13-Network Management and Monitoring Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18213-Network Management and Monitoring Command Reference
12-sFlow Commands
12-sFlow Commands 90.75 KB
sFlow configuration commands
display sflow
Standalone mode:
display sflow [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF mode:
display sflow [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Displays the sFlow configuration and operation information for the interface card specified by the slot number. (Standalone mode.)
chassis chassis-number slot slot-number: Displays the sFlow configuration and operation information for a card on an IRF member switch. The chassis-number argument refers to the ID of the IRF member switch. The slot-number argument refers to the number of the slot where the card resides. (IRF mode.)
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive  string of 1 to 256 characters.
Use display sflow to display the sFlow configuration and operation information.
# Display the sFlow configuration and operation information.
<Sysname> display sflow slot 2
sFlow Version: 5
sFlow Global Information:
Agent        IP:10.10.10.1 (Auto)
Collector Information
ID    IP              Port  Aging      Size VPN-instance Description
1     22:2:20::10     6343  N/A        1400 aaa          CLI Collector
2     192.168.3.5     6343  N/A        1400              netserver
3                     6343  N/A        1400
4                     6343  N/A        1400
5                     6343  N/A        1400
6                     6343  N/A        1400
7                     6343  N/A        1400
8                     6343  N/A        1400
9                     6343  N/A        1400
10                    6343  N/A        1400
sFlow Port Information:
Interface  CID    Interval(s)  FID MaxHLen   Rate       Mode        Status
GE3/0/1     1     100          1   128       1000       Determine   Active
GE3/0/2     2     100          2   128       1000       Determine   Active
sFlow Version
sFlow has the following versions:
·     4sFlow version 4.
·     5sFlow version 5.
sFlow global configuration information.
Agent
IP address of the sFlow agent:
·     CLIManually configured IP address.
·     AutoAutomatically obtained IP address.
Source Address
Source IP address of sent sFlow packets.
sFlow collector information.
ID
sFlow collector ID.
IP
IP address of the sFlow collector that receives sFlow packets.
Port
Number of the port receiving sFlow packets on the sFlow collector.
Aging
Remaining lifetime of the sFlow collector. If N/A is displayed, the sFlow collector is not aged out.
Size
Maximum length of the sFlow data portion in every sFlow packet that is sent out.
VPN-instance
Name of the VPN bound with the sFlow collector.
Description of the sFlow collector.
Information of the ports enabled with sFlow.
sFlow enabled interface.
CID
ID of the target collector for receiving the counter sampling data.
Interval(s)
Counter sampling interval, in seconds.
FID
ID of the target collector for receiving the flow sampling data.
MaxHLen
Maximum number of bytes of data copied from the original packet during header analysis.
Rate
Packet sampling rate.
Mode
Packet sampling mode:
·     DetermineSamples a fixed number of packets.
·     RandomSamples a random number of packets.
Status
Status of the sFlow enabled port:
·     Suspend—The port is down.
·     Active—The port is up.
sflow agent
sflow agent { ip ip-address | ipv6 ipv6-address }
undo sflow agent { ip | ipv6 }
View
Default level
2: System level
ip ip-address: Specifies the IPv4 address of the sFlow agent.
ipv6 ipv6-address: Specifies the IPv6 address of the sFlow agent.
Use sflow agent to configure the IP address of the sFlow agent.
Use undo sflow agent to remove the configured IP address.
By default, no IP address is configured for the sFlow agent. The device periodically checks whether the sFlow agent has an IP address. If not, the device automatically selects an IPv4 address for the sFlow agent but does not save the IPv4 address in the configuration file.
Note the following:
·     H3C recommends manually configuring an IP address for the sFlow agent.
·     Only one IP address can be specified for the sFlow agent on the switch.
# Configure the IP address of the sFlow agent.
[Sysname] sflow agent ip 10.10.10.1
sflow collector
sflow collector collector-id { [ vpn-instance vpn-instance-name ] { ip ip-address | ipv6 ipv6-address } | datagram-size size | description text | port port-number | timeout seconds } *
undo sflow collector collector-id
View
Default level
2: System level
collector-id: Specifies the ID of the sFlow collector, in the range of 1 to 10.
vpn-instance vpn-instance-name: Specifies the VPN instance of the sFlow collector by name, a case-sensitive string of 1 to 31 characters that cannot contain spaces. By default, the sFlow collector belongs to the public network.
ip ip-address: Specifies the IPv4 address of the sFlow collector.
ipv6 ipv6-address: Specifies the IPv6 address of the sFlow collector.
description text: Specifies a description for the sFlow collector. The default description is "CLI Collector."
datagram-size size: Specifies the maximum length of the sFlow data portion in every sFlow packet that is sent out. The value range for the size argument is 200 to 3000 bytes, and the default is 1400 bytes.
port port-number: Specifies the port number of the sFlow collector, in the range of 1 to 65535. The default port number is 6343.
timeout seconds: Specifies the aging time of the sFlow collector, in the range of 60 to 2147483647 seconds. By default, the sFlow collector is not aged out. When the aging time expires, all fields of the collector restore the default. The system does not save the configuration of collectors with the aging time specified.
