09 Security Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10009 Security Configuration Guide
05-Port security configuration
05-Port security configuration 200.59 KB
Configuring port security
Overview
Port security combines and extends 802.1X and MAC authentication to provide MAC-based network access control. This feature applies to networks, such as a WLAN, that require different authentication methods for different users on a port.
Port security provides the following functions:
·     Prevents unauthorized access to a network by checking the source MAC address of inbound traffic.
·     Prevents access to unauthorized devices or hosts by checking the destination MAC address of outbound traffic.
·     Controls MAC address learning and authentication on a port to make sure the port learns only source trusted MAC addresses.
A frame is illegal if its source MAC address cannot be learned in a port security mode or it is from a client that has failed 802.1X or MAC authentication. The port security feature automatically takes a predefined action on illegal frames. This automatic mechanism enhances network security and reduces human intervention.
For scenarios that require only 802.1X authentication or MAC authentication, H3C recommends you use  the 802.1X authentication or MAC authentication feature rather than port security. For more information about 802.1X and MAC authentication, see "Configuring 802.1X" and "Configuring MAC authentication."
Port security features
NTK
The need to know (NTK) feature prevents traffic interception by checking the destination MAC address in the outbound frames. The feature ensures that frames are sent only to the following hosts:
·     Hosts that have passed authentication.
·     Hosts whose MAC addresses have been learned or configured on the access device.
Intrusion protection
The intrusion protection feature checks the source MAC address in inbound frames for illegal frames, and takes a predefined action on each detected illegal frame. The action can be disabling the port temporarily, disabling the port permanently, or blocking frames from the illegal MAC address for 3 minutes (not user configurable).
Port security modes
Port security supports the following categories of security modes:
·     MAC learning control—Includes two modes: autoLearn and secure. MAC address learning is permitted on a port in autoLearn mode and disabled in secure mode.
·     Authentication—Security modes in this category implement MAC authentication, 802.1X authentication, or a combination of these two authentication methods.
Upon receiving a frame, the port in a security mode searches the MAC address table for the source MAC address. If a match is found, the port forwards the frame. If no match is found, the port learns the MAC address or performs authentication, depending on the security mode. If the frame is illegal, the port takes the predefined NTK or intrusion protection action. Outgoing frames are not restricted by port security's NTK action unless they trigger the NTK feature.
The maximum number of users a port supports equals the smaller value from the following values:
·     The maximum number of secure MAC addresses that port security allows.
·     The maximum number of concurrent users the authentication mode in use allows.
For example, if 802.1X allows more concurrent users than port security's limit on the number of MAC addresses on the port in userLoginSecureExt mode, port security's limit takes effect.
Table 1 describes the port security modes and the security features.
Table 1 Port security modes
Purpose
Security mode
Features that can be triggered
Turning off the port security feature
noRestrictions (the default mode)
In this mode, port security is disabled on the port and access to the port is not restricted.
N/A
Controlling MAC address learning
autoLearn
NTK/intrusion protection
secure
Performing 802.1X authentication
userLogin
N/A
userLoginSecure
userLoginSecureExt
userLoginWithOUI
Performing MAC authentication
macAddressWithRadius
Performing a combination of MAC authentication and 802.1X authentication
Or
macAddressOrUserLoginSecure
macAddressOrUserLoginSecureExt
Else
macAddressElseUserLoginSecure
macAddressElseUserLoginSecureExt
TIP
TIP:
·     userLogin specifies 802.1X authentication and port-based access control. userLogin with Secure specifies 802.1X authentication and MAC-based access control. Ext indicates allowing multiple 802.1X users to be authenticated and serviced at the same time. A security mode without Ext allows only one user to pass 802.1X authentication.
·     macAddress specifies MAC authentication.
·     Else specifies that the authentication method before Else is applied first. If the authentication fails, whether to turn to the authentication method following Else depends on the protocol type of the authentication request.
·     In a security mode with Or, the authentication method to be used depends on the protocol type of the authentication request.
·     autoLearn.
