- 01-Fundamentals Command Reference
- 01-CLI commands
- 02-RBAC commands
- 03-Login management commands
- 04-FTP and TFTP commands
- 05-File system management commands
- 06-Configuration file management commands
- 07-Software upgrade commands
- 08-ISSU commands
- 09-Emergency shell commands
- 10-Device management commands
- 11-Tcl commands
- 12-License management commands
- 13-Password recovery control command
- 14-Python commands
| 03-Login management commands | 220.18 KB |
Some login management commands are available in both user line view and user line class view. For these commands, the device uses the following rules to determine the settings to be activated:
· A setting in user line view is applied only to the user line. A setting in user line class view is applied to all user lines of the class.
· A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
· A setting in user line view takes effect immediately and affects the online user. A setting in user line class view takes effect only for new login users. It does not affect online users.
activation-key
Use activation-key to specify shortcut key for starting a terminal session.
Use undo activation-key to restore the default.
activation-key key-string
undo activation-key
Pressing Enter starts a terminal session.
User line view, user line class view
key-string: Specifies a shortcut key. It can be a single character, a key sequence, or an ASCII code value in the range of 0 to 127.
This command is not supported in VTY line view or VTY line class view.
This command is available in both user line view and user line class view. A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
To display the current shortcut key, use the display current-configuration | include activation-key command.
# Configure character s as the shortcut key for starting a terminal session on the console line.
[Sysname] line console 0
[Sysname-line-console0] activation-key s
To verify the configuration:
1. Exit the console session.
[Sysname-line-console0] return
<Sysname> quit
2. Log in again through the console line.
The following message appears:
Press ENTER to get started.
3. Press Enter.
Pressing Enter does not start a session.
4. Enter s.
A terminal session is started.
<Sysname>
authentication-mode
Use authentication-mode to set the authentication mode for a user line.
Use undo authentication-mode to restore the default.
In non-FIPS mode:
authentication-mode { none | password | scheme }
In FIPS mode:
authentication-mode scheme
In non-FIPS mode, the authentication mode is password for VTY and AUX lines, and none for console and TTY lines.
In FIPS mode, the authentication mode is scheme.
none: Performs no authentication.
password: Performs local password authentication.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
When the authentication mode is none, a user can log in without authentication. To improve device security, use the password or scheme authentication mode.
In VTY line view, this command is associated with the protocol inbound command. If you specify a non-default value for only one of the two commands in VTY line view, the other command uses the default setting, regardless of the setting in VTY line class view.
# Enable the none authentication mode for the user line VTY 0.
[Sysname] line vty 0
[Sysname-line-vty0] authentication-mode none
# Enable password authentication for the user line VTY 0 and set the password to 321.
[Sysname-line-vty0] authentication-mode password
[Sysname-line-vty0] set authentication password simple 321
# Enable scheme authentication for the user line VTY 0. Configure local user 123 and set the password to 321. Assign the Telnet service and the user role network-admin to the user.
[Sysname-line-vty0] authentication-mode scheme
[Sysname-line-vty0] quit
[Sysname] local-user 123 class manage
[Sysname-luser-manage-123] password simple 321
[Sysname-luser-manage-123] service-type telnet
[Sysname-luser-manage-123] authorization-attribute user-role network-admin
auto-execute command
CAUTION: After configuring this command for a user line, you might be unable to access the CLI through the user line. Make sure you can access the CLI through a different user line before you configure this command and save the configuration. |
Use auto-execute command to specify the command to be automatically executed for login users.
Use undo auto-execute command to remove the configuration.
auto-execute command command
Command auto-execution is disabled.
command: Specifies the command to be automatically executed.
This command is not supported in console line view or console line class view.
The device automatically executes the specified command when a user logs in through the user line, and closes the user connection after the command is executed. If the command triggers another task, the device does not close the user connection until the task is completed.
Typically, you configure the auto-execute command telnet X.X.X.X command on the device so the device redirects a Telnet user to the host at X.X.X.X. In this case, the connection to the current device is closed when the user terminates the Telnet connection to X.X.X.X.
# Configure the device to automatically Telnet to 192.168.1.41 after a user logs in through user line VTY 0.
[Sysname-line-vty0] auto-execute command telnet 192.168.1.41
% This action will lead to configuration failure through line-vty0. Are you sure?
