09 Security Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10009 Security Configuration Guide
10-SSH configuration
10-SSH configuration 422.56 KB
Configuring SSH·· 1
Overview·· 1
How SSH works 1
SSH authentication methods 2
FIPS compliance· 3
Configuring the device as an SSH server 4
SSH server configuration task list 4
Generating local key pairs 4
Enabling the Stelnet server 5
Enabling the SFTP server 5
Enabling the SCP server 6
Configuring NETCONF over SSH·· 6
Configuring user lines for SSH login· 6
Configuring a client's host public key· 7
Configuring an SSH user 8
Configuring the SSH management parameters 9
Configuring the device as an Stelnet client 11
Stelnet client configuration task list 11
Specifying the source IP address for SSH packets 11
Establishing a connection to an Stelnet server 11
Configuring the device as an SFTP client 13
SFTP client configuration task list 13
Specifying the source IP address for SFTP packets 13
Establishing a connection to an SFTP server 13
Working with SFTP directories 15
Working with SFTP files 15
Displaying help information· 15
Terminating the connection with the SFTP server 16
Configuring the device as an SCP client 16
Displaying and maintaining SSH·· 18
Stelnet configuration examples 18
Password authentication enabled Stelnet server configuration example· 18
Publickey authentication enabled Stelnet server configuration example· 21
Password authentication enabled Stelnet client configuration example· 26
Publickey authentication enabled Stelnet client configuration example· 30
SFTP configuration examples 32
Password authentication enabled SFTP server configuration example· 32
Publickey authentication enabled SFTP client configuration example· 35
SCP file transfer with password authentication· 38
Network requirements 38
Configuration procedure· 38
NETCONF over SSH configuration example with password authentication· 40
Network requirements 40
Configuration procedure· 40
Verifying the configuration· 42
Configuring SSH
Overview
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH can implement secure remote access and file transfer over an insecure network.
SSH uses the typical client-server model to establish a channel for secure data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
The device can work as an SSH server or as an SSH client.
·     When acting as an SSH server, the device provides services for SSH clients and supports the following SSH versions:
¡     For Secure Telnet (Stelnet), Secure File Transfer Protocol (SFTP), or Secure Copy (SCP) connections, the device supports SSH2 and SSH1 in non-FIPS mode and SSH2 in FIPS mode.
¡     For NETCONF-over-SSH connections, the device supports only SSH2 in both non-FIPS and FIPS modes.
·     When acting as an SSH client, the device supports only SSH2. It allows users to establish SSH connections with an SSH server.
The device supports the following SSH applications:
·     Secure Telnet—Stelnet provides secure and reliable network terminal access services. Through Stelnet, a user can securely log in to a remote server. Stelnet can protect devices against attacks, such as IP spoofing and plain text password interception. The device can act as an Stelnet server or an Stelnet client.
·     SFTP—Based on SSH2, it uses SSH connections to provide secure file transfer. The device can act as an SFTP server, allowing a remote user to log in to the SFTP server for secure file management and transfer. The device can also act as an SFTP client, enabling a user to log in from the device to a remote device for secure file transfer.
·     SCP—Based on SSH2, it offers a secure approach to copying files. The device can act as an SCP server, allowing a user to log in to the device for file upload and download. The device can also act as an SCP client, enabling a user to log in from the device to a remote device for secure file transfer.
·     NETCONF over SSH—Based on SSH2, it enables users to securely log in to the device through SSH and perform NETCONF operations on the device through the NETCONF-over-SSH connections. The device can act only as a server in NETCONF-over-SSH connections. For more information about NETCONF, see Network Management and Monitoring Configuration Guide.
How SSH works
This section uses SSH2 as an example to list the stages to establish an SSH session. For more information about these stages, see SSH Technology White Paper.
Table 1 Stages to establish an SSH session
Stages
Connection establishment
The SSH server listens to connection requests on port 22. After a client initiates a connection request, the server and the client establish a TCP connection.
Version negotiation
The two parties determine a version to use.
Algorithm negotiation
SSH supports multiple algorithms. Based on the local algorithms, the two parties negotiate the following algorithms:
·     Key exchange algorithm for generating session keys.
·     Encryption algorithm for encrypting data.
·     Public key algorithm for digital signature and authentication.
·     HMAC algorithm for protecting data integrity.
Key exchange
The two parties use the DH exchange algorithm to dynamically generate the session keys and session ID.
·     The session keys are used for protecting data transfer.
·     The session ID is used for identifying the SSH connection.
In this stage, the client also authenticates the server.
Authentication
The SSH server authenticates the client in response to the client's authentication request.
Session request
After passing the authentication, the client sends a session request to the server to request the establishment of a session (or request the Stelnet, SFTP, SCP, or NETCONF service).
Interaction
After the server grants the request, the client and the server start to communicate with each other in the session.
In this stage, you can paste commands in text format and execute them at the CLI. The text pasted at one time must be no more than 2000 bytes. To execute the commands successfully, H3C recommends that you paste commands that are in the same view.
To execute commands of more than 2000 bytes, save the commands in a configuration file, upload the file to the server through SFTP, and use it to restart the server.
This section describes authentication methods that are supported by the device when it acts as an SSH server.
