01-Fundamentals Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10001-Fundamentals Command Reference
08-ISSU commands
08-ISSU commands 145.11 KB
ISSU commands
display install active
Use display install active to display active software images.
In standalone mode:
display install active [ slot slot-number ] [ verbose ]
In IRF mode:
display install active [ chassis chassis-number slot slot-number ] [ verbose ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command is applied to all cards in the device. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member. If you do not specify this option, the command is applied to all cards in the IRF fabric. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays only image names.
# (In standalone mode.) Display active software images.
<Sysname> display install active
Active packages on slot 6:
  flash:/boot.bin
  flash:/system.bin
  flash:/feature.bin
# (In IRF mode.) Display active software images.
Active packages on chassis 1 slot 6:
  flash:/boot.bin
  flash:/system.bin
  flash:/feature.bin
# (In standalone mode.) Display detailed information about active software images.
<Sysname> display install active verbose
flash:/boot.bin
 [Package]
 Vendor: XXX
 Product: xxxx
 Service name: boot
 Platform version: 7.1.045
 Product version: Release 7180
 Supported board: mpu
 [Component]
 Component: boot
 Description: boot package
flash:/system.bin
 [Package]
 Vendor: XXX
 Product: xxxx
 Service name: system
 [Component]
 Component: system
 Description: system package
flash:/feature.bin
 [Package]
 Vendor: XXX
 Product: xxxx
 Service name: test
 [Component]
 Component: test
 Description: test package
# (In IRF mode.) Display detailed information about active software images.
flash:/boot.bin
 [Package]
 Vendor: xxx
 Product: xxxx
 Service name: boot
 [Component]
 Component: boot
flash:/system.bin
 [Package]
 Vendor: xxx
 Product: xxxx
 [Component]
 Component: system
flash:/feature.bin
 [Package]
 Vendor: xxx
 Product: xxxx
 Service name: test
 [Component]
 Component: test
Active packages on xxx
Active software images on the specified slot.
[Package]
Detailed information about the software image.
Service name
Image type:
·     boot—Boot image.
·     system—System image.
·     patch—Patch image.
·     Any other value indicates a feature image.
Supported board
Cards supported by the software image:
·     mpu—MPU.
·     lcLPU.
·     sfc—Switching fabric module.
[Component]
Information about components included in the image file.
install active
display install backup
Use display install backup to display backup startup software images.
In standalone mode:
display install backup [ slot slot-number ] [ verbose ]
In IRF mode:
display install backup [ chassis chassis-number slot slot-number ] [ verbose ]
Backup startup images are used only when the main boot or system image is missing or corrupt. For more information, see Fundamental Configuration Guide.
To modify the backup startup image list, you must use the boot-loader file command.
# (In standalone mode.) Display the backup startup software images.
<Sysname> display install backup
Backup startup software images on slot 6:
  flash:/boot-r7180.bin
  flash:/system-r7180.bin
# (In IRF mode.) Display the backup startup software images.
Backup startup software images on chassis 1 slot 6:
# Display detailed information about backup startup software images.
<Sysname> display install backup verbose
 [Package]
 Vendor: H3C
 Product: xxxx
 Service name: boot
 Supported board: mpu lpu
 [Component]
 Component: boot
 [Package]
 Vendor: H3C
 Product: xxxx
 [Component]
 Component: system
For information about the command output, see Table 1.
·     boot-loader file
·     display install committed
Use display install committed to display main startup software images.
In standalone mode:
display install committed [ slot slot-number ] [ verbose ]
In IRF mode:
display install committed [ chassis chassis-number slot slot-number ] [ verbose ]
After you execute the install commit command, use the display install committed command to verify that the main startup image list has been updated with the software image change.
Both the install commit and boot-loader file commands modify the main startup software image list.
# Display the main startup software images.
<Sysname> display install committed
Committed packages on slot 6:
 flash:/feature.bin
# Display detailed information about main startup software images.
<Sysname> display install committed verbose
 [Package]
 Vendor: H3C
 Product: xxxx
 Service name: boot
 [Component]
 Component: boot
 [Package]
 Vendor: H3C
 Product: xxxx
 [Component]
 Component: system
flash:/ssh-feature.bin
 [Package]
 Vendor: H3C
 Product: xxxx
 Service name: ssh
 [Component]
 Component: ssh
 Description: ssh package
·     boot-loader file
·     display install backup
·     install commit
display install inactive
Use display install inactive to display inactive software images.
In standalone mode:
display install inactive [ slot slot-number ] [ verbose ]
In IRF mode:
display install inactive [ chassis chassis-number slot slot-number ] [ verbose ]
This command displays inactive images in the root directories of the storage media.
# Display brief information about inactive software images in the root directories of the storage media.
<Sysname> display install inactive
Inactive packages on slot 6:
# Display detailed information about inactive software images in the root directories of the storage media.
<Sysname> display install inactive verbose
 [Package]
 Vendor: H3C
 Product: XXXX
 Service name: ssh
 [Component]
 Component: ssh
install deactivate
display install ipe-info
Use display install ipe-info to display the software images included in an .ipe file.
display install ipe-info ipe-filename
ipe-filename: Specifies the file path of an .ipe image package file, a case-insensitive string. The file must be stored in the root directory of a storage medium in the system. The maximum length is 1 to 63 characters for the storage-medium:/base-filename.ipe segments of the file path. This length limit does not include the IRF member ID or slot number segment in front of the storage medium segment. For more information about specifying a file path, see "Managing the file system."
