04-Layer 2 - LAN Switching Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guide-Release7128-6W71004-Layer 2 - LAN Switching Configuration Guide
09-LLDP configuration
09-LLDP configuration 226.4 KB
Overview
In a heterogeneous network, a standard configuration exchange platform ensures that different types of network devices from different vendors can discover one another and exchange configuration for the sake of interoperability and management.
The IETF drafted the Link Layer Discovery Protocol (LLDP) in IEEE 802.1AB. The protocol operates on the data link layer to exchange device information between directly connected devices. With LLDP, a device sends local device information (including its major functions, management IP address, device ID, and port ID) as TLV (type, length, and value) triplets in LLDP Data Units (LLDPDUs) to the directly connected devices. At the same time, the device stores the device information received in LLDPDUs sent from the LLDP neighbors in a standard MIB. For more information about MIBs, see Network Management and Monitoring Configuration Guide. LLDP enables a network management system to quickly detect and identify Layer 2 network topology changes.
Basic concepts
LLDP agent
An LLDP agent is a mapping of an entity where LLDP runs. Multiple LLDP agents can run on an interface at the same time. LLDP agents are divided into the following types: nearest bridge agent, nearest customer bridge agent, and nearest non-TPMR bridge agent. A Two-port MAC Relay (TPMR) is a type of bridge that has only two externally-accessible bridge ports, and supports a subset of the functions of a MAC bridge. A TPMR is transparent to all frame-based media independent protocols except those destined to it and those destined to reserved MAC addresses that the relay function of the TPMR is defined not to forward. LLDP exchanges packets between neighbor agents and creates and maintains neighbor information for them. Figure 1 shows the neighbor relationships for these LLDP agents. LLDP has two bridge modes: customer bridge (CB) and service bridge (SB).
Figure 1 LLDP neighbor relationships
LLDPDU formats
LLDP sends device information in LLDPDUs. LLDPDUs are encapsulated in Ethernet II or SNAP frames.
1.      LLDPDU encapsulated in Ethernet II
Figure 2 Ethernet II-encapsulated LLDPDU
Table 1 Fields in an Ethernet II-encapsulated LLDPDU
Destination MAC address
MAC address to which the LLDPDU is advertised. To distinguish between LLDP packets sent and received by different agent types on the same interface, LLDP specifies different multicast MAC addresses as destination MAC addresses for LLDP packets to different agent types. It is fixed to multicast MAC address 0x0180-C200-000E (only for LLDP packets destined for the nearest bridge neighbor), 0x0180-C200-0000 (only for LLDP packets destined for the nearest customer bridge neighbor), or 0x0180-C200-0003 (only for LLDP packets destined for the nearest non-two-port MAC relay (TPMR) bridge neighbor).
Source MAC address
MAC address of the sending port.
Ethernet type for the upper layer protocol. It is 0x88CC for LLDP.
Data
LLDPDU.
FCS
Frame check sequence, a 32-bit CRC value used to determine the validity of the received Ethernet frame.
2.      LLDPDU encapsulated in SNAP
Figure 3 SNAP-encapsulated LLDPDU format
Table 2 Fields in a SNAP-encapsulated LLDPDU
MAC address to which the LLDPDU is advertised. It is fixed at 0x0180-C200-000E, a multicast MAC address.
Source MAC address
SNAP type for the upper layer protocol. It is 0xAAAA-0300-0000-88CC for LLDP.
Data
LLDPDU.
FCS
LLDPDUs
LLDP uses LLDPDUs to exchange information. An LLDPDU comprises multiple TLV sequences. Each TLV carries a type of device information, as shown in Figure 4.
Figure 4 LLDPDU encapsulation format
An LLDPDU can carry up to 28 types of TLVs. Mandatory TLVs include Chassis ID TLV, Port ID TLV, Time to Live TLV, and End of LLDPDU TLV. Other TLVs are optional.
TLVs
TLVs are type, length, and value sequences that carry information elements.
