- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-Emergency shell commands
- 10-Device management commands
- 11-Tcl commands
- 12-License management commands
- 13-Password recovery control command
- 14-Python commands
| 02-RBAC commands | 180.72 KB |
Content
description
Use description to configure a description for a user role.
Use undo description to delete the description of a user role.
A user role does not have a description.
User role view
text: Configures a user role description, a case-sensitive string of 1 to 128 characters.
# Configure the description as labVIP for the user role role1.
[Sysname] role name role1
[Sysname-role-role1] description labVIP
· display role
· role
display role
Use display role to display user role information.
display role [ name role-name ]
name role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. If you do not specify a user role name, the command displays information about all user roles, including the predefined user roles.
# Display information about the user role 123.
<Sysname> display role name 123
Description: new role
VLAN policy: deny
Permitted VLANs: 1 to 5, 7 to 8
Interface policy: deny
Permitted interfaces: GigabitEthernet3/0/1 to GigabitEthernet3/0/2, Vlan-interface1 to Vlan-interface20
VPN instance policy: deny
Permitted VPN instances: vpn, vpn1, vpn2
Rule Perm Type Scope Entity
1 permit RWX feature-group abc
2 deny -W- feature ldap
3 permit command system ; radius sc *
4 permit R-- xml-element -
R:Read W:Write X:Execute
# Display information about all user roles.
Role: network-admin
Description: Predefined network admin role has access to all commands on the device
VLAN policy: permit (default)
Interface policy: permit (default)
VPN instance policy: permit (default)
sys-1 permit command *
sys-2 permit RWX web-menu -
sys-3 permit RWX xml-element -
sys-4 deny command display security-logfile summary
sys-5 deny command system-view ; info-center securi
ty-logfile directory *
sys-6 deny command security-logfile save
Role: network-operator
Description: Predefined network operator role has access to all read commands on the device
sys-1 permit command display *
sys-2 permit command xml
sys-3 deny command display history-command all
sys-4 deny command display exception *
sys-5 deny command display cpu-usage configuration
sys-6 deny command display kernel exception *
sys-7 deny command display kernel deadloop *
sys-8 deny command display kernel starvation *
sys-9 deny command display kernel reboot *
sys-10 deny command display memory trace *
sys-11 deny command display kernel memory *
sys-12 permit command system-view ; local-user *
sys-13 permit command system-view ; switchto mdc *
sys-14 permit R-- web-menu -
sys-15 permit R-- xml-element -
sys-16 deny command display security-logfile summary
sys-17 deny command system-view ; info-center securi
sys-18 deny command security-logfile save
Role: mdc-admin
Description: Predefined MDC admin role has access to all commands within an MDC instance
sys-4 deny RWX feature mdc
sys-5 permit command display mdc *
sys-6 permit command switchback
sys-7 deny command display security-logfile summary
sys-8 deny command system-view ; info-center securi
sys-9 deny command security-logfile save
Role: mdc-operator
Description: Predefined MDC operator role has access to all read commands within an MDC instance
sys-13 permit command switchback
Role: level-0
Description: Predefined level-0 role
sys-1 permit command tracert *
sys-2 permit command telnet *
sys-3 permit command ping *
sys-4 permit command ssh2 *
sys-5 permit command super *
Role: level-1
Description: Predefined level-1 role
sys-5 permit command display *
sys-6 permit command super *
sys-7 deny command display history-command all
Role: level-2
Description: Predefined level-2 role
Role: level-3
Description: Predefined level-3 role
Role: level-4
Description: Predefined level-4 role
Role: level-5
Description: Predefined level-5 role
Role: level-6
Description: Predefined level-6 role
Role: level-7
Description: Predefined level-7 role
Role: level-8
Description: Predefined level-8 role
Role: level-9
Description: Predefined leve-9 role
sys-1 permit RWX feature -
sys-2 deny RWX feature device
sys-3 deny RWX feature filesystem
sys-4 permit command display *
sys-5 deny command display history-command all
Role: level-10
Description: Predefined level-10 role
Role: level-11
Description: Predefined level-11 role
Role: level-12
Description: Predefined level-12 role
Role: level-13
Description: Predefined level-13 role
Role: level-14
Description: Predefined level-14 role
Role: level-15
Description: Predefined level-15 role
Role: 123
VLAN policy: deny
Role: security-audit
Description: Predefined security audit role only has access to commands for th
e security log administrator
sys-1 deny command *
sys-2 permit command display security-logfile summary
sys-3 permit command system-view ; info-center securi
sys-4 permit command security-logfile save
sys-5 permit command cd *
sys-6 permit command copy *
sys-7 permit command delete *
sys-8 permit command dir *
sys-9 permit command mkdir *
sys-10 permit command more *
sys-11 permit command move *
sys-12 permit command rmdir *
sys-13 permit command pwd
sys-14 permit command rename *
sys-15 permit command undelete *
sys-16 permit command ftp *
sys-17 permit command sftp *
sys-18 permit command virtual-ftp-append
sys-19 permit command virtual-ftp-ascii
sys-20 permit command virtual-ftp-binary
sys-21 permit command virtual-ftp-bye
sys-22 permit command virtual-ftp-cd
sys-23 permit command virtual-ftp-cdup
sys-24 permit command virtual-ftp-close
sys-25 permit command virtual-ftp-delete
sys-26 permit command virtual-ftp-debug
sys-27 permit command virtual-ftp-dir
sys-28 permit command virtual-ftp-disconnect
sys-29 permit command virtual-ftp-get
sys-30 permit command virtual-ftp-help
sys-31 permit command virtual-ftp-lcd
sys-32 permit command virtual-ftp-ls
sys-33 permit command virtual-ftp-mkdir
sys-34 permit command virtual-ftp-newer
sys-35 permit command virtual-ftp-open
sys-36 permit command virtual-ftp-passive
sys-37 permit command virtual-ftp-put
sys-38 permit command virtual-ftp-pwd
sys-39 permit command virtual-ftp-quit
sys-40 permit command virtual-ftp-reget
sys-41 permit command virtual-ftp-rstatus
sys-42 permit command virtual-ftp-rhelp
sys-43 permit command virtual-ftp-rename
sys-44 permit command virtual-ftp-reset
sys-45 permit command virtual-ftp-restart
sys-46 permit command virtual-ftp-rmdir
sys-47 permit command virtual-ftp-status
sys-48 permit command virtual-ftp-system
sys-49 permit command virtual-ftp-user
sys-50 permit command virtual-ftp-verbose
