01-Fundamentals Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10001-Fundamentals Command Reference
10-Device management commands
10-Device management commands 366.8 KB
Device management commands· 1
clock datetime· 1
clock protocol 2
clock summer-time· 2
clock timezone· 4
command· 5
copyright-info enable· 6
display alarm·· 7
display asset-info· 8
display clock· 10
display copyright 11
display cpu-usage· 11
display cpu-usage configuration· 13
display cpu-usage history· 14
display device· 16
display device manuinfo· 19
display device manuinfo chassis-only· 21
display device manuinfo fan· 22
display device manuinfo power 23
display diagnostic-information· 24
display environment 25
display fan· 27
display memory· 27
display memory-threshold· 29
display power 31
display scheduler job· 31
display scheduler logfile· 32
display scheduler reboot 33
display scheduler schedule· 33
display switch-mode status· 35
display system stable state· 37
display system-working-mode· 38
display transceiver alarm·· 39
display transceiver diagnosis· 40
display transceiver interface· 41
display transceiver manuinfo· 42
display version· 43
display version-update-record· 44
fabric-mode· 45
fan prefer-direction· 47
hardware-failure-detection· 48
header 49
job· 50
memory-threshold· 51
memory-threshold usage· 52
monitor cpu-usage enable· 53
monitor cpu-usage interval 54
monitor cpu-usage threshold· 55
monitor handshake-timeout disable-port 56
reboot 57
reset asset-info· 59
reset version-update-record· 61
reset scheduler logfile· 61
restore factory-default 61
scheduler job· 62
scheduler logfile size· 63
scheduler reboot at 64
scheduler reboot delay· 64
scheduler schedule· 65
set asset-info· 66
shutdown-interval 67
switch-fabric isolate· 68
switch-fabric removal-signal-suppression· 69
switch-mode· 70
sysname· 71
system-working-mode· 72
temperature-limit 73
time at 74
time once· 75
time repeating· 76
transceiver phony-alarm-disable· 78
user-role· 78
clock datetime
Use clock datetime to set the UTC time.
clock datetime time date
The UTC time is the device manufacture time.
time: Specifies a time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
Correct system time is essential to network management and communication. You must configure the system time correctly before you run the device on the network.
The system time is determined by the UTC time, the time zone, and the daylight saving time. You can use the display clock command to view the system time.
You can use this command to specify a UTC time for the device, or configure the device to obtain the UTC time from an NTP time source. The UTC time obtained from an NTP time source is more precise.
# Set the UTC time to 08:08:08 01/01/2012.
<Sysname> clock datetime 8:8:8 1/1/2012
# Set the UTC time to 08:10:00 01/01/2012.
<Sysname> clock datetime 8:10 2012/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol
Use clock protocol to specify the UTC time source.
Use undo clock protocol to restore the default.
clock protocol { none | ntp mdc mdc-id }
undo clock protocol
The device obtains the UTC time through NTP.
none: Uses the local UTC time set by using the clock datetime command.
ntp: Uses NTP to obtain the UTC time. You must configure NTP correctly. For more information about NTP and NTP configuration, see Network Management and Monitoring Configuration Guide.
mdc mdc-id: Specifies the MDC to be used for time synchronization.
The device can obtain the UTC time from one of the following time sources:
·     None—Local UTC time set by using the clock datetime command.
·     NTP—NTP time source.
All MDCs on the device use the same system time. After obtaining the system time from an MDC, the device automatically synchronizes the system time to the other MDCs. By default, the device uses the NTP time source specified on the default MDC.
# Configure the device to use the local UTC time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to configure the device to use daylight saving time during a specific period of time.
Use undo clock summer-time to cancel the configuration.
Daylight saving time is disabled.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week date, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
Make sure all devices on the network are using the same daylight saving time as the local time.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone
Use clock timezone to set the time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The time zone is not set.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the hh:mm:ss format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
Make sure all devices on the network are using the same time zone as the local time.
# Set the name of the time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order.
command: Specifies the command to be assigned to the job.
To assign a command (command A) to a job, you must first assign the job the command or commands for entering the view of command A.
If you specify the ID of an existing command for another command, the existing command is replaced.
Make sure all commands in a schedule are compliant to the command syntax. The system does not examine the syntax when you assign a command to a job.
If a command requires a yes or no answer, the system always assumes that a Y or Yes is entered. If a command requires a character string input, the system assumes that either the default character string (if any) or a null string is entered.
A job cannot contain the telnet, ftp, ssh2, or monitor process command.
# Assign commands to job backupconfig to back up configuration file startup.cfg to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# Assign commands to job shutdownGE to shut down the interface GigabitEthernet 1/0/1.
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
scheduler job
Use copyright-info enable to enable copyright statement display.
Use undo copyright-info enable to disable copyright statement display.
Copyright statement display is enabled.
# Enable copyright statement display.
[Sysname] copyright-info enable
·     When a Telnet user logs in, the following statement appears:
* Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                               *
* no decompiling or reverse-engineering shall be allowed.                  *
<Sysname>
·     When a console user quits user view, the system automatically restarts the session and displays the following message:
User interface aux0 is available.
Press ENTER to get started.
# Disable copyright statement display.
[Sysname] undo copyright-info enable
·     When a Telnet user logs in, the user view prompt appears as follows:
<Sysname>
display alarm
Use display alarm to display alarm information.
In standalone mode:
display alarm [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays alarm information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. On an IRF fabric, this command displays information for all cards if you do not specify a card. On an IRF 3 system, this command displays information for all cards and PEXs if you do not specify a card or PEX. (In IRF mode.)
# (In standalone mode.) Display alarm information.
<Sysname> display alarm
Slot   CPU   Level   Info
-      -     INFO    Power 1 is absent.
-      -     INFO    Power 2 is absent.
-      -     INFO    Power 3 is absent.
8      0     ERROR   Board is faulty
9      0     ERROR   Board is faulty
Slot
Slot number of the card with an alarm. If the value is a hyphen (-), the alarm was generated by the chassis. (In standalone mode.)
Level
Alarm severity. Possible values include ERROR, WARNING, NOTICE, and INFO, in descending order.
Info
Detailed alarm information.
faulty
The card is starting up or is faulty.
# (In IRF mode.) Display alarm information.
Chassis  Slot   CPU   Level   Info
1        -      -     INFO    Chassis 1 Power 1 is absent.
1        -      -     INFO    Chassis 1 Power 2 is absent.
1        8      0     ERROR   Chassis 1 Board is faulty
2        9      0     ERROR   Chassis 2 Board is faulty
Chassis
ID of the IRF member device with an alarm.
Slot
Slot number of the card.
Level
Info
The board in slot n is faulty.
The card in slot n is starting up or is faulty.
display asset-info
Use display asset-info to display the asset profile for a physical component.
In standalone mode:
display asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
In IRF mode:
display asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
chassis: Displays the asset profile for the chassis.
fan fan-id: Displays the asset profile for the specified fan tray.
power power-id: Displays the asset profile for the specified power module.
slot slot-number: Displays the asset profile for the card in the specified slot.
csn: Displays the asset ID for the asset.
custom: Displays the customized asset items.
department: Displays the department name.
description: Displays the asset description.
service-date: Displays the service start date.
state: Displays the asset usage status.
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
For a power module, only the csn keyword is supported.
To display an item in an asset profile, specify the corresponding keyword for the command. To display all items in an asset profile, do not specify the item keywords.
If an item is not configured, the system displays an empty field.
If you specify a fan tray or power module that does not exist, the system prompts that the fan tray or power module is absent.
