08-MPLS Command Reference
HomeSupportSwitchesS12500 SeriesReference GuidesCommand ReferencesH3C S12500 Command Reference-Release7128-6W71008-MPLS Command Reference
06-MPLS OAM commands
06-MPLS OAM commands 62.58 KB
MPLS OAM commands
ping mpls ipv4
Use ping mpls ipv4 to test MPLS LSP connectivity for IPv4 prefixes.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * ipv4 dest-addr mask-length [ destination  destination-ip-addr-header ]
-a source-ip: Specifies the source address for the MPLS echo request packets to be sent. If you do not specify this option, the primary IP address of the outgoing interface is the source address of the MPLS echo requests.
-c count: Specifies the number of MPLS echo request packets to be sent. The value range is 1 to 4294967295, and the default is 5.
-exp exp-value: Specifies the EXP value for echo request packets. The value range is 0 to 7, and the default is 0.
-h ttl-value: Specifies the TTL value for MPLS echo request packets. The value range is 1 to 255, and the default is 255.
-m wait-time: Specifies the interval for sending MPLS echo request packets. The value range is 1 to 10000 milliseconds, and the default is 200 milliseconds.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 1 or 2, where 1 means "Do not reply" and 2 means "Reply by using a UDP packet." The default is 2.
-s packet-size: Specifies the length (excluding the IP header and UDP header) of the MPLS echo request packets. The value for the packet-size argument is 65 to 8100 bytes, and the default is 100 bytes.
-t time-out: Specifies the timeout interval for the reply to an MPLS echo request. The value range is 0 to 65535 milliseconds, and the default is 2000 milliseconds.
-v: Displays detailed reply information. If you do not specify this keyword, the command displays brief reply information.
ipv4 dest-addr mask-length: Specifies an FEC by an IPv4 destination address and the mask length. The value range for the mask-length argument is 0 to 32.
destination destination-ip-addr-header: Specifies the destination address in the IP header of an MPLS echo request. The destination address must be an address on subnet 127.0.0.0/8—any local loopback address. The default destination address is 127.0.0.1.
# Test LSP connectivity to destination 3.3.3.9/32.
<Sysname> ping mpls ipv4 3.3.3.9 32
MPLS Ping FEC: 3.3.3.9/32 : 100 data bytes
100 bytes from 100.1.2.1: Sequence=1 time=49 ms
100 bytes from 100.1.2.1: Sequence=2 time=44 ms
100 bytes from 100.1.2.1: Sequence=3 time=60 ms
100 bytes from 100.1.2.1: Sequence=4 time=60 ms
100 bytes from 100.1.2.1: Sequence=5 time=76 ms
--- FEC: 3.3.3.9/32 ping statistics ---
round-trip min/avg/max = 44/57/76 ms
<Sysname> ping mpls -v ipv4 3.3.3.9 32
100 bytes from 100.1.2.1: Sequence=1 time=49 ms ReturnCode 3(1)
100 bytes from 100.1.2.1: Sequence=2 time=44 ms ReturnCode 3(1)
100 bytes from 100.1.2.1: Sequence=3 time=60 ms ReturnCode 3(1)
100 bytes from 100.1.2.1: Sequence=4 time=60 ms ReturnCode 3(1)
100 bytes from 100.1.2.1: Sequence=5 time=76 ms ReturnCode 3(1)
Tests connectivity of the LSP for FEC 3.3.3.9/32 by sending 100-byte MPLS echo requests.
Received a 100-byte reply from 100.1.2.1.
Sequence
Sequence number of the reply, for determination of packet loss, disorder, or duplicate.
time
Packet round-trip delay.
ReturnCode
Return code. The number in parentheses represents a sub return-code.
LSP inspection statistics.
Number of MPLS echo requests transmitted.
5 packets received
Number of MPLS echo replies received.
0.0% packet loss
Percentage of the unreplied packets to the total request packets.
Minimum, average, and maximum round-trip delay.
tracert mpls ipv4
tracert mpls ipv4
Use tracert mpls ipv4 to trace MPLS LSPs (from the ingress node to the egress node) for IPv4 prefixes.
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -t time-out ] * ipv4 dest-addr mask-length [ destination destination-ip-addr-header ]
-h ttl-value: Specifies the maximum TTL value for MPLS echo request packets, namely, the maximum number of hops to be inspected. The value range for the ttl-value argument is 1 to 255, and the default is 30.
# Trace the path that the LSP (for FEC 3.3.3.9/32) traverses from the ingress node to the egress node.
<Sysname> tracert mpls ipv4 3.3.3.9 32
MPLS Trace Route FEC: 3.3.3.9/32
  TTL   Replier            Time    Type      Downstream
  0                                Ingress   10.4.5.1/[1025]
  1     10.4.5.1           1 ms    Transit   100.3.4.1/[1024]
  2     100.1.4.2          63 ms   Transit   100.1.2.1/[3]
  3     100.1.2.1          129 ms  Egress
Table 2 Output description
TTL
Number of hops.
Replier
Address of the LSR that replied the request.
Time
Time used to receive the reply, in milliseconds.
LSR type: ingress, transit, or egress.
Downstream
Address of the downstream LSR and the label assigned by the downstream LSR.
ping mpls ipv4
