13-Network Management and Monitoring Command Reference
HomeSupportSwitchesS9500E SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18213-Network Management and Monitoring Command Reference
02-NQA Commands
02-NQA Commands 299.23 KB
NQA configuration commands 1
NQA client configuration commands 1
advantage-factor 1
codec-type· 1
data-fill 2
data-size· 3
description (any NQA test type view) 4
destination ip· 4
destination port 5
display nqa history· 6
display nqa reaction counters 7
display nqa result 9
display nqa statistics 13
filename· 19
frequency· 20
history-record enable· 20
history-record keep-time· 21
history-record number 22
http-version· 22
mode· 23
next-hop· 24
nqa· 24
nqa agent enable· 25
nqa agent max-concurrent 25
nqa schedule· 26
operation (FTP test type view) 27
operation (HTTP test type view) 28
operation interface· 28
password (FTP test type view) 29
probe count 29
probe packet-interval 30
probe packet-number 31
probe packet-timeout 32
probe timeout 32
reaction checked-element icpif 33
reaction checked-element { jitter-ds | jitter-sd } 34
reaction checked-element mos 35
reaction checked-element { owd-ds | owd-sd } 36
reaction checked-element packet-loss 37
reaction checked-element probe-duration· 38
reaction checked-element probe-fail (for trap) 40
reaction checked-element probe-fail (for trigger) 41
reaction checked-element rtt 42
reaction trap· 43
resolve-target 44
route-option bypass-route· 44
source interface· 45
source ip· 46
source port 46
statistics hold-time· 47
statistics max-group· 48
statistics interval 48
tos 49
ttl 50
type· 50
url 51
username (FTP test type view) 52
vpn-instance (ICMP echo test type view) 52
NQA server configuration commands 53
display nqa server status 53
nqa server enable· 54
nqa server tcp-connect 54
nqa server udp-echo· 55
advantage-factor
advantage-factor factor
undo advantage-factor
View
Voice test type view
Default level
2: System level
factor: Advantage factor, used to count Mean Opinion Scores (MOS) and Calculated Planning Impairment Factor (ICPIF) values, in the range of 0 to 20.
Use advantage-factor to configure the advantage factor that is used to count MOS and ICPIF values.
Use undo advantage-factor to restore the default.
By default, the advantage factor is 0.
The evaluation of voice quality depends on users' sensitivity to voice quality, and this factor should be taken into consideration. For users with a lower sensitivity to voice quality, use the advantage-factor command to configure the advantage factor. When the system calculates the ICPIF value, this advantage factor is subtracted to modify ICPIF and MOS values and both the objective and subjective factors are considered when you evaluate the voice quality.
# Configure the advantage factor for a voice test as 10.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test] type voice
[Sysname-nqa-admin-test-voice] advantage-factor 10
codec-type
codec-type { g711a | g711u | g729a }
undo codec-type
View
Default level
2: System level
g711a: G.711 A-law codec type.
g711u: G.711 µ-law codec type.
g729a: G.729 A-law codec type.
Use codec-type to configure the codec type for a voice test.
Use undo codec-type to restore the default.
By default, the codec type for a voice test is G.711 A-law.
# Configure the codec type for a voice test as g729a.
[Sysname-nqa-admin-test-voice] codec-type g729a
data-fill
data-fill string
undo data-fill
View
ICMP echo, UDP echo, UDP jitter, voice test type view
Default level
2: System level
string: A case-sensitive string of 1 to 200 characters.
Use data-fill to configure the string to be filled in the data field of a probe packet.
Use undo data-fill to restore the default.
By default, the string is the hexadecimal number 00010203040506070809.
If the data field length is smaller than the string length, only the first part of the string is filled. For example, if you configure the string as abcd and the data field size as 3 bytes, abc is filled.
If the data field length is greater than the string length, the system fills the data field with the string cyclically until the data field is full. For example, if you configure the string as abcd and the data field size as 6 bytes, abcdab is filled.
How the string is filled varies with test types:
·     For ICMP echo tests, the string fills the whole data field of ICMP echo requests.
·     For UDP echo tests, the first 5 bytes of the data field of a UDP packet are for special purpose, so the string fills the remaining part of data field.
·     For UDP jitter tests, the first 68 bytes of the data field of a UDP packet are for special purpose, so the string fills the remaining part of the data field.
·     For voice tests, the first 16 bytes of the data field of a UDP packet are for special purpose, so the string fills the remaining part of the data field.
# Configure string abcd to be filled in the data field of an ICMP echo request.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] data-fill abcd
data-size
data-size size
undo data-size
View
Default level
2: System level
size: Size of the data field in a probe packet in bytes. It is in the range of 20 to 8100 for probe packets of ICMP echo or UDP echo tests, from 68 to 8100 for probe packets of UDP jitter tests, and from 16 to 1500 for probe packets of voice tests.
Use data-size to configure the size of the data field in each ICMP echo request of the ICMP echo tests or in each UDP packet of UDP echo, UDP jitter, or voice tests.
Use undo data-size to restore the default.
Table 1 Default values of the size of a probe packet
Test type
Codec type
Default value (in bytes)
ICMP echo
N/A
100
UDP echo
N/A
100
UDP jitter
N/A
100
Voice
G.711 A-law
172
Voice
G.711 µ-law
172
Voice
G.729 A-law
32
# Configure the size of the data field in an ICMP echo request as 80 bytes.
[Sysname-nqa-admin-test-icmp-echo] data-size 80
View
Any NQA test type view
Default level
2: System level
text: A case-sensitive string of 1 to 200 characters, used to describe a test group.
Use description to give a brief description of a test group, usually, the test type or test purpose of a test group.
Use undo description to remove the configured description information.
By default, no descriptive string is available for a test group.
# Configure the descriptive string for a test group as icmp-probe.
[Sysname-nqa-admin-test-icmp-echo] description icmp-probe
destination ip
destination ip ip-address
undo destination ip
View
DLSw, FTP, DNS, HTTP, ICMP echo, SNMP, TCP, UDP echo, UDP jitter, voice test type view
Default level
2: System level
ip-address: Destination IP address of a test operation.
Use destination ip to configure a destination IP address for a test operation.
Use undo destination ip to remove the configured destination IP address.
By default, no destination IP address is configured for a test operation.
# Configure the destination IP address of an ICMP echo test operation as 10.1.1.1.
[Sysname-nqa-admin-test-icmp-echo] destination ip 10.1.1.1
destination port
destination port port-number
undo destination port
View
Default level
2: System level
port-number: Destination port number of a test operation, in the range of 1 to 65535.
Use destination port to configure a destination port number for a test operation.
Use undo destination port to remove the configured destination port number.
By default, no destination port number is configured for a test operation.
Do not perform a UDP jitter test and a voice test on ports from 1 to 1023 (well-known ports). Otherwise, the NQA test fails or the corresponding services of this port are unavailable.
# Configure the destination port number of a test operation as 9000.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] destination port 9000
display nqa history
display nqa history [ admin-name operation-tag ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
admin-name operation-tag: Displays history records of an NQA test group. If these two arguments are not specified, history records of all test groups are displayed. The admin-name argument represents the name of the NQA test group administrator who creates the NQA operation. It is a case-insensitive string of 1 to 32 characters. The operation-tag argument represents the test operation tag. It is a case-insensitive string of 1 to 32 characters.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display nqa history to display history records of the specified or all NQA test groups.
The display nqa history command cannot show you the results of voice tests and UDP jitter tests. To know the result of a voice test or a UDP jitter test, use the display nqa result command to view the probe results of the latest NQA test, or use the display nqa statistics command to view the statistics of NQA tests.