# (In standalone mode.) Display the asset ID for fan tray 0.
[Sysname] display asset-info fan 0 csn
Type        : Fan 0
csn         : 123456
# (In standalone mode.) Display the asset information for fan tray 0.
Type        : Fan 0
csn         : 123456
description : FAN 0
service-date:
department  : MKT
state       : Normal
custom      : 1:789
# (In IRF mode.) Display the asset ID for fan tray 0 on IRF member device 1.
<system-view> system-view
[Sysname] display asset-info chassis 1 fan 0 csn
Type        : Fan 0
csn         : 123456
# (In IRF mode.) Display the asset information for fan tray 0 on IRF member device 1.
Type        : Fan 0
csn         : 123456
description : FAN 0
service-date:
department  : MKT
state       : Normal
custom      : 1:789
·     reset asset-info
·     set asset-info
display clock
Use display clock to display the system time, date, local time zone, and daylight saving time.
display clock
# Display the system time and date when the local time zone is not specified.
<Sysname> display clock
10:09:00 UTC Fri 03/16/2012
# Display the system time and date when the local time zone Z5 is specified.
15:10:00 Z5 Fri 03/16/2012
Time Zone : Z5 add 05:00:00
# Display the system time and date when the local time zone Z5 and daylight saving time PDT are specified.
15:11:00 Z5 Fri 03/16/2012
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright
Use display copyright to display the copyright statement, including software and hardware copyright statements, and software license information.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display the current CPU usage statistics.
In standalone mode:
display cpu-usage [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display cpu-usage [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the CPU usage statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. On an IRF fabric, this command displays CPU usage statistics for all cards if you do not specify a card. On an IRF 3 system, this command displays CPU usage statistics for all cards and PEXs if you do not specify a card or PEX. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command displays the CPU usage statistics for the default CPU.
After startup, the device tracks the average CPU usage at the following intervals:
·     5 seconds.
·     1 minute.
·     5 minutes.
This command displays the average CPU usage values for the last 5 seconds, 1 minute, and 5 minutes.
# (In standalone mode.) Display the current CPU usage statistics.
<Sysname> display cpu-usage
Slot 3 CPU 0 CPU usage:
       2% in last 5 seconds
       2% in last 1 minute
       2% in last 5 minutes
Slot 7 CPU 0 CPU usage:
       0% in last 5 seconds
       0% in last 1 minute
       0% in last 5 minutes
# (In IRF mode.) Display the current CPU usage statistics for all cards.
Chassis 1 Slot 3 CPU 0 CPU usage:
       2% in last 1 minute
Chassis 1 Slot 7 CPU 0 CPU usage:
       0% in last 1 minute
Average CPU usage during the last 5-second interval.
2% in last 1 minute
Average CPU usage during the last 1-minute interval.
Average CPU usage during the last 5-minute interval.
Slot x CPU y CPU usage
Usage statistics for CPU y of the card in slot x. (In standalone mode.)
Chassis x Slot y CPU z CPU usage
Usage statistics for CPU z of the card in slot y on member device x. (In IRF mode.)
Use display cpu-usage configuration to display CPU usage monitoring settings.
In standalone mode:
In IRF mode:
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the CPU usage monitoring settings for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify a card or PEX, this command displays the CPU usage monitoring settings for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command displays the CPU usage monitoring settings for the default CPU.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 99%.
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
Use display cpu-usage history to display the historical CPU usage statistics in a coordinate system.
In standalone mode:
In IRF mode:
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id: Specifies a process by its ID. If you do not specify this option, the command displays the historical statistics for the entire system's CPU usage (the total CPU usage of all processes). To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies a card by its slot number. If you specify the job job-id option but do not specify this option, the command displays the historical CPU usage statistics for the process on the active MPU. If you do not specify any options, the command displays the historical statistics for all processes on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you specify a process but do not specify a card or PEX, this command displays the statistics for the process on the global active MPU. If you do not specify any options, this command displays the statistics for all processes in the IRF fabric. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you specify the job job-id option but do not specify this option, the command displays the historical CPU usage statistics for the default CPU. If you do not specify the job job-id option or this option, the command displays the historical statistics for all CPUs.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Consecutive pound signs (#) indicate the CPU usage at a specific time. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics for the entire system.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Chassis 1 Slot 7 CPU 0)
The output shows the following items:
·     Process name. The name SYSTEM represents the entire system.
·     CPU that is holding the process is CPU 0 in slot 7 of member device 1.
·     Historical CPU usage statistics for the entire system during the last 60 minutes.
¡     12 minutes ago: Approximately 5%.
¡     13 minutes ago: Approximately 10%.
¡     14 minutes ago: Approximately 15%.
¡     15 minutes ago: Approximately 10%.
¡     16 and 17 minutes ago: Approximately 5%.
¡     18 minutes ago: Approximately 10%.
¡     19 minutes ago: Approximately 5%.
¡     Other time: 2% or lower than 2%.
# Display the historical CPU usage statistics for process 1.
<Sysname> display cpu-usage history job 1
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|
 10%|
  5%|                   #
·     Process name, which is scmd. A process name in  a pair of square brackets ([ ]) represents a kernel process.
·     Historical CPU usage statistics for process 1 in the last 60 minutes.
¡     20 minutes ago: Approximately 5%.
display device
Use display device to display device information.
In standalone mode:
display device [ flash ] [ slot slot-number [ subslot subslot-number ] | verbose ]
In IRF mode:
display device [ flash ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
flash: Specifies the flash memory.
chassis chassis-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual chassis number. On an IRF fabric, this command displays hardware information for all member devices if you do not specify a member device. On an IRF 3 system, this command displays hardware information for all IRF member devices and PEXs if you do not specify a member device or PEX. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays hardware information for all cards. (In standalone mode.)
slot slot-number: Specifies a card or a PEX by its slot number. On an IRF fabric, this command displays hardware information for all cards if you do not specify a card. On an IRF 3 system, this command displays hardware information for all cards and PEXs if you do not specify a card or PEX. (In IRF mode.)
subslot subslot-number: Specifies a subcard by its subslot number. If you do not specify this option, the command does not display information about any subcards.
verbose: Displays detailed hardware information. If you do not specify this keyword, the command displays brief information.
# (In standalone mode.) Display device information.
<Sysname> display device
Slot   Type                State    Subslot  Soft Ver             Patch Ver
 0     NONE                Absent   0        NONE                 None
 1     NONE                Absent   0        NONE                 None
 2     NONE                Absent   0        NONE                 None
 3     LSUM1TGS24EC0       Normal   0        S7500E-X-7178        None
 4     NONE                Absent   0        NONE                 None
 5     NONE                Absent   0        NONE                 None
 6     NONE                Absent   0        NONE                 None
 7     LSQM1MPU06B0        Master   0        S7500E-X-7178        None
 8     NONE                Fault    0        NONE                 None
 9     NONE                Fault    0        NONE                 None
The output shows that the device has one MPU and one interface module. The MPU is in slot 7, and the interface module is in slot 3.
Slot No.
Brd Type
Hardware type of the card.
Brd Status
Card status:
·     StandbyThe card is the standby MPU.
·     MasterThe card is the active MPU.
·     AbsentThe slot is not installed with a card.
·     FaultThe card is faulty and cannot start up.
·     NormalThe card is an interface module and is operating correctly.
·     Offline—The switching fabric module is isolated.
Subslot Num
Maximum number of subcards that the base card supports.
Sft Ver
Software version of the card.
Patch Ver
Patch version of the card.
# (In IRF mode.) Display device information about all IRF member devices.
1/0    NONE                Absent   0        NONE                 None
1/1    NONE                Absent   0        NONE                 None
1/2    NONE                Absent   0        NONE                 None
1/3    LSUM1TGS24EC0       Normal   0        S7500E-X-7178        None
1/4    NONE                Absent   0        NONE                 None
1/5    NONE                Absent   0        NONE                 None
1/6    NONE                Absent   0        NONE                 None
1/7    LSQM1MPU06B0        Master   0        S7500E-X-7178        None
1/8    NONE                Fault    0        NONE                 None
1/9    NONE                Fault    0        NONE                 None
The output shows that the IRF fabric has one member device (with the member ID 1). The global active MPU is in slot 7. The card in slot 3 is an interface module.
Table 5 Command output
Slot
Member ID of the chassis and slot number of the card, in the member ID/slot number format.
Card type.
Card status:
·     AbsentNo card is inserted in the slot.
·     Master—The card is the global active MPU.
·     Standby—The card is a global standby MPU.
·     Normal—The card is an interface module and is operating correctly.
·     Fault—The card is faulty.
Subslot
Soft Ver
Patch Ver
Patch version of the card. If no patch is installed, the value of this field is None.
Use display device manuinfo to display electronic label information for the device.
