- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-Emergency shell commands
- 10-Device management commands
- 11-Tcl commands
- 12-License management commands
- 13-Password recovery control command
- 14-Python commands
| 08-ISSU commands | 231.75 KB |
display install active
Use display install active to display active software images.
In standalone mode:
display install active [ slot slot-number ] [ verbose ]
In IRF mode:
display install active [ chassis chassis-number slot slot-number ] [ verbose ]
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command is applied to all cards in the device. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member. If you do not specify this option, the command is applied to all cards in the IRF fabric. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays only the names of the active software images.
# (In standalone mode.) Display active software images.
<Sysname> display install active
Active packages on slot 1:
flash:/boot.bin
flash:/system.bin
flash:/feature.bin
# (In IRF mode.) Display active software images.
Active packages on chassis 1 slot 1:
flash:/boot.bin
flash:/system.bin
flash:/feature.bin
# (In standalone mode.) Display detailed information about active software images.
<Sysname> display install active verbose
flash:/boot.bin
[Package]
Vendor: H3C
Product: xxxx
Service name: boot
Platform version: 7.1.022
Product version: Test 2201
Supported board: mpu
[Component]
Component: boot
Description: boot package
flash:/system.bin
[Package]
Vendor: H3C
Product: xxxx
Service name: system
[Component]
Component: system
Description: system package
flash:/feature.bin
[Package]
Vendor: H3C
Product: xxxx
Service name: test
[Component]
Component: test
Description: test package
# (In IRF mode.) Display detailed information about active software images.
flash:/boot.bin
[Package]
Vendor: H3C
Product: xxxx
Service name: boot
[Component]
Component: boot
flash:/system.bin
[Package]
Vendor: H3C
Product: xxxx
[Component]
Component: system
flash:/feature.bin
[Package]
Vendor: H3C
Product: xxxx
Service name: test
[Component]
Component: test
Active packages on slot n |
Active software images on the card in the specified slot. (In standalone mode.) |
Active packages on chassis m slot n |
Active software images on the card in the specified slot of the specified member. (In IRF mode.) |
flash:/boot.bin |
Software image package path. |
[Package] |
Detailed information about the software image. |
Service name |
Image type: · boot—Boot image. · system—System image. · patch—Patch image. · Any other value indicates a feature image. |
Platform version |
Comware version number. |
Product version |
Release number of the product. |
Supported board |
Cards supported by the software image: · cen—Mother board. · mpu—MPU. · lc—LPU. · sfc—Switching fabric module. |
[Component] |
Information about components included in the image file. |
install active
display install backup
Use display install backup to display backup startup software images.
In standalone mode:
display install backup [ slot slot-number ] [ verbose ]
In IRF mode:
display install backup [ chassis chassis-number slot slot-number ] [ verbose ]
verbose: Displays detailed information. If you do not specify this keyword, the command displays only the names of the software images.
To change the backup startup software image list, you must use the boot-loader file command.
For more information about setting backup startup software images, see Fundamental Configuration Guide.
# (In standalone mode.) Display the backup startup software images.
<Sysname> display install backup
Backup startup software images on slot 1:
flash:/boot-a0201.bin
flash:/system-a0201.bin
# (In IRF mode.) Display the backup startup software images.
Backup startup software images on chassis 1 slot 1:
# Display detailed information about backup startup software images.
<Sysname> display install backup verbose
[Package]
Vendor: H3C
Product: xxxx
Service name: boot
Product version: Beta 1330
[Component]
Component: boot
[Package]
Vendor: H3C
Product: xxxx
Supported board: mr, lc, sfc
[Component]
Component: system
For information about the command output, see Table 1.
· boot-loader file
· display install committed
Use display install committed to display main startup software images.
In standalone mode:
display install committed [ slot slot-number ] [ verbose ]
In IRF mode:
display install committed [ chassis chassis-number slot slot-number ] [ verbose ]
When you execute the install commit command, the system refreshes the main startup software image set to use the currently active software images as the main startup software images.
The boot-loader file command can also change the main startup software image set.
For more information about main and backup startup software images, see Fundamental Configuration Guide.
# Display the main startup software images.
<Sysname> display install committed
Committed packages on slot 1:
flash:/feature.bin
# Display detailed information about main startup software images.
<Sysname> display install committed verbose
[Package]
Vendor: H3C
Product: xxxx
Service name: boot
[Component]
Component: boot
[Package]
Vendor: H3C
Product: xxxx
[Component]
Component: system
flash:/feature.bin
[Package]
Vendor: H3C
Product: xxxx
Service name: test
[Component]
Component: test
· boot-loader file
· display install backup
· install commit
display install inactive
Use display install inactive to display inactive software images.
In standalone mode:
display install inactive [ slot slot-number ] [ verbose ]
In IRF mode:
display install inactive [ chassis chassis-number slot slot-number ] [ verbose ]
This command searches the root directories of the storage media for inactive images and displays information about the inactive images.
# Display brief information about inactive software images in the root directory of each storage medium.
<Sysname> display install inactive
Inactive packages on slot 1:
flash:/feature.bin
# Display detailed information about inactive software images in the root directory of each storage medium.
<Sysname> display install inactive verbose
flash:/feature.bin
[Package]
Vendor: H3C
Product: XXXX
Service name: test
[Component]
Component: test
install deactivate
display install ipe-info
Use display install ipe-info to display the software images included in an .ipe file.
display install ipe-info ipe-filename
ipe-filename: Specifies the name of an .ipe file in the root directory of a storage medium. It must be a case-insensitive string of up to 63 characters that uses one of the following formats:
· storage-medium:/base-filename.ipe on the active MPU (in standalone mode) or global active MPU (in IRF mode).
· slotn#storage-medium:/base-filename.ipe on the standby MPU, for example, slot1#flash:/a.ipe. (In standalone mode.)
· chassismslotn#storage-medium:/base-filename.ipe on a standby MPU, for example, chassis1slot1#flash:/a.ipe. (In IRF mode.)
An .ipe file contains one or more software images. You can use the software images for a software upgrade.
# Display information about the .ipe file flash:/test.ipe.
<Sysname> display install ipe-info flash:/test.ipe
Verifying the file flash:/test.ipe on the device.....Done.
H3C Device images in IPE:
Images in IPE:
boot.bin
system.bin
display install package
display install job
Use display install job to display the ongoing ISSU activate, deactivate, or rollback operation.
display install job
# (In standalone mode.) Display the ongoing ISSU activate, deactivate, or rollback operation.
<Sysname> display install job
JobID:5
Action:install activate flash:/ssh-feature.bin on slot 1
The output shows that the device is executing the install activate flash:/ssh-feature.bin slot 1 command.