Use sflow collector to configure an sFlow collector.
Use undo sflow collector to remove a specified sFlow collector.
By default, the switch presets some empty collectors.
To display the information of the preset sFlow collectors, use the display sflow command.
# Specify collector 2's destination IP address as 3.3.3.1, port number as default, description as netserver, aging time as 1200 seconds, and maximum length of the sFlow data portion as 1000 bytes.
[Sysname] sflow collector 2 ip 3.3.3.1 description netserver timeout 1200 datagram-size 1000
sflow counter interval
sflow counter interval interval-time
undo sflow counter interval
View
Interface view
Default level
2: System level
interval-time: Specifies the counter sampling interval in the range of 2 to 86400 seconds.
Use sflow counter interval to set the counter sampling interval.
Use undo sflow counter interval to disable sFlow counter sampling.
By default, counter sampling is disabled.
This command is supported on Ethernet interfaces only, instead of logical interfaces (such as VLAN interfaces and Layer 3 aggregate interfaces) and network management ports.
# Set the counter sampling interval to 120 seconds on GigabitEthernet 3/0/1.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] sflow counter interval 120
sflow counter collector
sflow counter collector collector-id
undo sflow counter collector
View
Interface view
Default level
2: System level
collector-id: Specifies the ID of the sFlow collector.
Use sflow counter collector to specify the target collector to receive the counter sampling data.
Use undo sflow counter collector to remove the collector for counter sampling.
By default, no collector is specified for counter sampling.
# Specify sFlow collector 2 on GigabitEthernet 3/0/1 for counter sampling.
[Sysname-GigabitEthernet3/0/1] sflow counter collector 2
sflow flow collector
sflow flow collector collector-id
undo sflow flow collector
View
Interface view
Default level
2: System level
Use sflow flow collector to specify the target collector to receive the flow sampling data.
Use undo sflow flow collector to remove the binding between the flow sampling and the collector.
By default, flow sampling is not bound with any collector.
This command is available only on Ethernet interfaces. You cannot use it on VLAN interfaces, Layer 3 aggregate interfaces, and the management Ethernet interface.
# Specify sFlow collector 2 on GigabitEthernet 3/0/1 for flow sampling.
[Sysname-GigabitEthernet3/0/1] sflow flow collector 2
sflow flow max-header
sflow flow max-header length
undo sflow flow max-header
View
Interface view
Default level
2: System level
Length: Specifies the maximum bytes of data that can be copied from a sampled packet. The value range is 18 to 512.
Use sflow flow max-header to set the maximum bytes of data that can be copied from a sampled packet.
Use undo sflow flow max-header to restore the default.
By default, up to 128 bytes of data starting from the original packet header can be copied from a sampled packet. H3C recommends using the default setting.
# Set the maximum bytes of data that can be copied form a sampled packet to 60.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] sflow flow max-header 60
sflow sampling-mode
sflow sampling-mode { determine | random }
undo sflow sampling-mode
View
Interface view
Default level
2: System level
determine: Specifies the fixed sampling mode. For example, if the flow sampling interval is set to 4000 (by using the sflow sampling-rate command), the switch randomly samples a packet, like the tenth packet, from the first 4000 packets. The next time the switch samples the 4010th packet, and so on.
random: Specifies the random sampling mode. For example, if the packet sampling interval is set to 4000, the device might sample one packet from the first 4000 packets, multiple packets from the next 4000 packets, and none from the third 4000 packets, randomly. But generally the device samples one packet from 4000 packets on the average. The random sampling mode is not supported in the current software. This keyword is reserved for future support.
Use sflow sampling-mode to specify the fixed sampling mode.
Use undo sflow sampling-mode to restore the default.
By default, the fixed sampling mode is used.
Related commands: sflow sampling-rate.
# Configure the interface to sample a fixed number of packets.
[Sysname-GigabitEthernet3/0/1] sflow sampling-mode determine
sflow sampling-rate
sflow sampling-rate rate
undo sflow sampling-rate
View
Interface view
Default level
2: System level
rate: Specifies the number of packets out of which the interface will sample a packet. The value range is 512 to 1048576.
Use sflow sampling-rate to specify the number of packets out of which the interface will sample a packet.
Use undo sflow sampling-rate to disable sampling.
By default, flow sampling is disabled.
Related commands: sflow sampling-mode.
# Set the flow sampling rate to 4000 on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] sflow sampling-rate 4000
sflow source
sflow source { ip ip-address | ipv6 ipv6-address } *
undo sflow source { ip | ipv6 } *
View
Default level
2: System level
ip ip-address: Specifies the source IPv4 address of sent sFlow packets.
ipv6 ipv6-address: Specifies the source IPv6 address of sent sFlow packets.
Use sflow source to specify the source IP address of sent sFlow packets.
Use undo sflow source to remove the specified source IP address.
By default, no source IP address is specified for sent sFlow packets.
# Specify the source IPv4 address of sent sFlow packets as 10.0.0.1.
[Sysname] sflow source ip 10.0.0.1