A port in this mode can learn MAC addresses. The automatically learned MAC addresses are not added to the MAC address table as dynamic MAC address. Instead, these MAC addresses are added to the secure MAC address table as secure MAC addresses. You can also configure secure MAC addresses by using the port-security mac-address security command.
A port in autoLearn mode allows frames sourced from the following MAC addresses to pass:
¡     Secure MAC addresses.
¡     MAC addresses configured by using the mac-address dynamic and mac-address static commands.
When the number of secure MAC addresses reaches the upper limit, the port transitions to secure mode.
·     secure.
MAC address learning is disabled on a port in secure mode. You configure MAC addresses by using the mac-address static and mac-address dynamic commands. For more information about configuring MAC address table entries, see Layer 2—LAN Switching Configuration Guide.
A port in secure mode allows only frames sourced from the following MAC addresses to pass:
·     userLogin.
A port in this mode performs 802.1X authentication and implements port-based access control. The port can service multiple 802.1X users. Once an 802.1X user passes authentication on the port, any subsequent 802.1X users can access the network through the port without authentication.
·     userLoginSecure.
A port in this mode performs 802.1X authentication and implements MAC-based access control. The port services only one user passing 802.1X authentication.
·     userLoginSecureExt.
This mode is similar to the userLoginSecure mode except that this mode supports multiple online 802.1X users.
·     userLoginWithOUI.
This mode is similar to the userLoginSecure mode. The difference is that a port in this mode also permits frames from one user whose MAC address contains a specific OUI.
In this mode, the port performs OUI check first. If the OUI check fails, the port performs 802.1X authentication. The port permits frames that pass OUI check or 802.1X authentication.
An OUI is a 24-bit number that uniquely identifies a vendor, manufacturer, or organization. In MAC addresses, the first three octets are the OUI.
macAddressWithRadius: A port in this mode performs MAC authentication, and services multiple users.
·     macAddressOrUserLoginSecure.
This mode is the combination of the macAddressWithRadius and userLoginSecure modes. The mode allows one 802.1X authentication user and multiple MAC authentication users to log in.
In this mode, the port performs 802.1X authentication first. If 802.1X authentication fails, MAC authentication is performed.
·     macAddressOrUserLoginSecureExt.
This mode is similar to the macAddressOrUserLoginSecure mode, except that this mode supports multiple 802.1X and MAC authentication users.
·     macAddressElseUserLoginSecure.
This mode is the combination of the macAddressWithRadius and userLoginSecure modes, with MAC authentication having a higher priority as the Else keyword implies. The mode allows one 802.1X authentication user and multiple MAC authentication users to log in.
The port performs MAC authentication upon receiving non-802.1X frames. Upon receiving 802.1X frames, the port performs MAC authentication and then, if the authentication fails, 802.1X authentication.
·     macAddressElseUserLoginSecureExt.
This mode is similar to the macAddressElseUserLoginSecure mode except that this mode supports multiple 802.1X and MAC authentication users as the Ext keyword implies.
Configuration task list
Tasks at a glance
Remarks
(Required.) Enabling port security
N/A
(Optional.) Setting port security's limit on the number of secure MAC addresses on a port
N/A
(Required.) Setting the port security mode
N/A
(Required.) Configuring port security features:
·     Configuring NTK
·     Configuring intrusion protection
Configure one or more port security features according to the network requirements.
(Optional.) Configuring secure MAC addresses
N/A
(Optional.) Ignoring authorization information from the server
N/A
(Optional.) Enabling MAC move
N/A
(Optional.) Applying a NAS-ID profile to port security
N/A
(Optional.) Enabling the authorization-fail-offline feature
N/A
Before you enable port security, disable 802.1X and MAC authentication globally.
When port security is enabled, you cannot enable 802.1X or MAC authentication, or change the access control mode or port authorization state. Port security automatically modifies these settings in different security modes.
To enable port security:
Step
Remarks
N/A
2.     Enable port security.
port-security enable
By default, port security is disabled.
You can use the undo port-security enable command to disable port security. Because the command logs off the online users, make sure no online users are present.
Enabling or disabling port security resets the following security settings to the default:
·     802.1X access control mode is MAC based.