# Display information about the .ipe file flash:/test.ipe.
<Sysname> display install ipe-info flash:/test.ipe
Verifying the file flash:/test.ipe on slot 6.....Done.
H3C Device images in IPE:
  boot.bin
  system.bin
display install package
display install job
Use display install job to display ongoing ISSU activate and deactivate operations.
display install job
# (In standalone mode.) Display ongoing ISSU activate and deactivate operations.
<Sysname> display install job
 JobID:5
  Action:install activate flash:/ssh-feature.bin on slot 6
The output shows that the device is executing the install activate flash:/ssh-feature.bin slot 6 command.
# (In IRF mode.) Display ongoing ISSU activate and deactivate operations.
 JobID:5
  Action:install activate flash:/ssh-feature.bin on chassis 1 slot 6
The output shows that the device is executing the install activate flash:/ssh-feature.bin chassis 1 slot 6 command.
display install log
Use display install log to display ISSU log information.
display install log [ log-id ] [ verbose ]
log-id: Specifies a log entry by its ID. If you do not specify this argument, the command displays all software upgrade-related log entries.
verbose: Displays detailed ISSU log information. If you do not specify this keyword, the command displays brief ISSU log information.
The device creates one log entry for each ISSU operation to track the process and operation result.
The ISSU log can contain a maximum of 50 entries. The latest entry overwrites the oldest entry if the log is full.
# Display all ISSU log entries.
<Sysname> display install log
Install job 1 started by user root at 04/28/2001 08:39:29.
Job 1 completed successfully at 04/28/2001 08:39:30.
    Install activate flash:/ssh.bin on slot 7
Install job 2 started by user root at 04/28/2001 08:40:29.
Job 2 completed successfully at 04/28/2001 08:40:30.
    Install activate flash:/route.bin on slot 7
# Displays detailed information about ISSU log entry 1.
<Sysname> display install log 1 verbose
Detail of activating packages on slot 7.
    Get upgrade policy successfully.
    Uncompress package to system successfully.
    Remove files from system successfully.
reset install log-history oldest
Use display install package to display software image file information.
display install package { filename | all } [ verbose ]
filename: Specifies the file path of a .bin software image file, a case-insensitive string. The file must be stored in the root directory of a storage medium in the system. The maximum length is 1 to 63 characters for the storage-medium:/base-filename.ipe segments of the file path. This length limit does not include the IRF member ID or slot number segment in front of the storage medium segment. For more information about specifying a file path, see "Managing the file system."
all: Specifies all software image files in the root directories of the active MPU's storage media. (In standalone mode.)
all: Specifies all software image files in the root directories of the storage media on the global active MPU. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays only basic software image information.
# Display information about system.bin.
<Sysname> display install package flash:/system.bin
  flash:/system.bin
  [Package]
  Vendor: H3C
  Product: xxxx
# Display detailed information about system.bin.
<Sysname> display install package flash:/system.bin verbose
  flash:/system.bin
  [Package]
  Vendor: H3C
  Product: xxxx
  [Component]
  Component: system
For more information about the command output, see Table 1.
display install which
Use display install which to display all software image files that include a specific component or file.
In standalone mode:
display install which { component name | file filename } [ slot slot-number ]
In IRF mode:
display install which { component name | file filename } [ chassis chassis-number slot slot-number ]
component name: Specifies a component name.
file filename: Specifies a file name in base-filename.extension format, a case-insensitive string of 1 to 63 characters. It cannot contain path information.
A component is a collection of features. The features of a component are installed or uninstalled at the same time.
When the system displays a component or file error, use this command to identify the relevant image files before you make a software upgrade decision.
This command searches only the root directory of the storage medium.
# Display all software image files that include sshc.cli.
<Sysname> display install which file sshc.cli
File sshc.cli is in following packages on slot 6:
Verifying the file flash:/system.bin on slot 6...Done.
Verifying the file flash:/boot.bin on slot 6...Done.
  flash:/system.bin
  [Package]
  Vendor: xxx
  Product: xxxx
  Service name: ssh
  Supported board: mpu, lc, sfc
Verifying the file
The system was verifying the validity of the file.
For more information about other fields in the command output, see Table 1.
display issu state
Use display issu state to display ISSU status information.
display issu state
During an ISSU that uses issu commands, you can use this command to verify the ISSU status and determine what to do next.
This command does not apply to an ISSU that uses install commands, because the ISSU state machine is not involved.
# Display ISSU status information when no upgrade is taking place.
<Sysname> display issu state
ISSU state: Init
Compatibility: Unknown
Work state: Independent active
Upgrade method: Chassis by chassis
Upgraded chassis:
  chassis 2
Current upgrading chassis: None
Previous version list:
  boot: 7.1.045, Release 7148
  system: 7.1.045, Release 7148
  ssh: 7.1.045, Release 7148
Previous software images:
  flash:/boot.bin
  flash:/system.bin
  flash:/ssh.bin
Upgrade version list:
  system: 7.1.045, Release 7180
  ssh: 7.1.045, Release 7180
Upgrade software images:
  flash:/system04.bin
  flash:/ssh04.bin
# Display ISSU status information while the issu load command is being executed.
ISSU state: Loading
Compatibility: Incompatible
Upgraded chassis:
  chassis 2
  flash:/boot.bin
  flash:/system.bin
  flash:/ssh.bin
  flash:/system04.bin
  flash:/ssh04.bin
# Display ISSU status information on the original master after the issu load command is completed.
ISSU state: Loaded
Upgraded chassis:
  chassis 2
  flash:/boot.bin
  flash:/system.bin
  flash:/ssh.bin
  flash:/system04.bin
  flash:/ssh04.bin
ISSU state
ISSU status:
·     Init—The ISSU process has not started or has finished.