In standalone mode:
display device manuinfo [ slot slot-number [ subslot subslot-number ] ]
In IRF mode:
display device manuinfo [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ]
chassis chassis-number: Specifies an IRF member device by its member ID, or a PEX by its virtual chassis number. If you do not specify this option, the command displays electronic label information for all member devices and all PEXs. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays electronic label information of all cards. (In standalone mode.)
slot slot-number: Specifies a card or a PEX by its slot number. If you do not specify this option, the command displays electronic label information for all cards and PEXs. (In IRF mode.)
An electronic label is a profile of a device or card. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during debugging or testing.
# (In standalone mode.) Display electronic label information for the device.
<Sysname> display device manuinfo
Chassis self:
 DEVICE_NAME          : LS-S7506E-X
 DEVICE_SERIAL_NUMBER : 210235A1H19876543220
 MAC_ADDRESS          : NONE
 MANUFACTURING_DATE   : 2014-12-29
 VENDOR_NAME          : H3C
Slot 6 CPU 0:
DEVICE_NAME           : LSQM1MPU06B0
 DEVICE_SERIAL_NUMBER : 210231A2VP1236547987
 MAC_ADDRESS          : 00FE-5689-AA60
 MANUFACTURING_DATE   : 2014-12-26
 VENDOR_NAME          : H3C
Fan 0:
 DEVICE_NAME          : LSUM106FAN
 DEVICE_SERIAL_NUMBER : 210231A2YG9876543210
 MAC_ADDRESS          : NONE
 VENDOR_NAME          : H3C
Power 0
 DEVICE_NAME          : POWER
 DEVICE_SERIAL_NUMBER : 210231A0PPX127000196
 MAC_ADDRESS          : NONE
 MANUFACTURING_DATE   : 2012-07-05
 VENDOR_NAME          : H3C
Table 6 Command output
Slot m CPU n
Slot number of the card and number of the CPU.
DEVICE_NAME
Device name.
Serial number.
MAC_ADDRESS
MAC address.
MANUFACTURING_DATE
Manufacturing date.
VENDOR_NAME
Vendor name.
# (In IRF mode.) Display electronic label information for the device.
Chassis 1:
Chassis self:
MAC_ADDRESS          : NONE
VENDOR_NAME          : H3C
Slot 6 CPU 0:
 VENDOR_NAME          : H3C
Fan 0:
 DEVICE_NAME          :LSUM106FAN
DEVICE_SERIAL_NUMBER :210231A2YG9876543210
MAC_ADDRESS          :NONE
MANUFACTURING_DATE   :2014-12-29
VENDOR_NAME           :H3C
Table 7 Command output
Chassis x
Member ID of the member device
Slot y CPU z
Number of the slot and number of the CPU.
DEVICE_NAME
Device name.
Serial number.
MAC_ADDRESS
MAC address.
MANUFACTURING_DATE
Manufacturing date.
VENDOR_NAME
Vendor name.
Use display device manuinfo chassis-only to display electronic label information for a backplane.
In standalone mode:
In IRF mode:
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual chassis number. (In IRF mode.)
# (In standalone mode.) Display electronic label information for the backplane.
<Sysname> display device manuinfo chassis-only
Chassis self:
MAC_ADDRESS          : NONE
VENDOR_NAME          : H3C
# (In IRF mode.) Display electronic label information for the backplane on IRF member device 1.
<Sysname> display device manuinfo chassis 1 chassis-only
Chassis 1:
Chassis self:
MAC_ADDRESS          : NONE
VENDOR_NAME          : H3C
Use display device manuinfo fan to display electronic label information for a fan.
In standalone mode:
display device manuinfo fan fan-id
In IRF mode:
display device manuinfo chassis { chassis-number | virtual-chassis-number slot slot-number } fan fan-id
chassis { chassis-number | virtual-chassis-number slot slot-number }: Specifies an IRF member device by its member ID or specifies a PEX by its virtual chassis number and slot number. The slot number is fixed at 0. (In IRF mode.)
fan-id: Specifies a fan by its ID.
# (In standalone mode.) Display electronic label information for fan 0.
<Sysname> display device manuinfo fan 0
Fan 0:
DEVICE_SERIAL_NUMBER:210231A2YG9876543210
MAC_ADDRESS         :NONE
VENDOR_NAME         :H3C
# (In IRF mode.) Display electronic label information for fan 0 on IRF member device 1.
<Sysname> display device manuinfo chassis 1 fan 0
Chassis 1:
Fan 0:
MAC_ADDRESS         :NONE
VENDOR_NAME         :H3C
Use display device manuinfo power to display electronic label information for a power module.
In standalone mode:
display device manuinfo power power-id
In IRF mode:
display device manuinfo chassis { chassis-number | virtual-chassis-number slot slot-number } power power-id
power-id: Specifies a power module by its ID.
# (In standalone mode.) Display electronic label information for power module 2.
<Sysname> display device manuinfo power 2
Power 2
 DEVICE_NAME          : POWER
 MAC_ADDRESS          : NONE
 VENDOR_NAME          : H3C
# (In IRF mode.) Display electronic label information for power module 2 on IRF member device 1.
<Sysname> display device manuinfo chassis 1 power 2
Chassis 1:
Power 2
 DEVICE_NAME          : POWER
 MAC_ADDRESS          : NONE
 VENDOR_NAME          : H3C
Use display diagnostic-information to display or save device diagnostic information.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ filename ]
hardware: Displays hardware-related diagnostic information.
infrastructure: Displays diagnostic information about the fundamental modules.
l2: Displays diagnostic information about Layer 2 features.
l3: Displays diagnostic information about Layer 3 features.
service: Displays diagnostic information about upper-layer features.
filename: Saves the diagnostic information to a file. The filename argument must use the .tar.gz suffix. If you do not specify this argument, the command prompts you to choose whether to save the information to a file or display the information.
If you do not specify any feature options, the command displays or saves diagnostic information about all feature modules.
This command does not support the |, >, and >> options.
You can use one of the following methods to collect device diagnostic information:
·     Use separate display commands to collect diagnostic information feature by feature or module by module.
·     Use the display diagnostic-information command to collect diagnostic information about multiple or all features and hardware modules.
If you specify the filename argument, the device also collects and saves core files to the specified file. The file is automatically compressed to save storage space. The default file name is in the diag_sysname_YYYYMMDD-hhmmss.tar.gz format, for example, diag_sysname_20140829-083832.tar.gz.
To view the file content:
1.     Use the tar extract command to extract the file.
2.     Execute the more command.
# Display diagnostic information about all feature modules.
  ===============display cpu===============
       3% in last 1 minute
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
  ===============display cpu-usage history slot 3 ===============
# Save diagnostic information about all feature modules to file test.tar.gz.
·     Method 1: Specify the filename in interactive mode.
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_sysname_20140829-083832.tar.gz]: test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
·     Method 2: Specify the filename for the command.
<Sysname> display diagnostic-information test.tar.gz
Please wait...
Save successfully.
·     more
·     tar extract
display environment
Use display environment to display the temperature statistics for the temperature sensors, including the current temperature and temperature thresholds.
In standalone mode:
In IRF mode:
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual chassis number. On an IRF fabric, this command displays temperature information for all member devices if you do not specify a member device. On an IRF 3 system, this command displays temperature information for all IRF member devices and PEXs if you do not specify a member device or PEX. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. (In standalone mode.)
slot slot-number: Specifies a card or a PEX by its slot number. On an IRF fabric, this command displays temperature information for all cards if you do not specify a card. On an IRF 3 system, this command displays temperature information for all cards and PEXs if you do not specify a card or PEX. (In IRF mode.)
In standalone mode, this command displays statistics for all temperature sensors on the device if you do not specify a card.
In IRF mode, this command displays statistics for all temperature sensors in the IRF fabric if you do not specify an IRF member device. If you specify an IRF member device but do not specify a card, this command displays statistics for all sensors on the member device.
# (In standalone mode.) Display the temperature statistics for all temperature sensors on the device.
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 3     hotspot 1 38           0      80       97     NA
 3     hotspot 2 49           0      80       97     NA
 7     inflow  1 31           0      71       90     NA
 7     outflow 1 44           0      80       99     NA
 7     hotspot 1 47           0      81       100    NA
 7     hotspot 2 53           0      88       107    NA
Table 8 Command output
System Temperature information (degree centigrade)
Temperature information (°C).
sensor
Temperature sensor:
·     hotspot—Hotspot sensor.
