04-Layer 2 - LAN Switching Configuration Examples
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Configuration Examples-Release1825P01-6W10004-Layer 2 - LAN Switching Configuration Examples
02-S12500_VLAN_Termination_Configuration_Examples
Introduction
This document provides VLAN termination configuration examples.
VLAN termination allows VLAN interfaces to identify and remove the VLAN information of VLAN-tagged packets, so that these packets can be forwarded at Layer 3.
VLAN termination includes the following types:
·     Dot1q termination—Terminates the outermost layer of VLAN tags of received packets. By default, each VLAN interface supports Dot1q termination. You do not need to configure Dot1q termination on a VLAN interface. Packets sent out of the VLAN interface are single-tagged and tagged with the ID of that VLAN.
·     QinQ termination—Terminates the outermost two layers of VLAN tags of received packets. Packets sent out of a QinQ termination interface are double-tagged. QinQ termination includes unambiguous QinQ termination and ambiguous QinQ termination. When an unambiguous QinQ termination interface sends a packet, it tags the packet with two layers of VLAN IDs, where the inner VLAN ID is the specified value. When an ambiguous QinQ termination interface sends out the packet, it tags the packet with two layers of VLAN tags, where the inner VLAN ID is one of the specified VLAN IDs.
The following QinQ termination networking solutions are available:
·     Traditional solution—Configure QinQ on the distribution layer devices and configure QinQ termination on core layer devices.
·     Lite solution—Configure both QinQ and QinQ termination on core layer devices, and you do not need to configure the distribution layer devices.
This document assumes that you have basic knowledge of VLAN termination.
Example: Configuring ambiguous QinQ termination for a traditional solution
Network requirements
As shown in Figure 1:
·     The CVLANs for users in site A are VLANs 10 through 70, and the CVLANs for users in site B  are VLANs 30 through 90.
·     Basic QinQ is enabled on the edges devices PE1 and PE2 of the public network, which add SVLAN tag 100 and SVLAN tag 200 to the uplink packets from site A and site B, respectively. The basic QinQ configuration isolates packets from site A and site B.
Configure ambiguous QinQ termination on the P device, so that the users in site A and site B can communicate with the Internet through the public network.
Figure 1 Network diagram
Software version used
This configuration example was created and verified on the S12500-CMW520-R1825P01 version.
When you configure ambiguous QinQ termination for a traditional solution, follow these restrictions and guidelines:
·     A VLAN interface can receive only the packets whose outermost layer VLAN ID is the same as the VLAN interface number.
·     When the QinQ termination configuration changes on a VLAN interface, you must use the reset arp interface command in user view to change the ARP entries of the Layer 2 physical interface bound to the VLAN interface.
Configuration procedures
Configuring the hosts
Configure the gateway address of Host A as 1.1.1.11/24, and configure the gateway address of Host B as 1.1.2.11/24. (Details not shown.)
Configuring CE1 and CE2
Configure CE1 of site A as follows: (Details not shown.)
1.     Create CVLANs for site A.
2.     Assign the ports connecting to user terminals to these CVLANs.
3.     Configure the port connecting to PE1 as a trunk port, and assign the port to all CVLANs for site A.
Configure CE2 of site B as follows: (Details not shown.)
