-configuration command to activate the configured MST region level.
# Set the MSTP revision level of the MST region to 5.
[Sysname-mst-region] revision-level 5
·     instance
·     region-name
snmp-agent trap enable stp
Use snmp-agent trap enable stp to enable SNMP notifications for new-root election events or spanning tree topology changes.
Use undo snmp-agent trap enable stp to disable SNMP notifications for new-root election events or spanning tree topology changes.
snmp-agent trap enable stp [ new-root | tc ]
undo snmp-agent trap enable stp [ new-root | tc ]
SNMP notifications are disabled for new-root election events.
In MSTP mode, SNMP notifications are enabled in MSTI 0 and disabled in other MSTIs for spanning tree topology changes.
In PVST mode, SNMP notifications are disabled for spanning tree topology changes in all VLANs.
new-root: Enables the device to send traps if the device is elected as a new root bridge. This keyword applies only to STP, MSTP, and RSTP modes.
tc: Enables the device to send traps if the device receives TCN BPDUs. This keyword applies only to PVST mode.
If no keyword is specified, the snmp-agent trap enable stp command applies to SNMP notifications for different events as follows:
·     In STP, MSTP, and RSTP modes, the command applies to SNMP notifications for new-root election events.
·     In PVST mode, the command applies to SNMP notifications for spanning tree topology changes.
# Enable SNMP notifications for new-root election events.
[Sysname] snmp-agent trap enable stp new-root
stp log enable tc
stp bpdu-protection
Use stp bpdu-protection to enable the BPDU guard feature.
Use undo stp bpdu-protection to disable the BPDU guard feature.
stp bpdu-protection
The BPDU guard feature is disabled.
# Enable the BPDU guard feature.
[Sysname] stp bpdu-protection
stp bridge-diameter
Use stp bridge-diameter to set the network diameter.
Use undo stp bridge-diameter to restore the default.
stp [ vlan vlan-id-list ] bridge-diameter diameter
undo stp [ vlan vlan-id-list ] bridge-diameter
The network diameter of the switched network is 7.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 [ to vlan-id2 ]. The value for vlan-id2 must be equal to or greater than the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. If you set the STP, RSTP, or MSTP switched network diameter, do not specify this option.
diameter: Specifies the switched network diameter in the range of 2 to 7.
The switched network diameter refers to the maximum number of devices on the path for an edge device to reach another through the root bridge.
An appropriate setting of hello time, forward delay, and max age can speed up network convergence. The values of these timers are related to the network size, and you can set the timers by setting the network diameter. With the network diameter set to 7 (the default), the three timers are also set to their defaults.
In STP, RSTP, or MSTP mode, each MST region is considered as a device. The configured network diameter of the switched network takes effect only on the CIST (or the common root bridge).
In PVST mode, the configured network diameter takes effect only on the root bridges of the specified VLANs.
# In MSTP mode, set the network diameter of the switched network to 5.
[Sysname] stp bridge-diameter 5
# In PVST mode, set the network diameter of VLAN 2 in the switched network to 5.
[Sysname] stp vlan 2 bridge-diameter 5
·     stp timer forward-delay
·     stp timer hello
·     stp timer max-age
stp compliance
Use stp compliance to configure the mode a port uses to recognize and send MSTP BPDUs.
Use undo stp compliance to restore the default.
stp compliance { auto | dot1s | legacy }
undo stp compliance
A port automatically recognizes the formats of received MSTP packets and determines the formats of MSTP packets to be sent based on the recognized formats.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
auto: Configures the port to recognize the MSTP BPDU format automatically and determine the format of MSTP BPDUs to send.
dot1s: Configures the port to receive and send only standard-format (802.1s-compliant) MSTP BPDUs.
legacy: Configures the port to receive and send only compatible-format MSTP BPDUs.
When this command is configured in Layer 2 Ethernet interface view, it takes effect only on that interface.