·     802.1X port authorization state is auto.
For more information about 802.1X authentication and MAC authentication configuration, see "Configuring 802.1X" and "Configuring MAC authentication."
You can set the maximum number of secure MAC addresses that port security allows on a port for the following purposes:
·     Controlling the number of concurrent users on the port.
For a port operating in a security mode (except for autoLearn and secure), the upper limit equals the smaller of the following values:
¡     The limit of the secure MAC addresses that port security allows.
¡     The limit of concurrent users allowed by the authentication mode in use.
·     Controlling the number of secure MAC addresses on the port in autoLearn mode.
The port security's limit on the number of secure MAC addresses on a port is independent of the MAC learning limit described in MAC address table configuration. For more information about MAC address table configuration, see Layer 2—LAN Switching Configuration Guide.
To set the maximum number of secure MAC addresses allowed on a port:
Step
Remarks
N/A
2.     Enter Layer 2 Ethernet interface view.
N/A
3.     Set the maximum number of secure MAC addresses allowed on a port.
port-security max-mac-count count-value
By default, port security does not limit the number of secure MAC addresses on a port.
Before you set a port security mode for a port, complete the following tasks:
·     Disable 802.1X and MAC authentication.
·     Verify that the port does not belong to any aggregation group or service loopback group.
·     If you are configuring the autoLearn mode, set port security's limit on the number of secure MAC addresses. You cannot change the setting when the port is operating in autoLearn mode.
When you set the port security mode, follow these guidelines:
·     You can specify a port security mode when port security is disabled, but your configuration cannot take effect.
·     Changing the port security mode of a port logs off the online users of the port.
·     Do not enable 802.1X authentication or MAC authentication on a port where port security is configured.
To enable a port security mode:
Step
Remarks
N/A
2.     (Optional.) Set an OUI value for user authentication.
port-security oui index index-value mac-address oui-value
By default, no OUI value is configured for user authentication.
This command is required for the userlogin-withoui mode.
You can set multiple OUIs, but when the port security mode is userlogin-withoui, the port allows one 802.1X user and only one user that matches one of the specified OUIs.
3.     Enter Layer 2 Ethernet interface view.
N/A
4.     Set the port security mode.
port-security port-mode { autolearn | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-ext | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
By default, a port operates in noRestrictions mode.
After enabling port security, you can change the port security mode of a port only when the port is operating in noRestrictions (the default) mode. To change the port security mode for a port in any other mode, first use the undo port-security port-mode command to restore the default port security mode.
Configuring NTK
The NTK feature checks the destination MAC addresses in outbound frames to make sure frames are forwarded only to authenticated devices.
The NTK feature supports the following modes:
·     ntkonlyForwards only unicast frames with authenticated destination MAC addresses.
·     ntk-withbroadcastsForwards only broadcast frames and unicast frames with authenticated destination MAC addresses.
·     ntk-withmulticastsForwards only broadcast frames, multicast frames, and unicast frames with authenticated destination MAC addresses.
The NTK feature drops any unicast frame with an unknown destination MAC address. Not all port security modes support triggering the NTK feature. For more information, see Table 1.
To configure the NTK feature:
Step
Remarks
N/A
N/A
3.     Configure the NTK feature.
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkonly }
By default, NTK is disabled on a port and all frames are allowed to be sent.
Intrusion protection enables a device to take one of the following actions in response to illegal frames:
·     blockmac—Adds the source MAC addresses of illegal frames to the blocked MAC address list and discards the frames. All subsequent frames sourced from a blocked MAC address are dropped. A blocked MAC address is restored to normal state after being blocked for 3 minutes. The interval is fixed and cannot be changed.
·     disableport—Disables the port until you bring it up manually.
·     disableport-temporarily—Disables the port for a period of time. The period can be configured with the port-security timer disableport command.
To configure the intrusion protection feature:
Step
Remarks
N/A
N/A
3.     Configure the intrusion protection feature.
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
By default, intrusion protection is disabled.
