10-Security Configuration Examples
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Configuration Examples-Release1825P01-6W10010-Security Configuration Examples
02-S12500_Portal_Configuration_Examples
02-S12500_Portal_Configuration_Examples 175.31 KB
Introduction
This document provides portal configuration examples.
Portal authentication, also called Web authentication, provides a flexible network access control method through Web interfaces.
This document assumes that you have basic knowledge of H3C portal authentication.
General configuration restrictions and guidelines
When you configure portal authentication, follow these restrictions and guidelines:
·     If a QoS policy has been configured in a VLAN, on a member port in a VLAN, or globally, do not configure portal authentication for the VLAN or the interface. Otherwise, portal authentication does not take effect.
·     A portal authentication client is identified by its IP address. Make sure no NAT device is configured between the portal authentication client, the access device, the portal server, and the AAA server. This is to avoid portal authentication failures caused by network address translation.
Example: Configuring Layer 3 portal authentication
Network requirements
As shown in Figure 1, the clients in Department A access the core network of the company through Switch A and Switch B. Switch B is configured with portal authentication to control network access behaviors from Department A.
Before portal authentication, a client can access only the portal server and all Web access requests are redirected to the portal server. After portal authentication, a client can access other internal resources of the company and Internet resources.
Use a RADIUS server as the AAA server for portal users.
Configure a shared key on both Switch B and the RADIUS sever for secure packet exchange.
Figure 1 Network diagram
Requirements analysis
To authenticate the clients through portal in Department A, configure a portal server and enable portal authentication on Switch B.
To implement AAA for users through the RADIUS server, configure a RADIUS scheme and specify the AAA servers on Switch B. Apply the scheme to the authentication domain to which the portal users belong.
The shared key can ensure secure password exchange between Switch B and the RADIUS server, and also prevents the response packets from the RADIUS server from being tampered with.
Software version used
The configuration examples were created and verified on S12500-CMW520-R1825P01.
Only RADIUS servers support AAA for portal users. Make sure you configure routes on the RADIUS server to the authentication port and the user's IP subnet.
Configuration procedures
1.     Complete configurations on the RADIUS server and the portal server, for example, configuring the shared key for packet exchange. (Details not shown.)
2.     Assign IP addresses to the interfaces and configure the routing protocol on the devices to make sure the routes to the devices are reachable at Layer 3. (Details not shown.)
3.     On Switch A, configure the default route to the subnet 10.0.10.0/24, with the next hop as 10.0.11.1. (Details not shown.)
4.     Configure Switch B:
# Configure a portal server as follows:
¡     Name: newpt
¡     IPv6 address: 10.0.10.2
¡     Key: portal
¡     Port number: 50100
¡     URL: http:// 10.0.10.2/portal
<SwitchB>system-view
[SwitchB] portal server newpt ip 10.0.10.2 key portal port 50100 url http://10.0.10.2/portal
# Enable portal authentication on the interface connected to Switch A, and configure the authentication subnet as the one where Department A resides.
[SwitchB] interface Vlan-interface 11
[SwitchB-Vlan-interface11] portal auth-network 192.168.0.0 255.255.255.0
[SwitchB-Vlan-interface11] portal server newpt method layer3
[SwitchB-Vlan-interface11] quit
# Configure a portal-free rule to allow the routing protocol packets of Switch A to pass through.
[SwitchB] portal free-rule 0 source ip 10.0.11.2 mask 32
[SwitchB] quit
# Configure a RADIUS scheme named imc, and enter its view.
[SwitchB] radius scheme imc
New Radius scheme
# Configure the RADIUS scheme parameters, including the RADIUS server IP address, shared key, username format, and server type.
[SwitchB-radius-imc] primary authentication 10.0.10.2
[SwitchB-radius-imc] primary accounting 10.0.10.2
[SwitchB-radius-imc] key authentication imc
[SwitchB-radius-imc] key accounting imc
[SwitchB-radius-imc] server-type extended
[SwitchB-radius-imc] user-name-format without-domain
[SwitchB-radius-imc] quit
[SwitchB] quit
# Create an authentication domain named portal.com, and specify the RADIUS scheme for the domain.
[SwitchB] domain portal.com
[SwitchB-isp-portal.com] authentication portal radius-scheme imc
[SwitchB-isp-portal.com] accounting portal radius-scheme imc
[SwitchB-isp-portal.com] authorization portal radius-scheme imc
[SwitchB-isp-portal.com] quit
[SwitchB] quit
# Specify the authentication domain portal.com as the default ISP domain. Users without any domain name carried in the usernames are considered to be in the default domain.
