11-Security Command Reference
HomeSupportSwitchesH3C S9500E Switch SeriesReference GuidesCommand ReferencesH3C S9500E Command References-Release1828P04-6W18211-Security Command Reference
08-SSH Commands
08-SSH Commands 188.58 KB
SSH configuration commands
SSH server configuration commands
display ssh server
display ssh server { session | status } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
session: Displays the session information of the SSH server.
status: Displays the status information of the SSH server.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display ssh server on an SSH server to display SSH server status information or session information.
Related commands: ssh server authentication-retries, ssh server rekey-interval, ssh server authentication-timeout, ssh server enable, and ssh server compatible-ssh1x enable.
# Display the SSH server status information.
<Sysname> display ssh server status
 SSH server: Disable
 SSH version : 1.99
 SSH authentication-timeout : 60 second(s)
 SSH server key generating interval : 0 hour(s)
 SSH authentication retries : 3 time(s)
 SFTP server: Disable
 SFTP server Idle-Timeout: 10 minute(s)
SSH server
Whether the SSH server function is enabled.
SSH version
SSH protocol version.
When the SSH supports SSH1, the protocol version is 1.99. Otherwise, the protocol version is 2.
Authentication timeout timer.
SSH server key pair update interval.
Maximum number of SSH authentication attempts.
SFTP server
Whether the SFTP server function is enabled.
SFTP connection idle timeout timer.
# Display the SSH server session information.
<Sysname> display ssh server session
 Conn   Ver   Encry    State         Retry    SerType  Username
 VTY 0  2.0   DES      Established   0        SFTP     client001
Conn
Connected VTY channel.
Ver
SSH server protocol version.
Encry
Encryption algorithm.
Status of the session:
·     Init—Initialization.
·     Ver-exchange—Version negotiation.
·     Keys-exchange—Keys exchange.
·     Auth-request—Authentication request.
·     Serv-request—Session service request.
·     Established—The session is established.
·     Disconnected—The session is disconnected.
Retry
Number of authentication failures.
SerType
Service type, including SFTP, Secure Telnet (Stelnet), and secure copy (SCP).
Username
Name of a user during login.
display ssh user-information
display ssh user-information [ username ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
username: Specifies an SSH username, a string of 1 to 80 characters.
Use display ssh user-information on an SSH server to display information about one or all SSH users.
The users displayed by this command are only those configured by the ssh user command on the SSH server.
With the username argument not specified, the command displays information about all SSH users.
Related commands: ssh user.
# Display information about all SSH users.
<Sysname> display ssh user-information
 Total ssh users : 2
 Username    Authentication-type   User-public-key-name     Service-type
 yemx        password              null                      stelnet
 test        publickey             pubkey                     sftp
Username
Name of the user.
Authentication-type
Authentication method:
·     Password authentication.
·     Publickey authentication.
·     Password-publickey authentication.
·     Any authentication.
Public key of the user. If password authentication is used, this field displays null.
Service-type
Service type, including SFTP, Stelnet, SCP, and all. If all authentication methods are supported, this field displays all.
sftp server enable
sftp server enable
undo sftp server enable
View
Default level
3: Manage level
None
Use sftp server enable to enable the SFTP server function.
Use undo sftp server enable to disable the SFTP server function.
By default, the SFTP server function is disabled.
You can use the display ssh server command to view the status or session information of the SFTP server.
Related commands: display ssh server.
# Enable SFTP server.
[Sysname] sftp server enable
sftp server idle-timeout
undo sftp server idle-timeout
View
Default level
3: Manage level
time-out-value: Specifies a timeout timer in minutes, in the range of 1 to 35791.
Use sftp server idle-timeout to set the idle timeout timer for SFTP user connections.
Use undo sftp server idle-timeout to restore the default.
By default, the idle timeout timer is 10 minutes.
If an SFTP connection is idle when the idle timeout timer expires, the system automatically terminates the connection. If many SFTP connections are established, you can set a small value so that the connection resources can be timely released.
# Set the idle timeout timer for SFTP user connections to 500 minutes.
[Sysname] sftp server idle-timeout 500
ssh server authentication-retries times
undo ssh server authentication-retries
View
Default level
3: Manage level
times: Specifies the maximum number of authentication attempts, in the range 1 to 5.
Use ssh server authentication-retries to set the maximum number of SSH connection authentication attempts, which takes effect at next login.
Use undo ssh server authentication-retries to restore the default.
By default, the maximum number of SSH connection authentication attempts is 3.
