05-Layer 3 - IP Routing Configuration Examples
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Typical Configuration Example-R7328P02-6W10005-Layer 3 - IP Routing Configuration Examples
00-H3C S12500 OSPF Configuration Examples
00-H3C S12500 OSPF Configuration Examples 105 KB
Introduction
This document provides OSPF route filtering configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of OSPF route filtering.
Example: Configuring OSPF route filtering
Network requirements
As shown in Figure 1, the devices of an enterprise reside in OSPF and RIP domains.
Configure route redistribution between OSPF and RIP to interconnect the devices.
Configure route filtering on Device E, Device C, and Device D to meet the following requirements:
·     The route destined for R&D department 2 is not redistributed to OSPF.
·     Marketing department 1 cannot reach R&D department 1.
·     R&D department 1 and the After-sale service department cannot reach Marketing department 2.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
Vlan-int100
10.1.1.1/24
Device B
Vlan-int100
10.1.1.2/24
Vlan-int200
10.2.1.1/24
Vlan-int300
10.3.1.1/24
Vlan-int400
10.4.1.1/24
Device C
Vlan-int200
10.2.1.2/24
Device D
Vlan-int300
10.3.1.2/24
Loop0
192.168.3.1/24
Loop0
192.168.1.1/24
Loop1
192.168.2.1/24
Device E
Vlan-int400
10.4.1.2/24
Device F
Vlan-int500
10.5.1.2/24
Vlan-int500
10.5.1.1/24
Loop0
192.168.4.1/24
Loop1
192.168.5.1/24
Software version used
This configuration example was created and verified on S12500-CMW710-R7328P02.
When you configure OSPF route filtering, follow these restrictions and guidelines:
·     The filter-policy export command that filters redistributed routes takes effect only on an ASBR.
·     OSPF filters routes calculated using received LSAs. It does not filter LSAs.
·     IP communication is bidirectional. If a router filters a route destined for Network A, the subnets attached to the router cannot reach Network A, and Network A cannot reach the subnets.
·     When you configure route filtering by referencing an ACL, configure the rule permit source any item following multiple rule deny source items to allow unmatched routes to pass.
Configuration procedures
Configuring IP addresses
# Configure an IP address for VLAN-interface 100.
[DeviceA] interface Vlan-interface 100
[DeviceA-Vlan-interface100] ip address 10.1.1.1 24
# Configure IP addresses for other interfaces, as shown in Figure 1. (Details not shown.)
Configuring OSPF
# Enable OSPF on Device A.
[DeviceA] ospf
[DeviceA-ospf-1] area 0
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] quit
[DeviceA-ospf-1] area 2
[DeviceA-ospf-1-area-0.0.0.2] network 10.2.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.2] quit
[DeviceA-ospf-1] area 1
[DeviceA-ospf-1-area-0.0.0.1] network 10.4.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.1] quit
[DeviceA-ospf-1] quit
# Enable OSPF on Device B.
[DeviceB] ospf
[DeviceB-ospf-1] area 0
[DeviceB-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] quit
[DeviceB-ospf-1] area 3
[DeviceB-ospf-1-area-0.0.0.3] network 10.3.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.3] quit
[DeviceB-ospf-1] quit
# Enable OSPF on Device C.
<DeviceC> system-view
[DeviceC] ospf
[DeviceC-ospf-1] area 2
[DeviceC-ospf-1-area-0.0.0.2] network 10.2.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.2] network 192.168.3.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.2] quit
[DeviceC-ospf-1] quit
# Enable OSPF on Device D.
<DeviceD> system-view
[DeviceD] ospf
[DeviceD-ospf-1] area 3
[DeviceD-ospf-1-area-0.0.0.3] network 10.3.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.3] network 192.168.1.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.3] network 192.168.2.0 0.0.0.255