# Display the history records of the NQA test group in which the administrator name is administrator, and the operation tag is test.
<Sysname> display nqa history administrator test
  NQA entry (admin administrator, tag test) history record(s):
    Index      Response     Status           Time
    10         329          Succeeded        2007-04-29 20:54:26.5
    9          344          Succeeded        2007-04-29 20:54:26.2
    8          328          Succeeded        2007-04-29 20:54:25.8
    7          328          Succeeded        2007-04-29 20:54:25.5
    6          328          Succeeded        2007-04-29 20:54:25.1
    5          328          Succeeded        2007-04-29 20:54:24.8
    4          328          Succeeded        2007-04-29 20:54:24.5
    3          328          Succeeded        2007-04-29 20:54:24.1
    2          328          Succeeded        2007-04-29 20:54:23.8
    1          328          Succeeded        2007-04-29 20:54:23.4
Index
History record number.
Response
Round-trip delay of a test packet in the case of a successful test, timeout time in the case of timeout, or 0 in the case that a test cannot be completed (in milliseconds).
Status
Status value of test results:
·     Succeeded.
·     Unknown error.
·     Internal error.
·     Timeout.
Time
Time when the test is completed.
display nqa reaction counters [ admin-name operation-tag [ item-number ] ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
admin-name operation-tag: Displays current monitoring results of reaction entries in a test group. If these two arguments are not specified, monitoring results of all reaction entries of all test groups are displayed. The admin-name argument represents the name of the NQA test group administrator who creates the NQA operation. It is a case-insensitive string of 1 to 32 characters. The operation-tag argument represents the test operation tag. It is a case-insensitive string of 1 to 32 characters.
item-number: Displays current monitoring results of the specified reaction entry. If this argument is not provided, results of all reaction entries are displayed. The item-number argument represents the ID of the reaction entry, in the range 1 to 10.
Use display nqa reaction counters to display the current monitoring results of reaction entries.
If the threshold type is average value, or the monitored element is ICPIF or MOS in a voice test, the monitoring results are invalid.
The monitoring results are accumulated since the test group starts and are not cleared after the test completes.
# Display the monitoring results of all reaction entries in an ICMP echo test group, in which the administrator name is admin, and the operation tag is test.
<Sysname> display nqa reaction counters admin test
  NQA entry (admin admin, tag test) reaction counters:
    Index  Checked Element  Threshold Type  Checked Num  Over-threshold Num
    1      probe-duration   accumulate      12           4
    2      probe-duration   average         -            -
    3      probe-duration   consecutive     160          56
    4      probe-fail       accumulate      12           0
    5      probe-fail       consecutive     162          2
Index
ID of a reaction entry.
Checked Element
Monitored element.
Threshold Type
Threshold type.
Checked Num
Number of targets that have been monitored for data collection.
Over-threshold Num
Number of threshold violations.
Table 4 Description on the threshold monitoring fields of the display nqa reaction counters command
Monitored element
Threshold type
Collect data in
Checked Num
Over-threshold Num
probe-duration
accumulate
Probes since the group starts
Number of finished probes since the test group starts
Number of probes of which the duration exceeds the threshold since the test group starts
average
N/A
N/A
N/A
consecutive
Probes since the test group starts
probe-fail
accumulate
Number of probe failures since the test group starts
consecutive
RTT
accumulate
Packets sent since the test group starts
Number of packets sent since the test group starts
Number of packets of which the round-trip time exceeds the threshold since the test group starts
average
N/A
N/A
N/A
jitter-DS/jitter-SD
accumulate
Number of packets of which the one-way delay jitter exceeds the threshold since the test group starts
average
N/A
N/A
N/A
OWD-DS/OWD-SD
N/A
Number of packets of which the one-way delay exceeds the threshold since the test group starts
packet-loss
accumulate
Total packet loss since the test group starts
ICPIF
N/A
N/A
N/A
N/A
MOS
N/A
N/A
N/A
N/A
display nqa result
display nqa result [ admin-name operation-tag ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
admin-name operation-tag: Displays results of the last test of a test group. If these two arguments are not specified, results of the last tests of all test groups are displayed. The admin-name argument represents the name of the NQA test group administrator who creates the NQA operation. It is a case-insensitive string of 1 to 32 characters. The operation-tag argument represents the test operation tag. It is a case-insensitive string of 1 to 32 characters.
Use display nqa result to display results of the last NQA test.
# Display the results of the last UDP jitter test.
<Sysname> display nqa result admin test
  NQA entry (admin admin, tag test) test results:
    Destination IP address: 192.168.1.42
      Send operation times: 10             Receive response times: 10
      Min/Max/Average round trip time: 15/46/26
      Square-Sum of round trip time: 8103
      Last succeeded probe time: 2008-05-29 10:56:38.7
    Extended results:
      Packet loss in test: 0%
      Failures due to timeout: 0
      Failures due to disconnect: 0
      Failures due to no connection: 0
      Failures due to sequence error: 0
      Failures due to internal error: 0
      Failures due to other errors: 0
      Packet(s) arrived late: 0
    UDP-jitter results:
     RTT number: 10
      Min positive SD: 8                     Min positive DS: 8
      Max positive SD: 18                    Max positive DS: 8
      Positive SD number: 5                  Positive DS number: 2
      Positive SD sum: 75                    Positive DS sum: 32
      Positive SD average: 15                Positive DS average: 16
      Positive SD square sum: 1189           Positive DS square sum: 640
      Min negative SD: 8                     Min negative DS: 1
      Max negative SD: 24                    Max negative DS: 30
      Negative SD number: 4                  Negative DS number: 7
      Negative SD sum: 56                    Negative DS sum: 99
      Negative SD average: 14                Negative DS average: 14
      Negative SD square sum: 946            Negative DS square sum: 1495
    One way results:
      Max SD delay: 22                       Max DS delay: 23
      Min SD delay: 7                        Min DS delay: 7
      Number of SD delay: 10                 Number of DS delay: 10
      Sum of SD delay: 125                   Sum of DS delay: 132
      Square sum of SD delay: 1805           Square sum of DS delay: 1988
      SD lost packet(s): 0                   DS lost packet(s): 0
      Lost packet(s) for unknown reason: 0
# Display the results of the last voice test.
      Send operation times: 1000           Receive response times: 0
      Min/Max/Average round trip time: 0/0/0
      Square-Sum of round trip time: 0
      Last succeeded probe time: 0-00-00 00:00:00.0
    Extended results:
      Packet loss in test: 100%
      Failures due to timeout: 1000
    Voice results:
     RTT number: 0
      Min positive SD: 0                     Min positive DS: 0
      Max positive SD: 0                     Max positive DS: 0
      Positive SD number: 0                  Positive DS number: 0
      Positive SD sum: 0                     Positive DS sum: 0
      Positive SD average: 0                 Positive DS average: 0
      Positive SD square sum: 0              Positive DS square sum: 0
      Min negative SD: 0                     Min negative DS: 0
      Max negative SD: 0                     Max negative DS: 0
      Negative SD number: 0                  Negative DS number: 0
      Negative SD sum: 0                     Negative DS sum: 0
      Negative SD average: 0                 Negative DS average: 0
      Negative SD square sum: 0              Negative DS square sum: 0
    One way results:
      Max SD delay: 0                        Max DS delay: 0
      Min SD delay: 0                        Min DS delay: 0
      Number of SD delay: 0                  Number of DS delay: 0
      Sum of SD delay: 0                     Sum of DS delay: 0
      Square sum of SD delay: 0              Square sum of DS delay: 0
      Lost packet(s) for unknown reason: 1000
    Voice scores:
      MOS value: 0.99                        ICPIF value: 87
Table 5 Command output
IP address of the destination.
