06-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guide-Release7128-6W71006-Layer 3 - IP Routing Configuration Guide
06-BGP configuration
06-BGP configuration 1.07 MB
Configuring BGP· 3
Overview·· 3
BGP speaker and BGP peer 3
BGP message types 3
BGP path attributes 4
BGP route selection· 8
BGP route advertisement rules 8
BGP load balancing· 8
Settlements for problems in large-scale BGP networks 9
MP-BGP· 12
BGP configuration views 13
Protocols and standards 14
BGP configuration task list 14
Configuring basic BGP· 17
Enabling BGP· 17
Configuring a BGP peer 18
Configuring a BGP peer group· 19
Specifying the source interface for TCP connections 25
Generating BGP routes 26
Injecting a local network· 26
Redistributing IGP routes 27
Controlling route distribution and reception· 28
Configuring BGP route summarization· 28
Advertising optimal routes in the IP routing table· 30
Advertising a default route to a peer or peer group· 30
Limiting routes received from a peer or peer group· 31
Configuring BGP route filtering policies 32
Configuring BGP route dampening· 36
Controlling BGP path selection· 37
Specifying a preferred value for routes received· 37
Configuring preferences for BGP routes 38
Configure the default local preference· 39
Configuring the MED attribute· 40
Configuring the NEXT_HOP attribute· 44
Configuring the AS_PATH attribute· 46
Tuning and optimizing BGP networks 51
Configuring the keepalive interval and hold time· 51
Configuring the interval for sending updates for the same route· 52
Enabling BGP to establish an EBGP session over multiple hops 53
Enabling immediate reestablishment of direct EBGP connections upon link failure· 54
Enabling 4-byte AS number suppression· 54
Enabling MD5 authentication for BGP peers 55
Configuring BGP load balancing· 56
Disabling BGP to establish a session to a peer or peer group· 57
Configuring BGP soft-reset 57
Protecting an EBGP peer when memory usage reaches level 2 threshold· 61
Configuring a large-scale BGP network· 62
Configuring BGP community· 62
Configuring BGP route reflection· 64
Configuring a BGP confederation· 66
Configuring BGP GR· 67
Enabling trap· 68
Enabling logging of session state changes 68
Configuring BFD for BGP· 68
Configuring 6PE· 70
Configuring basic 6PE· 70
Configuring optional 6PE capabilities 71
Displaying and maintaining BGP· 72
IPv4 BGP configuration examples 75
Basic BGP configuration example· 75
BGP and IGP route redistribution configuration example· 79
BGP route summarization configuration example· 82
BGP load balancing configuration example· 85
BGP community configuration example· 88
BGP route reflector configuration example· 91
BGP confederation configuration example· 93
BGP path selection configuration example· 97
BGP GR configuration example· 100
BFD for BGP configuration example· 102
IPv6 BGP configuration examples 106
IPv6 BGP basic configuration example· 106
IPv6 BGP route reflector configuration example· 109
6PE configuration example· 111
BFD for IPv6 BGP configuration example· 114
Troubleshooting BGP· 118
Symptom·· 118
Analysis 119
Solution· 119
Overview
Border Gateway Protocol (BGP) is an exterior gateway protocol (EGP). It is called internal BGP (IBGP) when it runs within an AS and called external BGP (EBGP) when it runs between ASs.
The current version in use is BGP-4 (RFC 4271).
BGP has the following characteristics:
·           Focuses on route control and selection rather than route discovery and calculation.
·           Uses TCP to enhance reliability.
·           Measures the distance of a route by using a list of ASs that the route must travel through to reach the destination. BGP is also called a path-vector protocol.
·           Supports CIDR.
·           Reduces bandwidth consumption by advertising only incremental updates. BGP is very suitable to advertise large numbers of routes on the Internet.
·           Eliminates routing loops by adding AS path information to BGP route updates.
·           Uses policies to implement flexible route filtering and selection.
·           Has good scalability.
A router running BGP is a BGP speaker. A BGP speaker establishes peer relationships with other BGP speakers to exchange routing information over TCP connections.
BGP peers fall into the following types:
·           IBGP peers—Reside in the same AS as the local router.
·           EBGP peers—Reside in different ASs from the local router.
BGP message types
BGP uses the following message types:
·           Open—After establishing a TCP connection, BGP sends an Open message to establish a session with the peer.
·           Update—BGP sends update messages to exchange routing information between peers. Each update message can advertise a group of feasible routes with identical attributes and multiple withdrawn routes.
·           Keepalive—BGP sends Keepalive messages between peers to maintain connectivity.
·           Route-refresh—BGP sends a Route-refresh message to request the routing information of a specified address family from a peer.
·           Notification—BGP sends a Notification message upon detecting an error and immediately closes the connection.
BGP path attributes
BGP uses the following path attributes in update messages for route filtering and selection:
·           ORIGIN
The ORIGIN attribute specifies the origin of BGP routes. This attribute has the following types:
¡  IGPHas the highest priority. Routes generated in the local AS have the IGP attribute.
¡  EGPHas the second highest priority. Routes obtained through EGP have the EGP attribute.
¡  INCOMPLETEHas the lowest priority. The source of routes with this attribute is unknown. Routes redistributed from other routing protocols have the INCOMPLETE attribute.
·           AS_PATH
The AS_PATH attribute identifies the ASs through which a route has passed. Before advertising a route to another AS, BGP adds the local AS number into the AS_PATH attribute, so the receiver can determine ASs to route the message back.
The AS_PATH attribute has the following types:
¡  AS_SEQUENCE—Arranges AS numbers in sequence. As shown in Figure 1, the number of the AS closest to the receiver's AS is leftmost.
¡  AS_SET—Arranges AS numbers randomly.
Figure 1 AS_PATH attribute
BGP uses the AS_PATH attribute to implement the following functions:
¡  Avoid routing loopsA BGP router does not receive routes containing the local AS number to avoid routing loops.
¡  Affect route selectionBGP gives priority to the route with the shortest AS_PATH length if other factors are the same. As shown in Figure 1, the BGP router in AS 50 gives priority to the route passing AS 40 for sending data to the destination 8.0.0.0. In some applications, you can apply a routing policy to control BGP route selection by modifying the AS_PATH length. For more information about routing policy, see "Configuring routing policies."
¡  Filter routesBy using an AS path list, you can filter routes based on AS numbers contained in the AS_PATH attribute. For more information about AS path list, see "Configuring routing policies."
·           NEXT_HOP
The NEXT_HOP attribute may not be the IP address of a directly-connected router. Its value is determined as follows:
¡  When a BGP speaker advertises a self-originated route to a BGP peer, it sets the address of the sending interface as the NEXT_HOP.
¡  When a BGP speaker sends a received route to an EBGP peer, it sets the address of the sending interface as the NEXT_HOP.
¡  When a BGP speaker sends a route received from an EBGP peer to an IBGP peer, it does not modify the NEXT_HOP attribute. If load balancing is configured, BGP modifies the NEXT_HOP attribute for the equal-cost routes. For load balancing information, see "BGP load balancing."
Figure 1 NEXT_HOP attribute
·           MED (Multi-Exit Discriminator)
BGP advertises the MED attribute between two neighboring ASs, each of which does not advertise the attribute to any other AS.
Similar to metrics used by IGPs, MED is used to determine the best route for traffic going into an AS. When a BGP router obtains multiple routes to the same destination, but with different next hops from different EBGP peers, it considers the route with the smallest MED value the best route given that other conditions are the same. As shown in Figure 3, traffic from AS 10 to AS 20 travels through Router B that is selected according to MED.
Figure 2 MED attribute
Generally BGP only compares MEDs of routes received from the same AS. You can also use the compare-different-as-med command to force BGP to compare MED values of routes received from different ASs.
·           LOCAL_PREF
The LOCAL_PREF attribute is exchanged between IBGP peers only, and is not advertised to any other AS. It indicates the priority of a BGP router.
BGP uses LOCAL_PREF to determine the best route for traffic leaving the local AS. When a BGP router obtains from several IBGP peers multiple routes to the same destination but with different next hops, it considers the route with the highest LOCAL_PREF value as the best route. As shown in Figure 4, traffic from AS 20 to AS 10 travels through Router C that is selected according to LOCAL_PREF.
Figure 3 LOCAL_PREF attribute
·           COMMUNITY
The COMMUNITY attribute identifies the community of BGP routes. A BGP community is a group of routes with the same characteristics. It has no geographical boundaries. Routes of different ASs can belong to the same community.
A route can carry one or more COMMUNITY attribute values (each of which is represented by a 4-byte integer). A router uses the COMMUNITY attribute to determine whether to advertise the route and the advertising scope without using complex filters such as ACLs. This mechanism simplifies routing policy configuration, management, and maintenance.
Well-known COMMUNITY attributes involve the following:
¡  INTERNET—By default, all routes belong to the Internet community. Routes with this attribute can be advertised to all BGP peers.
¡  NO_EXPORT—Routes with this attribute cannot be advertised out of the local AS or out of the local confederation, but can be advertised to other sub-ASs in the confederation. For confederation information, see "Settlements for problems in large-scale BGP networks."
¡  No_ADVERTISE—Routes with this attribute cannot be advertised to other BGP peers.
¡  No_EXPORT_SUBCONFED—Routes with this attribute cannot be advertised out of the local AS or other sub-ASs in the local confederation.
You can configure BGP community lists to filter BGP routes based on the BGP COMMUNITY attribute.
·           Extended community attribute
To satisfy new demands, BGP defines the extended community attribute. The extended community attribute has the following advantages over the COMMUNITY attribute:
¡  Provides more attribute values by extending the attribute length to eight bytes.
¡  Allows for using different types of extended community attributes in different scenarios to enhance route filtering and control and simplify configuration and management.
BGP route selection
BGP discards routes with unreachable NEXT_HOPs. If multiple routes to the same destination are available, BGP selects the best route in the following sequence:
1.      The route with the highest Preferred_value.
2.      The route with the highest LOCAL_PREF.
3.      The route generated by the network command, the route redistributed by the importe-route command, or the summary route in turn.
4.      The route with the shortest AS_PATH.
5.      The IGP, EGP, or INCOMPLETE route in turn.
6.      The route with the lowest MED value.
7.      The route learned from EBGP, confederation EBGP, confederation IBGP, or IBGP in turn.
8.      The route with the smallest next hop metric.
9.      The route with the shortest CLUSTER_LIST.
10.    The route with the smallest ORIGINATOR_ID.
11.    The route advertised by the router with the smallest router ID.
12.    The route advertised by the peer with the lowest IP address.
CLUSTER_IDs of route reflectors form a CLUSTER_LIST. If a route reflector receives a route that contains its own CLUSTER ID in the CLUSTER_LIST, the router discards the route to avoid routing loops.
If load balancing is configured, the system selects available routes to implement load balancing.
BGP follow these rules for route advertisement:
·           When multiple feasible routes to a destination exist, BGP advertises only the best route to its peers. If the advertise-rib-active command is configured, BGP advertises the best route in the IP routing table; if not, BGP advertise the best route in the BGP routing table.
·           BGP advertises only routes that it uses.
·           BGP advertises routes learned from an EBGP peer to all BGP peers, including both EBGP and IBGP peers.
·           BGP advertises routes learned from an IBGP peer to EBGP peers, rather than other IBGP peers.
·           After establishing a session with a new BGP peer, BGP advertises all the routes matching the above rules to the peer. After that, BGP advertises only incremental updates to the peer.
BGP load balancing
BGP implements load balancing through route recursion and route selection.
·           BGP load balancing through route recursion.
The next hop of a BGP route may not be directly connected. One of the reasons is next hops in routing information exchanged between IBGP peers are not modified. The BGP router must find the directly-connected next hop through IGP. The matching route with the direct next hop is called the "recursive route." The process of finding a recursive route is route recursion.
The system supports BGP load balancing based on route recursion. If multiple recursive routes to the same destination are load balanced (suppose three direct next hop addresses), BGP generates the same number of next hops to forward packets. BGP load balancing based on route recursion is always enabled by the system rather than configured by using commands.
·           BGP load balancing through route selection.
BGP differs from IGP in the implementation of load balancing in the following ways:
¡  IGP routing protocols, such as RIP and OSPF, compute metrics of routes, and then implement load balancing over routes with the same metric and to the same destination. The route selection criterion is metric.
¡  BGP has no route computation algorithm, so it cannot implement load balancing according to metrics of routes. However, BGP has abundant route selection rules, through which, it selects available routes for load balancing and adds load balancing to route selection rules.
BGP implements load balancing only on routes that have the same AS_PATH, ORIGIN, LOCAL_PREF and MED, rather than using the route selection rules as described in "BGP route selection."
Figure 4 Network diagram
In Figure 5, Router A and Router B are IBGP peers of Router C. Router D and Router E both advertise a route 9.0.0.0 to Router C. If load balancing with a maximum number of two routes is configured on Router C, and the two routes have the same AS_PATH, ORIGIN, LOCAL_PREF, and MED, Router C installs both the two routes to its routing table for load balancing. After that, Router C forwards to Router A and Router B a single route that has NEXT_HOP changed to Router C and other attributes changed to those of the best route.
BGP load balancing is applicable between EBGP peers, between IBGP peers, and between confederations.
You can use the following methods to facilitate management and improve route distribution efficiency on a large-scale BGP network.
·           Route summarization
Route summarization can reduce the BGP routing table size by advertising summary routes rather than more specific routes.
The system supports both manual and automatic route summarization. Manual route summarization allows you to determine the attribute of a summary route and whether to advertise more specific routes.
·           Route dampening
Route frapping (a route comes up and disappears in the routing table frequently) causes BGP to send many routing updates. It can consume too many resources and affect other operations.
In most cases, BGP runs in complex networks where route changes are more frequent. To solve the problem caused by route flapping, you can use BGP route dampening to suppress unstable routes.
BGP route dampening uses a penalty value to judge the stability of a route. The bigger the value, the less stable the route. Each time a route state change (from reachable to unreachable) occurs, or a reachable route's attribute changes, BGP adds a penalty value (1000, which is a fixed number and cannot be changed) to the route. When the penalty value of the route exceeds the suppress value, the route is suppressed and cannot become the optimal route. When the penalty value reaches the upper limit, no penalty value is added.
If the suppressed route does not flap, its penalty value gradually decreases to half of the suppress value after a period of time. This period is called "Half-life." When the value decreases to the reusable threshold value, the route is usable again.
Figure 5 BGP route dampening
·           Peer group
You can organize BGP peers with the same attributes into a group to simplify their configurations.
When a peer joins the peer group, the peer obtains the same configuration as the peer group. If the configuration of the peer group is changed, the configuration of group members is changed.
·           Community
You can apply a community list or an extended community list to a routing policy for route control. For more information, see "BGP path attributes."
·           Route reflector
IBGP peers must be fully meshed to maintain connectivity. If n routers exist in an AS, the number of IBGP connections is n(n-1)/2. If a large number of IBGP peers exist, large amounts of network and CPU resources are consumed to maintain sessions.
Using route reflectors can solve this issue. In an AS, a router acts as a route reflector, and other routers act as clients connecting to the route reflector. The route reflector forwards routing information received from a client to other clients. In this way, all clients can receive routing information from one another without establishing BGP sessions.
A router that is neither a route reflector nor a client is a non-client, which, as shown in Figure 7, must establish BGP sessions to the route reflector and other non-clients.
Figure 6 Network diagram for a route reflector
The route reflector and clients form a cluster. Typically a cluster has one route reflector. The ID of the route reflector is the Cluster_ID. You can configure more than one route reflector in a cluster to improve availability, as shown in Figure 8. The configured route reflectors must have the same Cluster_ID to avoid routing loops.
Figure 7 Network diagram for route reflectors
When the BGP routers in an AS are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can use commands to disable route reflection instead of modifying network configuration or changing network topology.
After route reflection is disabled between clients, routes can still be reflected between a client and a non-client.
·           Confederation
Confederation is another method to manage growing IBGP connections in an AS. It splits an AS into multiple sub-ASs. In each sub-AS, IBGP peers are fully meshed. As shown in Figure 9, intra-confederation EBGP connections are established between sub-ASs in AS 200.
Figure 8 Confederation network diagram
A non-confederation BGP speaker does not need to know sub-ASs in the confederation. It considers the confederation as one AS, and the confederation ID as the AS number. In the above figure, AS 200 is the confederation ID.
Confederation has a deficiency. When you change an AS into a confederation, you must reconfigure the routers, and the topology will be changed.
In large-scale BGP networks, you can use both route reflector and confederation.
MP-BGP
BGP-4 carries only IPv4 unicast routing information. IETF extended BGP-4 by introducing Multiprotocol Extensions for BGP-4 (MP-BGP). MP-BGP can carry routing information for multiple address families, including IPv4 multicast, IPv6 unicast, IPv6 multicast, and VPNv4.
MP-BGP is backward compatible with BGP.
MP-BGP extended attributes
Prefixes and next hops are key routing information. BGP-4 uses update messages to carry feasible route prefixes in the Network Layer Reachability Information (NLRI) field, unfeasible route prefixes in the withdrawn routes field, and next hops in the NEXT_HOP attribute. These attributes cannot carry routing information for multiple network layer protocols.