sys-51 permit command virtual-ftp-remove
sys-52 permit command virtual-ftp-exit
Role |
User role name. Predefined user role names: · network-admin. · network-operator. · mdc-admin. · mdc-operator. · level-n (where n represents an integer in the range of 0 to 15). · security-audit. |
User role description you have configured for easy identification. |
VLAN policy |
VLAN policy of the user role: · deny—Denies access to any VLAN except permitted VLANs. · permit (default)—Default VLAN policy, which enables the user role to access any VLAN. |
Permitted VLANs |
VLANs accessible to the user role. |
Interface policy |
Interface policy of the user role: · deny—Denies access to any interface except permitted interfaces. · permit (default)—Default interface policy, which enables the user role to access any interface. |
Permitted interfaces |
Interfaces accessible to the user role. |
VPN instance policy |
VPN instance policy of the user role: · deny—Denies access to any VPN except permitted VPNs. · permit (default)—Default VPN instance policy, which enables the user role to access any VPN instance. |
Permitted VPN instances |
VPNs accessible to the user role. |
Rule |
User role rule number. A user role rule specifies access permissions for items, including commands, feature-specific commands, Web menus, and XML elements. Predefined user role rules are identified by sys-n, where n represents an integer. |
Perm |
Access control type: · permit—User role has access to the specified items. · deny—User role does not have access to the specified items. |
Type |
Controlled type: · R—Read-only. · W—Write. · X—Execute. |
Scope |
Rule control scope: · command—Controls access to the command or commands, as specified in the Entity field. · feature—Controls access to the commands of the feature, as specified in the Entity field. · feature-group—Controls access to the commands of the features in the feature group, as specified in the Entity field. · web-menu—Controls access to Web menus. · xml-element—Controls access to XML elements. |
Entity |
Command string, feature name, feature group, Web menu, or XML element specified in the user role rule: · An en dash (–) represents any feature. · An asterisk (*) represents zero or more characters. |
role
display role feature
Use display role feature to display features available in the system.
display role feature [ name feature-name | verbose ]
name feature-name: Displays the commands of a feature. The feature-name argument specifies the feature name, and all letters must be in lower case.
verbose: Displays the commands of each feature.
If you specify neither the name feature-name option nor the verbose keyword, the command displays only the list of features available in the system.
# Display the list of feature names.
<Sysname> display role feature
Feature: device (Device configuration related commands)
Feature: interface (Interface related commands)
Feature: syslog (Syslog related commands)
Feature: process (Process related commands)
# Display the commands of each feature.
<Sysname> display role feature verbose
display clock (R)
debugging dev (W)
display debugging dev (R)
display device * (R)
display diagnostic-information (R)
display environment * (R)
display fan * (R)
display alarm * (R)
display power-supply * (R)
display system-working-mode (R)
display current-configuration * (R)
display saved-configuration * (R)
display default-configuration * (R)
display startup (R)
display this * (R)
display archive configuration (R)
display brand (R)
clock datetime * (W)
reboot * (W)
save * (W)
archive configuration (W)
backup startup-configuration to * (W)
---- More ----
# Display the commands of the aaa feature.
<Sysname> display role feature name aaa
Feature: aaa (AAA related commands)
system-view ; domain * (W)
system-view ; header * (W)
system-view ; aaa * (W)
display domain * (R)
system-view ; user-group * (W)
system-view ; local-user * (W)
display local-user * (R)
display user-group * (R)
display debugging local-server (R)
debugging local-server * (W)
super * (X)
display password-control * (R)
reset password-control * (W)
system-view ; password-control * (W)
Table 2 Command output (display role feature name aaa)
Feature |
Displays the name and brief function description of the feature. |
system-view ; domain * |
All commands that start with the domain keyword in system view, and all commands in ISP domain view. |
system-view ; header * |
All commands that start with the header keyword in system view. |
system-view ; aaa * |
All commands that start with the aaa keyword in system view. |
display domain * |
All commands that start with the display domain keywords in user view. |
system-view ; user-group * |
All commands that start with the user-group keyword in system view, and all commands in user group view. |
system-view ; local-user * |
All commands that start with the local-user keyword in system view, and all commands in local user view. |
display user-group * |
All commands that start with the display user-group keywords in user view. |
display debugging local-server |
All commands that start with the display debugging local-server keywords in user view. |
debugging local-server * |
All commands that start with the debugging local-server keywords in user view. |
super * |
All commands that start with the super keyword in user view. |
display password-control * |
All commands that start with the display password-control keywords in user view. |
reset password-control * |
All commands that start with the reset password-control keywords in user view. |
system-view ; password-control * |
All commands that start with the password-control keyword in system view. |
(W) |
Command type is Write. A write command configures the system. |
(R) |
Command type is Read. A read command displays configuration or maintenance information. |
(X) |
Command type is Execute. An execute command executes a specific function. |
feature
display role feature-group
Use display role feature-group to display feature group information.
display role feature-group [ name feature-group-name ] [ verbose ]
name feature-group-name: Specifies a feature group. The feature-group-name argument represents the feature group name, a case-sensitive string of 1 to 31 characters. If you do not specify a feature group, the command displays information about all feature groups.
verbose: Displays the commands of each feature in the specified feature group. If you do not specify a feature group, the keyword enables displaying the commands of each feature in every feature group. If you do not specify this keyword, the command displays only the feature lists of feature groups.
