04-Layer 2 - LAN Switching Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guide-Release7128-6W71004-Layer 2 - LAN Switching Configuration Guide
08-VLAN mapping configuration
08-VLAN mapping configuration 172.38 KB
Configuring VLAN mapping
Overview
VLAN mapping, also known as "VLAN translation," re-marks VLAN tagged packets with new VLAN IDs and enables translation between CVLANs and SVLANs. H3C provides one-to-two VLAN mapping, which tags single-tagged packets with an outer VLAN tag.
Application scenario of one-to-two VLAN mapping
Figure 1 shows a typical application scenario of one-to-two VLAN mapping. In the application scenario, remote sites of VPN A, Site 1 and Site 2, must communicate across the SP network. Site 1 and Site 2 are both in VLAN 5. The SP network assigns VLAN 100 to VPN A.
Figure 1 Application scenario of one-to-two VLAN mapping
When Site 1 sends a packet to Site 2 and the packet tagged with VLAN 5 arrives at the edge of the SP network, PE 1 tags the packet with outer VLAN 100 by using one-to-two VLAN mapping. One-to-two VLAN mapping allows the network administrators to plan their own VLAN IDs without conflicting with the VLAN assignments in the SP networks, allows the SP network to use a single SVLAN to serve customers who have multiple CVLANs, and releases the stress on the SVLAN resource.
To enable the users of Site 1 to communicate with users of Site 2, PE2 removes the outer VLAN tag of the packet and forwards the packet to Site 2 through VLAN 5.
A packet from Site 2 to Site 1 is handled in a similar way.
You can use QinQ to implement one-to-two VLAN mapping. For information about how to implement one-to-two VLAN mapping through QinQ, see "Configuring QinQ."
Concepts and terms
Figure 2 shows a simplified network to help explain the concepts and terms that you may encounter when working with VLAN mapping:
Figure 2 Basic concepts of VLAN mapping
·           Uplink traffic—Traffic transmitted from the customer network to the service provider network.
·           Downlink traffic—Traffic transmitted from the service provider network to the customer network.
·           Network-side port—A port connected to or closer to the service provider network.
·           Customer-side port—A port connected to or closer to the customer network.
·           Uplink policy—A QoS policy that defines VLAN mapping rules for uplink traffic.
·           Downlink policy—A QoS policy that defines VLAN mapping rules for downlink traffic.
·           Customer VLANs—CVLANs are VLANs assigned to customers.
·           Service provider VLANs—SVLANs are VLANs assigned for transmitting traffic across the service provider network.
For more information about QoS policies, see ACL and QoS Configuration Guide.
One-to-two VLAN mapping implementation
Implement one-to-two VLAN mapping through the following configurations, as shown in Figure 3:
·           Apply an uplink policy to the incoming traffic on the customer-side port to tag the incoming packets from a certain CVLAN with an SVLAN tag. For more information about QoS policies, see ACL and QoS Configuration Guide.
·           Configure the customer-side port as a hybrid port, and assign the port to SVLANs as an untagged member. When the port forwards the packets from these SVLANs, it removes their SVLAN tags.
Figure 3 One-to-two VLAN mapping implementation
Configuring one-to-two VLAN mapping
Perform these tasks to configure one-to-two VLAN mapping:
Tasks at a glance
Configuring an uplink policy
Configuring the customer-side port
Configuring the network-side port
You can configure an uplink policy to add an SVLAN tag to CVLAN-tagged packets.
To configure an uplink policy:
Step
Remarks
1.     Enter system view.
N/A
2.     Configure a class for a CVLAN.
a.   Create a class and enter class view:
traffic classifier tcl-name [ operator { and | or } ]
b.   Configure CVLAN match criteria:
if-match customer-vlan-id { vlan-list | vlan-id1 to vlan-id2 }
c.    Return to system view:
N/A
3.     Configure one behavior for an SVLAN.
a.   Create a traffic behavior and enter traffic behavior view:
b.   Add a VLAN tag nesting action to add an SVLAN tag to the incoming packets from the CVLAN:
nest top-most vlan vlan-id
Repeat this step to configure one behavior for each SVLAN.
4.     Create a QoS policy and enter QoS policy view.
qos policy policy-name
N/A
5.     Associate the class with the behavior.
classifier tcl-name behavior behavior-name
Repeat this step to create class-behavior associations for other CVLANs.
Step
Remarks
N/A
2.     Enter Ethernet interface view.
N/A
3.     Configure the port as a hybrid port.
port link-type hybrid
The default link type of an Ethernet port is access.
4.     Assign the port to the SVLANs as an untagged member.
port hybrid vlan vlan-list untagged
By default, a hybrid port is an untagged member of VLAN 1.
5.     Apply the uplink policy to the incoming traffic.
N/A
Step
Remarks
N/A
N/A
3.     (Optional.) Configure the link type of the port.
·       Configure the port as a trunk port:
port link-type
trunk
·       Configure the port as a hybrid port:
4.     (Optional.) Assign the port to all SVLANs.