To support multiple network layer protocols, MP-BGP defines the following path attributes:
·           MP_REACH_NLRICarries feasible route prefixes and next hops for multiple network layer protocols.
·           MP_UNREACH_NLRICarries unfeasible route prefixes for multiple network layer protocols.
MP-BGP uses these two attributes to advertise feasible and unfeasible routes for different network layer protocols. BGP speakers not supporting MP-BGP ignore updates containing these attributes and do not forward them to its peers.
The current MP-BGP implementation supports multiple protocol extensions, including VPN, IPv6, and multicast. For more information about VPN, see MPLS Configuration Guide.
Address family
MP-BGP uses address families and subsequent address families to identify different network layer protocols for routes contained in the MP_REACH_NLRI and MP_UNREACH_NLRI attributes. For example, an Address Family Identifier (AFI) of 2 and a Subsequent Address Family Identifier (SAFI) of 1 identify IPv6 unicast routing information carried in the MP_REACH_NLRI attribute. For address family values, see RFC 1700.
BGP uses different views to manage routing information for different address families and different VPN instances. Most BGP commands are available in all BGP views. BGP supports multiple VPN instances by establishing a separate routing table for each VPN.
Table 1 describes different BGP views.
Table 1 BGP views
View names
Ways to enter the views
Remarks
BGP view
[Sysname] bgp 100
[Sysname-bgp]
Configurations in this view are effective for routes and peers of all address families on the public network and in all VPN instances (such as confederation, GR, and logging configurations), or only for routes and peers of all address families on the public network.
BGP IPv4 unicast instance view
[Sysname] bgp 100
[Sysname-bgp] ipv4-family unicast
[Sysname-bgp-ipv4]
Configurations in this view are effective for IPv4 unicast routes and peers on the public network.
BGP IPv6 unicast instance view
[Sysname] bgp 100
[Sysname-bgp] ipv6-family unicast
[Sysname-bgp-ipv6]
Configurations in this view are effective for IPv6 unicast routes and peers on the public network.
BGP VPNv4 instance view
[Sysname] bgp 100
[Sysname-bgp] ipv4-family vpnv4
[Sysname-bgp-vpnv4]
Configurations in this view are effective for VPNv4 routes and peers.
For more information about BGP VPNv4 instance view, see MPLS Configuration Guide.
BGP VPNv6 instance view
[Sysname] bgp 100
[Sysname-bgp] ipv6-family vpnv6
[Sysname-bgp-vpnv6]
Configurations in this view are effective for VPNv6 routes and peers.
For more information about BGP VPNv6 instance view, see MPLS Configuration Guide.
BGP-VPN view
[Sysname] bgp 100
[Sysname-bgp] ip vpn-instance vpn1
[Sysname-bgp-vpn1]
Configurations in this view are effective for routes and peers of all address families in the specified VPN instance.
BGP-VPN IPv4 unicast instance view
[Sysname] bgp 100
[Sysname-bgp-vpn1] ipv4-family unicast
[Sysname-bgp-ipv4-vpn1]
Configurations in this view are effective for IPv4 unicast routes and peers in the specified VPN instance.
BGP-VPN IPv6 unicast instance view
[Sysname] bgp 100
[Sysname-bgp-vpn1] ipv6-family unicast
[Sysname-bgp-ipv6-vpn1]
Configurations in this view are effective for IPv6 unicast routes and peers in the specified VPN instance.
BGP-VPN VPNv4 instance view
[Sysname] bgp 100
[Sysname-bgp-vpn1] ipv4-family vpnv4
[Sysname-bgp-vpnv4-vpn1]
Configurations in this view are effective for VPNv4 routes and peers in the specified VPN instance.
For more information about BGP-VPN VPNv4 instance view, see MPLS Configuration Guide.
·           RFC 1700, ASSIGNED NUMBERS
·           RFC 1771, A Border Gateway Protocol 4 (BGP-4)
·           RFC 2858, Multiprotocol Extensions for BGP-4
·           RFC 3392, Capabilities Advertisement with BGP-4
·           RFC 2918, Route Refresh Capability for BGP-4
·           RFC 2439, BGP Route Flap Damping
·           RFC 1997, BGP Communities Attribute
·           RFC 2796, BGP Route Reflection
·           RFC 3065, Autonomous System Confederations for BGP
·           RFC 4271, A Border Gateway Protocol 4 (BGP-4)
·           RFC 4724, Graceful Restart Mechanism for BGP
·           RFC 4360, BGP Extended Communities Attribute
·           RFC 4760, Multiprotocol Extensions for BGP-4
In a basic BGP network, you only need to perform the following configurations:
·           Enable BGP.
·           Configure BGP peers or peer groups. If you configure a BGP setting at both the peer group and the peer level, the most recent configuration takes effect on the peer.
·           Control BGP route generation.
To control BGP route distribution and path selection, you must perform additional configuration tasks.
To configure BGP, perform the following tasks (IPv4):
Tasks at a glance
Remarks
Configuring basic BGP:
·       (Required.) Enabling BGP
·       (Required.) Perform one of the following tasks:
¡ Configuring a BGP peer
¡ Configuring a BGP peer group
·       (Optional.) Specifying the source interface for TCP connections
H3C recommends configuring BGP peer groups on large scale BGP networks for easy configuration and maintenance.
Generating BGP routes:
·       Perform at least one of the following tasks:
¡ Injecting a local network
¡ Redistributing IGP routes
N/A
(Optional.) Controlling route distribution and reception:
·       Configuring BGP route summarization
·       Advertising optimal routes in the IP routing table
·       Advertising a default route to a peer or peer group
·       Limiting routes received from a peer or peer group
·       Configuring BGP route filtering policies
·       Configuring BGP route dampening
N/A
(Optional.) Controlling BGP path selection:
·       Specifying a preferred value for routes received
·       Configuring preferences for BGP routes
·       Configure the default local preference
·       Configuring the MED attribute
·       Configuring the NEXT_HOP attribute
·       Configuring the AS_PATH attribute
N/A
(Optional.) Tuning and optimizing BGP networks:
·       Configuring the keepalive interval and hold time
·       Configuring the interval for sending updates for the same route
·       Enabling BGP to establish an EBGP session over multiple hops
·       Enabling immediate reestablishment of direct EBGP connections upon link failure
·       Enabling 4-byte AS number suppression
·       Enabling MD5 authentication for BGP peers
·       Configuring BGP load balancing
·       Disabling BGP to establish a session to a peer or peer group
·       Configuring BGP soft-reset
·       Protecting an EBGP peer when memory usage reaches level 2 threshold
N/A
(Optional.) Configuring a large-scale BGP network:
·       Configuring BGP community
·       Configuring BGP route reflection
·       Configuring a BGP confederation
N/A
(Optional.) Configuring BGP GR
N/A
(Optional.) Enabling trap
N/A
(Optional.) Enabling logging of session state changes
N/A
(Optional.) Configuring BFD for BGP
N/A
To configure BGP, perform the following tasks (IPv6):
Tasks at a glance
Remarks
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
This section describes the basic settings required for a BGP network to run.
Enabling BGP
A router ID is the unique identifier of a BGP router in an AS.
·           To ensure the uniqueness of a router ID and enhance availability, specify in BGP view the IP address of a local loopback interface as the router ID.
·           If no router ID is specified in BGP view, the global router ID is used.
·           To modify a router ID, use the router-id command in BGP view, rather than the router id command in system view.
·           If you specify a router ID in BGP view and then remove the interface that owns the router ID, the router does not select a new router ID. To select a new router ID, use the undo router-id command in BGP view.
To enable BGP:
Step
Remarks
1.     Enter system view.
N/A
2.     Configure a global router ID.
router id router-id
By default, no global router ID is configured, and BGP uses the highest loopback interface IP address—if any—as the router ID. If no loopback interface IP address is available, BGP uses the highest physical interface IP address as the route ID regardless of the interface status.
3.     Enable BGP and enter BGP view or BGP-VPN view.
·       Enable BGP and enter BGP view:
bgp as-number
·       Enable BGP and enter BGP-VPN view:
a.   bgp as-number
b.   ip vpn-instance vpn-instance-name
By default, BGP is not enabled.
A router can reside in only one AS, so the router can run only one BGP process.
To enter BGP-VPN view, the specified VPN instance must already exist and have the route distinguisher (RD) configured. For more information, see MPLS Configuration Guide.
4.     Specify a router ID.
router-id router-id
By default, the global router ID is used.
Configuring an IPv4 BGP peer
Step
Remarks
N/A
2.     Enter BGP view or BGP-VPN view.
·       Enter BGP view:
bgp as-number
·       Enter BGP-VPN view:
a.   bgp as-number
N/A
3.     Create an IPv4 BGP peer and specify its AS number.
peer ip-address as-number as-number
By default, no IPv4 BGP peer is created.
4.     (Optional.) Configure a description for a peer.
peer ip-address description description-text
By default, no description is configured for a peer.
5.     Create and enter BGP IPv4 unicast instance view or BGP-VPN IPv4 unicast instance view.
ipv4-family [ unicast ]
By default, the BGP IPv4 unicast instance view and BGP-VPN IPv4 unicast instance view are not created.
6.     Enable the router to exchange IPv4 unicast routing information with the specified peer.
peer ip-address enable
By default, the router cannot exchange IPv4 unicast routing information with the peer.
Configuring an IPv6 BGP peer
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Create an IPv6 BGP peer and specify its AS number.
By default, no IPv6 BGP peer is created.
peer ipv6-address description description-text
5.     Create and enter BGP IPv6 unicast instance view or BGP-VPN IPv6 unicast instance view.
ipv6-family [ unicast ]
By default, the BGP IPv6 unicast instance view and BGP-VPN IPv6 unicast instance view are not created.
6.     Enable the router to exchange IPv6 unicast routing information with the specified peer.
peer ipv6-address enable
By default, the router cannot exchange IPv6 unicast routing information with the peer.
The peers in a peer group use the same route selection policy.
In a large-scale network, many peers can use the same route selection policy. You can configure a peer group and add these peers into this group. When you change the policy for the group, the modification also applies to the peers in the group.
A peer group is an IBGP peer group if peers in it belong to the local AS, and is an EBGP peer group if peers in it belong to different ASs.
Configuring an IBGP peer group
After you create an IBGP peer group and then add a peer into it, the system creates the peer in BGP view and specifies the local AS number for the peer.
To configure an IBGP peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Create an IBGP peer group.
group group-name [ internal ]
By default, no IBGP peer group is created.
4.     Add a peer into the IBGP peer group.
peer ip-address group group-name [ as-number as-number ]
By default, no peer exists in the peer group.
To use the as-number as-number option, you must specify the local AS number.
5.     (Optional.) Configure a description for a peer group.
peer group-name description description-text
By default, no description is configured for the peer group.
6.     Create and enter BGP IPv4 unicast instance view or BGP-VPN IPv4 unicast instance view.
7.     Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
peer group-name enable
By default, the router cannot exchange IPv4 unicast routing information with the peers.
To configure an IBGP peer group (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer ipv6-address group group-name [ as-number as-number ]
6.     Create and enter BGP IPv6 unicast instance view or BGP-VPN IPv6 unicast instance view.
7.     Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
By default, the router cannot exchange IPv6 unicast routing information with the peers.
Configuring an EBGP peer group
If peers in an EBGP group belong to the same external AS, the EBGP peer group is a pure EBGP peer group. If not, it is a mixed EBGP peer group.
Use one of the following approaches to configure an EBGP peer group:
·           Approach 1—Create an EBGP peer group, specify its AS number, and add peers into it. All the added peers have the same AS number. All peers in the peer group have the same AS number as the peer group. You can specify an AS number for a peer before adding it into the peer group. The AS number must be the same as that of the peer group.
·           Approach 2Create an EBGP peer group, specify an AS number for a peer, and add the peer into the peer group. Peers added in the group can have different AS numbers.
·           Approach 3Create an EBGP peer group and add a peer with an AS number into it. Peers added in the group can have different AS numbers.
To configure an EBGP peer group by using Approach 1 (IPv4):
Step
Remarks
8.     Enter system view.
N/A
9.     Enter BGP view or BGP-VPN view.
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
10.   Create an EBGP peer group.
group group-name external
By default, no EBGP peer group is created.
11.   Specify the AS number for the group.
By default, no AS number is specified.
If a peer group contains peers, you cannot remove or change its AS number.
12.   Add a peer into the EBGP peer group.
The as-number as-number option, if used, must specify the same AS number as the peer group-name as-number as-number command.
13.   (Optional.) Configure a description for a peer group.
14.   Create and enter BGP IPv4 unicast instance view or BGP-VPN IPv4 unicast instance view.
15.   Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
To configure an EBGP peer group by using Approach 1 (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Create an EBGP peer group.
4.     Specify the AS number for the group.
5.     Add a peer into the EBGP peer group.
6.     (Optional.) Configure a description for a peer group.
7.     Create and enter BGP IPv6 unicast instance view or BGP-VPN IPv6 unicast instance view.
8.     Enable the router to exchange IPv6 unicast routing information with peers in the specified peer group.
To configure an EBGP peer group by using Approach 2 (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
4.     Create an IPv4 BGP peer and specify its AS number.
5.     Add the peer into the EBGP peer group.
The as-number as-number option, if used, must specify the same AS number as the peer ip-address as-number as-number command.
7.     Create and enter BGP IPv4 unicast instance view or BGP-VPN IPv4 unicast instance view.
8.     Enable the router to exchange IPv4 unicast routing information with peers in the specified peer group.
To configure an EBGP peer group by using Approach 2 (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
4.     Create an IPv6 BGP peer and specify its AS number.
6.     (Optional.) Configure a description for the peer group.
To configure an EBGP peer group by using Approach 3 (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
4.     Add a peer into the EBGP peer group.
peer ip-address group group-name as-number as-number
5.     (Optional.) Configure a description for the peer group.
To configure an EBGP peer group by using Approach 3 (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer ipv6-address group group-name as-number as-number
By default, BGP uses the output interface of the optimal route to a peer or peer group as the source interface for establishing TCP connections to the peer or peer group, and it uses the IP address/IPv6 address of the output interface as the source IP address/IPv6 address of TCP connections. You can change the source interface in the following scenarios:
·           If the peer’s IP address/IPv4 address belongs to an interface indirectly connected to the local router, you must specify that interface as the source interface for TCP connections on the peer. For example, interface A on the local end is directly connected to interface B on the peer. If you use the peer x.x.x.x as-number as-number command in which x.x.x.x is not the IP address of interface B on the local end, you must use the peer connect-interface command on the peer to specify the interface whose IP address is x.x.x.x as the source interface for establishing a TCP connection.
·           On a BGP router that has multiple links to a peer, if the source interface fails, BGP has to reestablish TCP connections. To avoid this problem, use a loopback interface as the source interface.
·           To establish multiple BGP sessions between two routers, specify the source interface for establishing TCP connections to each peer on the local router. Otherwise, the local BGP router may fail to establish a TCP connection to a peer when using the outbound interface of the best route to the peer as the source interface.
To specify the source interface for TCP connections (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Specify the source interface for establishing TCP connections to a peer or peer group.
peer { group-name | ip-address } connect-interface interface-type interface-number
By default, BGP uses the outbound interface of the best route to the BGP peer or peer group as the source interface for establishing a TCP connection to the peer or peer group.
To specify the source interface for TCP connections (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } connect-interface interface-type interface-number
BGP can generate routes in the following ways:
·           Advertise local networks.
·           Redistribute IGP routes.
Perform this task to inject a network in the local routing table to the BGP routing table, so BGP can advertise the network to BGP peers. The ORIGIN attribute of BGP routes advertised in this way is IGP. You can also use a routing policy to control route advertisement.
The specified network must be available and active in the local IP routing table.
To inject a local network (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Enter BGP IPv4 unicast instance view or BGP-VPN IPv4 unicast instance view.
N/A
4.     Inject a local network to the BGP routing table.
network ip-address [ mask | mask-length ] [ route-policy route-policy-name ]
By default, BGP does not advertise any local network.
To inject a local network (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Enter BGP IPv6 unicast instance view or BGP-VPN IPv6 unicast instance view.
N/A
4.     Inject a local network to the IPv6 BGP routing table.
Perform this task to configure route redistribution from an IGP to BGP.
By default, BGP does not redistribute default IGP routes. You can use the default-route imported command to redistribute default IGP routes into the BGP routing table.
Only active routes can be redistributed. To view route state information, use the display ip routing-table protocol or display ipv6 routing-table protocol command.
The ORIGIN attribute of BGP routes redistributed from IGPs is INCOMPLETE.
To configure BGP to redistribute IGP routes (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Enable route redistribution from the specified IGP into BGP.
import-route protocol [ { process-id | all-processes } [ med med-value | route-policy route-policy-name ] * ]
By default, BGP does not redistribute IGP routes.
5.     (Optional.) Enable default route redistribution into BGP.
By default, BGP does not redistribute default routes.
To configure BGP to redistribute IGP routes (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
import-route protocol [ process-id [ med med-value | route-policy route-policy-name ] * ]
This section describes how to control route distribution and reception.