[SwitchB] domain default enable portal.com
# Before portal authentication, verify that the clients can access only the portal server, and any Web access request is redirected to the portal server.
C:\>ping -n 1 10.0.11.1
Pinging 10.0.11.1 with 32 bytes of data:
Request timed out.
Ping statistics for 10.0.11.1:
    Packets: Sent = 1, Received = 0, Lost = 1 (100% loss),
C:\>ping -n 1 10.0.10.1
Pinging 10.0.10.1 with 32 bytes of data:
Request timed out.
Ping statistics for 10.0.10.1:
C:\>ping -n 1 10.0.10.2
Pinging 10.0.10.2 with 32 bytes of data:
Reply from 10.0.10.2: bytes=32 time<1ms TTL=126
Ping statistics for 10.0.10.2:
    Packets: Sent = 1, Received = 1, Lost = 0 (0% loss),
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\>
# Enter the correct username and password on the portal authentication page. After successful authentication, the client can access the Internet.
Reply from 10.0.11.1: bytes=32 time<1ms TTL=254
Reply from 10.0.10.1: bytes=32 time<1ms TTL=254
C:\>
# On the device, you can display the portal users who have passed portal authentication.
<SwitchB>display portal user all
Index:3
 State:ONLINE
 SubState:NONE
 ACL:NONE
 Work-mode:stand-alone
 VPN instance:NONE
 MAC              IP                Vlan   Interface
 0000-0000-0000   192.168.0.2       11      Vlan-interface11
 Total 1 user(s) matched, 1 listed.
Configuration files
 portal server newpt ip 10.0.10.2 key cipher $c$3$c05cGkZePA4Ke+tMA4IehAeQfknE9t
F2PQ== url http://10.0.10.2/portal
 portal free-rule 0 source ip 10.0.11.2 mask 255.255.255.255 destination ip any
 forward-path check enable
vlan 1
vlan 10 to 11
radius scheme imc
key authentication cipher $c$3$M30nGDQxiOCAxe2AJ9yEZdk8kjoWag==
 key accounting cipher $c$3$sLGxmc7H4MDmvUvmcaaee50JnNLPrA==
domain portal.com
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
domain system
 state active
 idle-cut disable
user-group system
interface NULL0
interface Vlan-interface10
 ip address 10.0.10.1 255.255.255.0
interface Vlan-interface11
 ip address 10.0.11.1 255.255.255.0
 rip version 2 multicast
interface GigabitEthernet7/0/10
 port link-mode bridge
port access vlan 10
interface GigabitEthernet7/0/11
port access vlan 11
interface M-Ethernet0/0/0
rip 1
 version 2
 network 10.0.0.0
 import-route direct
user-interface con 0
user-interface aux 0
user-interface vty 0 17
Example: Configuring Layer 3 extended portal authentication
As shown in Figure 2, the clients in Department A access the core network of the company through Switch A and Switch B. Switch B is configured with portal authentication to control network access behaviors from Department A and to implement security check.
After passing identity authentication:
·     If the required antivirus software version is not installed, the user can access only the virus definitions update server and patch server.
·     If the required antivirus software version is installed, the user passes security authentication and can access the network resources.
Use a server to operate as a RADIUS server for AAA and as a security policy server for security check.
Figure 2 Network diagram
To implement AAA for users through the RADIUS server, configure a RADIUS scheme and specify the AAA servers on Switch B, and apply the scheme to the authentication domain to which the portal users belong.
To securely exchange user passwords between Switch B and the RADIUS server, and to make sure the response packets from the RADIUS server are not tampered with, configure a shared key on both Switch B and the RADIUS sever for packet exchange.
To implement security check for login users, create an ACL and configure rules. Only the users who meet the security check requirements can access network resources. The users who fail security check can access only the virus definitions update server and the patch server.
2.     Assign IP addresses to the interfaces, and configure the routing protocol on the devices to make sure the routes to the devices are reachable at Layer 3. (Details not shown.)