·     inflow—Air inlet sensor.
·     outflow—Air outlet sensor.
Slot
Slot number of a card. (In standalone mode.)
Slot
Member ID and slot number of a card on an IRF member device in the member ID/slot number format. (In IRF mode.)
Temperature
Current temperature.
LowerLimit
Lower temperature limit.
WarningLimit
Warning temperature threshold.
AlarmLimit
Alarming temperature threshold.
ShutdownLimit
Shutdown temperature threshold. When the sensor temperature reaches the limit, the system shuts down automatically.
display fan
Use display fan to display the operating states of fans.
In standalone mode:
display fan [ fan-id ]
In IRF mode:
display fan [ chassis { chassis-number | virtual-chassis-number slot slot-number } [ fan-id ] ]
chassis { chassis-number | virtual-chassis-number slot slot-number }: Specifies an IRF member device by its member ID or specifies a PEX by its virtual chassis number and slot number. The slot number is fixed at 0. On an IRF fabric, this command displays fan operating status information for all member devices if you do not specify a member device. On an IRF 3 system, this command displays fan operating status information for all IRF member devices and PEXs if you do not specify a member device or PEX. (In IRF mode.)
fan-id: Specifies a fan by its ID. If you do not specify this option, the command displays the operating states of all fans on the device. (In standalone mode.)
# Display the operating states of all fans.
<Sysname> display fan
Fan Frame 1  State: Normal
display memory
Use display memory to display memory usage information.
In standalone mode:
display memory [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display memory [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays memory usage for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device by its slot number and the member ID. If you do not specify this option, the command displays memory usage for all cards in the IRF fabric. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command displays information about the default CPU.
# (In standalone mode.) Display memory usage information.
<Sysname> display memory
The statistics about memory is measured in KB:
Slot 3:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:        999968    345792    654176         0         0     28496       65.4%
-/+ Buffers/Cache:    317296    682672
Swap:           0         0         0
Slot 7:
Mem:       8135316    737928   7397388         0       152    175584       90.9%
-/+ Buffers/Cache:    562192   7573124
Swap:           0         0         0
# (In IRF mode.) Display memory usage information.
Chassis 1 Slot 3:
Swap:           0         0         0
Chassis 1 Slot 7:
Swap:           0         0         0
Table 9 Command output
Slot
Chassis x Slot x
Slot number of a card on a member device. (In IRF mode.)
Mem
Memory usage information.
Total
Total size of the allocable physical memory space.
The memory space is virtually divided into two parts: the allocable part and the unallocable part. The latter is used for kernel codes, kernel management, and ISSU functions. The former can be allocated and used for such tasks as running service modules and storing files.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
Buffers
Physical memory used for buffers.
Cached
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Swap memory.
Use display memory-threshold to display memory alarm thresholds and statistics.
In standalone mode:
In IRF mode:
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the memory usage thresholds and statistics for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify a card or PEX, this command displays the memory usage thresholds and statistics for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command displays the memory usage thresholds and statistics for the default CPU.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory alarm thresholds and statistics.
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
    Minor: 96M
    Severe: 64M
    Critical: 48M
    Normal: 128M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
display power
Use display power to display power module information.
In standalone mode:
display power [ power-id ]
In IRF mode:
display power [ chassis { chassis-number | virtual-chassis-number slot slot-number } [ power-id ] ]
chassis { chassis-number | virtual-chassis-number slot slot-number }: Specifies an IRF member device by its member ID or specifies a PEX by its virtual chassis number and slot number. The slot number is fixed at 0. On an IRF fabric, this command displays power supply information for all member devices if you do not specify a member device. On an IRF 3 system, this command displays power supply information for all IRF member devices and PEXs if you do not specify a member device or PEX. (In IRF mode.)
power-id: Specifies a power module by its ID. If you do not specify this option, the command displays information about all power modules on the specified object.
This command does not display the power of an S5130-EI switch that acts as a PEX.
# Display power module information.
<Sysname> display power
Power        1 State: Normal
 Power        2 State: Absent
 Power        3 State: Absent
 Power        4 State: Absent
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify this option, the command displays configuration information for all jobs.
# Display configuration information for all jobs.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
// The output shows that the device has three jobs: the first has one command, the second has no command, and the third has two commands. Jobs are separated by blank lines.
Use display scheduler logfile to display job execution log information.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
[Sysname]interface rang gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Sysname-if-range]shutdown
Table 10 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job has no commands, this field is blank.
Job output
Commands in the job and their output.
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify this option, the command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule name        : START-pc1/pc2
Schedule type        : Run on every Mon Tue Wed Thu Fri at 08:00:00
Start time           : Thu Aug  7 08:00:00 2014
Last execution time  : Yet to be executed
start-GigabitEthernet1/0/1                        -NA-
start-GigabitEthernet1/0/2                        -NA-
Schedule name        : STOP-pc1/pc2
Schedule type        : Run on every Mon Tue Wed Thu Fri at 18:00:00
Start time           : Wed Aug  6 18:00:00 2014
shutdown-GigabitEthernet1/0/1                     -NA-
shutdown-GigabitEthernet1/0/2                     -NA-
Schedule name        : saveconfig
1                                                 -NA-
Table 11 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last completion time
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
Use display switch-mode status to display operating mode information about service modules.
In standalone mode:
In IRF mode:
display switch-mode status chassis chassis-number
If a service module does not have an operating mode specified, the Config field displays NONE. The service module will operate in the default mode after you save the running configuration and reboot the service module.
# (In standalone mode.) Display operating mode information about all service modules on the switch.
<Sysname> display switch-mode status
LPU switch mode:
Slot    Current        Config
2      NORMAL         *BRIDGING
 3      MIX            NONE
 4      NORMAL         NORMAL
 5      MIX            BRIDGING
* indicates the mode is not supported.
CurrentForwardMode: compatible
 NextForwardMode: high-speed
# (In IRF mode.) Display operating mode information about all interface modules on IRF member device 1.
<Sysname> display switch-mode status chassis 1
LPU switch mode:
Slot    Current        Config
 2      MIX            MIX
 3      MIX            NONE
 4      NORMAL         NORMAL
 5      MIX            BRIDGING
Table 12 Command output
Current
Current operating mode of the service module:
·     NONE—The service module does not support operating mode configuration.
·     BRIDGING—The service module is operating in extended MAC mode.
·     NORMAL—The service module is operating in normal mode.
·     ROUTING—The service module is operating in extended routing mode.
·     MIX—The service module is operating in extended hybrid mode.
·     STANDARD-IPV6—The service module is operating in IPv6 standard mode.
·     IPv6—The service module is operating in IPv6 mode.
Config
Operating mode specified for the service module:
·     NONE—No operating mode is specified for the service module.
·     BRIDGING—The extended MAC mode is specified for the service module.
·     NORMAL—The normal mode is specified for the service module.
·     ROUTING—The extended routing mode is specified for the service module.
·     MIX—The extended hybrid mode is specified for the service module.
·     STANDARD-IPV6—The IPv6 standard mode is specified for the service module.
·     IPv6—The IPv6 mode is specified for the service module.
The service module does not support the operating mode specified for it. The service module will use the default operating mode after reboot.
CurrentForwardMode
Current forwarding mode for service module slots:
·     compatible—Compatible mode.
·     standard—Standard mode.
·     high-speed—High-speed mode.
NextForwardMode
Forwarding mode for service module slots to be used at the next startup:
·     fabric-mode
·     switch-mode
Use display system stable state to display system stability and status information.
display system stable state [ mdc { id | all } ]
mdc { id | all }: Specifies an MDC by its ID or specifies all MDCs. If you do not specify this option, the command displays stability information for the system.
Before performing an ISSU or active/standby switchover, execute this command multiple times to identify whether the system is operating stably. If the value of the System State field is not Stable, you cannot perform an ISSU. If the value of the Redundancy Stable field is not Stable, you cannot perform an active/standby switchover.
The device/card/MDC startup takes some time. If the values of the status fields do not change to Stable, execute this command multiple times to identify the devices/cards/MDCs that are not in Stable state. You can also use other commands to identify the faulty components. For example:
·     Use the display device command to identify the cards in Fault state.