Route summarization can reduce the number of redistributed routes and the routing table size. IPv4 BGP supports automatic route summarization and manual route summarization. Manual summarization takes precedence over automatic summarization. IPv6 BGP supports only manual route summarization.
The output interface of a BGP summary route is Null 0 on the originating router. Therefore, a summary route must not be an optimal route on the originating router. Otherwise, BGP will fail to forward packets matching the route. If a summarized specific route has the same mask as the summary route, but has a lower priority, the summary route becomes the optimal route. In this case, you must change the priority of the summary or the specific route to make the specific route as the optimal route.
Configuring automatic route summarization
Automatic route summarization enables BGP to summarize IGP subnet routes redistributed by the import-route command so BGP advertises only natural network routes.
To configure automatic route summarization (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure automatic route summarization.
summary automatic
By default, automatic route summarization is not configured.
Configuring manual route summarization
By configuring manual route summarization, you can summarize both redistributed routes and routes injected using the network command and determine the mask length for a summary route as needed.
To configure BGP manual route summarization (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Create a summary route in the BGP routing table.
aggregate ip-address { mask | mask-length } [ as-set | attribute-policy route-policy-name | detail-suppressed | origin-policy route-policy-name | suppress-policy route-policy-name ] *
By default, no summary route is configured.
To configure BGP manual route summarization (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enter BGP IPv6 unicast instance view.
N/A
4.     Create a summary route in the IPv6 BGP routing table.
By default, BGP advertises optimal routes in the BGP routing table, which may not be optimal in the IP routing table. This task allows you to advertise BGP routes that are optimal in the IP routing table to all BGP peers.
To enable BGP to advertise optimal routes in the IP routing table:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable BGP to advertise optimal routes in the IP routing table.
By default, BGP advertises optimal routes in the BGP routing table.
Perform this task to advertise a default BGP route with the next hop being the advertising router to a peer or peer group.
To advertise a default route to a peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Advertise a default route to a peer or peer group.
peer { group-name | ip-address } default-route-advertise [ route-policy route-policy-name ]
By default, no default route is advertised.
To advertise a default route to a peer or peer group (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address } default-route-advertise [ route-policy route-policy-name ]
This feature can prevent attacks that send a large number of BGP routes to the router.
If the number of routes received from a peer or peer group exceeds the upper limit, the router takes one of the following actions based on your configuration:
·           Tear down the BGP session to the peer or peer group.
·           Display an alarm message.
·           Tear down the BGP session to the peer or peer group and, after a specified period of time, reestablishes a BGP session to the peer or peer group.
You can specify a percentage threshold for the router to display an alarm message. When the ratio of the number of received routes to the maximum number reaches the percentage value, the router displays an alarm message.
To limit routes that a router can receive from a peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Specify the maximum number of routes that a router can receive from a peer or peer group.
peer { group-name | ip-address } route-limit prefix-number [ { alert-only | reconnect reconnect-time } | percentage-value ] *
By default, the number of routes that a router can receive from a peer or peer group is not limited.
To limit routes that a router can receive from a peer or peer group (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address } route-limit prefix-number [ { alert-only | reconnect reconnect-time } | percentage-value ] *
Configuration prerequisites
Before you configure BGP routing filtering policies, configure the following filters used for route filtering as needed:
·           ACL (see ACL and QoS Configuration Guide)
·           Prefix list (see "Configuring routing policies")
·           Routing policy (see "Configuring routing policies")
·           AS path list (see "Configuring routing policies")
Configuring BGP route distribution filtering policies
To configure BGP route distribution filtering policies, use the following methods:
·           Use an ACL or prefix list to filter routing information advertised to all peers.
·           Use a routing policy, ACL, AS path list, or prefix list to filter routing information advertised to a peer or peer group.
If you configure multiple filtering policies, apply them in the following sequence:
1.      filter-policy export
2.      peer filter-policy export
3.      peer as-path-acl export
4.      peer prefix-list export
5.      peer route-policy export
Only routes passing all the configured policies can be advertised.
To configure BGP route distribution filtering policies (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure BGP route distribution filtering policies.
·       Reference an ACL or IP prefix list to filter routes redistributed to all peers:
filter-policy { acl-number | prefix-list prefix-list-name } export [ direct | isis process-id | ospf process-id | rip process-id | static ]
·       Reference a routing policy to filter advertisements to a peer or peer group:
peer { group-name | ip-address } route-policy route-policy-name export
·       Reference an ACL to filter advertisements to a peer or peer group:
peer { group-name | ip-address } filter-policy acl-number export
·       Reference an AS path list to filter routing information sent to a peer or peer group:
peer { group-name | ip-address } as-path-acl as-path-acl-number export
·       Reference an IPv4 prefix list to filter routing information sent to a peer or peer group:
peer { group-name | ip-address } prefix-list prefix-list-name export
Use at least one approach.
By default, no BGP distribution filtering policy is configured.
To configure BGP route distribution filtering policies (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
Ipv6-family [ unicast ]
N/A
·       Reference an ACL or IPv6 prefix list to filter routes redistributed to all peers:
filter-policy { acl6-number | prefix-list ipv6-prefix-name } export [ direct | isisv6 process-id | ospfv3 process-id | ripng process-id | static ]
peer { group-name | ipv6-address } route-policy route-policy-name export
peer { group-name | ipv6-address } filter-policy acl6-number export
peer { group-name | ipv6-address } as-path-acl as-path-acl-number export
·       Reference an IPv6 prefix list to filter routing information sent to peer { group-name | ipv6-address } prefix-list ipv6-prefix-name export
Not configured by default.
Configuring BGP route reception filtering policies
You can use the following methods to configure BGP route reception filtering policies:
·           Use an ACL or prefix list to filter routing information received from all peers.
·           Use a routing policy, ACL, AS path list, or prefix list to filter routing information received from a peer or peer group.
1.      filter-policy import
2.      peer filter-policy import
3.      peer as-path-acl import
4.      peer prefix-list import
5.      peer route-policy import
Only routes passing all the configured policies can be received.
To configure BGP route reception filtering policies (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure BGP route reception filtering policies.
·       Reference an ACL or IP prefix list to filter routes from all peers:
filter-policy { acl-number | prefix-list prefix-list-name } import
·       Reference a routing policy to filter routing information from a peer or peer group:
peer { group-name | ip-address } route-policy route-policy-name import
·       Reference an ACL to filter routing information from a peer or peer group:
peer { group-name | ip-address } filter-policy acl-number import
·       Reference  an AS path list to filter routing information from a peer or peer group:
peer { group-name | ip-address } as-path-acl as-path-acl-number import
·       Reference an IPv4 prefix list to filter routing information from a peer or peer group:
peer { group-name | ip-address } prefix-list prefix-list-name import
By default, no route reception filtering is configured.
To configure BGP route reception filtering policies (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
·       Reference ACL or IPv6 prefix list to filter routes from all peers:
filter-policy { acl6-number | prefix-list ipv6-prefix-name } import
peer { group-name | ipv6-address } route-policy route-policy-name import
peer { group-name | ipv6-address } filter-policy acl6-number import
peer { group-name | ipv6-address } as-path-acl as-path-acl-number import
·       Reference an IPv6 prefix list to filter routing information from a peer or peer group:
peer { group-name | ipv6-address } prefix-list ipv6-prefix-name import
Route dampening enables BGP to not select unstable routes as optimal routes.
To configure BGP route dampening (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure BGP route dampening.
By default, BGP route dampening is not configured.
To configure BGP route dampening (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure IPv6 BGP route dampening.
By default, IPv6 BGP route dampening is not configured.
By configuring BGP path attributes, you can control BGP path selection.
Perform this task to set a preferred value for specific routes to control BGP path selection.
Among multiple routes that have the same destination/mask and are learned from different peers, the one with the greatest preferred value is selected as the optimal route.
To specify a preferred value for routes from a peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Specify a preferred value for routes received from a peer or peer group.
peer { group-name | ip-address } preferred-value value
The default preferred value is 0.
If both a routing policy and the peer { group-name | ip-address } preferred-value value command are configured to specify a preferred value for routes received from a peer or peer group, the routing policy applies. If the preferred value set by the routing policy is 0 or no preferred value is set by the routing policy, the peer { group-name | ip-address } preferred-value value command applies. For how to specify a preferred value for BGP routes in a routing policy, see the peer { group-name | ip-address } route-policy route-policy-name { export | import } command.
To specify a preferred value for routes from a peer or peer group (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
peer { group-name | ipv6-address } preferred-value value
Routing protocols each have a default preference. If they find multiple routes destined for the same network, the route found by the routing protocol with the highest preference is selected as the optimal route.
You can use the preference command to modify preferences for EBGP, IBGP, and local BGP routes, or reference a routing policy to set a preference for matching routes (for routes not matching the routing policy, the default preference applies).
If a device has an EBGP route and a local BGP route to reach the same destination, it does not select the EBGP route because the EBGP route has a lower preference than the local BGP route by default. You can use the network short-cut command to configure the EBGP route as a shortcut route that has the same preference as the local BGP route so that the EBGP route will more likely become the optimal route.
To configure preferences for BGP routes (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure preferences for EBGP, IBGP, and local BGP routes.
The default preferences for EBGP, IBGP, and local BGP routes are 255, 255, and 130.
5.     Configure an EBGP route as a shortcut route.
network ip-address [ mask | mask-length ] short-cut
By default, an EBGP route has a preference of 255.
To configure preferences for BGP routes (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
The local preference is used to determine the best route for traffic leaving the local AS. When a BGP router obtains from several IBGP peers multiple routes to the same destination, but with different next hops, it considers the route with the highest local preference as the best route.
This task allows you to specify the default local preference for routes sent to IBGP peers.
To specify the default local preference (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure the default local preference.
The default local preference is 100.
To specify the default local preference (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
BGP uses MED to determine the best route for traffic going into an AS. When a BGP router obtains from EBGP peers multiple routes to the same destination but with different next hops, it considers the route with the smallest MED value as the best route if other conditions are the same.
Configuring the default MED value
To configure the default MED value (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure the default MED value.
default med med-value
The default MED value is 0.
To configure the default MED value (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
Enabling MED comparison for routes from different ASs
This task enables BGP to compare the MEDs of routes from different ASs.
To enable MED comparison for routes from different ASs (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Enable MED comparison for routes from different ASs.
To enable MED comparison for routes from different ASs (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
Enabling MED comparison for routes on a per-AS basis
This task enables BGP to compare the MEDs of routes from an AS.
Figure 9 Route selection based on MED (in an IPv4 network)
As shown in Figure 10, Router D learns network 10.0.0.0 from both Router A and Router B. Because Router B has a smaller router ID, the route learned from Router B is optimal.
     Network            NextHop         MED        LocPrf     PrefVal Path/Ogn
 *>i  10.0.0.0          2.2.2.2         50                    0       300e
 * i                    3.3.3.3         50                    0       200e
When Router D learns network 10.0.0.0 from Router C, it compares the route with the optimal route in its routing table. Because Router C and Router B reside in different ASs, BGP does not compare the MEDs of the two routes. Router C has a smaller router ID than Router B so the route from Router C becomes optimal.
 *>i  10.0.0.0          1.1.1.1         60                    0       200e
 * i  10.0.0.0          2.2.2.2         50                    0       300e
However, Router C and Router A reside in the same AS, and Router C has a greater MED, so network 10.0.0.0 learned from Router C should not be optimal.
You can configure the bestroute compare-med command to enable MED comparison for routes from the same AS on Router D. After that, Router D puts the routes received from each AS into a group, selects the route with the lowest MED from each group, and compares routes from different groups. This mechanism avoids the above-mentioned problem. The following output shows the BGP routing table on Router D after this feature is enabled. Network 10.0.0.0 learned from Router B is the optimal route.
 * i                    1.1.1.1         60                    0       200e
To enable MED comparison for routes on a per-AS basis (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Enable MED comparison for routes on a per-AS basis.
To enable MED comparison for routes on a per-AS basis (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
Enabling MED comparison for routes from confederation peers
This task enables BGP to compare the MEDs of routes received from confederation peers. However, if a route received from a confederation peer has an AS number that does not belong to the confederation, BGP does not compare the route with other routes. For example, a confederation has three AS numbers 65006, 65007, and 65009. BGP receives three routes from different confederation peers. The AS_PATH attributes of these routes are 65006 65009, 65007 65009, and 65008 65009, and the MED values of them are 2, 3, and 1. Because the third route's AS_PATH attribute contains AS number 65008 that does not belong to the confederation, BGP does not compare it with other routes. As a result, the first route becomes the optimal route.
To enable MED comparison for routes from confederation peers (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
·       Enter BGP-VPN instance view:
a.   bgp as-number
N/A
N/A
4.     Enable MED comparison for routes from confederation peers.
bestroute med-confederation
To enable MED comparison for routes from confederation peers (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
By default, a BGP router does not set itself as the next hop for routes advertised to an IBGP peer or peer group. In some cases, however, you must configure the advertising router as the next hop to make sure the BGP peer can find the correct next hop.
For example, as shown in Figure 11, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. If Router C has no route destined for IP address 1.1.1.1/24, you must configure Router B to set itself 3.1.1.1/24 as the next hop for the network 2.1.1.1/24 advertised to Router C.
Figure 10 NEXT_HOP attribute configuration
If a BGP router has two peers on a broadcast network, it does not set itself as the next hop for routes sent to an EBGP peer by default. As shown in Figure 12, Router A and Router B establish an EBGP neighbor relationship, and Router B and Router C establish an IBGP neighbor relationship. They are on the same broadcast network 1.1.1.0/24. When Router B sends EBGP routes to Router A, it does not set itself as the next hop by default. However, you can configure Router B to set it (1.1.1.2/24) as the next hop for routes sent to Router A by using the peer next-hop-local command as needed.
Figure 11 NEXT_HOP attribute configuration
IMPORTANT:
If you have configured BGP load balancing, the router sets itself as the next hop for routes sent to an IBGP peer or peer group regardless of whether the peer next-hop-local command is configured.
To configure the NEXT_HOP attribute (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Specify the router as the next hop for routes sent to a peer or peer group.
peer { group-name | ip-address } next-hop-local
By default, the router sets itself as the next hop for routes sent to an EBGP peer or peer group, but does not set itself as the next hop for routes sent to an IBGP peer or peer group.
To configure the NEXT_HOP attribute (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address } next-hop-local
Permitting local AS number to appear in routes from a peer or peer group
In general, BGP checks whether the AS_PATH attribute of a route from a peer contains the local AS number. If yes, it discards the route to avoid routing loops.
In certain network environments (for example, a Hub&Spoke network in MPLS L3VPN), however, the AS_PATH attribute of a route from a peer must be allowed to contain the local AS number. Otherwise, the route cannot be advertised correctly.
To permit the local AS number to appear in routes from a peer or peer group and specify the appearance times (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Permit the local AS number to appear in routes from a peer or peer group and specify the appearance times.
peer { group-name | ip-address } allow-as-loop [ number ]
By default, the local AS number is not allowed in routes from a peer or peer group.
To permit the local AS number to appear in routes from a peer or peer group and specify the appearance times (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
peer { group-name | ipv6-address } allow-as-loop [ number ]
Disabling BGP from considering AS_PATH during best route selection
To disable BGP from considering AS_PATH during best route selection (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Disable BGP from considering AS_PATH during best route selection.
bestroute as-path-neglect
By default, BGP considers AS_PATH during best route selection.
To disable BGP from considering AS_PATH during best route selection (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
Advertising a fake AS number to a peer or peer group
After you move a BGP router from an AS to another AS (from AS 2 to AS 3 for example), you have to modify the AS number of the router on all its EBGP peers. To avoid such modifications, you can configure the router to advertise a fake AS number 2 to its EBGP peers so that the EBGP peers still think that Router A is in AS 2.
To advertise a fake AS number to a peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Advertise a fake AS number to a peer or peer group.
peer { group-name | ip-address } fake-as as-number
By default, no fake AS number is advertised to a peer or peer group.
This command applies to only EBGP peers or EBGP peer groups.
To advertise a fake AS number to a peer or peer group (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } fake-as as-number
Configuring AS number substitution
IMPORTANT:
Do not configure AS number substitution in normal circumstances. Otherwise, routing loops might occur.
To use BGP between PE and CE in MPLS L3VPN, VPN sites in different geographical areas should have different AS numbers. Otherwise, BGP discards route updates containing the local AS number. If two CEs connected to different PEs use the same AS number, you must configure AS number substitution on each PE to replace the AS number in route updates originated by the remote CE as its own AS number before advertising them to the connected CE.
Figure 12 AS number substitution configuration (in an IPv4 network)
For example, as shown in Figure 13, CE 1 and CE 2 use the same AS number 800. To implement bidirectional communication between the two sites, configure AS number substitution on PE 2 to replace AS 800 as AS 100 for the BGP route update originated from CE 1 before advertising it to CE2, and perform the same configuration on PE1.
To configure AS number substitution for a peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Configure AS number substitution for a peer or peer group.
peer { group-name | ip-address } substitute-as
By default, AS number substitution is not configured.
