11-Security Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18211-Security Command Reference
16-SSL Commands
16-SSL Commands 108.54 KB
The device supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and command options might differ in FIPS mode and non-FIPS mode. For information about FIPS mode, see Security Configuration Guide.
ciphersuite
ciphersuite [ dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_256_cbc_sha | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha ] *
View
SSL server policy view
Default level
2: System level
dhe_rsa_aes_128_cbc_sha: Specifies the key exchange algorithm of DH_RSA, the data encryption algorithm of 128-bit AES_CBC, and the MAC algorithm of SHA. This keyword is available only for FIPS mode.
dhe_rsa_aes_256_cbc_sha: Specifies the key exchange algorithm of DH_RSA, the data encryption algorithm of 256-bit AES_CBC, and the MAC algorithm of SHA. This keyword is available only for FIPS mode.
rsa_3des_ede_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 3DES_EDE_CBC, and the MAC algorithm of SHA. This keyword is not available for FIPS mode.
rsa_aes_128_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit AES_CBC, and the MAC algorithm of SHA.
rsa_aes_256_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 256-bit AES_CBC, and the MAC algorithm of SHA.
rsa_des_cbc_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of DES_CBC, and the MAC algorithm of SHA. This keyword is not available for FIPS mode.
rsa_rc4_128_md5: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit RC4, and the MAC algorithm of MD5. This keyword is not available for FIPS mode.
rsa_rc4_128_sha: Specifies the key exchange algorithm of RSA, the data encryption algorithm of 128-bit RC4, and the MAC algorithm of SHA. This keyword is not available for FIPS mode.
Use ciphersuite to specify the cipher suites for an SSL server policy to support.
By default, an SSL server policy supports all cipher suites.
With no keyword specified, the command configures an SSL server policy to support all cipher suites.
If you execute the command multiple times, the most recent configuration takes effect.
Related commands: display ssl server-policy.
# Configure SSL server policy policy1 to support cipher suites rsa_rc4_128_md5 and rsa_rc4_128_sha.
[Sysname] ssl server-policy policy1
[Sysname-ssl-server-policy-policy1] ciphersuite rsa_rc4_128_md5 rsa_rc4_128_sha
client-verify enable
undo client-verify enable
View
Default level
2: System level
None
Use client-verify enable to configure the SSL server to require the client to pass certificate-based authentication.
Use undo client-verify enable to restore the default.
By default, the SSL server does not require certificate-based SSL client authentication.
If you configure the client-verify enable command and enable the SSL client weak authentication function, whether the client must be authenticated is up to the client. If the client chooses to be authenticated, the client must pass authentication before accessing the SSL server; otherwise, the client can access the SSL server without authentication.
If you configure the client-verify enable command but disable the SSL client weak authentication function, the SSL client must pass authentication before accessing the SSL server.
Related commands: client-verify weaken and display ssl server-policy.
# Configure the SSL server to require certificate-based SSL client authentication.
[Sysname-ssl-server-policy-policy1] client-verify enable
undo client-verify weaken
View
Default level
2: System level
None
Use client-verify weaken to enable SSL client weak authentication.
Use undo client-verify weaken to restore the default.
By default, SSL client weak authentication is disabled.
If the SSL server requires certificate-based client authentication and the SSL client weak authentication function is enabled, whether the client must be authenticated is up to the client. If the client chooses to be authenticated, the client must pass authentication before accessing the SSL server; otherwise, the client can access the SSL server without authentication.
If the SSL server requires certificate-based client authentication and SSL client weak authentication is disabled, the SSL client must pass authentication before accessing the SSL server.
The client-verify weaken command takes effect only when the SSL server requires certificate-based client authentication.
Related commands: client-verify enable and display ssl server-policy.
# Enable SSL client weak authentication.
[Sysname-ssl-server-policy-policy1] client-verify weaken
close-mode wait
close-mode wait
undo close-mode wait
View
Default level
2: System level
None
Use close-mode wait to set the SSL connection close mode to wait mode. In this mode, after sending a close-notify alert message to a client, the server does not close the connection until it receives a close-notify alert message from the client.
Use undo close-mode wait to restore the default.
