11-Security Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18211-Security Command Reference
12-ARP Attack Protection Commands
12-ARP Attack Protection Commands 111.4 KB
ARP defense against IP packet attacks configuration commands
arp resolving-route enable
undo arp resolving-route enable
View
Default level
2: System level
None
Use arp resolving-route enable to enable ARP blackhole routing.
Use undo arp resolving-route enable to disable the function.
By default, ARP blackhole routing is enabled.
# Enable ARP blackhole routing.
[Sysname] arp resolving-route enable
arp source-suppression enable
undo arp source-suppression enable
View
Default level
2: System level
None
Use arp source-suppression enable to enable the ARP source suppression function.
Use undo arp source-suppression enable to disable the function.
By default, the ARP source suppression function is disabled.
Related commands: display arp source-suppression.
# Enable the ARP source suppression function.
[Sysname] arp source-suppression enable
arp source-suppression limit
undo arp source-suppression limit
View
Default level
2: System level
limit-value: Specifies the maximum number of packets with the same source IP address and unresolvable destination IP addresses that the switch can receive in 5 seconds. The value is in the range of 2 to 1024.
Use arp source-suppression limit to set the maximum number of packets with the same source IP address and unresolvable destination IP addresses that the switch can receive in 5 seconds.
Use undo arp source-suppression limit to restore the default value, which is 10.
With this feature configured, if the number of packets with unresolvable destination IP addresses sent from a host within 5 seconds exceeds the specified threshold, the switch stops the sending host from triggering any ARP requests within the following 5 seconds.
# Set the maximum number of packets with the same source address and unresolvable destination IP addresses that the switch can receive in 5 seconds to 100.
[Sysname] arp source-suppression limit 100
display arp source-suppression [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display arp source-suppression to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 100
 Current cache length: 16
Maximum number of packets with the same source IP address but unresolvable destination IP addresses that the switch can receive in 5 seconds.
Size of cache used to record source suppression information.
ARP packet rate limit configuration commands
arp rate-limit
arp rate-limit { disable | rate pps drop }
undo arp rate-limit
View
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
Default level
2: System level
disable: Disables ARP packet rate limit.
rate pps: ARP packet rate in the range of 10 to 5000 pps.
drop: Discards the exceeded packets.
Use arp rate-limit to configure or disable ARP packet rate limit on an interface.
Use undo arp rate-limit to restore the default.
By default, ARP packet rate limit is disabled.
# Specify the ARP packet rate on GigabitEthernet 3/0/1 as 30 pps, and exceeded packets will be discarded.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] arp rate-limit rate 30 drop
Source MAC-based ARP attack detection configuration commands
arp anti-attack source-mac
arp anti-attack source-mac { filter | monitor }
undo arp anti-attack source-mac [ filter | monitor ]
View
Default level
2: System level
filter: Generates log messages and discards subsequent ARP packets from the MAC address.
monitor: Only generates log message.
Use arp anti-attack source-mac to enable the source MAC-based ARP attack detection and specify a handling method.
Use undo arp anti-attack source-mac to restore the default.
By default, source MAC-based ARP attack detection is disabled.
This function enables the switch to check the source MAC address of ARP packets received from the same MAC address within 5 seconds against a specific threshold. If the threshold is exceeded, the switch takes the preconfigured method to handle the attack.
If neither the filter nor the monitor keyword is specified in the undo arp anti-attack source-mac command, both handling methods are disabled.
# Enable the source MAC-based ARP attack detection and specify the filter handling method.
[Sysname] arp anti-attack source-mac filter
arp anti-attack source-mac aging-time
arp anti-attack source-mac aging-time time
undo arp anti-attack source-mac aging-time
View
Default level
2: System level
time: Age time for ARP attack entries, in the range of 60 to 6000 seconds.
Use arp anti-attack source-mac aging-time to configure the age time for source MAC addresses based on ARP attack detection entries.
Use undo arp anti-attack source-mac aging-time to restore the default.
By default, the age time for ARP attack entries is 300 seconds (5 minutes).
# Set the age time for ARP attack entries as 60 seconds.
[Sysname] arp anti-attack source-mac aging-time 60
arp anti-attack source-mac exclude-mac
arp anti-attack source-mac exclude-mac mac-address&<1-n>
undo arp anti-attack source-mac exclude-mac [ mac-address&<1-n> ]
View
Default level
2: System level
mac-address&<1-n>: MAC address list. The mac-address argument indicates an excluded MAC address in the format H-H-H. The maximum value for the n argument is 64. &<1-64> indicates that you can exclude up to 64 MAC addresses at a time.