LLDPDU TLVs fall into the following categories:
·           Basic management TLVs
·           Organizationally (IEEE 802.1 and IEEE 802.3) specific TLVs
·           LLDP-MED (media endpoint discovery) TLVs
Basic management TLVs are essential to device management. Organizationally specific TLVs and LLDP-MED TLVs are used for enhanced device management; they are defined by standardization or other organizations and are optional to LLDPDUs.
1.      Basic management TLVs
Table 3 lists the basic management TLV types. Some of them are mandatory to LLDPDUs (they must be included in every LLDPDU).
Table 3 Basic management TLVs
Remarks
Chassis ID
Specifies the bridge MAC address of the sending device.
Mandatory.
Port ID
Specifies the ID of the sending port.
If the LLDPDU carries LLDP-MED TLVs, the port ID TLV carries the MAC address of the sending port. Otherwise, the port ID TLV carries the port name.
Time to Live
Specifies the life of the transmitted information on the receiving device.
End of LLDPDU
Marks the end of the TLV sequence in the LLDPDU.
Port Description
Specifies the port description of the sending port.
Optional.
System Name
Specifies the assigned name of the sending device.
System Description
Specifies the description of the sending device.
System Capabilities
Identifies the primary functions of the sending device and the enabled primary functions.
Management Address
Specifies the management address, and the interface number and object identifier (OID) associated with the address.
2.      IEEE 802.1 organizationally specific TLVs
Table 4 IEEE 802.1 organizationally specific TLVs
Port VLAN ID
Specifies the port’s VLAN identifier (PVID). An LLDPDU carries only one TLV of this type.
Port And Protocol VLAN ID
Indicates whether the device supports protocol VLANs and, if so, what VLAN IDs these protocols will be associated with. An LLDPDU can carry multiple different TLVs of this type.
VLAN Name
Specifies the textual name of any VLAN to which the port belongs. An LLDPDU can carry multiple different TLVs of this type.
Protocol Identity
Indicates protocols supported on the port. An LLDPDU can carry multiple different TLVs of this type.
DCBX
Data center bridging exchange protocol.
·       H3C devices support only receiving protocol identity TLVs.
·       Layer 3 Ethernet ports do not support IEEE 802.1 organizationally specific TLVs.
3.      IEEE 802.3 organizationally specific TLVs
Table 5 IEEE 802.3 organizationally specific TLVs
MAC/PHY Configuration/Status
Contains the bit-rate and duplex capabilities of the sending port, support for autonegotiation, enabling status of autonegotiation, and the current rate and duplex mode.
Power Via MDI
Contains the power supply capability of the port, including the PoE type (PSE or PD), PoE mode, whether PSE power supply is supported, whether PSE power supply is enabled, and whether the PoE mode is controllable.
Link Aggregation
Indicates the aggregation capability of the port (whether the link is capable of being aggregated), and the aggregation status (whether the link is in an aggregation).
Maximum Frame Size
Indicates the supported maximum frame size. It is now the MTU of the port.
Power Stateful Control
Indicates the power state control configured on the sending port, including the power type of the PSE/PD, PoE sourcing/receiving priority, and PoE sourcing/receiving power.
·       The Power Stateful Control TLV is defined in IEEE P802.3at D1.0 and is not supported in later versions. The device sends this type of TLVs only after receiving them.
·       The switch cannot send MAC/PHY Configuration/Status TLVs but can receive them.
LLDP-MED TLVs
LLDP-MED TLVs provide multiple advanced applications for voice over IP (VoIP), such as basic configuration, network policy configuration, and address and directory management. LLDP-MED TLVs provide a cost-effective and easy-to-use solution for deploying voice devices in Ethernet. LLDP-MED TLVs are shown in Table 6.
Table 6 LLDP-MED TLVs
LLDP-MED Capabilities
Allows a network device to advertise the LLDP-MED TLVs that it supports.
Network Policy
Allows a network device or terminal device to advertise the VLAN ID of the specific port, the VLAN type, and the Layer 2 and Layer 3 priorities for specific applications.
Extended Power-via-MDI
Allows a network device or terminal device to advertise power supply capability. This TLV is an extension of the Power Via MDI TLV.