·       As a trunk port:
port trunk permit vlan
{ vlan-list | all }
·       As a hybrid port:
port hybrid
vlan vlan-list tagged
By default:
·       A trunk port is assigned to only VLAN 1.
·       A hybrid port is an untagged member of VLAN 1.
Displaying and maintaining VLAN mapping
Execute the display command in any view.
Display VLAN mapping information (in standalone mode).
display vlan translation [ interface interface-type interface-number | slot slot-number ]
Display VLAN mapping information (in IRF mode).
display vlan translation [ interface interface-type interface-number | chassis chassis-number slot slot-number ]
One-to-two VLAN mapping configuration example
IMPORTANT
IMPORTANT:
By default, Ethernet interfaces, VLAN-interfaces, and aggregate interfaces are down. To configure these interfaces, first bring up these interfaces by using the undo shutdown command.
Network requirements
As shown in Figure 4, two VPN A branches, Site 1 and Site 2, are in VLAN 10. The two sites use VPN access services of a service provider. The service provider assigns VLAN 100 to Site 1 and Site 2.
Configure one-to-two VLAN mapping to enable the two branches to communicate across the SP network.
Figure 4 Network diagram
Configuration procedure
1.      Configure PE 1:
# Configure a class named test to match traffic tagged with CVLAN 10.
<PE1> system-view
[PE1] traffic classifier test
[PE1-classifier-test] if-match customer-vlan-id 10
[PE1-classifier-test] quit
# Configure a behavior named test to tag traffic with SVLAN tag 100.
[PE1] traffic behavior test
[PE1-behavior-test] nest top-most vlan 100
[PE1-behavior-test] quit
# Create a QoS policy named test, and associate class test with behavior test in the QoS policy.
[PE1] qos policy test
[PE1-qospolicy-test] classifier test behavior test
[PE1-qospolicy-test] quit
# Configure customer-side port GigabitEthernet 4/0/1 as a hybrid port, and assign it to VLAN 100 as an untagged member.
[PE1] interface GigabitEthernet 4/0/1
[PE1-GigabitEthernet4/0/1] port link-type hybrid
[PE1-GigabitEthernet4/0/1] port hybrid vlan 100 untagged
# Apply uplink policy test to the incoming traffic of customer-side port GigabitEthernet 4/0/1.
[PE1-GigabitEthernet4/0/1] qos apply policy test inbound
[PE1-GigabitEthernet4/0/1] quit
# Configure network-side port GigabitEthernet 4/0/2 as a trunk port, and assign it to VLAN 100.
[PE1] interface GigabitEthernet 4/0/2
[PE1-GigabitEthernet4/0/2] port link-type trunk
[PE1-GigabitEthernet4/0/2] port trunk permit vlan 100
[PE1-GigabitEthernet4/0/2] quit
2.      Configure PE 2 in the same way as you configure PE 1. (Details not shown.)
# Display the VLAN mapping information on PE1.
Interface GigabitEthernet4/0/1:
 [Record 1]
     Action         : Nest
     Dot1p          : Inner
     Outer VLAN     : 1
     Inner VLAN     : 1 to 9, 11 to 4094
 [Record 2]
     Action         : Nest
     Dot1p          : Inner
     Outer VLAN     : 100
     Inner VLAN     : 10
The output shows that the customer-side port GigabitEthernet 4/0/1 of PE1 adds outer VLAN tag 100 to packets carrying inner VLAN tag 10. The VLAN mapping information on PE2 is the same as PE1.
VLAN one-to-two mapping, 2
configuring
VLAN mapping, 1
VLAN one-to-two mapping, 3, 4
VLAN one-to-two mapping customer-side port, 3
VLAN one-to-two mapping network-side port, 4
VLAN one-to-two mapping uplink policy, 3
customer-side port configuration, 3
CVLAN
VLAN mapping concepts and terms, 1
VLAN mapping configuration, 1
VLAN mapping one-to-two application scenario, 1
VLAN one-to-two mapping configuration, 3, 4
VLAN one-to-two mapping customer-side port configuration, 3
VLAN one-to-two mapping implementation, 2
VLAN one-to-two mapping network-side port configuration, 4
VLAN one-to-two mapping uplink policy configuration, 3
displaying VLAN mapping, 4
implementing VLAN one-to-two mapping, 2
network
network management
application scenario, 1, 2
configuration, 3, 4
packet
port
customer-side configuration, 3
network-side configuration, 4
procedure
configuring VLAN one-to-two mapping, 3, 4
configuring VLAN one-to-two mapping customer-side port, 3
configuring VLAN one-to-two mapping network-side port, 4
configuring VLAN one-to-two mapping uplink policy, 3
SVLAN
tag
VLAN mapping
configuration, 1
displaying, 4
one-to-two configuration, 3, 4
one-to-two customer-side port configuration, 3
one-to-two implementation, 2
one-to-two network-side port configuration, 4
one-to-two uplink policy configuration, 3
configuration, 3, 4
VLAN translation. See VLAN mapping