Use arp anti-attack source-mac exclude-mac to exclude specific MAC addresses from source MAC-based ARP attack detection.
Use undo arp anti-attack source-mac exclude-mac to remove the specified MAC addresses.
By default, MAC address is excluded from source MAC-based ARP attack detection.
If you do not specify any MAC address in the undo arp anti-attack source-mac exclude-mac command, this command removes all excluded MAC addresses.
# Exclude a MAC address from source MAC-based ARP attack detection.
[Sysname] arp anti-attack source-mac exclude-mac 2-2-2
arp anti-attack source-mac threshold
arp anti-attack source-mac threshold threshold-value
undo arp anti-attack source-mac threshold
View
Default level
2: System level
threshold-value: Specifies the threshold for source MAC-based ARP attack detection, in the range of 25 to 1500. The default value is 150.
Use arp anti-attack source-mac threshold to configure the threshold for source MAC-based ARP attack detection. If the number of ARP packets from a MAC address within 5 seconds exceeds this threshold, the switch recognizes this as an attack.
Use undo arp anti-attack source-mac threshold to restore the default.
# Configure the threshold for source MAC-based ARP attack detection as 30.
[Sysname] arp anti-attack source-mac threshold 30
display arp anti-attack source-mac
In standalone mode:
display arp anti-attack source-mac { slot slot-number | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display arp anti-attack source-mac { chassis chassis-number slot slot-number | interface interface-type interface number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays ARP attack entries detected on the interface.
slot slot-number: Displays ARP attack entries detected on the interface card specified by the slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP attack entries detected on a card of an IRF member switch. The chassis-number argument refers to the ID of the IRF member switch. The slot-number argument refers to the number of the slot where the card resides. You can display the member ID and slot number with the display device command. (In IRF mode.)
Use display arp anti-attack source-mac to display ARP attack entries detected by source MAC-based ARP attack detection.
# Display the ARP attack entries detected by source MAC-based ARP attack detection. (In standalone mode.)
<Sysname> display arp anti-attack source-mac slot 3
Source-MAC          VLAN-ID           Interface             Aging-time
23f3-1122-3344      4094              GE3/0/2                 10
23f3-1122-3355      4094              GE3/0/3                 30
23f3-1122-33ff      4094              GE3/0/4                 25
23f3-1122-33ad      4094              GE3/0/5                 30
23f3-1122-33ce      4094              GE3/0/6                 2
# Display the ARP attack entries detected by source MAC-based ARP attack detection. (In IRF mode.)
<Sysname> display arp anti-attack source-mac chassis 1 slot 3
Source-MAC          VLAN ID           Interface             Aging-time
23f3-1122-3344      4094              GE1/3/0/2                 10
23f3-1122-3355      4094              GE1/3/0/3                 30
23f3-1122-33ff      4094              GE1/3/0/4                 25
23f3-1122-33ad      4094              GE1/3/0/5                 30
23f3-1122-33ce      4094              GE1/3/0/6                 2
ARP packet source mac address consistency check configuration commands
arp anti-attack valid-check enable
undo arp anti-attack valid-check enable
View
Default level
2: System level
None
Use arp anti-attack valid-check enable to enable ARP packet source MAC address consistency check on the gateway. After you execute this command, the gateway device can filter out ARP packets with the source MAC address in the Ethernet header different from the sender MAC address in the ARP message.
Use undo arp anti-attack valid-check enable to restore the default.
By default, ARP packet source MAC address consistency check is disabled.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp anti-attack valid-check enable
ARP active acknowledgement configuration commands
arp anti-attack active-ack enable
undo arp anti-attack active-ack enable
View
Default level
2: System level
None
Use arp anti-attack active-ack enable to enable the ARP active acknowledgement function.
Use undo arp anti-attack active-ack enable to restore the default.
By default, the ARP active acknowledgement function is disabled.
This feature is configured on gateway devices to identify invalid ARP packets.
# Enable the ARP active acknowledgement function.
[Sysname] arp anti-attack active-ack enable
Authorized ARP configuration commands
This feature is supported only on Layer 3 Ethernet interfaces. For more information about the operating modes of Ethernet interfaces, see Interface Configuration Guide.
arp authorized enable
undo arp authorized enable
View
Default level
2: System level
None
Use arp authorized enable to enable authorized ARP on an interface.