When this command is configured in Layer 2 aggregate interface view, it takes effect only on the aggregate interface.
When this command is configured on a member port in an aggregation group, it takes effect only after the port leaves the aggregation group.
# Configure Ten-GigabitEthernet 1/1/1 to send only standard-format (802.1s) MSTP packets.
[Sysname-Ten-GigabitEthernet1/1/1] stp compliance dot1s
stp config-digest-snooping
Use stp config-digest-snooping to enable Digest Snooping.
Use undo stp config-digest-snooping to disable Digest Snooping.
The feature is disabled.
Enable this feature both globally and on ports connected to other vendors' devices. To minimize impact, enable the feature on all associated ports before you enable it globally.
# Enable Digest Snooping on Ten-GigabitEthernet 1/1/1 and then globally.
[Sysname-Ten-GigabitEthernet1/1/1] stp config-digest-snooping
[Sysname-Ten-GigabitEthernet1/1/1] quit
[Sysname] stp global config-digest-snooping
·     display stp
·     stp global config-digest-snooping
stp cost
Use stp cost to set the path cost of a port.
Use undo stp cost to restore the default.
stp [ instance instance-list | vlan vlan-id-list ] cost cost
undo stp [ instance instance-list | vlan vlan-id-list ] cost
The device automatically calculates the path costs of ports in each spanning tree based on the corresponding standard.
cost: Specifies the path cost of the port, with an effective range that varies by path cost calculation standard that is used.
·     When the IEEE 802.1d-1998 standard is selected for path cost calculation, the value range for the cost argument is 1 to 65535.
·     When the IEEE 802.1t standard is selected for path cost calculation, the value range for the cost argument is 1 to 200000000.
·     When the private standard is selected for path cost calculation, the value range for the cost argument is 1 to 200000.
Path cost is an important factor in spanning tree calculation. Setting different path costs for a port in MSTIs allows VLAN traffic flows to be forwarded along different physical links. This results in VLAN-based load balancing.
The path cost setting of a port can affect the role selection of the port. When the path cost of a port is changed, the system calculates the role of the port and initiates a state transition.
When this command is configured on a member port in an aggregation group, is takes effect only after the port leaves the aggregation group.
If you do not specify an MSTI or VLAN, this command sets the path cost of the port in the MSTP CIST or in the STP or RSTP spanning tree.
# In MSTP mode, set the path cost of port Ten-GigabitEthernet 1/1/3 in MSTI 2 to 200.
[Sysname] interface ten-gigabitethernet 1/1/3
[Sysname-Ten-GigabitEthernet1/1/3] stp instance 2 cost 200
# In PVST mode, set the path cost of port Ten-GigabitEthernet 1/1/3 in VLAN 2 to 200.
[Sysname-Ten-GigabitEthernet1/1/3] stp vlan 2 cost 200
·     display stp
·     stp pathcost-standard
stp edged-port
Use stp edged-port to configure a port as an edge port.
Use undo stp edged-port to configure a port as a non-edge port.
stp edged-port
undo stp edged-port
All ports are non-edge ports.
A port directly connecting to a user terminal rather than another device or a shared LAN segment can be configured as an edge port. In case the network topology changes, an edge port does not cause a temporary loop. You can enable the port to transit to the forwarding state rapidly by configuring it as an edge port. As a best practice, configure ports that directly connect to user terminals as edge ports.
Typically, configuration BPDUs from other devices cannot reach an edge port, because the edge port does not connect to any other device. When BPDU guard is disabled, a port configured as an edge port functions as a non-edge port if it receives configuration BPDUs.
On a port, the loop guard feature and the edge port setting are mutually exclusive.
# Configure Ten-GigabitEthernet 1/1/1 as an edge port.
[Sysname-Ten-GigabitEthernet1/1/1] stp edged-port
·     stp bpdu-protection
·     stp loop-protection
·     stp root-protection
stp enable
Use stp enable to enable the spanning tree feature.