The SSH server authenticates a client through the AAA mechanism. The password authentication process is as follows:
1.     The client sends the server an authentication request that includes the encrypted username and password.
2.     The server performs the following operations:
a.     Decrypts the request to get the username and password in plain text.
b.     Verifies the username and password locally or through remote AAA authentication.
c.     Informs the client of the authentication result.
If the AAA server requires the user to enter a password for secondary authentication, it sends the SSH server an authentication response carrying a prompt. The prompt is transparently transmitted to the client to notify the user to enter a specific password. When the user enters the correct password, the AAA sever examines the password validity. If the password is valid, the SSH server returns an authentication success message to the client.
For more information about AAA, see "Configuring AAA."
SSH1 clients do not support secondary password authentication that is initiated by the AAA server.
The server authenticates a client by verifying the digital signature of the client. The publickey authentication process is as follows:
1.     The client sends the server a publickey authentication request that includes the username, public key, and public key algorithm name.
If the digital certificate of the client is required in authentication, the client also encapsulates the digital certificate in the authentication request. The digital certificate carries the public key information of the client.
2.     The server verifies the client's public key.
¡     If the public key is invalid, the server informs the client of the authentication failure.
¡     If the public key is valid, the server requests the digital signature of the client. After receiving the signature, the server uses the public key to verify the signature, and informs the client of the authentication result.
When acting as an SSH server, the device supports using the public key algorithms RSA, DSA, and ECDSA to verify digital signatures.
When acting as an SSH client, the device supports using the public key algorithms RSA, DSA, and ECDSA to generate digital signatures.
For more information about public key configuration, see "Managing public keys."
Password-publickey authentication
The server requires SSH2 clients to pass both password authentication and publickey authentication. However, an SSH1 client only needs to pass either authentication, regardless of the requirement of the server.
Any authentication
The server requires clients to pass password authentication or publickey authentication.
FIPS compliance
The device supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and parameters might differ in FIPS mode and non-FIPS mode. For more information about FIPS mode, see "Configuring FIPS."
Tasks at a glance
Remarks
(Optional.) Generating local key pairs
N/A
(Required.) Enabling the Stelnet server
Required for Stelnet servers.
(Required.) Enabling the SFTP server
Required for SFTP servers.
(Required.) Enabling the SCP server
Required for SCP servers.
(Required.) Configuring NETCONF over SSH
Required for NETCONF-over-SSH servers.
(Required.) Configuring user lines for SSH login
Required for Stelnet servers and NETCONF-over-SSH servers.
(Required.) Configuring a client's host public key
Required if the authentication method is publickey, password-publickey, or any.
Configuring the PKI domain for verifying the client certificate
See "Configuring PKI."
Required if the following conditions exist:
·     The authentication method is publickey.
·     The clients send the public keys to the server through digital certificates for validity check.
The PKI domain must have the CA certificate to verify the client certificate.
(Required/optional.) Configuring an SSH user
Optional if the authentication method is password.
(Optional.) Configuring the SSH management parameters
N/A
The DSA, RSA, or ECDSA key pairs are required for generating the session keys and session ID in the key exchange stage. They can also be used by a client to authenticate the server. When a client authenticates the server, it compares the public key received from the server with the server's public key that the client saved locally. If the keys are consistent, the client uses the locally saved server's public key to decrypt the digital signature received from the server. If the decryption succeeds, the server passes the authentication.
When you execute any one of the SSH commands on the device to trigger the running of the SSH application, the SSH server automatically generates two RSA key pairs. You can also use the public-key local create command to generate DSA, RSA, or ECDSA key pairs on the device.
Configuration guidelines
When you generate local key pairs, follow these restrictions and guidelines:
·     SSH supports locally generated DSA, RSA, and ECDSA key pairs only with default names.
·     To support SSH clients that use different types of key pairs, generate DSA, RSA, and ECDSA key pairs on the SSH server.
·     The SSH server operating in FIPS mode supports only RSA and ECDSA key pairs.
·     The public-key local create rsa command generates a server key pair and a host key pair for RSA. In SSH1, the public key in the server key pair is used to encrypt the session key for secure transmission of the session key. Because SSH2 uses the DH algorithm to generate each session key on the SSH server and the client, no session key transmission is required. The server key pair is not used in SSH2.
·     The public-key local create dsa command generates only a DSA host key pair. SSH1 does not support the DSA algorithm.
·     The key modulus length must be less than 2048 bits when you use the public-key local create dsa command on the SSH server.
·     The public-key local create ecdsa secp256r1 command generates only an ECDSA host key pair.
To generate local key pairs on the SSH server:
Step
Remarks
N/A
2.     Generate local key pairs.
public-key local create { dsa | ecdsa secp256r1 | rsa }
By default, no local key pairs exist.
After you enable the Stelnet server on the device, clients can log in to the device through Stelnet.
To enable the Stelnet server:
Step
Remarks
N/A
2.     Enable the Stelnet server.
ssh server enable
By default, the Stelnet server is disabled.
After you enable the SFTP server on the device, clients can log in to the device through SFTP.
The device that acts as an SFTP server does not support SFTP connections initiated by SSH1 clients.
To enable the SFTP server:
Step
Remarks
N/A
2.     Enable the SFTP server.
sftp server enable
By default, the SFTP server is disabled.