Number of probe packets sent.
Number of response packets received.
Minimum/maximum/average round-trip time in the unit of millisecond.
Square sum of round-trip time.
Time when the last successful probe was finished.
Packet loss in test
Average packet loss ratio.
Number of timeout occurrences in a test.
Number of disconnections by the peer.
Number of failures to connect with the peer.
Number of failures owing to out-of-sequence packets.
Number of failures owing to internal errors.
Failures due to other errors.
Number of packets that arrived late.
UDP-jitter results
UDP jitter test results, available only in UDP jitter tests.
Voice results
Voice test results, available only in voice tests.
RTT number
Min positive SD
Minimum positive delay jitters from source to destination.
Min positive DS
Minimum positive delay jitters from destination to source.
Max positive SD
Maximum positive delay jitters from source to destination.
Max positive DS
Maximum positive delay jitters from destination to source.
Positive SD number
Number of positive delay jitters from source to destination.
Positive DS number
Number of positive delay jitters from destination to source.
Positive SD sum
Sum of positive delay jitter from source to destination.
Positive DS sum
Sum of positive delay jitters from destination to source.
Positive SD average
Average of positive delay jitter from source to destination.
Positive DS average
Average of positive delay jitter from destination to source.
Square sum of positive delay jitters from source to destination.
Square sum of positive delay jitters from destination to source.
Min negative SD
Minimum absolute value among negative delay jitters from source to destination.
Min negative DS
Minimum absolute value among negative delay jitters from destination to source.
Max negative SD
Maximum absolute value among negative delay jitters from source to destination.
Max negative DS
Maximum absolute value among negative delay jitters from destination to source.
Negative SD number
Number of negative delay jitters from source to destination.
Negative DS number
Number of negative delay jitters from destination to source.
Negative SD sum
Sum of absolute values of negative delay jitters from source to destination.
Negative DS sum
Sum of absolute values of negative delay jitters from destination to source.
Negative SD average
Average absolute value of negative delay jitters from source to destination.
Negative DS average
Average absolute value of negative delay jitters from destination to source.
Square sum of negative delay jitters from source to destination.
Square sum of negative delay jitters from destination to source.
One way results
Uni-direction delay test result, displayed in a UDP jitter or voice test.
Max SD delay
Maximum delay from source to destination.
Max DS delay
Maximum delay from destination to source.
Min SD delay
Minimum delay from source to destination.
Min DS delay
Minimum delay from destination to source.
Number of SD delay
Number of delays from source to destination.
Number of DS delay
Number of delays from destination to source.
Sum of SD delay
Sum of delays from source to destination.
Sum of DS delay
Sum of delays from destination to source.
Square sum of delays from source to destination.
Square sum of delays from destination to source.
SD lost packet(s)
Number of lost packets from the source to the destination.
DS lost packet(s)
Number of lost packets from the destination to the source.
Number of lost packets for unknown reasons.
Voice scores
Voice parameters, displayed only in a voice test.
MOS value
MOS value calculated for a voice test.
ICPIF value
ICPIF value calculated for a voice test.
display nqa statistics [ admin-name operation-tag ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
admin-name operation-tag: Displays statistics of the specified test group. If these two arguments are not specified, statistics of all test groups are displayed. The admin-name argument represents the name of the NQA test group administrator who creates the NQA operation. It is a case-insensitive string of 1 to 32 characters. The operation-tag argument represents the test operation tag. It is a case-insensitive string of 1 to 32 characters.
Use display nqa statistics to display statistics of test results for the specified or all test groups.
Statistics cannot be generated until all probe operations in the first test of a test group have finished. If they have not finished and you display statistics by using this command, the statistics will display as all 0s.
If a reaction entry is configured, the command displays the monitoring results of the reaction entry in the period specified by the statistics internal command. If the threshold type is average value or the monitored element is ICPIF or MOS for voice tests, the monitoring results are invalid.
Related commands: statistics interval.
# Display statistics of UDP jitter tests.
<Sysname> display nqa statistics admin test
  NQA entry (admin admin, tag test) test statistics:
    NO. : 1
    Destination IP address: 1.1.1.2
      Start time: 2007-01-01 09:33:22.3
      Life time: 23 seconds
      Send operation times: 100            Receive response times: 100
      Min/Max/Average round trip time: 1/11/5
      Square-Sum of round trip time: 24360
    Extended results:
    UDP-jitter results:
     RTT number: 550
      Min positive SD: 1                     Min positive DS: 1
      Max positive SD: 7                     Max positive DS: 1
      Positive SD number: 220                Positive DS number: 97
      Positive SD sum: 283                   Positive DS sum: 287
      Positive SD average: 1                 Positive DS average: 2
      Positive SD square sum: 709            Positive DS square sum: 1937
      Min negative SD: 2                     Min negative DS: 1
      Max negative SD: 10                    Max negative DS: 1
      Negative SD number: 81                 Negative DS number: 94
      Negative SD sum: 556                   Negative DS sum: 191
      Negative SD average: 6                 Negative DS average: 2
      Negative SD square sum: 4292           Negative DS square sum: 967
    One way results:
      Max SD delay: 5                        Max DS delay: 5
      Min SD delay: 1                        Min DS delay: 1
      Number of SD delay: 550                Number of DS delay: 550
      Sum of SD delay: 1475                  Sum of DS delay: 1201
      Square sum of SD delay: 5407           Square sum of DS delay: 3959
    Reaction statistics:
      1      jitter-DS        accumulate      90           25
      2      jitter-SD        average         -            -
      3      OWD-DS           -               100          24
      4      OWD-SD           -               100          13
      5      packet-loss      accumulate      0            0
      6      RTT              accumulate      100          52
# Display statistics of voice tests.
    NO. : 1
      Start time: 2007-01-01 09:33:45.3
      Life time: 120 seconds
      Min/Max/Average round trip time: 1/12/7
      Square-Sum of round trip time: 620
    Extended results:
    Voice results:
     RTT number: 10
      Min positive SD: 3                     Min positive DS: 1
      Max positive SD: 10                    Max positive DS: 1
      Positive SD number: 3                  Positive DS number: 2
      Positive SD sum: 18                    Positive DS sum: 2
      Positive SD average: 6                 Positive DS average: 1
      Positive SD square sum: 134            Positive DS square sum: 2
      Min negative SD: 3                     Min negative DS: 1
      Max negative SD: 9                     Max negative DS: 1
      Negative SD number: 4                  Negative DS number: 2
      Negative SD sum: 25                    Negative DS sum: 2
      Negative SD average: 6                 Negative DS average: 1
      Negative SD square sum: 187            Negative DS square sum: 2
    One way results:
    Voice scores:
      Max MOS value: 4.40                    Min MOS value: 4.40
      Max ICPIF value: 0                     Min ICPIF value: 0
      1      ICPIF            -               -            -
      2      MOS              -               -            -
Table 6 Command output
No.
Statistics group number.
Start time
Time when the test group starts.
Life time
Duration of the test, in seconds.
Packet loss in test
Number of response packets received after a probe times out.
UDP-jitter results
Voice results
RTT number
Min positive SD
Minimum positive delay jitter from source to destination.
Min positive DS
Minimum positive delay jitter from destination to source.
Max positive SD
Maximum positive delay jitter from source to destination.
Max positive DS
Maximum positive delay jitter from destination to source.
Positive SD number
Positive DS number
Positive SD sum
Sum of positive delay jitters from source to destination.
Positive DS sum
Positive SD average
Average of positive delay jitters from source to destination.
Positive DS average
Average of positive delay jitters from destination to source.