To configure AS number substitution for a peer or peer group (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } substitute-as
Removing private AS numbers from updates sent to an EBGP peer or peer group
Private AS numbers are typically used in test networks, and should not be transmitted in public networks. The range of private AS numbers is from 64512 to 65535.
To remove private AS numbers from updates sent to an EBGP peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure BGP to remove private AS numbers from the AS_PATH attribute of updates sent to an EBGP peer or peer group.
peer { group-name | ip-address } public-as-only
By default, this feature is not configured.
This command is only applicable to EBGP peers or peer groups.
To remove private AS numbers from updates sent to an EBGP peer or peer group (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
peer { group-name | ipv6-address } public-as-only
Ignoring the first AS number of EBGP route updates
By default, BGP checks whether the first AS number in the AS_PATH attribute of a route update received from a peer is the AS number of that peer. If not, BGP discards the route update.
To ignore the first AS number of EBGP route updates:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure BGP to ignore the first AS number of EBGP route updates.
ignore-first-as
By default, BGP checks the first AS number of EBGP route updates.
This section describes how to tune and optimize BGP networks.
BGP sends keepalive messages at a specific interval to keep the BGP session between two routers.
If a router receives no keepalive or update message from a peer within the hold time, it tears down the session.
You can configure the keepalive interval and hold time globally or for a specific peer or peer group. The individual settings take precedence over the global settings.
The actual keepalive interval and hold time are determined as follows:
·           If the hold time settings on the local and peer routers are different, the smaller setting is used. If the hold time is 0, BGP does not send keepalive messages to its peers and never tears down the session.
·           If the keepalive interval is 0 and the negotiated hold time is not 0, the actual keepalive interval equals 1/3 of the hold time. If the keepalive interval is not 0, the actual keepalive interval is the smaller one between 1/3 of the hold time and the keepalive interval.
To configure the keepalive interval and hold time (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Configure the keepalive interval and hold time.
·       Configure the global keepalive interval and hold time:
·       Configure the keepalive interval and hold time for a peer or peer group:
peer { group-name | ip-address } timer keepalive keepalive hold holdtime
Use either approach.
By default, the keepalive interval is 60 seconds, and hold time is 180 seconds.
The timer command takes effect for new BGP sessions and does not affect existing sessions.
If you modify the timers with the peer timer command, BGP immediately closes the existing BGP session and creates a new session to the peer by using the new settings.
To configure the keepalive interval and hold time (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } timer keepalive keepalive hold holdtime
A BGP router sends an update message to its peers when a route is changed. If the route changes frequently, the BGP router keeps sending updates for the same route, resulting route flapping. To prevent this situation, perform this task to configure the interval for sending updates for the same route to a peer or peer group.
To configure the interval for sending the same update to a peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Configure the interval for sending updates for the same route to a peer or peer group.
peer { group-name | ip-address } route-update-interval interval
By default, the interval is 15 seconds for an IBGP peer and 30 seconds for an EBGP peer.
To configure the interval for sending the same update to a peer or peer group (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } route-update-interval interval
To establish an EBGP connection, two routers must have a direct physical link. If no direct link is available, you must use the peer ebgp-max-hop command to enable BGP to establish an EBGP session over multiple hops and specify the maximum hops.
If directly connected EBGP peers use loopback interfaces to establish a BGP session, you do not need to configure the peer ebgp-max-hop command.
To enable BGP to establish an indirect EBGP session (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Enable BGP to establish an EBGP session to an indirectly-connected peer or peer group and specify the maximum hop count.
peer { group-name | ip-address } ebgp-max-hop [ hop-count ]
By default, BGP cannot establish an EBGP session to an indirectly-connected peer or peer group.
To enable BGP to establish an indirect EBGP session (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } ebgp-max-hop [ hop-count ]
When the link to a directly-connected EBGP peer goes down, the router does not reestablish a session to the peer until the hold time timer expires. This feature enables BGP to immediately recreate the session in that situation. When this feature is disabled, route flapping does not affect EBGP session state.
To enable immediate reestablishment of direct EBGP connections:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable immediate reestablishment of direct EBGP connections upon link failure.
ebgp-interface-sensitive
By default, this feature is enabled.
BGP supports 4-byte AS numbers. The 4-byte AS number occupies four bytes, in the range of 1 to 4294967295. By default, a device sends an Open message to the peer device for session establishment. The Open message indicates that the device supports 4-byte AS numbers. If the peer device does not support 4-byte AS numbers (supports only 2-byte AS numbers), the session cannot be established. To resolve this issue, enable the 4-byte AS number suppression function. The device then sends an Open message to inform the peer that it does not support 4-byte AS numbers, so the BGP session can be established.
If the peer device supports 4-byte AS numbers, do not enable the 4-byte AS number suppression function. Otherwise, the BGP session cannot be established.
To enable 4-byte AS number suppression (IPv4):
Step
Remarks
N/A
2.     Enter BGP view or BGP-VPN instance view.
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Enable 4-byte AS number suppression.
peer { group-name | ip-address } capability-advertise suppress-4-byte-as
By default, 4-byte AS number suppression is not enabled.
To enable 4-byte AS number suppression (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } capability-advertise suppress-4-byte-as
You can enable MD5 authentication to enhance security in the following ways:
·           Perform MD5 authentication when establishing TCP connections. Only the two parties that have the same password configured can establish TCP connections.
·           Perform MD5 calculation on TCP packets to avoid modification to the encapsulated BGP packets.
To enable MD5 authentication for BGP peers (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
3.     Enable MD5 authentication for BGP peers.
peer { group-name | ip-address } password { cipher | simple } password
By default, MD5 authentication is disabled.
To enable MD5 authentication for BGP peers (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
peer { group-name | ipv6-address } password { cipher | simple } password
If multiple BGP routes with the same AS_PATH, ORIGIN, LOCAL_PREF, and MED attributes to a destination exist, you can use the balance command to enable load balancing over these ECMP routes and specify the maximum number of ECMP routes.
To configure the maximum number of ECMP routes (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure the maximum number of ECMP routes for load balancing.
balance number
By default, load balancing is disabled.
To configure the maximum number of ECMP routes (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
balance number
This task enables you to temporarily tear down the BGP session to a specific peer or peer group so that you can perform network upgrade and maintenance without needing to delete and reconfigure the peer or peer group. To recover the session, execute the undo peer ignore command.
To disable BGP to establish a session to a peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Disable BGP to establish a session to a peer or peer group.
peer { group-name | ip-address } ignore
By default, BGP can establish a session to a peer or peer group.
To disable BGP to establish a session to a peer or peer group (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } ignore
By default, BGP can establish a session to a peer.
After you modify the route selection policy (for example, modify the preferred value), you must reset BGP sessions to apply the new policy. The reset operation tears down and re-establishes BGP sessions.
To avoid tearing down BGP sessions, you can use one of the following soft-reset methods to apply the new policy:
·           Enabling route-refresh—The BGP router advertises a route-refresh message to the specified peer, and the peer resends its routing information to the router. After receiving the routing information, the router filters the routing information by using the new policy.
This method requires that both the local router and the peer support route refresh.
·           Saving updates—Use the peer keep-all-routes command to save all route updates from the specified peer. After modifying the route selection policy, filter routing information by using the new policy.
This method does not require that the local router and the peer support route refresh but it uses more memory resources to save routes.
·           Manual soft-reset—Use the refresh bgp command to enable BGP to send local routing information or advertise a route-refresh message to the specified peer so the peer resends its routing information. After receiving the routing information, the router filters the routing information by using the new policy.
To enable BGP route refresh for a peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Enable BGP route refresh for a peer or peer group.
·       Enable BGP route refresh for the specified peer or peer group:
peer { group-name | ip-address } capability-advertise route-refresh
·       Enable BGP route refresh and multi-protocol extension capability for the specified peer or peer group:
undo peer { group-name | ip-address } capability-advertise conventional
By default, BGP route refresh is enabled.
To enable BGP route refresh for a peer or peer group (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } capability-advertise route-refresh
undo peer { group-name | ipv6-address } capability-advertise conventional
Saving updates
To save all route updates from the specified peer or peer group (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Save all route updates from the peer or peer group.
peer { group-name | ip-address } keep-all-routes
By default, the routes are not saved.
This command takes effect only for the routes received after this command is executed.
To save all route updates from the specified peer or peer group (IPv6):
Step
Remarks
N/A
2.     Enter BGP view
bgp as-number
N/A
N/A
peer { group-name | ipv6-address } keep-all-routes
Configuring manual soft-reset
To configure manual soft-reset (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
4.     Return to user view.
return
N/A
5.     Perform manual soft-reset.
refresh bgp { ip-address | all | external | group group-name | internal } { export | import } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
N/A
To configure manual soft-reset (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
return
N/A
refresh bgp { ipv6-address | all | external | group group-name | internal } { export | import } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
N/A
Memory usage includes the following levels of thresholds: normal, level 1, level 2, and level 3. When level 2 threshold is reached, BGP tears down an EBGP session to release memory resources periodically until the memory usage is exempt from level 2 threshold. You can configure this feature to avoid tearing down the BGP session with a specific EBGP peer when memory usage reaches level 2 threshold.
For more information about thresholds, see Fundamentals Configuration Guide.
To configure BGP to protect EBGP peer or peer group when the memory usage reaches level 2 threshold (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Configure BGP to protect EBGP peer or peer group when the memory usage reaches level 2 threshold.
peer { group-name | ip-address } low-memory-exempt
By default, BGP tears down an EBGP session to release memory resources periodically when level 2 threshold is reached.
To configure BGP to protect EBGP peer or peer group when the memory usage reaches level 2 threshold (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
peer { group-name | ipv6-address } low-memory-exempt
In a large network, the number of BGP connections is huge and BGP configuration and maintenance are complicated. To simply BGP configuration, you can use the peer group, community, route reflector, and confederation features as needed. For more information about configuring peer groups, see "Configuring a BGP peer group."
By default, a router does not advertise the COMMUNITY or extended community attribute to its peers or peer groups. When the router receives a route carrying the COMMUNITY or extended community attribute, it removes the attribute before advertising the route to other peers or peer groups.
Perform this task to enable a router to advertise the COMMUNITY or extended community attribute to its peers for route filtering and control. You can also reference a routing policy to add or modify the COMMUNITY or extended community attribute for specific routes. For more information about routing policy, see "Configuring routing policies."
To configure BGP community (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Advertise the COMMUNITY or extended community attribute to a peer or peer group.
·       Advertise the COMMUNITY attribute to a peer or peer group:
peer { group-name | ip-address } advertise-community
·       Advertise the extended community attribute to a peer or peer group:
peer { group-name | ip-address } advertise-ext-community
By default, the COMMUNITY or extended community attribute is not advertised.
5.     (Optional.) Apply a routing policy to routes advertised to a peer or peer group.
By default, no routing policy is applied.
To configure BGP community (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address } advertise-community
peer { group-name | ipv6-address } advertise-ext-community
To reduce IBGP connections in an AS where many BGP routers exist, you can group those routers into a cluster, and configure one of them as a route reflector and others as clients. The route reflector reflects routing information between the clients.
To improve availability, you can specify multiple route reflectors for a cluster. The route reflectors in the cluster must have the same cluster ID to avoid routing loops.
After receiving a route from a peer, the route reflector adds the ORIGINATOR_ID attribute to the route and then reflects the route. The ORIGINATOR_ID identifies the router ID of the originating peer. When a BGP router receives the route, it compares the ORIGINATOR_ID of the route with the local router ID. If they are the same, the BGP router discards the route to avoid routing loops.
In some special networks, a BGP router must ignore the ORIGINATOR_ID attribute so it can learn the routes in which the ORIGINATOR_ID is the same as the local router ID. For example, in the network illustrated in Figure 14, the sites connected to the PE belong to different VPNs, and some subnets need to communicate across VPNs. To implement inter-VPN communication, you need to perform the following configurations on the PE:
·           Configure different BGP router IDs for different VPN instances, establish an IBGP peer relationship between the VPN instances, and configure one VPN instance as the route reflector.
·           Configure a routing policy to control IBGP route advertisements between VPNs.
If the PE compares the ORIGINATOR_ID with the local router ID, a route from a VPN reflected by the route reflector is discarded by another VPN, so routes cannot be advertised between VPNs. To solve the problem, you can configure the BGP router to ignore the ORIGINATOR_ID attribute.
Figure 13 Network diagram for ORIGINATOR_ID igoration
When a route reflector is configured, and the clients of a route reflector are fully meshed, route reflection is unnecessary because it consumes more bandwidth resources. You can disable route reflection by executing the undo reflect between-clients command.
To configure BGP route reflection (IPv4):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
N/A
4.     Configure the router as a route reflector and specify a peer or peer group as its client.
peer { group-name | ip-address } reflect-client
By default, no route reflector or client is configured.
5.     Enable route reflection between clients.
By default, route reflection between clients is enabled.
6.     (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its own router ID as the cluster ID.
7.     Return to BGP view or BGP-VPN view.
N/A
8.     (Optional.) Ignore the ORIGINATOR_ID attribute of BGP routes.
peer { group-name | ip-address } ignore-originatorid
By default, a BGP router does not ignore the ORIGINATOR_ID attribute of BGP routes.
After this command is executed, the CLUSTER_LIST attribute of BGP routes is also ignored.
Use this command only when necessary. If routing loops cannot be avoided, do not execute this command.
To configure a BGP route reflector (IPv6):
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
peer { group-name | ipv6-address } reflect-client
N/A
peer { group-name | ipv6-address } ignore-originatorid
BGP confederation provides another way to reduce IBGP connections in an AS.
A confederation contains sub-ASs. In each sub-AS, IBGP peers are fully meshed. Sub-ASs establish EBGP connections in between.
After you split an AS into multiple sub-ASs, configure a router in a sub-AS as follows:
1.      Enable BGP and specify the AS number of the router. For more information, see "Enabling BGP."
2.      Specify the confederation ID. From an outsider’s perspective, the sub-ASs of the confederation is a single AS, which is identified by the confederation ID.
3.      If the router needs to establish EBGP connections to other sub-ASs, you must specify the peering sub-ASs in the confederation.
A confederation can contain a maximum of 32 sub-ASs. The AS number of a sub-AS is effective only in the confederation.
To configure a BGP confederation:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Configure a confederation ID.
confederation id as-number
By default, no confederation ID is configured.
4.     Specify peering sub-ASs in the confederation.
By default, no peering sub-AS is specified.
Configuring confederation compatibility
If any routers in the confederation do not comply with RFC 3065, enable confederation compatibility to allow the router to work with those routers.
To configure confederation compatibility:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable confederation compatibility.
confederation nonstandard
By default, confederation compatibility is disabled.
Configuring BGP GR
Graceful Restart (GR) ensures continuous forwarding when BGP restarts or an active/standby switchover occurs. GR defines the following types of GR-capable devices:
·           GR Restarter—Performs GR upon a BGP restart or active/standby switchover.
·           GR Helper—Helps the GR Restarter to complete the GR process.
A device can act as a GR Restarter and GR Helper at the same time.
BGP GR works as follows:
1.      The BGP GR Restarter and helper exchange Open messages for GR capability negotiation. If both parties have the GR capability, they establish a GR-capable session. The GR Restarter sends the GR timer set by the graceful-restart timer restart command to the GR Helper in an Open message.
2.      When an active/standby switchover occurs or BGP restarts, the GR Restarter does not remove existing BGP routes, and it still uses these routes for packet forwarding. The GR Helper marks all routes learned from the GR Restarter as stale instead of deleting them, and it still uses these routes for packet forwarding. During the GR process, packet forwarding is not interrupted.
3.      After the active/standby switchover or BGP restart completes, the GR Restarter reestablishes a BGP session with the GR Helper. If the BGP session fails to be established within the GR timer advertised by the GR Restarater, the GR Helper removes the stale routes.
4.      If the BGP session is established, routing information is exchanged for the GR Restarter to retrieve route entries and for the GR Helper to recover stale routes. You can use the graceful-restart timer wait-for-rib command to configure the time for the local router to wait for the End-Of-RIB (End of Routing-Information-Base) marker, and control the route convergence speed. If routing information exchange is not completed within the time, the GR Restarter does not receive new routes. Instead, the GR Restarter updates its routing table and forwarding table with the BGP routes already learned to complete BGP route convergence. The GR Helper removes the stale routes.
Follow these guidelines when you configure BGP GR:
·           The End-Of-RIB indicates the end of route updates.
·           The maximum time to wait for the End-of-RIB marker configured on the local end is not advertised to the peer. It controls the time for the local end to receive updates from the peer.
Perform the following configuration on the GR Restarter and GR Helper.
To configure BGP GR:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable GR capability for BGP.
graceful-restart
By default, GR capability is disabled for BGP.
4.     Configure the GR timer.
The default setting is 150 seconds.
The time that a peer waits to reestablish a session must be less than the hold time.
5.     Configure the maximum time to wait for the End-of-RIB marker.
The default setting is 180 seconds.
Enabling trap
After trap is enabled for BGP, BGP generates Level-4 traps to report important events. The generated traps are sent to the information center of the device. The output rules of the traps (whether to output the traps and where to output) are determined according to the information center configuration. For information center configuration, see Network Management and Monitoring Configuration Guide.