After you enable the SCP server on the device, clients can log in to the device through SCP.
The device that acts as an SCP server does not support SCP connections initiated by SSH1 clients.
To enable the SCP server:
Step
Remarks
N/A
2.     Enable the SCP server.
scp server enable
By default, the SCP server is disabled.
After you enable NETCONF over SSH on the device, a client can perform NETCONF operations on the device through a NETCONF-over-SSH connection.
When the device acts as a server in the NETCONF-over-SSH connection, connection requests initiated by SSH1 clients are not supported.
For more information about NETCONF over SSH commands, see Network Management and Monitoring Command Reference.
To configure NETCONF over SSH:
Step
Remark
N/A
2.     Enable NETCONF over SSH.
netconf ssh server enable
By default, NETCONF over SSH is disabled.
3.     Specify a port to listen for NETCONF-over-SSH connections.
netconf ssh server port port-number
By default, port 830 listens for NETCONF-over-SSH connections.
Depending on the SSH application, an SSH client can be an Stelnet client, SFTP client, SCP client, or NETCONF-over-SSH client.
Only Stelnet and NETCONF-over-SSH clients require the user line configuration. The user line configuration takes effect on the clients at the next login.
To configure the user lines for Stelnet and NETCONF-over-SSH clients:
Step
Remarks
N/A
2.     Enter VTY user line view.
line vty number [ ending-number ]
N/A
3.     Set the login authentication mode to scheme.
authentication-mode scheme
By default, the authentication mode is password.
For more information about this command, see Fundamentals Command Reference.
In publickey authentication, the server compares the SSH username and client's host public key that it receives from the client with the locally saved SSH username and the client's host public key. If they are the same, the server checks the digital signature that the client sends. The client generates the digital signature by using the private key that is associated with the client's host public key.
For publickey authentication, password-publickey authentication, or any authentication, you must perform the following tasks:
1.     Configure the client's DSA, RSA, or ECDSA host public key on the server.
H3C recommends that you configure no more than 20 SSH client host public keys on an SSH server.
2.     Specify the associated host private key on the client to generate the digital signature.
If the device acts as an SSH client, specify the public key algorithm on the client. The algorithm determines the associated host private key for generating the digital signature.
You can enter the content of a client's host public key or import the client's host public key from the public key file. H3C recommends that you import the client's host public key.
Entering a client's host public key
Before you enter the client's host public key, you must use the display public-key local public command on the client to obtain the client's host public key.
To enter a client's host public key:
Step
Remarks
N/A
2.     Enter public key view.
public-key peer keyname
N/A
3.     Configure a client's host public key.
Enter the content of the host public key
The host public key must be in the DER encoding format without being converted.
When you enter the contents for a host public key, you can use spaces and carriage returns between characters. When you save the host public key, spaces and carriage returns are removed automatically.
For more information, see "Managing public keys."
4.     Return to system view.
peer-public-key end
N/A
Importing the client's host public key from the public key file
Before you import the host public key, upload the client's public key file (in binary) to the server, for example, through FTP or TFTP. During the import process, the server automatically converts the host public key in the public key file to a string in PKCS format.
To import a client's host public key from the public key file:
Step
2.     Import a client's public key from a public key file.
public-key peer keyname import sshkey filename
Configure an SSH user and a local user depending on the authentication method.
·     If the authentication method is publickey, you must create an SSH user and a local user on the SSH server. The two users must have the same username, so that the SSH user can be assigned the correct working directory and user role.
·     If the authentication method is password, you must perform one of the following tasks:
¡     For local authentication, configure a local user on the SSH server.
¡     For remote authentication, configure an SSH user on a remote authentication server, for example, a RADIUS server.
You do not need to create an SSH user by using the ssh user command. However, if you want to display all SSH users, including the password-only SSH users, for centralized management, you can use this command to create them. If such an SSH user has been created, make sure you have specified the correct service type and authentication method.
·     If the authentication method is password-publickey or any, you must create an SSH user and perform one of the following tasks:
In either case, the local user or the SSH user configured on the remote authentication server must have the same username as the SSH user.
When you configure an SSH user, follow these restrictions and guidelines:
·     An SSH server supports up to 1024 SSH users.
·     For an SFTP or SCP user, the working directory depends on the authentication method.
¡     If the authentication method is password, the working directory is authorized by AAA.
¡     If the authentication method is publickey or password-publickey, the working folder is specified by the authorization-attribute command in the associated local user view.
·     For an SSH user, the user role also depends on the authentication method.
¡     If the authentication method is password, the user role is authorized by the remote AAA server or the local device.
¡     If the authentication method is publickey or password-publickey, the user role is specified by the authorization-attribute command in the associated local user view.
·     If you change the authentication method or public key for a logged-in SSH user, the changes take effect at the next login.
·     For all authentication methods except password authentication, you must specify a client's host public key or digital certificate.
¡     For a client that directly sends the user's public key information to the server, you must specify the client's host public key on the server. The specified public key must already exist. For more information about public keys, see "Configuring a client's host public key."
¡     For a client that sends the user's public key information to the server through a digital certificate, you must specify the PKI domain on the server. This PKI domain verifies the client certificate. To make sure the authorized SSH users can pass the authentication, the specified PKI domain must have the correct CA certificate. For more information about configuring a PKI domain, see "Configuring PKI."