Min negative SD
Min negative DS
Max negative SD
Max negative DS
Negative SD number
Negative DS number
Negative SD sum
Negative DS sum
Negative SD average
Negative DS average
One way results
Uni-direction delay test result, displayed on in a UDP-Jitter or voice test.
Max SD delay
Max DS delay
Min SD delay
Min DS delay
Number of SD delay
Number of DS delay
Sum of SD delay
Sum of DS delay
SD lost packet(s)
DS lost packet(s)
Voice scores
Max MOS value
Maximum MOS value.
Min MOS value
Minimum MOS value.
Max ICPIF value
Maximum ICPIF value.
Min ICPIF value
Minimum ICPIF value.
Reaction statistics
Statistics about the reaction entry in the counting interval.
Index
Checked Element
Monitored element.
Threshold Type
Threshold type.
Checked Num
Over-threshold Num
Table 7 Description on the threshold monitoring fields of the display nqa statistics command
Monitored element
Threshold type
Collect data in
Checked Num
Over-threshold Num
probe-duration
accumulate
Probes in the counting interval
Number of finished probes in the counting interval
Number of probes of which the duration exceeds the threshold in the counting interval
average
N/A
N/A
N/A
consecutive
probe-fail
accumulate
Number of probe failures in the counting interval
consecutive
RTT
accumulate
Packets sent in the counting interval
Number of packets sent in the counting interval
Number of packets of which the round-trip time exceeds the threshold in the counting interval
average
N/A
N/A
N/A
jitter-DS/jitter-SD
accumulate
Number of packets of which the one-way delay jitter exceeds the threshold in the counting interval
average
N/A
N/A
N/A
OWD-DS/OWD-SD
N/A
Number of packets of which the one-way delay exceeds the threshold in the counting interval
packet-loss
accumulate
Number of packet loss in the counting interval
ICPIF
N/A
N/A
N/A
N/A
MOS
N/A
N/A
N/A
N/A
filename
filename filename
undo filename
View
FTP test type view
Default level
2: System level
filename: Name of the file transferred between the FTP server and the FTP client. The file name is a case-sensitive string of 1 to 200 characters.
Use filename to specify a file to be transferred between the FTP server and the FTP client.
Use undo filename to restore the default.
By default, no file is specified.
# Specify the file to be transferred between the FTP server and the FTP client as config.txt.
[Sysname-nqa-admin-test] type ftp
[Sysname-nqa-admin-test-ftp] filename config.txt
frequency
frequency interval
undo frequency
View
Default level
2: System level
interval: Interval between two consecutive tests, in the range 0 to 604800000 milliseconds. The interval of 0 specifies the test group to perform only one test, and no statistics group information is collected.
Use frequency to configure the interval between two consecutive tests for a test group. When a test group starts, it performs tests one by one at the specified interval. However, if a test is not completed when the interval is reached, no new test starts.
Use undo frequency to restore the default.
By default, the interval between two consecutive voice tests is 60000 milliseconds, and the interval between two consecutive tests of other types is 0 milliseconds.
# Configure the ICMP echo test group starts tests one by one at an interval of 1000 milliseconds.
[Sysname-nqa-admin-test-icmp-echo] frequency 1000
undo history-record enable
View
Default level
2: System level
None
Use history-record enable to enable the saving of history records of an NQA test group.
Use undo history-record enable to disable the history records saving function.
By default, history records of an NQA test group are not saved.
If the history records saving function is enabled, the system saves the history records. To view the history records of the NQA test group, use the display nqa history command.
If the history records saving function is disabled, the system does not save the history records of the NQA test group and the existing history records are also removed.
Related commands: display nqa history.
# Enable the history records saving function of an NQA test group.
[Sysname-nqa-admin-test-icmp-echo] history-record enable
history-record keep-time keep-time
undo history-record keep-time
View
Default level
2: System level
keep-time: Specifies how long the history records can be saved. The time is in the range of 1 to 1440 minutes.
Use history-record keep-time to set the lifetime of the history records in an NQA test group.
Use undo history-record keep-time to restore the default.
By default, the history records in an NQA test group are kept for 120 minutes.
When an NQA test completes, the timing starts. All the records are removed when the lifetime is reached.
# Configure the lifetime of the history records in an NQA test group as 100 minutes.
[Sysname-nqa-admin-test-icmp-echo] history-record keep-time 100
history-record number number
undo history-record number
View
Default level
2: System level
number: Maximum number of history records that can be saved in a test group, in the range of 0 to 50.
Use history-record number to configure the maximum number of history records that can be saved in a test group.
Use undo history-record number to restore the default.
By default, the maximum number of records that can be saved in a test group is 50.
If the number of history records in a test group exceeds the maximum number, the earliest history record is removed.
# Configure the maximum number of history records that can be saved in a test group as 10.
[Sysname-nqa-admin-test-icmp-echo] history-record number 10
http-version
http-version v1.0
undo http-version
View
HTTP test type view
Default level
2: System level
v1.0: The HTTP version is 1.0 in an HTTP test.
Use http-version to configure the HTTP version used in an HTTP test.
Use undo http-version to restore the default.
By default, HTTP 1.0 is used in an HTTP test.
# Configure the HTTP version as 1.0 in an HTTP test.
[Sysname-nqa-admin-test] type http
[Sysname-nqa-admin-test-http] http-version v1.0
mode
mode { active | passive }
undo mode
View
FTP test type view
Default level
2: System level
active: Sets the data transmission mode to active for FTP tests. In this mode, the FTP server initiates a data connection request.
passive: Sets the data transmission mode to passive for FTP tests. In this mode, a client initiates a data connection request.
Use mode to set the data transmission mode for FTP tests.
Use undo mode to restore the default.
By default, the data transmission mode is active.
# Set the data transmission mode to passive for FTP tests.
[Sysname-nqa-admin-test-ftp] mode passive
next-hop
next-hop ip-address
undo next-hop
View
Default level
2: System level
ip-address: IP address of the next hop.
Use next-hop to configure the next hop IP address for ICMP echo requests of a test group.
Use undo next-hop to remove the configured next hop IP address.
By default, no next hop IP address is configured.
# Configure the next hop IP address as 10.1.1.1.
[Sysname-nqa-admin-test-icmp-echo] next-hop 10.1.1.1
nqa
nqa entry admin-name operation-tag
undo nqa { all | entry admin-name operation-tag }
View
Default level
2: System level
admin-name: Specifies the name of the NQA test group administrator who creates the NQA test operation. The name is a case-insensitive string of 1 to 32 characters excluding the hyphen (-).
operation-tag: Specifies the tag of a test operation, a case-insensitive string of 1 to 32 characters excluding the hyphen (-).
all: All NQA test groups.
Use nqa to create an NQA test group and enter NQA test group view.
Use undo nqa to remove the test group.
If the test type has been configured for the test group, you directly enter NQA test type view when you execute the nqa command.
# Create an NQA test group whose administrator name is admin and whose operation tag is test and enter NQA test group view.
nqa agent enable
nqa agent enable
undo nqa agent enable
View
Default level
2: System level
None
Use nqa agent enable to enable the NQA client.
Use undo nqa agent enable to disable the NQA client and stop all the tests being performed.
By default, the NQA client is enabled.
Related commands: nqa server enable.
# Enable the NQA client.
[Sysname] nqa agent enable
nqa agent max-concurrent number
undo nqa agent max-concurrent
View
Default level
2: System level
number: Maximum number of the tests that the NQA client can simultaneously perform, in the range of 1 to 30.
Use nqa agent max-concurrent to configure the maximum number of tests that the NQA client can simultaneously perform.
Use undo nqa agent max-concurrent to restore the default.
By default, the device can perform up to 10 tests simultaneously.