To enable trap:
Step
Remarks
1.     Enter system view.
N/A
2.     Enable trap for BGP.
snmp-agent trap enable bgp
By default, trap for BGP is enabled.
For more information about this command, see Network Management and Monitoring Configuration Guide.
Enabling logging of session state changes
Perform this task to enable BGP to log BGP session establishment and disconnection events. To view the log information, use the display bgp peer ipv4 log-info command.
To enable the logging of session state changes:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Enable the logging of session state changes globally.
log-peer-change
By default, logging of session state changes is enabled globally.
Configuring BFD for BGP
IMPORTANT:
If you have enabled GR, use BFD with caution because BFD might detect a failure before the system performs GR, which will result in GR failure. If you have enabled both BFD and GR for BGP, do not disable BFD during a GR process to avoid GR failure.
BGP maintains neighbor relationships based on the keepalive timer and hold timer in seconds. It requires that the hold time must be at least three times the keepalive interval. This mechanism makes link failure detection slow. Once a failure occurs on a high-speed link, a large quantity of packets will be dropped before routing convergence completes. BFD for BGP can solve this problem by fast detecting link failures to reduce convergence time.
For more information about BFD, see High Availability Configuration Guide.
Before you can enable BFD for the BGP peer, establish a BGP session between the local router and the peer.
To enable BFD for a BGP peer (IPv4):
Step
Remarks
N/A
2.     Enter BGP view or BGP-VPN view.
·       Enter BGP view:
bgp as-number
·       Enter BGP-VPN view:
a.   bgp as-number
b.   ip vpn-instance vpn-instance-name
N/A
3.     Enable BFD to detect the link to the specified BGP peer.
peer ip-address bfd
By default, BFD is not enabled.
To enable BFD for a BGP peer (IPv6):
Step
Remarks
N/A
·       Enter BGP view:
bgp as-number
a.   bgp as-number
N/A
3.     Enable BFD to detect the link to the specified IPv6 BGP peer.
peer ipv6-address bfd
Configuring 6PE
IPv6 provider edge (6PE) is a transition technology that uses MPLS to connect sparsely populated IPv6 networks through an existing IPv4 backbone network. It is an efficient solution for ISP IPv4/MPLS networks to provide IPv6 traffic switching capability.
Figure 14 Network diagram for 6PE
6PE mainly performs the following operations:
·           6PE assigns a label to IPv6 routing information received from a CE router, and sends the labeled IPv6 routing information to the peer 6PE device through an MP-BGP session. The peer 6PE device then forwards the IPv6 routing information to the attached customer site.
·           6PE provides tunnels over the IPv4 backbone so the IPv4 backbone can forward packets for IPv6 networks. The tunnels can be GRE tunnels or MPLS LSPs.
·           Upon receiving an IPv6 packet, 6PE adds an inner tag (corresponding to the IPv6 packet) and then an outer tag (corresponding to the public network tunnel) to the IPv6 packet. Devices in the IPv4 backbone network forwards the packet based on the outer tag. When the peer 6PE device receives the packet, it removes the outer and inner tags and forwards the original IPv6 packet to the attached customer site.
To implement exchange of IPv6 routing information, you can configure IPv6 static routing, an IPv6 IGP protocol, or IPv6 BGP between CE and 6PE devices.
For more information about MPLS, CE, and P (Provider), see MPLS Configuration Guide. For more information about GRE, see Layer 3IP Services Configuration Guide.
Configuring basic 6PE
Before you configure 6PE, complete the following tasks:
·           Establish tunnels in the IPv4 backbone network (see Layer 3—IP Services Configuration Guide).
·           Configure basic MPLS on 6PE devices (see MPLS Configuration Guide).
·           Configure BGP on 6PE devices so that they can advertise tagged IPv6 routing information through BGP sessions. The following describes only BGP configurations on 6PE devices.
To configure basic 6PE:
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
3.     Specify a 6PE peer or peer group and its AS number.
peer { group-name | ip-address } as-number as-number
No 6PE peer is specified by default.
4.     Enter BGP IPv6 unicast instance view.
ipv6-family [ unicast ]
N/A
5.     Enable BGP to exchange IPv6 unicast routing information with the 6PE peer or peer group.
peer { group-name | ip-address } enable
This function is disabled by default.
6.     Enable BGP to exchange labeled IPv6 routes with the 6PE peer or peer group.
peer { group-name | ip-address } label-route-capability
Configuring optional 6PE capabilities
Step
Remarks
N/A
2.     Enter BGP view.
bgp as-number
N/A
N/A
4.     Advertise COMMUNITY attribute to the 6PE peer or peer group.
By default, the COMMUNITY attribute is not advertised.
5.     Advertise extended community attribute to the 6PE peer or peer group.
By default, the extended community attribute is not advertised.
6.     Allow the local AS number to appear in routes from the 6PE peer or peer group and specify the repeat times.
By default, the local AS number is not allowed to appear in routes from the 6PE peer or peer group.
7.     Specify an AS path list to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ip-address } as-path-acl as-path-acl-number { export | import }
By default, no AS path list is specified.
8.     Specify an IPv6 ACL to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ip-address } filter-policy acl6-number { export | import }
By default, no ACL is specified.
9.     Specify an IPv6 prefix list to filter routes advertised to or received from the 6PE peer or peer group.
peer { group-name | ip-address } prefix-list ipv6-prefix-name { export | import }
By default, no IPv6 prefix list is specified.
10.   Specify a routing policy to filter routes advertised to or received from the 6PE peer or peer group.
By default, no routing policy is specified.
11.   Advertise a default route to the 6PE peer or peer group.
12.   Save all routes from the 6PE peer or peer group.
By default, routes from a peer or peer group are not saved.
13.   Configure BGP updates sent to the 6PE peer or peer group to carry only the public AS number.
14.   Specify the maximum number of routes that BGP can receive from the 6PE peer or peer group.
By default, the number of routes that a router can receive from the 6PE peer or peer group is not limited.
15.   Specify a preferred value for routes received from the 6PE peer or peer group.
By default, the preferred value is 0.
16.   Configure the device as a route reflector and the 6PE peer or peer group as a client.
17.   Return to user view.
return
N/A
18.   Display information about the 6PE peer or peer group.
display bgp peer ipv6 [ unicast ] [ group-name log-info | ip-address { log-info | verbose } | verbose ]
Available in any view.
19.   Display routing information advertised to or received from the 6PE peer or peer group.
display bgp routing-table ipv6 [ unicast ] peer ip-address { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
20.   Perform soft reset on the inbound or outbound BGP 6PE connection.
refresh bgp ip-address { export | import } ipv6 [ unicast ]
Available in user view.
21.   Reset a BGP 6PE connection.
reset bgp ip-address ipv6 [ unicast ]
Displaying and maintaining BGP
Execute display commands in any view and reset commands in user view (IPv4).
Display BGP IPv4 unicast peer group information.
display bgp group ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name ]
Display BGP IPv4 unicast peer or peer group information.
display bgp peer ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ip-address { log-info | verbose } | group-name log-info | verbose ]
Display BGP IPv4 unicast routing information.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ { mask | mask-length } [ longest-match ] ] ]
Display BGP IPv4 unicast route advertisement information.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] network-address [ mask | mask-length ] advertise-info
Display BGP IPv4 unicast routing information sent to/received from the specified BGP peer.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] peer ip-address { advertised-routes | received-routes } [ network-address [ mask | mask-length ] | statistic ]
Display BGP IPv4 unicast routing statistics.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] statistic
Display BGP IPv4 unicast routing information matching the specified AS path list.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl as-path-acl-number
Display BGP IPv4 unicast routing information matching the specified BGP community list.
display bgp routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
Display dampened BGP IPv4 unicast routing information.
display bgp routing-table dampened ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP dampening parameter information.
display bgp dampening parameter ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP IPv4 unicast routing flap statistics.
display bgp routing-table flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ { mask | mask-length } [ longest-match ] ] | as-path-acl as-path-acl-number ]
Display information about routes advertised by the network command and shortcut routes configured by the network short-cut command.
display bgp network ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP path attribute information.
display bgp paths [ as-regular-expression ]
Reset all BGP sessions.
reset bgp all
Reset IPv4 unicast BGP sessions.
reset bgp { as-number | ip-address | all | external | group group-name | internal } ipv4 [ unicast ] [ vpn-instance vpn-instance-name ]
Clear dampened BGP IPv4 unicast routing information and release suppressed routes.
reset bgp dampening ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ mask | mask-length ] ]
Clear BGP IPv4 unicast route flap information.
reset bgp flap-info ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address [ mask | mask-length ] | as-path-acl as-path-acl-number | peer peer-address ]
Execute display commands in any view and reset commands in user view (IPv6).
Display BGP IPv6 unicast peer group information.
display bgp group ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ group-name ]
Display BGP IPv6 unicast peer or peer group information.
display bgp peer ipv6 [ unicast ] [ group-name log-info | ip-address { log-info | verbose } | ipv6-address { log-info | verbose } | verbose ]
display bgp peer ipv6 [ unicast ] vpn-instance vpn-instance-name [ group-name log-info | ipv6-address { log-info | verbose } | verbose ]
Display BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length [ advertise-info ] ]
Display BGP IPv6 unicast routing information sent to/received from the specified BGP peer.
display bgp routing-table ipv6 [ unicast ] peer { ip-address | ipv6-address } { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
display bgp routing-table ipv6 [ unicast ] vpn-instance vpn-instance-name peer ipv6-address { advertised-routes | received-routes } [ network-address prefix-length | statistics ]
Display BGP IPv6 unicast routing statistics.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] statistics
Display BGP IPv6 unicast routing information matching the specified AS path list.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] as-path-acl as-path-acl-number
Display BGP IPv6 unicast routing information matching the specified BGP community list.
display bgp routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number }
Display dampened BGP IPv6 unicast routing information.
display bgp routing-table dampened ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
display bgp dampening parameter ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
Display BGP IPv6 unicast routing flap statistics.
display bgp routing-table flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length | as-path-acl as-path-acl-number ]
Display the incoming label of BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] inlabel
Display the outgoing label of BGP IPv6 unicast routing information.
display bgp routing-table ipv6 [ unicast ] outlabel
display bgp network ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
Reset IPv6 unicast BGP sessions.
reset bgp { as-number | ipv6-address | all | external | group group-name | internal } ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]
Clear dampened BGP IPv6 unicast routing information and release suppressed routes.
reset bgp dampening ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ network-address prefix-length ]
Clear BGP IPv6 unicast route flap information.
reset bgp flap-info ipv6 [ unicast ] [ vpn-instance vpn-instance-name ]  [ network-address prefix-length | as-path-acl as-path-acl-number | peer ipv6-address ]
IPv4 BGP configuration examples
By default, Ethernet, VLAN, and aggregate interfaces are down. To configure such an interface, bring the interface up by executing the undo shutdown command.
Basic BGP configuration example
Network requirements
In Figure 16, run EBGP between Switch A and Switch B, and run IBGP between Switch B and Switch C so that Switch C can access the network 8.1.1.0/24 connected to Switch A.
Figure 15 Network diagram
Configuration considerations
To prevent route flapping caused by port state changes, this example uses loopback interfaces to establish IBGP connections. Because loopback interfaces are virtual interfaces, use the peer connect-interface command to specify the loopback interface as the source interface for establishing BGP connections. Enable OSPF in AS 65009 to make sure that Switch B can communicate with Switch C through loopback interfaces.
The EBGP peers, Switch A and Switch B (usually belong to different carriers), are located in different ASs. Typically, their loopback interfaces are not reachable to each other, so directly connected interfaces are used for establishing BGP sessions. To enable Switch C to access the network 8.1.1.0/24 connected directly to Switch A, inject network 8.1.1.0/24 to the BGP routing table of Switch A.
Configuration procedure
1.      Configure IP addresses for interfaces. (Details not shown.)
2.      Configure IBGP:
# Configure Switch B.
[SwitchB] bgp 65009
[SwitchB-bgp] router-id 2.2.2.2
[SwitchB-bgp] peer 3.3.3.3 as-number 65009
[SwitchB-bgp] peer 3.3.3.3 connect-interface loopback 0
[SwitchB-bgp] ipv4-family unicast
[SwitchB-bgp-ipv4] peer 3.3.3.3 enable
[SwitchB-bgp-ipv4] quit
[SwitchB-bgp] quit
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 9.1.1.1 0.0.0.255
[SwitchB-ospf-1] quit
# Configure Switch C.
[SwitchC] bgp 65009
[SwitchC-bgp] router-id 3.3.3.3
[SwitchC-bgp] peer 2.2.2.2 as-number 65009
[SwitchC-bgp] peer 2.2.2.2 connect-interface loopback 0
[SwitchC-bgp] ipv4-family unicast
[SwitchC-bgp-ipv4] peer 2.2.2.2 enable
[SwitchC-bgp-ipv4] quit
[SwitchC-bgp] quit
[SwitchC] ospf 1
[SwitchC-ospf-1] area 0
[SwitchC-ospf-1] quit
 BGP local router ID : 3.3.3.3
 Local AS number : 65009
 Total number of peers : 1                 Peers in established state : 1
  2.2.2.2              65009        2        2    0       0 00:00:13 Established
The output shows that Switch C has established an IBGP peer relationship with Switch B.
3.      Configure EBGP:
# Configure Switch A.
[SwitchA] bgp 65008
[SwitchA-bgp] router-id 1.1.1.1
[SwitchA-bgp] peer 3.1.1.1 as-number 65009
[SwitchA-bgp] ipv4-family unicast
[SwitchA-bgp-ipv4] peer 3.1.1.1 enable
[SwitchA-bgp-ipv4] network 8.1.1.0 24
[SwitchA-bgp-ipv4] quit
[SwitchA-bgp] quit
[SwitchB] bgp 65009
[SwitchB-bgp] peer 3.1.1.2 as-number 65008
[SwitchB-bgp-ipv4] peer 3.1.1.2 enable
[SwitchB-bgp] quit
# Display BGP peer information on Switch B.
 BGP local router ID : 2.2.2.2
 Total number of peers : 2                 Peers in established state : 2
  3.3.3.3              65009        4        4    0       0 00:02:49 Established
  3.1.1.2              65008        2        2    0       0 00:00:05 Established
The output shows that Switch B has established an IBGP peer relationship with Switch C and an EBGP peer relationship with Switch A.
# Display the BGP routing table on Switch A.
 Total number of routes: 1
 Status codes: * - valid, > - best, d - damped, h - history,
               s - suppressed, S - Stale, i - internal, e - external
  >  8.1.1.0/24         8.1.1.1         0                     0       i
# Display the BGP routing table on Switch B.
  >e 8.1.1.0/24         3.1.1.2         0                     0       65008i
# Display the BGP routing table on Switch C.
   i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
The outputs show that Switch A has learned no route to AS 65009, and Switch C has learned network 8.1.1.0, but the next hop 3.1.1.2 is unreachable. As a result, the route is invalid.
4.      Redistribute direct routes:
Configure BGP to redistribute direct routes on Switch B, so that Switch A can obtain the route to 9.1.1.0/24, and Switch C can obtain the route to 3.1.1.0/24.
[SwitchB] bgp 65009
[SwitchB-bgp-ipv4] import-route direct
[SwitchB-bgp] quit
 Total number of routes: 4
  >e 2.2.2.2/32         3.1.1.1         0                     0       65009?
   e 3.1.1.0/24         3.1.1.1         0                     0       65009?
  >e 9.1.1.0/24         3.1.1.1         0                     0       65009?
Two routes, 2.2.2.2/32 and 9.1.1.0/24, have been added in Switch A’s routing table.
   i 2.2.2.2/32         2.2.2.2         0          100        0       ?
  >i 3.1.1.0/24         2.2.2.2         0          100        0       ?
  >i 8.1.1.0/24         3.1.1.2         0          100        0       65008i
  >i 9.1.1.0/24         2.2.2.2         0          100        0       ?
The output shows that the route 8.1.1.0 becomes valid with the next hop as Switch A.
# Ping 8.1.1.1 on Switch C.
[SwitchC] ping 8.1.1.1
PING 8.1.1.1 (8.1.1.1): 56 data bytes, press CTRL_C to break
--- 8.1.1.1 ping statistics ---
round-trip min/avg/max/stddev = 3.000/4.800/10.000/2.638 ms
BGP and IGP route redistribution configuration example
As shown in Figure 17, all devices of company A belong to AS 65008, and all devices of company B belong to AS 65009. AS 65008 and AS 65009 are connected through Switch A and Switch B. It is required that Switch A can access network 9.1.2.0/24 in AS 65009, and Switch C can access network 8.1.1.0/24 in AS 65008.
Figure 16 Network diagram
Configure BGP to redistribute routes from OSPF on Switch B, so Switch A can obtain the route to 9.1.2.0/24. Configure OSPF to redistribute routes from BGP on Switch B, so Switch C can obtain the route to 8.1.1.0/24.
2.      Configure OSPF:
Enable OSPF in AS 65009, so Switch B can obtain the route to 9.1.2.0/24.
