04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10004-Layer 2 - LAN Switching Command Reference
02-Ethernet link aggregation commands
02-Ethernet link aggregation commands 125.39 KB
bandwidth
Use bandwidth to set the expected bandwidth for an interface.
bandwidth bandwidth-value
undo bandwidth
Layer 2 aggregate interface view, Layer 3 aggregate interface view
The expected bandwidth of an interface affects link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth to 10000 kbps for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] bandwidth 10000
default
Use default to restore the default settings for an aggregate interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Layer 2 aggregate interface 1.
[Sysname-Bridge-Aggregation1] default
description
Use description to set a description for an interface.
The description of an interface is the interface-name plus Interface. For example, the default description of Bridge-Aggregation 1 is Bridge-Aggregation1 Interface.
text: Specifies the interface description, a string of 1 to 255 characters.
# Set the description to connect to the lab for Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] description connect to the lab
display interface
Use display interface to display aggregate interface information.
display interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ] [ brief [ description | down ] ]
bridge-aggregation: Specifies Layer 2 aggregate interfaces.
route-aggregation: Specifies Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
down: Displays information about interfaces in the down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify the bridge-aggregation and route-aggregation keywords, the command displays information about all interfaces.
If you specify the bridge-aggregation or route-aggregation keyword and do not specify an interface number, the command displays information about all aggregate interfaces of that type.
If you specify the bridge-aggregation interface-number or route-aggregation interface-number option, the command displays information about the specified aggregate interface.
# Display detailed information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1
Bridge-Aggregation1
Current state: UP
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e207-f2e0
Description: Bridge-Aggregation1 Interface
Bandwidth: 0kbps
2Gbps-speed mode, full-duplex mode
PVID: 1
Port link-type: access
 Tagged Vlan:   none
 UnTagged Vlan: 1
Last clearing of counters:  Never
Last 300 seconds input:  0 packets/sec 0 bytes/sec -%
Last 300 seconds output:  0 packets/sec 0 bytes/sec -%
Input (total):  0 packets, 0 bytes
Input (normal):  0 packets, 0 bytes
         0 CRC, 0 frame, 0 overruns, 0 aborts
         0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
         0 lost carrier, 0 no carrier
# Display detailed information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1
Route-Aggregation1
Current state: UP
Line protocol state: UP
Description: Route-Aggregation1 Interface
Bandwidth: 1000000kbps
Maximum Transmit Unit: 1500
Internet protocol processing: disabled
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0000-fc00-2501
IPv6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 0000-fc00-2501
    Last 300 seconds input rate: 6 bytes/sec, 48 bits/sec, 0 packets/sec
    Last 300 seconds output rate: 2 bytes/sec, 16 bits/sec, 0 packets/sec
    11 packets input, 800 bytes, 0 drops
    1 packets output, 80 bytes, 0 drops
# Display brief information about Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> display interface bridge-aggregation 1 brief
Brief information on interface(s) under bridge mode:
Speed or Duplex: (a)/A - auto; H - half; F - full
BAGG1                UP   auto    A      A    1
# Display brief information about Layer 3 aggregate interface Route-Aggregation 1.
<Sysname> display interface route-aggregation 1 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
RAGG1                UP   UP       --
Bridge-Aggregation1
Layer 2 aggregate interface name.
Route-Aggregation1
Layer 3 aggregate interface name.
Current state
Layer 3 aggregate interface status:
·     DOWN (Administratively down)—The interface is administratively shut down with the shutdown command.
·     DOWN—The interface is administratively up but physically down (possibly because no physical link is present or the link has failed).
·     UP—The Ethernet interface is both administratively and physically up.
IPv4 packet frame format.
The value PKTFMT_ETHNT_2 indicates that packets are encapsulated in Ethernet II format.
Bandwidth
Expected bandwidth of the interface.
The interface speed and duplex mode are unknown.
PVID
Port VLAN ID (PVID).