·     When the device operates in FIPS mode as an SSH server, the device does not support the authentication method of any or publickey.
For information about configuring local users and remote authentication, see "Configuring AAA."
To configure an SSH user, and specify the service type and authentication method:
Step
2.     Create an SSH user, and specify the service type and authentication method.
·     In non-FIPS mode:
ssh user
username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | { any | password-publickey | publickey } assign { pki-domain domain-name | publickey keyname } }
·     In FIPS mode:
ssh user
username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | password-publickey assign { pki-domain domain-name | publickey keyname } }
Step
Remarks
N/A
2.     Enable the SSH server to support SSH1 clients.
ssh server compatible-ssh1x enable
By default, the SSH server supports SSH1 clients.
This command is not available in FIPS mode.
3.     Set the minimum update interval for the RSA server key pair.
ssh server rekey-interval hours
By default, the RSA server key pair is not updated.
This command takes effect only on SSH1 users.
4.     Set the SSH user authentication timeout timer.
The default setting is 60 seconds.
If a user does not finish the authentication when the timeout timer expires, the connection cannot be established.
5.     Set the maximum number of SSH authentication attempts.
ssh server authentication-retries times
The default setting is 3.
6.     Specify an ACL to control SSH user connections.
·     Control IPv4 SSH user connections:
ssh server acl acl-number
·     Control IPv6 SSH user connections:
ssh server ipv6 acl [ ipv6 ] acl-number
By default, no ACLs are specified and all SSH users can initiate connections to the server.
7.     Set the DSCP value in the packets that the SSH server sends to the SSH clients.
·     Set the DSCP value in IPv4 packets:
ssh server dscp dscp-value
·     Set the DSCP value in IPv6 packets:
The default setting is 48.
The DSCP value of a packet defines the priority of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
8.     Configure the SFTP connection idle timeout timer.
The default setting is 10 minutes.
When the idle timeout timer expires, the system automatically terminates the connection.
9.     Specify the maximum number of concurrent online SSH users.
The default setting is 32.
When the number of online SSH users reaches the upper limit, the system denies new SSH connection requests.
Changing the upper limit does not affect online SSH users.
Tasks at a glance
(Optional.) Specifying the source IP address for SSH packets
(Required.) Establishing a connection to an Stelnet server
H3C recommends that you specify the IP address of the loopback interface as the source interface for SSH packets for the following purposes:
·     Ensuring the communication between the Stelnet client and the Stelnet server.
·     Improving the manageability of Stelnet clients in authentication service.
To specify the source IP address for SSH packets:
Step
Remarks
N/A
2.     Specify the source address for SSH packets.
·     Specify the source IPv4 address for SSH packets:
·     Specify the source IPv6 address for SSH packets:
ssh client ipv6 source
{ interface interface-type interface-number | ipv6 ipv6-address }
By default, the source IP address for SSH packets is not configured.
The IPv4 SSH packets use the primary IPv4 address of the output interface specified in the routing entry as their source address. The IPv6 SSH packets automatically select an IPv6 address as their source address in compliance with RFC 3484.
When you try to access an Stelnet server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
·     If you choose to continue, the device accesses the server and downloads the server's host public key.
·     If you choose to not continue, the connection cannot be established.
In an insecure network, H3C recommends that you configure the server's host public key on the device.
To establish a connection to an Stelnet server:
Remarks
Establish a connection to an Stelnet server.
·     In non-FIPS mode, establish a connection to an IPv4 Stelnet server:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | escape character | publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
·     In FIPS mode, establish a connection to an IPv4 Stelnet server:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ escape character | publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
·     In non-FIPS mode, establish a connection to an IPv6 Stelnet server:
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer- ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *[ dscp dscp-value | escape character | publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
·     In FIPS mode, establish a connection to an IPv6 Stelnet server:
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ escape character | publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Available in user view.
Tasks at a glance
(Optional.) Specifying the source IP address for SFTP packets
(Required.) Establishing a connection to an SFTP server
(Optional.) Working with SFTP directories
(Optional.) Working with SFTP files
(Optional.) Displaying help information
(Optional.) Terminating the connection with the SFTP server
H3C recommends that you specify the IP address of the loopback interface as the source interface for SFTP packets for the following purposes:
·     Ensuring the communication between the SFTP client and the SFTP server.
·     Improving the manageability of SFTP clients in the authentication service.
To specify the source IP address for SFTP packets:
Step
Remarks
N/A
2.     Specify the source address for SFTP packets.
·     Specify the source IPv4 address for SFTP packets:
sftp client source { ip ip-address | interface interface-type interface-number }
·     Specify the source IPv6 address for SFTP packets:
sftp client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
By default, the source IP address for SFTP packets is not configured.
The IPv4 SFTP packets use the primary IPv4 address of the output interface specified in the routing entry as their source IP address. The IPv6 SFTP packets automatically select an IPv6 address as their source address in compliance with RFC 3484.
When you try to access an SFTP server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
After the connection is established, you can directly enter SFTP client view on the server to perform file or directory operations.
To establish a connection to an SFTP server:
Remarks
Establish a connection to an SFTP server.