Use undo stp enable to disable the spanning tree feature.
stp enable
undo stp enable
The spanning tree feature is enabled on all ports.
When you enable the spanning tree feature, the device operates in STP, RSTP, PVST, or MSTP mode, depending on the spanning tree mode setting.
When you enable the spanning tree feature, the device dynamically maintains the spanning tree status of VLANs, based on received configuration BPDUs.
When you disable the spanning tree feature, the device stops maintaining the spanning tree status.
# In MSTP mode, disable the spanning tree feature on port Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] undo stp enable
·     stp global enable
·     stp mode
·     stp vlan enable
Use stp global config-digest-snooping to enable Digest Snooping globally.
Use undo stp global config-digest-snooping to disable Digest Snooping globally.
The feature is disabled globally.
·     display stp
·     stp config-digest-snooping
stp global enable
Use stp global enable to enable the spanning tree feature globally.
Use undo stp global enable to disable the spanning tree feature globally.
stp global enable
The spanning tree feature is globally disabled.
When the spanning tree feature is enabled, the device dynamically maintains the spanning tree status of VLANs based on received configuration BPDUs. When the spanning tree feature is disabled, the device stops maintaining the spanning tree status.
# Enable the spanning tree feature globally.
[Sysname] stp global enable
·     stp enable
·     stp mode
stp global mcheck
Use stp global mcheck to perform the mCheck operation globally.
stp global mcheck
When a port on an MSTP, RSTP, or PVST device connects to an STP device and receives STP BPDUs, the port automatically transits to the STP mode. However, the port cannot automatically transit back to the original mode when the following conditions exist:
·     The peer STP device is shut down or removed.
·     The port cannot detect the change.
In this case, you can perform an mCheck operation to forcibly transit the port to operate in the original mode.
The device operates in STP, RSTP, PVST, or MSTP mode, depending on the spanning tree mode setting.
The stp global mcheck command takes effect only when the device operates in MSTP, RSTP, or PVST mode.
# Perform mCheck globally.
[Sysname] stp global mcheck
·     stp mcheck
·     stp mode
stp log enable tc
Use stp log enable tc to enable the device to generate a log when it detects or receives a TCN BPDU in PVST mode.
Use undo stp log enable tc to restore the default.
stp log enable tc
In PVST mode, the device does not generate a log when it detects or receives a TCN BPDU.
The command takes effect only in PVST mode.
# Enable the device to generate a log when it detects or receives a TCN BPDU in PVST mode.
[Sysname] stp log enable tc
stp loop-protection
Use stp loop-protection to enable the loop guard feature on a port.
Use undo stp loop-protection to disable the loop guard feature on a port.
stp loop-protection
The loop guard feature is disabled.
On a port, the loop guard feature is mutually exclusive with the root guard feature or the edge port setting.
# Enable the loop guard feature on Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] stp loop-protection
·     stp edged-port
stp max-hops
Use stp max-hops to set the maximum number of hops for an MST region.
Use undo stp max-hops to restore the default.
stp max-hops hops
undo stp max-hops
The maximum number of hops for an MST region is 20.
hops: Specifies the maximum hops in the range of 1 to 40.
# Set the maximum hops of the MST region to 35.
[Sysname] stp max-hops 35
display stp
stp mcheck
Use stp mcheck to perform the mCheck operation on a port.
stp mcheck
In this case, you can perform an mCheck operation to forcibly transit the port to operation in the original mode.
For example, Device A, Device B, and Device C are connected in sequence. Device A runs STP, Device B does not run any spanning tree protocol, and Device C runs RSTP, MSTP, or PVST. When Device C receives an STP BPDU transparently transmitted by Device B, the receiving port transits to the STP mode. If you configure Device B to run RSTP, MSTP, or PVST with Device C, perform mCheck operations on the ports that connect Device B and Device C.