Hardware Revision
Allows a terminal device to advertise its hardware version.
Firmware Revision
Allows a terminal device to advertise its firmware version.
Software Revision
Allows a terminal device to advertise its software version.
Serial Number
Allows a terminal device to advertise its serial number.
Manufacturer Name
Allows a terminal device to advertise its vendor name.
Model Name
Allows a terminal device to advertise its model name.
Asset ID
Allows a terminal device to advertise its asset ID. The typical case is that the user specifies the asset ID for the endpoint to facilitate directory management and asset tracking.
Location Identification
Allows a network device to advertise the appropriate location identifier information for a terminal device to use in the context of location-based applications.
If the MAC/PHY configuration/status TLV is not advertisable, none of the LLDP-MED TLVs will be advertised even if they are advertisable. If the LLDP-MED capabilities TLV is not advertisable, the other LLDP-MED TLVs will not be advertised even if they are advertisable.
Management address
The network management system uses the management address of a device to identify and manage the device for topology maintenance and network management. The management address is encapsulated in the management address TLV.
Work mechanism
LLDP operating modes
LLDP can operate in one of the following modes:
·           TxRx mode—A port in this mode can send and receive LLDPDUs.
·           Tx mode—A port in this mode can only send LLDPDUs.
·           Rx mode—A port in this mode can only receive LLDPDUs.
·           Disable mode—A port in this mode cannot send or receive LLDPDUs.
Each time the LLDP operating mode of a port changes, its LLDP protocol state machine re-initializes. A configurable re-initialization delay prevents frequent initializations because of frequent changes to the operating mode. With this delay configured, before a port can initialize LLDP, it must wait for the specified interval after the LLDP operating mode changes.
Transmitting LLDPDUs
An LLDP-enabled port operating in TxRx mode or Tx mode sends LLDPDUs to its directly connected devices both periodically and when the local configuration changes. To prevent LLDPDUs from overwhelming the network during times of frequent changes to local device information, you can set a delay between two successive LLDPDUs.
This interval is shortened to 1 second in either of the following cases:
·           A new neighbor is discovered. A new LLDPDU is received and carries device information new to the local device.
·           The LLDP operating mode of the port changes from Disable or Rx to TxRx or Tx.
This is the fast sending mechanism of LLDP. With this mechanism, a specific number of LLDPDUs are sent successively at 1-second intervals to help LLDP neighbors discover the local device as soon as possible. Then, the normal LLDPDU transmit interval resumes.
Receiving LLDPDUs
An LLDP-enabled port that is operating in TxRx mode or Rx mode checks the validity of TLVs carried in every received LLDPDU. If valid, the information is saved and an aging timer is set for it based on the TTL value in the TTL TLV carried in the LLDPDU. If the TTL value is zero, the information ages out immediately.
Protocols and standards
·           IEEE 802.1AB-2005, Station and Media Access Control Connectivity Discovery
·           ANSI/TIA-1057, Link Layer Discovery Protocol for Media Endpoint Devices
·           DCB Capability Exchange Protocol Specification Rev 1.00
·           DCB Capability Exchange Protocol Base Specification Rev 1.01
LLDP configuration task list
Tasks at a glance
Performing basic LLDP configuration:
·       (Required.) Enabling LLDP
·       (Optional.) Setting the LLDP operating mode
·       (Optional.) Setting the LLDP re-initialization delay
·       (Optional.) Enabling LLDP polling
·       (Optional.) Configuring the advertisable TLVs
·       (Optional.) Configuring the management address and its encoding format
·       (Optional.) Setting other LLDP parameters
·       (Optional.) Setting an encapsulation format for LLDPDUs
(Optional.) Configuring CDP compatibility
(Optional.) Configuring LLDP trapping and LLDP-MED trapping
Enabling LLDP
To make LLDP take effect on specific ports, you must enable LLDP both globally and on these ports.
To enable LLDP:
Step
Remarks
1.     Enter system view.
N/A
2.     Enable LLDP globally.
lldp global enable
By default, LLDP is globally disabled.
