04-Layer 2 - LAN Switching Configuration Examples
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Configuration Examples-Release1825P01-6W10004-Layer 2 - LAN Switching Configuration Examples
00-S12500_Port_Isolation_Configuration_Examples
Introduction
This document provides port isolation configuration examples.
The port isolation feature isolates Layer 2 traffic for data privacy and security without using VLANs. You can also use this feature to isolate the hosts in a VLAN from one another.
This document assumes that you have basic knowledge of the port isolation feature.
Example: Configuring port isolation
Network requirements
As shown in Figure 1:
·     Ports GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, GigabitEthernet 3/0/3, and GigabitEthernet 3/0/4 of Device A belong to VLAN 10.
·     Device A connects to the Internet through port GigabitEthernet 3/0/4.
Configure port isolation to isolate Host A, Host B, and Host C at Layer 2 and allow them to access the Internet.
Figure 1 Network diagram
Requirements analysis
To isolate Host A, Host B, and Host C at Layer 2, assign ports GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, and GigabitEthernet 3/0/3 to an isolation group.
To allow these hosts to access the Internet, make sure port GigabitEthernet 3/0/4 can communicate with the customer-side ports at Layer 2, and do not assign port GigabitEthernet 3/0/4 to the isolation group.
Software version used
This configuration example was created and verified on S12500-CMW520-R1825P01.
Configuration procedures
# Assign IP addresses in the 1.1.1.0/24 network segment to hosts A, B, and C. Specify the gateway address for them as 1.1.1.11/24. (Details not shown.)
# Create VLAN 10 on Device A and assign ports GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, GigabitEthernet 3/0/3, and GigabitEthernet 3/0/4 to the VLAN.
[DeviceA] vlan 10
[DeviceA-vlan10] quit
[DeviceA] interface range GigabitEthernet 3/0/1 to GigabitEthernet 3/0/4
[DeviceA-if-range] undo shutdown
[DeviceA-if-range] port access vlan 10
[DeviceA-if-range] quit
# Create VLAN-interface 10, and assign an IP address to the VLAN-interface.
[DeviceA-Vlan-interface10] undo shutdown
[DeviceA-Vlan-interface10] ip address 1.1.1.11 255.255.255.0
# Create port isolation group 1.
[DeviceA] port-isolate group 1
[DeviceA-port-isolate-group1] quit
# Assign ports GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, and GigabitEthernet 3/0/3 to port isolation group 1.
[DeviceA] interface GigabitEthernet 3/0/1
[DeviceA-GigabitEthernet3/0/1] port-isolate enable group 1
[DeviceA-GigabitEthernet3/0/1] quit
[DeviceA] interface GigabitEthernet 3/0/2
[DeviceA-GigabitEthernet3/0/2] port-isolate enable group 1
[DeviceA-GigabitEthernet3/0/2] quit
[DeviceA] interface GigabitEthernet 3/0/3
[DeviceA-GigabitEthernet3/0/3] port-isolate enable group 1
[DeviceA-GigabitEthernet3/0/3] quit
1.     Display information about isolation group 1.
[DeviceA] display port-isolate group 1
Port-isolate group information:
Uplink port support: NO
Group ID: 1
Group members:
   GigabitEthernet3/0/1     GigabitEthernet3/0/2     GigabitEthernet3/0/3
The output shows that customer-side ports GigabitEthernet 3/0/1, GigabitEthernet 3/0/2, and GigabitEthernet 3/0/3 have been assigned to isolation group 1.
2.     Perform ping operations between Host A, Host B, and Host C.
Each ping operation fails.
3.     View the ARP entries of each host.
The output ARP entries show shat each host has not learned the MAC address of any other host. These hosts are isolated from each other at Layer 2.
4.     Ping the network to which the uplink port GigabitEthernet 3/0/4 is connected (for example, a device whose IP address is on the network segment 1.1.1.0/24) from Host A, Host B, and Host C, respectively.
Each ping operation succeeds.
Configuration files
vlan 10
interface Vlan-interface10
interface GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 10
interface GigabitEthernet3/0/2
 port access vlan 10
interface GigabitEthernet3/0/3
 port access vlan 10
interface GigabitEthernet3/0/4
 port access vlan 10
Related documentation
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Configuration Guide
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Command Reference