·     Loading—The system is executing the issu load command.
·     Loaded—The issu load command is completed.
·     Switching—The system is executing the issu run switchover command.
·     Switchover—The issu run switchover command is completed.
·     Accepted—The issu accept command is completed.
·     Committing—The system is executing the issu commit command.
·     Unknown—An upgrade is in process. This value might appear when you execute the command on an original standby MPU.
Compatibility
Version compatibility:
·     Compatible.
·     Incompatible.
·     Unknown—No upgrade is in process.
Work state
Operating state of the device:
·     Normal—The device is operating correctly.
·     Independent active—When you perform an ISSU for an incompatible version, the standby MPU that is upgraded first enters this state. In this state, the two MPUs of the device are running different software versions.
Upgrade method
Upgrade mode. The value can be Chassis by chassis.
On a multichassis IRF fabric, one or more subordinate members are upgraded first, and then the original master and the remaining subordinate members are upgraded.
Software versions running on the device before the ISSU.
If you execute this command on an original standby MPU during an ISSU for an incompatible version, the value of this field is Unknown.
Software images running on the device before the ISSU.
Software versions to upgrade to.
Software images used for the upgrade.
·     issu accept
·     issu commit
·     issu load
·     issu run switchover
display version comp-matrix
Use display version comp-matrix to display version compatibility information and identify the upgrade method.
display version comp-matrix file { boot filename | system filename | feature filename&<1-30> } *
display version comp-matrix file ipe ipe-filename
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies feature image files. You can specify a space-separated list of up to 30 feature image files.
filename: Specifies the name of a software image file on the active MPU (in standalone mode) or global active MPU (in IRF mode), in the format storage-medium:/base-filename.bin. It must be a case-insensitive string of 1 to 63 characters and cannot contain chassis or slot information.
ipe ipe-filename: Specifies the name of an .ipe file on the active MPU (in standalone mode) or global active MPU (in IRF mode), in the format storage-medium:/base-filename.ipe. It must be a case-insensitive string of 1 to 63 characters and cannot contain chassis or slot information.
On an IRF 3 system, this command displays the following information if you do not specify any files:
·     Compatibility information for the running images of the parent device.
·     Compatibility information for the running images of PEXs.
If you specify one or more file names, the command displays the following information:
·     Compatibility information for the specified images on the parent device.
·     Compatibility information for the specified images on the PEXs. The prerequisite is that you use the issu pex command to specify the images used for PEX upgrade before using this command.
·     Recommended ISSU methods for upgrading the running images to the specified images.
This command does not display information about software compatibility between the parent device and the PEXs. For this compatibility information, see the release notes.
# Display compatibility information for the running images.
<Sysname> display version comp-matrix
Boot image: flash:/cmw710-boot-r7180.bin
  Version:
  7.1.045
System image: flash:/cmw710-system-r7180.bin
  Version:
  V700R001B45D001
  Version compatibility list:
  V700R001B45D001
  Version dependency boot list:
  7.1.045
Feature image: flash:/cmw710-cfa-a7180.bin
  Version:
  V700R001B45D003
  V700R001B45D003
  Version dependency system list:
  V700R001B45D001
  V700R001B45D002
# Display compatibility information for flash:/boot-e2205.bin, flash:/system-e2205.bin, and flash:/dhcp-e2205.re.bin, as well as the recommended ISSU method. (In this example, the specified images are incompatible with the running images.)
<Sysname> display version comp-matrix file boot flash:/boot-e2205.bin system flash:/system-e2205.bin feature flash:/dhcp-e2205.re.bin
Verifying the flash:/dhcp-e2205.re.bin on slot 7............Done.
Verifying the file flash:/boot-e2205.bin on slot 7............Done.
Verifying the file flash:/system-e2205.bin on slot 7............Done.
Boot image: flash:/boot-e2205.bin
  Version:
  7.1.045
System image: flash:/system-e2205.bin
  Version:
  V200R001B45D012
  V200R001B45D012
  7.1.045
Feature image: flash:/dhcp-e2205.re.bin
  Version:
  V200R001B45D012
  V200R001B45D012
  V200R001B45D012
  V200R001B45D014
Incompatible upgrade.
# (In standalone mode.) Display compatibility information for cmw710-cfa-r7180.bin and the recommended ISSU methods. (In this example, the specified image is compatible with the running images.)
<Sysname> display version comp-matrix file feature flash:/cmw710-cfa-r7180.bin
Verifying the file flash:/boot-e2205.bin system on slot 6............Done.