Port link-type
Port link type: access, trunk, or hybrid.
Tagged Vlan
VLAN whose packets are sent out of this interface with a tag.
Untagged Vlan
VLAN whose packets are sent out of this interface without a tag.
Time when the reset counters interface command was last used to clear the interface statistics.
If the reset counters interface command has never been used on the interface since the device startup, this field displays Never.
Last 300 seconds input/output rate
Average input/output rate over the last 300 seconds.
Input/Output (total)
Statistics of all packets received/sent on the interface.
Input/Output (normal)
Statistics of all normal packets received/sent on the interface.
Line protocol state
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
IP packet processing.
Disabled indicates that IP packets cannot be processed.
For an interface configured with an IP address, this field changes to Internet Address is.
Brief information about Layer 3 interfaces.
Brief information about Layer 2 interfaces.
Link status:
·     ADM—The interface has been administratively shut down. To recover its physical layer state, run the undo shutdown command.
·     Stby—The interface is operating as a backup interface.
If the speed of an interface is automatically negotiated, the speed attribute of the interface includes the auto negotiation flag (the letter a in parentheses).
If an interface is configured to autonegotiate its speed but the autonegotiation has not started, its speed attribute is displayed as auto.
If the duplex mode of an interface is automatically negotiated, the duplex mode attribute of the interface includes the letter a in parentheses. H indicates the half duplex mode. F indicates the full duplex mode.
If an interface is configured to autonegotiate its duplex mode but the autonegotiation has not started, its duplex mode attribute is displayed as A.
Port link type options for interfaces.
If the data link layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present, its protocol attribute includes the spoofing flag (the letter s in parentheses).
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been administratively shut down. To bring up the interface, use the undo shutdown command.
Speed
Interface speed, in bps.
Protocol
Data link layer state of the interface:
·     UP—The data link layer of the interface is up.
·     DOWN—The data link layer of the interface is down.
·     UP(s)The data link layer of the interface is shown as UP, but its link is an on-demand link or not present.
Cause
Cause of a DOWN physical link.
Partial or complete interface description configured by using the description command.
·     If you do not specify the description keyword in the display interface brief command, this field displays only the first 27 characters of the interface description.
·     If you specify the description keyword in the display interface brief command, this field displays the complete interface description.
display lacp system-id
Use display lacp system-id to display the local system ID.
You can use the lacp system-priority command to change the LACP priority of the local system. The LACP priority value is specified in decimal format in the lacp system-priority command. However, it is displayed as a hexadecimal value in the output from the display lacp system-id command.
# Display the local system ID.
<Sysname> display lacp system-id
Actor System ID: 0x8000, 0000-fc00-6504
Local system ID, which contains the system LACP priority (0x8000 in this sample output) and the system MAC address (0000-FC00-6504 in this sample output).
display link-aggregation load-sharing mode
Use display link-aggregation load-sharing mode to display global or group-specific link-aggregation load sharing modes.
display link-aggregation load-sharing mode [ interface [ { bridge-aggregation | route-aggregation } interface-number ] ]
If you do not specify the interface keyword, the command displays the global link-aggregation load sharing modes.
If you specify the interface keyword, but do not specify an interface, the command displays all group-specific load sharing modes.
If you specify the bridge-aggregation interface-number or route-aggregation interface-number option, the command displays the load sharing mode of the specified aggregation group.
The bridge-aggregation or route-aggregation keyword is available only when Layer 2 or Layer 3 aggregate interfaces exist on the device.
# Display the default global link-aggregation load sharing modes.
<Sysname> display link-aggregation load-sharing mode
Link-Aggregation Load-Sharing Mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
# Display the configured global link-aggregation load sharing mode.
destination-mac address  source-mac address
# Display the default link-aggregation load sharing modes of Layer 2 aggregation group 10.
<Sysname> display link-aggregation load-sharing mode interface bridge-aggregation 10
Bridge-Aggregation10 Load-Sharing Mode:
# Display the configured link-aggregation load sharing mode of Layer 2 aggregation group 10.
Global link-aggregation load sharing mode.