[Y/N]:y
[Sysname-line-vty0]
# To verify the configuration, Telnet to 192.168.1.40.
The device automatically Telnets to 192.168.1.41, and the following output is displayed on the configuration terminal:
C:\> telnet 192.168.1.40
* Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All rights reserved. *
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<Sysname>
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
<Sysname.41>
This operation is the same as directly logging in to the device at 192.168.1.41 through Telnet. When you close the Telnet connection to 192.168.1.41, the Telnet connection to 192.168.1.40 is closed at the same time.
command accounting
Use command accounting to enable command accounting.
Use undo command accounting to restore the default.
command accounting
Command accounting is disabled, and the accounting server does not record executed commands.
When command accounting is enabled but command authorization is not, every executed command is recorded on the HWTACACS server.
When both command accounting and command authorization are enabled, only authorized commands that are executed are recorded on the HWTACACS server.
Invalid commands issued by users are not recorded.
If the command accounting command is configured in user line class view, command accounting is enabled on all user lines in the class. You cannot configure the undo command accounting command in the view of a user line in the class.
# Enable command accounting for the user line VTY 0.
[Sysname-line-vty0] command accounting
· accounting command (Security Command Reference)
· command authorization
Use command authorization to enable command authorization.
Use undo command authorization to restore the default.
Command authorization is disabled. Logged-in users can execute commands without authorization.
When command authorization is enabled, a command is available only if the following requirements are met:
· The user has the commensurate user role.
· The user is authorized to use the command by the AAA scheme.
If the command authorization command is configured in user line class view, command authorization is enabled on all user lines in the class. You cannot configure the undo command authorization command in the view of a user line in the class.
# Enable command authorization for VTY 0 so the VTY 0 user can execute only authorized commands that are permitted by the user role.
[Sysname-line-vty0] command authorization
· authorization command (Security Command Reference)
· command accounting
databits
Use databits to specify the number of data bits for a character.
Use undo databits to restore the default.
databits { 5 | 6 | 7 | 8 }
undo databits
Eight data bits are used for a character.
User line view
5: Uses five data bits for a character.
6: Uses six data bits for a character.
7: Uses seven data bits for a character.
8: Uses eight data bits for a character.
This command is supported only on the default MDC. For more information about MDC, see Virtual Technologies Configuration Guide.
This command is not supported in VTY line view.
This setting must be the same as the setting on the configuration terminal.
# Configure AUX 0 to use five data bits for a character.
[Sysname] line aux 0
[Sysname-line-aux0] databits 5
display line
Use display line to display user line information.
display line [ number1 | { aux | console | vty } number2 ] [ summary ]
number1: Specifies the absolute number of a user line. The following are the value ranges:
· Default MDC—0 to 67 in standalone mode, and 0 to 79 in IRF mode.
· Non-default MDC—0 to 63.
aux: Specifies the AUX line. This keyword is supported only on the default MDC.
console: Specifies the console line. This keyword is supported only on the default MDC.
vty: Specifies the VTY line.
number2: Specifies the relative number of a user line. The following are the value ranges:
· AUX line—0 to 1 in standalone mode and 0 to 7 in IRF mode.
· Console line—0 to 1 in standalone mode and 0 to 7 in IRF mode.
· VTY line—0 to 63.
summary: Displays summary information about user lines. If you do not specify this keyword, the detailed information is displayed.
# Display user line information.
<Sysname> display line 0
Idx Type Tx/Rx Modem Auth Int Location
0 CON 0 9600 - N - 0/0
+ : Line is active.
F : Line is active and in async mode.
Idx : Absolute index of line.
Type : Type and relative index of line.
Auth : Login authentication mode.
Int : Physical port of the line.
A : Authentication use AAA.
N : No authentication is required.
P : Password authentication.