Feature image: flash:/cmw710-cfa-r7180.bin
  Version:
  V700R001B45D002
  V700R001B45D001
  V700R001B45D002
  V700R001B45D001
  V700R001B45D002
  Slot                        Upgrade Way
  6                           Service Upgrade
  7                           Service Upgrade
Influenced service according to following table on slot 6:
flash:/cmw710-cfa-a7125.bin
    CFA
Influenced service according to following table on slot 7:
    CFA
# (In IRF mode.) Display compatibility information for cmw710-cfa-r7180.bin and the recommended ISSU methods. (In this example, the specified image is compatible with the running images.)
Verifying the file flash:/cmw710-cfa-r7180.bin system on chassis 1 slot 6............Done.
  Version:
  V700R001B45D002
  V700R001B45D001
  V700R001B45D002
  V700R001B45D001
  V700R001B45D002
  Chassis   Slot              Upgrade Way
  1         6                 Service Upgrade
  1         7                 Service Upgrade
  2         6                 Service Upgrade
  2         7                 Service Upgrade
Influenced service according to following table on chassis 1 slot 6:
    CFA
Influenced service according to following table on chassis 1 slot 7:
    CFA
Influenced service according to following table on chassis 2 slot 6:
    CFA
Influenced service according to following table on chassis 2 slot 7:
    CFA
# Display compatibility information for the running images on the parent device, and compatibility information for the running images on the PEXs.
  Version:
  7.1.045
  Version:
  D2404001
  D2404001
  7.1.045
Compatible info of S5120HI:
Boot image: flash:/rpu-s5120hi-boot.bin
  Version:
  7.1.045
System image: flash:/rpu-s5120hi-system.bin
  Version:
  T2206
  T2206
  7.1.045
# Display the following information:
·     Compatibility information for the upgrade images used for the parent device upgrade.
·     Compatibility information for the upgrade images used for the S6300HI PEX upgrade.
·     Recommended ISSU methods for the upgrades.
<Sysname> issu pex PEX-S6300HI file feature flash:/s6300hi-http-d2403.bin
Verifying the file flash:/s6300hi-http-d2403.bin on chassis 1 slot 6.....Done.
Copying file flash:/s6300hi-http-d2403.bin to chassis2#slot6#flash:/s6300hi-http-d2403.bin...Done.
<Sysname> display version comp-matrix file feature flash:/cmw710-cfa-a0041.bin
Verifying the file flash:/cmw710-cfa-a0041.bin system on chassis 1 slot 6............Done.
Feature image: flash:/cmw710-cfa-a0041.bin
  Version:
  A0042
  A0041
  A0042
  A0041
Compatible info of S6300HI:
Feature image: flash:/s6300hi-http-d2403.bin
  Version:
  D2403
  D2402
  D2403
  D2402
  1         6                 Service Upgrade
  1         7                 Service Upgrade
  1         9                 Service Upgrade
  2         6                 Service Upgrade
  2         7                 Service Upgrade
  101       6                 Service Upgrade
flash:/cmw710-cfa-a7122.bin
    CFA
    CFA
Influenced service according to following table on chassis 1 slot 9:
    CFA
    CFA
    CFA
Influenced service according to following table on chassis 101 slot 6:
    HTTP
Verifying the file
·     Under a system image, this field shows all system image versions that are compatible with the system image.
·     Under a feature image, this field shows all feature image versions that are compatible with the feature image.
Boot image versions that support the system image. To install the system image, you must install one of the boot image versions that are in the list.
System image versions that support the feature image. To install the feature image, you must install one of the system image versions that is in the list.
Compatibility information for the PEXs.
Services that will be affected by the upgrade.
This field is displayed only for compatible versions.
You are upgrading the software to an incompatible version.
Chassis
Member ID of the device in the IRF fabric. This field is displayed only for compatible versions in IRF mode.
Slot
Slot number of the card. This field is displayed only for compatible versions.
Upgrade Way
ISSU method to be used for a compatible version:
·     Service Upgrade—Service-level incremental upgrade.
·     File Upgrade—File-level incremental upgrade.
·     Reboot—Upgrades software by rebooting both data and control planes. This method disrupts services.
For more information about ISSU methods, see Fundamentals Configuration Guide.
issu load
install abort
Use install abort to abort an ISSU operation.
install abort [ job-id ]
job-id: Specifies the job ID of an ISSU operation. If you do not specify this argument, the command aborts all ongoing software image activate and deactivate operations.
The system creates a software image management job each time you use the install activate, install add, install commit, install deactivate, or install remove command. Each job represents one command and is assigned a unique job ID. You can abort only ongoing activate and deactivate operations.
To obtain the ID of a job, use the display install job command.
# Abort a software image operation.
<Sysname> install abort
display install job
install activate
Use install activate to activate software images, or identify the ISSU method and possible impact on the device.
In standalone mode:
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number  [ test ]
install activate patch filename { all | slot slot-number }
In IRF mode:
install activate { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number slot slot-number [ test ]
install activate patch filename { all | chassis chassis-number slot slot-number }
boot: Specifies a boot image file. This keyword is supported only for a PEX.
system: Specifies a system image file. This keyword is supported only for a PEX.
patch: Specifies a patch image file.
filename: Specifies the file path of a .bin software image file, a case-insensitive string. The file must be stored in the root directory of a storage medium in the system. The maximum length is 1 to 63 characters for the storage-medium:/base-filename.bin segments of the file path. This length limit does not include the IRF member ID or slot number segment in front of the storage medium segment. For more information about specifying a file path, see "Managing the file system."
all: Specifies all cards. (In standalone mode.)
all: Specifies all cards and PEXs. (In IRF mode.)