From the beginning to the end of a test, the NQA test is in test status. From the end of a test to the beginning of the next test, the NQA test is in waiting status.
# Configure the maximum number of the tests that the NQA client can simultaneously perform as 5.
[Sysname] nqa agent max-concurrent 5
nqa schedule
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd ] | now } lifetime { lifetime | forever }
undo nqa schedule admin-name operation-tag
View
Default level
2: System level
admin-name: Specifies the name of the NQA test group administrator who creates the NQA test operation, which is a case-insensitive string of 1 to 32 characters.
operation-tag: Specifies the test operation tag, which is a case-insensitive string of 1 to 32 characters.
start-time: Specifies the start time and date of a test group.
hh:mm:ss: Start time of a test group.
yyyy/mm/dd: Start date of a test group. The default value is the current system time, and yyyy is in the range of 2000 to 2035.
now: Starts the tests for a test group immediately.
lifetime: Specifies the duration of the test operation.
lifetime: Duration of the test operation in seconds, in the range of 1 to 2147483647.
forever: Specifies that the tests are performed for a test group forever.
Use nqa schedule to configure the test start time and test duration for a test group.
Use undo nqa schedule to stop the test for the test group.
You cannot enter test group view or test type view after a test group is scheduled.
A test group performs a test when the system time is between the start time and the end time (the start time plus test duration). If the system time is behind the start time when you execute the nqa schedule command, a test is started when the system time reaches the start time. If the system time is between the start time and the end time, a test is started at once. If the system time is ahead of the end time, no test is started. To view the current system time, use the display clock command.
Related commands: display clock (Fundamentals Command Reference).
# Start the tests for the test group with the administrator name admin and operation tag test. The start time and duration of the test group are 08:08:08 2008/08/08 and 1000 seconds respectively.
[Sysname] nqa schedule admin test start-time 08:08:08 2008/08/08 lifetime 1000
operation { get | put }
undo operation
View
FTP test type view
Default level
2: System level
get: Obtains a file from the FTP server.
put: Transfers a file to the FTP server.
Use operation to configure the FTP operation type.
Use undo operation to restore the default.
By default, the FTP operation type is get.
When you execute the put command, the NQA client creates a file (the name of which is specified in the filename command) with fixed size on the FTP server. The file has no relation to that saved on the NQA client. When you execute the get command, the device does not save the files obtained from the server.
# Configure the FTP operation type as put.
[Sysname-nqa-admin-test-ftp] operation put
operation { get | post }
undo operation
View
HTTP test type view
Default level
2: System level
get: Obtains data from the HTTP server.
post: Transfers data to the HTTP server.
Use operation to configure the HTTP operation type.
By default, the HTTP operation type is get.
# Configure the HTTP operation type as post.
[Sysname-nqa-admin-test-http] operation post
operation interface
operation interface interface-type interface-number
undo operation interface
View
DHCP test type view
Default level
2: System level
Use operation interface to specify the interface to perform a DHCP test. The specified interface must be up. Otherwise, no probe packets can be sent out.
Use undo operation interface to restore the default.
By default, no interface is specified to perform a DHCP test.
# Specify the interface to perform a DHCP test as VLAN-interface 2.
[Sysname-nqa-admin-test] type dhcp
[Sysname-nqa-admin-test-dhcp] operation interface vlan-interface 2
password [ cipher | simple ] password
undo password
View
FTP test type view
Default level
2: System level
cipher: Sets a ciphertext password.
simple: Sets a plaintext password.
password: Password used to log in to the FTP server. This argument is case sensitive. If simple is specified, it must be a plaintext string of 1 to 32 characters. If cipher is specified, it must be a ciphertext string of 1 to 73 characters. If neither cipher nor simple is specified, you set a plaintext password.
Use password to configure a password used to log onto the FTP server.
Use undo password to remove the configured password.
By default, no password is configured for logging onto the FTP server.
Related commands: username and operation.
# Configure the password used for logging in to the FTP server as ftpuser.
[Sysname-nqa-admin-test-ftp] password simple ftpuser
probe count
probe count times
undo probe count
View
DHCP, DNS, DLSw, FTP, HTTP, ICMP echo, SNMP, TCP, UDP echo, UDP jitter test type view
Default level
2: System level
times: Number of probe operations per test, in the range of 1 to 15.
Use probe count to configure the number of probe operations to be performed per test.
Use undo probe count to restore the default.
By default, one probe operation is performed in an NQA test.
Probe operations vary with NQA test types:
·     During a TCP or DLSw test, one probe operation means setting up one connection.
·     During a UDP jitter or a voice test, one probe operation means continuously sending the specified number of probe packets. The number of probe packets is configurable with the probe packet-number command.
·     During an FTP, HTTP, DHCP or DNS test, one probe operation means uploading or downloading a file, obtaining a web page, obtaining an IP address through DHCP, or translating a domain name to an IP address.
·     During an ICMP echo or UDP echo test, one probe operation means sending an ICMP echo request or a UDP packet.
·     During an SNMP test, one probe operation means sending one SNMPv1 packet, one SNMPv2c packet, and one SNMPv3 packet.
If more than one probe operation is to be performed in a test, the system starts a second probe operation when it receives responses to packets sent in the first probe operation, or when the probe timeout time expires.
This command is not supported by voice tests. Only one probe operation is performed per voice test.
# Configure the ICMP test group to perform 10 probe operations per test.
[Sysname-nqa-admin-test-icmp-echo] probe count 10
probe packet-interval packet-interval
undo probe packet-interval
View
Default level
2: System level
packet-interval: Interval for sending packets per probe operation, in the range of 10 to 60000 milliseconds.
Use probe packet-interval to configure the interval for sending packets per probe operation.
Use undo probe packet-interval to restore the default.
By default, the interval is 20 milliseconds.
# Configure the UDP jitter test group to send packets at an interval of 100 milliseconds during each probe operation.
[Sysname-nqa-admin-test] type udp-jitter
[Sysname-nqa-admin-test-udp-jitter] probe packet-interval 100
probe packet-number
probe packet-number packet-number
undo probe packet-number
View
Default level
2: System level
packet-number: Number of packets to be sent per probe operation. It is in the range of 10 to 1000 for each probe operation in one UDP jitter test, and from 10 to 60000 for each probe operation in one voice test.
Use probe packet-number to configure the number of packets to be sent per probe during one UDP jitter or voice test.
Use undo probe packet-number to restore the default.
By default, the number of packets to be sent per probe is 10 in one UDP jitter test and 1000 in one voice test.
# Configure the UDP jitter test group to send 100 packets per probe.
[Sysname-nqa-admin-test-udp-jitter] probe packet-number 100
probe packet-timeout packet-timeout
undo probe packet-timeout
View
Default level
2: System level
packet-timeout: Timeout time for waiting for responses in a UDP jitter or voice test, in the range of 10 to 3600000 milliseconds.
Use probe packet-timeout to configure the timeout time for waiting for a response in a UDP jitter or voice test.
Use undo probe packet-timeout to restore the default.
By default, the timeout time in a UDP jitter and a voice test is 3000 and 5000 milliseconds respectively.
# Configure the timeout time for waiting for a response in a UDP jitter test as 100 milliseconds.
[Sysname-nqa-admin-test-udp-jitter] probe packet-timeout 100
probe timeout
probe timeout timeout
undo probe timeout
View
DHCP, DNS, DLSw, FTP, HTTP, ICMP echo, SNMP, TCP, UDP echo test type view
Default level
2: System level
timeout: Timeout time for a probe operation, in milliseconds. The value range is 10 to 86400000 for an FTP or HTTP probe operation, and 10 to 3600000 for a DHCP, DNS, DLSw, ICMP echo, SNMP, TCP or UDP echo probe operation.