[SwitchB] ospf 1
[SwitchC] ospf 1
3.      Configure the EBGP connection:
Configure the EBGP connection and inject network 8.1.1.0/24 to the BGP routing table of Switch A, so that Switch B can obtain the route to 8.1.1.0/24.
[SwitchA] bgp 65008
[SwitchA-bgp] quit
[SwitchB] bgp 65009
4.      Configure BGP and IGP route redistribution:
# Configure route redistribution between BGP and OSPF on Switch B.
[SwitchB-bgp-ipv4] import-route ospf 1
[SwitchB-bgp] quit
[SwitchB] ospf 1
 Total number of routes: 3
  >e 3.3.3.3/32         3.1.1.1         1                     0       65009?
  >e 9.1.2.0/24         3.1.1.1         1                     0       65009?
# Display the OSPF routing table on Switch C.
                   Routing Tables
 Routing for Network
 9.1.1.0/24         1        Transit 9.1.1.2         3.3.3.3         0.0.0.0
 2.2.2.2/32         1        Stub    9.1.1.1         2.2.2.2         0.0.0.0
 Routing for ASEs
 Destination        Cost     Type    Tag         NextHop         AdvRouter
 8.1.1.0/24         1        Type2   1           9.1.1.1         2.2.2.2
 Total Nets: 3
 Intra Area: 2  Inter Area: 0  ASE: 1  NSSA: 0
# Use ping for verification.
PING 9.1.2.1 (9.1.2.1) from 8.1.1.1: 56 data bytes, press CTRL_C to break
--- 9.1.2.1 ping statistics ---
round-trip min/avg/max/stddev = 2.000/8.000/12.000/3.406 ms
PING 8.1.1.1 (8.1.1.1) from 9.1.2.1: 56 data bytes
round-trip min/avg/max/stddev = 3.000/4.400/9.000/2.332 ms
BGP route summarization configuration example
As shown in Figure 18, run EBGP between Switch C and Switch D, so the internal network and external network can communicate with each other.
In AS 65106, configure static routing between Switch A and Switch B, configure OSPF between Switch B and Switch C, and configure OSPF to redistribute static routes, so the devices in the internal network can communicate with each other.
Configure route summarization on Switch C so BGP advertises a summary route instead of the specific networks 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 to Switch D.
Figure 17 Network diagram
2.      Configure static routing between Switch A and Switch B:
# Configure a default route with the next hop 192.168.212.1 on Switch A.
[SwitchA] ip route-static 0.0.0.0 0 192.168.212.1
# Configure static routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 with the same next hop 192.168.212.161 on Switch B.
[SwitchB] ip route-static 192.168.64.0 24 192.168.212.161
[SwitchB] ip route-static 192.168.74.0 24 192.168.212.161
[SwitchB] ip route-static 192.168.99.0 24 192.168.212.161
3.      Configure OSPF between Switch B and Switch C and configure OSPF on Switch B to redistribute static routes:
# Configure OSPF to advertise the local network and enable OSPF to redistribute static routes on Switch B.
[SwitchB] ospf
[SwitchB-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[SwitchB-ospf-1] import-route static
# Configure OSPF to advertise the local networks on Switch C.
[SwitchC] ospf
[SwitchC-ospf-1-area-0.0.0.0] network 172.17.100.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 10.220.2.0 0.0.0.255
# Display the IP routing table on Switch C.
[SwitchC] display ip routing-table protocol ospf
Summary Count : 5
Summary Count : 3
192.168.64.0/24     OSPF   150  1            172.17.100.1    Vlan100
192.168.74.0/24     OSPF   150  1            172.17.100.1    Vlan100
192.168.99.0/24     OSPF   150  1            172.17.100.1    Vlan100
Summary Count : 2
10.220.2.0/24       OSPF   10   1            10.220.2.16     Vlan200
172.17.100.0/24     OSPF   10   1            172.17.100.2    Vlan100
The output shows that Switch C has learned routes to 192.168.64.0/24, 192.168.99.0/24, and 192.168.64.0/18 through OSPF.
4.      Configure BGP between Switch C and Switch D and configure BGP on Switch C to redistribute OSPF routes:
# On Switch C, enable BGP, specify Switch D as an EBGP peer, and configure BGP to redistribute OSPF routes.
[SwitchC] bgp 65106
[SwitchC-bgp] peer 10.220.2.217 as-number 64631
[SwitchC-bgp-ipv4] peer 10.220.2.217 enable
[SwitchC-bgp-ipv4] import-route ospf
# Enable BGP, and configure Switch C as an EBGP peer on Switch D.
[SwitchD] bgp 64631
[SwitchD-bgp] router-id 4.4.4.4
[SwitchD-bgp] peer 10.220.2.16 as-number 65106
[SwitchD-bgp] ipv4-family unicast
[SwitchD-bgp-ipv4] peer 10.220.2.16 enable
[SwitchD-bgp-ipv4] quit
[SwitchD-bgp] quit
# Display the IP routing table on Switch D.
[SwitchD] display ip routing-table protocol bgp
Summary Count : 3
Summary Count : 3
192.168.64.0/24     BGP    255  1            10.220.2.16     Vlan200
192.168.74.0/24     BGP    255  1            10.220.2.16     Vlan200
192.168.99.0/24     BGP    255  1            10.220.2.16     Vlan200
Summary Count : 0
The output shows that Switch D has learned routes to 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 through BGP.
After the above configurations, ping hosts on networks 192.168.74.0/24, 192.168.99.0/24, and 192.168.64.0/18 from Switch D. The ping operations succeed.
5.      Configure route summarization on Switch C to summarize 192.168.64.0/24, 192.168.74.0/24, and 192.168.99.0/24 into a single route 192.168.64.0/18 on Switch C, and disable advertisement of the specific routes.
[SwitchC-bgp-ipv4] aggregate 192.168.64.0 18 detail-suppressed
[SwitchC-bgp] quit
# Display IP routing table on Switch C.
[SwitchC] display ip routing-table | include 192.168
192.168.64.0/18     BGP    130  0            127.0.0.1       NULL0
The output shows that Switch C has a summary route 192.168.64.0/18 with the output interface Null 0.
# Display IP routing table on Switch D.
Summary Count : 1
Summary Count : 1
192.168.64.0/18     BGP    255  0            10.220.2.16     Vlan200
Summary Count : 0
The output shows that Switch D has only one route 192.168.64.0/18 to AS 65106.
After the above configurations, ping the hosts on networks 192.168.64.0/24, 192.168.74.0/24 and 192.168.99.0/24 from Switch D. The ping operations succeed.
BGP load balancing configuration example
As shown in Figure 19, run EBGP between Switch A and Switch B and between Switch A and Switch C. Run IBGP between Switch B and Switch C. Configure load balancing over the two EBGP links on Switch A.
Figure 18 Network diagram
On Switch A, establish EBGP connections with Switch B and Switch C. Configure BGP to advertise network 8.1.1.0/24 to Switch B and Switch C, so that Switch B and Switch C can access the internal network connected to Switch A.
On Switch B, establish an EBGP connection with Switch A and an IBGP connection with Switch C. Configure BGP to advertise network 9.1.1.0/24 to Switch A, so that Switch A can access the intranet through Switch B. Configure a static route to interface loopback 0 on Switch C (or use a routing protocol like OSPF) to establish the IBGP connection.
On Switch C, establish an EBGP connection with Switch A and an IBGP connection with Switch B. Configure BGP to advertise network 9.1.1.0/24 to Switch A, so that Switch A can access the intranet through Switch C. Configure a static route to interface loopback 0 on Switch B (or use another protocol like OSPF) to establish the IBGP connection.
Configure load balancing on Switch A.
2.      Configure BGP connections:
[SwitchA] bgp 65008
[SwitchA-bgp] peer 3.1.2.1 as-number 65009
[SwitchA-bgp-ipv4] peer 3.1.2.1 enable
[SwitchA-bgp-ipv4] network 8.1.1.1 24
[SwitchA-bgp] quit
[SwitchB] bgp 65009
[SwitchB-bgp-ipv4] network 9.1.1.0 24
[SwitchB-bgp] quit
[SwitchB] ip route-static 3.3.3.3 32 9.1.1.2
[SwitchC] bgp 65009
[SwitchC-bgp] peer 3.1.2.2 as-number 65008
[SwitchC-bgp-ipv4] peer 3.1.2.2 enable
[SwitchC-bgp-ipv4] network 9.1.1.0 24
[SwitchC-bgp] quit
[SwitchC] ip route-static 2.2.2.2 32 9.1.1.1
  >e 9.1.1.0/24         3.1.1.1         0                     0       65009i
*  e                    3.1.2.1         0                     0       65009i
¡  The output shows two valid routes to destination 9.1.1.0/24. The route with next hop 3.1.1.1 is marked with a greater-than sign (>), indicating it is the best route (because the ID of Switch B is smaller). The route with next hop 3.1.2.1 is marked with an asterisk (*), indicating it is a valid route, but not the best.
¡  By using the display ip routing-table command, you can find only one route to 9.1.1.0/24 with next hop 3.1.1.1 and outbound interface VLAN-interface 200.
3.      Configure loading balancing:
Because Switch A has two routes to reach AS 65009, configuring load balancing over the two BGP routes on Switch A can improve link usage.
[SwitchA] bgp 65008
[SwitchA-bgp-ipv4] balance 2
[SwitchA-bgp] quit
  >e                    3.1.2.1         0                     0       65009i
·           The route 9.1.1.0/24 has two next hops, 3.1.1.1 and 3.1.2.1, both of which are marked with a greater-than sign (>), indicating they are the best routes.
·           By using the display ip routing-table command, you can find two routes to 9.1.1.0/24. One has next hop 3.1.1.1 and outbound interface VLAN-interface 200, and the other has next hop 3.1.2.1 and outbound interface VLAN-interface 300.
BGP community configuration example
As shown in Figure 20, Switch B establishes EBGP connections with Switch A and C. Configure NO_EXPORT community attribute on Switch A to make routes from AS 10 not advertised by AS 20 to any other AS.
Figure 19 Network diagram
2.      Configure EBGP:
[SwitchA] bgp 10
[SwitchA-bgp] peer 200.1.2.2 as-number 20
[SwitchA-bgp-ipv4] peer 200.1.2.2 enable
[SwitchA-bgp-ipv4] network 9.1.1.0 255.255.255.0
[SwitchA-bgp] quit
[SwitchB] bgp 20
[SwitchB-bgp] peer 200.1.2.1 as-number 10
[SwitchB-bgp] peer 200.1.3.2 as-number 30
[SwitchB-bgp-ipv4] peer 200.1.2.1 enable
[SwitchB-bgp-ipv4] peer 200.1.3.2 enable
[SwitchB-bgp] quit
[SwitchC] bgp 30
[SwitchC-bgp] peer 200.1.3.1 as-number 20
[SwitchC-bgp-ipv4] peer 200.1.3.1 enable
[SwitchC-bgp] quit
[SwitchB] display bgp routing-table ipv4 9.1.1.0
 BGP local router ID: 2.2.2.2
 Local AS number: 20
 Paths:   1 available, 1 best
 Relay nexthop   : 200.1.2.1
 Original nexthop: 200.1.2.1
 OutLabel        : NULL
 AS-path         : 10
 Origin          : igp
 Attribute value : pref-val 0
 State           : valid, external, best,
# Display advertisement information of network 9.1.1.0 on Switch B.
[SwitchB] display bgp routing-table ipv4 9.1.1.0 advertise-info
 Local AS number: 20
 Paths:   1 best
    200.1.3.2
The output shows that Switch B can advertise the route with the destination 9.1.1.0/24 to other ASs through BGP.
  >e 9.1.1.0/24         200.1.3.1                             0       20 10i
The output shows that Switch C has learned route 9.1.1.0/24 from Switch B.
3.      Configure BGP community:
# Configure a routing policy.
[SwitchA] route-policy comm_policy permit node 0
[SwitchA-route-policy-comm_policy-0] apply community no-export
[SwitchA-route-policy-comm_policy-0] quit
# Apply the routing policy.
[SwitchA] bgp 10
[SwitchA-bgp-ipv4] peer 200.1.2.2 route-policy comm_policy export
[SwitchA-bgp-ipv4] peer 200.1.2.2 advertise-community
# Display the routing table on Switch B.
 Local AS number: 20
 OutLabel        : NULL
 Community       : No-Export
 AS-path         : 10
 Origin          : igp
# Display advertisement information for the route 9.1.1.0 on Switch B.
 Local AS number: 20
 Paths:   1 best
 Total number of routes: 0
You can see the NO_EXPORT community attribute in the output. In this case, Switch B does not advertise the route 9.1.1.0/24 through BGP.
BGP route reflector configuration example
In Figure 21, all switches run BGP.
·           Between Switch A and Switch B is an EBGP connection, between Switch C and Switch B, and between Switch C and Switch D are IBGP connections.
·           Switch C is a route reflector with clients Switch B and D.
·           Switch D can learn route 20.0.0.0/8 from Switch C.
Figure 20 Network diagram
[SwitchA] bgp 100
[SwitchA-bgp] peer 192.1.1.2 as-number 200
[SwitchA-bgp-ipv4] peer 192.1.1.2 enable
# Inject network 20.0.0.0/8 to the BGP routing table.
[SwitchA-bgp-ipv4] network 20.0.0.0
[SwitchA-bgp] quit
[SwitchB] bgp 200
[SwitchB-bgp] peer 192.1.1.1 as-number 100
[SwitchB-bgp] peer 193.1.1.1 as-number 200
[SwitchB-bgp-ipv4] peer 192.1.1.1 enable
[SwitchB-bgp-ipv4] peer 193.1.1.1 enable
[SwitchB-bgp-ipv4] peer 193.1.1.1 next-hop-local
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC-bgp] peer 193.1.1.2 as-number 200
[SwitchC-bgp] peer 194.1.1.2 as-number 200
[SwitchC-bgp-ipv4] peer 193.1.1.2 enable
[SwitchC-bgp-ipv4] peer 194.1.1.2 enable
[SwitchC-bgp] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] bgp 200
[SwitchD-bgp] peer 194.1.1.1 as-number 200
[SwitchD-bgp-ipv4] peer 194.1.1.1 enable
[SwitchD-bgp] quit
3.      Configure Switch C as the route reflector.
[SwitchC] bgp 200
[SwitchC-bgp-ipv4] peer 193.1.1.2 reflect-client
[SwitchC-bgp-ipv4] peer 194.1.1.2 reflect-client
[SwitchC-bgp] quit
  >e 20.0.0.0           192.1.1.1       0                     0       100i
# Display the BGP routing table on Switch D.
[SwitchD] display bgp routing-table ipv4
   i 20.0.0.0           193.1.1.2       0          100        0       100i
Switch D has learned route 20.0.0.0/8 from Switch C.
BGP confederation configuration example
As shown in Figure 22, to reduce IBGP connections, AS 200 is split into three sub-ASs: AS 65001, AS 65002, and AS 65003. Switches in AS 65001 are fully meshed.