Modem |
Whether the modem allows calling in or out. By default, this attribute is not configured and this field displays a hyphen (-). |
Int |
Physical port for the line. If there is no physical port for the line or the line is a console line, this field displays a hyphen (-). |
Location |
Physical position of the line, in the form slot number/CPU number in standalone mode or chassis number/slot number/CPU number in IRF mode. |
# (In standalone mode.) Display summary information about all user lines.
<Sysname> display line summary
Line type : [CON]
0:XX
Line type : [AUX]
2:XX
Line type : [VTY]
4:UUUU UXXX XXXX XXXX
20:XXXX XXXX XXXX XXXX
36:XXXX XXXX XXXX XXXX
52:XXXX XXXX XXXX XXXX
5 lines used. (U)
63 lines not used. (X)
# (In IRF mode.) Display summary information about all user lines.
Line type : [CON]
0:XXXX XXXX
Line type : [AUX]
8:XXXX XXXX
Line type : [VTY]
16:UXXX XXXX XXXX XXXX
32:XXXX XXXX XXXX XXXX
48:XXXX XXXX XXXX XXXX
64:XXXX XXXX XXXX XXXX
1 lines used. (U)
79 lines not used. (X)
Fields |
number:status |
number: Absolute number of the first user line in the user line class. status: User line status. X is for unused and U is for used. For example, if "2:UXXX X" is displayed, there are five user lines of the user line class, which use the absolute numbers 2 through 6. User line 2 is in use, and the other user lines are not. |
display telnet client
Use display telnet client to display the packet source setting for the Telnet client.
# Display the packet source setting for the Telnet client.
<Sysname> display telnet client
The source IP address is 1.1.1.1.
telnet client source
display user-interface
Use display user-interface to display user line information.
display user-interface [ number1 | { aux | console | vty } number2 ] [ summary ]
· VTY line—0 to 63.
This command is an older version reserved for backward compatibility purposes. H3C recommends that you use the display line command.
<Sysname> display user-interface 0
+ : Line is active.
Modem |
Int |
Location |
<Sysname> display user-interface summary
Line type : [CON]
0:XX
Line type : [AUX]
2:XX
Line type : [VTY]
4:UXXX XXXX XXXX XXXX
1 lines used. (U)
67 lines not used. (X)
Line type : [CON]
0:XXXX XXXX
Line type : [AUX]
8:XXXX XXXX
Line type : [VTY]
1 lines used. (U)
Fields |
number:status |
display users
Use display users to display online CLI user information.
display users [ all ]
all: Displays all user lines supported by the device.
# Display online user information.
<Sysname> display users
Idx Line Idle Time Pid Type
10 VTY 0 00:10:49 Jun 11 11:27:32 320 TEL
+ 11 VTY 1 00:00:00 Jun 11 11:39:40 334 TEL
Following are more details.
VTY 0 :
VTY 1 :
+ : Current operation user.
F : Current operation user works in async mode.
The output shows that two users have logged in to the device: one is using user line VTY 0 and the other (yourself) is using VTY 1. Your IP address is 192.168.1.26.
Table 5 Command output
Idx |
Absolute number of the user line. |
Line |
Type and relative number of the user line. |
Idle |
Time elapsed after the user's most recent input, in the hh:mm:ss format. |
Time |
Login time of the user. |
Pid |
Process ID of the user session. |
Type |
User type, such as Telnet, SSH, or PAD. |
User line you are using. |
Location |
IP address of the user. |
escape-key
Use escape-key to set the escape key.
Use undo escape-key to disable the escape key.
escape-key { key-string | default }
undo escape-key
Pressing Ctrl+C terminates a task.
key-string: Specifies a shortcut key. It can be a string of 1 to 3 characters, or an ASCII code value in the range of 0 to 127. If you enter a number that is greater than 127, or enter a string that is not a number, the first character is used as the shortcut key. For example, if you configure escape-key 987, the shortcut key is 9. If you configure escape-key abc, the shortcut key is a.
default: Restores the default escape key sequence Ctrl+C.
You can use this shortcut key to abort a command that is being executed. For example, you can press this shortcut key to abort a ping or tracert command.
Before such a command is completed, you can stop the command by pressing the shortcut key for terminating tasks.
Whether a command can be aborted by Ctrl+C by default depends on the software implementation of the command. For more information, see the usage guidelines for the command.
H3C recommends that you use a key sequence as the shortcut key. If you define a single character as the shortcut key, pressing the key while a command is being executed stops the command. If no command is being executed, the result depends on the following situations:
· If you are managing the local device, pressing the key enters the character as a common character.