Use probe timeout to configure the timeout time for a probe operation. When a probe operation does not complete within the period, the probe operation is timed out.
Use undo probe timeout to restore the default.
By default, the timeout time is 3000 milliseconds for a probe operation.
This command is not supported by UDP jitter or voice tests.
# Configure the timeout time for a DHCP probe operation as 10000 milliseconds.
[Sysname-nqa-admin-test-dhcp] probe timeout 10000
reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
undo reaction item-number
View
Default level
2: System level
item-number: ID for a reaction entry, in the range of 1 to 10.
threshold-value: Specifies threshold values.
upper-threshold: Upper threshold in the range of 1 to 100.
lower-threshold: Lower threshold in the range of 1 to 100. It must not be greater than the upper threshold.
action-type: Specifies what action to be triggered to react to certain measurement conditions and it defaults to none.
none: Specifies to only record events for terminal display, and not to send any trap messages.
trap-only: Specifies to record events and send SNMP trap messages.
Use reaction checked-element icpif to configure a reaction entry for monitoring the ICPIF value in a voice test of an NQA operation. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
Use undo reaction to delete the specified reaction entry.
By default, no reaction entry for monitoring ICPIF values is configured.
# Create reaction entry 1 for monitoring the ICPIF value in each voice test. Set the upper threshold to 50 and lower threshold to 5. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the ICPIF value is checked. If it is out of the threshold range, the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-voice] reaction 1 checked-element icpif threshold-value 50 5 action-type trap-only
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
View
Default level
2: System level
jitter-ds: Specifies destination-to-source delay jitter of each probe packet as the monitored element.
jitter-sd: Specifies source-to-destination delay jitter of each probe packet as the monitored element.
threshold-type: Specifies a threshold type.
accumulate accumulate-occurrences: Total number of threshold violations in a test. It is in the range of 1 to 14999 for UDP jitter tests, and 1 to 59999 for voice tests.
average: Average one-way delay jitter in each test.
threshold-value: Specifies threshold values in milliseconds.
upper-threshold: Upper threshold in the range of 0 to 3600000.
lower-threshold: Lower threshold in the range of 0 to 3600000. It must not be greater than the upper threshold.
Use reaction checked-element { jitter-ds | jitter-sd } to configure a reaction entry for monitoring one-way delay jitter in each test of an NQA operation. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
By default, no reaction entry for monitoring one-way delay jitter is configured.
Only successful probe packets are monitored. The data of a failed probe packet is not counted.
# Create reaction entry 1 for monitoring the average destination-to-source delay jitter of UDP jitter probe packets. Set the upper threshold to 50 milliseconds, and the lower threshold to 5 milliseconds. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the average destination-to-source delay jitter is checked. If it is out of the threshold range, the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element jitter-ds threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the destination-to-source delay jitter of UDP jitter probe packets. Set the upper threshold to 50 milliseconds, and the lower threshold to 5 milliseconds. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the destination-to-source delay jitter is checked against the threshold range. If the total number of threshold violations exceeds 100 (included), the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-udp-jitter] reaction 2 checked-element jitter-ds threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction item-number checked-element mos threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
View
Default level
2: System level
upper-threshold: Upper threshold in the range of 1 to 500.
lower-threshold: Lower threshold in the range of 1 to 500. It must not be greater than the upper threshold.
Use reaction checked-element mos to configure a reaction entry for monitoring the MOS value in each voice test of an NQA operation. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
By default, no reaction entry for monitoring the MOS value is configured.
For the MOS threshold, the number is expressed in three digits representing ones, tenths, and hundredths. For example, to express a MOS threshold of 1, enter 100.
# Create reaction entry 1 for monitoring the MOS value of each voice test. Set the upper threshold to 2, and lower threshold to 1. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the MOS value is checked. If it is out of the threshold range, the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-voice] reaction 1 checked-element mos threshold-value 200 100 action-type trap-only
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
View
Default level
2: System level
owd-ds: Specifies the destination-to-source delay of each probe packet as the monitored element.
owd-sd: Specifies the source-to-destination delay of each probe packet as the monitored element.
Use reaction checked-element { owd-ds | owd-sd } to configure a reaction entry for monitoring the one-way delay. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
By default, no reaction entry for monitoring the one-way delay is configured.
No actions can be configured for a reaction entry of monitoring one-way delays. The monitoring results and statistics, however, can be displayed by the display nqa reaction counters and display nqa statistics commands.
# Create reaction entry 1 for monitoring the destination-to-source delay of every UDP jitter probe packet. Set the upper threshold to 50 milliseconds and lower threshold to 5 milliseconds. Before the NQA test group starts, the initial state of the reaction entry is invalid. The destination-to-source delay is calculated after the response to the probe packet arrives. If the delay is out of the threshold range, the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element owd-ds threshold-value 50 5
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
View
Default level
2: System level
accumulate accumulate-occurrences: Total number of lost packets in a test. It is in the range of 1 to 15000 for UDP jitter tests and 1 to 60000 for voice tests.
Use reaction checked-element packet-loss to configure a reaction entry for monitoring the packet loss in each test of an NQA operation. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
By default, no reaction entry for monitoring the packet loss is configured.
# Create reaction entry 1 for monitoring the packet loss in each UDP jitter test. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the packet loss is checked. If the total number of lost packets exceeds 100 (included), the state of the reaction entry is set to over-threshold. Otherwise, the state is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element packet-loss threshold-type accumulate 100 action-type trap-only
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
View
DHCP, DLSw, DNS, FTP, HTTP, ICMP echo, SNMP, TCP, UDP echo test type view
Default level
2: System level
accumulate accumulate-occurrences: Total number of threshold violations in a test, in the range of 1 to 15.
average: Average probe duration in each test.
consecutive consecutive-occurrences: Number of consecutive threshold violations since the NQA test group starts, in the range of 1 to 16.
trap-only: Specifies to record events and send SNMP trap messages. This keyword is not supported in DNS test view.
Use reaction checked-element probe-duration to configure a reaction entry for monitoring the probe duration. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
By default, no reaction entry for monitoring the probe duration is configured.
Only successful probes are monitored. The duration of a failed probe is not counted.
# Create reaction entry 1 for monitoring the average duration of ICMP echo probes in a test. Set the upper threshold to 50 milliseconds and lower threshold to 5 milliseconds. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the average probe duration is checked. If it is out of the threshold range, the state is set to over-threshold. Otherwise, the state of the reaction entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-duration threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the duration of ICMP echo probes in a test. Set the upper threshold to 50 milliseconds, and the lower threshold to 5 milliseconds. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the probe duration is checked against the threshold range. If the total number of threshold violations exceeds 10 (included), the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-duration threshold-type accumulate 10 threshold-value 50 5 action-type trap-only
# Create reaction entry 3 for monitoring the duration time of ICMP echo probes. Set the upper threshold to 50 milliseconds, and the lower threshold to 5 milliseconds. Before the NQA test group starts, the initial state of the reaction entry is invalid. The probe duration is checked against the threshold range for each probe. If a threshold violation occurs consecutively for 10 times or more since the test group starts, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-icmp-echo] reaction 3 checked-element probe-duration threshold-type consecutive 10 threshold-value 50 5 action-type trap-only
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
View
Default level
2: System level
accumulate accumulate-occurrences: Total number of probe failures in a test, in the range of 1 to 15.
consecutive consecutive-occurrences: Number of consecutive probe failures since the NQA test group starts, in the range of 1 to 16.
Use reaction checked-element probe-fail to configure a reaction entry for monitoring the probe failures. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
By default, no reaction entry for monitoring probe failures is configured.