Feature groups L2 and L3 are predefined feature groups.
# Display the feature lists of feature groups.
<Sysname> display role feature-group
Feature group: L2
Feature: igmp-snooping (IGMP-Snooping related commands)
Feature: mld-snooping (MLD-Snooping related commands)
Feature: lacp (LACP related commands)
Feature: stp (STP related commands)
Feature: lldp (LLDP related commands)
Feature: dldp (DLDP related commands)
Feature: eoam (EOAM related commands)
Feature: smart-link (Smart-link related commands)
Feature: monitor-link (Monitor-link related commands)
Feature: loopbk-detect (Loopback-detection related commands)
Feature: vlan (Virtual LAN related commands)
Feature: evi-isis (EVI-ISIS related commands)
Feature: mvrp (MVRP related commands )
Feature group: L3
Feature: route (Route management related commands)
Feature: usr (Unicast static route related commands)
Feature: ospf (Open Shortest Path First protocol related commands)
Feature: rip (Routing Information Protocol related commands)
Feature: isis (ISIS protocol related commands)
Feature: bgp (Border Gateway Protocol related commands)
Feature: l3vpn (Layer 3 Virtual Private Network related commands)
Feature: route-policy (Routing Policy related commands)
Feature: multicast (Multicast related commands)
Feature: pim (Protocol Independent Multicast related commands)
Feature: igmp (Internet Group Management Protocol)
Feature: mld (Multicast Listener Discovery for IPv6)
# Display the commands in each feature group. For more information about the wildcards and marks used in the command list, see Table 2.
<Sysname> display role feature-group verbose
Feature group: L2
system-view ; igmp-snooping (W)
system-view ; vlan * ; igmp-snooping * (W)
system-view ; vlan * ; pim-snooping * (W)
system-view ; interface * ; igmp-snooping * (W)
display igmp-snooping * (R)
display pim-snooping * (R)
reset igmp-snooping * (W)
reset pim-snooping * (W)
debugging igmp-snooping * (W)
display debugging igmp-snooping * (R)
system-view ; mld-snooping (W)
system-view ; vlan * ; mld-snooping * (W)
system-view ; interface * ; mld-snooping * (W)
display mld-snooping * (R)
reset mld-snooping * (W)
debugging mld-snooping * (W)
display debugging mld-snooping * (R)
display link-aggregation * (R)
display lacp * (R)
system-view ; interface Bridge-Aggregation * ; (W)
system-view ; interface Route-Aggregation * ; (W)
system-view ; link-aggregation lacp traffic-redirect-notification enable (W
system-view ; link-aggregation global load-sharing mode * (W)
system-view ; lacp * (W)
system-view ; interface * ; link-aggregation * (W)
system-view ; interface * ; port link-aggregation * (W)
system-view ; interface * ; lacp * (W)
reset lacp * (W)
debugging link-aggregation * (W)
display debugging link-aggregation * (R)
display stp * (R)
system-view ; stp * (W)
system-view ; interface * ; stp * (W)
reset stp * (W)
debugging stp * (W)
display debugging stp * (R)
display lldp * (R)
system-view ; lldp * (W)
system-view ; interface * ; lldp * (W)
debugging lldp * (W)
display debugging lldp * (R)
display dldp * (R)
system-view ; dldp * (W)
system-view ; interface * ; dldp * (W)
reset dldp * (W)
debugging dldp * (W)
display debugging dldp * (R)
display oam * (R)
system-view ; oam * (W)
system-view ; interface * ; oam * (W)
oam remote-loopback * (W)
reset oam * (W)
debugging oam * (W)
display debugging oam * (R)
display smart-link * (R)
system-view ; smart-link * (W)
system-view ; interface * ; port smart-link * (W)
system-view ; interface * ; smart-link * (W)
reset smart-link * (W)
debugging smart-link * (W)
display debugging smart-link * (R)
display monitor-link * (R)
system-view ; monitor-link * (W)
system-view ; interface * ; port monitor-link * (W)
debugging monitor-link * (W)
display debugging monitor-link * (R)
display loopback-detection * (R)
system-view ; loopback-detection * (W)
system-view ; interface * ; loopback-detection * (W)
debugging loopback-detection * (W)
display debugging loopback-detection * (R)
display vlan * (R)
display port trunk (R)
display port hybrid (R)
display qinq * (R)
display debugging vlan (R)
debugging vlan * (W)
system-view ; probe ; display system internal vlan * (R)
system-view ; vlan * ; (W)
system-view ; interface * ; port link-type * (W)
system-view ; interface * ; port access vlan * (W)
system-view ; interface * ; port trunk pvid vlan * (W)
system-view ; interface * ; port trunk permit vlan * (W)
system-view ; interface * ; port hybrid pvid vlan * (W)
system-view ; interface * ; port hybrid vlan * (W)
system-view ; interface * ; qinq * (W)
system-view ; vlan * ; name * (W)
system-view ; vlan * ; description * (W)
system-view ; vlan * ; port * (W)
display evi isis * (R)
display debugging evi isis * (R)
reset evi isis * (W)
debugging evi isis * (W)
system-view ; evi-isis * (W)
system-view ; evi designated-vlan * (W)
system-view ; interface * ; evi isis * (W)
system-view ; interface * ; evi extend-vlan * (W)
system-view ; interface * ; evi enable * (W)
system-view ; probe ; evi generate-mac * (X)
system-view ; probe ; evi delete-mac * (X)
system-view ; probe ; display system internal eviisis * (R)
display mvrp * (R)
system-view ; mvrp * (W)
system-view ; interface * ; mvrp * (W)
system-view ; interface * ; mrp * (W)
reset mvrp * (W)
debugging mvrp * (W)
display debugging mvrp * (R)
Feature group: L3
display debugging rib * (R)
display ip routing-table * (R)