·     Use the display ha service-group command to display the status of HA service groups and identify the groups in batch backup state.
# (In standalone mode.) Display system stability and status information.
<Sysname> display system stable state
System state    : Stable
Redundancy state: Stable
  Slot   CPU   Role      State
* 1      0     Active    Stable
Table 13 Command output
System state
System status:
·     Stable—The system is operating stably.
·     Not ready—The system is not operating stably. You cannot perform an ISSU when the system is in this state.
Redundancy state
System redundancy status:
·     Stable—Both MPUs are operating stably. You can perform a switchover.
·     No Redundance—The system has only one MPU. You cannot perform a switchover.
·     Not Ready—The system is not operating stably. You cannot perform a switchover.
Role
Role of the card in the system:
·     Active—The card is the active MPU.
·     Standby—The card is the standby MPU.
·     Other—The card is not an MPU.
Card status:
·     Stable—The card is operating stably.
·     Board Inserted—The card has just been installed.
·     Kernel Init—Card kernel is being initialized.
·     Service Starting—Services are starting.
·     Service Stopping—Services are stopping.
·     HA Batch Backup—An HA batch backup is going on.
·     Interface Data Batch Backup—An interface data batch backup is in progress.
·     MDC Starting—MDCs are starting.
·     MDC Stopping—MDCs are stopping.
The object is not operating stably.
·     display device
·     display ha service-group (High Availability Command Reference)
·     display mdc (Virtual Technologies Command Reference)
Use display system-working-mode to display the current system working mode.
# Display the current system working mode.
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 14 shows the common transceiver alarms. If no error occurs, "None" is displayed.
Table 14 Common transceiver alarm components
SFP/SFP+:
RX
Receive
TX
Transmit
power
Optical power
Temp
Temperature
QSFP+:
RX
Receive
TX
Transmit
power
Optical power
Temp
Temperature
CFP:
RX
Receive
TX
Transmit
power
Optical power
Temp
Temperature
REFCLK
Reference clock
XFP:
RX
Receive
TX
Transmit
power
Optical power
Temp
Temperature
APD
Avalanche photo diode
TEC
Thermoelectric cooler
# Display the alarms present on the transceiver module in interface Ten-GigabitEthernet 3/0/45.
<Sysname> display transceiver alarm interface ten-gigabitethernet 3/0/45
Ten-GigabitEthernet3/0/45 transceiver current alarm information:
  RX power low
  RX signal loss
Table 15 Command output
Alarms present on the transceiver module.
RX signal loss
Received signals are lost.
RX power low
Received power is low.
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
This command cannot display information about some transceiver modules.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface Ten-GigabitEthernet 3/0/45.
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 3/0/45
Ten-GigabitEthernet3/0/45 transceiver diagnostic information:
    Temp.(°C) Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    30         3.36        7.82      -35.64         -2.23
  Alarm thresholds:
    High  73         3.80        13.20     1.00           0.00
    Low   -3         2.81        1.00      -9.50          -10.30
Table 16 Command output
Digital diagnosis information for the transceiver module in the interface.
Temp.(°C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
RX power in dBm, accurate to 0.01 dBm.
TX power(dBm)
TX power in dBm, accurate to 0.01 dBm.
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface Ten-GigabitEthernet 3/0/45.
<Sysname> display transceiver interface ten-gigabitethernet 3/0/45
Ten-GigabitEthernet3/0/45 transceiver information:
  Transceiver Type              : 10G_BASE_SR_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 80(OM2),20(OM1),300(OM3)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : FINISAR CORP.
Table 17 Command output
Transceiver information.
Transceiver Type
Transceiver type.
Connector Type
Connector type options:
·     SC—Fiber connector developed by NTT.
·     LC—1.25 mm/RJ-45 fiber connector developed by Lucent.
·     RJ-45.
·     CX 4.
Wavelength(nm)
·     Fiber transceiver: Central wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma.
·     Copper cable: Displayed as N/A.
Transfer Distance(xx)
Transmission distance, where xx indicates the distance unit:
·     km—Kilometers, for single-mode transceiver modules.
·     m—Meters, for other transceiver modules.
If the transceiver module supports multiple types of transmission media, this field displays the transmission distance for each type, in the form transmission distance (medium type).
Transmission medium types include:
·     9 um9/125 µm single-mode fiber.
·     50 um50/125 µm multimode fiber.
·     62.5 um62.5/125 µm multimode fiber.
·     TPTwisted pair.
·     CX4CX4 cable.
Support for the digital diagnosis feature:
·     YES—Supported.
·     NO—Not supported.
Ordering Name
Product code.
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules on all interfaces.
This command displays only part of the electronic label information.
# Display electronic label information for the transceiver module in interface Ten-GigabitEthernet 3/0/45.
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 3/0/45
Ten-gigabitethernet 3/0/45 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2012-09-01
  Vendor Name          : H3C
Table 18 Command output
Manu. Serial Number
Serial number generated during production of the transceiver module.
Manufacturing Date
Date when the electronic label information was written to the transceiver module.
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
H3C Comware Software, Version 7.1.045, Release 7178
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S7506E-X uptime is 0 weeks, 0 days, 7 hours, 57 minutes
Last reboot reason : Cold reboot
Boot image: flash:/S7500EX-cmw710-boot-r7178.bin
Boot image version: 7.1.045, Release 7178
  Compiled Jul 08 2014 16:07:02
System image: flash:/S7500EX-cmw710-system-r7178.bin
System image version: 7.1.045, Release 7178
LPU 3:
Uptime is 0 weeks,0 days,7 hours,54 minutes
BOARD TYPE:         LSUM1TGS24EC0
DRAM:               1024M bytes
FLASH:              0M bytes
NVRAM:              0K bytes
PCB 1 Version:      VER.A
Bootrom Version:    001
CPLD 1 Version:     001
Release Version:    H3C S7500EX-7178
Patch Version  :    None
Reboot Cause  :     ColdReboot
MPU(M) 7:
Uptime is 0 weeks,0 days,7 hours,57 minutes
BOARD TYPE:         LSQM1MPU06B0
DRAM:               8192M bytes
FLASH:              1024M bytes
NVRAM:              1M bytes
Bootrom Version:    103
CPLD 1 Version:     000
CPLD 2 Version:     001
display version-update-record
Use display version-update-record to display the startup software image upgrade history records of the active MPU. (In standalone mode.)
Use display version-update-record to display the startup software image upgrade history records of the global active MPU. (In IRF mode.)
The device records its current startup software version information and all subsequent version update information. Such information can survive reboots.
The maximum number of records is 10.
# Display the startup software image upgrade history records.
<Sysname> display version-update-record
Name                                   Version            Compile time
Record 1  (updated on Aug 04 2014 at 17:42:04):
  S7500EX-cmw710-boot-r7178.bin         7.1.045 Release 7178 Jul 08 2014 16:
07:02
  S7500EX-cmw710-system-r7178.bin       7.1.045 Release 7178 Jul 08 2014 16:07:
02
Record 2  (updated on Jul 31 2014 at 09:42:59):
* S7500EX-cmw710-boot-r7178.bin         7.1.045 Release 7178 Jul 08 2014 16:
07:02
* S7500EX-cmw710-system-r7178.bin       7.1.045 Release 7178 Jul 08 2014 16:07:
02
Table 19 Command output
Name
Software image file name.
The new software image is different from the old one.
reset version-update-record
fabric-mode
Use fabric-mode to specify a forwarding mode for service module slots.
Use undo fabric-mode to restore the default.
In standalone mode:
fabric-mode { compatible | standard | high-speed }
undo fabric-mode
In IRF mode:
fabric-mode { compatible | standard | high-speed } chassis chassis-number
undo fabric-mode
By default, service module slots operate in compatible mode.
compatible: Specifies the compatible mode.
standard: Specifies the standard mode.
high-speed: Specifies the high-speed mode.
This command is supported only on S7506E-X switches.
In different forwarding modes, service module slots support different types of service modules and provide different amounts of bandwidth, as shown in Table 20.