You can set this limit to prevent malicious hacking of usernames and passwords.
This configuration takes effect only on the users at next login.
Authentication fails if the number of authentication attempts (including both publickey and password authentication) exceeds the upper limit configured by this command.
If the authentication method of SSH users is password-publickey, the maximum number of SSH connection authentication attempts must be no less than 2. This is because SSH users must pass both password and publickey authentication.
# Set the maximum number of SSH connection authentication attempts to 4.
[Sysname] ssh server authentication-retries 4
undo ssh server authentication-timeout
View
Default level
3: Manage level
time-out-value: Specifies the authentication timeout timer in seconds, in the range 1 to 120.
Use ssh server authentication-timeout to set the SSH user authentication timeout timer on the SSH server. If a user does not finish the authentication when the timer expires, the connection cannot be established.
Use undo ssh server authentication-timeout to restore the default.
By default, the authentication timeout timer is 60 seconds.
You can set a small value for this timer to prevent malicious occupation of TCP connections.
# Set the SSH user authentication timeout timer to 10 seconds.
[Sysname] ssh server authentication-timeout 10
undo ssh server compatible-ssh1x
View
Default level
3: Manage level
None
Use ssh server compatible-ssh1x enable to enable the SSH server to support SSH1 clients.
Use undo ssh server compatible-ssh1x to disable the SSH server from supporting SSH1 clients.
By default, the SSH server supports SSH1 clients.
This configuration takes effect only on the clients at next login.
# Enable the SSH server to support SSH1 clients.
[Sysname] ssh server compatible-ssh1x enable
ssh server enable
ssh server enable
undo ssh server enable
View
Default level
3: Manage level
None
Use ssh server enable to enable SSH server so that the SSH clients use SSH to communicate with the server.
Use undo ssh server enable to disable SSH server.
By default, SSH server is disabled.
# Enable SSH server.
[Sysname] ssh server enable
ssh server rekey-interval hours
undo ssh server rekey-interval
View
Default level
3: Manage level
hours: Specifies the server key update interval in hours, in the range 1 to 24.
Use ssh server rekey-interval to set the interval for updating the RSA server key pair.
Use undo ssh server rekey-interval to remove the configuration.
By default, the update interval of the RSA server key pair is 0. The system does not update the RSA server key pair.
Updating the RSA server key periodically can prevent malicious hacking of the key and enhance security of the SSH connections.
This command is only available for SSH users that use SSH1 client software.
The system does not update any DSA key pair periodically.
# Set the RSA server key pair update interval to 3 hours.
[Sysname] ssh server rekey-interval 3
ssh user
ssh user username service-type stelnet authentication-type { password | { any | password-publickey | publickey } assign publickey keyname }
ssh user username service-type { all | scp | sftp } authentication-type { password | { any | password-publickey | publickey } assign publickey keyname work-directory directory-name }
undo ssh user username
View
Default level
3: Manage level
username: Specifies an SSH username, a case-sensitive string of 1 to 80 characters.
service-type: Specifies the service type of an SSH user:
·     all: Specifies Stelnet, SFTP, and SCP.
·     scp: Specifies the service type as SCP.
·     sftp: Specifies the service type as secure FTP.
·     stelnet: Specifies the service type of secure Telnet.
authentication-type: Specifies the authentication method of an SSH user:
·     password: Specifies password authentication. This authentication method features easy and fast encryption, but it is vulnerable. It can work with AAA to implement user authentication, authorization, and accounting.
·     any: Specifies either password authentication or publickey authentication. This keyword is not available in FIPS mode.
·     password-publickey: Specifies both password authentication and publickey authentication (featuring higher security) if the client runs SSH2, and specifies either type of authentication if the client runs SSH1.
·     publickey: Specifies publickey authentication. This authentication method has complicated and slow encryption, but it provides strong authentication that can defend against brute-force attacks. This authentication method is easy to use. If this method is configured, the authentication process completes automatically without the need of entering any password. This keyword is not available in FIPS mode.
assign publickey keyname: Assigns an existing public key to an SSH user. The keyname argument is a string of 1 to 64 characters.
work-directory directory-name: Specifies the working folder for an SFTP user. The directory-name argument is a string of 1 to 135 characters.
Use ssh user to create an SSH user and specify the service type and authentication method.
Use undo ssh user to delete an SSH user.