display ipv6 routing-table * (R)
display router id * (R)
display rib * (R)
display ipv6 rib * (R)
reset ip routing-table statistics * (W)
reset ipv6 routing-table statistics * (W)
debugging rib * (W)
debugging ipv6 rib * (W)
system-view ; router id * (W)
system-view ; rib * (W)
system-view ; probe * ; rib * (W)
system-view ; probe * ; ipv6 rib * (W)
system-view ; probe * ; display system internal rib * (R)
system-view ; probe * ; display system internal ipv6 rib * (R)
system-view ; probe * ; reset rib * (W)
system-view ; probe * ; reset ipv6 rib * (W)
display debugging route-static * (R)
display route-static * (R)
display ipv6 route-static * (R)
display route-direct * (R)
display ipv6 route-direct * (R)
debugging route-static * (W)
debugging ipv6 route-static * (W)
debugging route-direct * (W)
debugging ipv6 route-direct * (W)
system-view ; ip route-static * (W)
system-view ; ipv6 route-static * (W)
system-view ; delete static-routes * (W)
system-view ; delete ipv6 static-routes * (W)
system-view ; delete vpn-instance * (W)
system-view ; delete ipv6 vpn-instance * (W)
system-view ; probe * ; route-static * (W)
system-view ; probe * ; ipv6 route-static * (W)
system-view ; probe * ; display system internal route-static * (R)
system-view ; probe * ; display system internal ipv6 route-static * (R)
system-view ; probe * ; reset route-static * (W)
system-view ; probe * ; reset ipv6 route-static * (W)
system-view ; probe * ; route-direct * (W)
system-view ; probe * ; ipv6 route-direct * (W)
system-view ; probe * ; display system internal route-direct * (R)
system-view ; probe * ; display system internal ipv6 route-direct * (R)
system-view ; probe * ; reset route-direct * (W)
system-view ; probe * ; reset ipv6 route-direct * (W)
display ospf * (R)
display ospfv3 * (R)
display debugging ospf * (R)
display debugging ospfv3 * (R)
reset ospf * (W)
debugging ospf * (W)
debugging ospfv3 * (W)
system-view ; ospf * (W)
system-view ; snmp-agent trap enable ospf * (W)
system-view ; interface * ; ospf * (W)
system-view ; ospfv3 * (W)
system-view ; interface * ; ospfv3 * (W)
display rip * (R)
display ripng * (R)
reset rip * (W)
reset ripng * (W)
debugging rip * (W)
display debugging rip * (R)
debugging ripng * (W)
display debugging ripng * (R)
system-view ; rip * (W)
system-view ; interface * ; rip * (W)
system-view ; ripng * (W)
system-view ; interface * ; ripng * (W)
system-view ; probe * ; display system internal rip * (R)
system-view ; probe * ; display system internal ripng * (R)
display isis * (R)
reset isis * (W)
debugging isis * (W)
display debugging isis * (R)
system-view ; isis * (W)
system-view ; snmp-agent trap enable isis * (W)
system-view ; interface * ; isis * (W)
system-view ; probe * ; display system internal isis * (R)
display debugging bgp * (R)
display bgp * (R)
system-view ; probe ; display system internal bgp * (R)
reset bgp * (W)
refresh bgp * (W)
debugging bgp * (W)
system-view ; snmp-agent trap enable bgp (W)
system-view ; bgp * (W)
display ip vpn-instance * (R)
system-view ; ip vpn-instance * (W)
system-view ; interface * ; ip binding vpn-instance * (W)
system-view ; snmp-agent trap enable l3vpn (W)
system-view ; probe ; display system internal ip vpn-instance * (R)
display route-policy * (R)
display ip prefix-list * (R)
display ipv6 prefix-list * (R)
display mac-list * (R)
display debugging route-policy * (R)
display ip community-list * (R)
display ip as-path * (R)
display ip extcommunity-list * (R)
reset ip prefix-list * (W)
reset ipv6 prefix-list * (W)
reset mac-list * (W)
debugging route-policy * (W)
system-view ; ip prefix-list * (W)
system-view ; ipv6 prefix-list * (W)
system-view ; mac-list * (W)
system-view ; route-policy * (W)
system-view ; ip community-list * (W)
system-view ; ip as-path * (W)
system-view ; ip extcommunity-list * (W)
display multicast * (R)
display ipv6 multicast * (R)
display l2-multicast * (R)
display ipv6 l2-multicast * (R)
reset multicast * (W)
reset ipv6 multicast * (W)
debugging mfib * (W)
debugging ipv6 mfib * (W)
display debugging mfib * (R)
display debugging ipv6 mfib * (R)
debugging l2mf * (W)
debugging ipv6 l2mf * (W)
display debugging l2mf * (R)
display debugging ipv6 l2mf * (R)
debugging mrib * (W)
debugging ipv6 mrib * (W)
display debugging mrib * (R)
display debugging ipv6 mrib * (R)
system-view ; multicast * (W)
system-view ; ipv6 multicast * (W)
system-view ; ip rpf-route-static * (W)
system-view ; delete ip rpf-route-static * (W)
system-view ; interface * ; multicast * (W)
system-view ; interface * ; ipv6 multicast * (W)
display pim * (R)
display ipv6 pim * (R)
debugging pim * (W)
debugging ipv6 pim * (W)
display debugging pim * (R)
display debugging ipv6 pim * (R)
system-view ; pim * (W)
system-view ; ipv6 pim * (W)
system-view ; interface * ; pim * (W)
system-view ; interface * ; ipv6 pim * (W)
Feature: igmp (Internet Group Management Protocol related commands)
display igmp * (R)
debugging igmp * (W)
display debugging igmp * (R)
reset igmp * (W)
system-view ; interface * ; igmp * (W)
Feature: mld (Multicast Listener Discovery related commands)
display mld * (R)
debugging mld * (W)
display debugging mld * (R)
reset mld * (W)
system-view ; interface * ; mld * (W)
# Display the feature list of the L3 feature group.
<Sysname> display role feature-group name L3
Feature group: L3
· feature
· role feature-group
feature
Use feature to add a feature to a feature group.