4.     Return to system view.
N/A
5.     (Optional.) Set the silence timeout period during which a port remains disabled.
port-security timer disableport time-value
By default, the port silence timeout is 20 seconds.
On a port operating in either macAddressElseUserLoginSecure mode or macAddressElseUserLoginSecureExt mode, intrusion protection is triggered only after both MAC authentication and 802.1X authentication fail for the same frame.
Secure MAC addresses are configured or learned in autoLearn mode. If the secure MAC addresses are saved, they can survive a device reboot. You can bind a secure MAC address only to one port in a VLAN.
When the maximum number of secure MAC address entries is reached, the port changes to secure mode. In secure mode, the port cannot add or learn any more secure MAC addresses. The port allows only frames sourced from secure MAC addresses or MAC addresses configured by using the mac-address dynamic or mac-address static command to pass through.
Secure MAC addresses include static, sticky, and dynamic secure MAC addresses.
Table 2 A comparison of static, sticky, and dynamic secure MAC addresses
Address sources
Aging mechanism
Can be saved and survive a device reboot?
Static
Manually added (by using the port-security mac-address security command without the sticky keyword).
Not available.
The static addresses never age out unless you perform any of the following tasks:
·     Manually remove these MAC addresses.
·     Change the port security mode.
·     Disable the port security feature.
Yes.
Sticky
·     Manually added (by using the port-security mac-address security command with the sticky keyword).
·     Converted from dynamic secure MAC addresses.
·     Automatically learned when the dynamic secure MAC feature (port-security mac-address dynamic) is disabled.
By default, sticky MAC addresses do not age out. However, you can configure an aging timer or use the aging timer together with the inactivity aging feature to delete old sticky MAC addresses.
·     If only the aging timer is configured, the aging timer counts up regardless of whether traffic data has been sent from the sticky MAC address.
·     If both the aging timer and the inactivity aging feature are configured, the aging timer restarts once traffic data is detected from the sticky MAC address.
Yes.
The secure MAC aging timer restarts at a reboot.
Dynamic
·     Converted from sticky MAC addresses.
·     Automatically learned after the dynamic secure MAC feature is enabled.
Same as sticky MAC addresses.
No.
All dynamic secure MAC addresses are lost at reboot.
Configuration prerequisites
Before you configure secure MAC addresses, complete the following tasks:
·     Enable port security.
·     Set port security's limit on the number of MAC addresses on the port. Perform this task before you enable autoLearn mode.
·     Set the port security mode to autoLearn.
·     Configure the port to permit packets of the specified VLAN to pass or add the port to the VLAN. Make sure the VLAN already exists.
Configuration procedure
To configure a secure MAC address:
Step
Remarks
N/A
2.     (Optional.) Set the secure MAC aging timer.
port-security timer autolearn aging time-value
By default, secure MAC addresses do not age out.
3.     Configure a secure MAC address.
·     In system view:
port-security mac-address security [ sticky ] mac-address interface interface-type interface-number vlan vlan-id
·     In Layer 2 Ethernet interface view:
a.     interface interface-type interface-number
b.     port-security mac-address security [ sticky ] mac-address vlan vlan-id
c.     quit
By default, no secure MAC address exists.
In the same VLAN, a MAC address cannot be specified as both a static secure MAC address and a sticky MAC address.
4.     Enter Layer 2 Ethernet interface view.
N/A
5.     (Optional.) Enable inactivity aging.
port-security mac-address aging-type inactivity
By default, the inactivity aging feature is disabled.
6.     (Optional.) Enable the dynamic secure MAC feature.
By default, the dynamic secure MAC feature is disabled. Sticky MAC addresses can be saved to the configuration file. Once saved, they can survive a device reboot.
You can configure a port to ignore the authorization information received from the server (local or remote) after an 802.1X or MAC authentication user passes authentication.
To configure a port to ignore authorization information from the server:
Step
Remarks
N/A
N/A
3.     Ignore the authorization information received from the authentication server.
port-security authorization ignore
By default, a port uses the authorization information received from the authentication server.