Table 20 Service module operating modes
Forwarding mode
Restrictions
Compatible
This mode is not supported on the following service modules in slot 4 or slot 5:
·     EC interface module LSQM1TGS12EC0.
·     SA interface modules.
·     SC interface modules.
·     SF interface module LSQM2TGS16SF0.
·     Base card LSUM1SPMAEC0.
·     OAP modules.
Standard
This mode is not supported on the following service modules:
·     OAP modules.
High-speed
This mode is not supported on the following service modules in slot 0 or slot 1:
·     EC interface modules except for LSQM1TGS12EC0.
·     SF interface modules.
·     SG interface modules.
This mode is not supported on the following service modules in slot 2, slot 3, slot 4, or slot 5:
·     OAP modules.
A forwarding mode change takes effect after a device reboot.
This command is supported only on the default MDC. For more information about MDC, see Virtual Technologies Configuration Guide.
For more information about OAP modules, see OAA Configuration Guide.
# Set the forwarding mode for service module slots to standard.
[Sysname] fabric-mode standard
This command may need reboot the device. Continue? [Y/N]:y
Process OK.
·     display switch-mode status
·     reboot
fan prefer-direction
Use fan prefer-direction to specify the preferred airflow direction for a PEX.
Use undo fan prefer-direction to restore the default.
fan prefer-direction chassis chassis-number slot slot-number { power-to-port | port-to-power }
undo fan prefer-direction chassis chassis-number slot slot-number
The preferred airflow direction is from the power supply side to the port side.
chassis chassis-number slot slot-number: Specifies a PEX by its virtual chassis number and virtual slot number.
power-to-port: Specifies the airflow direction from the power supply side to the port side.
port-to-power: Specifies the airflow direction from the port side to the power supply side.
This command is available only for the following PEXs:
·     S5120-28SC-HI switches.
·     S5130-EI switches.
·     S5130-HI switches.
·     S6300 switches.
# Set the preferred airflow direction to port-to-power for a PEX.
[Sysname] fan prefer-direction chassis 110 slot 0 port-to-power
display fan
hardware-failure-detection
Use hardware-failure-detection to specify the action to be taken in response to hardware failures.
Use undo hardware-failure-detection to restore the default.
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
The system takes the action of warning in response to hardware failures on chips, cards, and the forwarding plane.
board: Specifies failures on control paths and cards.
chip: Specifies failures on components of cards such as the chips, capacitances, resistances.
forwarding: Specifies failures on the forwarding plane (including services and other relevant items).
isolate: Takes one or more of the following actions:
·     Shuts down the relevant ports.
·     Prohibits loading software for the relevant cards.
·     Isolates the relevant cards.
·     Powers off the relevant cards to reduce impact from the failures.
off: Takes no action.
reset: Restarts the relevant components or cards to recover from failures.
warning: Sends traps to notify you of the failures.
The device automatically detects hardware failures on components, cards, and the forwarding plane. You can specify the actions to be taken in response to detected failures.
# Configure the device to send traps in response to failures on components.
[Sysname] hardware-failure-detection chip warning
# Configure the device to restart the cards in response to failures on cards.
[Sysname] hardware-failure-detection board reset
header
Use header to create a banner.
Use undo header to clear a banner.
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
No banner is configured.
incoming: Configures the banner to be displayed before a modem dial-in user accesses user view. If authentication is required, the incoming banner appears after the authentication is passed. Modem dial-in is not supported in the current software version.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner to be displayed before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a non-modem dial-in user accesses user view.
text: Specifies the banner message. You can enter the banner message on the same line as the keywords or on different lines. For more information, see Fundamentals Configuration Guide.
# Create the incoming banner, legal banner, login banner, MOTD banner, and shell banner.
[Sysname] header incoming
Welcome to incoming(header incoming)%
[Sysname] header legal
Welcome to legal (header legal)%
[Sysname] header login
Welcome to login(header login)%
[Sysname] header motd
Welcome to motd(header motd)%
[Sysname] header shell
Welcome to shell(header shell)%
In this example, the percentage sign (%) is the starting and ending character of the text argument. Entering the percentage sign after the text quits the header command. Because it is the starting and ending character, the percentage sign is not included in the banner.
# Test the configuration by using Telnet. The login banner appears only when password or scheme login authentication has been configured.
* Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
 Press Y or ENTER to continue, N to exit.
Login authentication
Password:
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
In standalone mode:
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
·     Minor alarm threshold: 96 MB.
·     Severe alarm threshold: 64 MB.
·     Critical alarm threshold: 48 MB.
·     Normal state threshold: 128 MB.
minor minor-value: Specifies the minor alarm threshold. This threshold must be equal to or less than the normal state threshold. Setting this threshold to 0 disables the minor alarm feature.
severe severe-value: Specifies the severe alarm threshold. This threshold must be equal to or less than the minor alarm threshold. Setting this threshold to 0 disables the severe alarm feature.
critical critical-value: Specifies the critical alarm threshold. This threshold must be equal to or less than the severe alarm threshold. Setting this threshold to 0 disables the critical alarm feature.
normal normal-value: Specifies the normal state threshold. This threshold must be equal to or less than the total memory size.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command sets free-memory thresholds for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify a card or PEX, this command sets free-memory thresholds for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command sets free-memory thresholds for the default CPU.
To ensure correct operation and improve memory efficiency, the system monitors the amount of free memory space in real time. When a threshold is exceeded, the system sends an alarm notification or an alarm-removed notification to affected feature modules or processes so they can take countermeasures. For more information about the thresholds, see Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
memory-threshold usage
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
In standalone mode:
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
In IRF mode:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command sets the memory usage threshold for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify a card or PEX, this command sets the memory usage threshold for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command sets the memory usage threshold for the default CPU.
The device samples memory usage at an interval of 1 minute. If the sample is greater than the memory usage threshold, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold chassis 1 slot 2 cpu 1 usage 80
Use monitor cpu-usage enable to enable CPU usage monitoring.
Use undo monitor cpu-usage enable to disable CPU usage monitoring.
In standalone mode:
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU usage monitoring is enabled.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command enables CPU usage monitoring for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify a card or PEX, this command enables CPU usage monitoring for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command enables CPU usage monitoring for the default CPU.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the interval specified by the monitor cpu-usage interval command. You can use the display cpu-usage history command to view recent CPU usage.
# Enable CPU usage monitoring.
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
Use monitor cpu-usage interval to set the sampling interval for CPU usage monitoring.
In standalone mode:
monitor cpu-usage interval interval-value [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage interval interval-value [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The system samples CPU usage every 1 minute.
interval-value: Specifies the sampling interval for CPU usage monitoring. Valid values include 5Sec for 5 seconds, 1Min for 1 minute, and 5Min for 5 minutes.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command sets the interval for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify a card or PEX, this command sets the interval for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command sets the interval for the default CPU.
After CPU usage monitoring is enabled, the system samples and saves CPU usage at the specified interval. You can use the display cpu-usage history command to view recent CPU usage.
# Set the sampling interval for CPU usage monitoring to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
Use monitor cpu-usage threshold to set the CPU usage threshold.
Use undo monitor cpu-usage threshold to restore the default.
In standalone mode:
monitor cpu-usage threshold cpu-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
monitor cpu-usage threshold cpu-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
The CPU usage threshold is 99.
cpu-threshold: Specifies the CPU usage threshold in percentage. The value range is 0 to 100.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command sets the CPU usage threshold for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify a card or PEX, this command sets the CPU usage threshold for the global active MPU. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. If you do not specify this option, the command sets the CPU usage threshold for the default CPU.
The device samples CPU usage at an interval of 1 minute. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage threshold to 80%.
[Sysname] monitor cpu-usage threshold 80
monitor handshake-timeout disable-port
Use monitor handshake-timeout disable-port to enable the port-down feature globally.
Use undo monitor handshake-timeout disable-port to disable the feature globally.
The port-down feature is enabled.
The port-down feature applies to scenarios where two devices (one active and one standby) are used for high availability, for example, a network deployed with VRRP. This feature shuts down all service ports on the active device immediately after both MPUs on the active device are removed or reboot abnormally. The shutdown operation ensures quick service switchover to the standby device.
# Enable the port-down feature globally.
[Sysname] monitor handshake-timeout disable-port
Set successful!
reboot
Use reboot to reboot a card, a subcard, or the entire system. (In standalone mode.)