Use undo feature to remove a feature from a feature group.
feature feature-name
undo feature feature-name
A user-defined feature group does not have any feature.
Feature group view
feature-name: Specifies a feature name. You must enter the feature name exactly as the feature name is displayed, including the case.
Repeat the feature command to add multiple features to a feature group.
# Add the security features AAA and ACL to the security group security-features.
[Sysname] role feature-group name security-features
[Sysname-featuregrp-security-features] feature aaa
[Sysname-featuregrp-security-features] feature acl
· display role feature
· display role feature-group
interface policy deny
Use interface policy deny to enter user role interface policy view.
Use undo interface policy deny to restore the default user role interface policy.
A user role has access to any interface.
User role view
To restrict the interface access of a user role to a set of interfaces, perform the following tasks:
1. Use interface policy deny to enter user role interface policy view.
2. Use permit interface to specify accessible interfaces.
NOTE: The interface policy deny command denies the access of the user role to all interfaces if the permit interface command is not configured. |
To configure an interface, make sure the interface is permitted by the user role interface policy in use. You can perform the following tasks on an accessible interface:
· Create, remove, or configure the interface.
· Enter the interface view.
· Specify the interface in feature commands.
The creation and removal operations are available only for logical interfaces.
Any change to a user role interface policy takes effect only on users who log in with the user role after the change.
# Enter user role interface policy view of role1, and deny the user role role1 to access any interface.
[Sysname-role-role1] interface policy deny
[Sysname-role-role1-ifpolicy] quit
# Enter user role interface policy view of role1, and deny the user role role1 to access any interface except GigabitEthernet 3/0/1 to GigabitEthernet 3/0/5.
[Sysname-role-role1-ifpolicy] permit interface GigabitEthernet 3/0/1 to GigabitEthernet 3/0/5
· display role
· permit interface
· role
permit interface
Use permit interface to configure a list of interfaces accessible to a user role.
Use undo permit interface to disable the access of a user role to specific interfaces.
permit interface interface-list
undo permit interface [ interface-list ]
No permitted interfaces are configured in user role interface policy view.
User role interface policy view
interface interface-list: Specifies a space-separated list of up to 10 interface items. Each interface item specifies one interface in the interface-type interface-number form or a range of interfaces in the interface-type interface-number to interface-type interface-number form. If you specify an interface range, the end interface must meet the following requirements:
· Be the same type as the start interface.
· Have a higher interface number than the start interface.
To permit a user role to access an interface after you configure the interface policy deny command, you must add the interface to the permitted interface list of the policy. With the user role, you can perform the following tasks to the interfaces in the permitted interface list:
· Create, remove, or configure the interfaces.
· Enter the interface views.
· Specify the interfaces in feature commands.
The create and remove operations are available only for logical interfaces.
You can repeat the permit interface command to add permitted interfaces to a user role interface policy.
The undo permit interface command removes the entire list of permitted interfaces if you do not specify an interface.
1. Configure user role role1:
# Permit the user role role1 to execute all commands available in interface view and VLAN view.
[Sysname-role-role1] rule 1 permit command system-view ; interface *
[Sysname-role-role1] rule 2 permit command system-view ; vlan *
# Permit the user role to access GigabitEthernet 3/0/1, and GigabitEthernet 3/0/5 to GigabitEthernet 3/0/7.
[Sysname-role-role1-ifpolicy] permit interface GigabitEthernet 3/0/1 GigabitEthernet 3/0/5 to GigabitEthernet 3/0/7
[Sysname-role-role1] quit
2. Verify that you cannot use the user role to work on any interface except GigabitEthernet 3/0/1 and GigabitEthernet 3/0/5 to GigabitEthernet 3/0/7:
# Verify that you can enter GigabitEthernet 3/0/1 interface view.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] quit
# Verify that you can assign GigabitEthernet 3/0/5 to VLAN 10. In this example, the user role can access any VLAN because the default VLAN policy of the user role is used.
[Sysname] vlan 10
[Sysname-vlan10] port GigabitEthernet 3/0/5
[Sysname-vlan10] quit
# Verify that you cannot enter GigabitEthernet 3/0/2 interface view.
[Sysname] interface GigabitEthernet 3/0/2
Permission denied.
· display role
· interface policy deny
· role
permit vlan
Use permit vlan to configure a list of VLANs accessible to a user role.
Use undo permit vlan to remove the permission for a user role to access specific VLANs.
permit vlan vlan-id-list
undo permit vlan [ vlan-id-list ]
No permitted VLANs are configured in user role VLAN policy view.
User role VLAN policy view
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each VLAN item specifies a VLAN by VLAN ID or specifies a range of VLANs in the form of vlan-id1 to vlan-id2. The value range for the VLAN IDs is 1 to 4094. If you specify a VLAN range, the value for the vlan-id2 argument must be greater than the value for the vlan-id1 argument.
To permit a user role to access a VLAN after you configure the vlan policy deny command, you must add the VLAN to the permitted VLAN list of the policy. With the user role, you can perform the following tasks on the VLANs in the permitted VLAN list:
· Create, remove, or configure the VLANs.
· Enter the VLAN views.
· Specify the VLANs in feature commands.
You can repeat the permit vlan command to add permitted VLANs to a user role VLAN policy.
The undo permit vlan command removes the entire list of permitted VLANs if you do not specify a VLAN.
Any change to a user role VLAN policy takes effect only on users who log in with the user role after the change.
# Permit the user role role1 to access VLANs 2, 4, and 50 to 100.
[Sysname-role-role1] vlan policy deny
[Sysname-role-role1-vlanpolicy] permit vlan 2 4 50 to 100
[Sysname-role-role1-vlanpolicy] quit
2. Verify that you cannot use the user role to work on any VLAN except VLANs 2, 4, and 50 to 100:
# Verify that you can create VLAN 100 and enter the VLAN view.
[Sysname] vlan 100
[Sysname-vlan100] quit
# Verify that you can add port GigabitEthernet 3/0/1 to VLAN 100 as an access port.
[Sysname] interface GigabitEthernet3/0/1
[Sysname-GigabitEthernet3/0/1] port access vlan 100
# Verify that you cannot create VLAN 101 or enter the VLAN view.
[Sysname] vlan 101
Permission denied.