Enabling MAC move
MAC move allows 802.1X or MAC authenticated users to move between ports on a device. For example, if an authenticated 802.1X user moves to another 802.1X-enabled port on the device, the authentication session is deleted from the first port. The user is reauthenticated on the new port.
If MAC move is disabled and an 802.1X authenticated user moves to another port, the user is not reauthenticated.
H3C recommends you enable MAC move for wireless users that roam between ports to access the network.
To enable MAC move:
Step
Remarks
N/A
2.     Enable MAC move.
port-security mac-move permit
By default, MAC move is disabled.
By default, the device sends its device name in the NAS-Identifier attribute of all RADIUS requests.
A NAS-ID profile enables you to send different NAS-Identifier attribute strings in RADIUS requests from different VLANs. The strings can be organization names, service names, or any user categorization criteria, depending on the administrative requirements.
For example, map the NAS-ID companyA to all VLANs of company A. The device will send companyA in the NAS-Identifier attribute for the RADIUS server to identify requests from any Company A users.
You can apply a NAS-ID profile to port security globally or on a port. On a port, the device selects a NAS-ID profile in the following order:
1.     The port-specific NAS-ID profile.
2.     The NAS-ID profile applied globally.
If no NAS-ID profile is applied or no matching binding is found in the selected profile, the device uses the device name as the NAS-ID.
For more information about the NAS-ID profile configuration, see "Configuring AAA."
To apply a NAS-ID profile to port security:
Step
Remarks
N/A
2.     Apply a NAS-ID profile.
·     In system view:
port-security nas-id-profile profile-name
b.     port-security nas-id-profile profile-name
By default, no NAS-ID profile is applied in system view or in Layer 2 Ethernet interface view.
The authorization-fail-offline feature logs off port security users who fail ACL authorization.
A user fails ACL authorization in the following situations:
·     The device fails to authorize the specified ACL to the user.
·     The server assigns a nonexistent ACL to the user.
This feature does not apply to VLAN authorization failure. The device logs off these users directly.
To enable the authorization-fail-offline feature:
Step
Remarks
N/A
2.     Enable the authorization-fail-offline feature.
port-security authorization-fail offline
By default, this feature is disabled, and the device does not log off users who fail ACL authorization.
Displaying and maintaining port security
Execute display commands in any view:
Display the port security configuration, operation information, and statistics.
display port-security [ interface interface-type interface-number ]
Display information about secure MAC addresses.
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
Display information about blocked MAC addresses.
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ]
Port security configuration examples
autoLearn configuration example
Network requirements
As shown in Figure 1, configure port FortyGigE 1/1/1 on the device to meet the following requirements:
·     Accept up to 64 users without authentication.
·     Be permitted to learn and add MAC addresses as sticky MAC addresses, and set the secure MAC aging timer to 30 minutes.
·     Stop learning MAC addresses after the number of secure MAC addresses reaches 64. If any frame with an unknown MAC address arrives, intrusion protection starts, and the port shuts down and stays silent for 30 seconds.
Figure 1 Network diagram
# Enable port security.
[Device] port-security enable
# Set the secure MAC aging timer to 30 minutes.
[Device] port-security timer autolearn aging 30
# Set port security's limit on the number of secure MAC addresses to 64 on port FortyGigE 1/1/1.
[Device] interface fortygige 1/1/1
[Device-FortyGigE1/1/1] port-security max-mac-count 64
# Set the port security mode to autoLearn.
[Device-FortyGigE1/1/1] port-security port-mode autolearn
# Configure the port to be silent for 30 seconds after the intrusion protection feature is triggered.
[Device-FortyGigE1/1/1] port-security intrusion-mode disableport-temporarily
[Device-FortyGigE1/1/1] quit
[Device] port-security timer disableport 30
# Verify the port security configuration.
[Device] display port-security interface fortygige 1/1/1
Port security parameters:
   Port security          : Enabled
   AutoLearn aging time   : 30 min
   Disableport timeout    : 30 s
   MAC move               : Denied
   Authorization fail     : Online
 NAS-ID profile is not configured
   OUI value list         :
 FortyGigE1/1/1 is link-up
   Port mode                      : autoLearn
   NeedToKnow mode                : Disabled
   Intrusion protection mode      : DisablePortTemporarily
   Security MAC address attribute
       Learning mode              : Sticky
       Aging type                 : Periodical
   Max secure MAC addresses       : 64
   Current secure MAC addresses   : 5
   Authorization                  : Permitted
·     The port security's limit on the number of secure MAC addresses on the port is 64.