·     In non-FIPS mode, establish a connection to an IPv4 SFTP server:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
·     In FIPS mode, establish a connection to an IPv4 SFTP server:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
·     In non-FIPS mode, establish a connection to an IPv6 SFTP server:
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ dscp dscp-value | publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
·     In FIPS mode, establish a connection to an IPv6 SFTP server:
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Remarks
Change the working directory on the SFTP server.
cd [ remote-path ]
Available in SFTP client view.
Return to the upper-level directory.
cdup
Display the current working directory on the SFTP server.
pwd
Display files under a directory.
·     dir [ -a | -l ] [ remote-path ]
·     ls [ -a | -l ] [ remote-path ]
The dir command has the same function as the ls command.
Change the name of a directory on the SFTP server.
rename oldname newname
Create a new directory on the SFTP server.
mkdir remote-path
Delete one or more directories from the SFTP server.
rmdir remote-path
Remarks
Change the name of a file on the SFTP server.
rename old-name new-name
Download a file from the remote server and save it locally.
Upload a local file to the SFTP server.
Display the files under a directory.
·     delete remote-file
·     remove remote-file
The delete command has the same function as the remove command.
Remarks
Display the help information of SFTP client commands.
·     help
Remarks
Terminate the connection with the SFTP server and return to user view.
·     bye
·     exit
·     quit
These three commands have the same function.
This section describes how to configure the device as an SCP client to establish a connection with an SCP server and transfer files with the server.
When you try to access an SCP server, the device must use the server's host public key to authenticate the server. If the server's host public key is not configured on the device, the device will notify you to confirm whether to continue with the access.
To transfer files with an SCP server:
Remarks
Connect to the SCP server, and transfer files with the server.
·     In non-FIPS mode, connect to the IPv4 SCP server, and transfer files with this server:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
·     In FIPS mode, connect to the IPv4 SCP server, and transfer files with this server:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ip ip-address } ] *
·     In non-FIPS mode, connect to the IPv6 SCP server, and transfer files with this server:
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
·     In FIPS mode, connect to the IPv6 SCP server, and transfer files with this server:
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { ecdsa | rsa } | prefer-compress zlib | prefer-ctos-cipher { aes128 | aes256 } | prefer-ctos-hmac { sha1 | sha1-96 } | prefer-kex dh-group14 | prefer-stoc-cipher { aes128 | aes256 } | prefer-stoc-hmac { sha1 | sha1-96 } ] * [ publickey keyname | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Display the source IP address configured for the SFTP client.
display sftp client source
Display the source IP address configured for the Stelnet client.
display ssh client source
Display SSH server status or sessions.
Display SSH user information on the SSH server.
Display the public keys of the local key pairs.
display public-key local { dsa | ecdsa | rsa } public [ name publickey-name ]
Display the public keys of the SSH peers.
display public-key peer [ brief | name publickey-name ]
Unless otherwise noted, devices in the configuration examples are in non-FIPS mode.
When you configure Stelnet on a device that operates in FIPS mode, follow these restrictions and guidelines:
·     The modulus length of the key pair must be 2048 bits.
·     When the device acts as an Stelnet server, only RSA and ECDSA key pairs are supported.
As shown in Figure 1:
·     You can log in to Switch through the Stelnet client that runs on the host.
·     After login, you are assigned the user role network-admin for configuration management.
·     The switch acts as the Stelnet server and uses password authentication.
·     The username and password of the client are saved on the switch.
Figure 1 Network diagram
1.     Configure the Stelnet server:
# Generate RSA key pairs.
<Switch> system-view
[Switch] public-key local create rsa
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Generate a DSA key pair.
[Switch] public-key local create dsa
Generating Keys...
# Generate an ECDSA key pair.
[Switch] public-key local create ecdsa secp256r1
Generating Keys...
# Enable the Stelnet server.
[Switch] ssh server enable
# Assign an IP address to VLAN-interface 2. The Stelnet client uses this IP address as the destination for SSH connection.
[Switch-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[Switch-Vlan-interface2] quit
# Set the authentication mode to AAA for the user lines.
[Switch] line vty 0 63
[Switch-line-vty0-63] authentication-mode scheme
[Switch-line-vty0-63] quit
# Create a local device management user client001.
[Switch] local-user client001 class manage
# Specify the plaintext password as aabbcc and the service type as ssh for the user.
[Switch-luser-manage-client001] password simple aabbcc
[Switch-luser-manage-client001] service-type ssh
# Assign the user role network-admin to the user.
[Switch-luser-manage-client001] authorization-attribute user-role network-admin
[Switch-luser-manage-client001] quit
# Create an SSH user client001. Specify the service type as stelnet and the authentication method as password for the user.
[Switch] ssh user client001 service-type stelnet authentication-type password
2.     Establish a connection to the Stelnet server:
There are different types of Stelnet client software, such as PuTTY and OpenSSH. This example uses an Stelnet client that runs PuTTY version 0.58.
To establish a connection to the Stelnet server:
a.     Launch PuTTY.exe to enter the interface shown in Figure 2.
b.     In the Host Name (or IP address) field, enter the IP address 192.168.1.40 of the Stelnet server.
Figure 2 Specifying the host name (or IP address)
c.     Click Open to connect to the server.
If the connection is successfully established, the system notifies you to enter the username and password. After entering the username (client001 in this example) and password (aabbcc in this example), you can enter the CLI of the server.