· display role
· role
· vlan policy deny
permit vpn-instance
Use permit vpn-instance to configure a list of VPNs accessible to a user role.
Use undo permit vpn-instance to disable the access of a user role to specific VPNs.
permit vpn-instance vpn-instance-name&<1-10>
undo permit vpn-instance [ vpn-instance-name&<1-10> ]
No permitted VPNs are configured in user role VPN instance policy.
User role VPN instance policy view
vpn-instance-name&<1-10>: Specifies a space-separated list of up to 10 MPLS L3VPN names. Each name is a case-sensitive string of 1 to 31 characters.
To permit a user role to access an MPLS L3VPN after you configure the vpn-instance policy deny command, you must add the VPN to the permitted VPN list of the policy. With the user role, you can perform the following tasks on the VPNs in the permitted VPN list:
· Create, remove, or configure the VPNs.
· Enter the VPN instance views.
· Specify the VPNs in feature commands.
You can repeat the permit vpn-instance command to add permitted MPLS L3VPNs to a user role VPN instance policy.
The undo permit vpn-instance command removes the entire list of permitted VPNs if you do not specify a VPN.
Any change to a user role VPN instance policy takes effect only on users who log in with the user role after the change.
# Permit the user role role1 to execute all commands available in system view and in the child views of system view.
[Sysname-role-role1] rule 1 permit command system-view ; *
# Permit the user role to access VPN vpn1.
[Sysname-role-role1] vpn policy deny
[Sysname-role-role1-vpnpolicy] permit vpn-instance vpn1
[Sysname-role-role1-vpnpolicy] quit
2. Verify that you cannot use the user role to work on any VPN except vpn1:
# Verify that you can enter the view of vpn1.
# Verify that you can assign the primary accounting server at 10.110.1.2 to the VPN in the RADIUS scheme radius1.
[Sysname] radius scheme radius1
[Sysname-radius-radius1] primary accounting 10.110.1.2 vpn-instance vpn1
[Sysname-radius-radius1] quit
# Verify that you cannot create the VPN vpn2 or enter the VPN instance view.
[Sysname] ip vpn-instance vpn2
Permission denied.
· display role
· role
· vpn-instance policy deny
role
Use role to create a user role and enter user role view. If the user role has been created, you directly enter the user role view.
Use undo role to delete a user role.
role name role-name
undo role name role-name
The system has the following predefined user roles: network-admin, network-operator, mdc-admin, mdc-operator, level-n (where n represents an integer in the range of 0 to 15), and security-audit.
name role-name: Specifies a username. The role-name argument is a case-sensitive string of 1 to 63 characters.
You can create a maximum of 64 user roles in addition to the predefined user roles.
To change the permissions assigned to a user role, you must first enter the user role view.
You cannot delete the predefined user roles or change the permissions assigned to network-admin, network-operator, mdc-admin, mdc-operator, level-15, or security-audit.
You cannot assign the security-audit user role to non-AAA authentication users.
Level-0 to level-14 users can modify their own permissions for any command except for the display history-command all command.
# Create the user role role1 and enter the user role view.
· display role
· rule
· vlan policy deny
role default-role enable
Use role default-role enable to enable the default user role feature for remote AAA users.
Use undo role default-role enable to restore the default.
The default user role feature is disabled. AAA users who do not have a user role cannot log in to the device.
The default user role feature allows an AAA authentication user to access the system if the AAA server does not authorize any user role to the user.
You can configure this feature to enable an AAA authentication user who has not been assigned any user role to log in with a default user role.
· For login to the default MDC, the default user role is network-operator.
· For login to a non-default MDC, the default user role is mdc-operator.
If AAA users have been assigned user roles, they log in with the user roles.
# Enable the default user role feature.
[Sysname] role default-role enable
role
role feature-group
Use role feature-group to create a user role feature group and enter user role feature group view.
Use undo role feature-group to delete a user role feature group.
role feature-group name feature-group-name
undo role feature-group name feature-group-name
Two user role feature groups, L2 and L3, are created.
name feature-group-name: Specifies a feature group name. The feature-group-name argument is a case-sensitive string of 1 to 31 characters.
The L2 feature group includes all Layer 2 feature commands, and the L3 feature group includes all Layer 3 feature commands. These predefined feature groups are not user configurable.
In addition to the predefined feature groups L2 and L3, you can create a maximum of 64 user role feature groups.
After you create a user role feature group, you can use the display role feature command to display the features available in the system. Then you can use the feature command to add features to the feature group.
# Create the feature group security-features.
· feature
rule
Use rule to create or change a user role rule for controlling command, Web menu, or XML element access.
Use undo rule to delete a user role rule.
rule number { deny | permit } { command command-string | { execute | read | write } * { feature [ feature-name ] | feature-group feature-group-name | web-menu [ web-string ] | xml-element [ xml-string ] } }
undo rule { number | all }
A user-defined user role does not have any rule and cannot access any command, Web menu, or XML element.
User role view
number: Specifies a rule number in the range of 1 to 256.
deny: Denies access to any specified command, Web menu, or XML element.
permit: Permits access to any specified command, Web menu, or XML element.
command command-string: Specifies a command string. The command-string argument is a case-sensitive string of 1 to 128 characters, including the following characters:
· The wildcard asterisk (*).
· The delimiters space and tab.