By default, an SSL server sends a close-notify alert message to the client and closes the connection without waiting for the close-notify alert message from the client.
# Set the SSL connection close mode to wait.
[Sysname-ssl-server-policy-policy1] close-mode wait
display ssl client-policy
display ssl client-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Specifies an SSL client policy by its name, a case-insensitive string of 1 to 16 characters.
all: Displays information about all SSL client policies.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ssl client-policy to view information about a specified SSL client policy or all SSL client policies.
# Display information about SSL client policy policy1.
<Sysname> display ssl client-policy policy1
 SSL Client Policy: policy1
     SSL Version: SSL 3.0
     PKI Domain: 1
     Prefer Ciphersuite:
         RSA_RC4_128_SHA
     Server-verify: enabled
SSL Client Policy
SSL client policy name.
SSL Version
Version of the protocol used by the SSL client policy, SSL 3.0 or TLS 1.0
PKI Domain
PKI domain of the SSL client policy.
Prefer Ciphersuite
Preferred cipher suite of the SSL client policy.
Server-verify
Whether server authentication is enabled for the SSL client policy.
display ssl server-policy { policy-name | all } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
policy-name: Specifies an SSL server policy by its name, a case-insensitive string of 1 to 16 characters.
all: Displays information about all SSL server policies.
Use display ssl server-policy to view information about a specified SSL server policy or all SSL server policies.
# Display information about SSL server policy policy1.
<Sysname> display ssl server-policy policy1
 SSL Server Policy: policy1
     PKI Domain: domain1
     Ciphersuite:
         RSA_RC4_128_MD5
         RSA_RC4_128_SHA
         RSA_DES_CBC_SHA
         RSA_3DES_EDE_CBC_SHA
         RSA_AES_128_CBC_SHA
         RSA_AES_256_CBC_SHA
     Handshake Timeout: 3600
     Close-mode: wait disabled
     Session Timeout: 3600
     Session Cachesize: 500
     Client-verify: disabled
     Client-verify weaken: disabled
SSL Server Policy
SSL server policy name.
PKI Domain
PKI domain used by the SSL server policy.
Ciphersuite
Cipher suites supported by the SSL server policy.
Handshake Timeout
Handshake timeout time of the SSL server policy, in seconds.
Close-mode
Close mode of the SSL server policy:
·     wait disabled—In this mode, the server sends a close-notify alert message to the client and then closes the connection immediately without waiting for the close-notify alert message of the client.
·     wait enabled—In this mode, the server sends a close-notify alert message to the client and then waits for the close-notify alert message of the client. The server closes the connection only when it receives the expected message.
Session Timeout
Session timeout time of the SSL server policy, in seconds.
Session Cachesize
Maximum number of buffered sessions of the SSL server policy.
Client-verify
Whether the SSL server policy requires the client to be authenticated.
handshake timeout
handshake timeout time
undo handshake timeout
View
Default level
2: System level
time: Specifies the handshake timeout time in seconds, in the range of 180 to 7200.
Use handshake timeout to set the handshake timeout time for an SSL server policy.
Use undo handshake timeout to restore the default.
By default, the handshake timeout time is 3600 seconds.
If the SSL server does not receive any packet from the SSL client before the handshake timeout time expires, the SSL server will terminate the handshake process.
# Set the handshake timeout time of SSL server policy policy1 to 3000 seconds.
[Sysname-ssl-server-policy-policy1] handshake timeout 3000
pki-domain
pki-domain domain-name
undo pki-domain
View
SSL server policy view, SSL client policy view
Default level
2: System level
domain-name: Specify a PKI domain by its name, a case-insensitive string of 1 to 15 characters.
Use pki-domain to specify a PKI domain for an SSL server policy or SSL client policy.
Use undo pki-domain to restore the default.
By default, no PKI domain is configured for an SSL server policy or SSL client policy.
Related commands: display ssl server-policy and display ssl client-policy.