If the SSH server uses publickey authentication, you must create an SSH user account on the device. If the SSH server uses password authentication, you do not need to create the user account on the device, but you must configure the user account information on the device for local authentication, or on the remote authentication server (such as a RADIUS server) for remote authentication.
If you use the ssh user command to configure a public key for a user who has already had a public key, the new one overwrites the old one.
You can change the authentication method, service type, and host public key for an SSH user when the user is communicating with the SSH server, However, your changes does not affect the user that has logged in but the user that tries to log in after your configuration.
If an SFTP or SCP user has been assigned a public key, it is necessary to set a working folder for the user.
The working directory of an SFTP or SCP user depends on the authentication method. If the authentication method is password, the working folder is authorized by AAA. If the authentication method is publickey or password-publickey, the working folder is set by using the ssh user command.
Related commands: display ssh user-information.
# Create an SSH user named user1, setting the service type as sftp, the authentication method as publickey, assigning a public key named key1 to the client, and the work folder of the SFTP server as flash:.
[Sysname] ssh user user1 service-type sftp authentication-type publickey assign publickey key1 work-directory flash:
SSH client configuration commands
bye
bye
View
SFTP client view
Default level
3: Manage level
None
Use bye to terminate the connection with the SFTP server and return to user view.
This command functions as the exit and quit commands.
# Terminate the connection with the SFTP server.
sftp-client> bye
Bye
Connection closed.
<Sysname>
cd
cd [ remote-path ]
View
SFTP client view
Default level
3: Manage level
remote-path: Name of a path on the server.
Use cd to change the working path on an SFTP server. If the argument is not specified, the command displays the current working path.
You can use the cd .. command to return to the upper-level directory.
You can use the cd / command to return to the root directory of the system.
# Change the working path to new1.
sftp-client> cd new1
Current Directory is:/new1
cdup
cdup
View
SFTP client view
Default level
3: Manage level
None
Use cdup to return to the upper-level directory.
# Return to the upper-level directory from the current working directory /new1.
sftp-client> cdup
delete
delete remote-file&<1-10>
View
SFTP client view
Default level
3: Manage level
remote-file&<1-10>: Specifies the name of a file on the server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use delete to delete the specified files from a server.
This command functions as the remove command.
# Delete the file temp.c from the server.
sftp-client> delete temp.c
The following files will be deleted:
/temp.c
Are you sure to delete it? [Y/N]:y
This operation may take a long time. Please wait...
File successfully Removed
dir
View
SFTP client view
Default level
3: Manage level
-a: Displays the filenames or the folder names of the specified directory.
-l: Displays detailed information about the files and sub-directories of the specified directory in the form of a list.
remote-path: Specifies the name of the directory to be queried. If this argument is not specified, the command displays information about the files and sub-directories under the current working directory.
Use dir to display file and folder information under the specified directory.
If the –a and –l keywords are not specified, the command displays detailed information about the files and sub-directories under the specified working directory.
This command functions as the ls command.
# Display detailed information about the files and sub-directories under the current working directory in the form of a list.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:28 pub1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:24 new1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:18 new2
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:30 pub2
display sftp client source
display sftp client source [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display sftp client source to display the source IP address or source interface set for the SFTP client.
If neither source IP address nor source interface is specified for the SFTP client, the system will prompt you to specify the source information.
Related commands: sftp client source.
# Display the source IP address set for the SFTP client.
<Sysname> display sftp client source
The source IP address you specified is 192.168.0.1
display ssh client source
display ssh client source [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ssh client source to display the source IP address or source interface information set for an Stelnet client.
If neither source IP address nor source interface is specified for the Stelnet client, the system displays the message "Neither source IP address nor source interface was specified for the Stelnet client."
Related commands: ssh client source.
# Display the source IP address or source interface set for the Stelnet client.
<Sysname> display ssh client source
display ssh server-info
display ssh server-info [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ssh server-info on a client to display mappings between SSH servers and their host public keys saved on the client.
When an SSH client needs to authenticate the SSH server, it uses the locally saved public key of the server for the authentication. If the authentication fails, you can use this command to check the public key of the server saved on the client.
This command is also available on SFTP clients.
Related commands: ssh client authentication server.
# Display the mappings between SSH servers and their host public keys on the client.
<Sysname> display ssh server-info
Server Name(IP)                 Server public key name
______________________________________________________
192.168.0.1                      abc_key01
192.168.0.2                      abc_key02
Server Name(IP)
Name or IP address of the server.
Name of the host public key of the server.
exit
exit
View
SFTP client view
Default level
3: Manage level
None
Use exit to terminate the connection with the SFTP server and return to user view.