# (In IRF mode.) Display ongoing ISSU activate, deactivate, and rollback operations.
JobID:5
Action:install activate flash:/ssh-feature.bin on chassis 1 slot 1
The output shows that the device is executing the install activate flash:/ssh-feature.bin chassis 1 slot 1 command.
display install log
Use display install log to display ISSU logs.
display install log [ log-id ] [ verbose ]
log-id: Specifies a log by its ID. If you do not specify this argument, all software upgrade-related logs are displayed.
verbose: Displays detailed ISSU log information. If you do not specify this keyword, the command displays brief ISSU log information.
The device tracks every ISSU operation by generating a log for it, whether the operation is successful or not. A log is uniquely identified by an ID.
The device supports up to 50 ISSU logs. When the number of logs reaches this limit, the oldest log will be replaced by a newly generated log.
# Display all ISSU logs.
<Sysname> display install log
Install job 1 started by user root at 04/28/2001 08:39:29.
Job 1 completed successfully at 04/28/2001 08:39:30.
Install activate flash:/ssh.bin on slot 1
Install job 2 started by user root at 04/28/2001 08:40:29.
Job 2 completed successfully at 04/28/2001 08:40:29.
Install activate flash:/route.bin on slot 1
Job 2 completed successfully at 04/28/2001 08:40:30.
# Displays detailed information about ISSU log 1.
<Sysname> display install log 1 verbose
Job 1 completed successfully at 04/28/2001 08:39:29.
Detail of activating packages on slot 1.
Get upgrade policy successfully.
Uncompress package to system successfully.
Remove files from system successfully.
reset install log-history oldest
Use display install package to display software image file information.
display install package { filename | all } [ verbose ]
filename: Specifies the name of a software image file in the root directory of a storage medium. It must be a case-insensitive string of up to 63 characters that uses one of the following formats:
· storage-medium:/base-filename.bin on the active MPU (in standalone mode) or global active MPU (in IRF mode).
· slotn#storage-medium:/base-filename.bin on the standby MPU, for example, slot1#flash:/a.bin. (In standalone mode.)
· chassismslotn#storage-medium:/base-filename.bin on a standby MPU, for example, chassis1slot1#flash:/a.bin. (In IRF mode.)
all: Specifies all software image files in the root directories of the active MPU's storage media. (In standalone mode.)
all: Specifies all software image files in the root directories of the storage media on the global active MPU. (In IRF mode.)
verbose: Displays detailed information. If you do not specify this keyword, the command displays only basic software image information.
# Display information about software image file system.bin.
<Sysname> display install package flash:/system.bin
flash:/system.bin
[Package]
Vendor: H3C
Product: xxxx
# Display detailed information about software image file system.bin.
<Sysname> display install package flash:/system.bin verbose
flash:/system.bin
[Package]
Vendor: H3C
Product: xxxx
[Component]
Component: system
display install rollback
Use display install rollback to display rollback point information.
display install rollback [ point-id ]
point-id: Specifies a rollback point ID.
You can use the display install rollback command to view available rollback points.
Using issu series commands for an ISSU clears all rollback points created by an install command.
# Display all rollback points.
<Sysname> display install rollback
Install rollback information 1 on slot 1:
Updating from flash:/route-1.bin
to flash:/route-2.bin.
Install rollback information 2 on slot 1:
Deactivating flash:/route-2.bin
The output shows that the device has two rollback points.
· At rollback point 1, flash:/route-1.bin was upgraded to flash:/route-2.bin.
· At rollback point 2, flash:/route-2.bin was deactivated.
· install rollback
· reset install rollback oldest
display install which
Use display install which to display all software image files that include a specific component or file.
In standalone mode:
display install which { component name | file filename } [ slot slot-number ]
In IRF mode:
display install which { component name | file filename } [ chassis chassis-number slot slot-number ]
component name: Specifies a component name.
file filename: Specifies a file name in the basename.extension format without storage medium or directory information. The file name must be a case-insensitive string of up to 63 characters.
This command only supports full match for file names. To get package information for a file or component, you must enter the complete form of the component or file name.
A component is a collection of features related to each other. The features of a component are installed or uninstalled at the same time.
When the system notifies you of a component or file error, use this command to display all software image files that include the component or file on certain storage media. This helps you determine whether a software upgrade is required.
# Display all software image files that include file sshc.cli.
<Sysname> display install which file sshc.cli
File sshc.cli is in following packages on slot 1:
Verifying the file flash:/system.bin on slot 1...Done.
Verifying the file flash:/boot.bin on slot 1...Done.
flash:/system.bin
[Package]
Vendor: xxx
Product: xxxx
Service name: ssh
display issu rollback-timer
Use display issu rollback-timer to display automatic-rollback timer information.
Change to the automatic-rollback interval does not take effect on the ongoing ISSU process. The current remaining rollback time might be greater than the configured automatic-rollback interval.
# Display automatic-rollback timer information after the issu run switchover command is executed.
<Sysname> display issu rollback-timer
Rollback timer: Working
Rollback interval: 45 minutes
Rollback time remaining : 40 minutes
# Display automatic-rollback timer information after the issu accept command is executed.
Rollback timer: Not working
Rollback interval: 30 minutes
# Display automatic-rollback timer information when no ISSU process is taking place.
issu rollback-timer
display issu state
Use display issu state to display ISSU status information.
display issu state
During an ISSU that uses issu commands, you can use this command to verify the ISSU status and determine what to do next.
This command does not apply to an ISSU that uses install commands, because the ISSU state machine is not involved.
# (On a standalone device or single-chassis IRF fabric.) Display ISSU status information when no upgrade is in process.
<Sysname> display issu state
ISSU state: Init
Compatibility: Unknown
Work state: Normal
Upgrade method: Card by card
Upgraded slot: None
Current upgrading slot: None
Current version list:
boot: 7.1.041, Demo 2402
system: 7.1.041, Demo 2402
ssh: 7.1.041, Demo 2402
Current software images:
flash:/boot.bin
flash:/system.bin
flash:/ssh.bin
# (In standalone mode.) Display ISSU status information while the issu load command is being executed.
ISSU state: Loading
Compatibility: Incompatible
Work state: Normal
Upgraded slot: None
slot 1
Previous version list:
Previous software images:
flash:/boot.bin
flash:/system.bin
flash:/ssh.bin
Upgrade version list:
boot: 7.1.041, Demo 2403
system: 7.1.041, Demo 2403
ssh: 7.1.041, Demo 2403
Upgrade software images:
flash:/boot02.bin
flash:/system04.bin
flash:/ssh04.bin
# (On a single-chassis IRF fabric.) Display ISSU status information when the issu load command is being executed.
ISSU state: Loading
Work state: Normal
Upgraded slot: None
chassis 1 slot 1
flash:/boot.bin
flash:/system.bin
flash:/ssh.bin
flash:/boot02.bin
flash:/system04.bin
flash:/ssh04.bin
# (On a single-chassis IRF fabric.) Display ISSU status information on the global active MPU after the issu load command is completed.