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member. (In IRF mode.)
test: Only identifies the ISSU method to be used for the upgrade. If you do not specify this keyword, the command activates the specified software images.
Before you use this command to activate a software image, read the release notes to identify the licensing requirements for the image. If the image requires a license, make sure the device has a valid license installed for the image.
Images run in memory immediately after they are activated. However, only images activated by using the install activate patch filename all command still run in memory after a reboot. For other images to take effect after a reboot, you must commit the software change by using the install commit command.
In standalone mode, follow these guidelines:
·     If you specify the active MPU, the command takes effect on the active MPU and all LPUs.
·     If you specify the standby MPU, the command takes effect only on the standby MPU.
·     If the specified files are not saved on the MPU to be upgraded, the command copies the images to the MPU automatically.
In IRF mode, follow these guidelines:
·     If you specify the global active MPU, the command takes effect on the global active MPU and all LPUs.
·     If you specify a standby MPU, the command takes effect on the standby MPU.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install activate command on the subordinate device. To check the synchronization progress, use the display device and display mdc commands. The synchronization is completed when the following conditions are met:
·     All cards of the subordinate device are in normal state.
·     All MDCs are in active state.
# (In standalone mode.) Identify the ISSU method for feature upgrade with ssh2.bin on the standby MPU (in slot 7) and the upgrade impact.
<Sysname> install activate feature flash:/ssh2.bin slot 7 test
Copying file flash:/ssh2.bin to slot7#flash:/ssh2.bin......Done.
Verifying the file flash:/ssh2.bin on slot 7.....Done.
flash:/ssh2.bin
  Running Version             New Version
  Release 7148                Release 7180
  Slot                        Upgrade Way
  7                           Service Upgrade
Influenced service according to following table:
flash:/ssh2.bin
     SSH       IFMGR     CFA       LAGG
The output shows that a service upgrade is recommended. The SSH, IFMGR, CFA, and LAGG modules will be rebooted during the upgrade.
# (In IRF mode.) Identify the ISSU method for feature upgrade with ssh2.bin on the standby MPU in slot 7 of IRF member 1 and the upgrade impact.
<Sysname>install activate feature flash:/ssh2.bin chassis 1 slot 7 test
Copying file flash:/ssh2.bin to chassis1#slot7#flash:/ssh2.bin......Done.
Verifying the file flash:/ssh2.bin on chassis1 slot 7.....Done.
flash:/ssh2.bin
  1         7                 Service Upgrade
flash:/ssh2.bin
     SSH       IFMGR     CFA       LAGG
# (In standalone mode.) Activate the system image in file system.bin and feature images in file feature.bin on the standby MPU (in slot 7).
<Sysname> install activate system flash:/system.bin feature flash:/feature.bin slot 7
Copying file flash:/system.bin to slot7#flash:/system.bin......Done.
Verifying the file flash:/system.bin on slot 7.....Done.
Copying file flash:/feature.bin to slot7#flash:/feature.bin......Done.
Verifying the file flash:/feature.bin on slot 7.....Done.
flash:/system.bin
flash:/feature.bin
  None                        Release 7180
  Slot                        Upgrade Way
  7                           Service Upgrade
This operation maybe take several minutes, please wait.......................................................................Done.
# (In IRF mode.) Activate the feature images in file feature.bin on the standby MPU in slot 7 of IRF member 1.
<Sysname> install activate feature flash:/feature.bin chassis 1 slot 7
Copying file flash:/feature.bin to chassis1#slot7#flash:/feature.bin......Done.
Verifying the file flash:/feature.bin on chassis 1 slot 7.....Done.
flash:/route-feature.bin
  None                        Release 7180
  1         7                 Service Upgrade
Table 5 Command output
Verifying the file
Upgrade summary.
Running Version
Version number of the running software.
New Version
Version number of the new software.
Chassis
This field is available only in IRF mode.
Slot
Number of the slot where the card resides.
Upgrade Way
ISSU methods:
·     File Upgrade—File-level incremental upgrade. The upgrade involves only hidden program files and does not affect the operation of the system or services.
·     Reboot—Upgrading software by rebooting both data and control planes. This method disrupts services.
This field is displayed only for an upgrade to a compatible version.
Services influenced by the upgrade.
·     display install active
·     install commit
·     install deactivate
install add
Use install add to decompress an .ipe file.
install add ipe-filename medium-name:
medium-name: Specifies the name of the destination storage medium for the software images.
·     To specify a storage medium on the active MPU (in standalone mode) or global active MPU (in IRF mode), specify only the storage medium, for example, flash.
·     To specify a storage medium on the standby MPU in standalone mode, use the format slotslot-number#storage-medium.
·     To specify a storage medium on a global standby MPU in IRF mode, use the format chassischassis-number#slotslot-number#storage-medium.
·     To specify a storage medium on a PEX, use the format chassischassis-number#slotslot-number#storage-medium.
To use install commands for upgrade, you must use .bin image files. If the upgrade file is an .ipe file, use this command to decompress the .ipe file before you start the upgrade.
To identify software images that are included in an .ipe file, use the display install ipe-info command.
# Decompress all.ipe to the flash memory.
<Sysname> install add flash:/all.ipe flash:
Verifying the file flash:/all.ipe on slot 6...Done.