# Configure SSL server policy policy1 to use PKI domain server-domain.
[Sysname-ssl-server-policy-policy1] pki-domain server-domain
# Configure SSL client policy policy1 to use PKI domain client-domain.
[Sysname] ssl client-policy policy1
[Sysname-ssl-client-policy-policy1] pki-domain client-domain
prefer-cipher
prefer-cipher { dhe_rsa_aes_128_cbc_sha | dhe_rsa_aes_256_cbc_sha | rsa_3des_ede_cbc_sha | rsa_aes_128_cbc_sha | rsa_aes_256_cbc_sha | rsa_des_cbc_sha | rsa_rc4_128_md5 | rsa_rc4_128_sha }
undo prefer-cipher
View
Default level
2: System level
Use prefer-cipher to specify the preferred cipher suite for an SSL client policy.
Use undo prefer-cipher to restore the default.
By default, the preferred cipher suite for an SSL client policy is rsa_rc4_128_md5.
Related commands: display ssl client-policy.
# Set the preferred cipher suite for SSL client policy policy1 to rsa_aes_128_cbc_sha.
[Sysname-ssl-client-policy-policy1] prefer-cipher rsa_aes_128_cbc_sha
server-verify enable
undo server-verify enable
View
Default level
2: System level
None
Use server-verify enable to enable certificate-based SSL server authentication so that the SSL client authenticates the server by the server’s certificate during the SSL handshake process.
Use undo server-verify enable to disable certificate-based SSL server authentication. When certificate-based SSL server authentication is disabled, it is assumed that the SSL server is valid.
By default, certificate-based SSL server authentication is enabled.
# Enable certificate-based SSL server authentication.
[Sysname-ssl-client-policy-policy1] server-verify enable
session
undo session { cachesize | timeout } *
View
Default level
2: System level
cachesize size: Specifies the maximum number of cached sessions, in the range of 100 to 1000.
timeout time: Specifies the caching timeout time in seconds, in the range of 1800 to 72000.
Use session to set the maximum number of cached sessions and the caching timeout time.
Use undo session to restore the default.
By default, the maximum number of cached sessions is 500 and the caching timeout time is 3600 seconds.
It is a complicated process to use the SSL handshake protocol to negotiate session parameters and establish sessions. To simplify the process, SSL allows reusing negotiated session parameters to establish sessions. This feature requires that the SSL server maintain information about existing sessions.
The number of cached sessions and the session information caching time are limited:
·     If the number of sessions in the cache reaches the maximum, SSL does not cache new sessions.
·     If a session has been cached for a period equal to the caching timeout time, SSL will remove session from the cache.
# Set the caching timeout time to 4000 seconds and the maximum number of cached sessions to 600.
[Sysname-ssl-server-policy-policy1] session timeout 4000 cachesize 600
ssl client-policy
ssl client-policy policy-name
undo ssl client-policy { policy-name | all }
View
Default level
2: System level
policy-name: Specifies an SSL client policy name, a case-insensitive string of 1 to 16 characters. The string cannot be a, al, or all.
all: Specifies all SSL client policies.
Use ssl client-policy to create an SSL policy and enter its view.
Use undo ssl client-policy to delete a specified SSL client policy or all SSL client policies.
# Create SSL client policy policy1 and enter its view.
ssl server-policy
ssl server-policy policy-name
undo ssl server-policy { policy-name | all }
View
Default level
2: System level
policy-name: Specifies an SSL server policy name, a case-insensitive string of 1 to 16 characters. The string cannot be a, al, or all.
all: Specifies all SSL server policies.
Use ssl server-policy to create an SSL server policy and enter its view.
Use undo ssl server-policy to delete a specified SSL server policy or all SSL server policies.
You cannot delete an SSL server policy that has been associated with one or more application layer protocols.
# Create SSL server policy policy1 and enter its view.
version
version { ssl3.0 | tls1.0 }
undo version
View
Default level
2: System level
ssl3.0: Specifies SSL 3.0. This keyword is not available for FIPS mode.
tls1.0: Specifies TLS 1.0.
Use version to specify the SSL protocol version for an SSL client policy.
Use undo version to restore the default.
By default, the SSL protocol version for an SSL client policy is TLS 1.0.
# Specify the SSL protocol version for SSL client policy policy1 as SSL 3.0.
[Sysname-ssl-client-policy-policy1] version ssl3.0