[DeviceD-ospf-1-area-0.0.0.3] quit
[DeviceD-ospf-1] quit
# Enable OSPF on Device E.
<DeviceE> system-view
[DeviceE] ospf
[DeviceE-ospf-1] area 1
[DeviceE-ospf-1-area-0.0.0.1] network 10.4.1.0 0.0.0.255
[DeviceE-ospf-1-area-0.0.0.1] quit
[DeviceE-ospf-1] quit
Configure RIP
# Enable RIP on Device E.
[DeviceE] rip
[DeviceE-rip-1] version 2
[DeviceE-rip-1] undo summary
[DeviceE-rip-1] network 10.5.1.0 0.0.0.255
[DeviceE-rip-1] quit
# Enable RIP on Device F.
<DeviceF> system-view
[DeviceF] rip
[DeviceF-rip-1] version 2
[DeviceF-rip-1] undo summary
[DeviceF-rip-1] network 10.5.1.0 0.0.0.255
[DeviceF-rip-1] network 192.168.4.0 0.0.0.255
[DeviceF-rip-1] quit
Configuring route redistribution
# Configure Device E to redistribute OSPF and direct routes to RIP.
[DeviceE] rip
[DeviceE-rip-1] import-route direct
[DeviceE-rip-1] import-route ospf
# Configure Device E to redistribute RIP and direct routes to OSPF.
[DeviceE] ospf
[DeviceE-ospf-1] import-route direct
[DeviceE-ospf-1] import-route rip
# Verify that Device E has routes to all networks.
[DeviceE] display ip routing-table
Destinations : 24        Routes : 24
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
10.1.1.0/24         OSPF   10   2            10.4.1.1        Vlan400
10.2.1.0/24         OSPF   10   2            10.4.1.1        Vlan400
10.3.1.0/24         OSPF   10   3            10.4.1.1        Vlan400
10.4.1.0/24         Direct 0    0            10.4.1.2        Vlan400
10.4.1.0/32         Direct 0    0            10.4.1.2        Vlan400
10.4.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.4.1.255/32       Direct 0    0            10.4.1.2        Vlan400
10.5.1.0/24         Direct 0    0            10.5.1.1        Vlan500
10.5.1.0/32         Direct 0    0            10.5.1.1        Vlan500
10.5.1.1/32         Direct 0    0            127.0.0.1       InLoop0
10.5.1.255/32       Direct 0    0            10.5.1.1        Vlan500
127.0.0.0/32        Direct 0    0            127.0.0.1       InLoop0
192.168.1.1/32      OSPF   10   3            10.4.1.1        Vlan400
192.168.2.1/32      OSPF   10   3            10.4.1.1        Vlan400
192.168.3.1/32      OSPF   10   2            10.4.1.1        Vlan400
192.168.4.0/24      RIP    100  1            10.5.1.2        Vlan500
192.168.5.0/24      RIP    100  1            10.5.1.2        Vlan500
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
# Verify that other devices have routes to all networks. (Details not shown.)
# On Device C, configure IPv4 basic ACL 2000 to deny 192.168.2.0/24.
[DeviceC] acl number 2000
[DeviceC-acl-basic-2000] rule 0 deny source 192.168.2.0 0.0.0.255
[DeviceC-acl-basic-2000] rule permit source any
[DeviceC-acl-basic-2000] quit
# On Device C, use ACL 2000 to filter received routes.
[DeviceC] ospf
[DeviceC-ospf-1] filter-policy 2000 import
# On Device D, configure IPv4 basic ACL 2000 to deny 192.168.5.0/24.
[DeviceD] acl number 2000
[DeviceD-acl-basic-2000] rule 0 deny source 192.168.5.0 0.0.0.255
[DeviceD-acl-basic-2000] rule permit source any
[DeviceD-acl-basic-2000] quit
# On Device D, use ACL 2000 to filter received routes.
[DeviceD] ospf
[DeviceD-ospf-1] filter-policy 2000 import
# On Device E, configure IPv4 basic ACL 2000 to deny 192.168.4.0/24.
[DeviceE] acl number 2000
[DeviceE-acl-basic-2000] rule 0 deny source 192.168.4.0 0.0.0.255
[DeviceE-acl-basic-2000] rule permit source any
[DeviceE-acl-basic-2000] quit
# On Device E, use ACL 2000 to filter routes redistributed from RIP.
[DeviceE] ospf
[DeviceE-ospf-1] filter-policy 2000 export rip 1
# Verify that Device C does not have a route to 192.168.2.0/24.
[DeviceC] display ip routing-table
Destinations : 22        Routes : 22
10.1.1.0/24         OSPF   10   2            10.2.1.1        Vlan200
10.2.1.0/24         Direct 0    0            10.2.1.2        Vlan200
10.2.1.0/32         Direct 0    0            10.2.1.2        Vlan200
10.2.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.2.1.255/32       Direct 0    0            10.2.1.2        Vlan200