As shown in Figure 3:
·     You can log in to the switch through the Stelnet client (SSH2) that runs on the host.
·     The switch acts as the Stelnet server and uses publickey authentication and the RSA public key algorithm.
Figure 3 Network diagram
In the server configuration, the client's host public key is required. Use the client software to generate RSA key pairs on the client before configuring the Stelnet server.
The configuration procedure is as follows:
1.     Generate RSA key pairs on the Stelnet client:
a.     Run PuTTYGen.exe on the client, select SSH-2 RSA and click Generate.
Figure 4 Generating a key pair on the client
b.     Continuously move the mouse and do not place the mouse over the green progress bar shown in Figure 5. Otherwise, the progress bar stops moving and the key pair generating progress stops.
Figure 5 Generating process
c.     After the key pair is generated, click Save public key to save the public key.
A file saving window appears.
d.     Enter a file name (key.pub in this example), and click Save.
Figure 6 Saving a key pair on the client
e.     On the page as shown in Figure 6, click Save private key to save the private key.
A confirmation dialog box appears.
f.     Click Yes.
g.     Enter a file name (private.ppk in this example), and click Save.
h.     Transmit the public key file to the server through FTP or TFTP. (Details not shown.)
2.     Configure the Stelnet server:
Generating Keys...
Generating Keys...
Generating Keys...
# Import the client's public key from file key.pub and name it switchkey.
[Switch] public-key peer switchkey import sshkey key.pub
# Create an SSH user client002. Specify the authentication method as publickey for the user. Assign the public key switchkey to the user.
[Switch] ssh user client002 service-type stelnet authentication-type publickey assign publickey switchkey
# Create a local device management user client002. Specify the service type as ssh for the user. Assign the user role network-admin to the user.
[Switch] local-user client002 class manage
[Switch-luser-manage-client002] service-type ssh
[Switch-luser-manage-client002] authorization-attribute user-role network-admin
[Switch-luser-manage-client002] quit
3.     Specify the private key file and establish a connection to the Stelnet server:
a.     Launch PuTTY.exe on the Stelnet client to enter the interface shown in Figure 7.
Figure 7 Specifying the host name (or IP address)
c.     Select Connection > SSH from the navigation tree.
The window shown in Figure 8 appears.
d.     Specify the Preferred SSH protocol version as 2 in the Protocol options area.
Figure 8 Specifying the preferred SSH version
e.     Select Connection > SSH > Auth from the navigation tree.
The window shown in Figure 9 appears.
f.     Click Browse… to bring up the file selection window, navigate to the private key file (private.ppk in this example), and click OK.
Figure 9 Specifying the private key file
g.     Click Open to connect to the server.
If the connection is successfully established, the system notifies you to enter the username. After entering the username (client002), you can enter the CLI of the server.
As shown in Figure 10:
·     You can log in to Switch B through the Stelnet client that runs on Switch A.
·     Switch B acts as the Stelnet server and uses password authentication.
·     The username and password of the client are saved on Switch B.
Figure 10 Network diagram
[SwitchB] public-key local create rsa
Generating Keys...
[SwitchB] public-key local create dsa
Generating Keys...
[SwitchB] public-key local create ecdsa secp256r1
Generating Keys...
[SwitchB] ssh server enable
# Assign an IP address to VLAN-interface 2. The Stelnet client uses the address as the destination address of the SSH connection.
[SwitchB-Vlan-interface2] ip address 192.168.1.40 255.255.255.0
[SwitchB] line vty 0 63
[SwitchB-line-vty0-63] authentication-mode scheme
[SwitchB-line-vty0-63] quit
[SwitchB] local-user client001 class manage
[SwitchB-luser-manage-client001] password simple aabbcc
[SwitchB-luser-manage-client001] service-type ssh
[SwitchB-luser-manage-client001] authorization-attribute user-role network-admin
[SwitchB-luser-manage-client001] quit
[SwitchB] ssh user client001 service-type stelnet authentication-type password
2.     Establish a connection to the Stelnet server 192.168.1.40:
[SwitchA-Vlan-interface2] ip address 192.168.1.56 255.255.255.0
[SwitchA] quit
Before establishing a connection to the server, you can configure the server's host public key on the client to authenticate the server.
¡     To configure the server's host public key on the client, perform the following tasks:
# Use the display public-key local dsa public command on the server to display the server's host public key. (Details not shown.)
# Enter public key view of the client and copy the host public key of the server to the client.
[SwitchA] public-key peer key1
Enter public key view. Return to system view with "peer-public-key end" command.