Use undo arp authorized enable to restore the default.
By default, authorized ARP is not enabled on the interface.
# Enable authorized ARP on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] port link-mode route
[Sysname-GigabitEthernet3/0/1] arp authorized enable
ARP detection configuration commands
arp detection enable
undo arp detection enable
View
VLAN view
Default level
2: System level
None
Use arp detection enable to enable ARP detection for the VLAN.
Use undo arp detection enable to restore the default.
By default, ARP detection is disabled for a VLAN.
# Enable ARP detection for VLAN 1.
[Sysname] vlan 1
[Sysname-Vlan1] arp detection enable
arp detection trust
arp detection trust
undo arp detection trust
View
Default level
2: System level
None
Use arp detection trust to configure the port as an ARP trusted port.
Use undo arp detection trust to restore the default.
By default, the port is an ARP untrusted port.
# Configure GigabitEthernet 3/0/1 as an ARP trusted port.
[Sysname-GigabitEthernet3/0/1] arp detection trust
arp detection validate
undo arp detection validate [ dst-mac | ip | src-mac ] *
View
Default level
2: System level
dst-mac: Checks the target MAC address of ARP responses. If the target MAC address is all-zero, all-one, or inconsistent with the destination MAC address in the Ethernet header, the packet is considered invalid and discarded.
ip: Checks the source and destination IP addresses of ARP packets. The all-zero, all-one or multicast IP addresses are considered invalid and the corresponding packets are discarded. With this keyword specified, the source and destination IP addresses of ARP replies, and the source IP address of ARP requests will be checked.
src-mac: Checks whether the sender MAC address of an ARP packet is identical to the source MAC address in the Ethernet header. If they are identical, the packet is considered valid. Otherwise, the packet is discarded.
Use arp detection validate to configure ARP detection based on specified objects. You can specify one or more objects in one command line.
Use undo arp detection validate to remove detected objects. If you do not specify any keyword, this command removes all detected objects.
# Enable the checking of the MAC addresses and IP addresses of ARP packets.
[Sysname] arp detection validate dst-mac src-mac ip
undo arp restricted-forwarding enable
View
VLAN view
Default level
2: System level
None
Use arp restricted-forwarding enable to enable ARP restricted forwarding.
Use undo arp restricted-forwarding enable to disable ARP restricted forwarding.
By default, ARP restricted forwarding is disabled.
# Enable ARP restricted forwarding in VLAN 100.
[Sysname] vlan 100
[Sysname-vlan100] arp restricted-forwarding enable
display arp detection
display arp detection [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display arp detection to display the VLANs enabled with ARP detection.
Related commands: arp detection enable.
# Display the VLANs enabled with ARP detection.
<Sysname> display arp detection
ARP detection is enabled in the following VLANs:
1, 2, 4-5
display arp detection statistics
display arp detection statistics [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Displays the ARP detection statistics of a specific interface.
Use display arp detection statistics to display statistics about ARP detection. This command only displays numbers of discarded packets. If you do not specify any interface, this command displays the statistics of all interfaces.
# Display the ARP detection statistics of all interfaces.
<Sysname> display arp detection statistics
State: U-Untrusted  T-Trusted
ARP packets dropped by ARP inspect checking:
Interface(State)          IP         Src-MAC    Dst-MAC    Inspect
GE3/0/1(U)                 0         0             0       0
GE3/0/2(U)                 40        0             0       78
GE3/0/3(U)                 0         0             0       0
GE3/0/4(T)                 0         0             0       0
Interface(State)
State T or U identifies a trusted or untrusted port.
IP
Number of ARP packets discarded due to invalid source and destination IP addresses.
Src-MAC
Number of ARP packets discarded due to invalid source MAC address.
Dst-MAC
Number of ARP packets discarded due to invalid destination MAC address.
Inspect
Number of ARP packets that failed to pass ARP detection (based on static IP Source Guard binding entries/DHCP snooping entries/802.1X security entries/OUI MAC addresses).
reset arp detection statistics
reset arp detection statistics [ interface interface-type interface-number ]
View
Default level
1: Monitor level
interface interface-type interface-number: Clears the ARP detection statistics of a specific interface.
Use reset arp detection statistics to clear ARP detection statistics of a specific interface. If you do not specify any interface, this command displays the statistics of all interfaces.
# Clear the ARP detection statistics of all interfaces.
<Sysname> reset arp detection statistics