3.     Enter Layer 2 or Layer 3 Ethernet interface view.
N/A
4.     (Optional.) Enable LLDP.
lldp enable
By default, LLDP is enabled on a port.
To set the LLDP operating mode:
Step
Remarks
N/A
2.     Enter Layer 2 or Layer 3 Ethernet interface view.
N/A
3.     Set the LLDP operating mode.
lldp admin-status { disable | rx | tx | txrx }
The default setting is txrx.
When LLDP operating mode changes on a port, the port initializes the protocol state machines after a certain delay. By adjusting the LLDP re-initialization delay, you can avoid frequent initializations caused by frequent changes to the LLDP operating mode on a port.
To set the LLDP re-initialization delay for ports:
Step
Remarks
N/A
2.     Set the LLDP re-initialization delay.
lldp timer reinit-delay delay
The default setting is 2 seconds.
With LLDP polling enabled, a device periodically searches for local configuration changes. When the device detects a configuration change, it sends LLDPDUs to inform neighboring devices of the change.
To enable LLDP polling:
Step
Remarks
N/A
N/A
3.     Enable LLDP polling and set the polling interval.
lldp check-change-interval interval
By default, LLDP polling is disabled.
Step
Remarks
N/A
N/A
3.     Configure the advertisable TLVs (Layer 2 Ethernet interface view).
lldp tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | network-policy | power-over-ethernet } }
By default, all types of LLDP TLVs except the location identification TLV are advertisable on a Layer 2 Ethernet port.
4.     Configure the advertisable TLVs (Layer 3 Ethernet interface view).
lldp tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } | power-over-ethernet } }
By default, all types of LLDP TLVs except the IEEE 802.1 organizationally specific TLVs, network policy TLVs, and location identification TLVs are advertisable on a Layer 3 Ethernet port.
LLDP encodes management addresses in numeric or string format in management address TLVs.
By default, management addresses are encoded in numeric format. If a neighbor encodes its management address in character string format, you must configure the encoding format of the management address as string on the connecting port to guarantee normal communication with the neighbor.
To configure a management address to be advertised and its encoding format on a port:
Step
Remarks
N/A
N/A
3.     Allow LLDP to advertise the management address in LLDPDUs and configure the advertised management address.
lldp tlv-enable basic-tlv management-address-tlv [ ip-address ]
By default, the management address is sent through LLDPDUs.
·       For a Layer 2 Ethernet port, the management address is the main IP address of the VLAN interface that is in up state and whose corresponding VLAN ID is the lowest among the VLANs permitted on the port. If none of the VLAN interfaces of the permitted VLANs is assigned an IP address or all VLAN interfaces are down, no management address will be advertised.
·       For a Layer 3 Ethernet port, the management address is its own IP address. If no IP address is configured for the Layer 3 Ethernet port, no management address will be advertised.
4.     Configure the encoding format of the management address as character string.
lldp management-address-format string
By default, the management address is encapsulated in the numeric format.
The TTL TLV carried in an LLDPDU determines how long the device information carried in the LLDPDU can be saved on a recipient device.
By setting the TTL multiplier, you can configure the TTL of locally sent LLDPDUs, which determines how long information about the local device can be saved on a neighboring device. The TTL is expressed by using the following formula:
TTL = Min (65535, (TTL multiplier × LLDPDU transmit interval))
As the expression shows, the TTL can be up to 65535 seconds. TTLs greater than 65535 will be rounded down to 65535 seconds.
Follow these guidelines when you change LLDP parameters:
·           To make sure that LLDP neighbors can receive LLDPDUs to update information about the current device before it ages out, configure the LLDPDU transmit delay to be less than the TTL.
·           Set the LLDPDU transmit interval to be no less than four times the LLDPDU transmit delay.
·           If the LLDPDU transmit delay is greater than the LLDPDU transmit interval, the device uses the LLDPDU transmit delay as the transmit interval.