· If you Telnet to another device and manage the remote device, pressing the key does not do anything.
If you execute this command multiple times, the most recent setting takes effect. To display the current escape key, use the display current-configuration command.
# Define character a as the escape key for Console 0.
[Sysname-line-console0] escape-key a
1. Ping IP address 192.168.1.49, specifying the -c keyword to set the number of ICMP echo request packets to 20.
<Sysname> ping -c 20 192.168.1.49
PING 192.168.1.49: 56 data bytes, press a to break
Reply from 192.168.1.49: bytes=56 Sequence=1 ttl=255 time=3 ms
Reply from 192.168.1.49: bytes=56 Sequence=2 ttl=255 time=3 ms
2. Press a.
The system aborts the command and returns to user view.
--- 192.168.1.49 ping statistics ---
2 packet(s) transmitted
2 packet(s) received
0.00% packet loss
round-trip min/avg/max = 3/3/3 ms
<Sysname>
flow-control
Use flow-control to configure the flow control mode.
Use undo flow-control to restore the default.
undo flow-control
Flow control is disabled.
User line view
hardware: Performs hardware flow control.
none: Disables flow control.
software: Performs software flow control.
The device supports flow control in both the inbound and outbound directions.
· For flow control in the inbound direction, the local device listens to flow control information from the remote device.
· For flow control in the outbound direction, the local device sends flow control information to the remote device.
The flow control setting takes effect in both directions.
To communicate, two devices must operate in the same flow control mode.
# Configure software flow control in the inbound and outbound directions for the user line Console 0.
[Sysname-line-console0] flow-control software
free line
Use free line to release a user line.
free line { number1 | { aux | console | vty } number2 }
· VTY line—0 to 63.
This command does not release the line you are using.
# Release the user line VTY 1:
1. Display online users.
VTY 0 :
VTY 1 :
2. If the operations of the user on VTY 1 impact your operations, log out the user.
<Sysname> free line vty 1
Are you sure to free line vty1? [Y/N]:y
[OK]
free user-interface
Use free user-interface to release a user line.
free user-interface { number1 | { aux | console | vty } number2 }
· VTY line—0 to 63.
This command is an older version reserved for backward compatibility purposes. H3C recommends you use the free line command.
Idx LINE Idle Time Pid Type
VTY 0 :
VTY 1 :
<Sysname> free user-interface vty 1
[OK]
history-command max-size
Use history-command max-size to set the size of the command history buffer for a user line.
Use undo history-command max-size to restore the default.
history-command max-size size-value
The buffer for a user line saves up to 10 history commands.
size-value: Specifies the maximum number of history commands the buffer can store, in the range of 0 to 256.
Each user line uses a separate command history buffer to save commands successfully executed by its user. The buffer size determines how many history commands the buffer can store.
To display history commands in the buffer for your session, press the up or down arrow key, or execute the display history-command command.
Terminating a CLI session clears the commands in the history buffer.
# Set the command history buffer size to 20 for the user line Console 0.
[Sysname-line-console0] history-command max-size 20
idle-timeout
Use idle-timeout to set the session idle timeout.
Use undo idle-timeout to restore the default.
undo idle-timeout
The idle timeout is 10 minutes.
minutes: Specifies the number of minutes for the idle timeout, in the range of 0 to 35791. The default is 10 minutes.
seconds: Specifies the number of seconds for the idle timeout, in the range of 0 to 59. The default is 0 seconds.
The system automatically terminates a user connection if no information interaction occurs on the connection within the idle timeout.
Setting the idle timeout to 0 disables the idle timeout feature.
# Set the idle timeout to 1 minute and 30 seconds for the user line Console 0.
[Sysname-line-console0] idle-timeout 1 30
line
Use line to enter one or multiple user line views.
line { first-number1 [ last-number1 ] | { aux | console | vty } first-number2 [ last-number2 ] }
first-number1: Specifies the absolute number of the first user line. The following are the value ranges:
last-number1: Specifies the absolute number of the last user line. This number cannot be smaller than first-number1. The following are the value ranges:
· Default MDC—1 to 67 in standalone mode, and 1 to 79 in IRF mode.