ISSU state: Loaded
Compatibility: Compatible
Work state: Normal
Upgraded slot:
chassis 1 slot 1
flash:/boot.bin
flash:/system.bin
flash:/ssh.bin
ssh: 7.1.041, Demo 2403.
flash:/system02.bin
flash:/ssh02.bin
# (On a multichassis IRF fabric.) Display ISSU status information on the original master after the issu load command is completed.
ISSU state: Loaded
Work state: Independent active
Upgrade method: Chassis by chassis
Upgraded chassis:
chassis 2
Current upgrading chassis: None
flash:/boot.bin
flash:/system.bin
flash:/ssh.bin
flash:/system04.bin
flash:/ssh04.bin
ISSU state |
ISSU status: · Init—The ISSU process has not started or has finished. · Loading—The system is executing the issu load command. · Loaded—The issu load command is completed. · Switching—The system is executing the issu run switchover command. · Switchover—The issu run switchover command is completed. · Accepted—The issu accept command is completed. · Committing—The system is executing the issu commit command. · Rollbacking—A rollback is in process. · Unknown—An upgrade is in process. This value might appear when you execute the command on an original standby MPU. |
Compatibility |
Version compatibility: · Compatible. · Incompatible. · Unknown—No upgrade is in process. |
Work state |
Operating state of the device: · Normal—The device is operating correctly. · Independent active—When you perform an ISSU for an incompatible version, the standby MPU that is upgraded first enters this mode. In this mode, the two MPUs of the device are running different software versions. |
Upgrade method |
Upgrade mode: · Card by card—MPUs are upgraded one at a time. · Chassis by chassis—One or more subordinate members are upgraded first, and then the original master and the remaining subordinate members are upgraded. This mode is available only for a multichassis IRF fabric. |
Upgraded slot |
Upgraded cards. During a rollback, the value of this field is Unknown. (In standalone mode.) |
Current upgrading slot |
Cards that are being upgraded. During a rollback, the value of this field is Unknown. (In standalone mode.) |
Upgraded chassis |
Upgraded members. During a rollback, the value of this field is Unknown. (In IRF mode.) |
Current upgrading chassis |
Members that are being upgraded. During a rollback, the value of this field is Unknown. (In IRF mode.) |
Previous version list |
Software versions running on the device before the ISSU. If you execute this command on an original standby MPU during an ISSU for an incompatible version, the value of this field is Unknown. |
Previous software images |
Software images running on the device before the ISSU. If you execute this command on an original standby MPU during an ISSU for an incompatible version, the value of this field is Unknown. |
Upgrade version list |
Software versions to upgrade to. If you execute this command on an original standby MPU during an ISSU for an incompatible version, the value of this field is Unknown. |
Upgrade software images |
Software images used for the upgrade. If you execute this command on an original standby MPU during an ISSU for an incompatible version, the value of this field is Unknown. |
· issu accept
· issu commit
· issu load
· issu rollback
· issu run switchover
display version comp-matrix
Use display version comp-matrix to display version compatibility information.
display version comp-matrix file { boot filename | system filename | feature filename&<1-30> } *
display version comp-matrix file ipe ipe-filename
boot: Specifies a boot image file.
system: Specifies a system image file.
feature: Specifies feature image files. You can specify a space-separated list of up to 30 feature image files.
filename: Specifies the name of a software image file on the active MPU (in standalone mode) or global active MPU (in IRF mode), in the format of storage-medium:/base-filename.bin. It must be a case-insensitive string of up to 63 characters and cannot contain chassis or slot information. The file must be saved in the root directory.
ipe-filename: Specifies the name of an .ipe file on the active MPU (in standalone mode) or global active MPU (in IRF mode), in the format of storage-medium:/base-filename.ipe. It must be a case-insensitive string of up to 63 characters and cannot contain chassis or slot information. The file must be saved in the root directory.
If you do not specify any image files, the command displays compatibility information for the running software images.
If you specify image files, the command displays compatibility information for the specified images. The command also displays the recommended ISSU methods for upgrading the running images to the specified images.
# Display compatibility information for the running images.
<Sysname> display version comp-matrix
Boot image: flash:/boot-a7122.bin
Version:
7.1.031
System image: flash:/system-a7122.bin
Version:
V700R003B41D001
Version compatibility list:
V700R003B41D001
Version dependency boot list:
7.1.031
Feature image: flash:/cmw710-cfa-a7124.bin
Version:
V700R003B41D002
V700R003B41D001
Version dependency system list:
V700R003B41D001
V700R003B41D002
# Display compatibility information for flash:/boot-e2205.bin, flash:/system-e2205.bin, and flash:/dhcp-e2205.re.bin, as well as the recommended ISSU method. (In this example, the specified versions are incompatible with the running images.)
<Sysname> display version comp-matrix file boot flash:/boot-e2205.bin system flash:/system-e2205.bin feature flash:/dhcp-e2205.re.bin
Verifying the file flash:/dhcp-e2205.re.bin on slot 0...Done.
Verifying the file flash:/boot-e2205.bin on slot 0...Done.
Verifying the file flash:/system-e2205.bin on slot 0.....Done.
Boot image: flash:/boot-e2205.bin
Version:
7.1.035
System image: flash:/system-e2205.bin
Version:
V700R003B02D002
V700R003B02D002
7.1.035
Feature image: flash:/dhcp-e2205.re.bin
Version:
V700R003B02D002
V700R003B02D002
V700R003B02D002
V700R003B02D004
Incompatible upgrade.
# (In standalone mode.) Display compatibility information for cmw710-cfa-a7125.bin and the recommended ISSU methods. (In this example, the specified version is compatible with the running version.)
<Sysname> display version comp-matrix file feature flash:/cmw710-cfa-a7125.bin
Verifying the file flash:/cmw710-cfa-a7125.bin on slot 0.....Done.