The stp mcheck command takes effect only when the device operates in MSTP, RSTP, or PVST mode.
# Perform mCheck on Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] stp mcheck
·     stp global mcheck
·     stp mode
stp mode
Use stp mode to configure the spanning tree operating mode.
Use undo stp mode to restore the default.
stp mode { mstp | pvst | rstp | stp }
undo stp mode
A spanning tree device operates in MSTP mode.
mstp: Configures the spanning tree device to operate in MSTP mode.
pvst: Configures the spanning tree device to operate in PVST mode.
rstp: Configures the spanning tree device to operate in RSTP mode.
stp: Configures the spanning tree device to operate in STP mode.
The MSTP mode is compatible with the RSTP mode, and the RSTP mode is compatible with the STP mode.
The PVST mode's compatibility with other modes is as follows:
·     Access portThe PVST mode is compatible with other modes in any VLAN.
·     Trunk or hybrid portThe PVST mode is compatible with other modes only in VLAN 1.
# Configure the spanning tree device to operate in STP mode.
[Sysname] stp mode stp
·     stp enable
·     stp global enable
·     stp global mcheck
·     stp mcheck
·     stp vlan enable.
stp no-agreement-check
Use stp no-agreement-check to enable No Agreement Check on a port.
Use undo stp no-agreement-check to disable No Agreement Check on a port.
No Agreement Check is disabled.
This command takes effect only after you enable it on the root port.
# Enable No Agreement Check on Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] stp no-agreement-check
Use stp pathcost-standard to specify a standard for the device to use when calculating the default path costs for ports.
Use undo stp pathcost-standard to restore the default.
stp pathcost-standard { dot1d-1998 | dot1t | legacy }
The calculation standard used by the device is legacy.
dot1d-1998: Configures the device to calculate the default path cost for ports based on IEEE 802.1d-1998.
dot1t: Configures the device to calculate the default path cost for ports based on IEEE 802.1t.
legacy: Configures the device to calculate the default path cost for ports based on a private standard.
If you change the standard that the device uses in calculating the default path costs, you restore the path costs to the default.
# Configure the device to calculate the default path cost for ports based on IEEE 802.1d-1998.
[Sysname] stp pathcost-standard dot1d-1998
·     display stp
·     stp cost
stp point-to-point
Use stp point-to-point to configure the link type of a port.
Use undo stp point-to-point to restore the default.
stp point-to-point { auto | force-false | force-true }
The default setting is auto, and the spanning tree device automatically detects whether a port connects to a point-to-point link.
auto: Specifies automatic detection of the link type.
force-false: Specifies the non-point-to-point link type.
force-true: Specifies the point-to-point link type.
When connecting to a non-point-to-point link, a port is incapable of rapid state transition.
You can configure the link type as point-to-point for a Layer 2 aggregate interface or a port that operates in full duplex mode. As a best practice, use the default setting for the device to automatically detect the port link type.
The stp point-to-point force-false or stp point-to-point force-true command configured on a port in MSTP mode takes effect on all MSTIs or VLANs.
If you configure a non-point-to-point link as a point-to-point link, a temporary loop might occur.
# Configure the link that connects Ten-GigabitEthernet 1/1/3 as a point-to-point link.
[Sysname-Ten-GigabitEthernet1/1/3] stp point-to-point force-true
display stp
stp port priority
Use stp port priority to set the priority of a port. The port priority affects the role of a port in a spanning tree.
Use undo stp port priority to restore the default.
stp [ instance instance-list | vlan vlan-id-list ] port priority priority
undo stp [ instance instance-list | vlan vlan-id-list ] port priority
The port priority is 128.
priority: Specifies the port priority in the range of 0 to 240 in increments of 16 (as in 0, 16, 32).
The smaller the value, the higher the port priority. If all ports on your device use the same priority value, the port priority depends on the port index. The smaller the index, the higher the priority.