[SwitchA-pkey-public-key-key1]308201B73082012C06072A8648CE3804013082011F0281810
0D757262C4584C44C211F18BD96E5F0
[SwitchA-pkey-public-key-key1]61C4F0A423F7FE6B6B85B34CEF72CE14A0D3A5222FE08CECE
65BE6C265854889DC1EDBD13EC8B274
[SwitchA-pkey-public-key-key1]DA9F75BA26CCB987723602787E922BA84421F22C3C89CB9B0
6FD60FE01941DDD77FE6B12893DA76E
[SwitchA-pkey-public-key-key1]EBC1D128D97F0678D7722B5341C8506F358214B16A2FAC4B3
68950387811C7DA33021500C773218C
[SwitchA-pkey-public-key-key1]737EC8EE993B4F2DED30F48EDACE915F0281810082269009E
14EC474BAF2932E69D3B1F18517AD95
[SwitchA-pkey-public-key-key1]94184CCDFCEAE96EC4D5EF93133E84B47093C52B20CD35D02
492B3959EC6499625BC4FA5082E22C5
[SwitchA-pkey-public-key-key1]B374E16DD00132CE71B020217091AC717B612391C76C1FB2E
88317C1BD8171D41ECB83E210C03CC9
[SwitchA-pkey-public-key-key1]B32E810561C21621C73D6DAAC028F4B1585DA7F42519718CC
9B09EEF0381840002818000AF995917
[SwitchA-pkey-public-key-key1]E1E570A3F6B1C2411948B3B4FFA256699B3BF871221CC9C5D
F257523777D033BEE77FC378145F2AD
[SwitchA-pkey-public-key-key1]D716D7DB9FCABB4ADBF6FB4FDB0CA25C761B308EF53009F71
01F7C62621216D5A572C379A32AC290
[SwitchA-pkey-public-key-key1]E55B394A217DA38B65B77F0185C8DB8095522D1EF044B465E
8716261214A5A3B493E866991113B2D
[SwitchA-pkey-public-key-key1]485348
[SwitchA-pkey-public-key-key1] peer-public-key end
[SwitchA] quit
# Establish an SSH connection to the server, and specify the host public key of the server.
<SwitchA> ssh2 192.168.1.40 publickey key1
Username: client001
Connecting to 192.168.1.40 port 22.
[email protected]'s password:
Enter a character ~ and a dot to abort.
* Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
<SwitchB>
After you enter the correct password, you log in to Switch B successfully.
¡     If the client does not have the server's host public key, the system notifies you to confirm whether to continue with the access when you access the server. Select Yes to access the server and download the server's host public key.
Username: client001
The server is not authenticated. Continue? [Y/N]:y
Do you want to save the server public key? [Y/N]:y
<SwitchB>
After you enter the correct password, you can log in to Switch B successfully. The server's host public key is saved on the client. At the next connection attempt, the system will not notify you to authenticate the server.
As shown in Figure 11:
·     Switch B acts as the Stelnet server and uses publickey authentication and the DSA public key algorithm.
Figure 11 Network diagram
In the server configuration, the client public key is required. Use the client software to generate a DSA key pair on the client before configuring the Stelnet server.
1.     Configure the Stelnet client:
[SwitchA] public-key local create dsa
Generating Keys...
# Export the DSA host public key to file key.pub.
[SwitchA] public-key local export dsa ssh2 key.pub
[SwitchA] quit
# Transmit the public key file key.pub to the server through FTP or TFTP. (Details not shown.)
Generating Keys...
Generating Keys...
Generating Keys...
# Enable Stelnet server.
# Import the peer public key from the file key.pub, and name it switchkey.
[SwitchB] public-key peer switchkey import sshkey key.pub
[SwitchB] ssh user client002 service-type stelnet authentication-type publickey assign publickey switchkey
[SwitchB] local-user client002 class manage
[SwitchB-luser-manage-client002] service-type ssh
[SwitchB-luser-manage-client002] authorization-attribute user-role network-admin
[SwitchB-luser-manage-client002] quit
3.     Establish an SSH connection to the Stelnet server 192.168.1.40.
Username: client002
Do you want to save the server public key? [Y/N]:n
<SwitchB>
Select Yes to access the server and download the server's host public key. At the next connection attempt, the client authenticates the server by using the saved server's host public key on the client.
When you configure SFTP on a device that operates in FIPS mode, follow these restrictions and guidelines:
·     When the device acts as an SFTP server, only RSA and ECDSA key pairs are supported.
As shown in Figure 12:
·     You can log in to the switch through the SFTP client that runs on the host.
·     After login, you are assigned the user role network-admin to execute file management and transfer operations.
·     The switch acts as the SFTP server and uses password authentication.
Figure 12 Network diagram
1.     Configure the SFTP server:
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SFTP server.
[Switch] sftp server enable
# Assign an IP address to VLAN-interface 2. The SFTP client uses the address as the destination for SSH connection.
[Switch-Vlan-interface2] ip address 192.168.1.45 255.255.255.0
# Create a local device management user client002. Specify the plaintext password as aabbcc and the service type as ssh for the user. Assign the user role network-admin and the working directory flash:/ to the user.
[Switch-luser-manage-client002] password simple aabbcc
[Switch-luser-manage-client002] authorization-attribute user-role network-admin work-directory flash:/
# Create an SSH user client002. Specify the authentication method as password and the service type as sftp for the user.
[Switch] ssh user client002 service-type sftp authentication-type password
2.     Establish a connection between the SFTP client and the SFTP server:
The device supports different types of SFTP client software. This example uses an SFTP client that runs PSFTP of PuTTy version 0.58.
PSFTP supports only password authentication.
To establish a connection to the SFTP server:
a.     Run the psftp.exe to launch the client interface shown in Figure 13, and enter the following command:
open 192.168.1.45
b.     Enter username client002 and password aabbcc as prompted to log in to the SFTP server.