Feature image: flash:/cmw710-cfa-a7125.bin
Version:
V700R003B31D002
V700R003B31D001
V700R003B31D002
V700R003B31D001
V700R003B31D002
Slot Upgrade Way
0 Service Upgrade
1 Service Upgrade
1.1 Service Upgrade
4 Service Upgrade
Influenced service according to following table on slot 0:
CFA
Influenced service according to following table on slot 4:
CFA
Influenced service according to following table on slot 1:
CFA
Influenced service according to following table on slot 1.1:
CFA
# (In IRF mode.) Display compatibility information for cmw710-cfa-a7122.bin and the recommended ISSU methods. (In this example, the specified version is compatible with the running version.)
<Sysname> display version comp-matrix file feature flash:/cmw710-cfa-a7122.bin
Feature image: flash:/cmw710-cfa-a7122.bin
Version:
V700R003B41D002
V700R003B41D001
V700R003B41D002
V700R003B41D001
V700R003B41D002
Chassis Slot Upgrade Way
1 0 Service Upgrade
1 0.1 Service Upgrade
1 7 Service Upgrade
1 9 Service Upgrade
2 0 Service Upgrade
2 0.1 Service Upgrade
2 1 Service Upgrade
2 6 Service Upgrade
Influenced service according to following table on chassis 1 slot 0:
CFA
Influenced service according to following table on chassis 1 slot 7:
CFA
Influenced service according to following table on chassis 1 slot 9:
CFA
Influenced service according to following table on chassis 1 slot 0.1:
CFA
Influenced service according to following table on chassis 2 slot 0:
CFA
Influenced service according to following table on chassis 2 slot 1:
CFA
Influenced service according to following table on chassis 2 slot 6:
CFA
Influenced service according to following table on chassis 2 slot 0.1:
CFA
Verifying the file |
The system was verifying the validity of the file. |
Version compatibility list |
· When displayed under a system image, this field shows all system image versions that are compatible with the system image. · When displayed under a feature image, this field shows all feature image versions that are compatible with the feature image. |
Version dependency boot list |
Boot image versions that support the system image. To install the system image, you must install one of the boot image versions that is in the list. |
Version dependency system list |
System image versions that support the feature image. To install the feature image, you must install one of the system image versions that is in the list. |
Influenced service according to following table |
Services that will be affected by the upgrade. This field is displayed only for compatible versions. |
Incompatible upgrade |
You are upgrading the software to an incompatible version. |
Chassis |
Member ID of the device in the IRF fabric. This field is displayed only for compatible versions in IRF mode. |
Slot |
Slot number of the card. This field is displayed only for compatible versions. |
Upgrade Way |
ISSU methods: · Service Upgrade—Service-level incremental upgrade. · File Upgrade—File-level incremental upgrade. · ISSU Reboot—Reboots CPUs to complete the upgrade. · Reboot—Reboots the entire device to complete the upgrade. · Sequence Reboot—Upgrades the switching fabric modules one by one. This method applies only when the device has switching fabric modules that support this upgrade method. This field is displayed only for compatible versions. For more information about ISSU methods, see Fundamentals Configuration Guide. |
issu load
install abort
Use install abort to abort an ISSU operation.
install abort
After you issue the install activate, install add, install commit, install deactivate, install remove, or install rollback to command, the system creates a software image management job. To monitor and manage software image management jobs, the system assigns each job a unique job ID. Each job ID represents a single command.
You can abort only a software image activate or deactivate operation that is being executed.
To obtain the ID of a job, use the display install job command.
# Abort a software image operation.
<Sysname> install abort
display install job
install activate
Use install activate to activate software images, or identify the recommended ISSU method and the possible impact on the device.
In standalone mode:
install activate { boot filename | system filename | feature filename&<1-30> } * slot slot-number [ test ]
install activate patch filename slot slot-number
In IRF mode:
install activate { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number slot slot-number [ test ]
install activate patch filename chassis chassis-number slot slot-number
boot: Specifies a boot image file. For more information about software images, see Fundamental Configuration Guide.
patch: Specifies a patch image file.
filename: Specifies the file path of a .bin software image file, a case-insensitive string. The file must be stored in the root directory of a storage medium in the system. If the storage medium is partitioned, the file must be stored in the root directory of the first partition. The maximum length is 63 characters for the storage-medium:/base-filename.bin segments of the file path. This length limit does not include the IRF member ID or slot number segment in front of the storage medium segment. For more information about specifying a file path, see "Managing the file system."
slot slot-number: Specifies a card by its slot number. ( In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member. (In IRF mode.)
test: Only checks for the ISSU method to be used for the upgrade. If you do not specify this keyword, the command activates the specified software images.
Before you use this command to activate a software image, read the release notes to identify the licensing requirements for the image. If the image requires a license, make sure the device has a valid license installed for the image.
An image runs in memory immediately after it is activated. For an activated image to run after a reboot, you must commit the software change by using the install commit command.
In standalone mode, follow these guidelines:
· If you specify the active MPU, the command takes effect on the active MPU and all LPUs.
· If you specify the standby MPU, the command takes effect only on the standby MPU.
· If the specified files are not saved on the MPU to be upgraded, the command copies the images to the MPU automatically.
In IRF mode, follow these guidelines:
· If you specify the global active MPU, the command takes effect on the global active MPU and all LPUs.
· If you specify a standby MPU, the command takes effect on the standby MPU.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install activate command on the subordinate device. To check the synchronization progress, use the display device and display mdc commands. The synchronization is completed when the following requirements are met:
· All cards of the subordinate device are in normal state.
· All MDCs are in active state.
# (In standalone mode.) Identify the ISSU method for feature upgrade with ssh2.bin on the standby MPU (in slot 1) and the upgrade impact.
<Sysname> install activate feature flash:/ssh2.bin slot 1 test
Copying file flash:/ssh2.bin to slot1#flash:/ssh2.bin......Done.
Verifying the file flash:/ssh2.bin on slot 1.....Done.
flash:/ssh2.bin
Running Version New Version
Beta 1330 Beta 1331
Slot Upgrade Way
1 Service Upgrade
Influenced service according to following table:
flash:/ssh2.bin
SSH IFMGR CFA LAGG
The output shows that an incremental upgrade is recommended. The SSH, IFMGR, CFA, and LAGG modules will be rebooted during the upgrade.
# (In IRF mode.) Identify the ISSU method for feature upgrade with ssh2.bin on the standby MPU in slot 1 of IRF member 1 and the upgrade impact.
<Sysname>install activate feature flash:/ssh2.bin chassis 1 slot 1 test
Copying file flash:/ssh2.bin to chassis1#slot1#flash:/ssh2.bin......Done.