1.     Create CVLANs for site B.
3.     Configure the port connecting to PE2 as a trunk port, and assign the port to all CVLANs for site B.
Configuring PE 1
Configuring the customer-side port GigabitEthernet 3/0/1
# Configure GigabitEthernet 3/0/1 as a trunk port.
<PE1> system-view
[PE1] vlan 100
[PE1-vlan100] quit
[PE1] interface GigabitEthernet3/0/1
[PE1-GigabitEthernet3/0/1] undo shutdown
# Remove the port from VLAN 1, and assign the port to VLAN 100.
[PE1-GigabitEthernet3/0/1] port link-type trunk
[PE1-GigabitEthernet3/0/1] undo port trunk permit vlan 1
[PE1-GigabitEthernet3/0/1] port trunk permit vlan 100
# Configure VLAN 100 as the PVID of GigabitEthernet 3/0/1.
[PE1-GigabitEthernet3/0/1] port trunk pvid vlan 100
# Enable basic QinQ on the port to add outer VLAN tag 100 to the received packets.
[PE1-GigabitEthernet3/0/1] qinq enable
[PE1-GigabitEthernet3/0/1] quit
Configuring the network-side port GigabitEthernet 3/0/2
# Configure GigabitEthernet 3/0/2 as a trunk port.
[PE1] interface GigabitEthernet3/0/2
[PE1-GigabitEthernet3/0/2] undo shutdown
[PE1-GigabitEthernet3/0/2] port link-type trunk
# Assign the port to VLAN 100.
[PE1-GigabitEthernet3/0/2] port trunk permit vlan 100
Configuring PE 2
# Create VLAN 200.
<PE2> system-view
[PE2] vlan 200
[PE2-vlan200] quit
[PE2] interface GigabitEthernet3/0/1
[PE2-GigabitEthernet3/0/1] undo shutdown
[PE2-GigabitEthernet3/0/1] port link-type trunk
# Remove the port from VLAN 1, and assign the port to VLAN 200.
[PE2-GigabitEthernet3/0/1] undo port trunk permit vlan 1
[PE2-GigabitEthernet3/0/1] port trunk permit vlan 200
# Configure VLAN 200 as the PVID of GigabitEthernet 3/0/1.
[PE2-GigabitEthernet3/0/1] port trunk pvid vlan 200
# Enable basic QinQ on the port to add outer VLAN tag 200 to the received packets.
[PE2-GigabitEthernet3/0/1] qinq enable
[PE2-GigabitEthernet3/0/1] quit
[PE2] interface GigabitEthernet3/0/2
[PE2-GigabitEthernet3/0/2] undo shutdown
[PE2-GigabitEthernet3/0/2] port link-type trunk
# Assign the port to VLAN 200.
[PE2-GigabitEthernet3/0/2] port trunk permit vlan 200
Configuring the P device
Configuring QinQ termination
# Create VLAN-interface 100, and assign an IP address to the interface.
<P>system-view
[P]vlan 100
[P-vlan100]quit
[P]interface vlan-interface 100
[P-Vlan-interface100]undo shutdown
[P-Vlan-interface100]ip address 1.1.1.11 24
# Configure QinQ termination on VLAN interface 100 to terminate packets with the inner VLAN tags 10 through 70.
[P-Vlan-interface100]second-dot1q 10 to 70
[P-Vlan-interface100]quit
# Create VLAN-interface 200, and assign an IP address to the interface.
[P]vlan 200
[P-vlan200]quit
[P]interface vlan-interface 200
[P-Vlan-interface200]undo shutdown
[P-Vlan-interface200]ip address 1.1.2.11 24
# Configure QinQ termination on VLAN interface 200 to terminate packets with the inner VLAN tags 30 through 90.
[P-Vlan-interface200]second-dot1q 30 to 90
[P-Vlan-interface200]quit
Configuring the network-side ports
# Configure the network-side ports GigabitEthernet 3/0/1 and GigabitEthernet 3/0/2 as trunk ports.
[P] interface range GigabitEthernet 3/0/1 to GigabitEthernet 3/0/2
[P-if-range] undo shutdown
[P-if-range] port link-type trunk
# Assign them to the SVLANs 100 and 200.
[P-if-range] port trunk permit vlan 100 200
[P-if-range] quit
Configuring the Internet-side port
# Assign the Internet-side port GigabitEthernet 3/0/3 to VLAN 3.
[P] vlan 3
[P-vlan3] port GigabitEthernet 3/0/3
[P-vlan3] quit
[P] interface GigabitEthernet3/0/3
[P-GigabitEthernet3/0/3] undo shutdown
[P-GigabitEthernet3/0/3] quit
# Create VLAN interface 3, and assign an IP address to VLAN interface 3.
[P] interface vlan-interface 3
[P-Vlan-interface3] undo shutdown
[P-Vlan-interface3] ip address 1.1.3.11 24
[P-Vlan-interface3] quit
Users in site A and site B can communicate with the Internet.
Configuration files
·     PE1:
vlan 100
 port link-mode bridge
 qinq enable
port trunk permit vlan 1 100
·     PE2:
vlan 200
qinq enable
port trunk permit vlan 1 200
·     P:
vlan 3
vlan 100
vlan 200
interface Vlan-interface3
 ip address 1.1.3.11 255.255.255.0
interface Vlan-interface100
 ip address 1.1.1.11 255.255.255.0
interface Vlan-interface200
 ip address 1.1.2.11 255.255.255.0
port trunk permit vlan 1 100 200
 port access vlan 3
Example: Configuring ambiguous QinQ termination for a lite solution
As shown in Figure 2:
·     Host A, Host B, and Host C are connected to L2 Switch A, and they belong to VLAN 11, VLAN 12, and VLAN 13, respectively. The server group is connected to L2 Switch C, which supports only single-tagged packets.
·     QinQ is enabled on the port GigabitEthernet 3/0/10 that connects L3 Switch B to the customer sides, so that the port can add outer VLAN tag 100 before forwarding packets.
Configure ambiguous QinQ termination on L3 Switch B so that Host A, Host B, and Host C can communicate with the server group.
Figure 2 Network diagram
When you configure ambiguous QinQ termination for a lite solution, follow these restrictions and guidelines:
·     When you configure QinQ termination for a lite solution, make sure the inner VLAN ID range does not conflict with the VLAN interface number. For example, on VLAN-interface 100, the vlan-list argument cannot include 100 and do not specify the any keyword in the second-dot1q { vlan-list | any } command.