By default, this field displays the link-aggregation load sharing modes for Layer 2 traffic and Layer 3 traffic.
If you have set the global link-aggregation load sharing mode, this field displays the set mode.
Link-aggregation load sharing mode of Layer 2 aggregation group 10.
By default, this field displays the global link-aggregation load sharing modes.
If you have set a link-aggregation load sharing mode for this aggregation group, this field displays the set mode.
Route-Aggregation10 Load-Sharing Mode
Link-aggregation load sharing mode of Layer 3 aggregation group 10.
Default link-aggregation load sharing mode for Layer 2 traffic. In this sample output, Layer 2 traffic is load shared based on the packet type.
Default link-aggregation load sharing mode for Layer 3 traffic. In this sample output, Layer 3 traffic is load shared based on the packet type.
destination-mac address, source-mac address
User-configured link-aggregation load sharing mode. In this sample output, traffic is load shared based on source and destination MAC addresses.
display link-aggregation member-port
Use display link-aggregation member-port to display detailed link aggregation information for the specified member ports.
display link-aggregation member-port [ interface-list ]
interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number [ to interface-type interface-number ]. interface-type interface-number specifies an interface by its type and number.
A member port in a static aggregation group is unaware of information about the peer group. For such member ports, the command displays the port number, port priority, and operational key of only the local end.
# Display detailed link aggregation information for Ten-GigabitEthernet 1/1/1, which is a member port of a static aggregation group.
<Sysname> display link-aggregation member-port ten-gigabitethernet 1/1/1
       G -- Defaulted, H -- Expired
Ten-GigabitEthernet1/1/1:
Port Number: 1
Port Priority: 32768
Oper-Key: 1
# Display detailed link aggregation information for Ten-GigabitEthernet 1/1/2, which is a member port of a dynamic aggregation group.
<Sysname> display link-aggregation member-port ten-gigabitethernet 1/1/2
Ten-GigabitEthernet1/1/2:
Aggregate Interface: Bridge-Aggregation10
Local:
    Port Number: 2
    Oper-Key: 2
    Flag: {ACDEF}
Remote:
    Port Number: 26
    Oper-Key: 2
    Flag: {ACDEF}
Received LACP Packets: 5 packet(s)
Illegal: 0 packet(s)
Sent LACP Packets: 7 packet(s)
Flags
LACP state flags. This field is one byte long, represented by ABCDEFGH from the least significant bit to the most significant bit. The letter is present when its bit is 1 and absent when its bit is 0.
·     AIndicates whether LACP is enabled. 1 indicates enabled, and 0 indicates disabled.
·     B—Indicates the LACP short or long timeout. 1 indicates short timeout, and 0 indicates long timeout.
·     C—Indicates whether the sending system considers that the link is aggregatable. 1 indicates yes, and 0 indicates no.
·     D—Indicates whether the sending system considers that the link is synchronized. 1 indicates yes, and 0 indicates no.
·     E—Indicates whether the sending system considers that the incoming frames are collected. 1 indicates yes, and 0 indicates no.
·     F—Indicates whether the sending system considers that the outgoing frames are distributed. 1 indicates yes, and 0 indicates no.
·     G—Indicates whether the sending system receives frames in the default state. 1 indicates yes, and 0 indicates no.
·     H—Indicates whether the sending system receives frames in the expired state. 1 indicates yes, and 0 indicates no.
Aggregate Interface
Aggregate interface to which the member port belongs.
Local
Information about the local end.
Oper-key
Operational key.
Flag
LACP protocol state flag.
Remote
Information about the peer end.
System ID
Peer system ID, containing the system LACP priority and the system MAC address.
Total number of LACP packets received.