Verifying the file flash:/ssh2.bin on chassis 1 slot 1.....Done.
flash:/ssh2.bin
Beta 1330 Beta 1331
1 1 Service Upgrade
flash:/ssh2.bin
SSH IFMGR CFA LAGG
# (In standalone mode.) Activate the system image in file system.bin and feature images in file feature.bin on the standby MPU (in slot 1).
<Sysname> install activate system flash:/system.bin feature flash:/feature.bin slot 1
Copying file flash:/system.bin to slot1#flash:/system.bin......Done.
Verifying the file flash:/system.bin on slot 1.....Done.
Copying file flash:/feature.bin to slot1#flash:/feature.bin......Done.
Verifying the file flash:/feature.bin on slot 1.....Done.
flash:/system.bin
Beta 1330 Beta 1331
flash:/feature.bin
None Beta 1330
Slot Upgrade Way
1 Service Upgrade
This operation maybe take several minutes, please wait........................................Done.
# (In IRF mode.) Activate the feature images in file feature.bin on the global standby MPU in slot 0 of IRF member 1.
<Sysname> install activate feature flash:/feature.bin chassis 1 slot 1
Copying file flash:/feature.bin to chassis1#slot1#flash:/feature.bin......Done.
Verifying the file flash:/feature.bin on chassis 1 slot 1.....Done.
flash:/route-feature.bin
None Beta 1330
1 1 Service Upgrade
This operation maybe take several minutes, please wait...............................................Done.
The system is automatically copying files for the upgrade. This message is displayed only when you activate an image for a standby MPU. |
Upgrade summary according to following table |
Upgrade summary. |
Running Version |
Version number of the running software. |
New Version |
Version number of the new software. |
Chassis |
Member ID of the device in the IRF fabric. (In IRF mode.) |
Slot |
Number of the slot where the card resides. |
Upgrade Way |
ISSU methods: · Service Upgrade—Service-level incremental upgrade. · File Upgrade—File-level incremental upgrade. The upgrade involves only hidden program files and does not affect the operation of the system or services. · ISSU Reboot—Reboots CPUs to complete the upgrade. · Reboot—Reboots the entire device to complete the upgrade. · Sequence Reboot—Upgrades the switching fabric modules one by one. This method applies only when the device has switching fabric modules that support this upgrade method. This field is displayed only for an upgrade to a compatible version. For more information about ISSU methods, see Fundamentals Configuration Guide. |
Services influenced by the upgrade. |
· display install active
· install commit
· install deactivate
install add
Use install add to decompress an .ipe file.
install add ipe-filename medium-name:
ipe-filename: Specifies the file path of an .ipe image package file, a case-insensitive string. The file must be stored in the root directory of a storage medium in the system. If the storage medium is partitioned, the file must be stored in the root directory of the first partition. The maximum length is 63 characters for the storage-medium:/base-filename.ipe segments of the file path. This length limit does not include the IRF member ID or slot number segment in front of the storage medium segment.
medium-name: Specifies the name of the destination storage medium for the software images.
· To specify a storage medium on the standby MPU in standalone mode, use the format slotslot-number#storage-medium.
· To specify a storage medium on a global standby MPU in IRF mode, use the format chassischassis-number#slotslot-number#storage-medium.
To use install commands for upgrade, you must use .bin image files. If the upgrade file is an .ipe file, use this command to decompress the .ipe file before you start the upgrade.
To identify software images that are included in an .ipe file, use the display install ipe-info command.
# Decompress all.ipe to the flash memory.
<Sysname> install add flash:/route.ipe flash:
Verifying the file flash:/route.ipe on slot 0......Done.
Decompressing file boot.bin to flash:/boot.bin.......................Done.
Decompressing file system.bin to flash:/system.bin.................................Done.
install commit
Use install commit to confirm the software changes.
install commit
Before you use this command, view the release notes to determine whether the images require licenses. If the images require a license, make sure the device has valid licenses installed for the images.
During a reboot or ISSU reboot upgrade, the install activate command changes both the running software and the main startup software image set. You do not need to use the install commit command to confirm the software changes.
During an incremental upgrade, the install activate command changes only the running software. For the changes to take effect after a reboot, you must use the install commit command to confirm the software changes.
The install deactivate and install rollback commands change only the running software. To keep the changes after a reboot, you must use the install commit command to confirm the software changes.
Both the install commit and boot-loader file commands change main startup software images. To change backup startup images or add inactive images as main startup images, however, you must use the boot-loader file command.
For more information about main and backup startup software images and image sets, see Fundamental Configuration Guide.
# Confirm the software changes.
<Sysname> install commit
This operation will take several minutes, please wait...........................Done.
· install activate
· install rollback
install deactivate
Use install deactivate to deactivate feature images and patch images.
In standalone mode:
install deactivate feature filename&<1-30> slot slot-number
install deactivate patch filename slot slot-number
In IRF mode:
install deactivate feature filename&<1-30> chassis chassis-number slot slot-number
install deactivate patch filename chassis chassis-number slot slot-number
filename: Specifies the name of a software image file on the active MPU (in standalone mode) or global active MPU (in IRF mode). Use the format storage-medium:/base-filename.bin. It can be a case-insensitive string of up to 63 characters and cannot contain chassis or slot information. The file must be stored in the root directory.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member. ( In IRF mode.)
You can deactivate only feature and patch images that are active.
To prevent deactivated images from running after a reboot, you must commit the software changes by using the install commit command.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the install deactivate command on the subordinate device. To check the synchronization progress, use the display device and display mdc commands. The synchronization is completed when the following requirements are met:
# (In standalone mode.) Deactivate the patch images in route-patch.bin on slot 0.
<Sysname> install deactivate patch flash:/route-patch.bin slot 0
# (In IRF mode.) Deactivate the patch images in route-patch.bin on slot 0 of IRF member 1.
<Sysname> install deactivate feature flash:/route-feature.bin chassis 1 slot 0
· display install inactive
install remove
Use install remove to remove inactive software images.
In standalone mode:
install remove [ slot slot-number ] { filename | inactive }
In IRF mode:
install remove [ chassis chassis-number slot slot-number ] { filename | inactive }
filename: Specifies the name of a software image file on the active MPU (in standalone mode) or global active MPU (in IRF mode). Use the format storage-medium:/base-filename.bin. It must be a case-insensitive string of up to 63 characters and cannot contain chassis or slot information. The file must be saved in the root directory.
inactive: Removes all inactive software image files in the root directories of the specified storage media.
This command deletes only inactive software image files saved in the root directories of the specified storage media.
Removing a software image deletes the image file from the device permanently. You cannot use the install rollback to command to revert the operation, or use the install abort command to abort the operation.