Configuring Host A, Host B, and Host C
Configure the IP addresses of Host A, Host B, and Host C as 1.1.1.1/24, 1.1.1.2/24, and 1.1.1.3/24, respectively. Configure the gateway address as 1.1.1.11/24 for the hosts. (Details not shown.)
Configuring L2 Switch A
# Assign port GigabitEthernet 3/0/1 to VLAN 11.
<L2 Switch A>system-view
[L2 Switch A]vlan 11
[L2 Switch A-vlan11]port GigabitEthernet 3/0/1
[L2 Switch A-vlan11]quit
[L2 Switch A]interface GigabitEthernet 3/0/1
[L2 Switch A-GigabitEthernet3/0/1]undo shutdown
[L2 Switch A-GigabitEthernet3/0/1]quit
# Assign port GigabitEthernet 3/0/2 to VLAN 12.
[L2 Switch A]vlan 12
[L2 Switch A-vlan12]port GigabitEthernet 3/0/2
[L2 Switch A-vlan12]quit
[L2 Switch A]interface GigabitEthernet 3/0/2
[L2 Switch A-GigabitEthernet3/0/2]undo shutdown
[L2 Switch A-GigabitEthernet3/0/2]quit
# Assign port GigabitEthernet 3/0/3 to VLAN 13.
[L2 Switch A]vlan 13
[L2 Switch A-vlan13]port GigabitEthernet 3/0/3
[L2 Switch A-vlan13]quit
[L2 Switch A]interface GigabitEthernet 3/0/3
[L2 Switch A-GigabitEthernet3/0/3]undo shutdown
[L2 Switch A-GigabitEthernet3/0/3]quit
# Configure GigabitEthernet 3/0/10 as a trunk port.
[L2 Switch A]interface GigabitEthernet 3/0/10
[L2 Switch A-GigabitEthernet3/0/10]undo shutdown
[L2 Switch A-GigabitEthernet3/0/10]port link-type trunk
# Assign the port GigabitEthernet 3/0/10 to VLANs 11 through 13.
[L2 Switch A-GigabitEthernet3/0/10]port trunk permit vlan 11 to 13
Configuring L3 Switch B
# Assign port GigabitEthernet 3/0/10 to VLAN 100.
<L3 Switch B>system-view
[L3 Switch B]vlan 100
[L3 Switch B-vlan100]quit
[L3 Switch B]interface GigabitEthernet 3/0/10
[L3 Switch B-GigabitEthernet3/0/10]undo shutdown
[L3 Switch B-GigabitEthernet3/0/10]port access vlan 100
# Enable QinQ on the port GigabitEthernet 3/0/10 to tag the received packets with the PVID.
[L3 Switch B-GigabitEthernet3/0/10]qinq enable
[L3 Switch B-GigabitEthernet3/0/10]quit
[L3 Switch B]interface vlan-interface 100
[L3 Switch B-Vlan-interface100]undo shutdown
[L3 Switch B-Vlan-interface100]ip address 1.1.1.11 255.255.255.0
# Configure QinQ termination on VLAN-interface 100 to terminate double-tagged packets whose outermost VLAN tag is 100 and tag the packets to be sent out with inner CVLAN tag 11, 12, or 13.
[L3 Switch B-Vlan-interface100]second-dot1q 11 to 13
[L3 Switch B-Vlan-interface100]quit
# Assign port GigabitEthernet 3/0/1 to VLAN 2.
[L3 Switch B]vlan 2
[L3 Switch B-vlan2]port GigabitEthernet 3/0/1
[L3 Switch B-vlan2]quit
[L3 Switch B-GigabitEthernet3/0/1]undo shutdown
[L3 Switch B-GigabitEthernet3/0/1] quit
# Configure VLAN-interface 2, and assign an IP address to the interface.
[L3 Switch B]interface vlan-interface 2
[L3 Switch B-Vlan-interface2]undo shutdown
[L3 Switch B-Vlan-interface2]ip address 1.1.2.11 255.255.255.0
[L3 Switch B-Vlan-interface2]quit
Configuring L2 Switch C
Use the factory default settings for L2 Switch C.
Configuring the server group
Assign each server in the server group an IP address on the network segment 1.1.2.0/24 and configure the gateway IP address as 1.1.2.11/24.
The Server Group and each of Host A, Host B, and Host C can ping each other.
Configuration files
·     L2 Switch A:
 sysname L2 Switch A
vlan 11 to 13
 port access vlan 11
 port access vlan 12
 port access vlan 13
interface GigabitEthernet3/0/10
 port trunk permit vlan 1 11 to 13
·     L3 Switch B:
 sysname L3 Switch B
vlan 2
vlan 100
 port access vlan 2
 qinq enable
Related documentation
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Configuration Guide
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Command Reference