Figure 13 SFTP client interface
As shown in Figure 14:
·     You can log in to Switch B through the SFTP client that runs on Switch A.
·     Switch B acts as the SFTP server and uses publickey authentication and the RSA public key algorithm.
Figure 14 Network diagram
In the server configuration, the client's host public key is required. Generate RSA key pairs on the client before configuring the SFTP server.
1.     Configure the SFTP client:
[SwitchA-Vlan-interface2] ip address 192.168.0.2 255.255.255.0
[SwitchA] public-key local create rsa
Generating Keys...
# Export the host public key to the file pubkey.
[SwitchA] public-key local export rsa ssh2 pubkey
[SwitchA] quit
# Transmit the public key file pubkey to the server through FTP or TFTP. (Details not shown.)
2.     Configure the SFTP server:
Generating Keys...
Generating Keys...
Generating Keys...
[SwitchB] sftp server enable
[SwitchB-Vlan-interface2] ip address 192.168.0.1 255.255.255.0
# Import the peer public key from the file pubkey, and name it switchkey.
[SwitchB] public-key peer switchkey import sshkey pubkey
# Create an SSH user client001. Specify the service type as sftp and the authentication method as publickey for the user. Assign the public key switchkey to the user.
[SwitchB] ssh user client001 service-type sftp authentication-type publickey assign publickey switchkey
# Specify the service type as ssh for the user.
# Assign the user role network-admin and the working directory flash:/ to the user.
[SwitchB-luser-manage-client001] authorization-attribute user-role network-admin work-directory flash:/
3.     Establish a connection to the SFTP server:
# Establish a connection to the SFTP server and enter SFTP client view.
<SwitchA> sftp 192.168.0.1 identity-key rsa
Username: client001
Connecting to 192.168.0.1 port 22.
sftp>
# Display files under the current directory of the server, delete the file z, and verify the result.
sftp> dir -l
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey
drwxrwxrwx   1 noone    nogroup         0 Sep 01 06:22 new
-rwxrwxrwx   1 noone    nogroup       225 Sep 01 06:55 pub
-rwxrwxrwx   1 noone    nogroup         0 Sep 01 08:00 z
sftp> delete z
Removing /z
sftp> dir -l
# Add a directory new1 and verify the result.
sftp> mkdir new1
sftp> dir -l
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:30 new1
# Rename directory new1 to new2 and verify the result.
sftp> rename new1 new2
sftp> dir -l
drwxrwxrwx   1 noone    nogroup         0 Sep 02 06:33 new2
# Download the file pubkey2 from the server and save it as a local file public.
sftp> get pubkey2 public
Fetching / pubkey2 to public
/pubkey2                                  100% 225     1.4KB/s   00:00
# Upload the local file pu to the server, save it as puk, and verify the result.
sftp> put pu puk
Uploading pu to / puk
sftp> dir -l
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:35 pub
-rwxrwxrwx   1 noone    nogroup       283 Sep 02 06:36 puk
sftp>
# Exit SFTP client view.
sftp> quit
<SwitchA>
Unless otherwise noted, devices in the configuration example are in non-FIPS mode.
When you configure SCP on a device that operates in FIPS mode, follow these restrictions and guidelines:
·     When the device acts as an SCP server, only RSA and ECDSA key pairs are supported.
As shown in Figure 15:
·     You can log in to Switch B through the SCP client that runs on Switch A.
·     After login, you are assigned the user role network-admin and can securely transfer files with Switch B.
·     Switch B uses the password authentication method.
·     The client's username and password are saved on Switch B.
Figure 15 Network diagram
1.     Configure the SCP server:
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SCP server.
[SwitchB] scp server enable
# Configure an IP address for VLAN-interface 2. The SCP client uses this address as the destination for SCP connection.
# Configure an SSH user client001. Specify the service type as scp and the authentication method as password for the user.
[SwitchB] ssh user client001 service-type scp authentication-type password
2.     Configure an IP address for VLAN-interface 2 on the SCP client.
[SwitchA] quit
3.     Connect to the SCP server, download the file remote.bin from the server, and save it locally with the name local.bin.
<SwitchA> scp 192.168.0.1 get remote.bin local.bin
Username: client001
[email protected]’s password:
remote.bin                                       100% 2875     2.8KB/s   00:00
Unless otherwise noted, the switch in the configuration example is in non-FIPS mode.
When you configure NETCONF-over-SSH on a device that operates in FIPS mode, follow these restrictions and guidelines:
·     When the device acts as a NETCONF-over-SSH server, only RSA and ECDSA key pairs are supported.
As shown in Figure 16:
·     The switch uses local password authentication.
·     The client's username and password are saved on the switch.
Establish a NETCONF-over-SSH connection between the host and the switch, so that you can log in to the switch to perform NETCONF operations.
Figure 16 Network diagram
Generating Keys...
Generating Keys...
Generating Keys...
# Enable NETCONF over SSH.
[Switch] netconf ssh server enable
# Configure an IP address for VLAN-interface 2. The client uses this address as the destination for NETCONF-over-SSH connection.
# Configure an SSH user client001. Specify the service type as NETCONF and the authentication method as password for the user.
[Switch] ssh user client001 service-type netconf authentication-type password
# Verify that you can perform NETCONF operations after logging in to the switch. (Details not shown.)