# Remove inactive software image file flash:/ssh-feature.bin.
<Sysname> install remove flash:/ssh-feature.bin
install rollback to
Use install rollback to to roll back the software to an earlier rollback point.
install rollback to { point-id | original }
point-id: Specifies a rollback point ID. This option is supported only when there are two or more rollback points. To identify available rollback points, use the display install rollback command.
original: Rolls back to the software images that were running before the ISSU.
The system creates a rollback point for each service or file upgrade that is performed through an activate or deactivate operation. The rollback points are retained until any of the following events occur:
· An ISSU reboot or reboot upgrade is performed.
· The install commit command is executed.
After an ISSU reboot or reboot upgrade is performed, you can roll back the running software images only to the status before any activate or deactivate operations were performed.
After a commit operation is performed, you cannot perform a rollback.
For a rollback to take effect after a reboot, you must perform a commit operation to update the main startup software image list.
The device supports a maximum of 50 rollback points. The earliest rollback point is removed if this limit has been reached when a rollback point is created.
Patch images do not support rollback.
# Roll back the software to rollback point 1.
<Sysname>install rollback to 1
# Roll back the software to the original versions and observe the change made by the rollback.
flash:/ssh-feature-a0201.bin
Updating from no package
to flash:/ssh-feature-a0201.bin.
The output shows that currently three images are active but only two of them are confirmed. Image flash:/ssh-feature-a0201.bin is not confirmed yet.
<Sysname> install rollback to original
The output shows the SSH feature has been rolled back to the original version. Image flash:/ssh-feature-a0201.bin has been removed.
install verify
Use install verify to verify the software change confirmation status and software image integrity and consistency.
install verify
If some software images are not integral or some activated/deactivated software images are not confirmed, a switchover might not occur as expected, and the MPUs might run different versions of software images after a reboot or even cannot reboot correctly. (In standalone mode.)
If some software images are not integral or some activated/deactivated software images are not confirmed, a switchover might not occur as expected, and the MPUs might run different versions of software images after a reboot or even cannot reboot correctly. (In IRF mode.)
To solve the problem, perform one of the following tasks:
· Download and install the software images again to ensure software integrity.
· Use the install activate, install deactivate, and install commit commands as appropriate to guarantee software image consistency.
# (In standalone mode.) Verify the software change confirmation status and software image integrity and consistency.
<Sysname> install verify
Active packages on slot 1 are the reference packages.
Packages will be compared with the reference packages.
Verifying packages on slot 0:
Start to check active package completeness.
Verifying the file flash:/boot-a0101.bin on slot 0.....................Done.
flash:/boot-a0101.bin verification successful.
Verifying the file flash:/system-a0101.bin on slot 0.....................Done.
flash:/system-a0101.bin verification successful.
Start to check active package consistency.
Active packages are consistent with committed packages on their own board.
Active packages are consistent with the reference packages.
Verifying packages on slot 1:
Verifying the file flash:/boot-a0101.bin on slot 1.....................Done.
Verifying the file flash:/system-a0101.bin on slot 1.....................Done.
Verification is done.
# (In IRF mode.) Verify the software change confirmation status and software image integrity and consistency.
Verifying packages on chassis 1 slot 0:
Verifying the file flash:/boot-a0101.bin on chassis 1 slot 0.............Done.
Verifying the file flash:/system-a0101.bin on chassis 1 slot 0.........Done.
Verifying packages on chassis 1 slot 1:
Verifying the file flash:/boot-a0101.bin on chassis 1 slot 1.............Done.
Verifying the file flash:/system-a0101.bin on chassis 1 slot 1.........Done.
issu accept
Use issu accept to accept the upgrade to a compatible version and delete the automatic-rollback timer.
issu accept
The system cannot perform automatic rollback for the ISSU process after you execute this command. However, you can use the issu rollback command to perform a manual rollback.
You can execute the issu commit command to finish the ISSU process without executing this command.
The issu accept command does not apply to the ISSU to an incompatible version. The system will display an error message if you execute this command during this type of ISSU.
# Accept the upgrade to a compatible version.
<Sysname> issu accept
· issu load
issu commit
Use issu commit to complete an ISSU upgrade to a compatible version.
In standalone mode:
issu commit slot slot-number
In IRF mode (single-chassis):
issu commit chassis chassis-number slot slot-number
In IRF mode (multichassis):
slot slot-number: Specifies the slot number of the original active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies the member ID and slot number of the original active MPU. (Single-chassis IRF fabric.)
chassis chassis-number: Specifies the member ID of the original master or a subordinate member that has not been upgraded. (Multichassis IRF fabric.)
On a standalone device or a single-member IRF fabric, this command ends the ISSU process. When this command is completed, the ISSU status changes to Init, and the ISSU process cannot be rolled back.
On a multichassis IRF fabric, use this command to upgrade subordinate members (including the original master) in turn. You must wait for the upgraded subordinate member to start up again and join the IRF fabric before upgrading another subordinate member. After all members are upgraded, the ISSU status changes to Init. The ISSU process ends and cannot be rolled back.
At reboot, a subordinate device automatically synchronizes the master device's configuration and status data. You must wait for the synchronization to complete before using the issu commit command on the subordinate device. To check the synchronization progress, use the display device and display mdc commands. The synchronization is completed when the following requirements are met:
# (In standalone mode.) Upgrade the original active MPU to a compatible version. (In this example, the device has two MPUs.)
<Sysname> issu commit slot 0
flash:/feature.bin
Alpha 7122 Alpha 7123
Slot Upgrade Way
0 Service Upgrade
# (In standalone mode.) Finish the upgrade of the MPU to a compatible version. (In this example, the device only one MPU.)
# (In IRF mode.) Upgrade the members that have not been upgraded to a compatible version. (In this example, the member ID of the original master is 3. Members with the IDs 1 and 4 are not upgraded either.)
<Sysname> issu commit chassis 3
Copying file flash:/feature.bin to chassis3#slot1#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 3 slot 1..............Done.
flash:/feature.bin
3 0 Service Upgrade
3 1 Service Upgrade
3 2 Service Upgrade
3 3 Service Upgrade
3 4 Service Upgrade
<Sysname> issu commit chassis 4
Copying file flash:/feature.bin to chassis4#slot0#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 4 slot 0..............Done.
Copying file flash:/feature.bin to chassis4#slot1#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 4 slot 1..............Done.
flash:/feature.bin
4 0 Service Upgrade
4 1 Service Upgrade
4 2 Service Upgrade
4 3 Service Upgrade
4 4 Service Upgrade
<Sysname> issu commit chassis 1
Copying file flash:/feature.bin to chassis1#slot0#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 1 slot 0..............Done.