10.3.1.0/24         OSPF   10   3            10.2.1.1        Vlan200
10.4.1.0/24         OSPF   10   2            10.2.1.1        Vlan200
10.5.1.0/24         OSPF   150  1            10.2.1.1        Vlan200
192.168.1.1/32      OSPF   10   3            10.2.1.1        Vlan200
192.168.3.0/24      Direct 0    0            192.168.3.1     Loop0
192.168.3.0/32      Direct 0    0            192.168.3.1     Loop0
192.168.3.1/32      Direct 0    0            127.0.0.1       InLoop0
192.168.3.255/32    Direct 0    0            192.168.3.1     Loop0
192.168.5.0/24      OSPF   150  1            10.2.1.1        Vlan200
# Verify that Marketing department 1 cannot reach R&D department 1.
[DeviceC] ping -a 192.168.3.1 192.168.2.1
Ping 192.168.2.1 (192.168.2.1) from 192.168.3.1: 56 data bytes, press CTRL_C to
break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 192.168.2.1 ---
5 packet(s) transmitted, 0 packet(s) received, 100.0% packet loss
# Verify that Device D does not have a route to 192.168.5.0/24.
[DeviceD] display ip routing-table
Destinations : 25        Routes : 25
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
10.1.1.0/24         OSPF   10   2            10.3.1.1        Vlan300
10.2.1.0/24         OSPF   10   3            10.3.1.1        Vlan300
10.3.1.0/24         Direct 0    0            10.3.1.2        Vlan300
10.3.1.0/32         Direct 0    0            10.3.1.2        Vlan300
10.3.1.2/32         Direct 0    0            127.0.0.1       InLoop0
10.3.1.255/32       Direct 0    0            10.3.1.2        Vlan300
10.4.1.0/24         OSPF   10   3            10.3.1.1        Vlan300
10.5.1.0/24         OSPF   150  1            10.3.1.1        Vlan300
192.168.1.0/24      Direct 0    0            192.168.1.1     Loop0
192.168.1.0/32      Direct 0    0            192.168.1.1     Loop0
192.168.1.1/32      Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.1     Loop0
192.168.2.0/24      Direct 0    0            192.168.2.1     Loop1
192.168.2.0/32      Direct 0    0            192.168.2.1     Loop1
192.168.2.1/32      Direct 0    0            127.0.0.1       InLoop0
192.168.2.255/32    Direct 0    0            192.168.2.1     Loop1
192.168.3.1/32      OSPF   10   3            10.3.1.1        Vlan300
# Verify that the After-sale service department cannot reach Marketing department 2.
[DeviceD] ping -a 192.168.1.1 192.168.5.1
Ping 192.168.5.1 (192.168.5.1) from 192.168.1.1: 56 data bytes, press CTRL_C to
break
Request time out
Request time out
Request time out
Request time out
Request time out
--- Ping statistics for 192.168.5.1 ---
# Verify that R&D department 1 cannot reach Marketing department 2.
[DeviceD] ping -a 192.168.2.1 192.168.5.1
Ping 192.168.5.1 (192.168.5.1) from 192.168.2.1: 56 data bytes, press CTRL_C to
break
Request time out
Request time out
Request time out
Request time out
Request time out
The output on Device C and Device D shows that Device E has filtered the route destined for R&D development 2.
Configuration files
·     Device A:
ospf 1
 area 0.0.0.0
 area 0.0.0.1
area 0.0.0.2
vlan 100
vlan 200
vlan 400
interface Vlan-interface100
interface Vlan-interface200
 ip address 10.2.1.1 255.255.255.0
interface Vlan-interface400
 ip address 10.4.1.1 255.255.255.0
·     Device B:
ospf 1
 area 0.0.0.0
 area 0.0.0.3
vlan 100
vlan 300
interface Vlan-interface300
 ip address 10.3.1.1 255.255.255.0
·     Device C:
ospf 1
 area 0.0.0.2
vlan 200
interface LoopBack0
 ip address 192.168.3.1 255.255.255.0
 ip address 10.2.1.2 255.255.255.0
acl number 2000
rule 5 permit
·     Device D:
ospf 1
 area 0.0.0.3
vlan 300
interface LoopBack0
interface LoopBack1
 ip address 192.168.2.1 255.255.255.0
 ip address 10.3.1.2 255.255.255.0
acl number 2000
rule 5 permit
·     Device E:
ospf 1
 import-route direct
 import-route rip 1
 area 0.0.0.1
rip 1
 undo summary
 version 2
 import-route direct
 import-route ospf 1
vlan 400
vlan 500
 ip address 10.4.1.2 255.255.255.0
interface Vlan-interface500
 ip address 10.5.1.1 255.255.255.0
acl number 2000
rule 5 permit
·     Device F:
rip 1
 undo summary
 version 2
 network 192.168.4.0
 network 192.168.5.0
vlan 500
interface LoopBack0
 ip address 192.168.4.1 255.255.255.0
interface LoopBack1
 ip address 192.168.5.1 255.255.255.0
 ip address 10.5.1.2 255.255.255.0
Related documentation
·     H3C S12500 Routing Switch Series Layer 3IP Routing Command Reference-Release 7328
·     H3C S12500 Routing Switch Series Layer 3IP Routing Configuration Guide-Release 7328