·     The port security mode is autoLearn.
·     The intrusion protection action is disabling the port (DisablePortTemporarily) for 30 seconds.
The port allows for MAC address learning, and you can display the number of learned MAC addresses in the Current secure MAC addresses field.
# Display additional information about the learned MAC addresses.
[Device-FortyGigE1/1/1] display this
interface FortyGigE1/1/1
 port-security mac-address security sticky 0002-0000-0015 vlan 1
 port-security mac-address security sticky 0002-0000-0014 vlan 1
 port-security mac-address security sticky 0002-0000-0013 vlan 1
 port-security mac-address security sticky 0002-0000-0012 vlan 1
 port-security mac-address security sticky 0002-0000-0011 vlan 1
# Verify that the port security mode changes to secure after the number of MAC addresses learned by the port reaches 64.
# Verify that the port will be disabled for 30 seconds after it receives a frame with an unknown MAC address. (Details not shown.)
# After the port is re-enabled, delete several secure MAC addresses.
[Device] undo port-security mac-address security sticky 0002-0000-0015 vlan 1
[Device] undo port-security mac-address security sticky 0002-0000-0014 vlan 1
# Verify that the port security mode of the port changes to autoLearn, and the port can learn MAC addresses again. (Details not shown.)
userLoginWithOUI configuration example
As shown in Figure 2, a client is connected to the device through port FortyGigE 1/1/1. The device authenticates the client with a RADIUS server. If the authentication succeeds, the client is authorized to access the Internet.
·     The RADIUS server at 192.168.1.2 functions as the primary authentication server and the secondary accounting server. The RADIUS server at 192.168.1.3 functions as the secondary authentication server and the primary accounting server. The shared key for authentication is name, and the shared key for accounting is money.
·     All users use the authentication, authorization, and accounting methods of ISP domain sun.
·     The RADIUS server response timeout time is 5 seconds. The maximum number of RADIUS packet retransmission attempts is five. The device sends real-time accounting packets to the RADIUS server at 15-minute intervals, and sends usernames without domain names to the RADIUS server.
Configure port FortyGigE 1/1/1 of the device to allow only one 802.1X user and a user who uses one of the specified OUI values to be authenticated.
Figure 2 Network diagram
The following configuration steps cover some AAA/RADIUS configuration commands. For more information about the commands, see Security Command Reference.
Make sure the host and the RADIUS server can reach each other.
1.     Configure AAA:
# Configure a RADIUS scheme named radsun.
[Device] radius scheme radsun
[Device-radius-radsun] primary authentication 192.168.1.2
[Device-radius-radsun] primary accounting 192.168.1.3
[Device-radius-radsun] secondary authentication 192.168.1.3
[Device-radius-radsun] secondary accounting 192.168.1.2
[Device-radius-radsun] key authentication simple name
[Device-radius-radsun] key accounting simple money
[Device-radius-radsun] timer response-timeout 5
[Device-radius-radsun] retry 5
[Device-radius-radsun] timer realtime-accounting 15
[Device-radius-radsun] user-name-format without-domain
[Device-radius-radsun] quit
# Configure ISP domain sun.
[Device] domain sun
[Device-isp-sun] authentication lan-access radius-scheme radsun
[Device-isp-sun] authorization lan-access radius-scheme radsun
[Device-isp-sun] accounting lan-access radius-scheme radsun
[Device-isp-sun] quit
2.     Set the 802.1X authentication method to CHAP. By default, the authentication method for 802.1X is CHAP.
[Device] dot1x authentication-method chap
3.     Configure port security:
# Add five OUI values. (You can add up to 16 OUI values. The port permits only one user matching one of the OUIs to pass authentication.)