Copying file flash:/feature.bin to chassis1#slot1#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 1 slot 1..............Done.
flash:/feature.bin
1 0 Service Upgrade
1 1 Service Upgrade
1 2 Service Upgrade
1 3 Service Upgrade
1 4 Service Upgrade
# (In IRF mode.) Upgrade the original active MPU to a compatible version. (In this example, the IRF fabric has a single member and the member has two MPUs.)
<Sysname> issu commit chassis 1 slot 0
flash:/feature.bin
1 0 Service Upgrade
# (In IRF mode.) Finish the upgrade to a compatible version. (In this example, the IRF fabric has a single member and the member has only one MPU.)
For information about the command output, see Table 3.
· issu accept
· issu load
issu load
On a standalone device, use issu load to load the upgrade images from the active MPU to the standby MPU as the main startup software images.
On an IRF fabric, use issu load to load the upgrade images from the global active MPU to standby MPUs as the main startup software images.
In standalone mode:
issu load file { boot filename | system filename | feature filename&<1-30> } * slot slot-number
issu load file ipe ipe-filename slot slot-number
issu load file { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number slot slot-number
issu load file ipe ipe-filename chassis chassis-number slot slot-number
issu load file { boot filename | system filename | feature filename&<1-30> } * chassis chassis-number&<1-3>
issu load file ipe ipe-filename chassis chassis-number&<1-3>
ipe-filename: Specifies the name of an .ipe file on the active MPU (in standalone mode) or global active MPU (in IRF mode). Use the format storage-medium:/base-filename.ipe. It must be a case-insensitive string of up to 63 characters and cannot contain chassis or slot information. The file must be saved in the root directory.
slot slot-number: Specifies the slot number of the standby MPU. If the device has only one MPU, enter the slot number of the MPU to upgrade the entire device. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies the member ID and slot number of the standby MPU. If the member has only one MPU, enter the member ID and slot number of the MPU to upgrade the entire fabric. (Single-chassis IRF fabric.)
chassis chassis-number: Specifies the member ID of a subordinate member. For a compatible upgrade, you can specify only one member ID. For an incompatible upgrade, you can specify a space-separated list of up to three member IDs. (Multichassis IRF fabric.)
You may upgrade all or some of the software images. If you are upgrading only some of the images, make sure the new images are compatible with the images that are not to be upgraded. The upgrade will fail if a conflict exists.
To ensure a successful upgrade, perform the following tasks before you execute this command:
1. Use the display device command to verify that all cards are not in Fault state.
2. Use the display mdc command to verify that all MDCs are in active state.
When you execute this command, the system automatically checks the version compatibility, and then upgrades the specified MPUs with the specified software images.
# (In standalone mode.) Upgrade the standby MPU with the feature image file flash:/feature.bin. (In this example, the image is compatible with the running images.)
<Sysname> issu load file feature flash:/feature.bin slot 1
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:Y
Verifying the file flash:/feature.bin on slot 0...Done.
Verifying the file flash:/feature.bin on slot 1...Done.
flash:/feature.bin
Slot Upgrade Way
1 Service Upgrade
# (In standalone mode.) Upgrade the standby MPU with the feature image file flash:/feature.bin. (In this example, the image is incompatible with the running images.)
flash:/feature.bin
Slot Upgrade Way
1 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
# (On a single-MPU standalone device.) Upgrade the MPU with the feature image file flash:/feature.bin. (In this example, the image is compatible with the running images.)
<Sysname>issu load file feature flash:/feature.bin slot 0
flash:/feature.bin
Slot Upgrade Way
0 Service Upgrade
2 Service Upgrade
3 Service Upgrade
4 Service Upgrade
# (On a single-MPU standalone device.) Upgrade the MPU with the feature image file flash:/feature.bin. (In this example, the image is incompatible with the running images.)
<Sysname> issu load file feature flash:/feature.bin slot 0
flash:/feature.bin
Slot Upgrade Way
0 Reboot
2 Reboot
3 Reboot
4 Reboot
# (In IRF mode.) Upgrade member device 2 (a subordinate member) with the feature image file flash:/feature.bin. (In this example, the image is compatible with the running images. The member ID of the master is 1.)
<Sysname> issu load file feature flash:/feature.bin chassis 2
Verifying the file flash:/feature.bin on chassis 1 slot 0...Done.
Copying file flash:/feature.bin to chassis2#slot0#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 2 slot 0...Done.
Copying file flash:/feature.bin to chassis2#slot1#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 2 slot 1...Done.
flash:/feature.bin
2 0 Service Upgrade
2 1 Service Upgrade
2 2 Service Upgrade
2 3 Service Upgrade
2 4 Service Upgrade
# (In IRF mode.) Upgrade member devices 3 and 4 (subordinate members) with the feature image file flash:/feature.bin. (In this example, the image is incompatible with the running images. The member ID of the master is 1.)
<Sysname>issu load file feature flash:/feature.bin chassis 3 4
Copying file flash:/feature.bin to chassis3#slot0#flash:/feature.bin...Done.
Verifying the file flash:/feature.bin on chassis 3 slot 0...Done.
Verifying the file flash:/feature.bin on chassis 3 slot 1...Done.
Verifying the file flash:/feature.bin on chassis 4 slot 0...Done.
Verifying the file flash:/feature.bin on chassis 4 slot 1...Done.
flash:/feature.bin
3 0 Reboot
3 1 Reboot
3 2 Reboot
3 3 Reboot
3 4 Reboot
4 0 Reboot
4 1 Reboot
4 2 Reboot
4 3 Reboot
4 4 Reboot
# (On a dual-MPU single-chassis IRF fabric.) Upgrade the global standby MPU on member device 1 with the feature image file flash:/feature.bin. (In this example, the image is compatible with the running images.)
<Sysname>issu load file feature flash:/feature.bin chassis 1 slot 1
Verifying the file flash:/feature.bin on chassis 1 slot 1...Done.
flash:/feature.bin
1 1 Service Upgrade
# (On a dual-MPU single-chassis IRF fabric.) Upgrade the global standby MPU on member device 1 with the feature image file flash:/feature.bin. (In this example, the image is incompatible with the running images.)
flash:/feature.bin
1 1 Reboot
# (On a single-MPU single-chassis IRF fabric.) Upgrade the MPU on member device 1 with the feature image file flash:/feature.bin. (In this example, the image is compatible with the running images.)