Illegal
Total number of illegal packets.
Sent LACP Packets
Total number of LACP packets sent.
display link-aggregation summary
Use display link-aggregation summary to display brief information about all aggregation groups.
Static link aggregation groups are unaware of information about the peer groups. As a result, the Partner ID field displays None for a static link aggregation group.
# Display brief information for all aggregation groups.
<Sysname> display link-aggregation summary
Aggregation Interface Type:
BAGG -- Bridge-Aggregation, BLAGG -- Blade-Aggregation, RAGG -- Route-Aggregatio
n
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 0000-fc00-2500
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
BLAGG1     S     None                    0         0           0           Shar
BAGG1      S     None                    0         0           0           Shar
RAGG1      S     None                    1         0           0           Shar
Table 5 Command output
Aggregate Interface Type
Aggregate interface type:
·     BAGG—Layer 2.
·     RAGG—Layer 3.
Aggregation Mode
Aggregation group type:
·     S—Static.
·     D—Dynamic.
Loadsharing Type
Load sharing type:
·     Shar—Load sharing.
·     NonS—Non-load sharing.
Actor System ID
Local system ID, which contains the local system LACP priority and the local system MAC address.
AGG Interface
Type and number of the aggregate interface.
AGG Mode
Aggregation group type.
Partner ID
System ID of the peer system, which contains the peer system LACP priority and the peer system MAC address.
Selected Ports
Total number of Selected ports.
Unselected Ports
Total number of Unselected ports.
Individual Ports
Total number of Individual ports.
Share Type
Load sharing type.
display link-aggregation verbose
Use display link-aggregation verbose to display detailed information about the aggregation groups that correspond to the specified aggregate interfaces.
display link-aggregation verbose [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
interface-number: Specifies an existing aggregate interface by its number.
If you specify only the bridge-aggregation or route-aggregation keyword, the command displays detailed information about all Layer 2 or Layer 3 aggregation groups.
If you do not specify an aggregate interface type, the command displays detailed information about all aggregation groups.
# Display detailed information about Layer 2 aggregation group 10, which is a dynamic aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 10
Aggregation Mode: Dynamic
Local:
  Port             Status  Priority Oper-Key  Flag
  XGE1/1/1         S       32768    2         {ACDEF}
  XGE1/1/2         S       32768    2         {ACDEF}
  XGE1/1/3         S       32768    2         {AG}
Remote:
  Actor            Partner Priority Oper-Key  SystemID               Flag
  XGE1/1/1         1       32768    2         0x8000, 000f-e267-57ad {ACDEF}
  XGE1/1/2         2       32768    2         0x8000, 000f-e267-57ad {ACDEF}
  XGE1/1/3         0       32768    0         0x8000, 0000-0000-0000 {DEF}
# Display detailed information about Layer 2 aggregation group 20, which is a static aggregation group.
<Sysname> display link-aggregation verbose bridge-aggregation 20
Aggregate Interface: Bridge-Aggregation20
Aggregation Mode: Static
  XGE1/1/1         U       32768    1
  XGE1/1/2         U       32768    1
  XGE1/1/3         U       32768    1
Table 6 Command output
Loadsharing Type
Load sharing type:
Port Status
Port state: Selected, Unselected, or Individual.
Flags
Aggregate Interface
Name of the aggregate interface.
Aggregation Mode
·     S—Static.
·     D—Dynamic.
System ID
Local system ID, containing the local system LACP priority and the local system MAC address.
Local
Information about the local end:
·     Port—Port type and number.
·     Status—Port state, which can be Selected, Unselected, or Individual.
·     Priority—Port priority.
·     Oper-Key—Operational key.
·     Flag—LACP state flag.
For static aggregation groups, the Flag field is not displayed.
Remote
Information about the peer end:
·     ActorType and number of the local port.
·     PartnerIndex of the peer port.
·     Priority—Priority of the peer port.