# Create reaction entry 1 for monitoring the probe failures in ICMP echo tests. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, if the total number of probe failures exceeds 10 (included), the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-icmp-echo] reaction 1 checked-element probe-fail threshold-type accumulate 10 action-type trap-only
# Create reaction entry 2 for monitoring the probe failures in ICMP echo tests. Before the NQA test group starts, the initial state of the reaction entry is invalid. If probe failure occurs consecutively for 10 times or more since the test group starts, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-icmp-echo] reaction 2 checked-element probe-fail threshold-type consecutive 10 action-type trap-only
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
View
Default level
2: System level
consecutive consecutive-occurrences: Number of consecutive probe failures since the test group starts, in the range of 1 to 16.
action-type: Specifies what actions to be triggered to react to certain measurement conditions.
trigger-only: Triggers other modules to react to certain conditions.
Use reaction checked-element probe-fail to configure a reaction entry for monitoring the probe results of the current test group. If the number of consecutive probe failures reaches the threshold, collaboration with other modules is triggered. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
Use undo reaction to remove the specified reaction entry.
By default, no reaction entries are configured.
The collaboration function is not supported by UDP jitter or voice tests.
Related commands: track (High Availability Command Reference).
# Create reaction entry 1. If probe failure occurs consecutively for 3 times, collaboration with other modules is triggered.
[Sysname-nqa-admin-test] type tcp
[Sysname-nqa-admin-test-tcp] reaction 1 checked-element probe-fail threshold-type consecutive 3 action-type trigger-only
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
View
Default level
2: System level
accumulate accumulate-occurrences: Total number of threshold violations in a test. It is in the range of 1 to 15000 for UDP jitter tests and 1 to 60000 for voice tests.
average: Packet average round-trip time in a test.
Use reaction checked-element rtt to configure a reaction entry for monitoring packet round-trip time. You cannot edit a reaction entry. To change the attributes in a reaction entry, use undo reaction to delete this entire entry and start over.
By default, no reaction entry for monitoring packet round-trip time is configured.
# Create reaction entry 1 for monitoring the average round-trip time of UDP jitter probe packets. Set the upper threshold to 50 milliseconds and lower threshold to 5 milliseconds. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the average packet round-trip time is checked. If it is out of the threshold range, the state is set to over-threshold. Otherwise, the state is set to below-threshold. Once the reaction entry state changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type average threshold-value 50 5 action-type trap-only
# Create reaction entry 2 for monitoring the round-trip time of UDP jitter probe packets. Set the upper threshold to 50 milliseconds, and lower threshold to 5 milliseconds. Before the NQA test group starts, the initial state of the reaction entry is invalid. After each test, the packet round-trip time is checked against the threshold range. If the total number of threshold violations exceeds 100 (included), the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold. Once the state of the reaction entry changes, a trap message is generated and sent to the network management server.
[Sysname-nqa-admin-test-udp-jitter] reaction 1 checked-element rtt threshold-type accumulate 100 threshold-value 50 5 action-type trap-only
reaction trap
reaction trap { probe-failure consecutive-probe-failures | test-complete | test-failure cumulate-probe-failures }
undo reaction trap { probe-failure | test-complete | test-failure }
View
Default level
2: System level
probe-failure consecutive-probe-failures: Sends a trap to the network management server if the number of consecutive probe failures in one test is greater than or equal to consecutive-probe-failures, which is in the range of 1 to 15. During the test, the system counts the number of consecutive probe failures after each probe operation, so multiple traps might be sent.
test-complete: Sends a trap to indicate that the test is completed.
test-failure cumulate-probe-failures: Sends a trap if the total probe failures in an test is greater than or equal to cumulate-probe-failures, which is in the range of 1 to 15. The system counts the total probe failures after the test completes, so one trap at most is sent.
Use reaction trap to configure to send traps to network management server under specified conditions.
Use undo reaction trap to restore the default.
By default, no traps are sent to the network management server.
Only the reaction trap test-complete command is supported by voice tests.
# Configure the system to send a trap if consecutive probe failures in an ICMP echo test is greater than or equal to 5.
[Sysname] nqa entry admin test
[Sysname-nqa-admin-test-icmp-echo] reaction trap probe-failure 5
resolve-target
resolve-target domain-name
undo resolve-target
View
DNS test type view
Default level
2: System level
domain-name: Specifies the domain name to be resolved. It is a case-insensitive string separated by dots (.), each part consisting of 1 to 63 characters. The total length must be within 255 characters, Valid characters in a part include letters, digits, hyphens (-), and underscores (_).
Use resolve-target to set the domain name for a DNS test.
Use undo resolve-target to restore the default.
By default, no domain name is configured.
# Set the domain name for DNS resolution to domain1.
[Sysname-nqa-admin-test] type dns
[Sysname-nqa-admin-test-dns] resolve-target domain1
route-option bypass-route
undo route-option bypass-route
View
DLSw, DNS, FTP, HTTP, ICMP echo, SNMP, TCP, UDP echo, UDP jitter, voice test type view
Default level
2: System level
None
Use route-option bypass-route to enable the routing table bypass function to test the direct connectivity to the direct destination.
Use undo route-option bypass-route to disable the routing table bypass function.
By default, the routing table bypass function is disabled.
When the routing table bypass function enabled, the routing table is not searched, and the packet is directly sent to the destination in a directly connected network.
# Enable the routing table bypass function.
[Sysname-nqa-admin-test] type icmp-echo
[Sysname-nqa-admin-test-icmp-echo] route-option bypass-route
source interface
source interface interface-type interface-number
undo source interface
View
ICMP echo test type view
Default level
2: System level
Use source interface to configure the source interface for ICMP echo request packets. The ICMP echo request packets take the primary IP address of the source interface as their source IP address. The specified source interface must be up. Otherwise, no ICMP echo requests can be sent out.
Use undo source interface to restore the default.
By default, no source interface is configured for ICMP echo request packets.
If you configure both the source interface command and the source ip command, the source ip command takes effect.
Related commands: source ip.
# Specify the primary IP address of interface VLAN-interface 2 as the source IP address of ICMP echo request packets.
[Sysname-nqa-admin-test-icmp-echo] source interface vlan-interface 2
source ip
source ip ip-address
undo source ip
View
DLSw, FTP, HTTP, ICMP echo, SNMP, TCP, UDP echo, UDP jitter, voice test type view
Default level
2: System level
ip-address: Source IP address of a test operation.
Use source ip to configure the source IP address of probe packets. The specified source IP address must be the IP address of a local interface. The local interface must be up. Otherwise, no probe packets can be sent out.
Use undo source ip to remove the configured source address. The primary IP address of the interface that sends a probe packet serves as the source IP address of the probe packet.
By default, no source IP address is configured for probe packets.
If you only configure the source interface command, the primary IP address of the interface that sends a probe packet serves as the source IP address of the probe packet.
Related commands: source interface.
# Configure the source IP address of the ICMP echo packets as 10.1.1.1.
[Sysname-nqa-admin-test-icmp-echo] source ip 10.1.1.1
source port
source port port-number
undo source port
View
SNMP, UDP echo, UDP jitter, voice test type view
Default level
2: System level
port-number: Source port number of probe packets, in the range of 1 to 50000.
Use source port to configure the source port of probe packets.
Use undo source port to remove the configured port number.
By default, no source port number is configured.
# Configure port 8000 as the source port of probe packets in the UDP echo test group.
[Sysname-nqa-admin-test] type udp-echo
[Sysname-nqa-admin-test-udp-echo] source port 8000
statistics hold-time
statistics hold-time hold-time
undo statistics hold-time
View
Default level
2: System level
hold-time: Hold time of a statistics group in minutes, in the range of 1 to 1440.
