10-Security Configuration Examples
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Configuration Examples-Release1825P01-6W10010-Security Configuration Examples
06-S12500_Attack_Protection_Configuration_Examples
Introduction
This document provides configuration examples of link layer attack protection, ARP attack protection, network layer attack protection, and transport layer attack protection as shown in Table 1.
Table 1 Attack protection types
Link layer attack protection
MAC address attack protection
Prevents the attack of packets with different source MAC addresses or VLANs by configuring the maximum number of MAC addresses that an interface can learn.
STP packet attack protection
Provides protection measures such as BPDU guard, root guard, loop guard, TC-BPDU guard, and STP status confusion protection.
ARP source suppression
Prevents IP attack packets from fixed sources.
ARP black hole routing
Prevents IP attack packets from sources that are not fixed.
ARP active acknowledgement
Prevents user spoofing.
Source MAC-based ARP attack detection
Prevents ARP packet attacks from the same source MAC.
ARP packet source MAC consistency check
Prevents attacks from ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
Network layer attack protection
uRPF check
Protects a network against source spoofing attacks.
TTL attack protection
Prevents an attack by disabling sending ICMP time exceeded messages.
Transport layer attack protection
SYN flood attack protection
Enables the server to return a SYN ACK message upon receiving a TCP connection request, without establishing a half-open TCP connection.
Naptha attack protection
Enables the device to periodically check the number of TCP connections in each state. If it detects that the number of TCP connections in a state exceeds the maximum number, it will accelerate the aging of TCP connections in this state.
This document assumes that you have basic knowledge of attack protection.
Example: Configuring link layer attack protection
Network requirements
As shown in Figure 1, Switch A, Switch B, and Switch C run MSTP. Switch B acts as the root bridge, and GigabitEthernet 2/0/1 on Switch C is blocked. Configure the following features to protect against link layer attacks:
·     Configure root guard on GigabitEthernet 2/0/1 and GigabitEthernet 2/0/2 of Switch B to make sure Switch B act as the root bridge.
·     Configure loop guard on GigabitEthernet 2/0/2 of Switch C to prevent temporary loops. The loop guard feature makes sure the port stay in Discarding state in all MSTIs when it receives no BPDU.
·     Configure BPDU guard on GigabitEthernet 2/0/3 on Switch A and GigabitEthernet 2/0/3 on Switch C. The BPDU guard feature prevents the ports from performing spanning tree calculations upon receiving forged BPDUs with a higher priority.
·     Enable TC-BPDU guard on Switch A, Switch B, and Switch C. The TC-BPDU guard feature prevents a large number of TC-BPDUs in a short time from affecting the network.
·     Configure the maximum number of MAC addresses that can be learned by ports at the access side of Switch A and Switch C. This configuration is to protect the devices against a large number of attack packets with different source MAC addresses. The attack packets might cause a large MAC table and low forwarding performance.
·     Configure broadcast and multicast suppressions on all ports on Switch A, Switch B, and Switch C. When incoming broadcast or multicast traffic exceeds the threshold, an interface discards broadcast or multicast packets until the traffic drops below the threshold.
Figure 1 Network diagram
Requirements analysis
To make Switch A's and Switch C's ports that connect to user terminals rapidly transit to the forwarding state, configure GigabitEthernet 2/0/3 on Switch A and GigabitEthernet 2/0/3 on Switch C as edge ports by using the stp edged-port enable command.
Software version used
This example was created and verified on S12500-CMW520-R1825P01.
When you configure link layer attack protection, follow these restrictions and guidelines:
·     On a port, the loop guard function is mutually exclusive with the root guard function or the edge port setting.
·     Do not configure the loop guard function on a port that connects to user terminals. Otherwise, the port stays in Discarding state in all MSTIs because it cannot receive BPDUs.
Configuration procedures
Configuring Switch A
# Specify IP addresses for interfaces. (Details not shown.)
# Configure STP BPDU guard.
[SwitchA] stp bpdu-protection
[SwitchA] interface GigabitEthernet 2/0/3
[SwitchA-GigabitEthernet2/0/3] undo shutdown
[SwitchA-GigabitEthernet2/0/3] stp edged-port enable
# Configure TC-BPDU guard.
[SwitchA] stp tc-protection enable
[SwitchA] stp tc-protection threshold 10
# Configure the maximum number of MAC addresses that a port at the access side can learn (for example, GigabitEthernet 2/0/3).