This command functions as the bye and quit commands.
sftp-client> exit
Bye
Connection closed.
<Sysname>
get
View
SFTP client view
Default level
3: Manage level
remote-file: Specifies the name of a file on the SFTP server.
local-file: Specifies the name for the local file.
Use get to download a file from the SFTP server and save it locally.
If no local filename is specified, the file is saved locally with the same name as that on the SFTP server.
# Download the file temp1.c and save it as temp.c locally.
sftp-client> get temp1.c temp.c
Remote  file:/temp1.c --->  Local file: temp.c
Downloading file successfully ended
help
help [ all | command-name ]
View
SFTP client view
Default level
3: Manage level
all: Displays all commands.
command-name: Specifies the name of a command.
Use help to display all commands or the help information of an SFTP client command.
If the option is not specified, the command displays a list of all commands.
# Display help information of the get command.
sftp-client> help get
get remote-path [local-path]  Download file Default local-path is the same with remote-path
ls
View
SFTP client view
Default level
3: Manage level
Use ls to display the names of the files and sub-directories under the specified directory.
If the –a and –l keywords are not specified, the command displays detailed information of files and sub-directories under the specified directory in the form of a list.
This command functions as the dir command.
# Display detailed information about files and sub-directories under the current working directory in the form of a list.
sftp-client> ls
mkdir
mkdir remote-path
View
SFTP client view
Default level
3: Manage level
remote-path: Specifies the name for the directory on the SFTP server.
Use mkdir to create a directory on the SFTP server.
# Create a directory named test on the SFTP server.
sftp-client> mkdir test
New directory created
put
View
SFTP client view
Default level
3: Manage level
local-file: Specifies the name of a local file.
remote-file: Specifies the name for the file on an SFTP server.
Use put to upload a local file to an SFTP server.
If the remote-file argument is not specified, the file will be saved remotely with the same name as the local one.
# Upload the local file temp.c to the SFTP server and save it as temp1.c.
sftp-client> put temp.c temp1.c
Local file:temp.c --->  Remote file: /temp1.c
Uploading file successfully ended
pwd
pwd
View
SFTP client view
Default level
3: Manage level
None
Use pwd to display the current working directory of an SFTP server.
# Display the current working directory of the SFTP server.
sftp-client> pwd
View
SFTP client view
Default level
3: Manage level
None
Use quit to terminate the connection with an SFTP server.
This command functions as the bye and exit commands.
sftp-client> quit
Bye
Connection closed.
<Sysname>
remove
remove remote-file&<1-10>
View
SFTP client view
Default level
3: Manage level
remote-file&<1-10>: Specifies the name of a file on an SFTP server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use remove to delete the specified files from a remote server.
This command functions as the delete command.
sftp-client> remove temp.c
/temp.c
This operation may take a long time.Please wait...
rename
rename oldname newname
View
SFTP client view
Default level
3: Manage level
oldname: Specifies the name of an existing file or directory.
newname: Specifies a new name for the file or directory.
Use rename to change the name of a file or directory on an SFTP server.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp-client> rename temp1.c temp2.c
File successfully renamed
rmdir
rmdir remote-path&<1-10>
View
SFTP client view
Default level
3: Manage level
remote-path&<1-10>: Specifies the name of the directory on the SFTP server. &<1-10> means that you can provide up to 10 directory names that are separated by space.
Use rmdir to delete the specified directories from an SFTP server.
#Delete the directory temp1 in the current directory on the SFTP server.
sftp-client> rmdir temp1
Directory successfully removed
scp
scp [ ipv6 ] server [ port-number ] { get | put } source-file-path [ destination-file-path ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default level
3: Manage level
ipv6: Specifies the type of the server as IPv6. If this keyword is not specified, the server is an IPv4 server.
server: Specifies an IPv4 or IPv6 server by its address or host name. For an IPv4 server, it is a case-insensitive string of 1 to 20 characters. For an IPv6 server, it is a case-insensitive string of 1 to 46 characters.
port-number: Specifies the port number of the server, in the range of 0 to 65535. The default is 22.
get: Downloads the file.
put: Uploads the file.
source-file-path: Specifies the directory of the source file.
destination-file-path: Specifies the directory of the target file. If this argument is not specified, the directory names of the source and target files are same.
identity-key: Specifies the algorithm for publickey authentication, either dsa or rsa. The default is dsa.