<Sysname>issu load file feature flash:/feature.bin chassis 1 slot 0
flash:/feature.bin
1 0 Service Upgrade
1 2 Service Upgrade
1 3 Service Upgrade
1 4 Service Upgrade
# (On a single-MPU single-chassis IRF fabric.) Upgrade the MPU on member device 1 with the feature image file flash:/feature.bin. (In this example, the image is incompatible with the running images.)
flash:/feature.bin
1 0 Reboot
1 2 Reboot
1 3 Reboot
1 4 Reboot
Table 5 Command output
Copying file A to B......Done. |
The system is automatically copying files for the upgrade. This message is displayed only when you activate a image for a standby MPU. |
Chassis |
Slot |
Slot number of the card. |
Upgrade Way |
ISSU method: · Service Upgrade—Service-level incremental upgrade. · File Upgrade—File-level incremental upgrade. · ISSU Reboot—Reboots CPUs to complete the upgrade. · Reboot—Reboots the entire device to complete the upgrade. · Sequence Reboot—Upgrades the switching fabric modules one by one. This method applies only when the device has switching fabric modules that support this upgrade method. This field is displayed only for compatible versions. For more information about ISSU methods, see Fundamentals Configuration Guide. |
issu rollback
Use issu rollback to cancel the ISSU and roll back to the original software versions.
issu rollback
The device supports automatic rollback and manual rollback. This command performs a manual rollback.
You can perform a manual rollback while an ISSU is in one of the following states:
· Loading.
· Loaded.
· Switching (during an upgrade to a compatible version).
· Switchover (during an upgrade to a compatible version).
· Accepted.
If you perform a manual rollback while the ISSU is in Loading state, the rollback might fail. Use the display version command to check the operation result.
When an ISSU to an incompatible version is in Switching state, you cannot perform a manual rollback.
When the ISSU is in Committing state, rollback is not supported.
For a multichassis IRF fabric, a rollback performed after you execute the issu run switchover command cancels only the upgrades. The master/subordinate switchover operation is not canceled.
If multiple cards have been upgraded, a rollback operation rolls back all upgraded cards to their original versions.
# Roll back to the original software versions.
<Sysname> issu rollback
This command will quit the ISSU process and roll back to the previous version. Continue? [Y/N]:y
· issu accept
· issu commit
· issu load
issu rollback-timer
Use issu rollback-timer to set the automatic-rollback timer.
Use undo issu rollback-timer to restore the default.
issu rollback-timer minutes
The automatic-rollback interval is 45 minutes.
minutes: Specifies the automatic-rollback interval in minutes, in the range of 0 to 120. Setting it to 0 disables automatic rollback.
Automatic software version rollback is only available on a dual-MPU device (in standalone mode), a multichassis IRF fabric, or a single-chassis dual-MPU IRF fabric during an ISSU to a compatible version.
When you execute the issu run switchover command in a scenario where automatic rollback is supported, the system starts the automatic-rollback timer. If you do not execute the issu accept or issu commit command before the timer expires, the system automatically rolls back to the original software versions.
# Set the automatic-rollback timer to 50 minutes.
[Sysname] issu rollback-timer 50
issu rollback
issu run switchover
Use issu run switchover on a standalone device or single-chassis IRF fabric to perform an active/standby switchover during an ISSU process.
Use issu run switchover on a multichassis IRF fabric to perform an active/standby switchover during an ISSU process.
issu run switchover
Use this command only if the system has a minimum of two MPUs.
In a compatible upgrade, the command upgrades the LPUs and switching fabric modules in addition to the MPUs.
In an incompatible upgrade, the command upgrades all cards except for the upgraded MPU or member device.
To ensure a successful upgrade, perform the following tasks before you execute this command in IRF mode:
# (On a dual-MPU standalone device.) Perform an active/standby switchover and upgrade the LPUs and switching fabric modules to a compatible version.
<Sysname> issu run switchover
flash:/feature.bin
Slot Switchover Way
0 Active standby process switchover
Slot Upgrade Way
2 Service Upgrade
3 Service Upgrade
4 Service Upgrade
# (On a dual-MPU standalone device.) Perform an active/standby switchover and upgrade the current active MPU and the LPUs and switching fabric modules to an incompatible version.
flash:/feature.bin
Slot Upgrade Way
0 Reboot
2 Reboot
3 Reboot
4 Reboot
# (On a multichassis IRF fabric.) Perform a master/subordinate switchover during an ISSU to a compatible version.
flash:/feature.bin
Chassis Slot Switchover Way
1 0 Active standby process switchover
# (On a multichassis IRF fabric.) Perform a master/subordinate switchover and upgrade members that have not been upgraded during an ISSU to an incompatible version. In this example, the master (with the ID 1) and the subordinate member with the ID 2 have not been upgraded.
flash:/feature.bin
1 0 Reboot
1 1 Reboot
1 2 Reboot
1 3 Reboot
1 4 Reboot
2 0 Reboot
2 1 Reboot
2 2 Reboot
2 3 Reboot
2 4 Reboot
# (On a dual-MPU single-chassis IRF fabric.) Perform a master/subordinate switchover and upgrade the LPUs and switching fabric modules during an ISSU to a compatible version.
flash:/feature.bin
1 2 Service Upgrade
1 3 Service Upgrade
1 4 Service Upgrade
# (On a dual-MPU single-chassis IRF fabric.) Perform a master/subordinate switchover during an ISSU to an incompatible version.
flash:/feature.bin
1 0 Reboot
1 2 Reboot
1 3 Reboot
1 4 Reboot
Table 6 Command output
The system is automatically copying files for the upgrade. This message is displayed during an ISSU to an incompatible version only when the switchover operation upgrades cards that are not upgraded yet. |
Switchover Way |
Switchover method: · Active standby process switchover—Switch from the active process to the standby process. · Active standby MPU switchover—Switch from the active MPU to the standby MPU. (In standalone mode.) · Global active standby MPU switchover—Switch from the global active MPU to a global standby MPU. (In IRF mode.) |
For information about other fields' descriptions, see Table 3.
issu load
Use reset install log-history oldest to clear ISSU logs.
reset install log-history oldest log-number
log-number: Specifies the number of ISSU log entries to be deleted.
This command clears the specified number of log entries, beginning with the oldest log.
# Clear the two oldest ISSU log entries.
<Sysname> reset install log-history oldest 2
display install log
Use reset install rollback oldest to clear ISSU rollback points.
reset install rollback oldest point-id
point-id: Specifies a rollback point by its ID.
This command clears the specified rollback point and all rollback points older than the specified rollback point.
# Clear rollback point 2 and all rollback points older than rollback point 2.
<Sysname> reset install rollback oldest 2