To change LLDP parameters:
Step
Remarks
N/A
2.     Set the TTL multiplier.
lldp hold-multiplier value
The default setting is 4.
3.     Set the LLDPDU transmit interval.
The default setting is 30 seconds.
4.     Set the LLDPDU transmit delay.
lldp timer tx-delay delay
5.     Set the number of LLDPDUs sent each time fast LLDPDU transmission is triggered.
lldp fast-count count
The default setting is 3.
LLDPDUs can be encapsulated in the following formats: Ethernet II or SNAP frames.
·           With Ethernet II encapsulation configured, an LLDP port sends LLDPDUs in Ethernet II frames.
·           With SNAP encapsulation configured, an LLDP port sends LLDPDUs in SNAP frames.
To set the encapsulation format for LLDPDUs to SNAP:
Step
Remarks
N/A
N/A
3.     Set the encapsulation format for LLDPDUs to SNAP.
lldp encapsulation snap
By default, Ethernet II encapsulation format applies.
LLDP of earlier versions requires the same encapsulation format on both ends to process LLDPDUs. For this reason, to communicate stably with a neighboring device running LLDP of earlier versions, the local device should be configured with the same encapsulation format.
To make your device work with Cisco IP phones, you must enable CDP compatibility.
If your LLDP-enabled device cannot recognize CDP packets, it does not respond to the requests of Cisco IP phones for the voice VLAN ID configured on the device. As a result, a requesting Cisco IP phone sends voice traffic without any tag to your device, and your device cannot differentiate the voice traffic from other types of traffic.
With CDP compatibility enabled, your device can receive and recognize CDP packets from a Cisco IP phone and respond with CDP packets, which carry TLVs with the voice VLAN configuration. According to TLVs with the voice VLAN configuration, the IP phone automatically configures the voice VLAN. As a result, the voice traffic is confined in the configured voice VLAN and is differentiated from other types of traffic.
The switch does not support the voice VLAN function. Therefore, after configured with CDP compatibility, the switch can establish a neighbor relationship with Cisco devices, but it cannot exchange voice VLAN information with them.
Configuration prerequisites
Before you configure CDP compatibility, complete the following tasks:
·           Globally enable LLDP.
·           Enable LLDP on the port connecting to an IP phone, and configure the port to operate in TxRx mode.
CDP-compatible LLDP operates in one of the following modes:
·           TxRx—CDP packets can be transmitted and received.
·           Disable—CDP packets cannot be transmitted or received.
LLDP traps are sent periodically, and the interval is configurable. To make CDP-compatible LLDP take effect on specific ports, first enable CDP-compatible LLDP globally, and then configure CDP-compatible LLDP to operate in TxRx mode.
The maximum TTL value that CDP allows is 255 seconds. To make CDP-compatible LLDP work properly with Cisco IP phones, configure the LLDPDU transmit interval to be no more than 1/3 of the TTL value.
To enable LLDP to be compatible with CDP:
Step
Remarks
N/A
2.     Enable CDP compatibility globally.
lldp compliance cdp
By default, CDP compatibility is disabled globally.
N/A
4.     Configure CDP-compatible LLDP to operate in TxRx mode.
lldp compliance admin-status cdp txrx
By default, CDP-compatible LLDP operates in Disable mode.
LLDP trapping or LLDP-MED trapping notifies the network management system of events such as newly detected neighboring devices and link malfunctions.
To prevent excessive LLDP traps from being sent when the topology is unstable, set a trap transmit interval for LLDP.
To configure LLDP trapping and LLDP-MED trapping:
Step
Remarks
N/A
N/A
3.     Enable LLDP trapping.
lldp notification remote-change enable
By default, LLDP trapping is disabled.
4.     Enable LLDP-MED trapping.
lldp notification med-topology-change enable
By default, LLDP-MED trapping is disabled.
5.     Return to system view.
N/A
6.     (Optional.) Set the LLDP trap transmit interval.
The default setting is 5 seconds.
Displaying and maintaining LLDP
Display the global LLDP information or the information contained in the LLDP TLVs to be sent through a port.