· Non-default MDC—1 to 63.
first-number2: Specifies the relative number of the first user line. The following are the value ranges:
· VTY line—0 to 63.
last-number2: Specifies the relative number of the last user line. This number cannot be smaller than first-number2. The following are the value ranges:
· AUX line—1 in standalone mode and 1 to 7 in IRF mode.
· Console line—1 in standalone mode and 1 to 7 in IRF mode.
· VTY line—1 to 63.
To configure settings for a single user line, use this command to enter the user line view.
To configure the same settings for multiple user lines, use this command to enter multiple user line views.
# Enter the view of user line Console 0.
# Enter the views of user lines VTY 0 to VTY 63.
[Sysname] line vty 0 63
[Sysname-line-vty0-63]
line class
line class
Use line class to enter user line class view.
line class { aux | console | vty }
aux: Specifies the AUX line class view. This keyword is supported only on the default MDC.
console: Specifies the console line class view. This keyword is supported only on the default MDC.
vty: Specifies the VTY line class view.
To configure the same settings for all user lines of a line class, use this command to enter the user line class view.
In user line class view, you can execute the following commands:
· activation-key
· auto-execute command
· authentication-mode
· escape-key
· history-command max-size
· idle-timeout
· protocol inbound
· screen-length
· set authentication password
· shell
· terminal type
· user-role
For commands that are available in both user line view and user line class view, the device uses the following rules to determine the settings to be activated:
# Set the user connection timeout to 15 minutes in VTY line class view.
[Sysname] line class vty
[Sysname-line-class-vty] idle-timeout 15
# Set the shortcut key for starting a terminal session to s in console line class view.
[Sysname] line class console
[Sysname-line-class-console] activation-key s
[Sysname-line-class-console] quit
# Restore the default shortcut key for starting a terminal session in console line view.
[Sysname-line-console0] undo activation-key
Alternatively, use the following command:
[Sysname-line-console0] activation-key 13
To check for the setting that takes effect:
<Sysname> quit
3. Press Enter.
4. Enter s.
<Sysname>
line
lock
Use lock to lock the current user line. This method prevents unauthorized users from using the user line.
lock
By default, the system does not lock any user lines.
This command is not supported in FIPS mode.
This command requires you to enter a password for unlocking the user line. The user line is locked after you enter a password and confirm the password.
To unlock the user line, press Enter and enter the correct password.
# Lock the current user line and then unlock it.
<Sysname> lock
Please input password<1 to 16> to lock current line:
Password:
Again:
locked !
// The user line is locked. To unlock it, press Enter and enter the password:
Password:
<Sysname>
parity
Use parity to specify a parity check mode.
Use undo parity to restore the default.
undo parity
The setting is none, and no parity check is performed.
User line view
even: Performs even parity check.
mark: Performs mark parity check.
none: Disables parity check.
odd: Performs odd parity check.
space: Performs space parity check.
The configuration terminal and the device must be configured with the same parity check mode to communicate.
# Configure user line AUX 0 to perform odd parity check.
[Sysname-line-aux0] parity odd
protocol inbound
Use protocol inbound to enable a user line to support Telnet, PAD, SSH, or all three protocols.
Use undo protocol inbound to restore the default.
In non-FIPS mode:
protocol inbound { all | pad | ssh | telnet }
In FIPS mode:
protocol inbound ssh
SSH and Telnet are supported.
VTY line view, VTY line class view
all: Supports all three protocols.
pad: Supports PAD only. This keyword is not supported.
ssh: Supports SSH only.
telnet: Supports Telnet only.
A protocol change does not take effect for current online users. It takes effect only for new login users.
Before configuring a user line to support SSH, set the authentication mode to scheme for the user line. For more information, see authentication-mode.
In VTY line view, this command is associated with the authentication-mode command. If you specify a non-default value for only one of the two commands in VTY line view, the other command uses the default setting, regardless of the setting in VTY line class view.
# Enable user lines VTY 0 through VTY 63 to support only SSH.
[Sysname-line-vty0-63] authentication-mode scheme
[Sysname-line-vty0-63] protocol inbound ssh
# In VTY line class view, enable scheme authentication and support for SSH.
[Sysname-line-class-vty] authentication-mode scheme
[Sysname-line-class-vty] protocol inbound ssh
# In VTY line view, disable authentication.
[Sysname-line-class-vty] line vty 0 63
[Sysname-line-vty0-63] authentication-mode none
1. Telnet to the device.
Trying 192.168.1.241 ...