Decompressing file boot.bin to flash:/boot.bin.......................Done.
Decompressing file system.bin to flash:/system.bin.................................Done.
install commit
Use install commit to commit software changes.
install commit
Before you use this command, read the release notes to identify software image licensing requirements. Make sure the device has valid licenses for all license-based images.
This command revises the main startup software image list to be the same as the committed image list. Software changes take effect at the next startup.
You must execute this command after using the following commands:
·     The install activate command in an incremental upgrade.
·     The install deactivate command.
In a reboot upgrade, the install activate command revises both the current and startup software image lists. You do not need to commit software changes.
Both the install commit and boot-loader file commands change main startup software images. To change backup startup images or add inactive images as main startup images, however, you must use the boot-loader file command.
For more information about main and backup startup software images, see Fundamental Configuration Guide.
# Commit software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
·     install activate
install deactivate
Use install deactivate to deactivate feature images and patch images.
In standalone mode:
install deactivate feature filename&<1-30> slot slot-number
install deactivate patch filename { all | slot slot-number }
In IRF mode:
install deactivate feature filename&<1-30> chassis chassis-number slot slot-number
install deactivate patch filename { all | chassis chassis-number slot slot-number }
filename: Specifies the file path of a .bin software image file on the target slot, a case-insensitive string of 1 to 63 characters in the storage-medium:/base-filename.bin format. The file must be stored in the root directory of the storage medium. The file path cannot include slot or chassis information.
You can deactivate only active feature and patch images.
To prevent deactivated images from running after a reboot, you must commit the software changes by using the install commit command.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install deactivate command on the subordinate device. To check the synchronization progress, use the display device and display mdc commands. The synchronization is completed when the following conditions are met:
·     All cards in the subordinate device are in normal state.
# (In standalone mode.) Deactivate the patch images in route-patch.bin on slot 6.
<Sysname> install deactivate patch flash:/route-patch.bin slot 6
# (In IRF mode.) Deactivate the patch images in route-patch.bin on slot 6 of IRF member 1.
<Sysname> install deactivate feature flash:/route-feature.bin chassis 1 slot 6
·     display install inactive
install remove
Use install remove to delete inactive software images.
In standalone mode:
install remove [ slot slot-number ] { filename | inactive }
In IRF mode:
install remove [ chassis chassis-number slot slot-number ] { filename | inactive }
filename: Specifies the file path of a .bin software image file on the target slot, a case-insensitive string of 1 to 63 characters in the storage-medium:/base-filename.bin. The file must be stored in the root directory of the storage medium. The file path cannot include slot or chassis information.
inactive: Deletes all inactive software image files in the root directories of the specified storage media.
This command permanently deletes the software image file from the device. You cannot use the install abort command to abort the operation.
# Delete inactive software image file flash:/ssh-feature.bin.
<Sysname> install remove flash:/ssh-feature.bin
install verify
Use install verify to verify the software change confirmation status and software image integrity and consistency.
install verify
If some software images are not integral or some activated/deactivated software images are not confirmed, the following problems might occur:
·     A switchover might not occur as expected.
·     The MPUs might run software images of different versions after a reboot or even cannot reboot correctly.
To solve the problems, perform one of the following tasks:
·     Download and install the software images again to ensure software integrity.
·     Use the install activate, install deactivate, and install commit commands as appropriate to guarantee software image consistency.
# (In standalone mode.) Verify the software change confirmation status and software image integrity and consistency.
<Sysname> install verify
Active packages on slot 7 are the reference packages.
Packages will be compared with the reference packages.
  Verifying packages on slot 6:
  Start to check active package completeness.
Verifying the file flash:/boot-r7180.bin on slot 6.....................Done.
    flash:/boot-r7180.bin verification successful.
Verifying the file flash:/system-r7180.bin on slot 6.....................Done.
    flash:/system-r7180.bin verification successful.
  Start to check active package consistency.
    Active packages are consistent with committed packages on their own board.
    Active packages are consistent with the reference packages.
  Verifying packages on slot 7:
Verifying the file flash:/boot-r7180.bin on slot 7.....................Done.
Verifying the file flash:/system-r7180.bin on slot 7.....................Done.
Verification is done.
# (In IRF mode.) Verify the software change confirmation status and software image integrity and consistency.
  Verifying packages on chassis 1 slot 6:
  Verifying packages on chassis 1 slot 7:
issu accept
Use issu accept to accept the upgrade to a compatible version.
issu accept
You can execute the issu commit command to finish the ISSU process without executing this command.
The issu accept command does not apply to the ISSU to an incompatible version. The system will display an error message if you execute this command during this type of ISSU.
# Accept the upgrade to a compatible version.
<Sysname> issu accept
·     issu load
issu commit
Use issu commit to complete an ISSU upgrade to a compatible version.
issu commit chassis chassis-number
chassis chassis-number: Specifies the member ID of the original master or a subordinate member that has not been upgraded.
On a multichassis IRF fabric, use this command to upgrade subordinate members in turn. You must wait for the upgraded subordinate member to start up again and join the IRF fabric before upgrading another subordinate member. After all members are upgraded, the ISSU status changes to Init and the ISSU process ends.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu commit command on the subordinate device. To check the synchronization progress, use the display device and display mdc commands. The synchronization is completed when the following requirements are met:
# Upgrade the members that have not been upgraded during an ISSU to a compatible version. (In this example, the IRF fabric has four members, and only the member with the ID 2 has been upgraded.)