[Device] port-security oui index 1 mac-address 1234-0100-1111
[Device] port-security oui index 2 mac-address 1234-0200-1111
[Device] port-security oui index 3 mac-address 1234-0300-1111
[Device] port-security oui index 4 mac-address 1234-0400-1111
[Device] port-security oui index 5 mac-address 1234-0500-1111
# Set the port security mode to userLoginWithOUI.
[Device-FortyGigE1/1/1] port-security port-mode userlogin-withoui
# Verify the RADIUS scheme configuration.
[Device] display radius scheme radsun
RADIUS Scheme Name  : radsun
  Index : 0
  Primary Auth Server:
    IP  : 192.168.1.2                              Port: 1812   State: Active
    VPN : Not configured
  Primary Acct Server:
    IP  : 192.168.1.3                              Port: 1813   State: Active
  Second Auth Server:
    IP  : 192.168.1.3                              Port: 1812   State: Active
  Second Acct Server:
    IP  : 192.168.1.2                              Port: 1813   State: Active
  Accounting-On function                     : Disabled
    retransmission times                     : 50
    retransmission interval(seconds)         : 3
  Timeout Interval(seconds)                  : 5
  Retransmission Times                       : 5
  Retransmission Times for Accounting Update : 5
  Server Quiet Period(minutes)               : 5
  Realtime Accounting Interval(minutes)      : 15
  NAS IP Address                             : Not configured
  User Name Format                           : without-domain
  Data flow unit                             : Byte
  Packet unit                                : one
  Attribute-15 check-mode                    : strict
# After users pass authentication, display port security configuration. Verify that port FortyGigE 1/1/1 allows only one 802.1X user to be authenticated.
   AutoLearn aging time   : 0 min
   Disableport timeout    : 20 s
   MAC move               : Denied
   OUI value list         :
     Index :  1         Value : 123401
     Index :  2         Value : 123402
     Index :  3,        Value : 123403
     Index :  4,        Value : 123404
     Index :  5,        Value : 123405
   Port mode                      : userLoginWithOUI
   Intrusion protection mode      : NoAction
   Max secure MAC addresses       : Not configured
   Current secure MAC addresses   : 1
# Display information about the online 802.1X user to verify 802.1X configuration.
[Device] display dot1x
# Verify that the port also allows one user whose MAC address has an OUI among the specified OUIs to pass authentication.
[Device] display mac-address interface fortygige 1/1/1
MAC Address     VLAN ID   State          Port                               Aging
1234-0300-0011  1         Learned        FortyGigE1/1/1              Y
macAddressElseUserLoginSecure configuration example
As shown in Figure 3, a client is connected to the device through FortyGigE 1/1/1. The device authenticates the client by a RADIUS server. If the authentication succeeds, the client is authorized to access the Internet.
Configure port FortyGigE 1/1/1 of the device to meet the following requirements:
·     Allow more than one MAC authenticated user to log on.
·     For 802.1X users, perform MAC authentication first and then, if MAC authentication fails, 802.1X authentication. Allow only one 802.1X user to log on.
·     Use the MAC address of each user as the username and password for authentication. A MAC address is in the hexadecimal notation with hyphens, and letters are in upper case.
·     Set the total number of MAC authenticated users and 802.1X authenticated users to 64.
·     Enable NTK (ntkonly mode) to prevent frames from being sent to unknown MAC addresses.
Figure 3 Network diagram
1.     Configure RADIUS authentication/accounting and ISP domain settings. (See "userLoginWithOUI configuration example.")
2.     Configure port security:
# Use MAC-based accounts for MAC authentication. Each MAC address must be in the hexadecimal notation with hyphens, and letters are in upper case.