Connected to 192.168.1.241 ...
* Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved. *
<Server>
You are logged in without authentication.
2. Display online CLI user information.
+ 50 VTY 0 00:00:00 Jan 17 15:29:27 189 TEL
VTY 0 :
The output shows that you are using VTY 0. The configuration in user line view is effective.
screen-length
Use screen-length to set the maximum number of lines to be displayed on a screen.
Use undo screen-length to restore the default.
screen-length screen-length
undo screen-length
Up to 24 lines are displayed on a screen.
screen-length: Specifies the maximum number of lines to be displayed on a screen, in the range of 0 to 512. Setting it to 0 disables pausing between screens of output.
This command sets the maximum number of lines that can be displayed on one screen when the screen pause feature is enabled. If the screen pause feature is disabled, the system displays command output without a pause.
The actual number of lines that can be displayed on a screen is restricted by the display specification of the configuration terminal. For example, if you set the maximum number of lines for a screen to 40, the device sends 40 lines to the screen at a time. If the display specification is 24 lines, only the last 24 lines are displayed on the screen. To view the previous 16 lines, you must press PgUp.
The screen pause feature is enabled by default. To disable this feature, execute the screen-length 0 command or the screen-length disable command.
# Set the maximum number of lines to be displayed on a screen to 30 for the user line Console 0.
[Sysname-line-console0] screen-length 30
send
Use send to send messages to user lines.
send { all | number1 | { aux | console | vty } number2 }
all: Specifies all user lines.
· VTY line—0 to 63.
To end a message, press Enter. To cancel a message and return to user view, press Ctrl+C.
# Before you restart the device, send a notification to VTY 1 to inform the user.
<Sysname> send vty 1
Input message, end with Enter; abort with CTRL+C:
Your attention, please. I will reboot the system in 3 minutes.
Send message? [Y/N]:y
The message should appear on the screen of the user's configuration terminal, as shown in the following example:
[Sysname]
***Message from vty0 to vty1
Use set authentication password to set an authentication password.
Use undo set authentication password to remove the password.
set authentication password { hash | simple } password
No authentication password is set.
hash: Sets a hashed password.
simple: Sets a plaintext password.
password: Specifies the password string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 16 characters. If hash is specified, it must be a string of 1 to 110 characters.
Whether you specify the hash or simple keyword for the command, the password is hashed before being saved.
# Set the authentication password on user line Console 0 to hello.
[Sysname-line-console0] authentication-mode password
[Sysname-line-console0] set authentication password simple hello
When you log in again through user line Console 0, you must enter the password hello to pass authentication.
authentication-mode
shell
Use shell to enable the terminal service for a user line.
Use undo shell to disable the terminal service for a user line.
shell
undo shell
The terminal service is enabled on all user lines.
The undo shell command is not supported in console line view or console line class view.
You cannot disable the terminal service on the user line you are using.
When the device operates as a Telnet or SSH server, you cannot configure the undo shell command.
If the undo shell command is configured in user line class view, you cannot configure the shell command in the view of a user line in the class.
# Disable the terminal service for user lines VTY 0 through VTY 63 so no user can log in to the device through the user lines.
[Sysname-line-vty0-63] undo shell
Disable line-vty0-63 , are you sure? [Y/N]:y
speed
Use speed to set the transmission rate (also called the "baud rate") on a user line.
Use undo speed to restore the default.
speed speed-value
undo speed
The transmission rate is 9600 bps.
User line view
speed-value: Specifies the transmission rate in bps. Supported transmission rates vary by configuration environment. The transmission rates for asynchronous serial interfaces might include:
· 300 bps.
· 600 bps.
· 1200 bps.
· 2400 bps.
· 4800 bps.
· 9600 bps.
· 19200 bps.
· 38400 bps.
· 57600 bps.
· 115200 bps.
The configuration terminal and the device must be configured with the same transmission rate to communicate.
# Set the transmission rate to 19200 bps for the user line AUX 0.
[Sysname-line-aux0] speed 19200
stopbits
Use stopbits to specify the number of stop bits for a character.