<Sysname> issu commit chassis 3
Copying file flash:/feature.bin to chassis3#slot7#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 3 slot 7..............Done.
flash:/feature.bin
  3         6                 Service Upgrade
  3         7                 Service Upgrade
<Sysname> issu commit chassis 4
Copying file flash:/feature.bin to chassis4#slot6#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 4 slot 6..............Done.
Copying file flash:/feature.bin to chassis4#slot7#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 4 slot 7..............Done.
flash:/feature.bin
  4         6                 Service Upgrade
  4         7                 Service Upgrade
<Sysname> issu commit chassis 1
Copying file flash:/feature.bin to chassis1#slot6#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 1 slot 6..............Done.
Copying file flash:/feature.bin to chassis1#slot7#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 1 slot 7..............Done.
flash:/feature.bin
  1         6                 Service Upgrade
  1         7                 Service Upgrade
For information about the command output, see Table 4.
·     issu accept
·     issu load
issu load
Use issu load to load the upgrade images for standby MPUs as the main startup software images.
issu load file { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number&<1-3>
issu load file ipe ipe-filename chassis chassis-number&<1-3>
filename: Specifies the file path of a .bin software image file, a case-insensitive string of 1 to 63 characters in the storage-medium:/base-filename.bin format. The file must be stored in the root directory of the storage medium on the global active MPU. If the storage medium is partitioned, the files must be saved in the root directory of the first partition. The file path cannot include chassis information.
ipe ipe-filename: Specifies the file path of an .ipe file, a case-insensitive string of 1 to 63 characters in the format storage-medium:/base-filename.ipe. The file must be stored in the root directory of the storage medium on the global active MPU. If the storage medium is partitioned, the files must be saved in the root directory of the first partition. The file path cannot include chassis information.
chassis chassis-number: Specifies the member ID of a subordinate member. For a compatible upgrade, you can specify only one member ID. For an incompatible upgrade, you can specify a space-separated list of up to three member IDs.
You may upgrade all or some of the software images. If you are upgrading only some of the images, make sure the new images are compatible with the images that are not to be upgraded. The upgrade will fail if a conflict exists.
For successful upgrade, perform the following tasks before you execute this command:
1.     Use the display device command to verify that all cards are not in Fault state.
2.     Use the display mdc command to verify that all MDCs are in active state.
This command checks the version compatibility and upgrades the specified MPUs with the specified software images.
# Upgrade member device 2 (a subordinate member) with the feature image file flash:/feature.bin. (In this example, the image is compatible with the running images.)
<Sysname> issu load file feature flash:/feature.bin chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:Y
Verifying the file flash:/feature.bin on chassis 1 slot 6...Done.
Copying file flash:/feature.bin to chassis2#slot6#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 2 slot 6...Done.
Copying file flash:/feature.bin to chassis2#slot7#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 2 slot 7...Done.
flash:/feature.bin
  2         2                 Service Upgrade
  2         3                 Service Upgrade
  2         4                 Service Upgrade
  2         6                 Service Upgrade
  2         7                 Service Upgrade
# Upgrade member devices 3 and 4 (subordinate members) with the feature image file flash:/feature.bin. (In this example, the image is incompatible with the running images.)
<Sysname>issu load file feature flash:/feature.bin chassis 3 4
Copying file flash:/feature.bin to chassis3#slot6#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 3 slot 6...Done.
Verifying the file flash:/feature.bin on chassis 3 slot 7...Done.
Verifying the file flash:/feature.bin on chassis 4 slot 6...Done.
Verifying the file flash:/feature.bin on chassis 4 slot 7...Done.
flash:/feature.bin
  3         2                 Reboot
  3         3                 Reboot
  3         4                 Reboot
  3         6                 Reboot
  3         7                 Reboot
  4         2                 Reboot
  4         3                 Reboot
  4         4                 Reboot
  4         6                 Reboot
  4         7                 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
Table 6 Command output
Verifying the file
Chassis
Slot
Upgrade Way
ISSU method:
issu pex
Use issu pex to specify images used for PEX upgrade.
issu pex pex-model file { boot filename | system filename | feature filename&<1-30> } *
issu pex pex-model file ipe ipe-filename
pex-model: Specifies the PEX model, a case-insensitive string of up to 63 characters. You must enter the complete PEX model name for the device to identify the PEX correctly. For available PEX models, enter boot-loader pex ?
filename: Specifies the file path of a .bin software image file, a case-insensitive string. The file must be stored in the root directory of a storage medium in the system. The maximum length is 63 characters for the storage-medium:/base-filename.bin segments of the file path. For more information about specifying a file path, see "Managing the file system."
ipe ipe-filename: Specifies the file path of an .ipe image package file, a case-insensitive string. The file must be stored in the root directory of a storage medium in the system. The maximum length is 63 characters for the storage-medium:/base-filename.ipe segments of the file path.
Use this command if you want to upgrade PEXs during an ISSU that uses issu commands.
This command sets software images for all PEXs of the specified model.
If the PEXs have a storage medium, the system performs the following operations after verifying validity of the source file:
1.     If you specify an .ipe file, the system automatically decompresses the .bin image files from the .ipe file to the same directory as the .ipe file.