[Device] mac-authentication user-name-format mac-address with-hyphen uppercase
# Specify the MAC authentication domain.
[Device] mac-authentication domain sun
# Set the 802.1X authentication method to CHAP. By default, the authentication method for 802.1X is CHAP.
# Set port security's limit on the number of MAC addresses to 64 on the port.
# Set the port security mode to macAddressElseUserLoginSecure.
[Device-FortyGigE1/1/1] port-security port-mode mac-else-userlogin-secure
# Set the NTK mode of the port to ntkonly.
[Device-FortyGigE1/1/1] port-security ntk-mode ntkonly
   MAC move               : Denied
   OUI value list         :
   Port mode                      : macAddressElseUserLoginSecure
   NeedToKnow mode                : NeedToKnowOnly
   Current secure MAC addresses   : 0
# After users pass authentication, display MAC authentication information. Verify that port FortyGigE 1/1/1 allows multiple MAC authentication users to be authenticated.
[Device] display mac-authentication interface fortygige 1/1/1
   MAC authentication     : Enabled
   User name format       : MAC address in uppercase(XX-XX-XX-XX-XX-XX)
           Username       : mac
           Password       : Not configured
   Offline detect period  : 60 s
   Quiet period           : 5 s
   Server timeout         : 100 s
   Authentication domain  : sun
 Max MAC-auth users       : 4294967295 per slot
 Online MAC-auth users    : 3
 Silent MAC users:
          MAC address       VLAN ID  From port               Port index
   Carry User-IP              : Disabled
   Authentication domain      : Not configured
   Auth-delay timer           : Disabled
   Guest VLAN                 : Not configured
   Guest VLAN auth-period     : 30 s
   Critical VLAN              : Not configured
   Host mode                  : Single VLAN
   Max online users           : 4294967295
   Authentication attempts    : successful 3, failed 7
   Current online users       : 3
          MAC address       Auth state
    1234-0300-0011   authenticated
    1234-0300-0012   authenticated
    1234-0300-0013   authenticated
# Display 802.1X authentication information. Verify that FortyGigE 1/1/1 allows only one 802.1X user to be authenticated.
[Device] display dot1x interface fortygige 1/1/1
Global 802.1X parameters:
   802.1X authentication  : Enabled
   CHAP authentication    : Enabled
   Max-tx period          : 30 s
   Handshake period       : 15 s
   Quiet timer            : Disabled
       Quiet period       : 60 s
   Supp timeout           : 30 s
   Reauth period          : 3600 s
   Max auth requests      : 2
   EAD assistant function : Disabled
       EAD timeout        : 30 min
   Domain delimiter       : @
 Max 802.1X users         : 4294967295 per slot
 Online 802.1X users      : 1
   Handshake                  : Enabled
   Handshake reply            : Disabled
   Handshake security         : Disabled
   Unicast trigger            : Disabled
   Periodic reauth            : Disabled
   Port role                  : Authenticator
   Authorization mode         : Auto
   Port access control        : MAC-based
   Multicast trigger          : Enabled
   Mandatory auth domain      : Not configured
   Auth-Fail VLAN             : Not configured
   EAPOL packets: Tx 16331, Rx 102
   Sent EAP Request/Identity packets : 16316
        EAP Request/Challenge packets: 6
        EAP Success packets: 4
        EAP Failure packets: 5
   Received EAPOL Start packets : 6
            EAPOL LogOff packets: 2
            EAP Response/Identity packets : 80
            EAP Response/Challenge packets: 6
            Error packets: 0
   Online 802.1X users: 1
# Verify that frames with an unknown destination MAC address, multicast address, or broadcast address are discarded. (Details not shown.)
Troubleshooting port security
Cannot set the port security mode
Symptom
Cannot set the port security mode for a port.
Analysis
For a port operating in a port security mode other than noRestrictions, you cannot change the port security mode by using the port-security port-mode command.
Solution
To resolve the problem:
1.     Set the port security mode to noRestrictions.
[Device-FortyGigE1/1/1] undo port-security port-mode
2.     Set a new port security mode for the port, for example, autoLearn.
3.     If the problem persists, contact H3C Support.
Cannot configure secure MAC addresses
Symptom
Cannot configure secure MAC addresses.
Analysis
No secure MAC address can be configured on a port operating in a port security mode other than autoLearn.
Solution
1.     Set the port security mode to autoLearn.
[Device-FortyGigE1/1/1] port-security mac-address security 1-1-2 vlan 1
2.     If the problem persists, contact H3C Support.