Figure 21 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
200.1.1.1/24
Switch D
Vlan-int200
10.1.5.1/24
Vlan-int200
10.1.1.1/24
Vlan-int400
10.1.3.2/24
Vlan-int300
10.1.2.1/24
Switch E
Vlan-int200
10.1.5.2/24
Vlan-int400
10.1.3.1/24
Vlan-int500
10.1.4.2/24
Vlan-int500
10.1.4.1/24
Switch F
Vlan-int100
200.1.1.2/24
Switch B
Vlan-int200
10.1.1.2/24
Vlan-int600
9.1.1.1/24
Switch C
Vlan-int300
10.1.2.2/24
2.      Configure BGP confederation:
[SwitchA] bgp 65001
[SwitchA-bgp] confederation id 200
[SwitchA-bgp] confederation peer-as 65002 65003
[SwitchA-bgp] peer 10.1.1.2 as-number 65002
[SwitchA-bgp] peer 10.1.2.2 as-number 65003
[SwitchA-bgp-ipv4] peer 10.1.1.2 enable
[SwitchA-bgp-ipv4] peer 10.1.2.2 enable
[SwitchA-bgp-ipv4] peer 10.1.1.2 next-hop-local
[SwitchA-bgp-ipv4] peer 10.1.2.2 next-hop-local
[SwitchA-bgp] quit
[SwitchB] bgp 65002
[SwitchB-bgp] confederation id 200
[SwitchB-bgp] confederation peer-as 65001 65003
[SwitchB-bgp] peer 10.1.1.1 as-number 65001
[SwitchB-bgp-ipv4] peer 10.1.1.1 enable
[SwitchB-bgp] quit
[SwitchC] bgp 65003
[SwitchC-bgp] confederation id 200
[SwitchC-bgp] confederation peer-as 65001 65002
[SwitchC-bgp] peer 10.1.2.1 as-number 65001
[SwitchC-bgp-ipv4] peer 10.1.2.1 enable
[SwitchC-bgp] quit
3.      Configure IBGP connections in AS 65001:
[SwitchA] bgp 65001
[SwitchA-bgp] peer 10.1.3.2 as-number 65001
[SwitchA-bgp] peer 10.1.4.2 as-number 65001
[SwitchA-bgp-ipv4] peer 10.1.3.2 enable
[SwitchA-bgp-ipv4] peer 10.1.4.2 enable
[SwitchA-bgp-ipv4] peer 10.1.3.2 next-hop-local
[SwitchA-bgp-ipv4] peer 10.1.4.2 next-hop-local
[SwitchA-bgp] quit
[SwitchD] bgp 65001
[SwitchD-bgp] confederation id 200
[SwitchD-bgp] peer 10.1.3.1 as-number 65001
[SwitchD-bgp] peer 10.1.5.2 as-number 65001
[SwitchD-bgp-ipv4] peer 10.1.3.1 enable
[SwitchD-bgp-ipv4] peer 10.1.5.2 enable
[SwitchD-bgp] quit
# Configure Switch E.
<SwitchE> system-view
[SwitchE] bgp 65001
[SwitchE-bgp] router-id 5.5.5.5
[SwitchE-bgp] confederation id 200
[SwitchE-bgp] peer 10.1.4.1 as-number 65001
[SwitchE-bgp] peer 10.1.5.1 as-number 65001
[SwitchE-bgp] ipv4-family unicast
[SwitchE-bgp-ipv4] peer 10.1.4.1 enable
[SwitchE-bgp-ipv4] peer 10.1.5.1 enable
[SwitchE-bgp-ipv4] quit
[SwitchE-bgp] quit
4.      Configure the EBGP connection between AS 100 and AS 200:
[SwitchA] bgp 65001
[SwitchA-bgp] peer 200.1.1.2 as-number 100
[SwitchA-bgp-ipv4] peer 200.1.1.2 enable
[SwitchA-bgp] quit
# Configure Switch F.
<SwitchF> system-view
[SwitchF] bgp 100
[SwitchF-bgp] router-id 6.6.6.6
[SwitchF-bgp] peer 200.1.1.1 as-number 200
[SwitchF-bgp] ipv4-family unicast
[SwitchF-bgp-ipv4] peer 200.1.1.1 enable
[SwitchF-bgp-ipv4] network 9.1.1.0 255.255.255.0
[SwitchF-bgp-ipv4] quit
[SwitchF-bgp] quit
# Display the routing table on Switch B, which is similar to that on Switch C.
  >i 9.1.1.0/24         10.1.1.1        0          100        0       (65001)
        100i
 Local AS number: 65002
 Relay nexthop   : 10.1.1.1
 Original nexthop: 10.1.1.1
 OutLabel        : NULL
 AS-path         : (65001) 100
 Origin          : igp
 State           : valid, external-confed, best,
  >i 9.1.1.0/24         10.1.3.1        0          100        0       100i
[SwitchD] display bgp routing-table ipv4 9.1.1.0
 BGP local router ID: 4.4.4.4
 Local AS number: 65001
 Relay nexthop   : 10.1.3.1
 Original nexthop: 10.1.3.1
 OutLabel        : NULL
 AS-path         : 100
 Origin          : igp
 State           : valid, internal-confed, best,
The output indicates the following:
·           Switch F can send route information to Switch B and Switch C through the confederation by establishing only an EBGP connection with Switch A.
·           Switch B and Switch D are in the same confederation, but belong to different sub-ASs. They obtain external route information from Switch A and generate the same BGP route entries. It is likely that they reside in the same AS, although they have no direct connection in between.
BGP path selection configuration example
In Figure 23, all switches run BGP. EBGP runs between Switch A and Switch B, and between Switch A and Switch C. IBGP runs between Switch B and Switch D, and between Switch D and Switch C. OSPF is the IGP protocol in AS 200.
Configure routing policies, making Switch D use the route 1.0.0.0/8 from Switch C as the optimal.
Figure 22 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int101
1.0.0.1/8
Switch D
Vlan-int400
195.1.1.1/24
Vlan-int100
192.1.1.1/24
Vlan-int300
194.1.1.1/24
Vlan-int200
193.1.1.1/24
Switch C
Vlan-int400
195.1.1.2/24
Switch B
Vlan-int100
192.1.1.2/24
Vlan-int200
193.1.1.2/24
Vlan-int300
194.1.1.2/24
2.      Configure OSPF on Switch B, Switch C, and Switch D:
[SwitchB] ospf
[SwitchB-ospf] area 0
[SwitchB-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[SwitchC] ospf
[SwitchC-ospf] area 0
[SwitchC-ospf-1-area-0.0.0.0] network 193.1.1.0 0.0.0.255
[SwitchC-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[SwitchD] ospf
[SwitchD-ospf] area 0
[SwitchD-ospf-1-area-0.0.0.0] network 194.1.1.0 0.0.0.255
[SwitchD-ospf-1-area-0.0.0.0] network 195.1.1.0 0.0.0.255
[SwitchD-ospf-1] quit
3.      Configure BGP connections:
[SwitchA] bgp 100
[SwitchA-bgp] peer 193.1.1.2 as-number 200
[SwitchA-bgp-ipv4] peer 193.1.1.2 enable
# Inject network 1.0.0.0/8 to the BGP routing table on Switch A.
[SwitchA-bgp-ipv4] network 1.0.0.0 8
[SwitchA-bgp] quit
[SwitchB] bgp 200
[SwitchB-bgp] peer 194.1.1.1 as-number 200
[SwitchB-bgp-ipv4] peer 194.1.1.1 enable
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC-bgp] peer 193.1.1.1 as-number 100
[SwitchC-bgp] peer 195.1.1.1 as-number 200
[SwitchC-bgp-ipv4] peer 193.1.1.1 enable
[SwitchC-bgp-ipv4] peer 195.1.1.1 enable
[SwitchC-bgp] quit
[SwitchD] bgp 200
[SwitchD-bgp] peer 194.1.1.2 as-number 200
[SwitchD-bgp] peer 195.1.1.2 as-number 200
[SwitchD-bgp-ipv4] peer 194.1.1.2 enable
[SwitchD-bgp-ipv4] peer 195.1.1.2 enable
[SwitchD-bgp] quit
4.      Configure attributes for route 1.0.0.0/8, making Switch D give priority to the route learned from Switch C:
¡  (Method 1.) Configure a higher MED value for the route 1.0.0.0/8 advertised from Switch A to peer 192.1.1.2:
# Define an ACL numbered 2000 to permit route 1.0.0.0/8.
[SwitchA] acl number 2000
[SwitchA-acl-basic-2000] rule permit source 1.0.0.0 0.255.255.255
[SwitchA-acl-basic-2000] quit
# Define two routing policies, apply_med_50, which sets the MED for route 1.0.0.0/8 to 50, and apply_med_100, which sets the MED for route 1.0.0.0/8 to 100.
[SwitchA] route-policy apply_med_50 permit node 10
[SwitchA-route-policy-apply_med_50-10] if-match ip address acl 2000
[SwitchA-route-policy-apply_med_50-10] apply cost 50
[SwitchA-route-policy-apply_med_50-10] quit
[SwitchA] route-policy apply_med_100 permit node 10
[SwitchA-route-policy-apply_med_100-10] if-match ip address acl 2000
[SwitchA-route-policy-apply_med_100-10] apply cost 100
[SwitchA-route-policy-apply_med_100-10] quit
# Apply routing policy apply_med_50 to the route advertised to peer 193.1.1.2 (Switch C), and apply_med_100 to the route advertised to peer 192.1.1.2 (Switch B).
[SwitchA] bgp 100
[SwitchA-bgp-ipv4] peer 193.1.1.2 route-policy apply_med_50 export
[SwitchA-bgp-ipv4] peer 192.1.1.2 route-policy apply_med_100 export
[SwitchA-bgp] quit
 Total number of routes: 2
  >i 1.0.0.0            193.1.1.1       50         100        0       100i
*  i                    192.1.1.1       100        100        0       100i
Route 1.0.0.0/8 is the optimal route.
¡  (Method 2.) Configure different local preferences on Switch B and C for route 1.0.0.0/8, making Switch D give priority to the route from Switch C:
# Define an ACL numbered 2000 on Router C, permitting route 1.0.0.0/8.
[SwitchC] acl number 2000
[SwitchC-acl-basic-2000] rule permit source 1.0.0.0 0.255.255.255
[SwitchC-acl-basic-2000] quit
# Configure a routing policy named localpref on Switch C, setting the local preference of route 1.0.0.0/8 to 200 (the default is 100).
[SwitchC] route-policy localpref permit node 10
[SwitchC-route-policy-localpref-10] if-match ip address acl 2000
[SwitchC-route-policy-localpref-10] apply local-preference 200
[SwitchC-route-policy-localpref-10] quit
# Apply routing policy localpref to routes from peer 193.1.1.1.
[SwitchC] bgp 200
[SwitchC-bgp-ipv4] peer 193.1.1.1 route-policy localpref import
[SwitchC-bgp] quit
  >i 1.0.0.0            193.1.1.1                  200        0       100i
*  i                    192.1.1.1                  100        0       100i
Route 1.0.0.0/8 learned from Switch C is the optimal route.
BGP GR configuration example
In Figure 24 are all BGP switches. EBGP runs between Switch A and Switch B. IBGP runs between Switch B and Switch C. Enable GR capability for BGP so that the communication between Switch A and Switch C is not affected when an active/standby switchover occurs on Switch B.
Figure 23 Network diagram
1.      Configure Switch A:
# Configure IP addresses for interfaces. (Details not shown.)
# Configure the EBGP connection.
[SwitchA] bgp 65008
[SwitchA-bgp] peer 200.1.1.1 as-number 65009
# Enable GR capability for BGP.
[SwitchA-bgp] graceful-restart
# Inject network 8.0.0.0/8 to the BGP routing table.
[SwitchA-bgp-ipv4] network 8.0.0.0
# Enable Switch A to exchange IPv4 unicast routing information with Switch B.
[SwitchA-bgp-ipv4] peer 200.1.1.1 enable
2.      Configure Switch B:
[SwitchB] bgp 65009
[SwitchB-bgp] peer 200.1.1.2 as-number 65008
# Configure the IBGP connection.
[SwitchB-bgp] peer 9.1.1.2 as-number 65009
[SwitchB-bgp] graceful-restart
# Inject networks 200.1.1.0/24 and 9.1.1.0/24 to the BGP routing table.
[SwitchB-bgp-ipv4] network 200.1.1.0 24
# Enable Switch B to exchange IPv4 unicast routing information with Switch A and Switch C.
[SwitchB-bgp-ipv4] peer 200.1.1.2 enable
[SwitchB-bgp-ipv4] peer 9.1.1.2 enable
3.      Configure Switch C:
[SwitchC] bgp 65009
[SwitchC-bgp] peer 9.1.1.1 as-number 65009
[SwitchC-bgp] graceful-restart
# Enable Switch C to exchange IPv4 unicast routing information with Switch B.
[SwitchC-bgp-ipv4] peer 9.1.1.1 enable
Ping Switch C on Switch A. Meanwhile, perform an active/standby switchover on Switch B. The ping operation is successful during the whole switchover process.
BFD for BGP configuration example
As shown in Figure 25,
·           Configure OSPF as the IGP in AS 200.
·           Establish two IBGP connections between Switch A and Switch C. When both paths are working, Switch C adopts the path Switch A<—>Switch B<—>Switch C to exchange packets with network 1.1.1.0/24. Configure BFD over the path. If the path fails, BFD can quickly detect the failure and notify it to BGP. Then the path Switch A<—>Switch D<—>Switch C takes effect immediately.
Figure 24 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
3.0.1.1/24
Switch C
Vlan-int101
3.0.2.2/24
Vlan-int200
2.0.1.1/24
Vlan-int201
2.0.2.2/24
Switch B
Vlan-int100
3.0.1.2/24
Switch D
Vlan-int200
2.0.1.2/24
Vlan-int101
3.0.2.1/24
Vlan-int201
2.0.2.1/24
2.      Configure OSPF to make sure that Switch A and Switch C are reachable to each other. (Details not shown.)
3.      Configure BGP on Switch A:
# Establish two IBGP connections to Switch C.
[SwitchA] bgp 200
[SwitchA-bgp] peer 3.0.2.2 as-number 200
[SwitchA-bgp] peer 2.0.2.2 as-number 200
[SwitchA-bgp-ipv4] peer 3.0.2.2 enable
[SwitchA-bgp-ipv4] peer 2.0.2.2 enable
[SwitchA-bgp] quit
# Create ACL 2000 to permit 1.1.1.0/24 to pass.
[SwitchA-acl-basic-2000] rule permit source 1.1.1.0 0.0.0.255
# Create two route policies, apply_med_50 and apply_med_100. Policy apply_med_50 sets the MED for route 1.1.1.0/24 to 50. Policy apply_med_100 sets that to 100.
# Apply routing policy apply_med_50 to routes outgoing to peer 3.0.2.2, and apply routing policy apply_med_100 to routes outgoing to peer 2.0.2.2.
[SwitchA] bgp 200
[SwitchA-bgp-ipv4] peer 3.0.2.2 route-policy apply_med_50 export
[SwitchA-bgp-ipv4] peer 2.0.2.2 route-policy apply_med_100 export
# Enable BFD for peer 3.0.2.2.
[SwitchA-bgp] peer 3.0.2.2 bfd
[SwitchA-bgp] quit
4.      Configure BGP on Switch C:
# Establish two IBGP connections to Switch A.
[SwitchC] bgp 200
[SwitchC-bgp] peer 3.0.1.1 as-number 200
[SwitchC-bgp] peer 2.0.1.1 as-number 200
[SwitchC-bgp-ipv4] peer 3.0.1.1 enable
[SwitchC-bgp-ipv4] peer 2.0.1.1 enable
[SwitchC-bgp] quit
# Enable BFD for peer 3.0.1.1.
[SwitchC-bgp] peer 3.0.1.1 bfd
[SwitchC-bgp] quit
[SwitchC] quit
# Display detailed BFD session information on Router C.
<SwitchC> display bfd session verbose
       Local Discr: 513                  Remote Discr: 513
         Source IP: 3.0.2.2            Destination IP: 3.0.1.1
     Session State: Up                      Interface: N/A
      Min Tx Inter: 500ms                Act Tx Inter: 500ms
      Min Rx Inter: 500ms                Detect Inter: 2500ms
          Rx Count: 135                      Tx Count: 135
      Connect Type: Indirect           Running Up for: 00:00:58
         Hold Time: 2457ms                  Auth mode: None
       Detect Mode: Async                        Slot: 0
          Protocol: BGP
         Diag Info: No Diagnostic
The output shows that a BFD session has been established between Switch A and Switch C and that BFD runs properly.
# Display BGP peer information on Switch C.
<SwitchC> display bgp peer ipv4
 BGP local router ID: 3.3.3.3
 Local AS number: 200
 Total number of peers: 2                  Peers in established state: 2
  2.0.1.1                200        4        5    0       0 00:01:55 Established
  3.0.1.1                200        4        5    0       0 00:01:52 Established
The output shows that Switch C has established two BGP connections with Switch A, and both connections are in Established state.
# Display route 1.1.1.0/24 on Switch C.
<SwitchC> display ip routing-table 1.1.1.0 24 verbose
Summary Count : 1
Destination: 1.1.1.0/24
   Protocol: BGP             Process ID: 0
  SubProtID: 0x1                    Age: 00h00m09s
       Cost: 50              Preference: 255
        Tag: 0                    State: Active Adv
  OrigTblID: 0x1                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NBRID: 0x15000001          LastAs: 0
     AttrID: 0x1               Neighbor: 3.0.1.1
      Flags: 0x10060        OrigNextHop: 3.0.1.1
      Label: NULL           RealNextHop: 3.0.2.1
    BkLabel: NULL             BkNextHop: N/A
  Tunnel ID: Invalid          Interface: Vlan-interface101
BkTunnel ID: Invalid        BkInterface: N/A
The output shows that Switch C communicates with network 1.1.1.0/24 through the path Switch C<—>Switch B<—>Switch A. Then the path Switch C<—>Switch B<—>Switch A fails.
# Enable debugging on Switch C.
<SwitchC> debugging bgp event
<SwitchC> terminal monitor
<SwitchC> terminal logging level 7
%Mar 12 19:02:59:241 2012 SwitchC BFD/6/FSM: -MDC=1; Sess[3.0.2.2/3.0.1.1, LD/RD:
513/513, Interface:N/A, SessType:Ctrl, LinkType:INET], Sta: UP->DOWN, Diag: 1
*Mar 12 19:02:59:242 2012 SwitchC BGP/7/DEBUG: -MDC=1;
 BGP.: 3.0.1.1 Receive ManualStop event in ESTABLISHED state.
 BGP.: 3.0.1.1 Send NOTIFICATION
 Err/SubErr: 6/0 (Cease/ErrSubCode Unspecified)
 Error data NULL.
*Mar 12 19:02:59:243 2012 SwitchC BGP/7/DEBUG: -MDC=1;
 BGP.: 3.0.1.1 State is changed from ESTABLISHED to IDLE.
The output shows that Switch C can quickly detect the link failure and notify BGP to change the relevant IBGP session state.