If you do not specify an MSTI or VLAN, this command configures the priority of the ports in the MSTP CIST or in the STP or RSTP spanning tree.
# In MSTP mode, set the priority of port Ten-GigabitEthernet 1/1/3 to 16 in MSTI 2.
[Sysname-Ten-GigabitEthernet1/1/3] stp instance 2 port priority 16
# In PVST mode, set the priority of port Ten-GigabitEthernet 1/1/3 to 16 in VLAN 2.
[Sysname-Ten-GigabitEthernet1/1/3] stp vlan 2 port priority 16
display stp
stp port-log
Use stp port-log to enable outputting port state transition information.
Use undo stp port-log to disable outputting port state transition information.
stp port-log { all | instance instance-list | vlan vlan-id-list }
undo stp port-log { all | instance instance-list | vlan vlan-id-list }
This feature is disabled.
all: Specifies all MSTIs or VLANs.
# In MSTP mode, enable outputting port state transition information for MSTI 2.
[Sysname] stp port-log instance 2
%Aug 16 00:49:41:856 2011 Sysname STP/3/STP_DISCARDING: Instance 2's port Ten-GigabitEthernet1/1/1 has been set to discarding state.
%Aug 16 00:49:41:856 2011 Sysname STP/3/STP_FORWARDING: Instance 2's port Ten-GigabitEthernet1/1/2 has been set to forwarding state.
The output shows that Ten-GigabitEthernet 1/1/1 in MSTI 2 transited to the discarding state and Ten-GigabitEthernet 1/1/2 in MSTI 2 transited to the forwarding state.
# In PVST mode, enable outputting port state transition information for VLAN 1 through VLAN 4094.
[Sysname] stp port-log vlan 1 to 4094
%Aug 16 00:49:41:856 2006 Sysname STP/3/STP_DISCARDING: VLAN 2's Ten-GigabitEthernet1/1/1 has been set to discarding state.
%Aug 16 00:49:41:856 2006 Sysname STP/3/STP_FORWARDING: VLAN 2's Ten-GigabitEthernet1/1/2 has been set to forwarding state.
The output shows that Ten-GigabitEthernet 1/1/1 in VLAN 2 transited to the discarding state and Ten-GigabitEthernet 1/1/2 in VLAN 2 transited to the forwarding state.
stp priority
Use stp priority to set the priority of the device.
Use undo stp priority to restore the default priority.
stp [ instance instance-list | vlan vlan-id-list ] priority priority
undo stp [ instance instance-list | vlan vlan-id-list ] priority
The device priority is 32768.
priority: Specifies the device priority in the range of 0 to 61440 in increments of 4096 (as in 0, 4096, 8192). You can set up to 16 priority values on the device. The smaller the value, the higher the device priority.
If you do not specify an MSTI or VLAN, this command configures the priority of the device in the MSTP CIST or in the STP or RSTP spanning tree.
# In MSTP mode, set the device priority to 4096 in MSTI 1.
[Sysname] stp instance 1 priority 4096
# In PVST mode, set the device priority to 4096 in VLAN 1.
[Sysname] stp vlan 1 priority 4096
Use stp region-configuration to enter MST region view.
Use undo stp region-configuration to restore the default MST region configurations.
The default settings for the MST region are as follows:
·     The MST region name of the device is the MAC address of the device.
·     All VLANs are mapped to the CIST.
·     The MSTP revision level is 0.
After you enter MST region view, you can configure MST region parameters, including the region name, VLAN-to-instance mappings, and revision level.
# Enter MST region view.
stp role-restriction
Use stp role-restriction to enable port role restriction.
Use undo stp role-restriction to disable port role restriction.
Port role restriction is disabled.
When port role restriction is enabled on a port, the port cannot become a root port.
# Enable port role restriction on interface Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] stp role-restriction
stp root primary
Use stp root primary to configure the device as the root bridge.