·     Oper-Key—Operational key of the peer port.
·     System IDSystem ID of the peer end.
·     FlagLACP state flag of the peer end.
Use interface bridge-aggregation to create a Layer 2 aggregate interface and enter the Layer 2 aggregate interface view.
Use undo interface bridge-aggregation to delete a Layer 2 aggregate interface.
undo interface bridge-aggregation interface-number
No Layer 2 aggregate interfaces exist.
interface-number: Specifies a Layer 2 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
When you create a Layer 2 aggregate interface, the system automatically creates a Layer 2 aggregation group with the same number. The aggregation group operates in static aggregation mode by default.
Deleting a Layer 2 aggregate interface also deletes the Layer 2 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 2 aggregate interface Bridge-Aggregation 1, and enter its view.
Use interface route-aggregation to create a Layer 3 aggregate interface and enter Layer 3 aggregate interface view.
Use undo interface route-aggregation to delete a Layer 3 aggregate interface.
undo interface route-aggregation interface-number
No Layer 3 aggregate interfaces exist.
interface-number: Specifies a Layer 3 aggregate interface number. The value range for the interface-number argument is 1 to 1024.
When you create a Layer 3 aggregate interface, the system automatically creates a Layer 3 aggregation group with the same number. The Layer 3 aggregation group operates in static aggregation mode by default.
Deleting a Layer 3 aggregate interface also deletes the Layer 3 aggregation group. At the same time, the member ports of the aggregation group, if any, leave the aggregation group.
# Create Layer 3 aggregate interface Route-Aggregation 1 and enter its view.
[Sysname-Route-Aggregation1]
lacp edge-port
Use lacp edge-port to configure an aggregate interface as an edge aggregate interface.
Use undo lacp edge-port to restore the default.
lacp edge-port
undo lacp edge-port
An aggregate interface does not operate as an edge aggregate interface.
Use this command on the aggregate interface connecting an LACP-enabled device to an LACP-enabled server. This feature enables the aggregation member ports on the device to forward packets from the server (the peer system) during the server reboot process.
This command takes effect only on an aggregate interface corresponding to a dynamic aggregation group.
Link-aggregation traffic redirection cannot operate correctly on an edge aggregate interface.
# Configure Layer 2 aggregate interface Bridge-aggregation 1 as an edge aggregate interface.
<Sysname> System-view
[Sysname-Bridge-Aggregation1] lacp edge-port
lacp mode
Use lacp mode passive to configure LACP to operate in passive mode on a port.
Use undo lacp mode to restore the default.
lacp mode passive
undo lacp mode
LACP is operating in active mode on a port.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view
When LACP is operating in passive mode on a local member port and its peer port, both ports cannot send LACPDUs. When LACP is operating in active mode on either end of a link, both ports can send LACPDUs.
This command takes effect only on member ports of dynamic aggregation groups.
# Configure LACP to operate in passive mode on Ten-GigabitEthernet 1/1/1.
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] lacp mode passive
lacp period short
Use lacp period short to set the short LACP timeout interval (3 seconds) on an interface.
Use undo lacp period to restore the default.
lacp period short
undo lacp period
The LACP timeout interval is the long timeout interval (90 seconds).
To avoid traffic interruption during an ISSU, do not set the short LACP timeout interval before performing the ISSU. For more information about ISSU, see Fundamentals Configuration Guide.
# Set the short LACP timeout interval (3 seconds) on Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] lacp period short
Use lacp system-priority to set the system LACP priority.
Use undo lacp system-priority to restore the default.
lacp system-priority system-priority
The system LACP priority is 32768.
system-priority: Specifies the system LACP priority in the range of 0 to 65535. The smaller the value, the higher the system LACP priority.
# Set the system LACP priority to 64.
[Sysname] lacp system-priority 64
link-aggregation port-priority
link-aggregation bfd ipv4
Use link-aggregation bfd ipv4 to enable BFD for an aggregation group.