· All printable characters.
execute: Specifies the execute commands, Web menus, or XML elements. An execute command (for example, ping), Web menu, or XML element executes a specific function or program.
read: Specifies the read commands, Web menus, or XML elements. A read command (for example, display, dir, more, or pwd), Web menu, or XML element displays configuration or maintenance information.
write: Specifies the write commands, Web menus, or XML elements. A write command (for example, ssh server enable), Web menu, or XML element configures the system.
feature [ feature-name ]: Specifies one or all features. The feature-name argument specifies a feature name. If you do not specify a feature name, you specify all the features in the system. When you specify a feature, the feature name must be the same, including the case, as the name displayed by the display role feature command.
feature-group feature-group-name: Specifies a user-defined or predefined feature group. The feature-group-name argument represents the feature group name, a case-sensitive string of 1 to 31 characters. If the feature group has not been created, the rule takes effect after the group is created. To display the feature groups that have been created, use the display role feature-group command.
web-menu [ web-string ]: Specifies a Web menu. The web-string argument represents the ID path of the Web menu, a case-insensitive string of 1 to 512 characters. Use the forward slash (/) to separate ID items, for example, M_DEVICE/I_BASIC_INFO/I_reboot. If you do not specify a Web menu, the rule applies to all Web items. To verify the ID path of a Web menu, use the display web menu command.
xml-element [ xml-string ]: Specifies an XML element. The xml-string argument represents the XPath of the XML element, a case-insensitive string of 1 to 512 characters. Use the forward slash (/) to separate XPath items, for example, Interfaces/Index/Name. If you do not specify an XML element, the rule applies to all XML elements.
all: Deletes all the user role rules.
You can define the following types of rules for different access control granularities:
· Command rule—Controls access to a command or a set of commands that match a regular expression.
· Feature rule—Controls access to the commands of a feature by command type.
· Feature group rule—Controls access to the commands of a group of features by command type.
· Web menu rule—Controls access to Web menus by menu type.
· XML element rule—Controls access to XML elements by element type.
A user role can access the set of permitted commands, Web menus, and XML elements specified in the user role rules. User role rules include predefined (identified by sys-n) and user-defined user role rules.
· If two user-defined rules of the same type conflict, the rule with the higher ID takes effect. For example, a user role can use the tracert command but not the ping command if the user role contains rules configured by using the following commands:
¡ rule 1 permit command ping
¡ rule 2 permit command tracert
¡ rule 3 deny command ping
· If a predefined user role rule and a user-defined user role rule conflict, the user-defined user role rule takes effect.
You can configure a maximum of 256 user-defined rules for a user role. The total number of user-defined user role rules cannot exceed 1024.
Any rule modification, addition, or removal for a user role takes effect only on the users who log in with the user role after the change.
Access to the file system commands is controlled by both the file system command rules and the file system feature rule.
A command with output redirection to the file system is permitted only when the command type write is assigned to the file system feature.
When you specify a command string, follow the guidelines in Table 3.
Table 3 Command string configuration rules
Rule |
Guidelines |
Semicolon (;) is the delimiter. |
Use a semicolon to separate the command of each view that you must enter before you access a command or a set of commands. However, do not use a semicolon to separate commands available in user view or any view, for example, display and dir. Each semicolon-separated segment must have a minimum of one printable character. To specify the commands in a view but not the commands in the view's subviews, use a semicolon as the last printable character in the last segment. To specify the commands in a view and the view's subviews, the last printable character in the last segment must not be a semicolon. For example, you must enter system view before you enter interface view. To specify all commands starting with the ip keyword in any interface view, you must use the "system ; interface * ; ip * ;" command string. For another example, the "system ; radius scheme * ;" command string represents all commands that start with the radius scheme keywords in system view. The "system ; radius scheme *" command string represents all commands that start with the radius scheme keywords in system view and all commands in RADIUS scheme view. |
Asterisk (*) is the wildcard. |
An asterisk represents zero or multiple characters. In a non-last segment, you can use an asterisk only at the end of the segment. In the last segment, you can use an asterisk in any position of the segment. If the asterisk appears at the beginning, you cannot specify a printable character behind the asterisk. For example, the "system ; *" command string represents all commands available in system view and all subviews of the system view. The "debugging * event" command string represents all event debugging commands available in user view. |
Keyword abbreviation is allowed. |
You can specify a keyword by entering the first few characters of the keyword. Any command that starts with this character string matches the rule. For example, "rule 1 deny command dis mpls lsp protocol static asbr" denies access to the commands display mpls lsp protocol static asbr and display mpls lsp protocol static-cr asbr. |
To control the access to a command, you must specify the command immediately after the view that has the command. |
To control access to a command, you must specify the command immediately behind the view to which the command is assigned. The rules that control command access for any subview do not apply to the command. For example, the "rule 1 deny command system ; interface * ; *" command string disables access to any command that is assigned to interface view. However, you can still execute the acl number command in interface view, because this command is assigned to system view rather than interface view. To disable access to this command, use "rule 1 deny command system ; acl *;". |
Do not include the vertical bar (|), greater-than sign (>), or double greater-than sign (>>) when you specify display commands in a user role command rule. |
The system does not treat the redirect signs and the parameters that follow the signs as part of command lines. However, in user role command rules, these redirect signs and parameters are handled as part of command lines. As a result, no rule that includes any of these signs can find a match. For example, "rule 1 permit command display debugging > log" can never find a match. This is because the system has a display debugging command but not a display debugging > log command. |
# Permit the user role role1 to execute the display acl command.
[Sysname-role-role1] rule 1 permit command display acl
# Permit the user role role1 to execute all commands that start with the display keyword.
[Sysname-role-role1] rule 2 permit command display *
# Permit the user role role1 to execute the radius scheme aaa command in system view and use all commands assigned to RADIUS scheme view.
[Sysname-role-role1] rule 3 permit command system ; radius scheme aaa
# Deny the access of role1 to any read or write command of any feature.
[Sysname-role-role1] rule 4 deny read write feature
# Deny the access of role1 to any read command of the aaa feature.
[Sysname-role-role1] rule 5 deny read feature aaa
# Permit role1 to access all read, write, and execute commands of the feature group security-features.
[Sysname-role-role1] rule 6 permit read write execute feature-group security-features
· display role
· role
super
Use super to obtain another user role without reconnecting to the device.
super [ rolename ]
rolename: Specifies a user role, a case-sensitive string of 1 to 63 characters. The user role must exist in the system. If you do not specify a user role, you obtain one of the following user roles:
· You obtain the network-admin user role if you have logged in to the default MDC.