Use undo stp root to restore the default.
stp [ instance instance-list | vlan vlan-id-list ] root primary
undo stp [ instance instance-list | vlan vlan-id-list ] root
A device is not a root bridge.
Once you specify the device as the root bridge, you cannot change the priority of the device.
If you do not specify an MSTI or VLAN, this command configures the device as the root bridge of the MSTP CIST or of the STP or RSTP spanning tree.
# In MSTP mode, specify the device as the root bridge of MSTI 1.
[Sysname] stp instance 1 root primary
# In PVST mode, specify the device as the root bridge of VLAN 1.
[Sysname] stp vlan 1 root primary
·     stp priority
·     stp root secondary
stp root secondary
Use stp root secondary to configure the device as a secondary root bridge.
stp [ instance instance-list | vlan vlan-id-list ] root secondary
A device is not a secondary root bridge.
Once you specify the device as a secondary root bridge, you cannot change the priority of the device.
If you do not specify an MSTI or VLAN, this command configures a secondary root bridge for the MSTP CIST or the STP or RSTP spanning tree.
# In MSTP mode, specify the device as a secondary root bridge in MSTI 1.
[Sysname] stp instance 1 root secondary
# In PVST mode, specify the device as a secondary root bridge in VLAN 1.
[Sysname] stp vlan 1 root secondary
·     stp priority
·     stp root primary
stp root-protection
Use stp root-protection to enable the root guard feature on a port.
Use undo stp root-protection to disable the root guard feature on a port.
stp root-protection
The root guard feature is disabled.
On a port, the loop guard feature and the root guard feature are mutually exclusive.
# Enable the root guard feature for Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] stp root-protection
·     stp edged-port
stp tc-protection
Use stp tc-protection to enable the TC-BPDU attack guard feature for the device.
Use undo stp tc-protection to disable the TC-BPDU attack guard feature for the device.
stp tc-protection
The TC-BPDU attack guard feature is enabled.
With TC-BPDU guard, you can set the maximum number of immediate forwarding address entry flushes that the device can perform every 10 seconds. For TC-BPDUs received that exceed the limit, the device performs a forwarding address entry flush when the interval elapses. This prevents frequent flushing of forwarding address entries.
# Disable the TC-BPDU attack guard feature for the device.
[Sysname] undo stp tc-protection
stp tc-protection threshold
Use stp tc-protection threshold to set the maximum number of forwarding address entry flushes that the device can perform every 10 seconds.
Use undo stp tc-protection threshold to restore the default.
stp tc-protection threshold number
By default, the device can perform a maximum of six forwarding address entry flushes every 10 seconds.
number: Specifies the maximum number of immediate forwarding address entry flushes that the device can perform every 10 seconds. The value is in the range of 1 to 255.
# Configure the device to perform up to 10 forwarding address entry flushes every 10 seconds.
[Sysname] stp tc-protection threshold 10
stp tc-protection
stp tc-restriction
Use stp tc-restriction to enable TC-BPDU transmission restriction.
Use undo stp tc-restriction to disable TC-BPDU transmission restriction.
stp tc-restriction
TC-BPDU transmission restriction is disabled.
When TC-BPDU transmission restriction is enabled on a port, the port does not send TC-BPDUs to other ports. It also does not delete MAC address entries.
# Enable TC-BPDU transmission restriction on Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] stp tc-restriction
stp tc-snooping
Use stp tc-snooping to enable TC Snooping.
Use undo stp tc-snooping to disable TC Snooping.
stp tc-snooping
TC Snooping is disabled.
TC Snooping and the spanning tree feature are mutually exclusive. You must globally disable the spanning tree feature before enabling TC Snooping.
# Globally disable the spanning tree feature and enable TC Snooping.
[Sysname] undo stp global enable
[Sysname] stp tc-snooping
stp global enable
Use stp timer forward-delay to set the forward delay timer.