·     dsa: Specifies the public key algorithm dsa. This algorithm is not available in FIPS mode.
·     rsa: Specifies the public key algorithm rsa.
prefer-ctos-cipher: Specifies the preferred encryption algorithm from client to server. The default is aes128.
·     3des: Specifies the encryption algorithm 3des-cbc. This algorithm is not available in FIPS mode.
·     aes128: Specifies the encryption algorithm aes128-cbc.
·     aes256: Specifies the encryption algorithm aes256-cbc. This algorithm is available only in FIPS mode.
·     des: Specifies the encryption algorithm des-cbc. This algorithm is not available in FIPS mode.
prefer-ctos-hmac: Specifies the preferred HMAC algorithm from client to server. The default is sha1-96.
·     md5: Specifies the HMAC algorithm hmac-md5. This algorithm is not available in FIPS mode.
·     md5-96: Specifies the HMAC algorithm hmac-md5-96. This algorithm is not available in FIPS mode.
·     sha1: Specifies the HMAC algorithm hmac-sha1.
·     sha1-96: Specifies the HMAC algorithm hmac-sha1-96.
prefer-kex: Specifies the preferred key exchange algorithm. The default is dh-group-exchange.
·     dh-group-exchange: Specifies the key exchange algorithm diffie-hellman-group-exchange-sha1. This algorithm is not available in FIPS mode.
·     dh-group1: Specifies the key exchange algorithm diffie-hellman-group1-sha1. This algorithm is not available in FIPS mode.
·     dh-group14: Specifies the key exchange algorithm diffie-hellman-group14-sha1.
prefer-stoc-cipher: Specifies the preferred encryption algorithm from server to client. The default is aes128.
prefer-stoc-hmac: Specifies the preferred HMAC algorithm from server to client. The default is sha1-96.
Use scp to transfer files with an SCP server.
When the client's authentication method is publickey, the client must get the local private key for digital signature. As the publickey authentication uses RSA and DSA algorithms, you must specify an algorithm (by using the identity-key keyword) in order to get the correct data for the local private key. By default, the public key algorithm is DSA.
Only SSH users whose user privilege level is 3 can upload files to the SCP server.
# Connect to the SCP server (192.168.0.1), download the file remote.bin from the server, and save it locally to the file local.bin
<Sysname> scp 192.168.0.1 get remote.bin local.bin
sftp
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default level
3: Manage level
server: Specifies the IPv4 address or host name of the server, a case-insensitive string of 1 to 20 characters.
port-number: Specifies the port number of the server, in the range 0 to 65535. The default is 22.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the server belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the server is on the public network, do not specify this option.
Use sftp to establish a connection to an IPv4 SFTP server and enter SFTP client view.
When the server adopts publickey authentication to authenticate a client, the client must get the local private key for digital signature. Because publickey authentication uses RSA and DSA algorithms, you must specify the public key algorithm of the client (by using the identity-key keyword) in order to get the correct local private key. By default, the public key algorithm is DSA.
# Connect to SFTP server 10.1.1.2, using the following connection scheme:
·     The preferred key exchange algorithm is dh-group1.
·     The preferred encryption algorithm from server to client is aes128.
·     The preferred HMAC algorithm from client to server is md5.
·     The preferred HMAC algorithm from server to client is sha1-96.
<Sysname> sftp 10.1.1.2 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
Input Username:
sftp client ipv6 source
sftp client ipv6 source { interface interface-type interface-number | ipv6 ipv6-address }
undo sftp client ipv6 source
View
Default level
3: Manage level
interface interface-type interface-number: Specifies a source interface by its type and number.
ipv6 ipv6-address: Specifies a source IPv6 address.
Use sftp client ipv6 source to specify the source IPv6 address or source interface for the SFTP client.
Use undo sftp client ipv6 source to remove the configuration.
By default, the client uses the interface address specified by the route of the switch to access the SFTP server.
To make sure that the SFTP client and the SFTP server can communicate with each other, and to improve the manageability of SFTP clients in the authentication service, H3C recommends you to specify a loopback interface as the source interface.
Related commands: display sftp client source.
# Specify the source IPv6 address of the SFTP client as 2:2::2:2.
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
sftp client source
sftp client source { interface interface-type interface-number | ip ip-address }
undo sftp client source
View
Default level
3: Manage level
ip ip-address: Specifies a source IPv4 address.
Use sftp client source to specify the source IPv4 address or interface of an SFTP client.
Use undo sftp client source to remove the configuration.