[SwitchA-GigabitEthernet2/0/3] mac-address max-mac-count 1024
# Set the broadcast and multicast suppression thresholds on all ports that include ports at the access side, for example, GigabitEthernet 2/0/3.
[SwitchA] interface range GigabitEthernet 2/0/1 to GigabitEthernet 2/0/3
[SwitchA-if-range] undo shutdown
[SwitchA-if-range] broadcast-suppression pps 2000
[SwitchA-if-range] multicast-suppression pps 2000
Configuring Switch B
# Configure root guard on GigabitEthernet 2/0/2 and GigabitEthernet 2/0/1.
[SwitchB] interface GigabitEthernet 2/0/2
[SwitchB-GigabitEthernet2/0/2] undo shutdown
[SwitchB-GigabitEthernet2/0/2] stp root-protection
[SwitchB-GigabitEthernet2/0/2] quit
[SwitchB] interface GigabitEthernet 2/0/1
[SwitchB-GigabitEthernet2/0/1] undo shutdown
[SwitchB-GigabitEthernet2/0/1] stp root-protection
[SwitchB-GigabitEthernet2/0/1] quit
[SwitchB] stp tc-protection enable
[SwitchB] stp tc-protection threshold 10
# Set the broadcast and multicast suppression thresholds on GigabitEthernet 2/0/1 and GigabitEthernet 2/0/2.
[SwitchB] interface range GigabitEthernet 2/0/1 to GigabitEthernet 2/0/2
[SwitchB-if-range] broadcast-suppression pps 2000
[SwitchB-if-range] multicast-suppression pps 2000
Configuring Switch C
[SwitchC] stp bpdu-protection
[SwitchC] interface GigabitEthernet 2/0/3
[SwitchC-GigabitEthernet2/0/3] undo shutdown
[SwitchC-GigabitEthernet2/0/3] stp edged-port enable
# Configure root guard on GigabitEthernet 2/0/1.
[SwitchC] interface GigabitEthernet 2/0/1
[SwitchC-GigabitEthernet2/0/1] undo shutdown
[SwitchC-GigabitEthernet2/0/1] stp root-protection
[SwitchC-GigabitEthernet2/0/1] quit
# Configure loop guard on GigabitEthernet 2/0/2.
[SwitchC] interface GigabitEthernet 2/0/2
[SwitchC-GigabitEthernet2/0/2] undo shutdown
[SwitchC-GigabitEthernet2/0/2] stp loop-protection
[SwitchC-GigabitEthernet2/0/2] quit
[SwitchC] stp tc-protection enable
[SwitchC] stp tc-protection threshold 10
[SwitchC-GigabitEthernet2/0/3] mac-address max-mac-count 1024
[SwitchC] interface range GigabitEthernet 2/0/1 to GigabitEthernet 2/0/3
[SwitchC-if-range] broadcast-suppression pps 2000
[SwitchC-if-range] multicast-suppression pps 2000
After receiving STP BPDUs, the ports GigabitEthernet 2/0/3 of Switch A and Switch C go down. You can bring them up by executing the undo shutdown command.
After STP BPDUs with higher priority are sent to a port, the root port does not change, and the STP topology is stable.
After receiving a large number of various TC BPDUs, Switch A, Switch B, and Switch C do not refresh the FIB table frequently, and no serious packet loss occurs.
After you send a large number of broadcasts to GigabitEthernet 2/0/3 on Switch A and GigabitEthernet 2/0/3 on Switch C, no broadcast flooding occurs on the uplink ports.
Configuration files
·     Switch A:
stp bpdu-protection
 port link-mode bridge
·     Switch B:
stp root-protection
stp root-protection
·     Switch C:
stp bpdu-protection
stp root-protection
stp loop-protection
Example: Configuring ARP attack protection
As shown in Figure 2, Switch A and Switch B form a VRRP group. Configure the ARP attack protection features to protect Switch A and Switch B.
Figure 2 Network diagram
# Configure ARP source suppression and set the maximum number of unresolvable packets that can be received in 5 seconds to 8 to prevent IP attack packets from fixed sources.