Use undo stp timer forward-delay to restore the default.
stp [ vlan vlan-id-list ] timer forward-delay time
undo stp [ vlan vlan-id-list ] timer forward-delay
The forward delay timer is 1500 centiseconds.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 [ to vlan-id2 ]. The value for vlan-id2 must be equal to or greater than the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. If you set the STP, RSTP, or MSTP forward delay, do not specify this option.
time: Specifies the forward delay in centiseconds, in the range of 400 to 3000 in increments of 100 (as in 400, 500, 600).
The forward delay timer determines the time interval of state transition. To prevent temporary loops, a spanning tree port goes through the learning (intermediate) state before it transits from the discarding state to the forwarding state. To stay synchronized with the remote device, the port has a wait period that is determined by the forward delay timer between transition states.
As a best practice, specify the network diameter of the switched network by using the stp bridge-diameter command instead of setting the forward delay with this command. The stp bridge-diameter command makes the spanning tree protocols automatically calculate the optimal settings for the forward delay timer. If the network diameter uses the default value, the forward delay timer also uses the default value.
# In MSTP mode, set the forward delay timer to 2000 centiseconds.
[Sysname] stp timer forward-delay 2000
# In PVST mode, set the forward delay timer for VLAN 2 to 2000 centiseconds.
[Sysname] stp vlan 2 timer forward-delay 2000
·     stp bridge-diameter
·     stp timer hello
·     stp timer max-age
stp timer hello
Use stp timer hello to set the hello time.
Use undo stp timer hello to restore the default.
stp [ vlan vlan-id-list ] timer hello time
undo stp [ vlan vlan-id-list ] timer hello
The hello time is 200 centiseconds.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 [ to vlan-id2 ]. The value for vlan-id2 must be equal to or greater than the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. If you set the STP, RSTP, or MSTP hello time, do not specify this option.
time: Specifies the hello time in centiseconds, in the range of 100 to 1000 in increments of 100 (as in 100, 200, 300).
Hello time is the interval at which spanning tree devices send configuration BPDUs to maintain the spanning tree. If a device fails to receive configuration BPDUs within the set period of time, a new spanning tree calculation process is triggered.
As a best practice, specify the network diameter of the switched network by using the stp bridge-diameter command instead of setting the hello time with this command. The stp bridge-diameter command makes the spanning tree protocols automatically calculate the optimal settings for the hello timer. If the network diameter uses the default value, the hello timer also uses the default value.
# In MSTP mode, set the hello time to 400 centiseconds.
[Sysname] stp timer hello 400
# In PVST mode, set the hello time for VLAN 2 to 400 centiseconds.
[Sysname] stp vlan 2 timer hello 400
·     stp timer max-age
stp timer max-age
Use stp timer max-age to set the max age timer.
Use undo stp timer max-age to restore the default.
stp [ vlan vlan-id-list ] timer max-age time
undo stp [ vlan vlan-id-list ] timer max-age
The max age is 2000 centiseconds.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 [ to vlan-id2 ]. The value for vlan-id2 must be equal to or greater than the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. If you set the STP, RSTP, or MSTP max age, do not specify this option.
time: Specifies the max age in centiseconds, in the range of 600 to 4000 in increments of 100 (as in 600, 700, 800).
In the CIST of an MSTP network, the device determines whether a configuration BPDU received on a port has expired based on the max age timer. If the configuration BPDU has expired, a new spanning tree calculation process starts. The max age timer takes effect only on the CIST (or MSTI 0).
As a best practice, specify the network diameter of the switched network by using the stp bridge-diameter command instead of setting the max age timer with this command. The stp bridge-diameter command makes the spanning tree protocols automatically calculate the optimal settings for the max age timer. If the network diameter uses the default value, the max age timer also uses the default value.