Use undo stopbits to restore the default.
stopbits { 1 | 1.5 | 2 }
undo stopbits
One stop bit is used.
User line view
1: Uses one stop bit.
1.5: Uses one and a half stop bits. The device does not support using one and a half stop bits. If you specify this keyword, two stop bits are used.
2: Uses two stop bits.
The configuration terminal and the device must be configured to use the same number of stop bits to communicate.
# Set the number of stop bits to 1 for the user line AUX 0.
[Sysname-line-aux0] stopbits 1
telnet
Use telnet to Telnet to a host in an IPv4 network.
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } ] [ dscp dscp-value ]
remote-host: Specifies the IPv4 address or host name of a remote host. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters for a host name include letters, digits, hyphens (-), underscores (_), and dots (.).
service-port: Specifies the TCP port number for the Telnet service on the remote host. The value range is 0 to 65535 and the default is 23.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the remote host belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the remote host belongs to the public network, do not specify this option.
source: Specifies a source IPv4 address or source interface for outgoing Telnet packets.
interface interface-type interface-number: Specifies the source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies the source IPv4 address for outgoing Telnet packets.
dscp dscp-value: Specifies the DSCP value for IP to use in outgoing Telnet packets to indicate the packet transmission priority. The value range is 0 to 63. The default is 48.
To terminate the current Telnet connection, press Ctrl+K or execute the quit command.
The source address or interface specified by this command is applied only to the current Telnet connection.
# Telnet to host 1.1.1.2, using 1.1.1.1 as the source IP address for outgoing Telnet packets.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
Use telnet client source to specify a source IPv4 address or source interface for outgoing Telnet packets when the device acts as a Telnet client.
Use undo telnet client source to remove the configuration.
No source IPv4 address or source interface is specified for outgoing Telnet packets. The source IPv4 address is the primary IPv4 address of the outbound interface.
interface interface-type interface-number: Specifies a source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies a source IPv4 address.
The setting configured by this command applies to all Telnet connections but has a lower precedence than the source setting specified for the telnet command.
# Set the source IPv4 address for outgoing Telnet packets to 1.1.1.1 when the device acts as a Telnet client.
[Sysname] telnet client source ip 1.1.1.1
display telnet client configuration
telnet ipv6
Use telnet ipv6 to Telnet to a host in an IPv6 network.
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value ]
remote-host: Specifies the IP address or host name of a remote host. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters for a host name include letters, digits, hyphens (-), underscores (_), and dots (.).
-i interface-type interface-number: Specifies the outbound interface for sending Telnet packets. This option is required when the destination address is a link-local address.
port-number: Specifies the TCP port number for the Telnet service on the remote host. The value range is 0 to 65535 and the default is 23.
dscp dscp-value: Specifies the DSCP value for IPv6 to use in outgoing Telnet packets to indicate the packet transmission priority. The value range is 0 to 63. The default is 48.
# Telnet to the host at 5000::1.
<Sysname> telnet ipv6 5000::1
telnet server acl
Use telnet server acl to apply an ACL to filter Telnet logins.
Use undo telnet server acl to restore the default.
telnet server acl acl-number
No ACL is used to filter Telnet logins.
acl-number: Specifies an ACL by its number. The following are the value ranges:
· Basic ACL—2000 to 2999.
· Advanced ACL—3000 to 3999.
· Ethernet frame header ACL—4000 to 4999.
Only one ACL can be used to filter Telnet logins, and only users permitted by the ACL can Telnet to the device.
This command does not take effect on existing Telnet connections.
You can specify an ACL that has not been created yet in this command. The command takes effect after the ACL is created.
For more information about ACL, see ACL and QoS Configuration Guide.
# Permit only the user at 1.1.1.1 to Telnet to the device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 1.1.1.1 0
[Sysname-acl-basic-2001] quit
[Sysname] telnet server acl 2001
telnet server dscp
Use telnet server dscp to set the DSCP value for IPv4 to use for outgoing Telnet packets on a Telnet server.
Use undo telnet server dscp to restore the default.
telnet server dscp dscp-value
IPv4 uses the DSCP value 48 for outgoing Telnet packets on a Telnet server.
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IP packet to indicate the transmission priority of the packet.