Use undo link-aggregation bfd to disable BFD for an aggregation group.
link-aggregation bfd ipv4 source ip-address destination ip-address
BFD is disabled for an aggregation group.
source ip-address: Specifies the source IP address of BFD sessions.
destination ip-address: Specifies the destination IP address of BFD sessions.
The source and destination IP addresses of BFD sessions must be unicast addresses excluding 0.0.0.0. Make sure the source and destination IP addresses are consistent at two ends of an aggregate link. For example, if you execute link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2 on the local end, execute link-aggregation bfd ipv4 source 2.2.2.2 destination 1.1.1.1 on the peer end.
The BFD parameters configured on an aggregate interface take effect on all BFD sessions in the aggregation group.
H3C recommends not configuring other protocols to collaborate with BFD on a BFD-enabled aggregate interface.
# Enable BFD for Layer 3 aggregation group 1, and specify the source and destination IP addresses as 1.1.1.1 and 2.2.2.2 for BFD sessions.
[Sysname-Route-Aggregation1] link-aggregation bfd ipv4 source 1.1.1.1 destination 2.2.2.2
link-aggregation global load-sharing mode
Use link-aggregation global load-sharing mode to set the global link-aggregation load sharing mode.
Use undo link-aggregation global load-sharing mode to restore the default.
link-aggregation global load-sharing mode { destination-ip | destination-mac | destination-port | ingress-port | source-ip | source-mac | source-port } *
The device load shares traffic automatically based on packet types.
destination-ip: Load shares traffic based on destination IP addresses.
destination-mac: Load shares traffic based on destination MAC addresses.
destination-port: Load shares traffic based on destination ports.
ingress-port: Load shares traffic based on ingress ports.
source-ip: Load shares traffic based on source IP addresses.
source-mac: Load shares traffic based on source MAC addresses.
source-port: Load shares traffic based on source ports.
The load sharing mode that you configure overwrites the previous mode.
If an unsupported load sharing mode is configured, an error prompt appears.
In system view, the switch supports the following load sharing modes and combinations:
·     Source IP address.
·     Destination IP address.
·     Source MAC address.
·     Destination MAC address.
·     Source IP address and destination IP address.
·     Source IP address and source port.
·     Destination IP address and destination port.
·     Source IP address, source port, destination IP address, and destination port.
·     Any combination of ingress port, source MAC address, and destination MAC address.
# Set the global load sharing mode to load share packets based on destination MAC addresses.
[Sysname] link-aggregation global load-sharing mode destination-mac
link-aggregation ignore vlan
Use link-aggregation ignore vlan to configure a Layer 2 aggregate interface to ignore the specified VLANs.
Use undo link-aggregation ignore vlan to restore the default.
link-aggregation ignore vlan vlan-id-list
undo link-aggregation ignore vlan vlan-id-list
A Layer 2 aggregate interface does not ignore any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for vlan-id2 must be equal to or greater than the value for vlan-id1.
With this command configured, a Layer 2 aggregate interface ignores the permitted VLAN and VLAN tagging mode configuration of the specified VLANs when choosing Selected ports.
# Configure Layer 2 aggregate interface bridge-aggregation 1 to ignore VLAN 50.
[Sysname-Bridge-Aggregation1] link-aggregation ignore vlan 50
link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation lacp traffic-redirect-notification enable to enable link-aggregation traffic redirection.
Use undo link-aggregation lacp traffic-redirect-notification enable to disable link-aggregation traffic redirection.
Link-aggregation traffic redirection is disabled.
When you restart an IRF member device that contains Selected ports, this feature redirects traffic of the IRF member device to other IRF member devices. Zero packet loss is guaranteed for known unicast traffic, but not for unknown unicast traffic.
Link-aggregation traffic redirection applies only to dynamic link aggregation groups.