# In MSTP mode, set the max age timer to 1000 centiseconds.
[Sysname] stp timer max-age 1000
# In PVST mode, set the max age timer for VLAN 2 to 1000 centiseconds.
[Sysname] stp vlan 2 timer max-age 1000
·     stp timer hello
stp timer-factor
Use stp timer-factor to configure the timeout period by setting the timeout factor.
Timeout period = timeout factor × 3 × hello time.
Use undo stp timer-factor to restore the default.
stp timer-factor factor
The timeout factor of a device is set to 3.
factor: Specifies the timeout factor in the range of 1 to 20.
On a stable network, each non-root-bridge forwards configuration BPDUs to surrounding devices at the interval of hello time to determine whether any link fails. If a device does not receive a BPDU from the upstream device within nine times of the hello time, it assumes that the upstream device has failed. Then it starts a new spanning tree calculation process.
An upstream device might be too busy to forward configuration BPDUs in time, for example, many Layer 2 interfaces are configured on the upstream device. As a result, the downstream device fails to receive a BPDU within the timeout period and then starts an undesired spanning tree calculation. The calculation might fail, and it also wastes network resources. To prevent undesired spanning tree calculation and save network resources on a stable network, you can set the timeout factor to 5, 6, or 7.
# Set the timeout factor of the device to 7.
[Sysname] stp timer-factor 7
stp timer hello
stp transmit-limit
Use stp transmit-limit to set the BPDU transmission rate of a port.
Use undo stp transmit-limit to restore the default.
stp transmit-limit limit
The BPDU transmission rate of all ports is 10. Each port can send 10 BPDUs within each hello time.
limit: Specifies the BPDU transmission rate in the range of 1 to 255.
The maximum number of BPDUs a port can send within each hello time equals the BPDU transmission rate plus the hello timer value.
A larger BPDU transmission rate value requires more system resources. An appropriate BPDU transmission rate setting can prevent spanning tree protocols from using excessive bandwidth resources during network topology changes. As a best practice, use the default value.
# Set the BPDU transmission rate of port Ten-GigabitEthernet 1/1/1 to 5.
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] stp transmit-limit 5
stp vlan enable
Use stp vlan enable to enable the spanning tree feature for VLANs.
Use undo stp enable to disable the spanning tree feature for VLANs.
stp vlan vlan-id-list enable
undo stp vlan vlan-id-list enable
The spanning tree feature is enabled in VLANs.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 [ to vlan-id2 ]. The value for vlan-id2 must be equal to or greater than the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command globally enables or disables the spanning tree feature (VLANs are not included).
When you enable the spanning tree feature, the device dynamically maintains the spanning tree status of VLANs, based on received configuration BPDUs. When you disable the spanning tree feature, the device stops maintaining the spanning tree status.
# In PVST mode, globally enable the spanning tree feature and then enable the spanning tree feature for VLAN 2.
[Sysname] stp vlan 2 enable
·     stp enable
·     stp global enable
·     stp mode
vlan-mapping modulo
Use vlan-mapping modulo to map VLANs in an MST region to MSTIs according to the specified modulo value and quickly create a VLAN-to-instance mapping table.
vlan-mapping modulo modulo
All VLANs are mapped to the CIST (MSTI 0).
MST region view
modulo: Specifies a modulo value in the range of 1 to 64.
You cannot map a VLAN to different MSTIs. If you map a VLAN that has been mapped to an MSTI to a new MSTI, the old mapping is automatically removed.
This command maps each VLAN to the MSTI with ID (VLAN ID – 1) % modulo + 1. (VLAN ID – 1) % modulo is the modulo operation for (VLAN ID – 1). If the modulo value is 15, then VLAN 1 is mapped to MSTI 1, VLAN 2 to MSTI 2, …, VLAN 15 to MSTI 15, VLAN 16 to MSTI 16, and so on.
# Map VLANs to MSTIs as per modulo 8.
[Sysname-mst-region] vlan-mapping modulo 8
·     active region-configuration
·     check region-configuration
·     region-name
·     revision-level