Display the information contained in the LLDP TLVs sent from neighboring devices.
display lldp neighbor-information [ interface interface-type interface-number [ verbose ] | list [ system-name system-name ] | verbose ]
Display LLDP statistics.
display lldp statistics [ global | interface interface-type interface-number ]
Display LLDP status of a port.
display lldp status [ interface interface-type interface-number ]
Display types of advertisable optional LLDP TLVs.
display lldp tlv-config [ interface interface-type interface-number ]
Basic LLDP configuration example
By default, Ethernet, VLAN, and aggregate interfaces are down. To configure such an interface, bring the interface up by executing the undo shutdown command.
Network requirements
As shown in Figure 5, the NMS and Switch A are located in the same Ethernet network. An MED device and Switch B are connected to GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2 of Switch A.
Enable LLDP globally on Switch A and Switch B to monitor the link between Switch A and Switch B and the link between Switch A and the MED device on the NMS.
Figure 5 Network diagram
Configuration procedure
1.      Configure Switch A:
# Enable LLDP globally.
[SwitchA] lldp global enable
# Enable LLDP on GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2. (You can skip this step because LLDP is enabled on ports by default.) Set the LLDP operating mode to Rx.
[SwitchA] interface GigabitEthernet 4/0/1
[SwitchA-GigabitEthernet4/0/1] lldp enable
[SwitchA-GigabitEthernet4/0/1] lldp admin-status rx
[SwitchA-GigabitEthernet4/0/1] quit
[SwitchA] interface GigabitEthernet 4/0/2
[SwitchA-GigabitEthernet4/0/2] lldp enable
[SwitchA-GigabitEthernet4/0/2] lldp admin-status rx
[SwitchA-GigabitEthernet4/0/2] quit
2.      Configure Switch B:
[SwitchB] lldp global enable
# Enable LLDP on GigabitEthernet 4/0/1. (You can skip this step because LLDP is enabled on ports by default.) Set the LLDP operating mode to Tx.
[SwitchB] interface GigabitEthernet 4/0/1
[SwitchB-GigabitEthernet4/0/1] lldp enable
[SwitchB-GigabitEthernet4/0/1] lldp admin-status tx
[SwitchB-GigabitEthernet4/0/1] quit
3.      Verify the configuration:
# Display the global LLDP status and port LLDP status on Switch A.
[SwitchA] display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 2
Transmit interval              : 30s
Hold multiplier                : 4
Reinit delay                   : 2s
Transmit delay                 : 2s
Trap interval                  : 5s
Fast start times               : 3
LLDP status information of Port 1 [GigabitEthernet4/0/1]:
Port status of LLDP            : Enable
Admin status                   : RX_Only
Trap flag                      : No
MED trap flag                  : No
Polling interval               : 0s
Number of LLDP neighbors       : 1
Number of MED neighbors        : 1
Number of CDP neighbors        : 0
Number of sent optional TLV    : 0
Number of received unknown TLV : 0
LLDP status information of Port 2 [GigabitEthernet4/0/2]:
Trap flag                      : No
MED trap flag                  : No
Number of MED neighbors        : 0
Number of received unknown TLV : 3
The sample output shows that:
?  GigabitEthernet 4/0/1 of Switch A connects to an MED device.
?  GigabitEthernet 4/0/2 of Switch A connects to a non-MED device.
?  Both ports operate in Rx mode, and they can receive LLDPDUs but cannot send LLDPDUs.
# Remove the link between Switch A and Switch B, and then display the global LLDP status and port LLDP status on Switch A.
The current number of LLDP neighbors: 1
LLDP neighbor information last changed time: 0 days, 0 hours, 5 minutes, 20 seconds
Hold multiplier                : 4
Reinit delay                   : 2s
Transmit delay                 : 2s
Trap interval                  : 5s
Trap flag                      : No
MED trap flag                  : No
Trap flag                      : No
MED trap flag                  : No
Number of LLDP neighbors       : 0
The sample output shows that GigabitEthernet 4/0/2 of Switch A does not connect to any neighboring devices.