To prevent traffic interruption, enable link-aggregation traffic redirection on devices at both ends of the aggregate link.
Do not enable both spanning tree and link-aggregation traffic redirection on a device. Otherwise, light packet loss might occur when the device reboots.
To avoid traffic interruption on Layer 2 dynamic aggregate links after link-aggregation traffic redirection is enabled, make sure the corresponding aggregate interfaces do not have static MAC address entries. For information about MAC address entries, see Layer 2—LAN Switching Configuration Guide.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
Use link-aggregation load-sharing mode to set the link-aggregation load sharing mode.
Use undo link-aggregation load-sharing mode to restore the default.
link-aggregation load-sharing mode { { destination-ip | destination-mac | mpls-label1 | mpls-label2 | source-ip | source-mac } * | flexible }
The load sharing mode is the same as the global load sharing mode.
mpls-label1: Load shares MPLS traffic based on Layer 1 labels.
mpls-label2: Load shares MPLS traffic based on Layer 2 labels.
flexible: Load shares traffic flexibly based on the packet type (for example, Layer 2 protocol packets, IPv4 packets, IPv6 packets, or MPLS packets).
In Layer 2 aggregate interface view, the switch supports the following load sharing modes and combinations:
·     Layer 1 MPLS label.
·     Destination IP address and source IP address.
·     Destination MAC address and source MAC address.
·     Layer 1 MPLS label and Layer 2 MPLS label.
# Configure Layer 2 aggregation group 1 to load share packets based on destination MAC addresses.
[Sysname-Bridge-Aggregation1] link-aggregation load-sharing mode destination-mac
link-aggregation load-sharing mode local-first
Use link-aggregation load-sharing mode local-first to enable local-first load sharing for link aggregation.
Use undo link-aggregation load-sharing mode local-first to disable local-first load sharing for link aggregation.
Local-first load sharing is enabled for link aggregation.
When you disable local-first load sharing, the packets will be load shared among all Selected ports of the aggregate interface on all IRF member devices.
# Disable local-first load sharing for link aggregation.
[Sysname] undo link-aggregation load-sharing mode local-first
link-aggregation mode
Use link-aggregation mode dynamic to configure an aggregation group to operate in dynamic aggregation mode and enable LACP.
Use undo link-aggregation mode to restore the default.
An aggregation group operates in static aggregation mode.
# Configure Layer 2 aggregation group 1 to operate in dynamic aggregation mode.
Use link-aggregation port-priority to set the port priority of an interface.
Use undo link-aggregation port-priority to restore the default.
link-aggregation port-priority port-priority
The port priority of an interface is 32768.
port-priority: Specifies the port priority in the range of 0 to 65535. The smaller the value, the higher the port priority.
# Set the port priority to 64 for Layer 2 Ethernet interface Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] link-aggregation port-priority 64
# Set the port priority to 64 for Layer 3 Ethernet interface Ten-GigabitEthernet 1/1/2.
[Sysname] interface ten-gigabitethernet 1/1/2
[Sysname-Ten-GigabitEthernet1/1/2] link-aggregation port-priority 64
link-aggregation selected-port maximum
Use link-aggregation selected-port maximum to configure the maximum number of Selected ports allowed in an aggregation group.
Use undo link-aggregation selected-port maximum to restore the default.
link-aggregation selected-port maximum number
The maximum number of Selected ports allowed in an aggregation group depends on hardware limitation.
number: Specifies the maximum number of Selected ports allowed in an aggregation group. The value range for this argument is 1 to 32.
Executing this command might cause some of the Selected ports in an aggregation group to become Unselected ports.
The maximum number of Selected ports allowed in the aggregation groups of the local and peer ends must be consistent.
The maximum number of Selected ports allowed in an aggregation group is limited by one of the following values, whichever value is smaller:
·     Maximum number configured by using the link-aggregation selected-port maximum command.
·     Hardware limitation.