Use statistics hold-time to configure the hold time of statistics groups for a test group. A statistics group is deleted when its hold time expires.
Use undo statistics hold-time to restore the default.
By default, the hold time of a statistics group is 120 minutes.
This command is not supported by DHCP tests.
# Configure the hold time of a statistics group as 3 minutes.
[Sysname-nqa-admin-test-icmp-echo] statistics hold-time 3
statistics max-group
statistics max-group number
undo statistics max-group
View
Default level
2: System level
number: Maximum number of statistics groups that can be kept, in the range of 0 to 100. To disable collecting statistics, specify number 0.
Use statistics max-group to configure the maximum number of statistics groups that can be kept.
Use undo statistics max-group to restore the default.
By default, 2 statistics groups at most can be kept.
When the number of statistics groups kept reaches the upper limit and a new statistics group is to be saved, the earliest statistics group is deleted.
# Configure the NQA to save up to 5 statistics groups for the ICMP test group.
[Sysname-nqa-admin-test-icmp-echo] statistics max-group 5
statistics interval
statistics interval interval
undo statistics interval
View
Default level
2: System level
interval: Interval in minutes for collecting statistics of the test results for a test group, in the range of 1 to 35,791,394.
Use statistics interval to configure the interval for collecting test result statistics for a test group.
Use undo statistics interval to restore the default.
By default, the interval is 60 minutes.
NQA groups tests completed in the specified interval, and calculates the test result statistics. The statistics form a statistics group. To view information about the statistics groups, use the display nqa statistics command.
# Configure the interval for collecting the test result statistics of an ICMP test group as 2 minutes.
[Sysname-nqa-admin-test-icmp-echo] statistics interval 2
tos
tos value
undo tos
View
Default level
2: System level
value: Value of the ToS field in the IP header in an NQA probe packet, in the range of 0 to 255.
Use tos to configure the value of the ToS field in the IP header in an NQA probe packet.
Use undo tos to restore the default.
By default, the ToS field in the IP header of an NQA probe packet is 0.
# Configure the ToS field in an IP packet header in an NQA probe packet as 1.
[Sysname-nqa-admin-test-icmp-echo] tos 1
ttl
ttl value
undo ttl
View
Default level
2: System level
value: Maximum number of hops a probe packet traverses in the network, in the range of 1 to 255.
Use ttl to configure the maximum number of hops a probe packet traverses in the network.
Use undo ttl to restore the default.
By default, the maximum number of hops that a probe packet can traverse in a network is 20.
After you configure the route-option bypass-route command, the maximum number of hops a probe packet traverses in the network is 1, and the ttl command does not take effect.
# Configure the maximum number of hops that a probe packet can traverse in a network as 16.
[Sysname-nqa-admin-test-icmp-echo] ttl 16
type
type { dhcp | dlsw | dns | ftp | http | icmp-echo | snmp | tcp | udp-echo | udp-jitter | voice }
View
NQA test group view
Default level
2: System level
dhcp: DHCP test.
dlsw: DLSw test.
dns: DNS test.
ftp: FTP test.
http: HTTP test.
icmp-echo: ICMP echo test.
snmp: SNMP test.
tcp: TCP test.
udp-echo: UDP echo test.
udp-jitter: UDP jitter test.
voice: Voice test.
Use type to configure the test type of the current test group and enter test type view.
By default, no test type is configured.
# Configure the test type of a test group as FTP and enter test type view.
url
url url
undo url
View
HTTP test type view
Default level
2: System level
url: Website that an HTTP test visits, a case-sensitive string of 1 to 185 characters.
Use url to configure the website that an HTTP test visits.
Use undo url to remove the configured website that an HTTP test visits.
The character string of the configured URL cannot contain spaces.
# Configure the website that an HTTP test visits as /index.htm.
[Sysname-nqa-admin-test-http] url /index.htm
username (FTP test type view)
username username
undo username
View
FTP test type view
Default level
2: System level
username: Username used to log in to the FTP server. The username takes a case-sensitive string of 1 to 32 characters.
Use username to configure a username used to log onto the FTP server.
Use undo username to remove the configured username.
By default, no username is configured for logging onto the FTP server.
Related commands: password and operation.
# Configure the login username as administrator.
[Sysname-nqa-admin-test-ftp] username administrator
vpn-instance (ICMP echo test type view)
undo vpn-instance
View
Default level
2: System level
vpn-instance-name: Specifies the MPLS L3VPN, a case-sensitive string of 1 to 31 characters.
Use vpn-instance to apply the ICMP echo test group to the specified VPN.
Use undo vpn-instance to restore the default.
By default, the ICMP echo test group applies to the public network.
# Specify vpn1 as the MPLS L3VPN.
[Sysname-nqa-admin-test-icmp-echo] vpn-instance vpn1
NQA server configuration commands
You only need to configure the NQA server for UDP jitter, TCP, UDP echo, and voice tests.
display nqa server status
display nqa server status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display nqa server status to display NQA server status.
# Display NQA server status.
<Sysname> display nqa server status
nqa server is: enabled
tcp-connect:
    IP Address     Port           Status
    2.2.2.2        2000           active
udp-echo:
    3.3.3.3        3000            inactive
Table 8 Command output
tcp-connect
NQA server status in the NQA TCP test.
udp-echo
NQA server status in the NQA UDP test.
IP Address
IP address specified for the TCP/UDP listening service on the NQA server.
Port
Port number of the TCP/UDP listening service on the NQA server.
Status
Listening service status:
·     active—Listening service is ready.
·     inactive—Listening service is not ready.
nqa server enable
nqa server enable
undo nqa server enable
View
Default level
2: System level
None
Use nqa server enable to enable the NQA server.
Use undo nqa server enable to disable the NQA server.
By default, the NQA server is disabled.
Related commands: nqa server tcp-connect, nqa server udp-echo, and display nqa server status.
# Enable the NQA server.
[Sysname] nqa server enable
nqa server tcp-connect ip-address port-number
undo nqa server tcp-connect ip-address port-number
View
Default level
2: System level
ip-address: IP address specified for the TCP listening service on the NQA server.
port-number: Port number specified for the TCP listening service on the NQA server, in the range of 1 to 50000.
Use nqa server tcp-connect to create a TCP listening service on the NQA server.
Use undo nqa server tcp-connect to remove the TCP listening service created.
Configure the command on the NQA server for TCP tests only.
The IP address and port number must be consistent with those on the NQA client and must be different from those for an existing listening service.
The IP address must be that of an interface on the NQA server. Otherwise, the configuration will be invalid.
Related commands: nqa server enable and display nqa server status.
# Create a TCP listening service by using the IP address 169.254.10.2 and port 9000.
[Sysname] nqa server tcp-connect 169.254.10.2 9000
nqa server udp-echo
nqa server udp-echo ip-address port-number
undo nqa server udp-echo ip-address port-number
View
Default level
2: System level
ip-address: IP address specified for the UDP listening service on the NQA server.
port-number: Port number specified for the UDP listening service on the NQA server, in the range of 1 to 50000.
Use nqa server udp-echo to create a UDP listening service on the NQA server.
Use undo nqa server udp-echo to remove the UDP listening service created.
Configure the command on the NQA server for UDP jitter, UDP echo and voice tests only.
The IP address and port number must be consistent with those configured on the NQA client and must be different from those of an existing listening service.
The IP address must be that of an interface on the NQA server. Otherwise, the configuration becomes invalid.
# Create a UDP listening service by using the IP address 169.254.10.2 and port 9000.
[Sysname] nqa server udp-echo 169.254.10.2 9000