¡     Name: newpt
¡     Key: portal
[SwitchB]portal server newpt ip 10.0.10.2 key portal port 50100 url http://10.0.10.2/portal
[SwitchB]interface Vlan-interface 11
[SwitchB-Vlan-interface11]portal auth-network 192.168.0.0 255.255.255.0
[SwitchB-Vlan-interface11]portal server newpt method layer3
[SwitchB-Vlan-interface11]quit
[SwitchB]portal free-rule 0 source ip 10.0.11.2 mask 32
[SwitchB]quit
[SwitchB]radius scheme imc
[SwitchB-radius-imc]primary authentication 10.0.10.2
[SwitchB-radius-imc]primary accounting 10.0.10.2
[SwitchB-radius-imc]key authentication imc
[SwitchB-radius-imc]key accounting imc
[SwitchB-radius-imc]server-type extended
[SwitchB-radius-imc]user-name-format without-domain
[SwitchB-radius-imc]quit
[SwitchB]quit
[SwitchB]
[SwitchB]domain portal.com
[SwitchB-isp-portal.com]authentication portal radius-scheme imc
[SwitchB-isp-portal.com]accounting portal radius-scheme imc
[SwitchB-isp-portal.com]authorization portal radius-scheme imc
[SwitchB-isp-portal.com]quit
[SwitchB]quit
# Specify the authentication domain portal.com as the default ISP domain. Users without any domain name carried in their usernames are considered to be in the default domain.
# Configure ACL 3000 to allow only the packets destined for the virus definitions update server and patch server to pass through.
[SwitchB]acl number 3000
[SwitchB-acl-adv-3000]rule permit ip destination 10.0.12.2 0
[SwitchB-acl-adv-3000]rule permit ip destination 10.0.12.3 0
[SwitchB-acl-adv-3000]rule deny ip
[SwitchB-acl-adv-3000]quit
[SwitchB]quit
# Configure ACL 3001 to allow access to all network destinations.
[SwitchB]acl number 3001
[SwitchB-acl-adv-3001]rule permit ip
[SwitchB]quit
# Before portal authentication, verify that Client A can access only the portal server.
Request timed out.
Request timed out.
C:\>ping -n 1 10.0.12.1
Pinging 10.0.12.1 with 32 bytes of data:
Request timed out.
Ping statistics for 10.0.12.1:
C:\>ping -n 1 10.0.12.2
Pinging 10.0.12.2 with 32 bytes of data:
Request timed out.
Ping statistics for 10.0.12.2:
C:\>ping -n 1 10.0.12.3
Pinging 10.0.12.3 with 32 bytes of data:
Request timed out.
Ping statistics for 10.0.12.3:
# On the security policy server, configure a security policy to use isolation mode. Configure the isolation ACL as ACL 3000 and security ACL as ACL 3001. Perform virus scanning for the client, and configure the required version of Symantec virus definition higher than the virus definition version on the client.
# Use Client A to establish a portal connection through the iNode client on Switch B. After entering the correct username and password, the user can log in successfully. After that, the security check begins but fails, and the client is quarantined. Displaying the portal user information on the device, you can see that the isolation ACL is used for the client.
 Index:77
 State:ONLINE
 SubState:NONE
 ACL:3000
VPN instance:NONE
# Display network access information about Client A. Client A can access only the portal server, patch server, and virus definitions update server.
Request timed out.
Request timed out.
Request timed out.
Reply from 10.0.12.2: bytes=32 time=2ms TTL=126
    Minimum = 2ms, Maximum = 2ms, Average = 2ms
Reply from 10.0.12.3: bytes=32 time<1ms TTL=126
# Update the virus definitions on Client A to satisfy the virus definitions version requirement. Tear down the portal connection and log in again. After identity authentication, the security check begins, and the iNode client is notified that the security check has succeeded. Displaying the portal user information on the device, you can see that the security ACL is now used for the client.
 Index:79
 State:ONLINE
 SubState:NONE
 ACL:3001
VPN instance:NONE
# Display network access information about Client A. Client A can access network resources.
Reply from 10.0.12.1: bytes=32 time<1ms TTL=254
Configuration files
 portal server newpt ip 10.0.10.2 key cipher $c$3$NutFYbU0hYwh72HWnP2zrtfThyQfRb
6pmw url http://10.0.10.2/portal
acl number 3000
 rule 0 permit ip destination 10.0.12.2 0
 rule 5 permit ip destination 10.0.12.3 0
 rule 10 deny ip
acl number 3001
 rule 0 permit ip
vlan 1
vlan 10 to 11
radius scheme imc
domain portal.com
 state active
 idle-cut disable
domain system
 state active
 idle-cut disable
user-group system
interface NULL0
interface Vlan-interface12
 ip address 10.0.12.1 255.255.255.0
port access vlan 10
port access vlan 11
interface GigabitEthernet7/0/12
port access vlan 12
rip 1
 version 2
 network 10.0.0.0
 import-route direct
Related documentation
·     H3C S12500 Routing Switch Series Security Configuration Guide
·     H3C S12500 Routing Switch Series Security Command Reference