[SwitchA] arp source-suppression enable
[SwitchA] arp source-suppression limit 8
# Configure ARP black hole routing to prevent IP attack packets from sources that are not fixed.
[SwitchA] arp resolving-route enable
# Configure ARP active acknowledgment to prevent user spoofing.
[SwitchA] arp anti-attack active-ack enable
# Configure source MAC-based ARP attack detection to prevent ARP packet attacks from the same source MAC.
[SwitchA] arp anti-attack source-mac filter
[SwitchA] arp anti-attack source-mac threshold 25
# Configure ARP packet source MAC address consistency check to prevent attacks from ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
[SwitchA] arp anti-attack valid-check enable
[SwitchB] arp source-suppression enable
[SwitchB] arp source-suppression limit 8
[SwitchB] arp resolving-route enable
[SwitchB] arp anti-attack active-ack enable
[SwitchB] arp anti-attack source-mac filter
[SwitchB] arp anti-attack source-mac threshold 25
[SwitchB] arp anti-attack valid-check enable
After you send various ARP attack packets to the switches, no busy CPU event occurs, and other service modules are operating correctly.
Take ARP source suppression as an example. After you send 20 forged packets with fixed source IP addresses and unresolvable destination IP addresses to a switch, the switch stops resolving the packets when the number of unresolvable packets within 5 seconds reaches 8.
# Display information about the ARP source suppression configuration.
<Sysname> display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 8
 Current cache length: 16
Configuration files
·     Switch A:
·     Switch B:
Example: Configuring network layer attack protection
As shown in Figure 3, configure the network layer protection features to protect Switch A from being attacked by IP packet attacks from users and the network.
Figure 3 Network diagram
After you disable sending ICMP time exceeded messages, the traceroute feature is not available.
# Configure uRPF to prevent source spoofing attacks.
[SwitchA-Vlan-interface100] ip urpf strict
[SwitchA] vlan 200
[SwitchA-vlan] port GigabitEthernet 2/0/2
[SwitchA-vlan] quit
[SwitchA] interface GigabitEthernet 2/0/2
[SwitchA-GigabitEthernet2/0/2] undo shutdown
[SwitchA-GigabitEthernet2/0/2] quit
[SwitchA-Vlan-interface200] undo shutdown
[SwitchA-Vlan-interface200] ip address 202.101.0.2 255.255.255.0
[SwitchA-Vlan-interface200] ip urpf strict
# Disable sending ICMP time exceeded messages to prevent attacks from packets with TTL being 1. Sending ICMP time exceeded messages is disabled by default.
[SwitchA] undo ip ttl-expires
After you use a PC to send packets with TTL 1 to the device, the packets are dropped, and the PC does not receive TTL timeout ICMP packets.
After you send packets with forged source IP addresses to Switch A, the packets are filtered.
Configuration files
vlan 100
vlan 200
interface Vlan-interface100
 ip address 192.168.0.1 255.255.255.0
interface Vlan-interface200
interface GigabitEthernet2/0/1
port access vlan 100
interface GigabitEthernet2/0/2
 port access vlan 200
 ip urpf strict
Example: Configuring transport layer attack protection
As shown in Figure 4, configure SYN Cookie and Naptha attack protection on Switch A to protect Switch A from SYN Flood and Naptha attacks and to make sure BGP can operate correctly.
Figure 4 Network diagram
# Enable SYN Cookie.
[SwitchA] tcp syn-cookie enable
# Enable Naptha attack protection.
[SwitchA] tcp anti-naptha enable
After you send a large number of protocol packets with the destination port as the BGP protocol port to Switch A, BGP can operate correctly.
After you send a large number of Naptha attack packets to Switch A, the switch and BGP can operate correctly.
Configuration files
Related documentation
·     H3C S12500 Routing Switch Series Layer 2LAN Switching Configuration Guide
·     H3C S12500 Routing Switch Series Layer 2LAN Switching Command Reference
·     H3C S12500 Routing Switch Series Layer 3IP Services Configuration Guide
·     H3C S12500 Routing Switch Series Layer 3IP Services Command Reference
·     H3C S12500 Routing Switch Series Security Configuration Guide
·     H3C S12500 Routing Switch Series Security Command Reference