Use reboot to reboot an IRF member device, a subcard, or all IRF member devices. (In IRF mode.)
In standalone mode:
reboot [ slot slot-number [ subslot subslot-number ] ] [ force ]
In IRF mode:
reboot [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] ] [ force ]
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
slot slot-number: Specifies a card or a PEX by its slot number.(In IRF mode.)
force: Reboots the device immediately without performing software or hard disk check. If this keyword is not specified, the system first checks whether the reboot might result in data loss or a system failure. For example, the system checks whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A device reboot might interrupt network services.
·     If the main startup software images are corrupt or missing, you must re-specify a set of main startup software images before executing the reboot command.
·     Use the force keyword only when the device fails or a reboot command without the force keyword cannot perform a reboot correctly. A reboot command with the force keyword might result in file system corruption because it does not perform data protection.
·     Do not use this feature to reboot an LSR1DRUP1L1 subcard. If you reboot an LSR1DRUP1L1 subcard, the system automatically reboots the LSUM1SPMAEC0 base card that hosts the subcard.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
In standalone mode:
·     To reboot a card, specify the slot number.
·     To reboot the entire device, do not specify the slot number option.
In IRF mode, you can use the command on the master to reboot the master or a subordinate member.
·     To reboot a card, specify both the IRF member ID and the slot number.
·     To reboot an IRF member device or PEX, specify only the IRF member ID or virtual chassis number.
·     To reboot all IRF member devices and PEXs, do not specify the member ID or slot number option.
# Reboot the device when no configuration change has occurred since the last time you saved the running configuration.
<Sysname> reboot
Now rebooting, please wait...
# If any configuration has changed, reboot the device and save the configuration.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
# If any configuration has changed, reboot the device but do not save the configuration.
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:n
# Reboot the device immediately without performing software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
# (In standalone mode.) Reboot the interface module in slot 2.
<Sysname> reboot slot 2
.......DONE!
This command will reboot the specified slot, Continue? [Y/N]:y
# (In standalone mode.) Reboot the interface module in slot 2 by force.
<Sysname> reboot slot 2 force
# (In IRF mode.) Reboot IRF member device 2.
<Sysname> reboot chassis 2
.......DONE!
This command will reboot the specified chassis, Continue? [Y/N]:y
# (In IRF mode.) Reboot IRF member device 2 by force.
<Sysname> reboot chassis 2 force
# (In IRF mode.) Reboot the interface module in slot 2 on IRF member device 2.
<Sysname> reboot chassis 2 slot 2
.......DONE!
# (In IRF mode.) Reboot the interface module in slot 2 on IRF member device 2 by force.
<Sysname> reboot chassis 2 slot 2 force
reset asset-info
Use reset asset-info to clear the asset profile for a physical component.
In standalone mode:
reset asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
In IRF mode:
reset asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom| department | description | location | service-date | state ]
chassis: Clears the asset profile for the chassis.
fan fan-id: Clears the asset profile of the specified fan tray.
power power-id: Clears the asset profile for the specified power module.
slot slot-number: Clears the asset profile for the card in the specified slot.
csn: Clears the asset ID.
custom: Clears customized asset items.
department: Clears the department name.
description: Clears the asset description.
service-date: Clears the service start date.
state: Clears the usage status
chassis chassis-number: Specifies an IRF member device by its member ID. (In IRF mode.)
For a power module, only the csn keyword is supported.
To clear an item in an asset profile, specify the corresponding keyword for the command. To clear all items in an asset profile, do not specify the item keywords.
If you specify a fan tray or power module that does not exist, the system prompts that the fan tray or power module is absent.
# (In standalone mode.) Clear the asset ID for fan tray 0.
[Sysname] reset asset-info fan 0 csn
# (In IRF mode.) Clear the asset ID for fan tray 0 on IRF member device 1.
[Sysname] reset asset-info chassis 1 fan 0 csn
·     display asset-info
·     set asset-info
Use reset version-update-record to clear the startup software image upgrade history records of the active MPU. (In standalone mode.)
Use reset version-update-record to clear the startup software image upgrade history records of the global active MPU. (In IRF mode.)
# Clear the startup software image upgrade history records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
reset scheduler logfile
Use reset scheduler logfile to clear job execution log information.
# Clear job execution log information.
<Sysname> reset scheduler logfile
restore factory-default
Use restore factory-default to restore the factory-default configuration for the device.
CAUTION
CAUTION:
This command is disruptive. Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
This command performs the following tasks:
·     Deletes all configuration files (.cfg files) in the root directories of the storage media.
·     Deletes all log files (.log files in the folder /logfile).
·     Clears all log information (in the log buffer), trap information, and debugging information.
·     Restores the parameters for the BootWare to the factory-default settings.
·     Deletes all license files (.ak files).
After this command is executed, only the items required for fundamental device operation are retained, including the .bin files, the MAC addresses, and the electronic label information.
# Restore the factory-default configuration for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter job view. If the job already exists, you enter job view directly.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
·     command
scheduler logfile size
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Sets the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information to be written to the file is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to delete the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
Device reboot interrupts network services.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
For data security, if you are performing file operations at the reboot time, the system does not reboot.
The device supports only one device reboot schedule. If you configure both the schedule reboot delay and schedule reboot delay commands or configure one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2011.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2011.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter schedule view. If the schedule already exists, you enter schedule view directly.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can configure a schedule to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job and enter job view.
2.     Use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule and enter schedule view.
4.     Use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     Use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     Use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time for a schedule.
# Create a schedule named saveconfig.
·     job
·     time at
·     time once
set asset-info
Use set asset-info to configure an asset profile for a physical component.
In standalone mode:
set asset-info { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
In IRF mode:
set asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
chassis: Configures an asset profile for the chassis.
fan fan-id: Configures an asset profile for the specified fan tray.
power power-id: Configures an asset profile for the specified power module.
slot slot-number: Configures an asset profile for the card in the specified slot.
csn csn-number: Specifies an asset ID for the asset, a string of 1 to 64 characters.
custom name value: Defines an asset profile item and specifies the value.
department department: Specifies the department name, a string of 1 to 64 characters.
description description: Specifies the asset description, a string of 1 to 64 characters.
location location: Specifies the asset location, a string of 1 to 64 characters.
service-date date: Specifies the service start date, a string of 1 to 25 characters.
state state: Specifies the asset usage status, a string of 1 to 64 characters.
You can configure an asset profile for the chassis, a card, or an installed fan tray or power module.
An asset profile has the following system-defined fields:
·     Asset ID.
·     Department name.
·     Asset description.
·     Asset location.
·     Service start date (when the asset started to provide services).
·     Asset usage status.
You can define additional fields by using the custom name value option.
# (In standalone mode.) Set the asset ID to 123456 for fan tray 0.
[Sysname] set asset-info fan 0 csn 123456
# (In IRF mode.) Set the asset ID to 123456 for fan tray 0 on IRF member device 1.
[Sysname] set asset-info chassis 1 fan 0 csn 123456
·     reset asset-info
shutdown-interval
Use shutdown-interval to set the port status detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval time
The port status detection timer setting is 30 seconds.
interval: Specifies the port status detection timer value in seconds. The value range is 0 to 300. To disable port status detection, set this argument to 0.
The device starts a port status detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
If you change the timer during port status detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
·     If T < T1, the port will be brought up after T1T seconds.
·     If T T1, the port is brought up immediately.
For example, the timer is 30 seconds. If you change it to 10 seconds 2 seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer to 2 seconds 10 seconds after the port is shut down, the port comes up immediately.
# Set the port status detection timer to 100 seconds.
[Sysname] shutdown-interval 100
switch-fabric isolate
Use switch-fabric isolate to isolate a switching fabric module or channel.
Use undo switch-fabric isolate to restore the default.
In standalone mode:
switch-fabric isolate slot slot-number
undo switch-fabric isolate slot slot-number
In IRF mode:
switch-fabric isolate chassis chassis-number slot slot-number
undo switch-fabric isolate chassis chassis-number slot slot-number
A switching fabric module is not isolated from the forwarding plane and forwards traffic.
slot slot-number: Specifies a switching fabric module by its slot number.
chassis chassis-number slot slot-number: Specifies a switching fabric module on an IRF member device by its slot number and the member ID.