2.     Copies the .bin files to all PEXs of the specified model.
3.     Displays a prompt for you to delete the following files:
¡     Source .ipe file (if any).
¡     Source .bin files if the .bin files are not on a PEX of the specified model.
If the PEXs do not have a storage medium, the system performs the following operations after verifying validity of the source file:
2.     Copies the .bin files to all other MPUs.
The PEXs will be upgraded with the upgrade images during the ISSU process.
# Specify flash:/devkit.bin as the image for upgrading S5120HI PEXs that do not have a storage medium.
<Sysname> issu pex PEX-S5120HI file feature flash:/devkit.bin
Verifying the file flash:/devkit.bin on chassis 1 slot 6............Done.
File flash:/devkit.bin already exists on chassis 1 slot 6.
Overwrite the existing files? [Y/N]:Y
Copying file flash:/devkit.bin to chassis101#slot6#flash:/devkit.bin...Done.
# Specify flash:/devkit.bin as the image for upgrading S6300HI PEXs that have a storage medium.
<Sysname> issu pex PEX-S6300HI file feature flash:/devkit.bin
Verifying the file flash:/test.ipe on chassis 1 slot 6............Done.
File flash:/devkit.bin already exists on chassis 101 slot 0.
Copying file flash:/devkit.bin to chassis101#slot0#flash:/devkit.bin...Done.
Delete flash:/devkit.bin from chassis 1 slot 6? [Y/N]:Y
# Specify flash:/test.ipe as the image source for upgrading S5120HI PEXs that do not have a storage medium.
<Sysname> issu pex PEX-S5120HI file ipe flash:/test.ipe
File flash:/manufacture.bin already exists on chassis 1 slot 6.
Decompressing file devkit.bin to flash:/devkit.bin. .....Done.
Decompressing file manufacture.bin to flash:/manufacture.bin.....Done.
Copying file flash:/devkit.bin to chasis1#slot6#flash:/devkit.bin. ...Done.
Copying file flash:/manufacture.bin to chassis1#slot6#flash:/manufacture.bin....Done.
# Specify flash:/test.ipe as the image source for upgrading S6300HI PEXs that have a storage medium.
<Sysname> issu pex PEX-S6300HI file ipe flash:/test.ipe
Decompressing file devkit.bin to flash:/devkit.bin...Done.
Copying file flash:/manufacture.bin to chassis101#slot0#flash:/manufacture.bin...Done.
Delete flash:/manufacture.bin from chassis 1 slot 6? [Y/N]:Y
Delete flash:/test.ipe from chassis 1 slot 6? [Y/N]:Y
issu load
issu rollback-timer
Use issu rollback-timer to set the automatic rollback timer.
Use undo issu rollback-timer to restore the default.
issu rollback-timer minutes
The automatic rollback interval is 45 minutes.
minutes: Specifies the automatic rollback interval in minutes, in the range of 0 to 120. Setting it to 0 disables automatic rollback.
As a best practice, do not use the automatic rollback feature. This feature is complicated.
# Disable automatic rollback.
[Sysname] issu rollback-timer 0
issu rollback
issu run switchover
Use issu run switchover to perform an ISSU switchover.
issu run switchover
For a compatible upgrade, this command performs operations depending on the ISSU method.
·     Incremental upgrade—Performs a process-level master/subordinate switchover for the processes to be upgraded.
·     Reboot upgrade or ISSU upgrade—Reboots the current master with the old software version, causing the upgraded subordinate member to be elected as the new master.
For an incompatible upgrade, this command splits the IRF fabric into two fabrics, with the upgraded members forming a new fabric. The issu run switchover command reboots the old IRF fabric's members with the upgrade images to upgrade the members. After startup, the members join the new IRF fabric as subordinate members.
During a reboot upgrade to a compatible version, the LPUs and switching fabric modules reboot to load the new software from the upgraded MPU. A transient service outage occurs on the cards.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu run switchover command on the subordinate device. To check the synchronization progress, use the display device and display mdc commands. The synchronization is completed when the following conditions are met:
# Perform an  ISSU switchover during an ISSU to a compatible version.
<Sysname> issu run switchover
flash:/feature.bin
Chassis   Slot              Switchover Way
  1         6                 Active standby process switchover
# Perform an ISSU switchover and upgrade members that have not been upgraded (member 1 and member 2) during an ISSU to an incompatible version.
Verifying the file flash:/feature.bin on chassis 1 slot 7...Done.
flash:/feature.bin
  1         2                 Reboot
  1         3                 Reboot
  1         4                 Reboot
  1         6                 Reboot
  1         7                 Reboot
  2         2                 Reboot
  2         3                 Reboot
  2         4                 Reboot
  2         6                 Reboot
  2         7                 Reboot
Table 7 Command output
Verifying the file
Switchover Way
Switchover method:
·     Active standby process switchover—Switch from the active process to the standby process.
·     Global active standby MPU switchover—Switch from the global active MPU to a global standby MPU.
For more information about the command output, see Table 4.
issu load
Use reset install log-history oldest to clear ISSU log entries.
reset install log-history oldest log-number
log-number: Specifies the number of ISSU log entries to be deleted.
This command clears the specified number of log entries, beginning with the oldest log.
# Clear the two oldest ISSU log entries.
<Sysname> reset install log-history oldest 2
display install log