By default, a client uses the IP address of the interface specified by the route to access the SFTP server.
# Specify the source IP address of the SFTP client as 192.168.0.1.
[Sysname] sftp client source ip 192.168.0.1
sftp ipv6
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default level
3: Manage level
server: Specifies the IPv6 address or host name of the server, a case-insensitive string of 1 to 46 characters.
Use sftp ipv6 to establish a connection to an IPv6 SFTP server and enter SFTP client view.
# Connect to server 2:5::8:9, using the following connection scheme:
<Sysname> sftp ipv6 2:5::8:9 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
Input Username:
ssh client authentication server server assign publickey keyname
undo ssh client authentication server server assign publickey
View
Default level
2: System level
server: Specifies the IP address or name of the server, a string of 1 to 80 characters.
keyname: Specifies the name of the host public key of the server, a string of 1 to 64 characters.
Use ssh client authentication server on the client to configure the host public key of the specified server so that the client can determine whether the server is trustworthy.
Use undo ssh client authentication server to remove the configuration.
By default, no host public key of a server is configured. When the client logs into a server, it uses the IP address or host name of the server as the public key name.
If the client does not support first authentication, it will reject unauthenticated servers. In this case, you need to configure the public keys of the servers and specify the mappings between public keys and servers on the client, so that the client uses the correct public key of a server to authenticate the server.
The specified host public key of the server must already exist.
Related commands: ssh client first-time enable.
# Configure the public key of the server at 192.168.0.1 to be key1.
[Sysname] ssh client authentication server 192.168.0.1 assign publickey key1
undo ssh client first-time
View
Default level
2: System level
None
Use ssh client first-time enable to enable the first authentication function.
Use undo ssh client first-time to disable the function.
By default, the function is enabled.
With first-time authentication, when an SSH client not configured with the server’s host public key accesses the server for the first time, the user can continue accessing the server, and save the server’s host public key on the client. When accessing the server again, the client uses the saved host public key to authenticate the server.
Without first-time authentication, a client not configured with the server’s host public key does not access the server. To access the server, a user must configure in advance the server’s host public key locally and specify the public key name for authentication.
Because the server might update its key pairs periodically, a client must obtain the most recent host public key of the server for successful authentication of the server.
# Enable the first authentication function.
[Sysname] ssh client first-time enable
ssh client ipv6 source
undo ssh client ipv6 source
View
Default level
3: Manage level
Use ssh client ipv6 source to specify the source IPv6 address or source interface for the Stelnet client.
Use undo ssh client ipv6 source to remove the configuration.
By default, an Stelnet client uses the IPv6 address of the interface specified by the route of the device to access the Stelnet server.
To make sure that the Stelnet client and the Stelnet server can communicate with each other, and to improve the manageability of Stelnet clients in the authentication service, H3C recommends you to specify a loopback interface as the source interface.
Related commands: display ssh client source.
# Specify the source IPv6 address of the Stelnet client as 2:2::2:2.
[Sysname] ssh client ipv6 source ipv6 2:2::2:2
ssh client source
undo ssh client source
View
Default level
3: Manage level
Use ssh client source to specify the source IPv4 address or source interface of the Stelnet client.
Use undo ssh client source to remove the configuration.
By default, an Stelnet client uses the IP address of the interface specified by the route of the device to access the Stelnet server.
# Specify the source IPv4 address of the Stelnet client as 192.168.0.1.
[Sysname] ssh client source ip 192.168.0.1
ssh2
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default level
0: Visit level
·     aes256: Specifies the encryption algorithm aes256-cbc. This algorithm is only available in FIPS mode.
Use ssh2 to establish a connection to an IPv4 Stelnet server and specify the public key algorithm, the preferred key exchange algorithm, and the preferred encryption algorithms and preferred HMAC algorithms between the client and server.
# Log in to Stelnet server 10.214.50.51, using the following connection scheme:
<Sysname> ssh2 10.214.50.51 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
ssh2 ipv6
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { 3des | aes128 | aes256 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { 3des | aes128 | aes256 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Default level
0: Visit level
prefer-kex: Specifies the preferred key exchange algorithm, default to dh-group-exchange.
Use ssh2 ipv6 to establish a connection to an IPv6 Stelnet server and specify public key algorithm, the preferred key exchange algorithm, and the preferred encryption algorithms and preferred HMAC algorithms between the client and server.
# Login to Stelnet server 2000::1, using the following connection scheme:
<Sysname> ssh2 ipv6 2000::1 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