CAUTION
CAUTION:
·     Isolating the only switching fabric module of the switch disables the forwarding feature.
·     Do not reboot the device when a switching fabric module is isolated.
If the switch has multiple switching fabric modules, isolating a switching fabric module decreases the forwarding bandwidth and reduces the forwarding performance.
If you do not want to use a switching fabric module, remove the module after you isolate the module.
To use an isolated switching fabric module:
1.     Use the undo switch-fabric isolate command to cancel the isolation.
2.     Reboot the switching fabric module.
# (In standalone mode.) Isolate the switching fabric module in slot 10.
[Sysname] switch-fabric isolate slot 10
The command will isolate the switch fabric from the system. Continue? [Y/N]y
# (In IRF mode.) Isolate the switching fabric module in slot 10 of member device 1.
[Sysname] switch-fabric isolate chassis 1 slot 10
switch-fabric removal-signal-suppression
Use switch-fabric removal-signal-suppression to disable the switching fabric module from sending removal interrupt signals before it is removed.
Use undo switch-fabric removal-signal-suppression to restore the default.
The switching fabric module sends removal interrupt signals before it is removed.
If the switching fabric module frequently sends incorrect removal interrupt signals before it is removed, the device might fail. To avoid this problem, configure the switch-fabric removal-signal-suppression command.
# Disable the switching fabric module from sending removal interrupt signals before it is removed.
[Sysname] switch-fabric removal-signal-suppression
switch-mode
Use switch-mode to specify an operating mode for a service module.
Use undo switch-mode to remove the operating mode configuration. The service module does not have an operating mode specified.
In standalone mode:
switch-mode { acl-ipv4 | acl-l2 | bridging | high-speed | ipv6 | low-speed | mix-bridging-routing | normal | port-extender | routing | standard-ipv6 } slot slot-number
undo switch-mode slot slot-number
In IRF mode:
switch-mode { acl-ipv4 | acl-l2 | bridging | high-speed | ipv6 | low-speed | mix-bridging-routing | normal | port-extender | routing | standard-ipv6 } chassis chassis-number slot slot-number
undo switch-mode chassis chassis-number slot slot-number
Table 21 Default operating modes for service modules
Service modules
·     LSUM1SPMAEC0 base card
·     EC and SG interface modules
·     The following SC interface modules:
LSQM2GP44TSSC0
LSQM2GP24TSSC0
LSQM2GT24PTSSC0
LSQM2GT24TSSC0
LSQM2GT48SC0
LSQM4GV48SC0
·     SC interface module LSQ1QGS4SC0
normal
acl-ipv4: Specifies the acl-ipv4 mode. This keyword is not supported in the current software version.
acl-l2: Specifies the acl-l2 mode. This keyword is not supported in the current software version.
bridging: Specifies the extended MAC mode.
high-speed: Specifies the high-speed mode. This keyword is not supported in the current software version.
ipv6: Specifies the IPv6 mode.
low-speed: Specifies the low-speed mode. This keyword is not supported in the current software version.
mix-bridging-routing: Specifies the extended hybrid mode.
normal: Specifies the normal mode.
port-extender: Specifies the port extender mode. This keyword is not supported in the current software version.
routing: Specifies the extended routing mode.
standard-ipv6: Specifies the IPv6 standard mode.
slot slot-number: Specifies the number of the slot where the service module resides.
chassis chassis-number: Specifies the ID of the IRF member device. (In IRF mode.)
Different types of service modules support different operating modes. For more information, see Fundamentals Configuration Guide.
To make an operating mode change take effect, save the configuration and reboot the service module.
# (In standalone mode.) Set the operating mode to bridging for the EA interface module in slot 2.
[Sysname] switch-mode bridging slot 2
# (In IRF mode.) Set the operating mode to bridging for the EA interface module in slot 2 of IRF member device 2.
[Sysname] switch-mode bridging chassis 1 slot 2
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The default device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used as the user view prompt at the CLI. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
system-working-mode
Use system-working-mode to set the system operating mode.
Use undo system-working-mode to restore the default.
system-working-mode { advance | standard }
The device operates in standard mode.
advance: Sets the system operating mode to advanced.
standard: Sets the system operating mode to standard.
The advance keyword is supported on the following interface modules:
·     EC interface modules.
In different operating modes, the device supports different features, and might have different specifications for the supported features. For example, the FCoE feature is supported only in advanced mode.
To change the operating mode to advance, make sure the device has enough IFP ACL resources. To display the current IFP ACL resource information, use the display qos-acl resource command. For more information about this command, see ACL and QoS Command Reference.
After changing the operating mode, you must reboot the device to make the device operate in the new mode.
# Set the system operating mode to advanced.
[Sysname] system-working-mode advance
The system working mode is changed, it will take effect after system restart.
temperature-limit
Use temperature-limit to set the temperature alarm thresholds for the device.
Use undo temperature-limit to restore the default.
In standalone mode:
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
In IRF mode:
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
To view the default thresholds, use the undo form of the command to restore the default and execute the display environment command.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
inflow: Configures temperature alarm thresholds for inlet sensors. An inlet sensor is near the air inlet and used for monitoring ambient temperature.
outflow: Configures temperature alarm thresholds for outlet sensors. An outlet sensor is near the air outlet for monitoring device temperature.
sensor-number: Specifies a sensor by its number, an integer starting from 1. Each number represents a temperature sensor on the device or card.
lowlimit: Specifies the low-temperature threshold in Celsius degrees.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the high-temperature warning threshold.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning threshold, the device sends a log message and a trap.
When the device temperature reaches the high-temperature alarming threshold, the device sends log messages and traps repeatedly, and sets LEDs on the device panel.
Different cards have different threshold value ranges. To view the value ranges, use the CLI online help.
# (In standalone mode.) Set temperature alarm thresholds for hotspot sensor 1 on the card in slot 7.
[sysname] temperature-limit slot 7 hotspot 1 -5 80 95
# (In IRF mode.) Set temperature alarm thresholds for hotspot sensor 1 on the card in slot 7 on IRF member device 1.
[sysname] temperature-limit chassis 1 slot 7 hotspot 1 -5 80 95
time at
Use time at to specify an execution date and time for a non-periodic schedule.
Use undo time to delete the execution date and time configuration for a non-periodic schedule.
time at time date
undo time
No execution time or date is specified for a non-periodic schedule.
Schedule view
time: Specifies the schedule execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently configured command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2011.
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a non-periodic schedule.
Use undo time to delete the execution day and time configuration for a non-periodic schedule.
time once delay time
undo time
No execution time or day is specified for a non-periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid week day values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
Use undo time to delete the execution time table configuration for a periodic schedule.
time repeating [ at time [ date ] ] interval interval-time
undo time
No execution time table is specified for a periodic schedule.
Schedule view
at time: Specifies the execution time in the hh:mm format. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the MM/DD/YYYY or YYYY/MM/DD format. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval-time: Specifies the execution time interval in the hh:mm or mm format. This argument can contain up to six characters. When in the hh:mm format, mm must be in the range of 0 to 59. When in the mm format, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
The time repeating [ at time [ date ] ] interval interval-time command configures the device to execute a schedule at an interval from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute a schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is configured most recently takes effect.
# Configure the device to execute schedule saveconfig once a hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
transceiver phony-alarm-disable
Use transceiver phony-alarm-disable to disable alarm traps for transceiver modules.
Use undo transceiver phony-alarm-disable to restore the default.
Alarm traps are enabled for transceiver modules.
Disable alarm traps if the transceiver modules were manufactured or sold by H3C.
The device regularly detects transceiver modules that have a vendor name other than H3C or do not have a vendor name. Upon detecting such a transceiver module, the device repeatedly outputs traps and logs to notify the user to replace the module.
# Disable alarm traps for transceiver modules.
[Sysname] transceiver phony-alarm-disable
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, mdc-admin, mdc-operator, and level-0 to level-15.
A schedule must have one or more user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule. For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
A schedule can have a maximum of 64 user roles. After the limit is reached, you cannot assign additional user roles to the schedule.
# Assign user role rolename to schedule test.
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
·     command