Summary Count : 1
  SubProtID: 0x1                    Age: 00h03m08s
       Cost: 100             Preference: 255
      NBRID: 0x15000000          LastAs: 0
     AttrID: 0x0               Neighbor: 2.0.1.1
      Flags: 0x10060        OrigNextHop: 2.0.1.1
      Label: NULL           RealNextHop: 2.0.2.1
  Tunnel ID: Invalid          Interface: Vlan-interface201
The output shows that Switch C communicates with network 1.1.1.0/24 through the path Switch C<—>Switch D<—>Switch A.
IPv6 BGP configuration examples
IPv6 BGP basic configuration example
In Figure 26, run EBGP between Switch A and Switch B, and run IBGP between Switch B and Switch C so that Switch C can access the network 50::/64 connected to Switch A.
Figure 25 Network diagram
2.      Configure IBGP:
[SwitchB] bgp 65009
[SwitchB-bgp] peer 9::2 as-number 65009
[SwitchB-bgp] ipv6-family
[SwitchB-bgp-ipv6] peer 9::2 enable
[SwitchB-bgp-ipv6] quit
[SwitchC] bgp 65009
[SwitchC-bgp] peer 9::1 as-number 65009
[SwitchC-bgp] ipv6-family
[SwitchC-bgp-ipv6] peer 9::1 enable
3.      Configure EBGP:
[SwitchA] bgp 65008
[SwitchA-bgp] peer 10::1 as-number 65009
[SwitchA-bgp] ipv6-family
[SwitchA-bgp-ipv6] peer 10::1 enable
[SwitchB-bgp] peer 10::2 as-number 65008
[SwitchB-bgp-ipv6] peer 10::2 enable
4.      Inject network routes to the BGP routing table:
[SwitchA-bgp-ipv6] network 10:: 64
[SwitchA-bgp-ipv6] network 50:: 64
[SwitchA-bgp-ipv6] quit
[SwitchA-bgp] quit
[SwitchB-bgp-ipv6] network 10:: 64
[SwitchB-bgp-ipv6] network 9:: 64
[SwitchB-bgp] quit
[SwitchC-bgp-ipv6] network 9:: 64
[SwitchC-bgp-ipv6] quit
[SwitchC-bgp] quit
# Display IPv6 BGP peer information on Switch B.
[SwitchB] display bgp peer ipv6
 Local AS number: 65009
  9::2                 65009       41       43    0       1 00:29:00 Established
  10::2                65008       38       38    0       2 00:27:20 Established
The output shows that Switch A and Switch B have established an EBGP connection, and Switch B and Switch C have established an IBGP connection.
# Display IPv6 BGP routing table information on Switch A.
[SwitchA] display bgp routing-table ipv6
  >e Network : 9::                                      PrefixLen : 64
     NextHop : 10::1                                    LocPrf    :
     MED     : 0
     Path/Ogn: 65009i
  >  Network : 10::                                     PrefixLen : 64
     NextHop : ::                                       LocPrf    :
     PrefVal : 32768                                    OutLabel  : NULL
     MED     : 0
     Path/Ogn: i
*  e Network : 10::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: 65009i
  >  Network : 50::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: i
The output shows that Switch A has learned routing information of AS 65009.
# Display IPv6 BGP routing table information on Switch C.
[SwitchC] display bgp routing-table ipv6
  >  Network : 9::                                      PrefixLen : 64
     MED     : 0
     Path/Ogn: i
*  i Network : 9::                                      PrefixLen : 64
     NextHop : 9::1                                     LocPrf    : 100
     MED     : 0
     Path/Ogn: i
  >i Network : 10::                                     PrefixLen : 64
     MED     : 0
     Path/Ogn: i
  >i Network : 50::                                     PrefixLen : 64
     NextHop : 10::2                                    LocPrf    : 100
     MED     : 0
     Path/Ogn: 65008i
The output shows that Switch C has learned the route 50::/64.
# Ping hosts on network 50::/64 on Switch C. The ping operations succeed.
IPv6 BGP route reflector configuration example
In Figure 27, run EBGP between Switch A and Switch B, run IBGP between Switch C and Switch B, and between Switch C and Switch D. Switch C is a route reflector with clients Switch B and D.
Figure 26 Network diagram
1.      Configure IPv6 addresses for interfaces and IPv4 addresses for loopback interfaces. (Details not shown.)
2.      Configure IBGP and EBGP connections and advertise network routes through IPv6 BGP:
[SwitchA] bgp 100
[SwitchA-bgp] peer 100::2 as-number 200
[SwitchA-bgp-ipv6] peer 100::2 enable
[SwitchA-bgp-ipv6] network 1:: 64
[SwitchA-bgp-ipv6] network 100:: 96
[SwitchA-bgp] quit
[SwitchB] bgp 200
[SwitchB-bgp] peer 100::1 as-number 100
[SwitchB-bgp] peer 101::1 as-number 200
[SwitchB-bgp-ipv6] peer 100::1 enable
[SwitchB-bgp-ipv6] peer 101::1 enable
[SwitchB-bgp-ipv6] peer 101::1 next-hop-local
[SwitchB-bgp-ipv6] network 100:: 96
[SwitchB-bgp-ipv6] network 101:: 96
[SwitchB-bgp] quit
[SwitchC] bgp 200
[SwitchC-bgp] peer 101::2 as-number 200
[SwitchC-bgp] peer 102::2 as-number 200
[SwitchC-bgp-ipv6] peer 101::2 enable
[SwitchC-bgp-ipv6] peer 102::2 enable
[SwitchC-bgp-ipv6] network 101:: 96
[SwitchC-bgp-ipv6] network 102:: 96
[SwitchD] bgp 200
[SwitchD-bgp] peer 102::1 as-number 200
[SwitchD-bgp] ipv6-family
[SwitchD-bgp-ipv6] peer 102::1 enable
[SwitchD-bgp-ipv6] network 102:: 96
3.      Configure Switch C as a route reflector, and configure Switch B and Switch D as its clients.
[SwitchC-bgp-ipv6] peer 101::2 reflect-client
[SwitchC-bgp-ipv6] peer 102::2 reflect-client
[SwitchC-bgp] quit
# Execute the display bgp routing-table ipv6 command on Switch D.
[SwitchD] display bgp routing-table ipv6
 Total number of routes: 5
  >i Network : 1::                                      PrefixLen : 64
     NextHop : 101::2                                   LocPrf    : 100
     MED     : 0
     Path/Ogn: 100i
  >i Network : 100::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
  >i Network : 101::                                    PrefixLen : 96
     NextHop : 102::1                                   LocPrf    : 100
     MED     : 0
     Path/Ogn: i
  >  Network : 102::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
*  i Network : 102::                                    PrefixLen : 96
     MED     : 0
     Path/Ogn: i
The output shows that Switch D has learned the network 1::/64 from Switch C through route reflection.
6PE configuration example
Use 6PE to connect two isolated IPv6 networks over an IPv4/MPLS network:
·           The ISP uses OSPF as the IGP.
·           PE 1 and PE 2 are edge devices of the ISP, and establish an IPv4 IBGP connection between them.
·           CE 1 and CE 2 are edge devices of the IPv6 networks, and they connect the IPv6 networks to the ISP.
·           A CE and a PE exchange IPv6 packets through IPv6 static routing.
Figure 27 Network diagram
1.      Configure IPv6 addresses and IPv4 addresses for interfaces. (Details not shown.)
2.      Configure PE 1:
# Enable LDP globally, and configure the LSP generation policy.
<PE1> system-view
[PE1] mpls lsr-id 2.2.2.2
[PE1] mpls ldp
[PE1-ldp] lsp-trigger all
[PE1-ldp] quit
# Enable MPLS and LDP on VLAN-interface 30.
[PE1] interface vlan-interface 30
[PE1-Vlan-interface30] mpls enable
[PE1-Vlan-interface30] mpls ldp enable
[PE1-Vlan-interface30] quit
# Configure IBGP, enable the peer's 6PE capabilities, and redistribute IPv6 direct and static routes.
[PE1] bgp 65100
[PE1-bgp] router-id 2.2.2.2
[PE1-bgp] peer 3.3.3.3 as-number 65100
[PE1-bgp] peer 3.3.3.3 connect-interface loopback 0
[PE1-bgp] ipv6-family
[PE1-bgp-ipv6] import-route direct
[PE1-bgp-ipv6] import-route static
[PE1-bgp-ipv6] peer 3.3.3.3 enable
[PE1-bgp-ipv6] peer 3.3.3.3 label-route-capability
[PE1-bgp-ipv6] quit
[PE1-bgp] quit
# Configure a static route to CE 1.
[PE1] ipv6 route-static 1::1 128 10::1
# Configure OSPF for the ISP.
[PE1] ospf
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 1.1.0.0 0.0.255.255
[PE1-ospf-1] quit
3.      Configure PE 2:
<PE2> system-view
[PE2] mpls lsr-id 3.3.3.3
[PE2] mpls ldp
[PE2-mpls-ldp] lsp-trigger all
[PE2-mpls-ldp] quit
[PE2] interface vlan-interface 30
[PE2-Vlan-interface30] mpls enable
[PE2-Vlan-interface30] mpls ldp enable
[PE2-Vlan-interface30] quit
[PE2] bgp 65100
[PE2-bgp] router-id 3.3.3.3
[PE2-bgp] peer 2.2.2.2 as-number 65100
[PE2-bgp] peer 2.2.2.2 connect-interface loopback 0
[PE2-bgp] ipv6-family
[PE2-bgp-ipv6] import-route direct
[PE2-bgp-ipv6] import-route static
[PE2-bgp-ipv6] peer 2.2.2.2 enable
[PE2-bgp-ipv6] peer 2.2.2.2 label-route-capability
[PE2-bgp-ipv6] quit
[PE2-bgp] quit
# Configure the static route to CE 2.
[PE2] ipv6 route-static 4::4 128 20::1
[PE2] ospf
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.0.0 0.0.255.255
[PE2-ospf-1] quit
4.      Configure a static route on CE 1, with PE 1 as the default next hop.
<CE1> system-view
[CE1] ipv6 route-static :: 0 10::2
5.      Configure a static route on CE 2, with PE 2 as the default next hop.
<CE2> system-view
[CE2] ipv6 route-static :: 0 20::2
Display the IPv6 BGP routing tables on PE 1 and PE 2, and you can see that each of them has two IPv6 network routes.
# Display the IPv6 BGP routing table on PE 1.
[PE1] display bgp routing-table ipv6
  >  Network : 1::1                                     PrefixLen : 128
     MED     : 0
     Path/Ogn: ?
  >i Network : 4::4                                     PrefixLen : 128
     NextHop : ::FFFF:3.3.3.3                           LocPrf    : 100
     PrefVal : 0                                        OutLabel  : 1279
     MED     : 0
     Path/Ogn: ?
     MED     : 0
     Path/Ogn: ?
  >  Network : 10::2                                    PrefixLen : 128
     NextHop : ::1                                      LocPrf    :
     MED     : 0
     Path/Ogn: ?
  >i Network : 20::                                     PrefixLen : 64
     PrefVal : 0                                        OutLabel  : 1278
     MED     : 0
     Path/Ogn: ?
# Ping the IPv6 address 4::4 (loopback interface address) of CE 2 from CE 1. The ping operation succeeds.
BFD for IPv6 BGP configuration example
As shown in Figure 29, configure OSPFv3 as the IGP in AS 200.
Establish two IBGP connections between Switch A and Switch C. When both paths are working, Switch C adopts the path Switch A<—>Switch B<—>Switch C to exchange packets with network 1200::0/64. Configure BFD over the path. Then if the path fails, BFD can quickly detect the failure and notify it to IPv6 BGP. Then the path Switch A<—>Switch D<—>Switch C takes effect immediately.
Figure 28 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
3000::1/64
Switch C
Vlan-int101
3001::3/64
Vlan-int200
2000::1/64
Vlan-int201
2001::3/64
Switch B
Vlan-int100
3000::2/64
Switch D
Vlan-int200
2000::2/64
Vlan-int101
3001::2/64
Vlan-int201
2001::2/64
1.      Configure IPv6 addresses for interfaces. (Details not shown.)
2.      Configure OSPFv3 so that Switch A and Switch C can reach each other. (Details not shown.)
3.      Configure IPv6 BGP on Switch A:
[SwitchA] bgp 200
[SwitchA-bgp] peer 3001::3 as-number 200
[SwitchA-bgp] peer 2001::3 as-number 200
[SwitchA-bgp-ipv6] peer 3001::3 enable
[SwitchA-bgp-ipv6] peer 2001::3 enable
# Create IPv6 ACL 2000 to permit 1200::0/64 to pass.
[SwitchA] acl ipv6 number 2000
[SwitchA-acl6-basic-2000] rule permit source 1200:: 64
[SwitchA-acl6-basic-2000] quit
# Create two route policies, apply_med_50 and apply_med_100. Policy apply_med_50 sets the MED for route 1200::0/64 to 50. Policy apply_med_100 sets that to 100.
[SwitchA-route-policy-apply_med_50-10] if-match ipv6 address acl 2000
[SwitchA-route-policy-apply_med_100-10] if-match ipv6 address acl 2000
# Apply routing policy apply_med_50 to routes outgoing to peer 3001::3, and apply routing policy apply_med_100 to routes outgoing to peer 2001::3.
[SwitchA] bgp 200
[SwitchA-bgp] ipv6-family unicast
[SwitchA-bgp-ipv6] peer 3001::3 route-policy apply_med_50 export
[SwitchA-bgp-ipv6] peer 2001::3  route-policy apply_med_100 export
# Enable BFD for peer 3001::3.
[SwitchA-bgp] peer 3001::3 bfd
[SwitchA-bgp] quit
4.      Configure IPv6 BGP on Switch C:
[SwitchC] bgp 200
[SwitchC-bgp] peer 3000::1 as-number 200
[SwitchC-bgp] peer 2000::1 as-number 200
[SwitchC-bgp-ipv6] peer 3000::1 enable
[SwitchC-bgp-ipv6] peer 2000::1 enable
# Enable BFD for peer 3001::1.
[SwitchC-bgp] peer 3000::1 bfd
[SwitchC-bgp] quit
[SwitchC] quit
# Display detailed BFD session information on Switch C.
 IPv6 Session Working Under Ctrl Mode:
         Source IP: 3001::3
    Destination IP: 3000::1
          Rx Count: 13                       Tx Count: 14
      Connect Type: Indirect           Running Up for: 00:00:05
         Hold Time: 2243ms                  Auth mode: None
          Protocol: BGP6
<SwitchC> display bgp peer ipv6
  2000::1                200        8        8    0       0 00:04:45 Established
  3000::1                200        5        4    0       0 00:01:53 Established
# Display route 1200::0/64 on Switch C.
<SwitchC> display ipv6 routing-table 1200::0 64 verbose
Summary Count : 1
Destination: 1200::/64
   Protocol: BGP4+           Process ID: 0
  SubProtID: 0x1                    Age: 00h01m07s
    TableID: 0xa                 OrigAs: 0
      NBRID: 0x25000001          LastAs: 0
     AttrID: 0x1               Neighbor: 3000::1
      Flags: 0x10060        OrigNextHop: 3000::1
      Label: NULL           RealNextHop: FE80::20C:29FF:FE4A:3873
The output shows that Switch C communicates with network 1200::0/64 through the path Switch C<—>Switch B<—>Switch A. Then the path Switch C<—>Switch B<—>Switch A fails.
%Mar 14 15:00:24:256 2012 SwitchC BFD/6/FSM: -MDC=1; Sess[3002::2/3001::1, LD/RD:
*Mar 14 15:00:24:257 2012 SwitchC BGP/7/DEBUG: -MDC=1;
 BGP.: 3001::1 Receive ManualStop event in ESTABLISHED state.
 BGP.: 3001::1 Send NOTIFICATION
 Error data NULL.
*Mar 14 15:00:24:258 2012 SwitchC BGP/7/DEBUG: -MDC=1;
 BGP.: 3001::1 State is changed from ESTABLISHED to IDLE.
Summary Count : 1
  SubProtID: 0x1                    Age: 00h00m57s
      NBRID: 0x25000000          LastAs: 0
     AttrID: 0x0               Neighbor: 2000::1
      Flags: 0x10060        OrigNextHop: 2000::1
      Label: NULL           RealNextHop: FE80::20C:29FF:FE40:715
The output shows that Switch C communicates with network 1200::0/64 through the path Switch C<—>Switch D<—>Switch A.
Troubleshooting BGP
Symptom
Display BGP peer information by using the display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command. The state of the connection to a peer cannot become established.
Analysis
To become BGP peers, any two routers must establish a TCP connection using port 179 and exchange Open messages successfully.
Solution
1.      Use the display current-configuration command to verify the current configuration, and verify that the peer's AS number is correct.
2.      Use the display bgp peer ipv4 unicast or display bgp peer ipv6 unicast command to verify that the peer's IP address/IPv6 address is correct.
3.      If a loopback interface is used, verify that the loopback interface is specified with the peer connect-interface command.
4.      If the peer is a non-direct EBGP peer, verify that the peer ebgp-max-hop command is configured.
5.      Verify that a valid route to the peer is available.
6.      Use the ping command to verify the connectivity to the peer.
7.      Use the display tcp verbose or display ipv6 tcp verbose command to verify the TCP connection.
8.      Verify that no ACL rule is applied to disable TCP port 179.