You can configure backup between two ports by performing the following tasks:
·     Assigning two ports to an aggregation group.
·     Setting the maximum number of Selected ports to 1 for the aggregation group.
Then, only one Selected port is allowed in the aggregation group at any point in time, while the Unselected port acts as a backup port.
# Set the maximum number of Selected ports to 5 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port maximum 5
link-aggregation selected-port minimum
Use link-aggregation selected-port minimum to configure the minimum number of Selected ports in an aggregation group.
Use undo link-aggregation selected-port minimum to restore the default.
link-aggregation selected-port minimum number
The minimum number of Selected ports in an aggregation group is not specified.
number: Specifies the minimum number of Selected ports in an aggregation group required to bring up the aggregate interface. The value range for this argument is 1 to 32.
Executing this command might cause all member ports in the aggregation group to become Unselected ports.
The minimum number of Selected ports allowed in the aggregation groups of the local and peer ends must be consistent.
# Set the minimum number of Selected ports to 3 for Layer 2 aggregation group 1.
[Sysname-Bridge-Aggregation1] link-aggregation selected-port minimum 3
mtu
Use mtu to set the MTU for a Layer 3 aggregate interface.
mtu size
undo mtu
The MTU for Layer 3 aggregate interfaces is 1500 bytes.
size: Specifies the MTU in bytes. The value range is 46 to 1560.
# Set the MTU to 1430 bytes for Layer 3 aggregate interface Route-Aggregation 1.
[Sysname-Route-Aggregation1] mtu 1430
display interface
port link-aggregation group
Use port link-aggregation group to assign an Ethernet interface to an aggregation group.
Use undo port link-aggregation group to remove an Ethernet interface from the aggregation group to which it belongs.
port link-aggregation group number
An Ethernet interface does not belong to any aggregation group.
number: Specifies an aggregation group by its aggregate interface number. The value range for the number argument is 1 to 1024.
A Layer 2 Ethernet interface can be assigned to a Layer 2 aggregation group only. A Layer 3 Ethernet interface can be assigned to a Layer 3 aggregation group only.
An interface can belong to only one aggregation group.
# Assign Layer 2 Ethernet interface Ten-GigabitEthernet 1/1/1 to Layer 2 aggregation group 2.
[Sysname-Ten-GigabitEthernet1/1/1] port link-aggregation group 2
# Assign Layer 3 Ethernet interface Ten-GigabitEthernet 1/1/2 to Layer 3 aggregation group 3.
[Sysname-Ten-GigabitEthernet1/1/2] port link-aggregation group 3
Use reset counters interface to clear statistics for the specified aggregate interfaces.
reset counters interface [ { bridge-aggregation | route-aggregation } [ interface-number ] ]
interface-number: Specifies an aggregate interface number.
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify any options, the command clears statistics for all interfaces in the system.
If you specify only the bridge-aggregation or route-aggregation keyword, the command clears statistics for all Layer 2 or Layer 3 aggregate interfaces.
If you specify the bridge-aggregation interface-number or route-aggregation interface-number option, the command clears statistics for the specified Layer 2 or Layer 3 aggregate interface.
# Clear statistics for Layer 2 aggregate interface Bridge-Aggregation 1.
<Sysname> reset counters interface bridge-aggregation 1
reset lacp statistics
Use reset lacp statistics to clear LACP statistics for the specified link aggregation member ports.
interface interface-list: Specifies a list of link aggregation member ports, in the format interface-type interface-number [ to interface-type interface-number ]. interface-type interface-number specifies an interface by its type and number. If you do not specify any member ports, the command clears LACP statistics for all member ports.
# Clear LACP statistics for all link aggregation member ports.
<Sysname> reset lacp statistics
shutdown
Use shutdown to shut down an aggregate interface.
Use undo shutdown to bring up an aggregate interface.
shutdown
An aggregate interface is up.
# Bring up Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] undo shutdown