# Set the DSCP value for IPv4 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server dscp 30
telnet server ipv6 acl
Use telnet server ipv6 acl to apply an IPv6 ACL to filter IPv6 Telnet logins.
Use undo telnet server ipv6 acl to restore the default.
telnet server ipv6 acl [ ipv6 ] acl-number
No ACL is used to filter IPv6 Telnet logins.
acl-number: Specifies an IPv6 ACL by its number. The following are the value ranges:
· Basic ACL—2000 to 2999. The ipv6 option is required.
· Advanced ACL—3000 to 3999. The ipv6 option is required.
· Ethernet frame header ACL—4000 to 4999. Do not specify the ipv6 option.
If the ACL does not exist or does not have a rule, all users are permitted to Telnet to the device.
When the ACL exists and has rules, only users permitted by the ACL can Telnet to the device.
This command does not take effect for existing Telnet connections.
# Permit only the user at 2000::1 to Telnet to the device.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 2000::1 128
[Sysname-acl6-basic-2001] quit
[Sysname] telnet server ipv6 acl ipv6 2001
telnet server ipv6 dscp
Use telnet server ipv6 dscp to set the DSCP value for IPv6 to use for outgoing Telnet packets on a Telnet server.
Use undo telnet server ipv6 dscp to restore the default.
IPv6 uses the DSCP value 48 for outgoing Telnet packets on a Telnet server.
The DSCP value is carried in the Traffic class field of an IPv6 packet to indicate the transmission priority of the packet.
# Set the DSCP value for IPv6 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server ipv6 dscp 30
telnet server enable
Use telnet server enable to enable the Telnet server feature.
Use undo telnet server enable to disable the Telnet server feature.
The Telnet server feature is disabled.
Administrators can Telnet to the device only when the Telnet server feature is enabled.
# Enable the Telnet server feature.
terminal type
Use terminal type to specify the terminal display type.
Use undo terminal type to restore the default.
undo terminal type
The terminal display type is ANSI.
ansi: Specifies the terminal display type ANSI.
vt100: Specifies the terminal display type VT100.
The device supports two terminal display types: ANSI and VT100. H3C recommends that you set the display type to VT100 on both the device and the configuration terminal. If either side uses the ANSI type, a display problem such as cursor positioning error might occur when a command line has more than 80 characters.
# Set the terminal display type to VT100.
[Sysname-line-vty0] terminal type vt100
user-interface
Use user-interface to enter one or multiple user line views.
user-interface { first-number1 [ last-number1 ] | { aux | console | vty } first-number2 [ last-number2 ] }
· VTY line—0 to 63.
· VTY line—1 to 63.
This command is an older version reserved for backward compatibility purposes. H3C recommends you use the line command.
[Sysname] user-interface console 0
[Sysname] user-interface vty 0 63
user-interface class
Use user-interface class to enter user line class view.
user-interface class { aux | console | vty }
This command is an older version reserved for backward compatibility purposes. H3C recommends you use the line class command.
To configure the same settings for all user lines of a line class, you can use this command to enter the user line class view.
The following commands are available in user line class view:
· activation-key
· escape-key
· idle-timeout
· protocol inbound
· screen-length
· shell
· terminal type
· user-role
[Sysname] user-interface class vty
<Sysname> quit
3. Press Enter.
4. Enter s.
<Sysname>
user-interface
user-role
Use user-role to assign a user role to a user line so users logged in through the user line get the user role at login.
Use undo user-role to remove a user role or restore the default.
user-role role-name
undo user-role [ role-name ]
A console line user of the default MDC is assigned the user role network-admin. Users of other default MDC user lines are assigned the user role network-operator.
A non-default MDC user switched from the default device by using the switchto mdc command is assigned the user role mdc-admin. Other non-default MDC users are assigned the user role mdc-operator.
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be predefined (network-admin, network-operator, mdc-admin, mdc-operator, or level-0 to level-15) or user-defined. If you do not specify this argument for the undo user-role command, the command restores the default user role.
You can assign up to 64 user roles to a user line. A user logged in through the user line gets all the user roles.
For more information about user roles, see "Configuring RBAC."
# Assign user role network-admin through the user line AUX 0.
[Sysname-line-aux0] user-role network-admin