· You obtain the mdc-admin user role if you have logged in to the non-default MDCs.
The obtained user role is a temporary user role, because this command is effective only on the current login. The next time you are logged in with the user account, the original user role settings take effect.
To enable a user to obtain another user role without reconnecting to the device, you must configure user role authentication.
· If no local password is configured in the local password authentication (local), a console or AUX user can obtain the user role by either entering a string or not entering anything.
· If no local password is configured in the local-then-remote authentication (local scheme), the following rules apply:
¡ A console or VTY user performs remote authentication.
¡ An AUX user can obtain user role authorization by either entering a string or not entering anything.
# Obtain the user role network-operator.
<Sysname> super network-operator
Password:
User privilege role is network-operator, and only those commands can be used that authorized to the role.
· authentication super (Security Command Reference)
· super authentication-mode
· super password
Use super authentication-mode to set an authentication mode for temporary user role authorization.
Use undo super authentication-mode to restore the default.
super authentication-mode { local | scheme } *
Local password authentication applies.
local: Enables local password authentication.
scheme: Enables remote AAA authentication.
For local password authentication, use the super password command to set a password.
For remote AAA authentication, set the username and password on the RADIUS or HWTACACS server.
If you specify both local and scheme keywords, the keyword first entered in the command takes precedence.
· scheme local—Enables remote-then-local authentication mode. The device first performs AAA authentication to obtain a temporary user role. Local password authentication is performed if the remote HWTACACS or RADIUS server does not respond, or if the AAA configuration on the device is invalid.
· local scheme—Enables local-then-remote authentication mode. The device first performs local password authentication. If no password is configured for the user role, the device performs remote authentication.
For more information about AAA, see Security Configuration Guide.
# Enable local-only authentication for temporary user role authorization.
[Sysname] super authentication-mode local
# Enable remote-then-local authentication for temporary user role authorization.
[Sysname] super authentication-mode scheme local
· super password
super password
Use super password to set a password for a user role.
Use undo super password to restore the default.
In non-FIPS mode:
super password [ role rolename ] [ { hash | simple } password ]
undo super password [ role rolename ]
In FIPS mode:
No password is set for a user role.
role rolename: Specifies a user role, a case-sensitive string of 1 to 63 characters. The user role must exist in the system. If you do not specify a user role for the command, the following rules apply:
· If you log in to the default MDC, the command sets a password for the network-admin user role.
· If you log in to a non-default MDC, the command sets a password for the mdc-admin user role.
hash: Sets a hashed password.
simple: Sets a plaintext password. This password will be saved in hashed text for secrecy.
password: Specifies the password string. This argument is case sensitive.
· In non-FIPS mode:
¡ If the simple keyword is specified, the password must be a string of 1 to 63 characters.
¡ If the hash keyword is specified, the password must be a string of 1 to 110 characters.
· In FIPS mode, the password must be a string of 15 to 63 characters. The string must contain four character types including digits, uppercase letters, lowercase letters, and special characters.
If you do not specify any parameters, you specify a plaintext password in the interactive mode.
The FIPS mode supports only the interactive mode for setting a password.
Set a password if you configure local password authentication for temporary user role authorization.
It is a good practice to specify different passwords for different user roles.
# Set the password to abc for the user role network-operator.
[Sysname] super password role network-operator simple abc
# Set the password to abc in the interactive mode for the user role network-operator.
Password:
Confirm :
Updating user information. Please wait... ...
vlan policy deny
Use vlan policy deny to enter user role VLAN policy view.
Use undo vlan policy deny to restore the default user role VLAN policy.
vlan policy deny
A user role has access to any VLAN.
User role view
To restrict the VLAN access of a user role to a set of VLANs, perform the following tasks:
1. Use vlan policy deny to enter user role VLAN policy view.
2. Use permit vlan to specify accessible VLANs.
NOTE: The vlan policy deny command denies the access of the user role to all VLANs if the permit vlan command is not configured. |
To configure a VLAN, make sure the VLAN is permitted by the user role VLAN policy in use. You can perform the following tasks on an accessible VLAN:
· Create, remove, or configure the VLAN.
· Enter the VLAN view.
· Specify the VLAN in feature commands.
# Enter user role VLAN policy view of role1, and deny the access of role1 to any VLAN.
# Enter user role VLAN policy view of role1, and deny the access of role1 to any VLAN except VLANs 50 to 100.
[Sysname-role-role1-vlanpolicy] permit vlan 50 to 100
· display role
· permit vlan
· role
Use vpn-instance policy deny to enter user role VPN instance policy view.
Use undo vpn-instance policy deny to restore the default user role VPN instance policy.
A user role has access to any VPN.
User role view
To restrict the VPN access of a user role to a set of VPNs, perform the following tasks:
1. Use vpn-instance policy deny to enter user role VPN instance policy view.
2. Use permit vpn-instance to specify accessible VPNs.
NOTE: The vpn-instance policy deny command denies the access of the user role to all VPNs if the permit vpn-instance command is not configured. |
To configure a VPN, make sure the VPN is permitted by the user role VPN instance policy in use. You can perform the following tasks on an accessible VPN:
· Create, remove, or configure the VPN.
· Enter the VPN instance view.
· Specify the VPN in feature commands.
# Enter user role VPN instance policy view of role1, and deny the access of user role role1 to any VPN.
[Sysname-role-role1] vpn-instance policy deny
# Enter user role VPN instance policy view of role1, and deny the access of user role role1 to any VPN except vpn2.
[Sysname-role-role1-vpnpolicy] permit vpn-instance vpn2
· display role
· permit vpn-instance
· role
